@228df42
11/07/12 13:10:56 |
Sebastian Huber |
sapi: Add BSP_INITIAL_EXTENSION to confdefs.h
A BSP can supply an …
4.115
@466cf31d
11/07/12 12:59:19 |
Sebastian Huber |
score: Statically initialize user extensions
The initial extensions …
4.115
@9ed2bef
11/07/12 09:54:49 |
Sebastian Huber |
score: Add and use RTEMS_ARRAY_SIZE()
4.115
@2195fd27
11/07/12 10:23:03 |
Sebastian Huber |
sapi: Make initial user extensions table read-only
4.115
@b596754
11/07/12 09:19:46 |
Sebastian Huber |
sapi: Fix user scheduler configuration
The comment in confdefs.h …
4.115
@ae4f125e
11/06/12 12:54:05 |
Sebastian Huber |
sapi: Make Configuration read-only
The Configuration is now read-only …
4.115
@ef5f359
11/06/12 11:18:10 |
Sebastian Huber |
sapi: Delete duplicate declarations
4.115
@e39fa07
11/06/12 11:13:29 |
Sebastian Huber |
sapi: Delete unused macros
Delete rtems_configuration_get_table(), …
4.115
@c53b330c
11/06/12 10:34:10 |
Sebastian Huber |
sapi: Use rtems_configuration_get_maximum_drivers
4.115
@47a3cd8
08/09/12 14:48:00 |
Sebastian Huber |
score: Work area initialization API change
The work areas (RTEMS work …
4.115
@fd71610
10/11/12 16:25:03 |
Ralf Corsepius |
Cleanup Krzysztof's copyright notices.
4.115
@a6eaa548
08/29/12 12:38:54 |
Krzysztof Miesowicz |
timespec helpers: Add wrappers with new test
4.115
@50fc8f6
06/13/12 07:44:32 |
Sebastian Huber |
sapi: Add nanoseconds_per_tick to configuration
Add …
4.115
@39ee704e
05/31/12 08:27:29 |
Sebastian Huber |
libblock: Add read-ahead task
Read-ahead requests were previously …
4.115
@b6911069
05/29/12 16:02:52 |
Sebastian Huber |
libblock: Add task stack size bdbuf configuration
The task stack size …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@5a4bb75
04/26/12 12:28:52 |
Sebastian Huber |
Filesystem: Remove per file descriptor semaphore
The per file …
4.115
@5c51ba1
04/16/12 08:38:31 |
Sebastian Huber |
rbheap: API changes and documentation
4.115
@8c6608bd
04/13/12 07:10:12 |
Sebastian Huber |
rbtree: PR2046: Replace rtems_rbtree_unique
4.115
@5eb434e
04/11/12 13:04:22 |
Sebastian Huber |
score: New macros and functions
New macros
o …
4.115
@e752630
04/10/12 09:19:39 |
Sebastian Huber |
rbheap: New files
In the Red-Black Tree Heap the administration data …
4.115
@e53aae2
03/26/12 20:42:38 |
Gedare Bloom |
confdefs: Add declaration for unlimited objects.
Adds to confdefs a …
4.115
@3b7c123
03/13/12 10:33:51 |
Sebastian Huber |
Filesystem: Reference counting for locations
o A new data structure …
4.115
@5693f2e
02/22/12 08:58:59 |
Ralf Corsepius |
2012-02-22 Ralf Corsépius <ralf.corsepius@…>
4.115
@9fa3cf0d
12/14/11 13:17:19 |
Sebastian Huber |
2011-12-14 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@3df4d74
12/13/11 14:37:03 |
Sebastian Huber |
2011-12-13 Sebastian Huber <sebastian.huber@…>
4.115
@517bf08
12/13/11 10:52:21 |
Sebastian Huber |
4.115
@b929b39e
12/05/11 13:51:06 |
Ralf Corsepius |
2011-12-05 Ralf Corsépius <ralf.corsepius@…>
4.115
@84e1742
11/18/11 20:04:49 |
Jennifer.Averett |
2011-11-18 Jennifer Averett <Jennifer.Averett@…>
4.115
@b4f635e
11/10/11 14:40:13 |
Sebastian Huber |
2011-11-10 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@48943dc
10/10/11 07:11:26 |
Ralf Corsepius |
2011-10-10 Ralf Corsépius <ralf.corsepius@…>
4.115
@82db8e56
09/15/11 15:49:32 |
Joel Sherrill |
2011-09-15 Petr Benes <benesp16@…>
PR 1906/cpukit
4.115
@5472ad41
09/11/11 20:52:37 |
Joel Sherrill |
2011-09-11 Petr Benes <benesp16@…>
PR 1896/cpukit
4.115
@5817297
09/09/11 11:02:03 |
Sebastian Huber |
2011-09-09 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@ac9d2ecc
09/01/11 18:13:54 |
Joel Sherrill |
2011-09-01 Petr Benes <benesp16@…>
PR 1895/cpukit
4.115
@74f1c73e
08/21/11 20:07:11 |
Joel Sherrill |
2011-08-21 Petr Benes <benesp16@…>
