@a2d0f39
05/17/99 22:56:13 |
Joel Sherrill |
Moved some MP routines to semmp.c.
4.104.114.84.95
@3270ca6
05/17/99 22:53:34 |
Joel Sherrill |
Forgot to actually remove the routines. :)
4.104.114.84.95
@1e1b3e00
05/17/99 22:52:59 |
Joel Sherrill |
Split Message Manager into one routine per file.
4.104.114.84.95
@ef22ab2
05/17/99 22:46:01 |
Joel Sherrill |
Moved an MP routine from msg.c to here.
4.104.114.84.95
@86cb89f
05/17/99 22:45:47 |
Joel Sherrill |
Cleaned up some multiprocessing issues.
4.104.114.84.95
@bd83f47
05/17/99 22:42:47 |
Joel Sherrill |
Split Clock Manager into one routine per file.
4.104.114.84.95
@5aa64518
05/17/99 22:39:20 |
Joel Sherrill |
Split Region Manager into one routine per file.
4.104.114.84.95
@c4d69e2
05/17/99 21:02:16 |
Joel Sherrill |
Split Task Manager into multiple files. Eventually this effort will …
4.104.114.84.95
@577c4080
05/17/99 15:28:52 |
Joel Sherrill |
Patch from D. V. Henkel-Wallace <gumby@…>:
Here's a tiny …
4.104.114.84.95
@5a909149
05/07/99 17:09:20 |
Joel Sherrill |
Made all calls to _Thread_Yield_processor consistent in how they are …
4.104.114.84.95
@f4a8ee1
03/17/99 16:01:03 |
Joel Sherrill |
Unlimited objects patch from Chris Johns <ccj@…>. Email …
4.104.114.84.95
@dd746c38
02/10/99 00:29:02 |
Joel Sherrill |
Comments fixed after problem report from Ian Lance Taylor <ian@…>.
4.104.114.84.95
@fdd9fe17
12/03/98 21:52:20 |
Joel Sherrill |
Corrected ifdef on RTEMS_MULTIPROCESSING so the queue is actually closed.
4.104.114.84.95
@97e2729d
11/23/98 17:38:09 |
Joel Sherrill |
Added --disable-multiprocessing flag and modified a lot of files to …
4.104.114.84.95
@ff0b008
08/24/98 14:50:00 |
Joel Sherrill |
Added RTEMS_INSIDE macro to insure that ".inl" files are ALWAYS …
4.104.114.84.95
@7a035ebc
08/21/98 16:54:17 |
Joel Sherrill |
Added system task attribute to allow one to create a task with "0" …
4.104.114.84.95
@cb1b853d
06/18/98 19:01:57 |
Joel Sherrill |
All task delete API level services were incorrectly assuming that the …
4.104.114.84.95
@60b791ad
02/17/98 23:46:28 |
Joel Sherrill |
updated copyright to 1998
4.104.114.84.95
@cdfd74a5
10/21/97 18:37:58 |
Joel Sherrill |
Added check that return argument pointer for old_isr_handler was valid.
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@7e4938c
10/06/97 21:28:40 |
Joel Sherrill |
Make Post an atomic operation.
4.104.114.84.95
@7d352a49
08/28/97 13:59:41 |
Joel Sherrill |
Added RTEMS_IO_ERROR status code.
4.104.114.84.95
@b2fed481
08/02/97 17:55:09 |
Joel Sherrill |
Added these files to contain bodies for routines included in the API …
4.104.114.84.95
@e7d8b58
07/31/97 19:01:42 |
Joel Sherrill |
Added rtems_message_queue_get_number_pending directive.
4.104.114.84.95
@e24e9b5
07/18/97 15:05:05 |
Joel Sherrill |
fixed typo
4.104.114.84.95
@2c5d78b
07/09/97 23:46:59 |
Joel Sherrill |
Corrected typos and spacing.
4.104.114.84.95
@00d2a828
05/28/97 20:36:35 |
Joel Sherrill |
Added support for context switching the data used by the gcc m68k …
4.104.114.84.95
@e8cdda4
04/25/97 18:13:49 |
Joel Sherrill |
Corrected by adding check for NULL address passed into get_status …
4.104.114.84.95
@f8f5106
04/25/97 18:13:26 |
Joel Sherrill |
Added to comment header block to include new status directive.
