@ecabd384
07/11/17 07:51:43 |
Sebastian Huber |
rtems: Add rtems_scheduler_ident_by_processor_set
Update #3070.
5
@548d65a5
07/11/17 05:24:39 |
Sebastian Huber |
rtems: Add rtems_scheduler_ident_by_processor()
Update #3069.
5
@3b14e7aa
07/11/17 11:51:10 |
Sebastian Huber |
rtems: Fix warning
Update #3059.
5
@1ec9c86
07/03/17 08:38:31 |
Sebastian Huber |
rtems: Fix rtems_scheduler_remove_processor()
Account for the thread …
5
@6b1d8c7
07/04/17 05:28:44 |
Sebastian Huber |
score: Add processor set to scheduler context
Replace the simple …
5
@a300ca1b
04/24/17 01:35:41 |
joel |
ratemonreportstatistics.c: Fix printf() warnings so clean on 32 and 64 …
5
@70ddaa0e
03/28/17 06:18:06 |
Sebastian Huber |
rtems: Fix error return path
5
@e366f77
01/31/17 07:08:24 |
Sebastian Huber |
score: Add _Thread_queue_Object_name
Add the special thread queue …
5
@0794197
01/27/17 22:15:50 |
c0066c |
rtems: Fix _Rate_monotonic_Renew_deadline()
Prepare a precondition to …
5
@d7feb86
01/25/17 20:47:48 |
c0066c |
Remove rtems_rate_monotonic_postponed_job_count()
Add a variable …
5
@b8d6eb7
01/24/17 14:05:22 |
Sebastian Huber |
rtems: rtems_rate_monotonic_postponed_job_count()
Use proper locking …
5
@625bd6a
01/24/17 14:04:11 |
Sebastian Huber |
rtems: Fix _Rate_monotonic_Release_postponed_job()
5
@1240aade
01/24/17 13:37:42 |
Sebastian Huber |
Make …
5
@cb2cbec
01/13/17 18:54:11 |
Gedare Bloom |
classic: adjust names of RM postponed job functions
closes #2795
5
@3a46b72
12/21/16 16:42:39 |
c0066c |
Enhancement of the RMS manager for the overrun handling.
Three …
5
@ba776282
08/12/16 19:25:10 |
Gedare Bloom |
posix: shared memory support
Add POSIX shared memory manager (Shm). …
5
@96bb2e4b
01/12/17 06:53:12 |
Sebastian Huber |
rtems: Use header file for rtems_object_get_name()
5
@d063e7b3
01/11/17 07:42:04 |
Sebastian Huber |
score: Replace STATES_DELAYING
Replace STATES_DELAYING with …
5
@7a4b2645
01/11/17 15:43:06 |
joel |
Remove obsolete RTEMS_HAVE_SYS_CPUSET_H
5
@3a659b04
12/09/16 06:19:22 |
Sebastian Huber |
score: Introduce _Internal_error()
5
@279d5260
12/09/16 05:49:25 |
Sebastian Huber |
Add INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED
Update #2825.
5
@b6606e8
12/08/16 15:41:30 |
Sebastian Huber |
score: Remove fatal is internal indicator
The fatal is internal …
5
@7da78cf
12/02/16 10:51:16 |
Sebastian Huber |
rtems: Use _Thread_Dispatch_direct()
Update #2797.
5
@d10716f
12/02/16 10:18:32 |
Sebastian Huber |
rtems: Fix rtems_scheduler_add_processor()
Fix thread dispatch …
5
@5b6c290
12/01/16 19:42:48 |
Sebastian Huber |
score: Initialize thread queue context early
Initialize thread queue …
5
@620b23e
11/24/16 05:13:11 |
Sebastian Huber |
score: Optimize _Thread_queue_Enqueue()
Move thread state for …
5
@c42be504
11/16/16 13:50:09 |
Sebastian Huber |
posix: Add self-contained pthread spinlock
Turn pthread_spinlock_t …
5
@a4217c6
11/22/16 09:53:03 |
Sebastian Huber |
score: Rename _Thread_queue_Enqueue_critical()
Delete unused …
5
@125f248
11/16/16 15:39:43 |
Sebastian Huber |
score: Add thread queue enqueue callout
Replace the expected thread …
5
@d78d529
11/14/16 08:11:07 |
Sebastian Huber |
score: Add and use _Thread_Dispatch_direct()
This function is useful …
5
@05ca53d
10/31/16 12:08:33 |
Sebastian Huber |
rtems: Add scheduler processor add/remove
Update #2797.
