Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit/rtems
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @0b713f89   05/30/16 04:59:55 Sebastian Huber score: Rework CORE inherit priority mutex Provide dedicated seize and … 5
(edit) @33e250c9   05/27/16 13:41:41 Sebastian Huber score: Rework CORE priority ceiling mutex Rework seize and surrender … 5
(edit) @5a598ac   05/27/16 06:02:03 Sebastian Huber score: Add CORE mutex variants Add CORE_recursive_mutex_Control and … 5
(edit) @bac50cfc   05/30/16 08:51:29 Sebastian Huber rtems: Remove superfluous includes 5
(edit) @3c1ad257   05/27/16 07:41:18 Sebastian Huber rtems: Simplify rtems_semaphore_delete() Due to the unified status … 5
(edit) @8a77ef63   05/27/16 07:34:17 Sebastian Huber rtems: Simplify rtems_semaphore_flush() Due to the unified status … 5
(edit) @09c5ca4   05/26/16 20:29:56 Sebastian Huber score: Simplify CORE mutex Remove superfluous support for simple … 5
(edit) @2581a56   05/20/16 19:39:56 Sebastian Huber score: Add semaphore variants 5
(edit) @3ca6e618   05/25/16 14:49:53 Sebastian Huber rtems: Simplify rtems_semaphore_delete() 5
(edit) @af746b0   05/25/16 14:30:23 Sebastian Huber score: Use thread queue lock for MrsP Replace the ISR lock in … 5
(edit) @93306058   05/27/16 12:43:19 Sebastian Huber score: _CORE_mutex_Check_dispatch_for_seize() Move the safety check … 5
(edit) @0e1d11f3   05/27/16 11:26:53 Sebastian Huber score: Add _Thread_queue_Context_set_MP_callout() Add … 5
(edit) @dce48791   05/23/16 11:37:59 Sebastian Huber score: Add Status_Control for all APIs Unify the status codes of the … 5
(edit) @39bcf741   05/25/16 12:23:48 Sebastian Huber Fix semaphore post overflow status Close #2720. 5
(edit) @631b3c8   05/23/16 09:40:18 Sebastian Huber score: Move thread queue MP callout to context Drop the … 5
(edit) @c3d8d9e   05/23/16 04:55:49 Sebastian Huber score: Get rid of mp_id parameter Get rid of the mp_id parameter used … 5
(edit) @8866e62   05/23/16 04:26:58 Sebastian Huber score: Move thread queue object support 5
(edit) @24d0ee57   05/20/16 08:39:50 Chris Johns cpukit, testsuite: Add rtems_printf and rtems_printer support. This … 5
(edit) @16dbcdcd   05/23/16 09:42:41 Sebastian Huber score: _CORE_message_queue_Seize() Delete unused parameter. 5
(edit) @7af4d67   05/24/16 10:00:32 Sebastian Huber mpci: Add missing return statements 5
(edit) @bdb3b7f   05/20/16 13:52:27 Sebastian Huber score: _CORE_semaphore_Seize() Delete unused parameter. 5
(edit) @e266d13   05/20/16 13:10:27 Sebastian Huber Replace *_Get_interrupt_disable() with *_Get() Uniformly use *_Get() … 5
(edit) @582bb23c   05/20/16 13:04:16 Sebastian Huber score: Rename _Objects_Get_local() Rename _Objects_Get_local() into … 5
(edit) @62c528e6   05/20/16 12:59:30 Sebastian Huber rtems: _Semaphore_Get_interrupt_disable() Use _Objects_Get_local() … 5
(edit) @641b44c2   05/20/16 12:21:12 Sebastian Huber rtems: _Message_queue_Get_interrupt_disable() Use … 5
(edit) @0a00b2b   05/20/16 11:24:11 Sebastian Huber rtems: Remove location from _Partition_Get() Use _Objects_Get_local() … 5
(edit) @516ee75   05/20/16 12:23:56 Sebastian Huber mpci: Delete unused region support 5
(edit) @7dfb4b9   05/19/16 09:20:58 Sebastian Huber score: Add per scheduler instance maximum priority The priority … 5
(edit) @c2f301b5   05/18/16 06:08:38 Sebastian Huber score: Rename _ISR_Flash() into _ISR_Local_flash() This is a … 5
(edit) @24713163   05/18/16 06:06:54 Sebastian Huber score: Rename _ISR_Disable() and _ISR_Enable() Rename _ISR_Disable() … 5
(edit) @4b04cb61   05/18/16 06:03:05 Sebastian Huber score: Rename _ISR_Disable_without_giant() Rename … 5
(edit) @f36ada32   05/17/16 12:38:57 Sebastian Huber rtems: Avoid Giant lock for rtems_task_delete() Update #2555. 5
(edit) @33829ce   05/13/16 12:07:23 Sebastian Huber score: Avoid Giant lock for _Thread_Start() Update #2555. 5