4.104.114.84.95
@e0de6ef
04/22/97 20:19:12 |
Joel Sherrill |
promote TOD_MICROSECONDS_TO_TICKS through API as …
4.104.114.84.95
@84ff7c23
04/22/97 17:42:17 |
Joel Sherrill |
File changed to reflect change in license and copyright.
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@113ef9fc
04/09/97 20:02:29 |
Joel Sherrill |
added support for statistics on rate monotonic periods.
4.104.114.84.95
@dab057a
03/08/97 03:51:09 |
Joel Sherrill |
Modified calls to _Thread_Change_priority to take a third argument. …
4.104.114.84.95
@ffe316d
12/02/96 22:50:33 |
Joel Sherrill |
Suggested changes from Mark Jordan which eliminate warnings and errors …
4.104.114.84.95
@7fea679b
09/06/96 15:16:19 |
Joel Sherrill |
changed _TOD_Is_set from a function to a boolean variable
4.104.114.84.95
@503dc058
07/03/96 14:20:03 |
Joel Sherrill |
switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"
4.104.114.84.95
@ebd40c0
06/06/96 14:55:08 |
Joel Sherrill |
Added Sporadic Server support to posix threads which required changes …
4.104.114.84.95
@742b399
06/03/96 21:08:26 |
Joel Sherrill |
added priority ceiling support
4.104.114.84.95
@5e7b6272
05/31/96 23:27:45 |
Joel Sherrill |
renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the …
4.104.114.84.95
@98849f44
05/29/96 16:55:05 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@019bce7
05/29/96 16:05:06 |
Joel Sherrill |
It is now not an error to have 0 RTEMS initialization tasks since you …
4.104.114.84.95
@c627b2a3
05/28/96 21:40:52 |
Joel Sherrill |
split the inclusion of "EXTERN" data based on whether it was sapi, …
4.104.114.84.95
@e6d4b1d
05/28/96 13:13:34 |
Joel Sherrill |
added initial posix configuration support
4.104.114.84.95
@debe919
04/19/96 21:10:58 |
Joel Sherrill |
event.c: _Event_Manager_initialization no longer a static inline
4.104.114.84.95
@78b2ff1
04/19/96 21:10:38 |
Joel Sherrill |
4.104.114.84.95
@c26b62f
04/19/96 21:10:32 |
Joel Sherrill |
event.h: _Event_Manager_initialization no longer a static inline
4.104.114.84.95
@8f9e9bdc
04/19/96 21:10:27 |
Joel Sherrill |
4.104.114.84.95
@1a8fde6c
03/06/96 21:34:57 |
Joel Sherrill |
Removed prototyes for static inline routines and moved the comments …
4.104.114.84.95
@94b3ec59
02/13/96 22:14:48 |
Joel Sherrill |
changed post task extension from user set to api set and added flag
in …
4.104.114.84.95
@18269cef
02/13/96 15:37:33 |
Joel Sherrill |
comment added to describe synchronization logic in timeout routine
4.104.114.84.95
@107ce47b
02/09/96 14:30:42 |
Joel Sherrill |
new isr synchronization algorithm using a single enumerated set of states.
4.104.114.84.95
@6dae1c2d
02/09/96 14:25:33 |
Joel Sherrill |
added rtems_interrupt_is_in_progress
4.104.114.84.95
@f3dabb04
02/08/96 22:16:35 |
Joel Sherrill |
changed synchronization algorithm to be a single list of enumerated states
4.104.114.84.95
@5d3e539
01/17/96 20:11:33 |
Joel Sherrill |
added class to initial id macro
4.104.114.84.95
@c64e4ed4
01/15/96 21:50:28 |
Joel Sherrill |
updates from Tony Bennett for PA and UNIX ports
4.104.114.84.95
@67d224a
12/08/95 21:06:15 |
Joel Sherrill |
added correct use of _Thread_queue_Enter_critical_section
4.104.114.84.95
@11ab74e
12/05/95 15:27:51 |
Joel Sherrill |
new states added and _Rate_monotonic_Set_State removed.
