@8123cae8
09/08/16 13:32:22 |
Sebastian Huber |
rtems: Add rtems_task_get_priority()
Update #2556.
Update #2784.
5
@300f6a48
06/22/16 15:09:23 |
Sebastian Huber |
score: Rework thread priority management
Add priority nodes which …
5
@b20b736
06/28/16 04:54:50 |
Sebastian Huber |
score: Introduce _Thread_Get_priority()
Avoid direct access to thread …
5
@e41308ea
08/22/16 08:58:34 |
Sebastian Huber |
score: Introduce Thread_queue_Lock_context
Introduce …
5
@114e408
08/22/16 11:17:05 |
Sebastian Huber |
score: Simplify thread queue acquire/release
5
@ee0e4135
08/04/16 08:20:29 |
Sebastian Huber |
score: Fix a release/cancel job race condition
Split up the potential …
5
@21bdca4
08/03/16 13:41:31 |
Sebastian Huber |
score: Indroduce cancel job scheduler operation
Do not use a deadline …
5
@ec735c6a
08/03/16 11:27:13 |
Sebastian Huber |
score: Fix for RTEMS_DEBUG
5
@1fcac5ad
07/25/16 14:35:37 |
Sebastian Huber |
score: Turn thread lock into thread wait lock
The …
5
@10e4000
06/23/16 18:40:43 |
Gedare Bloom |
cpukit/rtems: fix return type mismatch for _TOD_To_seconds
5
@f23d470
06/09/16 15:33:15 |
Gedare Bloom |
cpukit: Add and use Watchdog_Discipline.
Clock disciplines may be …
5
@0e507d55
07/02/16 22:19:38 |
pisa |
rtems+bsps/cache: Define cache manager operations for code …
5
@c0bd006
06/30/16 12:08:18 |
Sebastian Huber |
rtems: Fix rtems_task_set_scheduler() API
Task priorities are only …
5
@02987728
06/29/16 13:33:26 |
Sebastian Huber |
score: Avoid atomic fences for thread wait flags
The use of atomic …
5
@254dc82
06/24/16 09:22:03 |
Sebastian Huber |
score: Change Priority_Control to 64-bit
A 32-bit Priority_Control …
5
@9a78f8a5
06/16/16 15:08:54 |
Sebastian Huber |
score: Modify release job scheduler operation
Pass the deadline in …
5
@77ff5599
06/10/16 06:48:54 |
Sebastian Huber |
score: Introduce map priority scheduler operation
Introduce map/unmap …
5
@c82835a
06/21/16 15:12:40 |
Sebastian Huber |
rtems: Rework RTEMS API to SuperCore? priority
Use same structure as …
5
@a33bfb6
06/21/16 12:15:03 |
Sebastian Huber |
Avoid <rtems/print.h> in <rtems/rtems/ratemon.h>
This gets rid of the …
5
@506bfc8
06/21/16 11:30:15 |
Sebastian Huber |
Move printer initialization to separate header
The RTEMS print user …
5
@57c676c6
06/16/16 08:44:00 |
Sebastian Huber |
rtems: Fix rtems_semaphore_create()
Destroy the thread queue in case …
5
@6fc34e4
06/06/16 08:58:04 |
Sebastian Huber |
rtems: Simplify rtems_semaphore_create()
Remove superfluous includes. …
5
@3ad5f86
06/03/16 06:15:21 |
Sebastian Huber |
rtems: Fix no protocol mutex release
The Classic binary semaphores …
5
@a65b02d
05/30/16 10:21:55 |
Sebastian Huber |
rtems: Remove superfluous includes
5
@73f2ddb
05/30/16 08:43:31 |
Sebastian Huber |
rtems: Fix semaphore field name
5
@3692095
05/30/16 08:41:22 |
Sebastian Huber |
rtems: Move MrsP semaphore operations
Move MrsP semaphore operations …
5
@0b713f89
05/30/16 04:59:55 |
Sebastian Huber |
score: Rework CORE inherit priority mutex
Provide dedicated seize and …
5
@33e250c9
05/27/16 13:41:41 |
Sebastian Huber |
score: Rework CORE priority ceiling mutex
Rework seize and surrender …
5
@5a598ac
05/27/16 06:02:03 |
Sebastian Huber |
score: Add CORE mutex variants
Add CORE_recursive_mutex_Control and …
5
@bac50cfc
05/30/16 08:51:29 |
Sebastian Huber |
5
@3c1ad257
05/27/16 07:41:18 |
Sebastian Huber |
rtems: Simplify rtems_semaphore_delete()
Due to the unified status …
5
@8a77ef63
05/27/16 07:34:17 |
Sebastian Huber |
rtems: Simplify rtems_semaphore_flush()
5
@09c5ca4
05/26/16 20:29:56 |
Sebastian Huber |
score: Simplify CORE mutex
Remove superfluous support for simple …
5
@2581a56
05/20/16 19:39:56 |
Sebastian Huber |
score: Add semaphore variants
5
@3ca6e618
05/25/16 14:49:53 |
Sebastian Huber |
5
@af746b0
05/25/16 14:30:23 |
Sebastian Huber |
score: Use thread queue lock for MrsP
Replace the ISR lock in …
5
@93306058
05/27/16 12:43:19 |
Sebastian Huber |
score: _CORE_mutex_Check_dispatch_for_seize()
Move the safety check …
5
@0e1d11f3
05/27/16 11:26:53 |
Sebastian Huber |
score: Add _Thread_queue_Context_set_MP_callout()
Add …
5
@dce48791
05/23/16 11:37:59 |
Sebastian Huber |
score: Add Status_Control for all APIs
Unify the status codes of the …
5
@39bcf741
05/25/16 12:23:48 |
Sebastian Huber |
Fix semaphore post overflow status
Close #2720.