(edit) @54550e04   05/13/16 06:16:30 Sebastian Huber posix: Rework pthread_join() Rework pthread_join() to use … 5
(edit) @9388390   05/13/16 05:04:43 Sebastian Huber score: Split _Thread_Restart() Split _Thread_Restart() into … 5
(edit) @270394e   05/12/16 12:25:50 Sebastian Huber score: Avoid superfluous life protection Disable thread dispatching … 5
(edit) @b7f5e391   05/12/16 04:12:06 Sebastian Huber score: Add _Thread_Exit() The goal is to make _Thread_Exit() a … 5
(edit) @0727760   05/12/16 09:22:33 Sebastian Huber rtems: Add rtems_interrupt_lock_interrupt_disable Update #2707. 5
(edit) @ef6f8a83   05/11/16 12:03:23 Sebastian Huber score: Avoid Giant lock for scheduler set/get Update #2555. 5
(edit) @d9952999   05/11/16 09:06:51 Sebastian Huber score: Avoid Giant lock _Scheduler_Get_affinity() Update #2555. 5
(edit) @e135271   05/11/16 08:58:59 Sebastian Huber score: Avoid Giant lock _Scheduler_Set_affinity() Update #2555. 5
(edit) @bd12dda   05/11/16 09:54:49 Sebastian Huber score: Use thread state lock for current state In addition protect … 5
(edit) @11c66437   05/11/16 08:27:37 Sebastian Huber rtems: Avoid Giant lock rtems_task_is_suspended() Update #2555. 5
(edit) @4d76300a   05/11/16 08:21:57 Sebastian Huber rtems: Avoid Giant lock for some task operations Avoid Giant lock for … 5
(edit) @105b4e6   05/10/16 04:47:19 Sebastian Huber rtems: Use thread state lock for signals 5
(edit) @6e4f929   05/06/16 04:44:41 Sebastian Huber score: Introduce thread state lock Update #2556. 5
(edit) @a0162bf   05/04/16 14:02:39 Sebastian Huber mpci: Delete unused region support 5
(edit) @bb2ad039   05/04/16 08:09:45 Sebastian Huber rtems: Avoid Giant lock for signals Update #2555. 5
(edit) @a0dee7c7   05/03/16 07:59:50 Sebastian Huber score: Simplify _Thread_Get_interrupt_disable() Remove the object … 5
(edit) @49a134dd   05/03/16 07:59:06 Sebastian Huber rtems: Return status in _Event_Surrender() 5
(edit) @1d40d81b   05/03/16 05:38:19 Sebastian Huber rtems: Remove task variables Update #2494. Update #2555. 5
(edit) @0a68d8e   05/01/16 14:11:30 Sebastian Huber score: Optimize _Objects_Get_local() Make the interrupt lock context … 5
(edit) @e38a92b   05/02/16 04:30:49 Sebastian Huber mpci: Make _*_MP_Get_packet() static 5
(edit) @c506158c   05/02/16 04:17:07 Sebastian Huber mpci: Make _*_MP_Send_response_packet() static 5
(edit) @500a8e9c   04/28/16 04:26:01 Sebastian Huber score: Delete RTEMS_STRICT_ORDER_MUTEX Remove support for strict … 5
(edit) @1ef8e4a8   04/27/16 20:07:56 Sebastian Huber score: Avoid Giant lock for set time of day Update #2555. Update #2630. 5
(edit) @3888771   04/27/16 19:32:23 Sebastian Huber score: Streamline set time of day functions Rename _TOD_Set() into … 5
(edit) @f4d541cc   04/27/16 14:46:57 Sebastian Huber rtems: Avoid Giant lock in rtems_object_set_name() Update #2555. 5
(edit) @f009ed0   04/27/16 14:36:04 Sebastian Huber rtems: Avoid Giant lock for semaphores Update #2555. 5
(edit) @c8982e5   04/26/16 19:20:31 Sebastian Huber posix: Simplify message queues The mq_open() function returns a … 5
(edit) @6741d30a   04/27/16 04:49:59 Sebastian Huber rtems: Avoid Giant lock for message queues Update #2555. 5
(edit) @99112f7   04/27/16 14:21:07 Sebastian Huber score: _CORE_message_queue_Submit() Move lock acquire to caller of … 5
(edit) @b0eba5ed   04/27/16 14:20:05 Sebastian Huber score: _CORE_message_queue_Seize() Move lock acquire to caller of … 5
(edit) @7580995   04/26/16 19:18:52 Sebastian Huber score: _CORE_message_queue_Close() Move lock acquire to caller of … 5
(edit) @9c3bae11   04/21/16 05:52:19 Sebastian Huber rtems: Avoid Giant lock for dual ported memory There is no need for … 5
(edit) @f27383a   04/20/16 12:01:02 Sebastian Huber score: Avoid Giant lock for barriers Use … 5
(edit) @4025a60f   04/19/16 15:02:54 Sebastian Huber score: Avoid Giant lock for CORE mtx/sem Avoid Giant lock for CORE … 5
