@b95e303f
11/02/99 17:14:40 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@4dc89814
11/02/99 17:00:35 |
Joel Sherrill |
Split mqueue.c into a variety of files.
4.104.114.84.95
@fd882ee
11/02/99 15:29:47 |
Joel Sherrill |
Now much closer to working.
4.104.114.84.95
@26c828f
11/02/99 15:29:04 |
Joel Sherrill |
Added assert in case _Objects_Get_information fails since this
should …
4.104.114.84.95
@2b95c07
11/02/99 15:28:02 |
Joel Sherrill |
Commented out lines causing warning.
4.104.114.84.95
@0910a251
11/01/99 20:31:25 |
Joel Sherrill |
Added name to id support routine.
4.104.114.84.95
@89b63972
11/01/99 18:02:44 |
Joel Sherrill |
Removed routines that had already been separated into their own files.
4.104.114.84.95
@b6c868e
10/25/99 16:05:34 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…>
to …
4.104.114.84.95
@812f440
10/21/99 16:38:49 |
Joel Sherrill |
Fixed core dump caused when output parameter (otimer) was NULL.
4.104.114.84.95
@260b0c2
08/30/99 18:05:48 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…> to …
4.104.114.84.95
@ed1a0e51
07/01/99 22:57:23 |
Joel Sherrill |
Honor 0 as PID of caller.
4.104.114.84.95
@51e04a2c
07/01/99 22:28:30 |
Joel Sherrill |
New file to implement signal(2).
4.104.114.84.95
@a0b94685
05/14/99 14:43:53 |
Joel Sherrill |
Removed check for initialized ID at request of Rosimildo DaSilva? …
4.104.114.84.95
@5a909149
05/07/99 17:09:20 |
Joel Sherrill |
Made all calls to _Thread_Yield_processor consistent in how they are …
4.104.114.84.95
@16775a5
05/07/99 16:36:29 |
Joel Sherrill |
Patch from Jiri Gaisler <jgais@…> to allow stacksize
of …
4.104.114.84.95
@df3e78a
04/19/99 15:54:03 |
Joel Sherrill |
The default action for real-time signals is supposed to be …
4.104.114.84.95
@2df1974
04/15/99 18:58:27 |
Joel Sherrill |
Added include of rtems/posix/cancel.h.
4.104.114.84.95
@da41ecbc
04/15/99 18:58:02 |
Joel Sherrill |
Removed alarm(), killinfo() and pause() because they are now in their …
4.104.114.84.95
@93994fdb
04/15/99 18:57:31 |
Joel Sherrill |
Now compiles and is included in normal build even though it is …
4.104.114.84.95
@0f4e074
04/15/99 18:57:02 |
Joel Sherrill |
Cleaned up.
4.104.114.84.95
@3afecf8
04/15/99 18:56:42 |
Joel Sherrill |
Now compiles and is included in normal build even though it is untested.
4.104.114.84.95
@82f490f
04/12/99 20:24:56 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to correct the …
4.104.114.84.95
@d115315
04/12/99 15:36:07 |
Joel Sherrill |
Added line to initialize timer_max.
4.104.114.84.95
@5c95996
03/31/99 22:09:11 |
Joel Sherrill |
When compiled in debug mode, the POSIX threads inline file was not …
4.104.114.84.95
@e069cdc3
03/01/99 15:18:26 |
Joel Sherrill |
Part of the automake VI patch from Ralf Corsepius …
4.104.114.84.95
@dae18b5
02/10/99 17:22:16 |
Joel Sherrill |
POSIX timer support.
4.104.114.84.95
@aee3d68
02/10/99 17:03:46 |
Joel Sherrill |
POSIX timer support modifications.
4.104.114.84.95
@0747e2d
02/03/99 16:22:18 |
Joel Sherrill |
POSIX Timers submitted by Juan Zamorano Flores …
4.104.114.84.95
@07d880f4
01/31/99 20:45:31 |
Joel Sherrill |
Split psignal.c into many more files. This reduced the amount of …
4.104.114.84.95
@d90df9aa
01/26/99 16:00:04 |
Joel Sherrill |
Added include of <rtems/posix/priority.h> so a macro would expand
and …
4.104.114.84.95
@03598b1
01/25/99 23:20:52 |
Joel Sherrill |
Split most of POSIX Threads Manager into multiple files.
4.104.114.84.95
@07a3253d
11/23/98 19:07:58 |
Joel Sherrill |
Added base version of file system infrastructure. This includes a …
4.104.114.84.95
@97e2729d
11/23/98 17:38:09 |
Joel Sherrill |
Added --disable-multiprocessing flag and modified a lot of files to …
4.104.114.84.95
@847375f
11/19/98 17:35:49 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
1) Socket timeout …
4.104.114.84.95
@cb646cb9
09/27/98 16:37:16 |
Joel Sherrill |
New files.
4.104.114.84.95
@b965227f
09/25/98 13:28:28 |
Joel Sherrill |
Now compiles.
