@f4d541cc
04/27/16 14:46:57 |
Sebastian Huber |
rtems: Avoid Giant lock in rtems_object_set_name()
Update #2555.
5
@f009ed0
04/27/16 14:36:04 |
Sebastian Huber |
rtems: Avoid Giant lock for semaphores
Update #2555.
5
@c8982e5
04/26/16 19:20:31 |
Sebastian Huber |
posix: Simplify message queues
The mq_open() function returns a …
5
@6741d30a
04/27/16 04:49:59 |
Sebastian Huber |
rtems: Avoid Giant lock for message queues
Update #2555.
5
@99112f7
04/27/16 14:21:07 |
Sebastian Huber |
score: _CORE_message_queue_Submit()
Move lock acquire to caller of …
5
@b0eba5ed
04/27/16 14:20:05 |
Sebastian Huber |
score: _CORE_message_queue_Seize()
5
@7580995
04/26/16 19:18:52 |
Sebastian Huber |
score: _CORE_message_queue_Close()
5
@9c3bae11
04/21/16 05:52:19 |
Sebastian Huber |
rtems: Avoid Giant lock for dual ported memory
There is no need for …
5
@f27383a
04/20/16 12:01:02 |
Sebastian Huber |
score: Avoid Giant lock for barriers
Use …
5
@4025a60f
04/19/16 15:02:54 |
Sebastian Huber |
score: Avoid Giant lock for CORE mtx/sem
Avoid Giant lock for CORE …
5
@3d0c4005
04/19/16 13:07:39 |
Sebastian Huber |
score: Rename _CORE_barrier_Wait()
Rename _CORE_barrier_Wait() into …
5
@242a05a
04/19/16 13:04:34 |
Sebastian Huber |
score: Rename _MRSP_Obtain()
Rename _MRSP_Obtain() into …
5
@88575577
04/19/16 12:14:31 |
Sebastian Huber |
score: Optimize _Objects_Get_local()
Make the id the first parameter …
5
@d7a12be9
04/19/16 12:14:10 |
Sebastian Huber |
score: Optimize _Objects_Get_no_protection()
Make the id the first …
5
@f05eeb2
04/19/16 11:39:00 |
Sebastian Huber |
score: Simplify _Objects_Initialize_information()
Remove unused …
5
@adbedd1
04/15/16 19:18:26 |
Sebastian Huber |
score: Introduce _Thread_queue_Flush_critical()
Replace …
5
@8765c57
04/18/16 05:00:55 |
Sebastian Huber |
score: Remove id parameter _CORE_mutex_Seize()
Parameter was unused.
5
@ca18cb59
04/18/16 04:53:10 |
Sebastian Huber |
score: Close semaphore object before flush
This prevents use of the …
5
@90f1265e
04/18/16 04:23:27 |
Sebastian Huber |
score: Fix _CORE_semaphore_Flush()
Use proper CORE_semaphore_Status …
5
@928d455
04/17/16 13:57:19 |
Sebastian Huber |
score: Close barrier object before flush
5
@e781ddb
04/17/16 13:57:03 |
Sebastian Huber |
score: Simplify _CORE_barrier_Flush()
5
@5cc6bf4
04/17/16 13:47:33 |
Sebastian Huber |
score: Simplify _CORE_message_queue_Close()
Drop status parameter …
5
@e65c45c
03/22/16 22:13:30 |
joel |
Obsolete rtems_clock_get() directive.
