# # ChangeLog for cpukit/rtems in rtems # # Generated by Trac 1.2.1.dev0 # 05/31/24 14:11:35 Fri, 06 Oct 2017 07:42:32 GMT Sebastian Huber [900fda45] * cpukit/rtems/src/ratemonreportstatistics.c (modified) rtems: Fix format warnings Update #3111. Wed, 27 Sep 2017 13:08:33 GMT Sebastian Huber [de59c065] * c/src/ada-tests/mptests/mp01/config_base.h (modified) * c/src/ada-tests/mptests/mp03/config_base.h (modified) * c/src/ada-tests/mptests/mp04/config_base.h (modified) * c/src/ada-tests/mptests/mp05/config_base.h (modified) * c/src/ada-tests/mptests/mp06/config_base.h (modified) * c/src/ada-tests/mptests/mp07/config_base.h (modified) * c/src/ada-tests/mptests/mp08/config_base.h (modified) * c/src/ada-tests/mptests/mp09/config_base.h (modified) * c/src/ada-tests/mptests/mp10/config_base.h (modified) * c/src/ada-tests/mptests/mp11/config_base.h (modified) * c/src/ada-tests/mptests/mp12/config_base.h (modified) * c/src/ada-tests/mptests/mp13/config_base.h (modified) * c/src/ada-tests/mptests/mp14/config_base.h (modified) * c/src/ada-tests/samples/base_mp/config.h (modified) * c/src/ada-tests/samples/base_sp/config.h (modified) * c/src/ada-tests/samples/hello/config.h (modified) * c/src/ada-tests/samples/nsecs/config.h (modified) * c/src/ada-tests/samples/ticker/config.h (modified) * c/src/ada-tests/sptests/sp01/config.h (modified) * c/src/ada-tests/sptests/sp02/config.h (modified) * c/src/ada-tests/sptests/sp03/config.h (modified) * c/src/ada-tests/sptests/sp04/config.h (modified) * c/src/ada-tests/sptests/sp05/config.h (modified) * c/src/ada-tests/sptests/sp06/config.h (modified) * c/src/ada-tests/sptests/sp07/config.h (modified) * c/src/ada-tests/sptests/sp08/config.h (modified) * c/src/ada-tests/sptests/sp09/config.h (modified) * c/src/ada-tests/sptests/sp11/config.h (modified) * c/src/ada-tests/sptests/sp12/config.h (modified) * c/src/ada-tests/sptests/sp13/config.h (modified) * c/src/ada-tests/sptests/sp14/config.h (modified) * c/src/ada-tests/sptests/sp15/config.h (modified) * c/src/ada-tests/sptests/sp16/config.h (modified) * c/src/ada-tests/sptests/sp17/config.h (modified) * c/src/ada-tests/sptests/sp19/config.h (modified) * c/src/ada-tests/sptests/sp20/config.h (modified) * c/src/ada-tests/sptests/sp22/config.h (modified) * c/src/ada-tests/sptests/sp23/config.h (modified) * c/src/ada-tests/sptests/sp24/config.h (modified) * c/src/ada-tests/sptests/sp25/config.h (modified) * c/src/ada-tests/sptests/spname01/config.h (modified) * c/src/ada-tests/tmtests/tm01/config.h (modified) * c/src/ada-tests/tmtests/tm02/config.h (modified) * c/src/ada-tests/tmtests/tm03/config.h (modified) * c/src/ada-tests/tmtests/tm04/config.h (modified) * c/src/ada-tests/tmtests/tm05/config.h (modified) * c/src/ada-tests/tmtests/tm06/config.h (modified) * c/src/ada-tests/tmtests/tm07/config.h (modified) * c/src/ada-tests/tmtests/tm08/config.h (modified) * c/src/ada-tests/tmtests/tm09/config.h (modified) * c/src/ada-tests/tmtests/tm10/config.h (modified) * c/src/ada-tests/tmtests/tm11/config.h (modified) * c/src/ada-tests/tmtests/tm12/config.h (modified) * c/src/ada-tests/tmtests/tm13/config.h (modified) * c/src/ada-tests/tmtests/tm14/config.h (modified) * c/src/ada-tests/tmtests/tm15/config.h (modified) * c/src/ada-tests/tmtests/tm16/config.h (modified) * c/src/ada-tests/tmtests/tm17/config.h (modified) * c/src/ada-tests/tmtests/tm18/config.h (modified) * c/src/ada-tests/tmtests/tm19/config.h (modified) * c/src/ada-tests/tmtests/tm20/config.h (modified) * c/src/ada-tests/tmtests/tm21/config.h (modified) * c/src/ada-tests/tmtests/tm22/config.h (modified) * c/src/ada-tests/tmtests/tm23/config.h (modified) * c/src/ada-tests/tmtests/tm24/config.h (modified) * c/src/ada-tests/tmtests/tm25/config.h (modified) * c/src/ada-tests/tmtests/tm28/config.h (modified) * c/src/ada-tests/tmtests/tm29/config.h (modified) * c/src/ada-tests/tmtests/tmck/config.h (modified) * c/src/ada-tests/tmtests/tmoverhd/config.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (deleted) * cpukit/posix/include/rtems/posix/muteximpl.h (modified) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/mutex.c (deleted) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexget.c (deleted) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/muteximpl.h (added) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/mutex.c (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/psx05.scn (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psxaio01/system.h (modified) * testsuites/psxtests/psxaio02/system.h (modified) * testsuites/psxtests/psxaio03/system.h (modified) * testsuites/psxtests/psxautoinit01/init.c (modified) * testsuites/psxtests/psxautoinit01/psxautoinit01.scn (modified) * testsuites/psxtests/psxautoinit02/init.c (modified) * testsuites/psxtests/psxcleanup/system.h (modified) * testsuites/psxtests/psxcond01/init.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxkey07/init.c (modified) * testsuites/psxtests/psxsignal06/init.c (modified) * testsuites/psxtests/psxtimer01/system.h (modified) * testsuites/psxtmtests/psxtmcond03/init.c (modified) * testsuites/psxtmtests/psxtmcond04/init.c (modified) * testsuites/psxtmtests/psxtmcond06/init.c (modified) * testsuites/psxtmtests/psxtmcond07/init.c (modified) * testsuites/psxtmtests/psxtmcond08/init.c (modified) * testsuites/psxtmtests/psxtmmutex01/init.c (modified) * testsuites/psxtmtests/psxtmmutex02/init.c (modified) * testsuites/psxtmtests/psxtmmutex03/init.c (modified) * testsuites/psxtmtests/psxtmmutex04/init.c (modified) * testsuites/psxtmtests/psxtmmutex05/init.c (modified) * testsuites/psxtmtests/psxtmmutex06/init.c (modified) * testsuites/psxtmtests/psxtmmutex07/init.c (modified) * testsuites/smptests/smppsxmutex01/init.c (modified) * testsuites/sptests/spmutex01/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) * testsuites/sptests/spthreadq01/init.c (modified) posix: Implement self-contained POSIX mutex POSIX mutexes are now ... Tue, 26 Sep 2017 05:49:17 GMT Sebastian Huber [5222488] * c/src/ada-tests/mptests/mp01/config_base.h (modified) * c/src/ada-tests/mptests/mp03/config_base.h (modified) * c/src/ada-tests/mptests/mp04/config_base.h (modified) * c/src/ada-tests/mptests/mp05/config_base.h (modified) * c/src/ada-tests/mptests/mp06/config_base.h (modified) * c/src/ada-tests/mptests/mp07/config_base.h (modified) * c/src/ada-tests/mptests/mp08/config_base.h (modified) * c/src/ada-tests/mptests/mp09/config_base.h (modified) * c/src/ada-tests/mptests/mp10/config_base.h (modified) * c/src/ada-tests/mptests/mp11/config_base.h (modified) * c/src/ada-tests/mptests/mp12/config_base.h (modified) * c/src/ada-tests/mptests/mp13/config_base.h (modified) * c/src/ada-tests/mptests/mp14/config_base.h (modified) * c/src/ada-tests/samples/base_mp/config.h (modified) * c/src/ada-tests/samples/base_sp/config.h (modified) * c/src/ada-tests/samples/hello/config.h (modified) * c/src/ada-tests/samples/nsecs/config.h (modified) * c/src/ada-tests/samples/ticker/config.h (modified) * c/src/ada-tests/sptests/sp01/config.h (modified) * c/src/ada-tests/sptests/sp02/config.h (modified) * c/src/ada-tests/sptests/sp03/config.h (modified) * c/src/ada-tests/sptests/sp04/config.h (modified) * c/src/ada-tests/sptests/sp05/config.h (modified) * c/src/ada-tests/sptests/sp06/config.h (modified) * c/src/ada-tests/sptests/sp07/config.h (modified) * c/src/ada-tests/sptests/sp08/config.h (modified) * c/src/ada-tests/sptests/sp09/config.h (modified) * c/src/ada-tests/sptests/sp11/config.h (modified) * c/src/ada-tests/sptests/sp12/config.h (modified) * c/src/ada-tests/sptests/sp13/config.h (modified) * c/src/ada-tests/sptests/sp14/config.h (modified) * c/src/ada-tests/sptests/sp15/config.h (modified) * c/src/ada-tests/sptests/sp16/config.h (modified) * c/src/ada-tests/sptests/sp17/config.h (modified) * c/src/ada-tests/sptests/sp19/config.h (modified) * c/src/ada-tests/sptests/sp20/config.h (modified) * c/src/ada-tests/sptests/sp22/config.h (modified) * c/src/ada-tests/sptests/sp23/config.h (modified) * c/src/ada-tests/sptests/sp24/config.h (modified) * c/src/ada-tests/sptests/sp25/config.h (modified) * c/src/ada-tests/sptests/spname01/config.h (modified) * c/src/ada-tests/tmtests/tm01/config.h (modified) * c/src/ada-tests/tmtests/tm02/config.h (modified) * c/src/ada-tests/tmtests/tm03/config.h (modified) * c/src/ada-tests/tmtests/tm04/config.h (modified) * c/src/ada-tests/tmtests/tm05/config.h (modified) * c/src/ada-tests/tmtests/tm06/config.h (modified) * c/src/ada-tests/tmtests/tm07/config.h (modified) * c/src/ada-tests/tmtests/tm08/config.h (modified) * c/src/ada-tests/tmtests/tm09/config.h (modified) * c/src/ada-tests/tmtests/tm10/config.h (modified) * c/src/ada-tests/tmtests/tm11/config.h (modified) * c/src/ada-tests/tmtests/tm12/config.h (modified) * c/src/ada-tests/tmtests/tm13/config.h (modified) * c/src/ada-tests/tmtests/tm14/config.h (modified) * c/src/ada-tests/tmtests/tm15/config.h (modified) * c/src/ada-tests/tmtests/tm16/config.h (modified) * c/src/ada-tests/tmtests/tm17/config.h (modified) * c/src/ada-tests/tmtests/tm18/config.h (modified) * c/src/ada-tests/tmtests/tm19/config.h (modified) * c/src/ada-tests/tmtests/tm20/config.h (modified) * c/src/ada-tests/tmtests/tm21/config.h (modified) * c/src/ada-tests/tmtests/tm22/config.h (modified) * c/src/ada-tests/tmtests/tm23/config.h (modified) * c/src/ada-tests/tmtests/tm24/config.h (modified) * c/src/ada-tests/tmtests/tm25/config.h (modified) * c/src/ada-tests/tmtests/tm28/config.h (modified) * c/src/ada-tests/tmtests/tm29/config.h (modified) * c/src/ada-tests/tmtests/tmck/config.h (modified) * c/src/ada-tests/tmtests/tmoverhd/config.h (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/cond.h (deleted) * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/cond.c (deleted) * cpukit/posix/src/conddestroy.c (modified) * cpukit/posix/src/condget.c (deleted) * cpukit/posix/src/condinit.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condwait.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * testsuites/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/psx10.scn (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psxaio01/system.h (modified) * testsuites/psxtests/psxaio02/system.h (modified) * testsuites/psxtests/psxaio03/system.h (modified) * testsuites/psxtests/psxautoinit02/init.c (modified) * testsuites/psxtests/psxautoinit02/psxautoinit02.scn (modified) * testsuites/psxtests/psxcleanup/system.h (modified) * testsuites/psxtests/psxcond01/init.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxkey07/init.c (modified) * testsuites/psxtests/psxsignal06/init.c (modified) * testsuites/psxtests/psxtimer01/system.h (modified) * testsuites/psxtmtests/psxtmcond01/init.c (modified) * testsuites/psxtmtests/psxtmcond02/init.c (modified) * testsuites/psxtmtests/psxtmcond03/init.c (modified) * testsuites/psxtmtests/psxtmcond04/init.c (modified) * testsuites/psxtmtests/psxtmcond05/init.c (modified) * testsuites/psxtmtests/psxtmcond06/init.c (modified) * testsuites/psxtmtests/psxtmcond07/init.c (modified) * testsuites/psxtmtests/psxtmcond08/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) * testsuites/sptests/spthreadq01/init.c (modified) posix: Implement self-contained POSIX condvar POSIX condition ... Thu, 21 Sep 2017 13:42:45 GMT Sebastian Huber [89fc9345] * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/rwlock.h (deleted) * cpukit/posix/include/rtems/posix/rwlockimpl.h (modified) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/prwlock.c (deleted) * cpukit/posix/src/prwlockdestroy.c (modified) * cpukit/posix/src/prwlockinit.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/corerwlock.h (deleted) * cpukit/score/include/rtems/score/corerwlockimpl.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxrwlock01/main.c (modified) * testsuites/psxtests/psxrwlock01/psxrwlock01.scn (modified) * testsuites/psxtests/psxrwlock01/test.c (modified) * testsuites/psxtmtests/psxtmrwlock01/init.c (modified) * testsuites/psxtmtests/psxtmrwlock02/init.c (modified) * testsuites/psxtmtests/psxtmrwlock03/init.c (modified) * testsuites/psxtmtests/psxtmrwlock04/init.c (modified) * testsuites/psxtmtests/psxtmrwlock05/init.c (modified) * testsuites/psxtmtests/psxtmrwlock06/init.c (modified) * testsuites/psxtmtests/psxtmrwlock07/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) * testsuites/sptests/spthreadq01/init.c (modified) posix: Implement self-contained POSIX rwlocks POSIX rwlocks are now ... Thu, 21 Sep 2017 12:13:16 GMT Sebastian Huber [e67929c] * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/barrier.h (deleted) * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/pbarrier.c (deleted) * cpukit/posix/src/pbarrierdestroy.c (modified) * cpukit/posix/src/pbarrierinit.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * testsuites/psxtests/psxbarrier01/main.c (modified) * testsuites/psxtests/psxbarrier01/psxbarrier01.scn (modified) * testsuites/psxtests/psxbarrier01/test.