@db8e9011
08/12/96 17:02:39 |
Joel Sherrill |
pthread_mutexattr_setprioceiling: valid priority ceiling check looked …
4.104.114.84.95
@684c3c4
08/12/96 16:29:14 |
Joel Sherrill |
pthread_mutexattr_getprotocol: added check for attribute structure …
4.104.114.84.95
@b9444fb9
08/09/96 19:58:58 |
Joel Sherrill |
added code to catch NULL pointers for return values passed to get routines
4.104.114.84.95
@8699a70
08/09/96 18:45:10 |
Joel Sherrill |
sched_yield: was not invoking the dispatcher.
4.104.114.84.95
@d858fdb
08/09/96 17:30:13 |
Joel Sherrill |
merged remote object id and invalid id error cases.
4.104.114.84.95
@567ac45
08/08/96 18:24:29 |
Mark.Johannes |
_POSIX_signals_Clear_signals: added this routine …
4.104.114.84.95
@2014063
08/07/96 22:06:08 |
Joel Sherrill |
sporadic server debugged and working. This required minor changes in …
4.104.114.84.95
@a14684c3
08/07/96 20:58:59 |
Mark.Johannes |
_POSIX_Mutex_From_core_mutex_status: added priority ceiling violation case
4.104.114.84.95
@a61f1a46
08/06/96 16:24:41 |
Joel Sherrill |
_POSIX_Threads_Delete_extension: reorder to eliminate use of local …
4.104.114.84.95
@06883e13
08/06/96 16:24:06 |
Mark.Johannes |
POSIX_Mutex_Default_attributes: changed prio_ceiling to maximum priority
4.104.114.84.95
@b521ae2
08/06/96 16:23:09 |
Joel Sherrill |
pthread_getspecific: use local variable so references to tcb are …
4.104.114.84.95
@22b4b2e
08/01/96 19:24:57 |
Joel Sherrill |
added page delimiters for comment blocks
4.104.114.84.95
@adae080a
07/15/96 14:02:14 |
Mark.Johannes |
Fixed default vectors initialization, sigaction which had a redundant …
4.104.114.84.95
@69c9543
07/04/96 18:09:23 |
Joel Sherrill |
basic test cases passed
4.104.114.84.95
@df8d1440
07/02/96 18:13:59 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@108ef35
06/15/96 19:55:39 |
Joel Sherrill |
initial modifications to support sigtimedwait.
4.104.114.84.95
@9e28da4
06/13/96 22:16:47 |
Mark.Johannes |
sigtimedwait passes initial test cases of timeout and simple satisfaction.
4.104.114.84.95
@c53cfd0f
06/13/96 20:46:15 |
Joel Sherrill |
added queued signals and cleaned up setting of process wide signals so …
4.104.114.84.95
@b85649c4
06/13/96 16:42:21 |
Joel Sherrill |
basic test cases for kill() and alarm().
kill() in particular needs …
4.104.114.84.95
@281ad52
06/12/96 22:49:14 |
Joel Sherrill |
basic kill() which send a signal to pthread_self() appears to work.
4.104.114.84.95
@2291b71
06/12/96 17:45:01 |
Joel Sherrill |
initial implementation of blocking signal routines -- sigwait, …
4.104.114.84.95
@937808f5
06/11/96 22:55:39 |
Joel Sherrill |
added comment to make sure we add unblock of thread
4.104.114.84.95
@ea1a5bef
06/11/96 22:52:42 |
Joel Sherrill |
first attempt at adding algorithm to select the thread which will …
4.104.114.84.95
@c8f5ab5
06/11/96 20:43:55 |
Joel Sherrill |
tested blocking a signal, sending it to self, then unblocking it.
4.104.114.84.95
@98ed15e
06/11/96 16:01:37 |
Joel Sherrill |
Basic signal functionality appears to work. pthread_kill() can …
4.104.114.84.95
@fdec30b
06/10/96 20:47:23 |
Joel Sherrill |
first attempt at the routine which vectors signals.
4.104.114.84.95
@05ce4e09
06/07/96 15:21:27 |
Joel Sherrill |
changed code which set errno and then returned -1 to use the macro …
4.104.114.84.95
@895efd9
06/07/96 13:54:23 |
Joel Sherrill |
key destructor is now run at correct point in pthread_exit() sequence …
4.104.114.84.95
@782bdfd
06/06/96 19:09:27 |
Joel Sherrill |
Removed assert's from routines which return the error ENOSYS.
4.104.114.84.95
@e754dd1d
06/06/96 17:54:37 |
Joel Sherrill |
process oriented scheduler routines now return ENOSYS
4.104.114.84.95
@5d9cb7e
06/06/96 17:24:44 |
Joel Sherrill |
removed timer_getoverrun() since it was also in ptimer.c
4.104.114.84.95
@0207c55
06/06/96 15:36:18 |
Joel Sherrill |
Made the implementation of pthread_equal conditional on RTEMS_DEBUG. …
4.104.114.84.95
@65a5c1b
06/06/96 15:32:49 |
Joel Sherrill |
completed pthread_setschedparam.
4.104.114.84.95
@624133c
06/06/96 14:53:12 |
Joel Sherrill |
added Sporadic Server support
4.104.114.84.95
@9b4e549
06/05/96 14:45:05 |
Joel Sherrill |
renamed Schedule to schedparam in the posix api control information.
