@3ef54dc
07/06/00 19:33:52 |
Joel Sherrill |
Added support for converting a mutex id to a pointer and returning …
4.104.114.84.95
@8ef3818
06/12/00 19:57:02 |
Joel Sherrill |
Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier …
4.104.114.84.95
@df49c60
06/12/00 15:00:15 |
Joel Sherrill |
Merged from 4.5.0-beta3a
4.104.114.84.95
@bf85b19
04/13/00 14:37:14 |
Joel Sherrill |
Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@70810dc
02/08/00 22:33:25 |
Joel Sherrill |
Patches rtems-rc-20000204-0.diff from Ralf Corsepius …
4.104.114.84.95
@e49ebbfa
01/14/00 18:37:59 |
Joel Sherrill |
Removed unused variable warning.
4.104.114.84.95
@4d1af20
01/14/00 18:37:30 |
Joel Sherrill |
Removed no prototype of kill() warning.
4.104.114.84.95
@53fb837a
01/13/00 19:25:15 |
Joel Sherrill |
POSIX message queues now include complete functionality including …
4.104.114.84.95
@d78c6fe3
01/13/00 18:22:32 |
Jennifer.Averett |
+ Comment cleanup
4.104.114.84.95
@661ff9a
01/13/00 18:22:09 |
Jennifer.Averett |
Removed referance to rtems error.
Added correct include file.
4.104.114.84.95
@e38cb52
01/12/00 18:47:22 |
Jennifer.Averett |
Debugged and yellow line tested routines.
4.104.114.84.95
@68b05694
01/12/00 18:46:54 |
Jennifer.Averett |
+ Modified return codes
+ Added messsage size check
+ Debugged and …
4.104.114.84.95
@bcbc50a
01/12/00 18:44:19 |
Jennifer.Averett |
+ Added signal processing.
+ Yellow line tested source.
4.104.114.84.95
@352d01e
01/12/00 18:43:21 |
Jennifer.Averett |
+ Modified to correct return codes.
+ Removed extra flag attribute …
4.104.114.84.95
@70329c80
01/12/00 18:41:14 |
Jennifer.Averett |
+ Changed call from core flush to core close routine. This flushes …
4.104.114.84.95
@399ba06
01/12/00 18:40:18 |
Jennifer.Averett |
+ Removed name validation code (this was already done in nametoid.
4.104.114.84.95
@7558283
01/11/00 15:43:16 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@4fa5eae
01/11/00 15:42:05 |
Joel Sherrill |
This code did not return properly when a process oriented signal
was …
4.104.114.84.95
@70af0ea1
01/10/00 18:47:58 |
Joel Sherrill |
Don't look at the object information structure for threads/tasks
for …
4.104.114.84.95
@5870ac55
01/05/00 22:19:21 |
Joel Sherrill |
Added support for simple binary semaphores in addition to the high …
4.104.114.84.95
@65800393
01/05/00 17:16:48 |
Jennifer.Averett |
Added priority conversion between POSIX and core.
4.104.114.84.95
@c5858ef
01/05/00 17:16:02 |
Jennifer.Averett |
Added priority conversion between POSIX and core priorities.
4.104.114.84.95
@3ebd4c1
01/05/00 17:13:50 |
Jennifer.Averett |
+ Changed priority to the POSIX priority type.
+ Added priority …
4.104.114.84.95
@fcd0c90
01/05/00 17:11:36 |
Jennifer.Averett |
+ Added check for reading from a write only queue.
+ Added ability to …
4.104.114.84.95
@cecd206
01/05/00 17:09:36 |
Jennifer.Averett |
+ Added check for name greater than PATH_MAX.
4.104.114.84.95
@e015106
01/05/00 17:08:56 |
Jennifer.Averett |
+ Changed to resonable default values for maxmsg and msgsize.
+ Added …
4.104.114.84.95
@f602eeb
01/05/00 17:07:52 |
Jennifer.Averett |
Added mqueuetranslatereturncode.c.
4.104.114.84.95
@864ac98
01/05/00 17:06:45 |
Jennifer.Averett |
Added routines to translate to and from the core message queue return …
4.104.114.84.95
@590eb87
01/04/00 17:08:16 |
Joel Sherrill |
Added this file to contain an example program.
4.104.114.84.95
@a148f56
01/04/00 14:00:38 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@2e97c01
12/23/99 22:11:01 |
Jennifer.Averett |
+ Added routine to remove from namespace.
4.104.114.84.95
@afebb3f
12/23/99 22:10:13 |
Jennifer.Averett |
4.104.114.84.95
@7fbef786
12/23/99 22:09:36 |
Jennifer.Averett |
+ Debugged.