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtmtests/psxtmbarrier01/init.c (modified) * testsuites/psxtmtests/psxtmbarrier02/init.c (modified) * testsuites/psxtmtests/psxtmbarrier03/init.c (modified) * testsuites/psxtmtests/psxtmbarrier04/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) posix: Implement self-contained POSIX barriers POSIX barriers are ... Tue, 11 Jul 2017 06:48:15 GMT Sebastian Huber [a961e198] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) Add interrupt server suspend/resume This mechanism can be used to ... Tue, 11 Jul 2017 07:51:43 GMT Sebastian Huber [ecabd384] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (added) * testsuites/smptests/smpscheduler02/init.c (modified) * testsuites/sptests/spscheduler01/init.c (modified) rtems: Add rtems_scheduler_ident_by_processor_set Update #3070. Tue, 11 Jul 2017 05:24:39 GMT Sebastian Huber [548d65a5] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (added) * testsuites/smptests/smpfatal04/init.c (modified) * testsuites/sptests/spscheduler01/init.c (modified) rtems: Add rtems_scheduler_ident_by_processor() Update #3069. Tue, 11 Jul 2017 11:51:10 GMT Sebastian Huber [3b14e7aa] * cpukit/rtems/src/schedulerremoveprocessor.c (modified) rtems: Fix warning Update #3059. Mon, 03 Jul 2017 08:38:31 GMT Sebastian Huber [1ec9c86] * cpukit/rtems/src/schedulerremoveprocessor.c (modified) rtems: Fix rtems_scheduler_remove_processor() Account for the ... Tue, 04 Jul 2017 05:28:44 GMT Sebastian Huber [6b1d8c7] * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/src/smp.c (modified) score: Add processor set to scheduler context Replace the simple ... Mon, 24 Apr 2017 01:35:41 GMT Joel Sherrill [a300ca1b] * cpukit/rtems/src/ratemonreportstatistics.c (modified) ratemonreportstatistics.c: Fix printf() warnings so clean on 32 and ... Tue, 28 Mar 2017 06:18:06 GMT Sebastian Huber [70ddaa0e] * cpukit/rtems/src/semsetpriority.c (modified) rtems: Fix error return path Thu, 02 Feb 2017 08:16:53 GMT Sebastian Huber [6dd96af] * cpukit/rtems/include/rtems.h (modified) rtems: Fix RTEMS_NO_TIMEOUT define Cast the internal ... Wed, 01 Feb 2017 12:00:15 GMT Sebastian Huber [70f559d8] * cpukit/rtems/include/rtems/rtems/tasks.h (modified) rtems: Fix RTEMS_MAXIMUM_PRIORITY define Cast the internal ... Tue, 31 Jan 2017 07:08:24 GMT Sebastian Huber [e366f77] * cpukit/libcsupport/src/assocthreadstatestostring.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) score: Add _Thread_queue_Object_name Add the special thread queue ... Fri, 27 Jan 2017 22:15:50 GMT Kuan-Hsun Chen [0794197] * cpukit/rtems/src/ratemontimeout.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sprmsched02/Makefile.am (added) * testsuites/sptests/sprmsched02/init.c (added) * testsuites/sptests/sprmsched02/sprmsched02.doc (added) * testsuites/sptests/sprmsched02/sprmsched02.scn (added) rtems: Fix _Rate_monotonic_Renew_deadline() Prepare a precondition ... Wed, 25 Jan 2017 20:47:48 GMT Kuan-Hsun Chen [d7feb86] * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * testsuites/sptests/sp69/init.c (modified) * testsuites/sptests/sp69/sp69.doc (modified) * testsuites/sptests/sp69/sp69.scn (modified) Remove rtems_rate_monotonic_postponed_job_count() Add a variable ... Tue, 24 Jan 2017 14:05:22 GMT Sebastian Huber [b8d6eb7] * cpukit/rtems/src/ratemonperiod.c (modified) rtems: rtems_rate_monotonic_postponed_job_count() Use proper ... Tue, 24 Jan 2017 14:04:11 GMT Sebastian Huber [625bd6a] * cpukit/rtems/src/ratemonperiod.c (modified) rtems: Fix _Rate_monotonic_Release_postponed_job() Use proper ... Tue, 24 Jan 2017 13:37:42 GMT Sebastian Huber [1240aade] * cpukit/rtems/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) rtems: Fix _Rate_monotonic_Renew_deadline() Make ... Fri, 13 Jan 2017 18:54:11 GMT Gedare Bloom [cb2cbec] * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * testsuites/sptests/spedfsched04/spedfsched04.doc (modified) * testsuites/sptests/sprmsched01/sprmsched01.doc (modified) classic: adjust names of RM postponed job functions closes #2795 Wed, 21 Dec 2016 16:42:39 GMT Kuan-Hsun Chen [3a46b72] * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) Enhancement of the RMS manager for the overrun handling. Three ... Fri, 12 Aug 2016 19:25:10 GMT Gedare Bloom [ba776282] * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/shm.h (added) * cpukit/posix/include/rtems/posix/shmimpl.h (added) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/shm.c (added) * cpukit/posix/src/shmheap.c (added) * cpukit/posix/src/shmopen.c (modified) * cpukit/posix/src/shmunlink.c (modified) * cpukit/posix/src/shmwkspace.c (added) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxshm01/Makefile.am (added) * testsuites/psxtests/psxshm01/init.c (added) * testsuites/psxtests/psxshm01/psxshm01.scn (added) * testsuites/psxtests/psxshm01/system.h (added) * testsuites/psxtests/psxshm02/Makefile.am (added) * testsuites/psxtests/psxshm02/init.c (added) * testsuites/psxtests/psxshm02/psxshm02.scn (added) * testsuites/psxtests/psxshm02/system.h (added) * testsuites/sptests/spsysinit01/init.c (modified) posix: shared memory support Add POSIX shared memory manager (Shm). ... Thu, 12 Jan 2017 06:53:12 GMT Sebastian Huber [96bb2e4b] * cpukit/rtems/src/rtemsobjectgetname.c (modified) rtems: Use header file for rtems_object_get_name() Wed, 11 Jan 2017 07:42:04 GMT Sebastian Huber [d063e7b3] * cpukit/libdebugger/rtems-debugger-threads.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) score: Replace STATES_DELAYING Replace STATES_DELAYING with ... Wed, 11 Jan 2017 15:43:06 GMT Joel Sherrill [7a4b2645] * cpukit/configure.ac (modified) * cpukit/posix/include/rtems/posix/pthreadimpl.h (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadattrcompare.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/taskgetaffinity.c (modified) * cpukit/rtems/src/tasksetaffinity.c (modified) * cpukit/score/include/rtems/score/cpuset.h (modified) * cpukit/score/include/rtems/score/cpusetimpl.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/src/cpuset.c (modified) * cpukit/score/src/cpusetprintsupport.c (modified) * cpukit/score/src/schedulergetaffinity.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spcpuset01/init.c (modified) * testsuites/sptests/spcpuset01/system.h (modified) * testsuites/sptests/spcpuset01/test.c (modified) * testsuites/sptests/spscheduler01/init.c (modified) Remove obsolete __RTEMS_HAVE_SYS_CPUSET_H__ Fri, 09 Dec 2016 06:19:22 GMT Sebastian Huber [3a659b04] * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/wkspace.c (modified) score: Introduce _Internal_error() Fri, 09 Dec 2016 05:49:25 GMT Sebastian Huber [279d5260] * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spfatal01/testcase.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) Add INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED Update #2825. Thu, 08 Dec 2016 15:41:30 GMT Sebastian Huber [b6606e8] * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/src/exshutdown.