Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit/posix
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @57fe91f   12/06/00 15:30:58 Joel Sherrill 2000-12-06 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @eb33fa54   12/01/00 22:05:32 Joel Sherrill 2000-12-01 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @2b2bda4   12/01/00 18:57:36 Joel Sherrill 2000-12-01 Joel Sherrill <joel@…> * Added macro support to … 4.104.114.84.95
(edit) @40b05974   11/30/00 14:32:56 Joel Sherrill 2000-11-30 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @a3cdac3   11/27/00 16:58:41 Joel Sherrill 2000-11-27 Joel Sherrill <joel@…> * src/sysconf.c: Add … 4.104.114.84.95
(edit) @feead226   11/09/00 16:43:05 Joel Sherrill 2000-11-09 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @a314d3b4   11/02/00 15:49:06 Joel Sherrill 2000-11-02 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @d60b3efa   10/31/00 21:17:06 Joel Sherrill 2000-10-30 Ralf Corsepius <corsepiu@…> * configure.in: … 4.104.114.84.95
(edit) @781262bb   10/31/00 16:33:48 Joel Sherrill 2000-10-30 Joel Sherrill <joel@…> * include/Makefile.am: … 4.104.114.84.95
(edit) @5582de1   10/25/00 17:19:31 Joel Sherrill 2000-10-25 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @3ac5d4e2   09/05/00 15:34:41 Joel Sherrill 2000-09-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @188c82b   08/30/00 17:12:55 Joel Sherrill 2000-08-30 Joel Sherrill <joel@…> * Many files: Moved … 4.104.114.84.95
(edit) @b602c298   08/25/00 17:15:44 Joel Sherrill 2000-08-25 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @02fe6ab   08/15/00 13:23:13 Joel Sherrill 2000-08-15 Joel Sherrill <joel@…> * src/ptimer1.c: Minor … 4.104.114.84.95
(edit) @939e29d   08/15/00 13:19:57 Joel Sherrill 2000-08-15 Joel Sherrill <joel@…> * src/ptimer1.c: Removed … 4.104.114.84.95
(edit) @ea56c0a8   08/15/00 13:10:29 Joel Sherrill 2000-08-15 Joel Sherrill <joel@…> * posix/src/ptimer1.c: … 4.104.114.84.95
(edit) @16ce86f9   08/15/00 13:00:01 Joel Sherrill 2000-08-15 Joel Sherrill <joel@…> * posix/src/ptimer1.c … 4.104.114.84.95
(edit) @e94ad1fe   08/10/00 13:24:00 Joel Sherrill Adding ChangeLogs?. 4.104.114.84.95
(edit) @17508d02   07/26/00 19:26:28 Joel Sherrill Port of RTEMS to the Texas Instruments C3x/C4x DSP families including … 4.104.114.84.95
(edit) @df976833   07/07/00 19:31:30 Joel Sherrill Fixed problem reported by Victor V. Vengerov … 4.104.114.84.95
(edit) @1b7e8c51   07/06/00 19:34:49 Joel Sherrill Switched to using _POSIX_Mutex_Get_interrupt_disable to improve … 4.104.114.84.95
(edit) @3ef54dc   07/06/00 19:33:52 Joel Sherrill Added support for converting a mutex id to a pointer and returning … 4.104.114.84.95
(edit) @8ef3818   06/12/00 19:57:02 Joel Sherrill Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier … 4.104.114.84.95
(edit) @df49c60   06/12/00 15:00:15 Joel Sherrill Merged from 4.5.0-beta3a 4.104.114.84.95
(edit) @bf85b19   04/13/00 14:37:14 Joel Sherrill Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @70810dc   02/08/00 22:33:25 Joel Sherrill Patches rtems-rc-20000204-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @e49ebbfa   01/14/00 18:37:59 Joel Sherrill Removed unused variable warning. 4.104.114.84.95
(edit) @4d1af20   01/14/00 18:37:30 Joel Sherrill Removed no prototype of kill() warning. 4.104.114.84.95
(edit) @53fb837a   01/13/00 19:25:15 Joel Sherrill POSIX message queues now include complete functionality including … 4.104.114.84.95
(edit) @d78c6fe3   01/13/00 18:22:32 Jennifer.Averett + Comment cleanup 4.104.114.84.95
(edit) @661ff9a   01/13/00 18:22:09 Jennifer.Averett Removed referance to rtems error. Added correct include file. 4.104.114.84.95
(edit) @e38cb52   01/12/00 18:47:22 Jennifer.Averett Debugged and yellow line tested routines. 4.104.114.84.95
(edit) @68b05694   01/12/00 18:46:54 Jennifer.Averett + Modified return codes + Added messsage size check + Debugged and … 4.104.114.84.95
