@df49c60
06/12/00 15:00:15 |
Joel Sherrill |
Merged from 4.5.0-beta3a
4.104.114.84.95
@bf85b19
04/13/00 14:37:14 |
Joel Sherrill |
Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@70810dc
02/08/00 22:33:25 |
Joel Sherrill |
Patches rtems-rc-20000204-0.diff from Ralf Corsepius …
4.104.114.84.95
@bf24479
02/04/00 16:32:38 |
Joel Sherrill |
Incorrect error status returned. Noted by Andrew Klossner …
4.104.114.84.95
@edb2176
02/04/00 16:09:38 |
Joel Sherrill |
4.104.114.84.95
@b452a40
02/03/00 22:20:41 |
Joel Sherrill |
Changed behavior to match that expected by EPICS test code. Reported …
4.104.114.84.95
@1382cea3
02/03/00 13:18:21 |
Joel Sherrill |
Fixed spelling errors.
4.104.114.84.95
@8d37343
01/23/00 19:07:02 |
Joel Sherrill |
Directive rtems_task_variable_get() added by Eric Norum.
4.104.114.84.95
@c941a98
01/21/00 15:07:55 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to implement this:
I'd …
4.104.114.84.95
@e49ebbfa
01/14/00 18:37:59 |
Joel Sherrill |
Removed unused variable warning.
4.104.114.84.95
@53fb837a
01/13/00 19:25:15 |
Joel Sherrill |
POSIX message queues now include complete functionality including …
4.104.114.84.95
@b0461cd4
01/13/00 17:13:12 |
Jennifer.Averett |
Added comment to indicate this path does not occur.
4.104.114.84.95
@5870ac55
01/05/00 22:19:21 |
Joel Sherrill |
Added support for simple binary semaphores in addition to the high …
4.104.114.84.95
@28adcfd
01/05/00 22:14:09 |
Joel Sherrill |
Added message priority parameter returned by core support routine.
4.104.114.84.95
@7d91d72
12/13/99 15:29:20 |
Joel Sherrill |
First attempt at adding simple binary semaphore in addition to the …
4.104.114.84.95
@1d9a2fc
11/29/99 15:45:11 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius …
4.104.114.84.95
@fba12eb6
11/23/99 13:29:04 |
Joel Sherrill |
Patch rtems-rc-19991117-11.diff from Ralf Corsepius …
4.104.114.84.95
@9608320
11/22/99 13:41:11 |
Joel Sherrill |
Patch rtems-rc-19991117-4.diff from Ralf Corsepius …
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@aad726e
11/16/99 22:56:38 |
Joel Sherrill |
Moved task_variable pointer to basic shared part of TCB instead of …
4.104.114.84.95
@1925ec9b
11/12/99 15:54:07 |
Joel Sherrill |
Corrected remaining references to struct rtems_task_variable_t since …
4.104.114.84.95
@95bb279
11/12/99 14:54:13 |
Joel Sherrill |
Used typedef so all "struct rtems_task_variable_t" uses are now
just …
4.104.114.84.95
@884b460
11/12/99 14:52:36 |
Joel Sherrill |
Added per-task variable data stucture (rtems_task_variable_t), …
4.104.114.84.95
@5aa5560
11/12/99 14:38:19 |
Joel Sherrill |
Added per task variables based on patch from Eric Norum …
4.104.114.84.95
@72719d2
11/10/99 20:37:01 |
Joel Sherrill |
Added call to _Thread_Enable_dispatch() and did some cleanup.
4.104.114.84.95
@eb02f47
11/10/99 13:48:27 |
Joel Sherrill |
Committed modifications from ITRON Task and Task Dependendent …
4.104.114.84.95
@bd0b378
11/09/99 19:45:23 |
Joel Sherrill |
4.104.114.84.95
@f817b02
11/04/99 18:05:09 |
Joel Sherrill |
The files in libcpu should not be directly dependent on any BSP. In …
4.104.114.84.95
@93b4e6ef
11/02/99 21:05:17 |
Joel Sherrill |
Split Heap and Time of Day Handlers.
4.104.114.84.95
@861e94d9
11/02/99 15:35:58 |
Joel Sherrill |
Added comment to make sure Classic API priority to Core priority
is …
4.104.114.84.95
@3ba754e1
11/02/99 15:34:40 |
Joel Sherrill |
Added comments for _RTEMS_tasks_Create_extension, …
4.104.114.84.95
@b970c48
11/02/99 15:33:14 |
Joel Sherrill |
Added a case to support the core semaphore error returned when the …
4.104.114.84.95
@d80188eb
11/02/99 15:30:20 |
Joel Sherrill |
Added code to utilize the maximum_count attribute of core semaphores …
4.104.114.84.95
@61a4d81
10/21/99 19:36:29 |
Joel Sherrill |
Removed warning.
