@3e9f4c92
10/31/16 12:05:55 |
Sebastian Huber |
posix: Fix timeout handling in sigtimedwait()
Update #2798.
5
@8797c76
09/27/16 13:23:00 |
Sebastian Huber |
score: Unify CORE mutex seize/surrender
Use the …
5
@300f6a48
06/22/16 15:09:23 |
Sebastian Huber |
score: Rework thread priority management
Add priority nodes which …
5
@b20b736
06/28/16 04:54:50 |
Sebastian Huber |
score: Introduce _Thread_Get_priority()
Avoid direct access to thread …
5
@15b5678d
08/01/16 09:03:16 |
Sebastian Huber |
score: Move thread wait node to scheduler node
Update #2556.
5
@e41308ea
08/22/16 08:58:34 |
Sebastian Huber |
score: Introduce Thread_queue_Lock_context
Introduce …
5
@709594f0
08/01/16 20:54:18 |
Gedare Bloom |
posix: nanosleep: adjust elapsed time calculation
Use clock_gettime …
5
@aaaf9610
08/08/16 06:44:51 |
Sebastian Huber |
score: Add debug support to red-black trees
This helps to detect …
5
@2cb9b86e
08/08/16 06:30:17 |
Sebastian Huber |
posix: Fix for RTEMS_DEBUG
5
@3b3552bf
08/03/16 11:40:26 |
Sebastian Huber |
5
@842005e4
07/29/16 17:13:41 |
Gedare Bloom |
posix: nanosleep: optimize away a time conversion
updates #2732
5
@1fcac5ad
07/25/16 14:35:37 |
Sebastian Huber |
score: Turn thread lock into thread wait lock
The …
5
@dfa2cdb
07/27/16 07:09:01 |
Sebastian Huber |
posix: Fix error status
5
@39d97ab
07/26/16 18:13:36 |
Gedare Bloom |
cpukit: refactor nanosleep and use 64-bit timeout for threadq
* Fixes …
5
@e0f17fc
07/15/16 16:52:05 |
Gedare Bloom |
posix: fix clock_nanosleep and nanosleep clock use
Sleeping with …
5
@b5bfaaf9
06/23/16 20:55:38 |
Gedare Bloom |
posix: cond_timedwait remember and use clock from condattr
updates #2745
5
@127c20eb
06/23/16 20:10:39 |
Gedare Bloom |
posix: refactor cond wait support to defer abstime conversion
updates …
5
@6e98ea91
06/09/16 15:40:35 |
Gedare Bloom |
posix: add clock_nanosleep and tests
updates #2732
5
@f23d470
06/09/16 15:33:15 |
Gedare Bloom |
cpukit: Add and use Watchdog_Discipline.
Clock disciplines may be …
5
@059529e
07/21/16 08:15:02 |
Sebastian Huber |
score: Add debug support to chains
* double …
5
@3cdda03
07/21/16 10:02:17 |
Sebastian Huber |
posix: Fix double chain extract
5
@254dc82
06/24/16 09:22:03 |
Sebastian Huber |
score: Change Priority_Control to 64-bit
A 32-bit Priority_Control …
5
@51e008dd
06/23/16 09:49:22 |
Sebastian Huber |
posix: Fix pthread_create()
Do not access data of the executing …
5
@77ff5599
06/10/16 06:48:54 |
Sebastian Huber |
score: Introduce map priority scheduler operation
Introduce map/unmap …
5
@1a4eac50
06/15/16 14:31:33 |
Sebastian Huber |
posix: Generalize _POSIX_Priority_To_core()
Move POSIX API priority …
5
@5a32c48
06/14/16 13:57:54 |
Sebastian Huber |
posix: Make POSIX API aware of scheduler instances
5
@eec08ef
06/15/16 04:59:57 |
Sebastian Huber |
posix: Rework sporadic server scheduling policy
Instead of lowering …
5
@6bab009
06/14/16 15:23:03 |
Sebastian Huber |
posix: Delete POSIX_API_Control::schedparam
This field was redundant.
5
@4dc5450
06/14/16 15:21:53 |
Sebastian Huber |
posix: Delete POSIX_API_Control::schedpolicy
5
@4da078a8
06/14/16 15:01:52 |
Sebastian Huber |
posix: Delete POSIX_API_Control::ss_high_priority
This field was unused.
5
@2df7fcf
06/14/16 09:45:22 |
Sebastian Huber |
posix: _POSIX_Mutex_Default_attributes
Make …
5
@ce6e9ec2
06/14/16 04:50:38 |
Sebastian Huber |
posix: pthread_mutexattr_setprioceiling()
Accept all priority values …
5
@6131b84
03/09/16 21:15:37 |
joel |
Add pthread_condattr_getclock() and pthread_condattr_setclock()
5
@917884c
06/15/16 08:39:09 |
Sebastian Huber |
posix: Fix poradic server initial CPU budget
Update #2738.
5
@5d65d0dd
06/15/16 06:50:29 |
Sebastian Huber |
posix: Use _POSIX_Threads_Sporadic_timer_insert()
5
@6a631da
06/14/16 09:13:22 |
Sebastian Huber |
posix: sched_get_priority_max()
Enable for all configurations since …
5
@0c34dbf3
06/13/16 13:22:47 |
Sebastian Huber |
posix: Add pthread_setschedprio()
Close #2734.
5
@fc30ac5
06/13/16 13:10:31 |
Sebastian Huber |
posix: Fix pthread_setschedparam()
Close #2735.