5
@631b3c8
05/23/16 09:40:18 |
Sebastian Huber |
score: Move thread queue MP callout to context
Drop the …
5
@c3d8d9e
05/23/16 04:55:49 |
Sebastian Huber |
score: Get rid of mp_id parameter
Get rid of the mp_id parameter used …
5
@8866e62
05/23/16 04:26:58 |
Sebastian Huber |
score: Move thread queue object support
5
@24d0ee57
05/20/16 08:39:50 |
Chris Johns |
cpukit, testsuite: Add rtems_printf and rtems_printer support.
This …
5
@16dbcdcd
05/23/16 09:42:41 |
Sebastian Huber |
score: _CORE_message_queue_Seize()
Delete unused parameter.
5
@7af4d67
05/24/16 10:00:32 |
Sebastian Huber |
mpci: Add missing return statements
5
@bdb3b7f
05/20/16 13:52:27 |
Sebastian Huber |
score: _CORE_semaphore_Seize()
5
@e266d13
05/20/16 13:10:27 |
Sebastian Huber |
Replace *_Get_interrupt_disable() with *_Get()
Uniformly use *_Get() …
5
@582bb23c
05/20/16 13:04:16 |
Sebastian Huber |
score: Rename _Objects_Get_local()
Rename _Objects_Get_local() into …
5
@62c528e6
05/20/16 12:59:30 |
Sebastian Huber |
rtems: _Semaphore_Get_interrupt_disable()
Use _Objects_Get_local() …
5
@641b44c2
05/20/16 12:21:12 |
Sebastian Huber |
rtems: _Message_queue_Get_interrupt_disable()
Use …
5
@0a00b2b
05/20/16 11:24:11 |
Sebastian Huber |
rtems: Remove location from _Partition_Get()
5
@516ee75
05/20/16 12:23:56 |
Sebastian Huber |
mpci: Delete unused region support
5
@7dfb4b9
05/19/16 09:20:58 |
Sebastian Huber |
score: Add per scheduler instance maximum priority
The priority …
5
@c2f301b5
05/18/16 06:08:38 |
Sebastian Huber |
score: Rename _ISR_Flash() into _ISR_Local_flash()
This is a …
5
@24713163
05/18/16 06:06:54 |
Sebastian Huber |
score: Rename _ISR_Disable() and _ISR_Enable()
Rename _ISR_Disable() …
5
@4b04cb61
05/18/16 06:03:05 |
Sebastian Huber |
score: Rename _ISR_Disable_without_giant()
Rename …
5
@f36ada32
05/17/16 12:38:57 |
Sebastian Huber |
rtems: Avoid Giant lock for rtems_task_delete()
Update #2555.
5
@33829ce
05/13/16 12:07:23 |
Sebastian Huber |
score: Avoid Giant lock for _Thread_Start()
Update #2555.
5
@54550e04
05/13/16 06:16:30 |
Sebastian Huber |
posix: Rework pthread_join()
Rework pthread_join() to use …
5
@9388390
05/13/16 05:04:43 |
Sebastian Huber |
score: Split _Thread_Restart()
Split _Thread_Restart() into …
5
@270394e
05/12/16 12:25:50 |
Sebastian Huber |
score: Avoid superfluous life protection
Disable thread dispatching …
5
@b7f5e391
05/12/16 04:12:06 |
Sebastian Huber |
score: Add _Thread_Exit()
The goal is to make _Thread_Exit() a …
5
@0727760
05/12/16 09:22:33 |
Sebastian Huber |
rtems: Add rtems_interrupt_lock_interrupt_disable
Update #2707.
5
@ef6f8a83
05/11/16 12:03:23 |
Sebastian Huber |
score: Avoid Giant lock for scheduler set/get
Update #2555.
5
@d9952999
05/11/16 09:06:51 |
Sebastian Huber |
score: Avoid Giant lock _Scheduler_Get_affinity()
Update #2555.