4.104.114.84.95
@e7264f07
10/21/99 16:44:24 |
Joel Sherrill |
Added rtems_semaphore_flush directive.
4.104.114.84.95
@e39431b
10/20/99 20:33:02 |
Joel Sherrill |
Added prototype for rtems_task_is_suspended at request of
Eric Norum.
4.104.114.84.95
@4a4efb5
10/07/99 16:26:31 |
Joel Sherrill |
New directive added -- rtems_task_is_suspended.
4.104.114.84.95
@811804fe
10/04/99 19:15:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make fix bug …
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@e49d7c3
08/30/99 15:02:20 |
Joel Sherrill |
Removed definition of NO_IMPLICIT_EXTERN_C since it is supposed to be …
4.104.114.84.95
@2fe7208
08/10/99 15:02:23 |
Joel Sherrill |
Added NO_IMPLICIT_EXTERN_C at suggestion of Jason Merrill.
4.104.114.84.95
@0860426
06/09/99 16:46:13 |
Joel Sherrill |
Modified to return an error when a bogus return address for the …
4.104.114.84.95
@82d11f87
05/27/99 15:43:32 |
Joel Sherrill |
Corrected macro names.
4.104.114.84.95
@9180f63
05/17/99 23:26:50 |
Joel Sherrill |
Fixed some typos.
4.104.114.84.95
@c9973bb
05/17/99 23:22:45 |
Joel Sherrill |
Split Interrupt Manager into one routine per file.
4.104.114.84.95
@0123e3b
05/17/99 23:20:52 |
Joel Sherrill |
Split Signal Manager into one routine per file.
4.104.114.84.95
@1dc030f
05/17/99 23:18:20 |
Joel Sherrill |
Dual-Ported Memory Manager split into one routine per file.
4.104.114.84.95
@842db5f3
05/17/99 23:15:20 |
Joel Sherrill |
Split Partition Manager into one routine per file.
4.104.114.84.95
@be47df9
05/17/99 23:10:36 |
Joel Sherrill |
Split Timer Manager into one routine per file.
4.104.114.84.95
@cc2bc302
05/17/99 23:06:03 |
Joel Sherrill |
Split Event Manager into one routine per file.
4.104.114.84.95
@5f9b3db
05/17/99 23:03:07 |
Joel Sherrill |
Split Rate Monotonic Manager into one routine per file.
4.104.114.84.95
@c06d8f64
05/17/99 22:58:30 |
Joel Sherrill |
Split the Semaphore Manager into one routine per file.
4.104.114.84.95
@a2d0f39
05/17/99 22:56:13 |
Joel Sherrill |
Moved some MP routines to semmp.c.
4.104.114.84.95
@3270ca6
05/17/99 22:53:34 |
Joel Sherrill |
Forgot to actually remove the routines. :)
4.104.114.84.95
@1e1b3e00
05/17/99 22:52:59 |
Joel Sherrill |
Split Message Manager into one routine per file.
4.104.114.84.95
@ef22ab2
05/17/99 22:46:01 |
Joel Sherrill |
Moved an MP routine from msg.c to here.
4.104.114.84.95
@86cb89f
05/17/99 22:45:47 |
Joel Sherrill |
Cleaned up some multiprocessing issues.
4.104.114.84.95
@bd83f47
05/17/99 22:42:47 |
Joel Sherrill |
Split Clock Manager into one routine per file.
4.104.114.84.95
@5aa64518
05/17/99 22:39:20 |
Joel Sherrill |
Split Region Manager into one routine per file.
4.104.114.84.95
@c4d69e2
05/17/99 21:02:16 |
Joel Sherrill |
Split Task Manager into multiple files. Eventually this effort will …
4.104.114.84.95
@577c4080
05/17/99 15:28:52 |
Joel Sherrill |
Patch from D. V. Henkel-Wallace <gumby@…>:
Here's a tiny …
4.104.114.84.95
@5a909149
05/07/99 17:09:20 |
Joel Sherrill |
Made all calls to _Thread_Yield_processor consistent in how they are …
4.104.114.84.95
@f4a8ee1
03/17/99 16:01:03 |
Joel Sherrill |
Unlimited objects patch from Chris Johns <ccj@…>. Email …
4.104.114.84.95
@dd746c38
02/10/99 00:29:02 |
Joel Sherrill |
Comments fixed after problem report from Ian Lance Taylor <ian@…>.
4.104.114.84.95
@fdd9fe17
12/03/98 21:52:20 |
Joel Sherrill |
Corrected ifdef on RTEMS_MULTIPROCESSING so the queue is actually closed.