(edit) @bcbc50a   01/12/00 18:44:19 Jennifer.Averett + Added signal processing. + Yellow line tested source. 4.104.114.84.95
(edit) @352d01e   01/12/00 18:43:21 Jennifer.Averett + Modified to correct return codes. + Removed extra flag attribute … 4.104.114.84.95
(edit) @70329c80   01/12/00 18:41:14 Jennifer.Averett + Changed call from core flush to core close routine. This flushes … 4.104.114.84.95
(edit) @399ba06   01/12/00 18:40:18 Jennifer.Averett + Removed name validation code (this was already done in nametoid. 4.104.114.84.95
(edit) @7558283   01/11/00 15:43:16 Joel Sherrill Fixed spacing. 4.104.114.84.95
(edit) @4fa5eae   01/11/00 15:42:05 Joel Sherrill This code did not return properly when a process oriented signal was … 4.104.114.84.95
(edit) @70af0ea1   01/10/00 18:47:58 Joel Sherrill Don't look at the object information structure for threads/tasks for … 4.104.114.84.95
(edit) @5870ac55   01/05/00 22:19:21 Joel Sherrill Added support for simple binary semaphores in addition to the high … 4.104.114.84.95
(edit) @65800393   01/05/00 17:16:48 Jennifer.Averett Added priority conversion between POSIX and core. 4.104.114.84.95
(edit) @c5858ef   01/05/00 17:16:02 Jennifer.Averett Added priority conversion between POSIX and core priorities. 4.104.114.84.95
(edit) @3ebd4c1   01/05/00 17:13:50 Jennifer.Averett + Changed priority to the POSIX priority type. + Added priority … 4.104.114.84.95
(edit) @fcd0c90   01/05/00 17:11:36 Jennifer.Averett + Added check for reading from a write only queue. + Added ability to … 4.104.114.84.95
(edit) @cecd206   01/05/00 17:09:36 Jennifer.Averett + Added check for name greater than PATH_MAX. 4.104.114.84.95
(edit) @e015106   01/05/00 17:08:56 Jennifer.Averett + Changed to resonable default values for maxmsg and msgsize. + Added … 4.104.114.84.95
(edit) @f602eeb   01/05/00 17:07:52 Jennifer.Averett Added mqueuetranslatereturncode.c. 4.104.114.84.95
(edit) @864ac98   01/05/00 17:06:45 Jennifer.Averett Added routines to translate to and from the core message queue return … 4.104.114.84.95
(edit) @590eb87   01/04/00 17:08:16 Joel Sherrill Added this file to contain an example program. 4.104.114.84.95
(edit) @a148f56   01/04/00 14:00:38 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @2e97c01   12/23/99 22:11:01 Jennifer.Averett + Added routine to remove from namespace. 4.104.114.84.95
(edit) @afebb3f   12/23/99 22:10:13 Jennifer.Averett + Added check for name greater than PATH_MAX 4.104.114.84.95
(edit) @7fbef786   12/23/99 22:09:36 Jennifer.Averett + Debugged. 4.104.114.84.95
(edit) @8f12d069   12/23/99 22:08:43 Jennifer.Averett + Filled in routine. 4.104.114.84.95
(edit) @96d4aea   12/23/99 22:07:43 Jennifer.Averett + Initial debug 4.104.114.84.95
(edit) @d4548d1   12/23/99 22:07:11 Jennifer.Averett + Made work + Added checks for valid attribute maxmsg and msgsize + … 4.104.114.84.95
(edit) @e1786ee3   12/23/99 22:05:25 Jennifer.Averett + Fixed errno response to match the POSIX manual. 4.104.114.84.95
(edit) @1d9a2fc   11/29/99 15:45:11 Joel Sherrill Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @64f55e7   11/29/99 15:40:38 Joel Sherrill Made sure POSIX would build with MP enabled. 4.104.114.84.95
(edit) @fba12eb6   11/23/99 13:29:04 Joel Sherrill Patch rtems-rc-19991117-11.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @101e9b0   11/22/99 16:14:00 Jennifer.Averett Fixed dispatching and cleaned up code. 4.104.114.84.95
(edit) @cb3c1718   11/22/99 16:13:22 Jennifer.Averett + Corrected enable/disable of dispatch. + Cleaned up code. 4.104.114.84.95
(edit) @2545646   11/22/99 16:12:19 Jennifer.Averett + Updated comments. + Corrected enable/disable of dispatch. 4.104.114.84.95
(edit) @94f81bbd   11/22/99 16:11:35 Jennifer.Averett + Corrected bug in error check. 4.104.114.84.95