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/fatal2.c (deleted) * cpukit/sapi/src/posixapi.c (modified) * cpukit/score/cpu/nios2/nios2-context-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) * cpukit/score/cpu/nios2/nios2-isr-set-level.c (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/devnullfatal01/testcase.h (modified) * testsuites/psxtests/psxfatal01/testcase.h (modified) * testsuites/psxtests/psxfatal02/testcase.h (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/sptests/spfatal01/testcase.h (modified) * testsuites/sptests/spfatal02/testcase.h (modified) * testsuites/sptests/spfatal03/testcase.h (modified) * testsuites/sptests/spfatal04/testcase.h (modified) * testsuites/sptests/spfatal05/testcase.h (modified) * testsuites/sptests/spfatal06/testcase.h (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spfatal08/testcase.h (modified) * testsuites/sptests/spfatal09/testcase.h (modified) * testsuites/sptests/spfatal10/testcase.h (modified) * testsuites/sptests/spfatal11/testcase.h (modified) * testsuites/sptests/spfatal12/testcase.h (modified) * testsuites/sptests/spfatal13/testcase.h (modified) * testsuites/sptests/spfatal14/testcase.h (modified) * testsuites/sptests/spfatal15/testcase.h (modified) * testsuites/sptests/spfatal16/testcase.h (modified) * testsuites/sptests/spfatal17/testcase.h (modified) * testsuites/sptests/spfatal18/testcase.h (modified) * testsuites/sptests/spfatal19/testcase.h (modified) * testsuites/sptests/spfatal20/testcase.h (modified) * testsuites/sptests/spfatal24/testcase.h (modified) * testsuites/sptests/spfatal25/testcase.h (modified) * testsuites/sptests/spfatal27/testcase.h (modified) * testsuites/sptests/spfatal28/testcase.h (modified) * testsuites/sptests/spfatal29/testcase.h (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Remove fatal is internal indicator The fatal is internal ... Fri, 02 Dec 2016 10:51:16 GMT Sebastian Huber [7da78cf] * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) rtems: Use _Thread_Dispatch_direct() Update #2797. Fri, 02 Dec 2016 10:18:32 GMT Sebastian Huber [d10716f] * cpukit/rtems/src/scheduleraddprocessor.c (modified) rtems: Fix rtems_scheduler_add_processor() Fix thread dispatch ... Thu, 01 Dec 2016 19:42:48 GMT Sebastian Huber [5b6c290] * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedprio.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadtimeout.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/sptests/spthreadq01/init.c (modified) score: Initialize thread queue context early Initialize thread ... Thu, 24 Nov 2016 05:13:11 GMT Sebastian Huber [620b23e] * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Optimize _Thread_queue_Enqueue() Move thread state for ... Wed, 16 Nov 2016 13:50:09 GMT Sebastian Huber [c42be504] * cpukit/configure.ac (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/spinlock.h (deleted) * cpukit/posix/include/rtems/posix/spinlockimpl.h (modified) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/pspin.c (deleted) * cpukit/posix/src/pspindestroy.c (modified) * cpukit/posix/src/pspininit.c (modified) * cpukit/posix/src/pspinlock.c (modified) * cpukit/posix/src/pspintrylock.c (deleted) * cpukit/posix/src/pspinunlock.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/corespinlock.h (deleted) * cpukit/score/include/rtems/score/corespinlockimpl.h (deleted) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/corespinlockrelease.c (deleted) * cpukit/score/src/corespinlockwait.c (deleted) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxspin01/main.c (modified) * testsuites/psxtests/psxspin01/psxspin01.scn (modified) * testsuites/psxtests/psxspin01/test.c (modified) * testsuites/psxtests/psxspin02/Makefile.am (deleted) * testsuites/psxtests/psxspin02/main.c (deleted) * testsuites/psxtests/psxspin02/psxspin02.doc (deleted) * testsuites/psxtests/psxspin02/psxspin02.scn (deleted) * testsuites/psxtests/psxspin02/test.c (deleted) * testsuites/sptests/spsysinit01/init.c (modified) posix: Add self-contained pthread spinlock Turn pthread_spinlock_t ... Tue, 22 Nov 2016 09:53:03 GMT Sebastian Huber [a4217c6] * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Rename _Thread_queue_Enqueue_critical() Delete unused ... Wed, 16 Nov 2016 15:39:43 GMT Sebastian Huber [125f248] * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/rtems/include/rtems/rtems/regionimpl.h (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/sptests/spfatal03/testcase.h (modified) score: Add thread queue enqueue callout Replace the expected thread ... Fri, 11 Nov 2016 09:51:25 GMT Sebastian Huber [141e16d] * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) rtems: Conditionally define rtems_interrupt_frame Update #2808. Mon, 14 Nov 2016 08:11:07 GMT Sebastian Huber [d78d529] * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/sched_yield.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal29/Makefile.am (added) * testsuites/sptests/spfatal29/spfatal29.doc (added) * testsuites/sptests/spfatal29/spfatal29.scn (added) * testsuites/sptests/spfatal29/testcase.h (added) * testsuites/sptests/spinternalerror02/init.c (modified) score: Add and use _Thread_Dispatch_direct() This function is ... Mon, 31 Oct 2016 12:08:33 GMT Sebastian Huber [05ca53d] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/scheduleraddprocessor.c (added) * cpukit/rtems/src/schedulerremoveprocessor.c (added) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersmpstartidle.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpscheduler02/init.c (modified) * testsuites/smptests/smpscheduler04/Makefile.am (added) * testsuites/smptests/smpscheduler04/init.c (added) * testsuites/smptests/smpscheduler04/smpscheduler04.doc (added) * testsuites/smptests/smpscheduler04/smpscheduler04.scn (added) * testsuites/sptests/spscheduler01/init.c (modified) rtems: Add scheduler processor add/remove Update #2797. Wed, 02 Nov 2016 05:36:13 GMT Sebastian Huber [2612a0b] * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/rtems/src/taskgetpriority.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * testsuites/smptests/smpscheduler02/init.c (modified) score: Simplify _Scheduler_Get_by_id() Avoid dead code in non-SMP ... Fri, 04 Nov 2016 14:26:52 GMT Sebastian Huber [2f5ac5b5] * cpukit/rtems/src/taskcreate.c (modified) rtems: Fix rtems_task_create() scheduler selection Use the home ... Mon, 31 Oct 2016 15:10:32 GMT Sebastian Huber [0dd49d0] * cpukit/rtems/src/semcreate.