4.104.114.84.95
@97149ba
09/25/98 13:17:32 |
Joel Sherrill |
Added ENOSYS stubs for a number of process routines.
4.104.114.84.95
@cb1b853d
06/18/98 19:01:57 |
Joel Sherrill |
All task delete API level services were incorrectly assuming that the …
4.104.114.84.95
@20fff72
04/27/98 13:46:45 |
Joel Sherrill |
Moved POSIX_signals_Siginfo_node structure definition to …
4.104.114.84.95
@d14418b
10/06/97 21:28:18 |
Joel Sherrill |
Added _Thread_Enable_dispatch to already_timedout path on Wait_support.
4.104.114.84.95
@e8ee2f32
10/05/97 16:26:04 |
Joel Sherrill |
If the specified time period is less than a clock tick, then
it is …
4.104.114.84.95
@9b1f5678
08/22/97 19:11:02 |
Joel Sherrill |
Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER.
4.104.114.84.95
@a14d2af
07/09/97 23:52:08 |
Joel Sherrill |
Changed name from entry to thread_entry to be more compatible with
Ada …
4.104.114.84.95
@d627c0c4
03/10/97 16:57:08 |
Joel Sherrill |
created. Split getpid() from types.c to allow it to be overridden by …
4.104.114.84.95
@fec60e9
03/10/97 16:56:08 |
Joel Sherrill |
Fixed bug where the initial detachstate was not being set properly
4.104.114.84.95
@f926b34
03/08/97 03:51:55 |
Joel Sherrill |
Modified calls to _Thread_Change_priority to take a third argument. …
4.104.114.84.95
@232d6c1c
03/08/97 03:50:17 |
Joel Sherrill |
Removed getpid from this file and made it its own file. This lets it …
4.104.114.84.95
@5cdcbd2
03/08/97 03:47:34 |
Joel Sherrill |
Added commit to indicate exepcted _Thread_Dispatch_disable_level. …
4.104.114.84.95
@52d99d4a
01/28/97 23:33:22 |
Joel Sherrill |
Switch to using newlib's implementation of time().
4.104.114.84.95
@348ba42
09/30/96 20:14:08 |
Joel Sherrill |
changed stack size of posix initialization threads to double the …
4.104.114.84.95
@41be2e8
09/17/96 21:31:30 |
Joel Sherrill |
added routine _POSIX_Timespec_subtract
4.104.114.84.95
@aa48536
09/17/96 21:31:10 |
Joel Sherrill |
Added code to insure that the post switch extension was executed and …
4.104.114.84.95
@9093c3c
09/17/96 21:29:51 |
Joel Sherrill |
Corrected implementation of timed wait on condition variables. First …
4.104.114.84.95
@3335420
09/08/96 16:22:05 |
Joel Sherrill |
moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to pthread.h so it …
4.104.114.84.95
@e7a36a9
09/08/96 16:21:48 |
Joel Sherrill |
Ada task stack size minimize is twice that for regular pthreads.
4.104.114.84.95
@65c421f
09/05/96 20:45:05 |
Joel Sherrill |
default thread attributes: default value for inheritsched changed from …
4.104.114.84.95
@297be5c
09/05/96 20:41:10 |
Joel Sherrill |
pthread_mutex_setprioceiling: fixed bug where returned priority was
4.104.114.84.95
@9a5cbef0
09/05/96 20:29:07 |
Joel Sherrill |
nanosleep: negative value for tv_sec is no longer an error. It now
is …
4.104.114.84.95
@62bf651f
08/29/96 16:39:01 |
Joel Sherrill |
new file to support GNU Ada.
currently the only routine in this file …
4.104.114.84.95
@b5c04b6
08/27/96 15:19:51 |
Joel Sherrill |
fixed typo .. changed == to !=
4.104.114.84.95
@5a234809
08/27/96 15:19:33 |
Joel Sherrill |
check that we were passed a valid mutex and ignore errors from the …
4.104.114.84.95
@0b710dbb
08/23/96 14:47:58 |
Mark.Johannes |
pthread_create: changed EINVAL for no more threads back to EAGAIN
4.104.114.84.95
@c5c5f8c
08/19/96 15:30:25 |
Mark.Johannes |
Changed all EFAULTs to EINVALs
4.104.114.84.95
@02f041e
08/19/96 15:27:37 |
Mark.Johannes |
pthread_mutex_init: added error messages for NULL mutex and EBUSY
4.104.114.84.95
@9ac3e76
08/15/96 19:38:46 |
Mark.Johannes |
changed ENOMEM error message
4.104.114.84.95
@f3e19146
08/15/96 18:58:09 |
Joel Sherrill |
clock_gettime: changed assert condition to a standard error code
4.104.114.84.95
@b03ab630
08/15/96 18:57:07 |
Joel Sherrill |
sched_rr_get_interval: converted assert condition into a standard …
4.104.114.84.95
@de45ddc
08/15/96 16:29:00 |
Mark.Johannes |
pthread_kill: fixed the move of SIG_IGN not SA_SIGINFO
4.104.114.84.95
@948721c
08/15/96 16:24:44 |
Mark.Johannes |
pthread_kill: moved check for SA_SIGINFO to allow for validation of …
4.104.114.84.95
@48e685c
08/15/96 16:22:59 |
Mark.Johannes |
fixed typo for NOTSUP -> ENOTSUP
4.104.114.84.95
@4e63ae5
08/14/96 17:20:45 |
Mark.Johannes |
commented of ENOTSUP until fixed in newlib
4.104.114.84.95
@aae1c932
08/14/96 17:20:03 |
Mark.Johannes |
pthread_cond_timedwait: added error cases for abstime
4.104.114.84.95
@dce801d
08/13/96 21:32:49 |
Mark.Johannes |
pthread_cond_destroy: added enable dispatch to EBUSY case
4.104.114.84.95
@95b76bc
08/13/96 21:10:06 |
Mark.Johannes |
pthread_codn_destroy: EBUSY case moved and uses Thread_queue_First
4.104.114.84.95
@456b3769
08/13/96 20:50:54 |
Mark.Johannes |
pthread_cond_destroy: EBUSY case now uses Thread_queue_First
4.104.114.84.95
@392b35e
08/13/96 20:38:30 |
Joel Sherrill |
deleted a line for spacing correction
4.104.114.84.95
@48b40d8
08/13/96 19:53:51 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: changed status of lock and …
4.104.114.84.95
@76f03c6
08/13/96 19:03:29 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: fixed the timeout sequence.