(edit) @2c3af4c5   11/22/99 16:10:25 Jennifer.Averett + Added description of routine to comment. 4.104.114.84.95
(edit) @0ca4fc8   11/22/99 16:09:55 Jennifer.Averett + Corrected error processing code. 4.104.114.84.95
(edit) @f85409c   11/22/99 16:08:53 Jennifer.Averett + Added checks for NULL and NULL string names (for sem_open & sem_unlink). 4.104.114.84.95
(edit) @0ebf5694   11/22/99 16:07:02 Jennifer.Averett + Cleaned up comments. 4.104.114.84.95
(edit) @9608320   11/22/99 13:41:11 Joel Sherrill Patch rtems-rc-19991117-4.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @c38f5f16   11/18/99 19:55:28 Jennifer.Averett Added EINVAL for passing a NULL pointer in. 4.104.114.84.95
(edit) @17879f4   11/18/99 19:43:13 Jennifer.Averett + Debuged to the point that you could open, unlink and close a … 4.104.114.84.95
(edit) @c9ae846   11/18/99 19:41:34 Jennifer.Averett Added a routine to remove a semaphore name from its namespace. 4.104.114.84.95
(edit) @08311cc3   11/17/99 17:51:34 Joel Sherrill Updated copyright notice. 4.104.114.84.95
(edit) @165fe39   11/16/99 16:01:54 Joel Sherrill Return a reasonable error other than ENOSYS. 4.104.114.84.95
(edit) @7fec3b7a   11/16/99 16:01:32 Joel Sherrill Added call to _Watchdog_Remove to remove the sporadic timer. It was … 4.104.114.84.95
(edit) @80fd699   11/15/99 22:19:51 Joel Sherrill Removed nanosleep() since it is now in its own file. 4.104.114.84.95
(edit) @352c9b2   11/09/99 22:07:23 Joel Sherrill This patch adds the basic framework for the ITRON 3.0 API … 4.104.114.84.95
(edit) @3fb8909a   11/09/99 13:39:42 Joel Sherrill sem_close was accidentally lost in the split. 4.104.114.84.95
(edit) @1c55d2e8   11/05/99 19:38:37 Joel Sherrill Split unistd.c file into sysconf.c and sleep.c. 4.104.114.84.95
(edit) @2b2ab1c   11/03/99 12:51:09 Joel Sherrill Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since … 4.104.114.84.95
(edit) @2b295183   11/03/99 12:47:16 Joel Sherrill Added prototype of _POSIX_Semaphore_Delete to avoid warnings. 4.104.114.84.95
(edit) @0a3946f   11/03/99 12:46:58 Joel Sherrill Added prototype of POSIX_Thread_cancel_run to avoid warnings. 4.104.114.84.95
(edit) @811fae1   11/02/99 19:24:38 Joel Sherrill Split types.s into individual files. 4.104.114.84.95
(edit) @07e0743   11/02/99 19:11:16 Joel Sherrill Final tuning required to drop out POSIX timers. 4.104.114.84.95
(edit) @68003979   11/02/99 19:04:51 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @db7f70a   11/02/99 18:47:06 Joel Sherrill Split cancel.c into multiple files. 4.104.114.84.95
(edit) @43ed935   11/02/99 18:46:30 Joel Sherrill Missed these in the initial split up. 4.104.114.84.95
(edit) @63edcf24   11/02/99 18:40:30 Joel Sherrill Split key.c into multiple files. 4.104.114.84.95
(edit) @cec0371   11/02/99 18:39:52 Joel Sherrill Wrong routine was initially cut into this file. 4.104.114.84.95
(edit) @9f95a19   11/02/99 18:35:52 Joel Sherrill Split time.c into multiple files. 4.104.114.84.95
(edit) @98dca75   11/02/99 18:25:26 Joel Sherrill Split condition variables into multiple files. 4.104.114.84.95
(edit) @799c767   11/02/99 18:00:15 Joel Sherrill Split the POSIX semaphore manager into multiple files. 4.104.114.84.95
(edit) @ee979cd   11/02/99 17:36:20 Joel Sherrill Split some more stuff out of psignal.c. 4.104.114.84.95
(edit) @96c041c   11/02/99 17:19:23 Joel Sherrill Split mutex.c into multiple files. 4.104.114.84.95
(edit) @8a5f2ca   11/02/99 17:18:58 Joel Sherrill Split mqueue into multiple files. 4.104.114.84.95
(edit) @b95e303f   11/02/99 17:14:40 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @4dc89814   11/02/99 17:00:35 Joel Sherrill Split mqueue.c into a variety of files. 4.104.114.84.95
(edit) @fd882ee   11/02/99 15:29:47 Joel Sherrill Now much closer to working. 4.104.114.84.95
(edit) @26c828f   11/02/99 15:29:04 Joel Sherrill Added assert in case _Objects_Get_information fails since this should … 4.104.114.84.95