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/threadqenqueue.c (modified) score: Introduce thread resource count methods This makes it easier ... Thu, 03 Nov 2016 09:52:53 GMT Sebastian Huber [6e31b56f] * cpukit/rtems/src/semcreate.c (modified) * testsuites/tmtests/tm02/task1.c (modified) rtems: Fix binary semaphore resource count Binary semaphores (not ... Mon, 31 Oct 2016 07:33:11 GMT Sebastian Huber [2dd098a] * cpukit/libmisc/capture/capture.h (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedprio.c (modified) * cpukit/posix/src/sched_getprioritymax.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/taskgetscheduler.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/sched.c (modified) * cpukit/score/src/schedulergetaffinity.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * cpukit/score/src/threadgetcputimeused.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/task1.c (modified) score: Introduce Thread_Scheduler_control::home Replace ... Mon, 31 Oct 2016 12:37:59 GMT Sebastian Huber [d271c3bb] * cpukit/libcsupport/src/sync.c (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/taskiterate.c (added) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/iterateoverthreads.c (modified) * cpukit/score/src/threaditerate.c (added) * testsuites/sptests/sp41/init.c (modified) * testsuites/sptests/sp41/sp41.scn (modified) rtems: Add rtems_task_iterate() Update #2423. Tue, 27 Sep 2016 13:23:00 GMT Sebastian Huber [8797c76] * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) score: Unify CORE mutex seize/surrender Use the ... Thu, 08 Sep 2016 13:32:22 GMT Sebastian Huber [8123cae8] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/taskgetpriority.c (added) * testsuites/smptests/smpmutex01/init.c (modified) * testsuites/sptests/spscheduler01/init.c (modified) * testsuites/sptests/spscheduler01/spscheduler01.doc (modified) rtems: Add rtems_task_get_priority() Update #2556. Update #2784. Wed, 22 Jun 2016 15:09:23 GMT Sebastian Huber [300f6a48] * cpukit/libmisc/capture/capture.h (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/posix/include/rtems/posix/pthreadimpl.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedprio.c (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/mrsp.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/priorityimpl.h (added) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulernode.h (modified) * cpukit/score/include/rtems/score/schedulernodeimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsnodeinit.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/schedulerdefaultnodeinit.c (modified) * cpukit/score/src/schedulerdefaultreleasejob.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfnodeinit.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerpriority.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadqops.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadsetpriority.c (deleted) * cpukit/score/src/threadtimeout.c (modified) * testsuites/smptests/smpmutex01/init.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/sptests/spmutex01/init.c (modified) * testsuites/sptests/spsem03/init.c (modified) * testsuites/sptests/spsem03/spsem03.doc (modified) score: Rework thread priority management Add priority nodes which ... Tue, 28 Jun 2016 04:54:50 GMT Sebastian Huber [b20b736] * cpukit/libmisc/capture/capture.h (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedprio.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/schedulersimpleimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadqops.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadsetpriority.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/sptests/sp34/changepri.c (modified) * testsuites/sptests/sp35/priinv.c (modified) score: Introduce _Thread_Get_priority() Avoid direct access to ... Mon, 22 Aug 2016 08:58:34 GMT Sebastian Huber [e41308ea] * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/posix/include/rtems/posix/mqueueimpl.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/semunlink.c (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) score: Introduce Thread_queue_Lock_context Introduce ... Mon, 22 Aug 2016 11:17:05 GMT Sebastian Huber [114e408] * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/include/rtems/posix/psignalimpl.h (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/score/include/rtems/score/corebarrierimpl.h (modified) * cpukit/score/include/rtems/score/coremsgimpl.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/corerwlockimpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Simplify thread queue acquire/release Thu, 04 Aug 2016 08:20:29 GMT Sebastian Huber [ee0e4135] * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemongetstatistics.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemonresetstatistics.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulerdefaultreleasejob.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) score: Fix a release/cancel job race condition Split up the ... Wed, 03 Aug 2016 13:41:31 GMT Sebastian Huber [21bdca4] * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/score/src/schedulerdefaultreleasejob.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) score: Indroduce cancel job scheduler operation Do not use a ... Wed, 03 Aug 2016 11:27:13 GMT Sebastian Huber [ec735c6a] * cpukit/rtems/src/tasksetscheduler.c (modified) score: Fix for RTEMS_DEBUG Mon, 25 Jul 2016 14:35:37 GMT Sebastian Huber [1fcac5ad] * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/rtems/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqops.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadtimeout.c (modified) * testsuites/sptests/spthreadq01/init.c (modified) score: Turn thread lock into thread wait lock The ... Thu, 23 Jun 2016 18:40:43 GMT Gedare Bloom [10e4000] * cpukit/rtems/src/clocktodtoseconds.c (modified) cpukit/rtems: fix return type mismatch for _TOD_To_seconds Thu, 09 Jun 2016 15:33:15 GMT Gedare Bloom [f23d470] * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/score/include/rtems/score/corebarrierimpl.h (modified) * cpukit/score/include/rtems/score/coremsgimpl.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/corerwlockimpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) cpukit: Add and use Watchdog_Discipline. Clock disciplines may be ... Sat, 02 Jul 2016 22:19:38 GMT Pavel Pisa [0e507d55] * c/src/lib/libcpu/shared/src/cache_manager.c (modified) * cpukit/libcsupport/src/cachealignedalloc.c (modified) * cpukit/rtems/include/rtems/rtems/cache.h (modified) rtems+bsps/cache: Define cache manager operations for code ... Thu, 30 Jun 2016 12:08:18 GMT Sebastian Huber [c0bd006] * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/status.h (modified) * testsuites/smptests/smpclock01/init.c (modified) * testsuites/smptests/smpmigration02/init.c (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmutex01/init.c (modified) * testsuites/smptests/smppsxmutex01/init.c (modified) * testsuites/smptests/smpscheduler02/init.