PR 1886/cpukit
4.115
@542ae51
08/17/11 09:14:09 |
Sebastian Huber |
2011-08-17 Sebastian Huber <sebastian.huber@…>
4.115
@6de36ed
08/16/11 11:40:53 |
Sebastian Huber |
2011-08-16 Sebastian Huber <sebastian.huber@…>
4.115
@f58ef8ae
07/13/11 18:34:22 |
Joel Sherrill |
2011-07-13 Joel Sherrill <joel.sherrilL@…>
PR 1824/cpukit …
4.115
@21242c2
06/24/11 17:52:58 |
Joel Sherrill |
2011-06-24 Joel Sherrill <joel.sherrill@…>
4.115
@c1545f0
05/23/11 16:06:23 |
Joel Sherrill |
2011-05-23 Marta Rybczynska <marta.rybczynska@…>
PR …
4.115
@49f6309b
05/23/11 14:55:58 |
Joel Sherrill |
2011-05-23 Joel Sherrill <joel.sherrilL@…>
PR 1804/cpukit …
4.115
@ba7bc099
05/17/11 19:48:44 |
Joel Sherrill |
2011-05-17 Joel Sherrill <joel.sherrill@…>
PR 1789/cpukit …
4.115
@5af951f
05/13/11 13:49:16 |
Sebastian Huber |
2011-05-13 Sebastian Huber <sebastian.huber@…>
4.115
@e58f80cb
04/11/11 17:23:06 |
Joel Sherrill |
2011-04-11 Joel Sherrill <joel.sherrill@…>
4.115
@bd9baa81
04/04/11 18:44:16 |
Joel Sherrill |
2010-07-28 Gedare Bloom <giddyup44@…>
PR 1641/cpukit
4.115
@e79093a
04/04/11 16:40:00 |
Joel Sherrill |
2011-04-04 Joel Sherrill <joel.sherrilL@…>
PR 1773/cpukit …
4.115
@06dcaf0
03/16/11 20:05:06 |
Joel Sherrill |
2011-03-16 Jennifer Averett <jennifer.averett@…>
PR …
4.115
@0118ed6
03/16/11 16:32:22 |
Joel Sherrill |
PR …
4.115
@08d01a1
03/10/11 16:39:14 |
Sebastian Huber |
2011-03-10 Sebastian Huber <sebastian.huber@…>
4.115
@4c794c8
03/03/11 16:01:35 |
Joel Sherrill |
2011-03-03 Joel Sherrill <joel.sherrill@…>
4.115
@fd580d5
02/23/11 14:13:16 |
Ralf Corsepius |
2011-02-23 Ralf Corsépius <ralf.corsepius@…>
4.115
@22c28282
02/21/11 17:00:51 |
Joel Sherrill |
2011-02-21 Joel Sherrill <joel.sherrill@…>
4.115
@4be93c0
02/21/11 11:54:37 |
Sebastian Huber |
2011-02-21 Sebastian Huber <sebastian.huber@…>
4.115
@108c4b0
02/18/11 15:12:44 |
Joel Sherrill |
2011-02-18 Joel Sherrill <joel.sherrill@…>
4.115
@010192d
02/17/11 22:21:44 |
Joel Sherrill |
2011-02-17 Joel Sherrill <joel.sherrill@…>
4.115
@b2b56cb9
02/09/11 06:18:57 |
Ralf Corsepius |
2011-02-09 Ralf Corsépius <ralf.corsepius@…>
4.115
@5aecf664
12/17/10 14:56:06 |
Joel Sherrill |
2010-12-17 Joel Sherrill <joel.sherrill@…>
Jennifer …
4.115
@5c4e0c5
11/25/10 13:24:26 |
Sebastian Huber |
2010-11-25 Sebastian Huber <sebastian.huber@…>
4.115
@0faa9dad
11/24/10 15:51:28 |
Joel Sherrill |
2010-11-24 Gedare Bloom <giddyup44@…>
PR 1647/cpukit
4.115
@db5f134
11/16/10 19:14:10 |
Joel Sherrill |
2010-11-16 Joel Sherrill <joel.sherrill@…>
PR 1718/cpukit …
4.115
@69f2a07
08/24/10 14:29:55 |
Sebastian Huber |
2010-08-24 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@b3263f5
08/20/10 13:26:55 |
Ralf Corsepius |
2010-08-16 Ralf Corsépius <ralf.corsepius@…>
4.115
@58fa947
08/11/10 12:16:11 |
Sebastian Huber |
2010-09-11 Sebastian Huber <sebastian.huber@…>
4.115
@a46e6b6d
07/30/10 18:44:46 |
Joel Sherrill |
2010-07-30 Vinu Rajashekhar <vinutheraj@…>
4.115
@9bd0258d
07/26/10 22:20:43 |
Joel Sherrill |
2010-07-26 Joel Sherrill <joel.sherrill@…>
4.115
@80c1577
07/26/10 21:28:06 |
Joel Sherrill |
4.115
@39d3f8d
07/25/10 15:13:35 |
Joel Sherrill |
2010-07-25 Joel Sherrill <joel.sherrill@…>
4.115
@59673224
07/01/10 09:51:50 |
Sebastian Huber |
2010-07-01 Sebastian Huber <sebastian.huber@…>
4.115
@0de235f9
06/21/10 21:13:42 |
Joel Sherrill |
2010-06-21 Joel Sherrill <joel.sherrilL@…>
PR 1581/cpukit …
4.115
@46e69ff
06/20/10 19:41:33 |
Joel Sherrill |
2010-06-20 Joel Sherrill <joel.sherrill@…>
4.115
@659019e
06/19/10 23:39:56 |
Joel Sherrill |
2010-06-19 Joel Sherrill <joel.sherrilL@…>
4.115
@1a5f4bc7
06/18/10 04:04:05 |
Ralf Corsepius |
2010-06-18 Ralf Corsépius <ralf.corsepius@…>
4.115
@08c3066
06/18/10 03:03:22 |
Ralf Corsepius |
Remove RTEMS_ITRON_API conditional blocks.