4.104.114.84.95
@8d0b7d96
12/01/95 22:03:55 |
Joel Sherrill |
Insert mode argument to _Watchdog_Insert removed. Now are watchdog …
4.104.114.84.95
@a26603d
12/01/95 21:06:53 |
Joel Sherrill |
Changed code for exit from synchronization state to a switch on the …
4.104.114.84.95
@3837215d
12/01/95 19:39:32 |
Joel Sherrill |
spurious blank line removed
4.104.114.84.95
@a8cd94a
12/01/95 19:28:58 |
Joel Sherrill |
Replaced critical section algorithm to correct race conditions.
4.104.114.84.95
@7f6fab6
12/01/95 19:28:52 |
Joel Sherrill |
Made _Event_Sync volatile
Replaced critical section algorithm to …
4.104.114.84.95
@c4808ca
10/31/95 21:28:16 |
Joel Sherrill |
typos fixed
4.104.114.84.95
@9700578
10/30/95 21:54:45 |
Joel Sherrill |
SPARC port passes all tests
4.104.114.84.95
@5e9b32b
09/26/95 19:27:15 |
Joel Sherrill |
posix support initially added
4.104.114.84.95
@7af35da5
09/21/95 20:55:07 |
Joel Sherrill |
More file movement required api extension to be added to score
4.104.114.84.95
@24b1cb9
09/21/95 19:55:51 |
Joel Sherrill |
More file movement
4.104.114.84.95
@be650a84
09/21/95 16:22:25 |
Joel Sherrill |
moving files around
4.104.114.84.95
@3652ad35
09/19/95 14:53:29 |
Joel Sherrill |
Minor bug fixes to get all targets compilable and running. The
single …
4.104.114.84.95
@3a4ae6c
09/11/95 19:35:39 |
Joel Sherrill |
The word "RTEMS" almost completely removed from the core.
4.104.114.84.95
@7f6a24ab
08/28/95 15:30:29 |
Joel Sherrill |
Added unused priority ceiling parameter to rtems_semaphore_create.
4.104.114.84.95
@5250ff39
08/23/95 21:06:31 |
Joel Sherrill |
Moved _Thread_Information -> _RTEMS_tasks_Information.
Added a table …
4.104.114.84.95
@3235ad9
08/23/95 19:30:23 |
Joel Sherrill |
Support for variable length names added to Object Handler. This …
4.104.114.84.95
@da6375b
08/22/95 16:03:46 |
Joel Sherrill |
fix broken RCS Ids -- $ accidentally lost merging changes earlier
4.104.114.84.95
@bb322a0
08/22/95 15:37:59 |
Joel Sherrill |
make inline and macro implementations match
4.104.114.84.95
@b2c491a0
08/22/95 14:52:08 |
Joel Sherrill |
4.104.114.84.95
@9863dbf
08/18/95 21:42:58 |
Joel Sherrill |
+ Added object type field to object id.
+ Added name pointer to …
4.104.114.84.95
@b06e68ef
08/17/95 19:51:51 |
Joel Sherrill |
Numerous miscellaneous features incorporated from Tony Bennett …
4.104.114.84.95
@3b438fa
08/17/95 19:39:31 |
Joel Sherrill |
variable length messages
4.104.114.84.95
@a1df0118
08/17/95 15:33:31 |
Joel Sherrill |
Id reinserted
4.104.114.84.95
@199fa36
08/17/95 15:32:35 |
Joel Sherrill |
no limit removed
4.104.114.84.95
@45819022
08/16/95 19:42:41 |
Joel Sherrill |
bug fixes to make macro implementations work
4.104.114.84.95
@ea9d7db
08/04/95 22:17:48 |
Joel Sherrill |
split out event support functions in anticipation of making a handler
4.104.114.84.95
@4f90134
08/01/95 15:39:55 |
Joel Sherrill |
deleted unused code
4.104.114.84.95
@3a5dbdc
07/31/95 22:22:38 |
Joel Sherrill |
Switched to events for mp receive server and eliminated the special …
4.104.114.84.95
@88d594a
05/24/95 21:39:42 |
Joel Sherrill |
Fully tested on all in-house targets
4.104.114.84.95
@ac7d5ef0
05/11/95 17:39:37 |
Joel Sherrill |
Initial revision
4.104.114.84.95