This service was marked as …
5
@c39da818
04/08/16 06:14:31 |
Sebastian Huber |
rtems: Delete Region_Control::page_size
5
@60a23875
04/08/16 06:13:49 |
Sebastian Huber |
rtems: Delete Region_Control::length
5
@acf7cf3b
04/08/16 06:12:06 |
Sebastian Huber |
rtems: Delete Region_Control::starting_address
5
@b4b062f
04/08/16 05:50:42 |
Sebastian Huber |
rtems: Delete Region_Control::number_of_used_blocks
Use …
5
@1142f55
04/08/16 04:56:46 |
Sebastian Huber |
rtems: Add and use _Region_Get_and_lock()
Get region and lock …
5
@572cb624
04/07/16 14:48:30 |
Sebastian Huber |
score: Simplify _Objects_Get_no_protection()
This functions supports …
5
@0158a60
04/08/16 04:28:04 |
Sebastian Huber |
rtems: Ensure lock ownership for _Region_Get()
5
@d26b053
04/07/16 14:49:22 |
Sebastian Huber |
rtems: Remove dead code
The heap protection enabled by RTEMS_DEBUG …
5
@3570ec6
04/04/16 08:13:35 |
Sebastian Huber |
rtems: Avoid Giant lock for partitions
Use an ISR lock to protect the …
5
@8f96581
04/01/16 09:38:47 |
Sebastian Huber |
score: Rework MP thread queue callout support
The thread queue …
5
@9809d6e0
03/30/16 09:39:58 |
Sebastian Huber |
score: _Thread_queue_Flush() parameter changes
Change …
5
@97312fcc
04/05/16 12:36:30 |
Sebastian Huber |
score: Delete Thread_Wait_information::id
This field was only by the …
5
@9d9b6b56
03/30/16 06:36:08 |
Sebastian Huber |
score: Objects_Thread_queue_Extract_callout
Change parameters of the …
5
@06f68a96
03/30/16 06:34:23 |
Sebastian Huber |
score: Fix set but not used warning
5
@863c074
03/30/16 06:33:41 |
Sebastian Huber |
score: Fix statement with no effect warning
No need to add an assert …
5
@97b7244
03/30/16 06:32:56 |
Sebastian Huber |
5
@9f71433
03/30/16 06:31:26 |
Sebastian Huber |
5
@8afeb993
03/30/16 06:29:07 |
Sebastian Huber |
5
@081d03d
03/30/16 06:08:44 |
Sebastian Huber |
No need to add an assert due to …
5
@75c19d25
03/30/16 06:05:54 |
Sebastian Huber |
5
@97bbf02
03/22/16 07:52:50 |
Sebastian Huber |
score: Use constant for maximum count of CORE sema
5
@1e1a91ed
03/23/16 09:01:31 |
Sebastian Huber |
score: Remove Thread_queue_Queue::operations field
Remove the …
5
@50b73d3
03/21/16 00:28:20 |
joel |
cpukit/rtems/src/*mp.c: Fix set but not used warning
5
@426f35f
03/22/16 18:15:07 |
joel |
cpukit/rtems/include/rtems/rtems/sem.h: Remove junk in comment
5
@30cac38f
03/22/16 06:40:18 |
Sebastian Huber |
rtems: Use object allocator lock
Object creation and destruction is …
5
@90960bd
03/21/16 14:01:57 |
Sebastian Huber |
rtems: Rework rate-monotonic scheduler
Use the default thread lock to …
5
@875c26d
03/21/16 09:45:44 |
Sebastian Huber |
rtems: Avoid RTEMS_USE_TICKS_FOR_STATISTICS
Option was removed by …
5
@300eaad
03/21/16 09:41:31 |
Sebastian Huber |
rtems: Delete Rate_monotonic_Period_time_t
Variables with this type …
5
@610e87d
03/21/16 09:36:20 |
Sebastian Huber |
rtems: Inline _Rate_monotonic_Reset_statistics()
Use inline function …
5
@92dee4ab
03/17/16 05:51:56 |
Sebastian Huber |
rtems: Avoid Giant lock in rtems_signal_catch()
Update #2555.
5
@f5bb2991
03/17/16 05:30:29 |
Sebastian Huber |
rtems: Avoid Giant lock in rtems_task_mode()
Update #2555.
5
@d37adfe5
03/03/16 06:02:03 |
Sebastian Huber |
score: Fix CPU time used by executing threads
The CPU time used of a …
5
@77e6eba7
03/07/16 15:01:57 |
Sebastian Huber |
score: Add and use _Objects_Get_local()
This simplifies the handling …
5
@03b900d
02/18/16 07:36:26 |
Sebastian Huber |
score: Replace watchdog handler implementation
Use a red-black tree …
5
@d297c81d
03/01/16 05:36:16 |
Sebastian Huber |
score: Delete Thread_CPU_usage_t
This type is superfluous since all …
5
@67de508
02/25/16 12:08:45 |
Sebastian Huber |
5
@2e71aa41
02/17/16 11:52:17 |
Sebastian Huber |
score: Simplify _Watchdog_Tick()
Move thread dispatch disable check …
5
@3bc12a8f
01/26/16 10:16:56 |
Sebastian Huber |
Delete unused API extensions
5
@1ff8eca
01/26/16 10:10:43 |
Sebastian Huber |
Use linker set for Classic User Tasks init
Update #2408.
5
@2605a489
12/15/15 08:32:55 |
Sebastian Huber |
Optional POSIX Keys initialization
Update #2408.
5
@58089ff
12/14/15 14:28:51 |
Sebastian Huber |
rtems: Delete empty _RTEMS_API_Initialize()
5
@97d94ff
12/14/15 14:27:56 |
Sebastian Huber |
Optional Classic Barrier initialization
Update #2408.
5
@b377e3f
12/14/15 14:15:22 |
Sebastian Huber |
Optional Classic Rate Monotonic initialization
Update #2408.
