@2545646
11/22/99 16:12:19 |
Jennifer.Averett |
+ Updated comments.
+ Corrected enable/disable of dispatch.
4.104.114.84.95
@94f81bbd
11/22/99 16:11:35 |
Jennifer.Averett |
+ Corrected bug in error check.
4.104.114.84.95
@2c3af4c5
11/22/99 16:10:25 |
Jennifer.Averett |
+ Added description of routine to comment.
4.104.114.84.95
@0ca4fc8
11/22/99 16:09:55 |
Jennifer.Averett |
+ Corrected error processing code.
4.104.114.84.95
@f85409c
11/22/99 16:08:53 |
Jennifer.Averett |
+ Added checks for NULL and NULL string names (for sem_open & sem_unlink).
4.104.114.84.95
@0ebf5694
11/22/99 16:07:02 |
Jennifer.Averett |
+ Cleaned up comments.
4.104.114.84.95
@9608320
11/22/99 13:41:11 |
Joel Sherrill |
Patch rtems-rc-19991117-4.diff from Ralf Corsepius …
4.104.114.84.95
@c38f5f16
11/18/99 19:55:28 |
Jennifer.Averett |
Added EINVAL for passing a NULL pointer in.
4.104.114.84.95
@17879f4
11/18/99 19:43:13 |
Jennifer.Averett |
+ Debuged to the point that you could open, unlink and close a …
4.104.114.84.95
@c9ae846
11/18/99 19:41:34 |
Jennifer.Averett |
Added a routine to remove a semaphore name from its namespace.
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@165fe39
11/16/99 16:01:54 |
Joel Sherrill |
Return a reasonable error other than ENOSYS.
4.104.114.84.95
@7fec3b7a
11/16/99 16:01:32 |
Joel Sherrill |
Added call to _Watchdog_Remove to remove the sporadic timer. It was …
4.104.114.84.95
@80fd699
11/15/99 22:19:51 |
Joel Sherrill |
Removed nanosleep() since it is now in its own file.
4.104.114.84.95
@352c9b2
11/09/99 22:07:23 |
Joel Sherrill |
This patch adds the basic framework for the ITRON 3.0 API …
4.104.114.84.95
@3fb8909a
11/09/99 13:39:42 |
Joel Sherrill |
sem_close was accidentally lost in the split.
4.104.114.84.95
@1c55d2e8
11/05/99 19:38:37 |
Joel Sherrill |
Split unistd.c file into sysconf.c and sleep.c.
4.104.114.84.95
@2b2ab1c
11/03/99 12:51:09 |
Joel Sherrill |
Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since …
4.104.114.84.95
@2b295183
11/03/99 12:47:16 |
Joel Sherrill |
Added prototype of _POSIX_Semaphore_Delete to avoid warnings.
4.104.114.84.95
@0a3946f
11/03/99 12:46:58 |
Joel Sherrill |
Added prototype of POSIX_Thread_cancel_run to avoid warnings.
4.104.114.84.95
@811fae1
11/02/99 19:24:38 |
Joel Sherrill |
Split types.s into individual files.
4.104.114.84.95
@07e0743
11/02/99 19:11:16 |
Joel Sherrill |
Final tuning required to drop out POSIX timers.
4.104.114.84.95
@68003979
11/02/99 19:04:51 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@db7f70a
11/02/99 18:47:06 |
Joel Sherrill |
Split cancel.c into multiple files.
4.104.114.84.95
@43ed935
11/02/99 18:46:30 |
Joel Sherrill |
Missed these in the initial split up.
4.104.114.84.95
@63edcf24
11/02/99 18:40:30 |
Joel Sherrill |
Split key.c into multiple files.
4.104.114.84.95
@cec0371
11/02/99 18:39:52 |
Joel Sherrill |
Wrong routine was initially cut into this file.
4.104.114.84.95
@9f95a19
11/02/99 18:35:52 |
Joel Sherrill |
Split time.c into multiple files.
4.104.114.84.95
@98dca75
11/02/99 18:25:26 |
Joel Sherrill |
Split condition variables into multiple files.
4.104.114.84.95
@799c767
11/02/99 18:00:15 |
Joel Sherrill |
Split the POSIX semaphore manager into multiple files.
4.104.114.84.95
@ee979cd
11/02/99 17:36:20 |
Joel Sherrill |
Split some more stuff out of psignal.c.
4.104.114.84.95
@96c041c
11/02/99 17:19:23 |
Joel Sherrill |
Split mutex.c into multiple files.
4.104.114.84.95
@8a5f2ca
11/02/99 17:18:58 |
Joel Sherrill |
Split mqueue into multiple files.
