# # ChangeLog for cpukit/pppd/README in rtems # # Generated by Trac 1.2.1.dev0 # 04/30/24 21:44:06 Thu, 03 May 2012 17:24:46 GMT Joel Sherrill [65c6425] * INSTALL (modified) * LICENSE (modified) * LICENSE.NET (modified) * LICENSE.RPCXDR (modified) * LICENSE.WEBSERVER (modified) * SUPPORT (modified) * VERSION (modified) * ampolish3 (modified) * bootstrap (modified) * c/ACKNOWLEDGEMENTS (modified) * c/TOOL_TARGETS (modified) * c/src/aclocal/bsp-alias.m4 (modified) * c/src/aclocal/bsp-bootcard-options.m4 (modified) * c/src/aclocal/bsp-bspcleanup-options.m4 (modified) * c/src/aclocal/bspopts.m4 (modified) * c/src/aclocal/canonicalize-tools.m4 (modified) * c/src/aclocal/check-cxx.m4 (modified) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/check-posix.m4 (modified) * c/src/aclocal/check-smp.m4 (modified) * c/src/aclocal/gcc-pipe.m4 (modified) * c/src/aclocal/gcc-specs.m4 (modified) * c/src/aclocal/i386-gas-code16.m4 (modified) * c/src/aclocal/ppc.m4 (modified) * c/src/aclocal/project-root.m4 (modified) * c/src/lib/libbsp/MERGE.PROCEDURE (modified) * c/src/lib/libbsp/arm/gp32/include/bsp.h (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/rumble.c (modified) * c/src/lib/libbsp/i386/pc386/3c509/elink.c (modified) * c/src/lib/libbsp/i386/pc386/3c509/elink.h (modified) * c/src/lib/libbsp/i386/pc386/HOWTO (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/README (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/gdbinit (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/runtest (modified) * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235.cfg (modified) * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg (modified) * c/src/lib/libbsp/m68k/mcf5235/make/custom/mcf5235.cfg (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.h (modified) * c/src/lib/libbsp/m68k/mrm332/misc/dotests (modified) * c/src/lib/libbsp/m68k/mrm332/misc/gdbinit68 (modified) * c/src/lib/libbsp/m68k/mvme162/include/page_table.h (modified) * c/src/lib/libbsp/m68k/ods68302/startup/debugger (modified) * c/src/lib/libbsp/m68k/ods68302/startup/rom (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c.nocache (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/BOOTING (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/if_hdlcsubr.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.h (modified) * c/src/lib/libbsp/sh/gensh2/start/start.ram (modified) * c/src/lib/libbsp/sh/gensh2/start/start.rom (modified) * c/src/lib/libbsp/sparc64/shared/helenos/README (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/fpsp.defs (modified) * c/src/lib/libcpu/mips/mongoosev/duart/README.mguart (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/README (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c.polled (modified) * c/src/libchip/display/disp_hcms29xx.c (modified) * c/src/libchip/network/README.tulipclone (modified) * c/src/libchip/network/cs8900.c.bsp (modified) * c/src/libchip/network/cs8900.h.bsp (modified) * c/src/libchip/network/if_dc.c (modified) * c/src/make/bsp.mak (modified) * contrib/mingw/rtems.ini (modified) * cpukit/doxy-filter (modified) * cpukit/libcsupport/include/sys/filio.h (modified) * cpukit/libcsupport/include/sys/ttycom.h (modified) * cpukit/libcsupport/src/CASES (modified) * cpukit/libcsupport/src/TODO (modified) * cpukit/libmisc/serdbg/serdbgio.c (modified) * cpukit/libmisc/serdbg/termios_printk.c (modified) * cpukit/libnetworking/arpa/inet.h (modified) * cpukit/libnetworking/arpa/nameser_compat.h (modified) * cpukit/libnetworking/libc/ether_addr.c (modified) * cpukit/libnetworking/machine/in_cksum.h (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/netinet/igmp.h (modified) * cpukit/libnetworking/netinet/in_proto.c (modified) * cpukit/libnetworking/netinet/in_var.h (modified) * cpukit/libnetworking/netinet/ip_fw.c (modified) * cpukit/libnetworking/netinet/ip_fw.h (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/netinet/tcp_output.c (modified) * cpukit/libnetworking/netinet/tcp_timer.c (modified) * cpukit/libnetworking/netinet/tcp_var.h (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/resolv.h (modified) * cpukit/libnetworking/rtems/mkrootfs.h (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl_kern.c (modified) * cpukit/libnetworking/sys/socketvar.h (modified) * cpukit/libnetworking/vm/vm.h (modified) * cpukit/librpc/include/rpc/rpc_com.h (modified) * cpukit/librpc/include/rpc/rpc_msg.h (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/README (modified) * cpukit/pppd/STATUS (modified) * cpukit/pppd/example/README (modified) * cpukit/pppd/pppd.8 (modified) * cpukit/score/cpu/m68k/rtems/m68k/m68360.h (modified) * cpukit/score/src/Unlimited.txt (modified) * doc/TODO (modified) * doc/new_chapters/STATUS (modified) * doc/new_chapters/gen_section (modified) * doc/posix1003.1/summarize (modified) * doc/posix_users/gen_size_report (modified) * doc/setup.def (modified) * doc/tools/word-replace2 (modified) * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * release_support (modified) * tools/build/Makefile.am (modified) * tools/build/cvsignore-add.sh (modified) * tools/build/doxy-filter (modified) * tools/build/multigen (modified) * tools/build/search-id.sh (deleted) * tools/cpu/sh/COPYING (modified) Remove CVS Id Strings (manual edits after script) These ... Thu, 31 Jan 2002 21:42:11 GMT Joel Sherrill [0286b9f] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/configure.ac (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/net/bsd-comp.c (added) * c/src/exec/libnetworking/net/if_ppp.c (added) * c/src/exec/libnetworking/net/if_ppp.h (modified) * c/src/exec/libnetworking/net/if_pppvar.h (modified) * c/src/exec/libnetworking/net/ppp-comp.h (modified) * c/src/exec/libnetworking/net/ppp-deflate.c (added) * c/src/exec/libnetworking/net/ppp.h (added) * c/src/exec/libnetworking/net/ppp_defs.h (modified) * c/src/exec/libnetworking/net/ppp_tty.c (added) * c/src/exec/libnetworking/net/pppcompress.c (moved) * c/src/exec/libnetworking/net/zlib.c (added) * c/src/exec/libnetworking/net/zlib.h (added) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.ac (modified) * c/src/libnetworking/modem/.cvsignore (deleted) * c/src/libnetworking/modem/Makefile.am (deleted) * c/src/libnetworking/modem/ppp.h (deleted) * c/src/libnetworking/modem/ppp_tty.c (deleted) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/net/bsd-comp.c (added) * c/src/libnetworking/net/if_ppp.c (moved) * c/src/libnetworking/net/if_ppp.h (modified) * c/src/libnetworking/net/if_pppvar.h (modified) * c/src/libnetworking/net/ppp-comp.h (modified) * c/src/libnetworking/net/ppp-deflate.c (added) * c/src/libnetworking/net/ppp.h (added) * c/src/libnetworking/net/ppp_defs.h (modified) * c/src/libnetworking/net/ppp_tty.c (added) * c/src/libnetworking/net/pppcompress.c (added) * c/src/libnetworking/net/zlib.c (added) * c/src/libnetworking/net/zlib.h (added) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/pppd/README (modified) * c/src/libnetworking/pppd/STATUS (modified) * c/src/libnetworking/pppd/chap.h (modified) * c/src/libnetworking/pppd/chat.c (modified) * c/src/libnetworking/pppd/example/netconfig.h (modified) * c/src/libnetworking/pppd/fsm.c (modified) * c/src/libnetworking/pppd/fsm.h (modified) * c/src/libnetworking/pppd/ipcp.c (modified) * c/src/libnetworking/pppd/options.c (modified) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/rtemsmain.c (modified) * c/src/libnetworking/pppd/rtemspppd.c (modified) * c/src/libnetworking/pppd/rtemspppd.h (modified) * c/src/libnetworking/pppd/sys-rtems.c (modified) * c/src/libnetworking/pppd/upap.h (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/net/bsd-comp.c (added) * cpukit/libnetworking/net/if_ppp.c (added) * cpukit/libnetworking/net/if_ppp.h (modified) * cpukit/libnetworking/net/if_pppvar.h (modified) * cpukit/libnetworking/net/ppp-comp.h (modified) * cpukit/libnetworking/net/ppp-deflate.c (added) * cpukit/libnetworking/net/ppp.h (added) * cpukit/libnetworking/net/ppp_defs.h (modified) * cpukit/libnetworking/net/ppp_tty.c (added) * cpukit/libnetworking/net/pppcompress.c (added) * cpukit/libnetworking/net/zlib.c (added) * cpukit/libnetworking/net/zlib.h (added) * cpukit/libnetworking/wrapup/Makefile.am (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/README (modified) * cpukit/pppd/STATUS (modified) * cpukit/pppd/chap.h (modified) * cpukit/pppd/chat.c (modified) * cpukit/pppd/example/netconfig.h (modified) * cpukit/pppd/fsm.c (modified) * cpukit/pppd/fsm.h (modified) * cpukit/pppd/ipcp.c (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/pppd.h (modified) * cpukit/pppd/rtemsmain.c (modified) * cpukit/pppd/rtemspppd.c (modified) * cpukit/pppd/rtemspppd.h (modified) * cpukit/pppd/sys-rtems.c (modified) * cpukit/pppd/upap.h (modified) 2001-01-31 Mike Siers * Nice Update ... Fri, 12 Oct 2001 13:43:05 GMT Joel Sherrill [aee474b] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/README (modified) * c/src/libnetworking/pppd/STATUS (modified) * c/src/libnetworking/pppd/cbcp.c (modified) * c/src/libnetworking/pppd/cbcp.h (modified) * c/src/libnetworking/pppd/chat.c (modified) * c/src/libnetworking/pppd/example/README (modified) * c/src/libnetworking/pppd/example/pppd.options (added) * c/src/libnetworking/pppd/modem_example/16550.h (deleted) * c/src/libnetworking/pppd/modem_example/README (deleted) * c/src/libnetworking/pppd/modem_example/modem.c (deleted) * c/src/libnetworking/pppd/modem_example/modem.h (deleted) * c/src/libnetworking/pppd/modem_example/ppp.c (deleted) * c/src/libnetworking/pppd/modem_example/ppp.h (deleted) * c/src/libnetworking/pppd/modem_example/pppcompress.c (deleted) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/rtemsmain.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/pppd/README (modified) * cpukit/pppd/STATUS (modified) * cpukit/pppd/cbcp.c (modified) * cpukit/pppd/cbcp.h (modified) * cpukit/pppd/chat.c (modified) * cpukit/pppd/example/README (modified) * cpukit/pppd/example/pppd.options (added) * cpukit/pppd/pppd.h (modified) * cpukit/pppd/rtemsmain.c (modified) 2001-10-12 Mike Siers * Update to ... Thu, 16 Aug 2001 20:42:09 GMT Joel Sherrill [2f1b930] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/net/if_ppp.h (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/modem/ppp_tty.c (modified) * c/src/libnetworking/net/if_ppp.h (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/pppd/README (modified) * c/src/libnetworking/pppd/STATUS (modified) * c/src/libnetworking/pppd/auth.c (modified) * c/src/libnetworking/pppd/cbcp.c (deleted) * c/src/libnetworking/pppd/cbcp.h (deleted) * c/src/libnetworking/pppd/ccp.c (modified) * c/src/libnetworking/pppd/ccp.h (modified) * c/src/libnetworking/pppd/chap.c (modified) * c/src/libnetworking/pppd/chap.h (modified) * c/src/libnetworking/pppd/chap_ms.c (modified) * c/src/libnetworking/pppd/chat.c (modified) * c/src/libnetworking/pppd/demand.c (modified) * c/src/libnetworking/pppd/example/Makefile (added) * c/src/libnetworking/pppd/example/README (added) * c/src/libnetworking/pppd/example/init.c (added) * c/src/libnetworking/pppd/example/netconfig.h (added) * c/src/libnetworking/pppd/example/ppp.conf (added) * c/src/libnetworking/pppd/example/pppdapp.c (added) * c/src/libnetworking/pppd/example/system.h (added) * c/src/libnetworking/pppd/fsm.c (modified) * c/src/libnetworking/pppd/fsm.h (modified) * c/src/libnetworking/pppd/ipcp.c (modified) * c/src/libnetworking/pppd/ipcp.h (modified) * c/src/libnetworking/pppd/ipxcp.c (modified) * c/src/libnetworking/pppd/ipxcp.h (modified) * c/src/libnetworking/pppd/lcp.c (modified) * c/src/libnetworking/pppd/lcp.h (modified) * c/src/libnetworking/pppd/magic.c (modified) * c/src/libnetworking/pppd/main.c (deleted) * c/src/libnetworking/pppd/options.c (modified) * c/src/libnetworking/pppd/patchlevel.h (modified) * c/src/libnetworking/pppd/pathnames.h (modified) * c/src/libnetworking/pppd/ppp_tty.c (deleted) * c/src/libnetworking/pppd/pppd.8 (added) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/pppmain.c (deleted) * c/src/libnetworking/pppd/rtemsmain.c (added) * c/src/libnetworking/pppd/rtemspppd.c (added) * c/src/libnetworking/pppd/rtemspppd.h (added) * c/src/libnetworking/pppd/sys-rtems.c (moved) * c/src/libnetworking/pppd/upap.c (modified) * c/src/libnetworking/pppd/upap.h (modified) * c/src/libnetworking/pppd/utils.c (added) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/net/if_ppp.h (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/README (modified) * cpukit/pppd/STATUS (modified) * cpukit/pppd/auth.c (modified) * cpukit/pppd/cbcp.c (deleted) * cpukit/pppd/cbcp.h (deleted) * cpukit/pppd/ccp.c (modified) * cpukit/pppd/ccp.h (modified) * cpukit/pppd/chap.c (modified) * cpukit/pppd/chap.h (modified) * cpukit/pppd/chap_ms.c (modified) * cpukit/pppd/chat.c (modified) * cpukit/pppd/demand.c (modified) * cpukit/pppd/example/README (added) * cpukit/pppd/example/init.c (added) * cpukit/pppd/example/netconfig.h (added) * cpukit/pppd/example/ppp.conf (added) * cpukit/pppd/example/pppdapp.c (added) * cpukit/pppd/example/system.h (added) * cpukit/pppd/fsm.c (modified) * cpukit/pppd/fsm.h (modified) * cpukit/pppd/ipcp.c (modified) * cpukit/pppd/ipcp.h (modified) * cpukit/pppd/ipxcp.c (modified) * cpukit/pppd/ipxcp.h (modified) * cpukit/pppd/lcp.c (modified) * cpukit/pppd/lcp.h (modified) * cpukit/pppd/magic.c (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/patchlevel.h (modified) * cpukit/pppd/pathnames.h (modified) * cpukit/pppd/pppd.8 (added) * cpukit/pppd/pppd.h (modified) * cpukit/pppd/rtemsmain.c (added) * cpukit/pppd/rtemspppd.c (added) * cpukit/pppd/rtemspppd.h (added) * cpukit/pppd/sys-rtems.c (added) * cpukit/pppd/upap.c (modified) * cpukit/pppd/upap.h (modified) * cpukit/pppd/utils.c (added) 2001-08-16 Mike Siers * Update of ... Mon, 03 Jan 2000 18:28:36 GMT Joel Sherrill [0173ab8] * c/src/libnetworking/pppd/README (modified) * c/src/libnetworking/pppd/main.c (modified) * cpukit/pppd/README (modified) Comments added and some messages translated from Polish. Tue, 30 Nov 1999 22:12:50 GMT Joel Sherrill [d0950ad] * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/net/ppp_defs.h (added) * c/src/exec/libnetworking/sys/syslog.h (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/net/ppp_defs.h (added) * c/src/libnetworking/pppd/Makefile.in (added) * c/src/libnetworking/pppd/README (added) * c/src/libnetworking/pppd/STATUS (added) * c/src/libnetworking/pppd/auth.c (added) * c/src/libnetworking/pppd/cbcp.c (added) * c/src/libnetworking/pppd/cbcp.h (added) * c/src/libnetworking/pppd/ccp.c (added) * c/src/libnetworking/pppd/ccp.h (added) * c/src/libnetworking/pppd/chap.c (added) * c/src/libnetworking/pppd/chap.h (added) * c/src/libnetworking/pppd/chap_ms.c (added) * c/src/libnetworking/pppd/chap_ms.h (added) * c/src/libnetworking/pppd/chat.c (added) * c/src/libnetworking/pppd/demand.c (added) * c/src/libnetworking/pppd/fsm.c (added) * c/src/libnetworking/pppd/fsm.h (added) * c/src/libnetworking/pppd/ipcp.c (added) * c/src/libnetworking/pppd/ipcp.h (added) * c/src/libnetworking/pppd/ipxcp.c (added) * c/src/libnetworking/pppd/ipxcp.h (added) * c/src/libnetworking/pppd/lcp.c (added) * c/src/libnetworking/pppd/lcp.h (added) * c/src/libnetworking/pppd/magic.c (added) * c/src/libnetworking/pppd/magic.h (added) * c/src/libnetworking/pppd/main.c (added) * c/src/libnetworking/pppd/md4.c (added) * c/src/libnetworking/pppd/md4.h (added) * c/src/libnetworking/pppd/md5.c (added) * c/src/libnetworking/pppd/md5.h (added) * c/src/libnetworking/pppd/options.c (added) * c/src/libnetworking/pppd/patchlevel.h (added) * c/src/libnetworking/pppd/pathnames.h (added) * c/src/libnetworking/pppd/ppp_tty.c (added) * c/src/libnetworking/pppd/pppd.h (added) * c/src/libnetworking/pppd/rtems-ppp.c (added) * c/src/libnetworking/pppd/upap.c (added) * c/src/libnetworking/pppd/upap.h (added) * c/src/libnetworking/sys/syslog.h (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/net/ppp_defs.h (added) * cpukit/libnetworking/sys/syslog.h (modified) * cpukit/pppd/README (added) * cpukit/pppd/STATUS (added) * cpukit/pppd/auth.c (added) * cpukit/pppd/cbcp.c (added) * cpukit/pppd/cbcp.h (added) * cpukit/pppd/ccp.c (added) * cpukit/pppd/ccp.h (added) * cpukit/pppd/chap.c (added) * cpukit/pppd/chap.h (added) * cpukit/pppd/chap_ms.c (added) * cpukit/pppd/chap_ms.h (added) * cpukit/pppd/chat.c (added) * cpukit/pppd/demand.c (added) * cpukit/pppd/fsm.c (added) * cpukit/pppd/fsm.h (added) * cpukit/pppd/ipcp.c (added) * cpukit/pppd/ipcp.h (added) * cpukit/pppd/ipxcp.c (added) * cpukit/pppd/ipxcp.h (added) * cpukit/pppd/lcp.c (added) * cpukit/pppd/lcp.h (added) * cpukit/pppd/magic.c (added) * cpukit/pppd/magic.h (added) * cpukit/pppd/md4.c (added) * cpukit/pppd/md4.h (added) * cpukit/pppd/md5.c (added) * cpukit/pppd/md5.h (added) * cpukit/pppd/options.c (added) * cpukit/pppd/patchlevel.h (added) * cpukit/pppd/pathnames.h (added) * cpukit/pppd/pppd.h (added) * cpukit/pppd/upap.c (added) * cpukit/pppd/upap.h (added) Added port of ppp-2.3.5 from Tomasz Domin of ComArch ...