4.104.114.84.95
@8f12d069
12/23/99 22:08:43 |
Jennifer.Averett |
+ Filled in routine.
4.104.114.84.95
@96d4aea
12/23/99 22:07:43 |
Jennifer.Averett |
+ Initial debug
4.104.114.84.95
@d4548d1
12/23/99 22:07:11 |
Jennifer.Averett |
+ Made work
+ Added checks for valid attribute maxmsg and msgsize
4.104.114.84.95
@e1786ee3
12/23/99 22:05:25 |
Jennifer.Averett |
+ Fixed errno response to match the POSIX manual.
4.104.114.84.95
@1d9a2fc
11/29/99 15:45:11 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius …
4.104.114.84.95
@64f55e7
11/29/99 15:40:38 |
Joel Sherrill |
Made sure POSIX would build with MP enabled.
4.104.114.84.95
@fba12eb6
11/23/99 13:29:04 |
Joel Sherrill |
Patch rtems-rc-19991117-11.diff from Ralf Corsepius …
4.104.114.84.95
@101e9b0
11/22/99 16:14:00 |
Jennifer.Averett |
Fixed dispatching and cleaned up code.
4.104.114.84.95
@cb3c1718
11/22/99 16:13:22 |
Jennifer.Averett |
+ Corrected enable/disable of dispatch.
+ Cleaned up code.
4.104.114.84.95
@2545646
11/22/99 16:12:19 |
Jennifer.Averett |
+ Updated comments.
4.104.114.84.95
@94f81bbd
11/22/99 16:11:35 |
Jennifer.Averett |
+ Corrected bug in error check.
4.104.114.84.95
@2c3af4c5
11/22/99 16:10:25 |
Jennifer.Averett |
+ Added description of routine to comment.
4.104.114.84.95
@0ca4fc8
11/22/99 16:09:55 |
Jennifer.Averett |
+ Corrected error processing code.
4.104.114.84.95
@f85409c
11/22/99 16:08:53 |
Jennifer.Averett |
+ Added checks for NULL and NULL string names (for sem_open & sem_unlink).
4.104.114.84.95
@0ebf5694
11/22/99 16:07:02 |
Jennifer.Averett |
+ Cleaned up comments.
4.104.114.84.95
@9608320
11/22/99 13:41:11 |
Joel Sherrill |
Patch rtems-rc-19991117-4.diff from Ralf Corsepius …
4.104.114.84.95
@c38f5f16
11/18/99 19:55:28 |
Jennifer.Averett |
Added EINVAL for passing a NULL pointer in.
4.104.114.84.95
@17879f4
11/18/99 19:43:13 |
Jennifer.Averett |
+ Debuged to the point that you could open, unlink and close a …
4.104.114.84.95
@c9ae846
11/18/99 19:41:34 |
Jennifer.Averett |
Added a routine to remove a semaphore name from its namespace.
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@165fe39
11/16/99 16:01:54 |
Joel Sherrill |
Return a reasonable error other than ENOSYS.
4.104.114.84.95
@7fec3b7a
11/16/99 16:01:32 |
Joel Sherrill |
Added call to _Watchdog_Remove to remove the sporadic timer. It was …
4.104.114.84.95
@80fd699
11/15/99 22:19:51 |
Joel Sherrill |
Removed nanosleep() since it is now in its own file.
4.104.114.84.95
@352c9b2
11/09/99 22:07:23 |
Joel Sherrill |
This patch adds the basic framework for the ITRON 3.0 API …
4.104.114.84.95
@3fb8909a
11/09/99 13:39:42 |
Joel Sherrill |
sem_close was accidentally lost in the split.
4.104.114.84.95
@1c55d2e8
11/05/99 19:38:37 |
Joel Sherrill |
Split unistd.c file into sysconf.c and sleep.c.
4.104.114.84.95
@2b2ab1c
11/03/99 12:51:09 |
Joel Sherrill |
Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since …
4.104.114.84.95
@2b295183
11/03/99 12:47:16 |
Joel Sherrill |
Added prototype of _POSIX_Semaphore_Delete to avoid warnings.
4.104.114.84.95
@0a3946f
11/03/99 12:46:58 |
Joel Sherrill |
Added prototype of POSIX_Thread_cancel_run to avoid warnings.
4.104.114.84.95
@811fae1
11/02/99 19:24:38 |
Joel Sherrill |
Split types.s into individual files.
4.104.114.84.95
@07e0743
11/02/99 19:11:16 |
Joel Sherrill |
Final tuning required to drop out POSIX timers.