4.104.114.84.95
@f48c9068
08/13/96 14:24:00 |
Joel Sherrill |
removed errors for TOD not set yet.
made nanosleep return -1/EINTR …
4.104.114.84.95
@1087564
08/12/96 20:59:41 |
Joel Sherrill |
clock_getres: added error check for NULL pointer being passed in.
4.104.114.84.95
@5f08fd6
08/12/96 19:55:09 |
Joel Sherrill |
nanosleep: verify rqtp parameter is non-NULL.
nanosleep: return 0 …
4.104.114.84.95
@40cfab47
08/12/96 19:19:03 |
Joel Sherrill |
time: It is not an error if the TOD is not set.
4.104.114.84.95
@9b77fee
08/12/96 19:00:12 |
Mark.Johannes |
Wait_support: removed the calls to mutex core to posix status codes
4.104.114.84.95
@1402ee25
08/12/96 18:56:04 |
Joel Sherrill |
fixed spacing ; moved a dummy MP support routine to clean up printout.
4.104.114.84.95
@ccdf4c57
08/12/96 18:05:47 |
Joel Sherrill |
pthread_mutex_getprioceiling: added error check for null old_ceiling
4.104.114.84.95
@af04a791
08/12/96 17:40:56 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: added …
4.104.114.84.95
@cdcea6ce
08/12/96 17:21:04 |
Mark.Johannes |
_POSIX_Condition_variables_Signal_support: added setting mutex back to …
4.104.114.84.95
@f126ae2
08/12/96 17:04:13 |
Joel Sherrill |
pthread_mutexattr_setprioceiling: fixed typo
4.104.114.84.95
@db8e9011
08/12/96 17:02:39 |
Joel Sherrill |
pthread_mutexattr_setprioceiling: valid priority ceiling check looked …
4.104.114.84.95
@684c3c4
08/12/96 16:29:14 |
Joel Sherrill |
pthread_mutexattr_getprotocol: added check for attribute structure …
4.104.114.84.95
@b9444fb9
08/09/96 19:58:58 |
Joel Sherrill |
added code to catch NULL pointers for return values passed to get routines
4.104.114.84.95
@8699a70
08/09/96 18:45:10 |
Joel Sherrill |
sched_yield: was not invoking the dispatcher.
4.104.114.84.95
@d858fdb
08/09/96 17:30:13 |
Joel Sherrill |
merged remote object id and invalid id error cases.
4.104.114.84.95
@567ac45
08/08/96 18:24:29 |
Mark.Johannes |
_POSIX_signals_Clear_signals: added this routine …
4.104.114.84.95
@2014063
08/07/96 22:06:08 |
Joel Sherrill |
sporadic server debugged and working. This required minor changes in …
4.104.114.84.95
@a14684c3
08/07/96 20:58:59 |
Mark.Johannes |
_POSIX_Mutex_From_core_mutex_status: added priority ceiling violation case
4.104.114.84.95
@a61f1a46
08/06/96 16:24:41 |
Joel Sherrill |
_POSIX_Threads_Delete_extension: reorder to eliminate use of local …
4.104.114.84.95
@06883e13
08/06/96 16:24:06 |
Mark.Johannes |
POSIX_Mutex_Default_attributes: changed prio_ceiling to maximum priority
4.104.114.84.95
@b521ae2
08/06/96 16:23:09 |
Joel Sherrill |
pthread_getspecific: use local variable so references to tcb are …
4.104.114.84.95
@22b4b2e
08/01/96 19:24:57 |
Joel Sherrill |
added page delimiters for comment blocks
4.104.114.84.95