4.115
@97e2fc3f
06/17/10 18:39:28 |
Joel Sherrill |
2010-06-17 Joel Sherrill <joel.sherrill@…>
4.115
@739329f
06/17/10 18:38:00 |
Joel Sherrill |
2010-06-17 Joel Sherrill <joel.sherrilL@…>
4.115
@f89c34bb
06/14/10 09:48:41 |
Sebastian Huber |
2010-06-14 Sebastian Huber <sebastian.huber@…>
4.115
@14fc3a77
06/09/10 09:38:10 |
Sebastian Huber |
2010-06-09 Sebastian Huber <sebastian.huber@…>
4.115
@241f4c96
06/08/10 10:25:46 |
Sebastian Huber |
2010-06-08 Sebastian Huber <sebastian.huber@…>
4.115
@7d01d244
06/07/10 15:35:24 |
Sebastian Huber |
2010-06-07 Sebastian Huber <sebastian.huber@…>
4.115
@46969df
06/03/10 06:46:51 |
Chris Johns |
2010-06-03 Chris Johns <chrisj@…>
4.104.115
@dfce6724
06/02/10 00:43:13 |
Chris Johns |
2010-06-01 Chris Johns <chrisj@…>
4.104.115
@29e92b0
05/31/10 13:56:37 |
Chris Johns |
2010-05-31 Chris Johns <chrisj@…>
4.104.115
@b2f216e1
05/03/10 09:13:36 |
Sebastian Huber |
2010-05-03 Sebastian Huber <sebastian.huber@…>
4.104.115
@7a09a7a
03/04/10 14:40:51 |
Joel Sherrill |
2010-03-04 Joel Sherrill <joel.sherrill@…>
4.104.115
@b7de5de
01/26/10 15:01:56 |
Thomas.Doerfler |
User extension API: add const to some params, inline …
4.104.115
@5ad790ff
11/30/09 13:20:29 |
Thomas.Doerfler |
Added defines for initialization of empty chains.
4.104.115
@28352fae
11/29/09 13:51:53 |
Ralf Corsepius |
Whitespace removal.
4.104.115
@35693ae2
10/21/09 16:06:50 |
strauman |
2009-10-21 Till Straumann <strauman@…>
4.104.115
@031b57c
10/09/09 13:46:39 |
Joel Sherrill |
2009-10-09 Sebastian Huber <Sebastian.Huber@…>
4.104.115
@456a776
10/05/09 15:00:53 |
Joel Sherrill |
2009-10-04 Sebastian Huber <Sebastian.Huber@…>
4.104.115
@c42d1a4
09/25/09 17:51:46 |
Joel Sherrill |
2009-09-25 Sebastian Huber <Sebastian.Huber@…>
4.104.115
@7bbedbe
08/26/09 12:18:42 |
Joel Sherrill |
2009-08-26 Sebastian Huber <Sebastian.Huber@…>
4.104.115
@93f7ea15
08/19/09 16:40:03 |
Joel Sherrill |
2009-08-19 Joel Sherrill <joel.sherrill@…>
4.104.115
@717391f5
08/12/09 20:53:33 |
Joel Sherrill |
2009-08-12 Joel Sherrill <joel.sherrill@…>
4.104.115
@2b558ffd
08/05/09 19:13:27 |
Joel Sherrill |
2009-08-05 Joel Sherrill <joel.sherrill@…>
4.104.115
@61ae99b
08/05/09 16:43:33 |
Joel Sherrill |
4.104.115
@ade17392
08/05/09 15:29:19 |
Joel Sherrill |
4.104.115
@0d15414e
08/05/09 00:00:54 |
Chris Johns |
009-08-05 Chris Johns <chrisj@…>
4.104.115
@8fed642
08/04/09 17:06:26 |
Joel Sherrill |
2009-08-04 Joel Sherrill <joel.sherrill@…>
4.104.115