4.104.114.84.95
@b95e303f
11/02/99 17:14:40 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@4dc89814
11/02/99 17:00:35 |
Joel Sherrill |
Split mqueue.c into a variety of files.
4.104.114.84.95
@fd882ee
11/02/99 15:29:47 |
Joel Sherrill |
Now much closer to working.
4.104.114.84.95
@26c828f
11/02/99 15:29:04 |
Joel Sherrill |
Added assert in case _Objects_Get_information fails since this
should …
4.104.114.84.95
@2b95c07
11/02/99 15:28:02 |
Joel Sherrill |
Commented out lines causing warning.
4.104.114.84.95
@733a248
11/02/99 15:27:38 |
Joel Sherrill |
Added #define for SEM_FAILED.
4.104.114.84.95
@9d3a44b
11/02/99 15:27:20 |
Joel Sherrill |
Added include of <sys/siginfo.h>.
4.104.114.84.95
@f2422aa
11/02/99 15:26:46 |
Joel Sherrill |
Added message queues and semaphores.
4.104.114.84.95
@0910a251
11/01/99 20:31:25 |
Joel Sherrill |
Added name to id support routine.
4.104.114.84.95
@89b63972
11/01/99 18:02:44 |
Joel Sherrill |
Removed routines that had already been separated into their own files.
4.104.114.84.95
@b6c868e
10/25/99 16:05:34 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…>
to …
4.104.114.84.95
@812f440
10/21/99 16:38:49 |
Joel Sherrill |
Fixed core dump caused when output parameter (otimer) was NULL.
4.104.114.84.95
@811804fe
10/04/99 19:15:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make fix bug …
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@260b0c2
08/30/99 18:05:48 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…> to …
4.104.114.84.95
@ed1a0e51
07/01/99 22:57:23 |
Joel Sherrill |
Honor 0 as PID of caller.
4.104.114.84.95
@51e04a2c
07/01/99 22:28:30 |
Joel Sherrill |
New file to implement signal(2).
4.104.114.84.95
@a0b94685
05/14/99 14:43:53 |
Joel Sherrill |
Removed check for initialized ID at request of Rosimildo DaSilva? …
4.104.114.84.95
@5a909149
05/07/99 17:09:20 |
Joel Sherrill |
Made all calls to _Thread_Yield_processor consistent in how they are …
4.104.114.84.95
@16775a5
05/07/99 16:36:29 |
Joel Sherrill |
Patch from Jiri Gaisler <jgais@…> to allow stacksize
of …
4.104.114.84.95
@c7aa9d6
04/26/99 18:22:08 |
Joel Sherrill |
Repairing damage and recovering changes including C++ wrappers..
4.104.114.84.95
@c8cfdcfe
04/26/99 18:04:46 |
Joel Sherrill |
Recovered changes since CVS file was corrupted.
4.104.114.84.95
@df3e78a
04/19/99 15:54:03 |
Joel Sherrill |
The default action for real-time signals is supposed to be …
4.104.114.84.95
@2df1974
04/15/99 18:58:27 |
Joel Sherrill |
Added include of rtems/posix/cancel.h.
4.104.114.84.95
@da41ecbc
04/15/99 18:58:02 |
Joel Sherrill |
Removed alarm(), killinfo() and pause() because they are now in their …
4.104.114.84.95
@93994fdb
04/15/99 18:57:31 |
Joel Sherrill |
Now compiles and is included in normal build even though it is …
4.104.114.84.95
@0f4e074
04/15/99 18:57:02 |
Joel Sherrill |
Cleaned up.
4.104.114.84.95
@3afecf8
04/15/99 18:56:42 |
Joel Sherrill |
Now compiles and is included in normal build even though it is untested.
4.104.114.84.95
@d0f53fe
04/15/99 18:54:01 |
Joel Sherrill |
Enabled cancellation information in POSIX API thread extension structure.
4.104.114.84.95
@82f490f
04/12/99 20:24:56 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to correct the …
4.104.114.84.95
@d115315
04/12/99 15:36:07 |
Joel Sherrill |
Added line to initialize timer_max.
4.104.114.84.95
@5c95996
03/31/99 22:09:11 |
Joel Sherrill |
When compiled in debug mode, the POSIX threads inline file was not …
4.104.114.84.95
@5c6c4c2
03/30/99 17:41:26 |
Joel Sherrill |
Fixed typo where _POSIX_signals_Clear_process_signals was not …
4.104.114.84.95
@e069cdc3
03/01/99 15:18:26 |
Joel Sherrill |
Part of the automake VI patch from Ralf Corsepius …
4.104.114.84.95
@dae18b5
02/10/99 17:22:16 |
Joel Sherrill |
POSIX timer support.