5
@e135271
05/11/16 08:58:59 |
Sebastian Huber |
score: Avoid Giant lock _Scheduler_Set_affinity()
Update #2555.
5
@bd12dda
05/11/16 09:54:49 |
Sebastian Huber |
score: Use thread state lock for current state
In addition protect …
5
@11c66437
05/11/16 08:27:37 |
Sebastian Huber |
rtems: Avoid Giant lock rtems_task_is_suspended()
Update #2555.
5
@4d76300a
05/11/16 08:21:57 |
Sebastian Huber |
rtems: Avoid Giant lock for some task operations
Avoid Giant lock for …
5
@105b4e6
05/10/16 04:47:19 |
Sebastian Huber |
rtems: Use thread state lock for signals
5
@6e4f929
05/06/16 04:44:41 |
Sebastian Huber |
score: Introduce thread state lock
Update #2556.
5
@a0162bf
05/04/16 14:02:39 |
Sebastian Huber |
5
@bb2ad039
05/04/16 08:09:45 |
Sebastian Huber |
rtems: Avoid Giant lock for signals
Update #2555.
5
@a0dee7c7
05/03/16 07:59:50 |
Sebastian Huber |
score: Simplify _Thread_Get_interrupt_disable()
Remove the object …
5
@49a134dd
05/03/16 07:59:06 |
Sebastian Huber |
rtems: Return status in _Event_Surrender()
5
@1d40d81b
05/03/16 05:38:19 |
Sebastian Huber |
rtems: Remove task variables
Update #2494.
Update #2555.
5
@0a68d8e
05/01/16 14:11:30 |
Sebastian Huber |
score: Optimize _Objects_Get_local()
Make the interrupt lock context …
5
@e38a92b
05/02/16 04:30:49 |
Sebastian Huber |
mpci: Make _*_MP_Get_packet() static
5
@c506158c
05/02/16 04:17:07 |
Sebastian Huber |
mpci: Make _*_MP_Send_response_packet() static
5
@500a8e9c
04/28/16 04:26:01 |
Sebastian Huber |
score: Delete RTEMS_STRICT_ORDER_MUTEX
Remove support for strict …
5
@1ef8e4a8
04/27/16 20:07:56 |
Sebastian Huber |
score: Avoid Giant lock for set time of day
Update #2555.
Update #2630.
5
@3888771
04/27/16 19:32:23 |
Sebastian Huber |
score: Streamline set time of day functions
Rename _TOD_Set() into …
5
@f4d541cc
04/27/16 14:46:57 |
Sebastian Huber |
rtems: Avoid Giant lock in rtems_object_set_name()
Update #2555.
5
@f009ed0
04/27/16 14:36:04 |
Sebastian Huber |
rtems: Avoid Giant lock for semaphores
Update #2555.
5
@c8982e5
04/26/16 19:20:31 |
Sebastian Huber |
posix: Simplify message queues
The mq_open() function returns a …
5
@6741d30a
04/27/16 04:49:59 |
Sebastian Huber |
rtems: Avoid Giant lock for message queues
Update #2555.
5
@99112f7
04/27/16 14:21:07 |
Sebastian Huber |
score: _CORE_message_queue_Submit()
Move lock acquire to caller of …
5
@b0eba5ed
04/27/16 14:20:05 |
Sebastian Huber |
5
@7580995
04/26/16 19:18:52 |
Sebastian Huber |
score: _CORE_message_queue_Close()
5
@9c3bae11
04/21/16 05:52:19 |
Sebastian Huber |
rtems: Avoid Giant lock for dual ported memory
There is no need for …
5
@f27383a
04/20/16 12:01:02 |
Sebastian Huber |
score: Avoid Giant lock for barriers
Use …
5
@4025a60f
04/19/16 15:02:54 |
Sebastian Huber |
score: Avoid Giant lock for CORE mtx/sem
Avoid Giant lock for CORE …
5
@3d0c4005
04/19/16 13:07:39 |
Sebastian Huber |
score: Rename _CORE_barrier_Wait()
Rename _CORE_barrier_Wait() into …
5
@242a05a
04/19/16 13:04:34 |
Sebastian Huber |
score: Rename _MRSP_Obtain()
Rename _MRSP_Obtain() into …
5
@88575577
04/19/16 12:14:31 |
Sebastian Huber |
Make the id the first parameter …
5
@d7a12be9
04/19/16 12:14:10 |
Sebastian Huber |
score: Optimize _Objects_Get_no_protection()
Make the id the first …
5
@f05eeb2
04/19/16 11:39:00 |
Sebastian Huber |
score: Simplify _Objects_Initialize_information()
Remove unused …
5
@adbedd1
04/15/16 19:18:26 |
Sebastian Huber |
score: Introduce _Thread_queue_Flush_critical()
Replace …
5
@8765c57
04/18/16 05:00:55 |
Sebastian Huber |
score: Remove id parameter _CORE_mutex_Seize()
Parameter was unused.
5