4.104.114.84.95
@97e2729d
11/23/98 17:38:09 |
Joel Sherrill |
Added --disable-multiprocessing flag and modified a lot of files to …
4.104.114.84.95
@ff0b008
08/24/98 14:50:00 |
Joel Sherrill |
Added RTEMS_INSIDE macro to insure that ".inl" files are ALWAYS …
4.104.114.84.95
@7a035ebc
08/21/98 16:54:17 |
Joel Sherrill |
Added system task attribute to allow one to create a task with "0" …
4.104.114.84.95
@cb1b853d
06/18/98 19:01:57 |
Joel Sherrill |
All task delete API level services were incorrectly assuming that the …
4.104.114.84.95
@60b791ad
02/17/98 23:46:28 |
Joel Sherrill |
updated copyright to 1998
4.104.114.84.95
@cdfd74a5
10/21/97 18:37:58 |
Joel Sherrill |
Added check that return argument pointer for old_isr_handler was valid.
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@7e4938c
10/06/97 21:28:40 |
Joel Sherrill |
Make Post an atomic operation.
4.104.114.84.95
@7d352a49
08/28/97 13:59:41 |
Joel Sherrill |
Added RTEMS_IO_ERROR status code.
4.104.114.84.95
@b2fed481
08/02/97 17:55:09 |
Joel Sherrill |
Added these files to contain bodies for routines included in the API …
4.104.114.84.95
@e7d8b58
07/31/97 19:01:42 |
Joel Sherrill |
Added rtems_message_queue_get_number_pending directive.
4.104.114.84.95
@e24e9b5
07/18/97 15:05:05 |
Joel Sherrill |
fixed typo
4.104.114.84.95
@2c5d78b
07/09/97 23:46:59 |
Joel Sherrill |
Corrected typos and spacing.
4.104.114.84.95
@00d2a828
05/28/97 20:36:35 |
Joel Sherrill |
Added support for context switching the data used by the gcc m68k …
4.104.114.84.95
@e8cdda4
04/25/97 18:13:49 |
Joel Sherrill |
Corrected by adding check for NULL address passed into get_status …
4.104.114.84.95
@f8f5106
04/25/97 18:13:26 |
Joel Sherrill |
Added to comment header block to include new status directive.
4.104.114.84.95
@e0de6ef
04/22/97 20:19:12 |
Joel Sherrill |
promote TOD_MICROSECONDS_TO_TICKS through API as …
4.104.114.84.95
@84ff7c23
04/22/97 17:42:17 |
Joel Sherrill |
File changed to reflect change in license and copyright.
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@113ef9fc
04/09/97 20:02:29 |
Joel Sherrill |
added support for statistics on rate monotonic periods.
4.104.114.84.95
@dab057a
03/08/97 03:51:09 |
Joel Sherrill |
Modified calls to _Thread_Change_priority to take a third argument. …
4.104.114.84.95
@ffe316d
12/02/96 22:50:33 |
Joel Sherrill |
Suggested changes from Mark Jordan which eliminate warnings and errors …
4.104.114.84.95
@7fea679b
09/06/96 15:16:19 |
Joel Sherrill |
changed _TOD_Is_set from a function to a boolean variable
4.104.114.84.95
@503dc058
07/03/96 14:20:03 |
Joel Sherrill |
switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"
4.104.114.84.95
@ebd40c0
06/06/96 14:55:08 |
Joel Sherrill |
Added Sporadic Server support to posix threads which required changes …
4.104.114.84.95
@742b399
06/03/96 21:08:26 |
Joel Sherrill |
added priority ceiling support
4.104.114.84.95
@5e7b6272
05/31/96 23:27:45 |
Joel Sherrill |
renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the …
4.104.114.84.95
@98849f44
05/29/96 16:55:05 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@019bce7
05/29/96 16:05:06 |
Joel Sherrill |
It is now not an error to have 0 RTEMS initialization tasks since you …
4.104.114.84.95
@c627b2a3
05/28/96 21:40:52 |
Joel Sherrill |
split the inclusion of "EXTERN" data based on whether it was sapi, …
4.104.114.84.95
@e6d4b1d
05/28/96 13:13:34 |
Joel Sherrill |
added initial posix configuration support
4.104.114.84.95
@debe919
04/19/96 21:10:58 |
Joel Sherrill |
event.c: _Event_Manager_initialization no longer a static inline
4.104.114.84.95
@78b2ff1
04/19/96 21:10:38 |
Joel Sherrill |
4.104.114.84.95
@c26b62f
04/19/96 21:10:32 |
Joel Sherrill |
event.h: _Event_Manager_initialization no longer a static inline
4.104.114.84.95
@8f9e9bdc
04/19/96 21:10:27 |
Joel Sherrill |
4.104.114.84.95