5
@af12278
12/14/15 14:12:39 |
Sebastian Huber |
Optional Classic Dual-Ported Memory initialization
Update #2408.
5
@365456cc
12/14/15 14:10:32 |
Sebastian Huber |
Optional Classic Region initialization
Update #2408.
5
@fd3cc36f
12/14/15 14:08:27 |
Sebastian Huber |
Optional Classic Partition initialization
Update #2408.
5
@cbaac1f7
12/14/15 14:05:47 |
Sebastian Huber |
Optional Classic Semaphore initialization
Update #2408.
5
@ed8b00e6
12/14/15 14:02:45 |
Sebastian Huber |
Optional Classic Message Queue initialization
Update #2408.
5
@ae85b066
12/14/15 13:59:56 |
Sebastian Huber |
Optional Classic Event initialization
Update #2408.
5
@a7f36829
12/14/15 13:56:41 |
Sebastian Huber |
Optional Classic Signal initialization
Update #2408.
5
@26335844
12/14/15 13:52:35 |
Sebastian Huber |
Optional Classic Timer initialization
Update #2408.
5
@565672a
12/14/15 13:46:10 |
Sebastian Huber |
Optional Classic Tasks initialization
Update #2408.
5
@76ac1ee3
12/23/15 06:29:47 |
Sebastian Huber |
score: Fix simple timecounter support
Update #2502.
5
@2b9374e1
01/18/16 23:34:25 |
joel |
taskcreate.c: Add method name to comment to be clearer
5
@33ece0da
01/18/16 23:31:09 |
joel |
sem.h: Delete junk in comment
5
@815b653
01/18/16 23:30:38 |
joel |
ratemon.h: Fix comments
5
@1506658c
01/08/16 11:11:03 |
Sebastian Huber |
score: Simplify _Thread_Start()
5
@ccd5434
01/07/16 08:55:45 |
Sebastian Huber |
score: Introduce Thread_Entry_information
This avoids potential dead …
5
@4e3bb2dd
01/08/16 08:05:34 |
Sebastian Huber |
rtems: Fix warning
5
@44e9871
12/22/15 08:40:48 |
Sebastian Huber |
score: Avoid dead code in global construction
Update #2514.
5
@fe100e16
12/22/15 08:13:08 |
Sebastian Huber |
score: Add fatal errors for NULL entry init tasks
This simplifies the …
5
@d5154d0f
12/23/15 20:44:02 |
admin |
api: Remove deprecated Notepads
Notepads where a feature of RTEMS' …
5
@e01b184
12/14/15 13:07:40 |
Sebastian Huber |
rtems: Delete empty function
5
@54c3fbd
12/11/15 10:09:13 |
Sebastian Huber |
score: Initialize thread control to zero
This reduces the code size …
5
@df55d07f
12/10/15 13:10:48 |
Sebastian Huber |
score: Untangle thread actions
Remove the thread action handler …
5
@8054b1c
11/26/15 13:08:56 |
Sebastian Huber |
Remove <rtems/debug.h>
Close #2477.
5
@a062014
11/26/15 13:11:19 |
Sebastian Huber |
Delete _Region_Debug_Walk()
The expensive heap walks are superfluous …
5
@8ce0b0cb
11/25/15 06:55:00 |
Sebastian Huber |
Fix _Assert() statement
5
@b84a51c
11/10/15 16:23:12 |
Sebastian Huber |
score: Fix race condition on SMP
We must ensure that the …
5
@4fee129
11/11/15 09:47:52 |
Sebastian Huber |
Introduce general purpose system server event
Use this event for the …
5
@c52568d
10/16/15 06:17:52 |
Sebastian Huber |
basdefs.h: Add and use RTEMS_DEPRECATED
5
@7def219
09/02/15 21:54:21 |
Martin Galvan |
various .h files: Add missing C++ extern wrappers
Updates #2405.
5
@d7665823
06/24/15 13:43:19 |
Sebastian Huber |
score: Introduce Thread_queue_Heads
Move the storage for the thread …
5
@bd67d7d2
06/25/15 11:48:00 |
Sebastian Huber |
score: Simplify <rtems/score/thread.h>
Avoid Thread_Control typedef …
4.115
@cdf30f05
06/19/15 12:57:44 |
Sebastian Huber |
rtems: Add rtems_interrupt_local_disable|enable()
Add …
4.115
@e6b31b27
05/27/15 15:13:58 |
Joel Sherrill |
Remove use ticks for statistics configure option.
This was obsolete …
4.115
@80fca28
06/13/15 13:29:04 |
Sebastian Huber |
score: Add _Watchdog_Preinitialize()
Add an assert to ensure that the …
4.115