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/smptests/smpwakeafter01/init.c (modified) * testsuites/sptests/spscheduler01/init.c (modified) rtems: Fix rtems_task_set_scheduler() API Task priorities are only ... Wed, 29 Jun 2016 13:33:26 GMT Sebastian Huber [02987728] * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadtimeout.c (modified) score: Avoid atomic fences for thread wait flags The use of atomic ... Fri, 24 Jun 2016 09:22:03 GMT Sebastian Huber [254dc82] * cpukit/posix/include/rtems/posix/priorityimpl.h (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/psxpriorityisvalid.c (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityimpl.h (modified) * cpukit/score/src/schedulerprioritychangepriority.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * testsuites/smptests/smpmrsp01/init.c (modified) score: Change Priority_Control to 64-bit A 32-bit Priority_Control ... Thu, 16 Jun 2016 15:08:54 GMT Sebastian Huber [9a78f8a5] * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulerdefaultreleasejob.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) score: Modify release job scheduler operation Pass the deadline in ... Fri, 10 Jun 2016 06:48:54 GMT Sebastian Huber [77ff5599] * cpukit/libmisc/monitor/mon-sema.c (modified) * cpukit/posix/include/rtems/posix/priorityimpl.h (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/psxpriorityisvalid.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/include/rtems/rtems/tasksimpl.h (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/score/include/rtems/score/status.h (modified) * cpukit/score/src/schedulerdefaultmappriority.c (added) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/psxtests/psxautoinit01/init.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smppsxmutex01/Makefile.am (added) * testsuites/smptests/smppsxmutex01/init.c (added) * testsuites/smptests/smppsxmutex01/smppsxmutex01.doc (added) * testsuites/smptests/smppsxmutex01/smppsxmutex01.scn (added) * testsuites/smptests/smpscheduler02/init.c (modified) score: Introduce map priority scheduler operation Introduce ... Tue, 21 Jun 2016 15:12:40 GMT Sebastian Huber [c82835a] * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/capture/capture.h (modified) * cpukit/rtems/include/rtems/rtems/tasksimpl.h (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/score/include/rtems/score/status.h (modified) * testsuites/sptests/sp51/init.c (modified) * testsuites/sptests/sp51/sp51.scn (modified) * testsuites/sptests/spmrsp01/init.c (modified) * testsuites/sptests/sptimer_err02/init.c (modified) rtems: Rework RTEMS API to SuperCore priority Use same structure as ... Tue, 21 Jun 2016 12:15:03 GMT Sebastian Huber [a33bfb6] * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) Avoid in This gets rid of ... Tue, 21 Jun 2016 11:30:15 GMT Sebastian Huber [506bfc8] * c/src/lib/libbsp/shared/src/irq-info.c (modified) * c/src/lib/libbsp/shared/src/irq-shell.c (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/print.h (modified) * cpukit/include/rtems/printer.h (added) * cpukit/libcsupport/src/print_fprintf.c (modified) * cpukit/libcsupport/src/print_printf.c (modified) * cpukit/libcsupport/src/printf_plugin.c (modified) * cpukit/libcsupport/src/printk_plugin.c (modified) * cpukit/libdl/rap.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/fb/mw_print.c (modified) * cpukit/libmisc/shell/main_blkstats.c (modified) * cpukit/libmisc/shell/main_cpuinfo.c (modified) * cpukit/libmisc/shell/main_cpuuse.c (modified) * cpukit/libmisc/shell/main_perioduse.c (modified) * cpukit/libmisc/shell/main_profreport.c (modified) * cpukit/libmisc/shell/main_stackuse.c (modified) * cpukit/libmisc/shell/main_top.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/testsupport/test.h (modified) * cpukit/mghttpd/mongoose.c (modified) * cpukit/preinstall.am (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/score/src/cpusetprintsupport.c (modified) * testsuites/samples/hello/init.c (modified) Move printer initialization to separate header The RTEMS print user ... Thu, 16 Jun 2016 08:44:00 GMT Sebastian Huber [57c676c6] * cpukit/rtems/src/semcreate.c (modified) rtems: Fix rtems_semaphore_create() Destroy the thread queue in ... Mon, 06 Jun 2016 08:58:04 GMT Sebastian Huber [6fc34e4] * cpukit/rtems/src/semcreate.c (modified) rtems: Simplify rtems_semaphore_create() Remove superfluous ... Fri, 03 Jun 2016 06:15:21 GMT Sebastian Huber [3ad5f86] * cpukit/rtems/src/semrelease.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * testsuites/sptests/sp42/init.c (modified) * testsuites/sptests/sp42/sp42.scn (modified) rtems: Fix no protocol mutex release The Classic binary semaphores ... Mon, 30 May 2016 10:21:55 GMT Sebastian Huber [a65b02d] * cpukit/rtems/src/sem.c (modified) rtems: Remove superfluous includes Mon, 30 May 2016 08:43:31 GMT Sebastian Huber [73f2ddb] * cpukit/libmisc/monitor/mon-sema.c (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) rtems: Fix semaphore field name Mon, 30 May 2016 08:41:22 GMT Sebastian Huber [3692095] * cpukit/libmisc/monitor/mon-sema.c (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) rtems: Move MrsP semaphore operations Move MrsP semaphore ... Mon, 30 May 2016 04:59:55 GMT Sebastian Huber [0b713f89] * cpukit/libmisc/monitor/mon-sema.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/apimutex.h (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/src/apimutex.c (modified) * cpukit/score/src/apimutexisowner.c (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/coremutex.c (deleted) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/debugisownerofallocator.c (modified) score: Rework CORE inherit priority mutex Provide dedicated seize ... Fri, 27 May 2016 13:41:41 GMT Sebastian Huber [33e250c9] * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/src/apimutex.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) score: Rework CORE priority ceiling mutex Rework seize and ... Fri, 27 May 2016 06:02:03 GMT Sebastian Huber [5a598ac] * cpukit/libmisc/monitor/mon-sema.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/muteximpl.h (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/src/apimutex.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) score: Add CORE mutex variants Add CORE_recursive_mutex_Control and ... Mon, 30 May 2016 08:51:29 GMT Sebastian Huber [bac50cfc] * cpukit/rtems/src/semident.c (modified) rtems: Remove superfluous includes Fri, 27 May 2016 07:41:18 GMT Sebastian Huber [3c1ad257] * cpukit/rtems/src/semdelete.