5
@2612a0b
11/02/16 05:36:13 |
Sebastian Huber |
score: Simplify _Scheduler_Get_by_id()
Avoid dead code in non-SMP …
5
@2f5ac5b5
11/04/16 14:26:52 |
Sebastian Huber |
rtems: Fix rtems_task_create() scheduler selection
Use the home …
5
@0dd49d0
10/31/16 15:10:32 |
Sebastian Huber |
score: Introduce thread resource count methods
This makes it easier …
5
@6e31b56f
11/03/16 09:52:53 |
Sebastian Huber |
rtems: Fix binary semaphore resource count
Binary semaphores (not …
5
@2dd098a
10/31/16 07:33:11 |
Sebastian Huber |
score: Introduce Thread_Scheduler_control::home
Replace …
5
@d271c3bb
10/31/16 12:37:59 |
Sebastian Huber |
rtems: Add rtems_task_iterate()
Update #2423.
5
@8797c76
09/27/16 13:23:00 |
Sebastian Huber |
score: Unify CORE mutex seize/surrender
Use the …
5
@8123cae8
09/08/16 13:32:22 |
Sebastian Huber |
rtems: Add rtems_task_get_priority()
Update #2556.
Update #2784.
5
@300f6a48
06/22/16 15:09:23 |
Sebastian Huber |
score: Rework thread priority management
Add priority nodes which …
5
@b20b736
06/28/16 04:54:50 |
Sebastian Huber |
score: Introduce _Thread_Get_priority()
Avoid direct access to thread …
5
@e41308ea
08/22/16 08:58:34 |
Sebastian Huber |
score: Introduce Thread_queue_Lock_context
Introduce …
5
@114e408
08/22/16 11:17:05 |
Sebastian Huber |
score: Simplify thread queue acquire/release
5
@ee0e4135
08/04/16 08:20:29 |
Sebastian Huber |
score: Fix a release/cancel job race condition
Split up the potential …
5
@21bdca4
08/03/16 13:41:31 |
Sebastian Huber |
score: Indroduce cancel job scheduler operation
Do not use a deadline …
5
@ec735c6a
08/03/16 11:27:13 |
Sebastian Huber |
score: Fix for RTEMS_DEBUG
5
@1fcac5ad
07/25/16 14:35:37 |
Sebastian Huber |
score: Turn thread lock into thread wait lock
The …
5
@10e4000
06/23/16 18:40:43 |
Gedare Bloom |
cpukit/rtems: fix return type mismatch for _TOD_To_seconds
5
@f23d470
06/09/16 15:33:15 |
Gedare Bloom |
cpukit: Add and use Watchdog_Discipline.
Clock disciplines may be …
5
@c0bd006
06/30/16 12:08:18 |
Sebastian Huber |
rtems: Fix rtems_task_set_scheduler() API
Task priorities are only …
5
@02987728
06/29/16 13:33:26 |
Sebastian Huber |
score: Avoid atomic fences for thread wait flags
The use of atomic …
5
@9a78f8a5
06/16/16 15:08:54 |
Sebastian Huber |
score: Modify release job scheduler operation
Pass the deadline in …
5
@77ff5599
06/10/16 06:48:54 |
Sebastian Huber |
score: Introduce map priority scheduler operation
Introduce map/unmap …
5
@c82835a
06/21/16 15:12:40 |
Sebastian Huber |
rtems: Rework RTEMS API to SuperCore? priority
Use same structure as …
5
@506bfc8
06/21/16 11:30:15 |
Sebastian Huber |
Move printer initialization to separate header
The RTEMS print user …
5
@57c676c6
06/16/16 08:44:00 |
Sebastian Huber |
rtems: Fix rtems_semaphore_create()
Destroy the thread queue in case …
5
@6fc34e4
06/06/16 08:58:04 |
Sebastian Huber |
rtems: Simplify rtems_semaphore_create()
Remove superfluous includes. …
5
@3ad5f86
06/03/16 06:15:21 |
Sebastian Huber |
rtems: Fix no protocol mutex release
The Classic binary semaphores …
5
@a65b02d
05/30/16 10:21:55 |
Sebastian Huber |
rtems: Remove superfluous includes
5
@73f2ddb
05/30/16 08:43:31 |
Sebastian Huber |
rtems: Fix semaphore field name
5
@3692095
05/30/16 08:41:22 |
Sebastian Huber |
rtems: Move MrsP semaphore operations
Move MrsP semaphore operations …
5
@0b713f89
05/30/16 04:59:55 |
Sebastian Huber |
score: Rework CORE inherit priority mutex
Provide dedicated seize and …
5
@33e250c9
05/27/16 13:41:41 |
Sebastian Huber |
score: Rework CORE priority ceiling mutex
Rework seize and surrender …
5
@5a598ac
05/27/16 06:02:03 |
Sebastian Huber |
score: Add CORE mutex variants
Add CORE_recursive_mutex_Control and …
5
@bac50cfc
05/30/16 08:51:29 |
Sebastian Huber |
5
@3c1ad257
05/27/16 07:41:18 |
Sebastian Huber |
rtems: Simplify rtems_semaphore_delete()
Due to the unified status …
5
@8a77ef63
05/27/16 07:34:17 |
Sebastian Huber |
rtems: Simplify rtems_semaphore_flush()
5
@09c5ca4
05/26/16 20:29:56 |
Sebastian Huber |
score: Simplify CORE mutex
Remove superfluous support for simple …
5
@2581a56
05/20/16 19:39:56 |
Sebastian Huber |
score: Add semaphore variants
5
@3ca6e618
05/25/16 14:49:53 |
Sebastian Huber |
5
@af746b0
05/25/16 14:30:23 |
Sebastian Huber |
score: Use thread queue lock for MrsP
Replace the ISR lock in …
5
@93306058
05/27/16 12:43:19 |
Sebastian Huber |
score: _CORE_mutex_Check_dispatch_for_seize()
Move the safety check …
5
@0e1d11f3
05/27/16 11:26:53 |
Sebastian Huber |
score: Add _Thread_queue_Context_set_MP_callout()
Add …
5
@dce48791
05/23/16 11:37:59 |
Sebastian Huber |
score: Add Status_Control for all APIs
Unify the status codes of the …
5
@39bcf741
05/25/16 12:23:48 |
Sebastian Huber |
Fix semaphore post overflow status
Close #2720.