4.104.114.84.95
@aee3d68
02/10/99 17:03:46 |
Joel Sherrill |
POSIX timer support modifications.
4.104.114.84.95
@0747e2d
02/03/99 16:22:18 |
Joel Sherrill |
POSIX Timers submitted by Juan Zamorano Flores …
4.104.114.84.95
@07d880f4
01/31/99 20:45:31 |
Joel Sherrill |
Split psignal.c into many more files. This reduced the amount of …
4.104.114.84.95
@d90df9aa
01/26/99 16:00:04 |
Joel Sherrill |
Added include of <rtems/posix/priority.h> so a macro would expand
and …
4.104.114.84.95
@03598b1
01/25/99 23:20:52 |
Joel Sherrill |
Split most of POSIX Threads Manager into multiple files.
4.104.114.84.95
@535db3ae
01/25/99 23:20:39 |
Joel Sherrill |
Added enough prototypes to allow most of POSIX Threads Manager to be …
4.104.114.84.95
@07a3253d
11/23/98 19:07:58 |
Joel Sherrill |
Added base version of file system infrastructure. This includes a …
4.104.114.84.95
@97e2729d
11/23/98 17:38:09 |
Joel Sherrill |
Added --disable-multiprocessing flag and modified a lot of files to …
4.104.114.84.95
@847375f
11/19/98 17:35:49 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
1) Socket timeout …
4.104.114.84.95
@cb646cb9
09/27/98 16:37:16 |
Joel Sherrill |
New files.
4.104.114.84.95
@b965227f
09/25/98 13:28:28 |
Joel Sherrill |
Now compiles.
4.104.114.84.95
@97149ba
09/25/98 13:17:32 |
Joel Sherrill |
Added ENOSYS stubs for a number of process routines.
4.104.114.84.95
@cb1b853d
06/18/98 19:01:57 |
Joel Sherrill |
All task delete API level services were incorrectly assuming that the …
4.104.114.84.95
@20fff72
04/27/98 13:46:45 |
Joel Sherrill |
Moved POSIX_signals_Siginfo_node structure definition to …
4.104.114.84.95
@9f0dfea
04/27/98 13:46:18 |
Joel Sherrill |
Changed POSIX_SIGNALS_h to RTEMS_POSIX_SIGNALS_h to avoid conflict …
4.104.114.84.95
@a456074d
04/03/98 18:44:44 |
Joel Sherrill |
Made these have real constants.
4.104.114.84.95
@60b791ad
02/17/98 23:46:28 |
Joel Sherrill |
updated copyright to 1998
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@d14418b
10/06/97 21:28:18 |
Joel Sherrill |
Added _Thread_Enable_dispatch to already_timedout path on Wait_support.
4.104.114.84.95
@e8ee2f32
10/05/97 16:26:04 |
Joel Sherrill |
If the specified time period is less than a clock tick, then
it is …
4.104.114.84.95
@9b1f5678
08/22/97 19:11:02 |
Joel Sherrill |
Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER.
4.104.114.84.95
@799a5b9
08/22/97 19:10:44 |
Joel Sherrill |
Added commit about missing support for condition initializer.
4.104.114.84.95
@a14d2af
07/09/97 23:52:08 |
Joel Sherrill |
Changed name from entry to thread_entry to be more compatible with
Ada …
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@6881e0c
04/15/97 18:02:18 |
Joel Sherrill |
Reduced number of POSIX thread priorities from 255 to 254 to avoid …
4.104.114.84.95
@d627c0c4
03/10/97 16:57:08 |
Joel Sherrill |
created. Split getpid() from types.c to allow it to be overridden by …
4.104.114.84.95
@fec60e9
03/10/97 16:56:08 |
Joel Sherrill |
Fixed bug where the initial detachstate was not being set properly
4.104.114.84.95
@f926b34
03/08/97 03:51:55 |
Joel Sherrill |
Modified calls to _Thread_Change_priority to take a third argument. …
4.104.114.84.95
@232d6c1c
03/08/97 03:50:17 |
Joel Sherrill |
Removed getpid from this file and made it its own file. This lets it …
4.104.114.84.95
@5cdcbd2
03/08/97 03:47:34 |
Joel Sherrill |
Added commit to indicate exepcted _Thread_Dispatch_disable_level. …
4.104.114.84.95
@52d99d4a
01/28/97 23:33:22 |
Joel Sherrill |
Switch to using newlib's implementation of time().
4.104.114.84.95
@348ba42
09/30/96 20:14:08 |
Joel Sherrill |
changed stack size of posix initialization threads to double the …
4.104.114.84.95