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) rtems: Simplify rtems_semaphore_delete() Due to the unified status ... Fri, 27 May 2016 07:34:17 GMT Sebastian Huber [8a77ef63] * cpukit/rtems/src/semflush.c (modified) rtems: Simplify rtems_semaphore_flush() Due to the unified status ... Thu, 26 May 2016 20:29:56 GMT Sebastian Huber [09c5ca4] * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/src/coremutexsurrender.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) score: Simplify CORE mutex Remove superfluous support for simple ... Fri, 20 May 2016 19:39:56 GMT Sebastian Huber [2581a56] * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/posix/src/semaphorecreatesupp.c (modified) * cpukit/posix/src/semaphoredeletesupp.c (modified) * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/mpci.c (modified) score: Add semaphore variants Wed, 25 May 2016 14:49:53 GMT Sebastian Huber [3ca6e618] * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semobtain.c (modified) rtems: Simplify rtems_semaphore_delete() Wed, 25 May 2016 14:30:23 GMT Sebastian Huber [af746b0] * cpukit/rtems/src/semobtain.c (modified) * cpukit/score/include/rtems/score/mrsp.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) score: Use thread queue lock for MrsP Replace the ISR lock in ... Fri, 27 May 2016 12:43:19 GMT Sebastian Huber [93306058] * cpukit/posix/include/rtems/posix/psignalimpl.h (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalsetprocesssignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/sptests/spfatal03/testcase.h (modified) score: _CORE_mutex_Check_dispatch_for_seize() Move the safety check ... Fri, 27 May 2016 11:26:53 GMT Sebastian Huber [0e1d11f3] * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/posix/include/rtems/posix/mqueueimpl.h (modified) * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) score: Add _Thread_queue_Context_set_MP_callout() Add ... Mon, 23 May 2016 11:37:59 GMT Sebastian Huber [dce48791] * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/posix/include/rtems/posix/mqueueimpl.h (modified) * cpukit/posix/include/rtems/posix/muteximpl.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/rwlockimpl.h (modified) * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/posix/include/rtems/posix/spinlockimpl.h (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mqueuetranslatereturncode.c (deleted) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutextranslatereturncode.c (deleted) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/pbarriertranslatereturncode.c (deleted) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktranslatereturncode.c (deleted) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pspinlock.c (modified) * cpukit/posix/src/pspinlocktranslatereturncode.c (deleted) * cpukit/posix/src/pspintrylock.c (modified) * cpukit/posix/src/pspinunlock.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/semaphoretranslatereturncode.c (deleted) * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (modified) * cpukit/rtems/include/rtems/rtems/eventimpl.h (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/include/rtems/rtems/statusimpl.h (modified) * cpukit/rtems/src/barriertranslatereturncode.c (deleted) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqtranslatereturncode.c (deleted) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regionprocessqueue.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (deleted) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/corebarrierimpl.h (modified) * cpukit/score/include/rtems/score/coremsgimpl.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/corerwlockimpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/corespinlockimpl.h (modified) * cpukit/score/include/rtems/score/mpciimpl.h (modified) * cpukit/score/include/rtems/score/mrsp.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/status.h (added) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/corespinlockrelease.c (modified) * cpukit/score/src/corespinlockwait.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadtimeout.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical20/init.c (modified) score: Add Status_Control for all APIs Unify the status codes of ... Wed, 25 May 2016 12:23:48 GMT Sebastian Huber [39bcf741] * cpukit/posix/src/semaphoretranslatereturncode.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/src/mpci.c (modified) * testsuites/psxtests/psxsem01/init.c (modified) * testsuites/sptests/spsem_err01/init.c (modified) * testsuites/sptests/spsem_err01/spsem_err01.scn (modified) Fix semaphore post overflow status Close #2720. Mon, 23 May 2016 09:40:18 GMT Sebastian Huber [631b3c8] * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/include/rtems/posix/mqueueimpl.h (modified) * cpukit/posix/include/rtems/posix/muteximpl.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/rwlockimpl.h (modified) * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/posix/src/conddestroy.c (modified) * cpukit/posix/src/condget.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/mqueueclose.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuegetattr.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mqueuesetattr.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexget.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/pbarrierdestroy.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/posix/src/prwlockdestroy.c (modified) * cpukit/posix/src/prwlockinit.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/posix/src/semaphoredeletesupp.c (modified) * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/posix/src/semclose.c (modified) * cpukit/posix/src/semdestroy.c (modified) * cpukit/posix/src/semgetvalue.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semunlink.c (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/barrierdelete.c (modified) * cpukit/rtems/src/barrierrelease.c (modified) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/score/include/rtems/score/corebarrierimpl.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremsgimpl.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/corerwlockimpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) score: Move thread queue MP callout to context Drop the ... Mon, 23 May 2016 04:55:49 GMT Sebastian Huber [c3d8d9e] * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/posix/src/semaphoredeletesupp.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/rtems/src/barrierdelete.c (modified) * cpukit/rtems/src/barrierrelease.c (modified) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/score/include/rtems/score/corebarrierimpl.h (modified) * cpukit/score/include/rtems/score/coremsgimpl.