4.104.114.84.95
@2c207d1f
06/04/96 20:36:37 |
Joel Sherrill |
make PTHREAD_SCOPE_SYSTEM an unsupported value for contentionscope.
4.104.114.84.95
@65911c32
06/04/96 19:50:15 |
Joel Sherrill |
made sure _Thread_Enable_dispatch is not invoked in cases
where …
4.104.114.84.95
@56bd4a36
06/04/96 19:48:08 |
Joel Sherrill |
made sure routines which called _Objects_Get also called …
4.104.114.84.95
@230a0dcb
06/04/96 19:44:16 |
Joel Sherrill |
added some of the required functionality to pthread_setschedparam and …
4.104.114.84.95
@3ff4688
06/04/96 19:20:53 |
Joel Sherrill |
clean up pass
4.104.114.84.95
@6b067c4
06/04/96 19:15:28 |
Joel Sherrill |
renamed the local variable attrp to the_attr in pthread_create
4.104.114.84.95
@24adc5b
06/04/96 19:05:16 |
Joel Sherrill |
changed sched_rr_get_interval to use the interval to timespec routine.
4.104.114.84.95
@c48e0ee
06/04/96 16:15:59 |
Joel Sherrill |
added interpretation of scheduling policy and parameter information to …
4.104.114.84.95
@8f857992
06/03/96 22:08:18 |
Joel Sherrill |
added thread queue for list of threads waiting to join.
thread is …
4.104.114.84.95
@e811d68
06/03/96 21:06:51 |
Joel Sherrill |
deleted POSIX threads typedef masking Thread_Control
added initial …
4.104.114.84.95
@a26ee01c
06/03/96 18:27:48 |
Joel Sherrill |
nanosleep now fills in the time remaining structure.
4.104.114.84.95
@5b748a1
06/03/96 17:32:19 |
Joel Sherrill |
renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval
4.104.114.84.95
@5ff991e8
06/03/96 16:29:59 |
Joel Sherrill |
created ptimer.c and moved the timer_* routines out of time.c into ptimer.c
4.104.114.84.95
@5e7b6272
05/31/96 23:27:45 |
Joel Sherrill |
renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the …
4.104.114.84.95
@c238a218
05/31/96 21:40:48 |
Joel Sherrill |
added checks to validate values passed to set attribute routines
4.104.114.84.95
@e72d995a
05/31/96 19:01:26 |
Joel Sherrill |
moved sleep() from psignal.c to unistd.c
implemented sigemptyset() …
4.104.114.84.95
@5600661
05/30/96 20:48:10 |
Joel Sherrill |
First cut at implementing time, clock_gettime, clock_settime, …
4.104.114.84.95
@dd32d883
05/29/96 22:46:05 |
Joel Sherrill |
posix initialization threads table was misnamed "posix initialization …
4.104.114.84.95
@7f72217e
05/29/96 21:27:26 |
Joel Sherrill |
comment clean up
4.104.114.84.95
@2a98af84
05/29/96 21:02:20 |
Joel Sherrill |
types.c: spacing
psignal.c: kill recognizes SIGABRT and exits to …
4.104.114.84.95
@cfcfdf0
05/29/96 20:55:05 |
Joel Sherrill |
added pthread_exit
first posix thread ran
4.104.114.84.95
@ece8c9a
05/29/96 19:28:01 |
Joel Sherrill |
first cut at pthread_create
4.104.114.84.95
@9c877c0d
05/29/96 18:46:46 |
Joel Sherrill |
addressed minimum stack size attribute.
There is a potential problem …
4.104.114.84.95
@613cff6
05/29/96 16:54:52 |
Joel Sherrill |
removed all ifdef's on NOT_IMPLEMENTED.
4.104.114.84.95
@974ff40
05/29/96 16:04:31 |
Joel Sherrill |
renamed signal.c to psignal.c to avoid naming problems.
added mp …
4.104.114.84.95
@5a18e04
05/28/96 19:28:32 |
Joel Sherrill |
added initial set of api extension callouts
4.104.114.84.95
@8165b48f
05/28/96 16:16:28 |
Joel Sherrill |
comment cleanup
4.104.114.84.95
@568ebf3
05/24/96 19:32:37 |
Joel Sherrill |
updates to fix typos
4.104.114.84.95
@f4719d5a
05/22/96 22:32:39 |
Joel Sherrill |
These files have been modified in the initial pass at getting the …
4.104.114.84.95
@92262ab
05/10/96 20:23:27 |
Joel Sherrill |
fixed typo
4.104.114.84.95
@67d224a
12/08/95 21:06:15 |
Joel Sherrill |
added correct use of _Thread_queue_Enter_critical_section
4.104.114.84.95
@8d0b7d96
12/01/95 22:03:55 |
Joel Sherrill |
Insert mode argument to _Watchdog_Insert removed. Now are watchdog …
4.104.114.84.95
@eb5a7e07
10/06/95 20:48:38 |
Joel Sherrill |
fixed missing CVS IDs
4.104.114.84.95
@5e9b32b
09/26/95 19:27:15 |
Joel Sherrill |
posix support initially added
4.104.114.84.95