(edit) @3d0c4005   04/19/16 13:07:39 Sebastian Huber score: Rename _CORE_barrier_Wait() Rename _CORE_barrier_Wait() into … 5
(edit) @242a05a   04/19/16 13:04:34 Sebastian Huber score: Rename _MRSP_Obtain() Rename _MRSP_Obtain() into … 5
(edit) @88575577   04/19/16 12:14:31 Sebastian Huber score: Optimize _Objects_Get_local() Make the id the first parameter … 5
(edit) @d7a12be9   04/19/16 12:14:10 Sebastian Huber score: Optimize _Objects_Get_no_protection() Make the id the first … 5
(edit) @f05eeb2   04/19/16 11:39:00 Sebastian Huber score: Simplify _Objects_Initialize_information() Remove unused … 5
(edit) @adbedd1   04/15/16 19:18:26 Sebastian Huber score: Introduce _Thread_queue_Flush_critical() Replace … 5
(edit) @8765c57   04/18/16 05:00:55 Sebastian Huber score: Remove id parameter _CORE_mutex_Seize() Parameter was unused. 5
(edit) @ca18cb59   04/18/16 04:53:10 Sebastian Huber score: Close semaphore object before flush This prevents use of the … 5
(edit) @90f1265e   04/18/16 04:23:27 Sebastian Huber score: Fix _CORE_semaphore_Flush() Use proper CORE_semaphore_Status … 5
(edit) @928d455   04/17/16 13:57:19 Sebastian Huber score: Close barrier object before flush This prevents use of the … 5
(edit) @e781ddb   04/17/16 13:57:03 Sebastian Huber score: Simplify _CORE_barrier_Flush() 5
(edit) @5cc6bf4   04/17/16 13:47:33 Sebastian Huber score: Simplify _CORE_message_queue_Close() Drop status parameter … 5
(edit) @e65c45c   03/22/16 22:13:30 joel Obsolete rtems_clock_get() directive. This service was marked as … 5
(edit) @c39da818   04/08/16 06:14:31 Sebastian Huber rtems: Delete Region_Control::page_size 5
(edit) @60a23875   04/08/16 06:13:49 Sebastian Huber rtems: Delete Region_Control::length 5
(edit) @acf7cf3b   04/08/16 06:12:06 Sebastian Huber rtems: Delete Region_Control::starting_address 5
(edit) @b4b062f   04/08/16 05:50:42 Sebastian Huber rtems: Delete Region_Control::number_of_used_blocks Use … 5
(edit) @1142f55   04/08/16 04:56:46 Sebastian Huber rtems: Add and use _Region_Get_and_lock() Get region and lock … 5
(edit) @572cb624   04/07/16 14:48:30 Sebastian Huber score: Simplify _Objects_Get_no_protection() This functions supports … 5
(edit) @0158a60   04/08/16 04:28:04 Sebastian Huber rtems: Ensure lock ownership for _Region_Get() 5
(edit) @d26b053   04/07/16 14:49:22 Sebastian Huber rtems: Remove dead code The heap protection enabled by RTEMS_DEBUG … 5
(edit) @3570ec6   04/04/16 08:13:35 Sebastian Huber rtems: Avoid Giant lock for partitions Use an ISR lock to protect the … 5
(edit) @8f96581   04/01/16 09:38:47 Sebastian Huber score: Rework MP thread queue callout support The thread queue … 5
(edit) @9809d6e0   03/30/16 09:39:58 Sebastian Huber score: _Thread_queue_Flush() parameter changes Change … 5
(edit) @97312fcc   04/05/16 12:36:30 Sebastian Huber score: Delete Thread_Wait_information::id This field was only by the … 5
(edit) @9d9b6b56   03/30/16 06:36:08 Sebastian Huber score: Objects_Thread_queue_Extract_callout Change parameters of the … 5
(edit) @06f68a96   03/30/16 06:34:23 Sebastian Huber score: Fix set but not used warning 5
(edit) @863c074   03/30/16 06:33:41 Sebastian Huber score: Fix statement with no effect warning No need to add an assert … 5
(edit) @97b7244   03/30/16 06:32:56 Sebastian Huber score: Fix statement with no effect warning No need to add an assert … 5
(edit) @9f71433   03/30/16 06:31:26 Sebastian Huber score: Fix statement with no effect warning No need to add an assert … 5
(edit) @8afeb993   03/30/16 06:29:07 Sebastian Huber score: Fix statement with no effect warning No need to add an assert … 5
(edit) @081d03d   03/30/16 06:08:44 Sebastian Huber score: Fix set but not used warning No need to add an assert due to … 5
(edit) @75c19d25   03/30/16 06:05:54 Sebastian Huber score: Fix set but not used warning 5