5
@631b3c8
05/23/16 09:40:18 |
Sebastian Huber |
score: Move thread queue MP callout to context
Drop the …
5
@c3d8d9e
05/23/16 04:55:49 |
Sebastian Huber |
score: Get rid of mp_id parameter
Get rid of the mp_id parameter used …
5
@8866e62
05/23/16 04:26:58 |
Sebastian Huber |
score: Move thread queue object support
5
@24d0ee57
05/20/16 08:39:50 |
Chris Johns |
cpukit, testsuite: Add rtems_printf and rtems_printer support.
This …
5
@16dbcdcd
05/23/16 09:42:41 |
Sebastian Huber |
score: _CORE_message_queue_Seize()
Delete unused parameter.
5
@7af4d67
05/24/16 10:00:32 |
Sebastian Huber |
mpci: Add missing return statements
5
@bdb3b7f
05/20/16 13:52:27 |
Sebastian Huber |
score: _CORE_semaphore_Seize()
5
@e266d13
05/20/16 13:10:27 |
Sebastian Huber |
Replace *_Get_interrupt_disable() with *_Get()
Uniformly use *_Get() …
5
@62c528e6
05/20/16 12:59:30 |
Sebastian Huber |
rtems: _Semaphore_Get_interrupt_disable()
Use _Objects_Get_local() …
5
@641b44c2
05/20/16 12:21:12 |
Sebastian Huber |
rtems: _Message_queue_Get_interrupt_disable()
Use …
5
@0a00b2b
05/20/16 11:24:11 |
Sebastian Huber |
rtems: Remove location from _Partition_Get()
5
@516ee75
05/20/16 12:23:56 |
Sebastian Huber |
mpci: Delete unused region support
5
@c2f301b5
05/18/16 06:08:38 |
Sebastian Huber |
score: Rename _ISR_Flash() into _ISR_Local_flash()
This is a …
5
@24713163
05/18/16 06:06:54 |
Sebastian Huber |
score: Rename _ISR_Disable() and _ISR_Enable()
Rename _ISR_Disable() …
5
@f36ada32
05/17/16 12:38:57 |
Sebastian Huber |
rtems: Avoid Giant lock for rtems_task_delete()
Update #2555.
5
@33829ce
05/13/16 12:07:23 |
Sebastian Huber |
score: Avoid Giant lock for _Thread_Start()
Update #2555.
5
@54550e04
05/13/16 06:16:30 |
Sebastian Huber |
posix: Rework pthread_join()
Rework pthread_join() to use …
5
@9388390
05/13/16 05:04:43 |
Sebastian Huber |
score: Split _Thread_Restart()
Split _Thread_Restart() into …
5
@270394e
05/12/16 12:25:50 |
Sebastian Huber |
score: Avoid superfluous life protection
Disable thread dispatching …
5
@b7f5e391
05/12/16 04:12:06 |
Sebastian Huber |
score: Add _Thread_Exit()
The goal is to make _Thread_Exit() a …
5
@ef6f8a83
05/11/16 12:03:23 |
Sebastian Huber |
score: Avoid Giant lock for scheduler set/get
Update #2555.
5
@d9952999
05/11/16 09:06:51 |
Sebastian Huber |
score: Avoid Giant lock _Scheduler_Get_affinity()
Update #2555.
5
@e135271
05/11/16 08:58:59 |
Sebastian Huber |
score: Avoid Giant lock _Scheduler_Set_affinity()
Update #2555.
5
@bd12dda
05/11/16 09:54:49 |
Sebastian Huber |
score: Use thread state lock for current state
In addition protect …
5
@11c66437
05/11/16 08:27:37 |
Sebastian Huber |
rtems: Avoid Giant lock rtems_task_is_suspended()
Update #2555.
5