4.104.114.84.95
@68003979
11/02/99 19:04:51 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@db7f70a
11/02/99 18:47:06 |
Joel Sherrill |
Split cancel.c into multiple files.
4.104.114.84.95
@43ed935
11/02/99 18:46:30 |
Joel Sherrill |
Missed these in the initial split up.
4.104.114.84.95
@63edcf24
11/02/99 18:40:30 |
Joel Sherrill |
Split key.c into multiple files.
4.104.114.84.95
@cec0371
11/02/99 18:39:52 |
Joel Sherrill |
Wrong routine was initially cut into this file.
4.104.114.84.95
@9f95a19
11/02/99 18:35:52 |
Joel Sherrill |
Split time.c into multiple files.
4.104.114.84.95
@98dca75
11/02/99 18:25:26 |
Joel Sherrill |
Split condition variables into multiple files.
4.104.114.84.95
@799c767
11/02/99 18:00:15 |
Joel Sherrill |
Split the POSIX semaphore manager into multiple files.
4.104.114.84.95
@ee979cd
11/02/99 17:36:20 |
Joel Sherrill |
Split some more stuff out of psignal.c.
4.104.114.84.95
@96c041c
11/02/99 17:19:23 |
Joel Sherrill |
Split mutex.c into multiple files.
4.104.114.84.95
@8a5f2ca
11/02/99 17:18:58 |
Joel Sherrill |
Split mqueue into multiple files.
4.104.114.84.95
@b95e303f
11/02/99 17:14:40 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@4dc89814
11/02/99 17:00:35 |
Joel Sherrill |
Split mqueue.c into a variety of files.
4.104.114.84.95
@fd882ee
11/02/99 15:29:47 |
Joel Sherrill |
Now much closer to working.
4.104.114.84.95
@26c828f
11/02/99 15:29:04 |
Joel Sherrill |
Added assert in case _Objects_Get_information fails since this
should …
4.104.114.84.95
@2b95c07
11/02/99 15:28:02 |
Joel Sherrill |
Commented out lines causing warning.
4.104.114.84.95
@733a248
11/02/99 15:27:38 |
Joel Sherrill |
Added #define for SEM_FAILED.
4.104.114.84.95
@9d3a44b
11/02/99 15:27:20 |
Joel Sherrill |
Added include of <sys/siginfo.h>.
4.104.114.84.95
@f2422aa
11/02/99 15:26:46 |
Joel Sherrill |
Added message queues and semaphores.
4.104.114.84.95
@0910a251
11/01/99 20:31:25 |
Joel Sherrill |
Added name to id support routine.
4.104.114.84.95
@89b63972
11/01/99 18:02:44 |
Joel Sherrill |
Removed routines that had already been separated into their own files.
4.104.114.84.95
@b6c868e
10/25/99 16:05:34 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…>
to …
4.104.114.84.95
@812f440
10/21/99 16:38:49 |
Joel Sherrill |
Fixed core dump caused when output parameter (otimer) was NULL.
4.104.114.84.95
@811804fe
10/04/99 19:15:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make fix bug …
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@260b0c2
08/30/99 18:05:48 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…> to …
4.104.114.84.95
@ed1a0e51
07/01/99 22:57:23 |
Joel Sherrill |
Honor 0 as PID of caller.
4.104.114.84.95
@51e04a2c
07/01/99 22:28:30 |
Joel Sherrill |
New file to implement signal(2).
4.104.114.84.95
@a0b94685
05/14/99 14:43:53 |
Joel Sherrill |
Removed check for initialized ID at request of Rosimildo DaSilva? …
4.104.114.84.95
@5a909149
05/07/99 17:09:20 |
Joel Sherrill |
Made all calls to _Thread_Yield_processor consistent in how they are …
4.104.114.84.95
@16775a5
05/07/99 16:36:29 |
Joel Sherrill |
Patch from Jiri Gaisler <jgais@…> to allow stacksize
of …
4.104.114.84.95
@c7aa9d6
04/26/99 18:22:08 |
Joel Sherrill |
Repairing damage and recovering changes including C++ wrappers..
4.104.114.84.95
@c8cfdcfe
04/26/99 18:04:46 |
Joel Sherrill |
Recovered changes since CVS file was corrupted.
4.104.114.84.95
@df3e78a
04/19/99 15:54:03 |
Joel Sherrill |
The default action for real-time signals is supposed to be …
4.104.114.84.95
@2df1974
04/15/99 18:58:27 |
Joel Sherrill |
Added include of rtems/posix/cancel.h.
4.104.114.84.95
@da41ecbc
04/15/99 18:58:02 |
Joel Sherrill |
Removed alarm(), killinfo() and pause() because they are now in their …
4.104.114.84.95