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Get rid of mp_id parameter Get rid of the mp_id parameter ... Mon, 23 May 2016 04:26:58 GMT Sebastian Huber [8866e62] * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadwaitgetid.c (modified) score: Move thread queue object support Fri, 20 May 2016 08:39:50 GMT Chris Johns [24d0ee57] * c/src/lib/libbsp/shared/include/irq-info.h (modified) * c/src/lib/libbsp/shared/src/irq-info.c (modified) * c/src/lib/libbsp/shared/src/irq-shell.c (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/print.h (added) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/blkdev-blkstats.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/print_fprintf.c (added) * cpukit/libcsupport/src/print_printf.c (added) * cpukit/libcsupport/src/printf_plugin.c (modified) * cpukit/libcsupport/src/printk.c (modified) * cpukit/libcsupport/src/printk_plugin.c (modified) * cpukit/libcsupport/src/putk.c (modified) * cpukit/libcsupport/src/vprintk.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/cpuuse/cpuuse.h (modified) * cpukit/libmisc/fb/mw_print.c (modified) * cpukit/libmisc/fb/mw_uid.h (modified) * cpukit/libmisc/shell/main_blkstats.c (modified) * cpukit/libmisc/shell/main_cpuuse.c (modified) * cpukit/libmisc/shell/main_perioduse.c (modified) * cpukit/libmisc/shell/main_profreport.c (modified) * cpukit/libmisc/shell/main_stackuse.c (modified) * cpukit/libmisc/shell/main_top.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) * cpukit/libmisc/testsupport/test.h (modified) * cpukit/libmisc/testsupport/testbeginend.c (modified) * cpukit/libmisc/testsupport/testextension.c (modified) * cpukit/preinstall.am (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/sapi/include/rtems/profiling.h (modified) * cpukit/sapi/src/profilingreportxml.c (modified) * cpukit/score/src/cpusetprintsupport.c (modified) * testsuites/fstests/fsnofs01/init.c (modified) * testsuites/libtests/block02/init.c (modified) * testsuites/libtests/block03/init.c (modified) * testsuites/libtests/block04/init.c (modified) * testsuites/libtests/block05/init.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block07/init.c (modified) * testsuites/libtests/block08/init.c (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/libtests/block14/init.c (modified) * testsuites/libtests/capture01/init.c (modified) * testsuites/libtests/complex/init.c (modified) * testsuites/libtests/devnullfatal01/testcase.h (modified) * testsuites/libtests/exit01/init.c (modified) * testsuites/libtests/exit02/init.c (modified) * testsuites/libtests/math/init.c (modified) * testsuites/libtests/mathf/init.c (modified) * testsuites/libtests/mathl/init.c (modified) * testsuites/libtests/mouse01/init.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/uid01/init.c (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/samples/capture/init.c (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp07/init.c (modified) * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) * testsuites/smptests/smpfatal04/init.c (modified) * testsuites/smptests/smpfatal05/init.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) * testsuites/sptests/sperror01/init.c (modified) * testsuites/sptests/sperror02/init.c (modified) * testsuites/sptests/sperror03/init.c (modified) * testsuites/sptests/spextensions01/init.c (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spfatal16/testcase.h (modified) * testsuites/sptests/spfatal26/init.c (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/spprintk/init.c (modified) * testsuites/sptests/spprofiling01/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) * testsuites/support/include/buffer_test_io.h (modified) * testsuites/support/include/test_support.h (modified) * testsuites/support/src/locked_print.c (modified) cpukit, testsuite: Add rtems_printf and rtems_printer support. This ... Mon, 23 May 2016 09:42:41 GMT Sebastian Huber [16dbcdcd] * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/score/include/rtems/score/coremsgimpl.h (modified) * cpukit/score/src/coremsgseize.c (modified) score: _CORE_message_queue_Seize() Delete unused parameter. Tue, 24 May 2016 10:00:32 GMT Sebastian Huber [7af4d67] * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) mpci: Add missing return statements Fri, 20 May 2016 13:52:27 GMT Sebastian Huber [bdb3b7f] * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/src/mpci.c (modified) score: _CORE_semaphore_Seize() Delete unused parameter. Fri, 20 May 2016 13:10:27 GMT Sebastian Huber [e266d13] * cpukit/posix/include/rtems/posix/muteximpl.h (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexget.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadgetaffinitynp.c (modified) * cpukit/posix/src/pthreadgetattrnp.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadsetaffinitynp.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskgetaffinity.c (modified) * cpukit/rtems/src/taskgetscheduler.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasksetaffinity.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/threadget.c (modified) * testsuites/smptests/smpmigration02/init.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) * testsuites/sptests/spintrcritical23/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) Replace *_Get_interrupt_disable() with *_Get() Uniformly use ... Fri, 20 May 2016 13:04:16 GMT Sebastian Huber [582bb23c] * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/posix/include/rtems/posix/mqueueimpl.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/posix/include/rtems/posix/spinlockimpl.h (modified) * cpukit/posix/include/rtems/posix/timerimpl.h (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (modified) * cpukit/rtems/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/include/rtems/rtems/timerimpl.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/threadget.c (modified) score: Rename _Objects_Get_local() Rename _Objects_Get_local() into ... Fri, 20 May 2016 12:59:30 GMT Sebastian Huber [62c528e6] * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) rtems: _Semaphore_Get_interrupt_disable() Use _Objects_Get_local() ... Fri, 20 May 2016 12:21:12 GMT Sebastian Huber [641b44c2] * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) rtems: _Message_queue_Get_interrupt_disable() Use ... Fri, 20 May 2016 11:24:11 GMT Sebastian Huber [0a00b2b] * cpukit/rtems/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) rtems: Remove location from _Partition_Get() Use ... Fri, 20 May 2016 12:23:56 GMT Sebastian Huber [516ee75] * cpukit/rtems/src/region.c (modified) mpci: Delete unused region support