5
@23b1bb38
06/13/16 04:53:27 |
Sebastian Huber |
posix: Fix pthread_getschedparam()
Return the unmodified thread …
5
@0b713f89
05/30/16 04:59:55 |
Sebastian Huber |
score: Rework CORE inherit priority mutex
Provide dedicated seize and …
5
@33e250c9
05/27/16 13:41:41 |
Sebastian Huber |
score: Rework CORE priority ceiling mutex
Rework seize and surrender …
5
@5a598ac
05/27/16 06:02:03 |
Sebastian Huber |
score: Add CORE mutex variants
Add CORE_recursive_mutex_Control and …
5
@bbb3c5f
05/27/16 09:48:14 |
Sebastian Huber |
posix: Delete POSIX_Mutex_Protocol::process_shared
5
@dbd6550
05/27/16 09:10:42 |
Sebastian Huber |
posix: Avoid use of internal mutex methods
Avoid use of internal …
5
@e0bb60b
05/27/16 08:17:28 |
Sebastian Huber |
5
@2581a56
05/20/16 19:39:56 |
Sebastian Huber |
score: Add semaphore variants
5
@93306058
05/27/16 12:43:19 |
Sebastian Huber |
score: _CORE_mutex_Check_dispatch_for_seize()
Move the safety check …
5
@dce48791
05/23/16 11:37:59 |
Sebastian Huber |
score: Add Status_Control for all APIs
Unify the status codes of the …
5
@d887c1b
05/25/16 12:28:34 |
Sebastian Huber |
posix: Fix sem_init() with too large initial value
Close #2721.
5
@39bcf741
05/25/16 12:23:48 |
Sebastian Huber |
Fix semaphore post overflow status
Close #2720.
5
@9ec7d492
05/25/16 06:37:28 |
Sebastian Huber |
posix: Fix pthread_spin_unlock() error status
Close #2719.
5
@631b3c8
05/23/16 09:40:18 |
Sebastian Huber |
score: Move thread queue MP callout to context
Drop the …
5
@c3d8d9e
05/23/16 04:55:49 |
Sebastian Huber |
score: Get rid of mp_id parameter
Get rid of the mp_id parameter used …
5
@8866e62
05/23/16 04:26:58 |
Sebastian Huber |
score: Move thread queue object support
5
@4b623d65
05/24/16 05:40:18 |
Sebastian Huber |
score: Fix blocking _CORE_message_queue_Submit()
Close #2718.
5
@16dbcdcd
05/23/16 09:42:41 |
Sebastian Huber |
score: _CORE_message_queue_Seize()
Delete unused parameter.
5
@bdb3b7f
05/20/16 13:52:27 |
Sebastian Huber |
score: _CORE_semaphore_Seize()
5
@e266d13
05/20/16 13:10:27 |
Sebastian Huber |
Replace *_Get_interrupt_disable() with *_Get()
Uniformly use *_Get() …
5
@28ba7e2
05/20/16 07:38:56 |
Sebastian Huber |
posix: Remove dead code and shrink comment
5
@05f9b02e
05/20/16 05:01:03 |
Sebastian Huber |
posix: Add and use _POSIX_Get_object_body()
5
@64fe1663
05/17/16 11:56:02 |
Sebastian Huber |
posix: Avoid Giant lock for pthread_kill()
Update #2555.
5
@da826560
05/13/16 08:28:14 |
Sebastian Huber |
posix: Rework thread cancellation
Add …
5
@33829ce
05/13/16 12:07:23 |
Sebastian Huber |
score: Avoid Giant lock for _Thread_Start()
Update #2555.
5
@54550e04
05/13/16 06:16:30 |
Sebastian Huber |
posix: Rework pthread_join()
Rework pthread_join() to use …
5
@270394e
05/12/16 12:25:50 |
Sebastian Huber |
score: Avoid superfluous life protection
Disable thread dispatching …
5
@b7f5e391
05/12/16 04:12:06 |
Sebastian Huber |
score: Add _Thread_Exit()
The goal is to make _Thread_Exit() a …
5
@3c20d28
05/17/16 11:39:15 |
Sebastian Huber |
posix: Fix return states of pthread_kill()
POSIX mandates that an …
5
@9fd7271
05/13/16 12:59:31 |
Sebastian Huber |
posix: Fix return status of pthread_cancel()
POSIX recommends ESRCH …
5
@8bc6bf28
05/11/16 11:42:58 |
Sebastian Huber |
posix: Avoid Giant lock for some pthread functions
Avoid Giant lock …
5
@d9952999
05/11/16 09:06:51 |
Sebastian Huber |
score: Avoid Giant lock _Scheduler_Get_affinity()
Update #2555.
5
@e135271
05/11/16 08:58:59 |
Sebastian Huber |
score: Avoid Giant lock _Scheduler_Set_affinity()
Update #2555.
5
@6e4f929
05/06/16 04:44:41 |
Sebastian Huber |
score: Introduce thread state lock
Update #2556.
5
@d9bb9eb
05/06/16 04:58:37 |
Sebastian Huber |
posix: Make _POSIX_signals_Action_handler() static
5
@64051ec
05/04/16 09:10:32 |
Sebastian Huber |
posix: Avoid Giant lock in pthread_equal()
Update #2555.
5
@0a68d8e
05/01/16 14:11:30 |
Sebastian Huber |
score: Optimize _Objects_Get_local()
Make the interrupt lock context …
5
@66374df
04/29/16 07:27:11 |
Sebastian Huber |
posix: Avoid Giant lock in _POSIX_signals_Send()
Update #2555.
Update …
5
@259d885
04/28/16 04:55:16 |
Sebastian Huber |
posix: Remove superfluous thread dispatch disable
The …
5
@500a8e9c
04/28/16 04:26:01 |
Sebastian Huber |
score: Delete RTEMS_STRICT_ORDER_MUTEX
Remove support for strict …
5
@1ef8e4a8
04/27/16 20:07:56 |
Sebastian Huber |
score: Avoid Giant lock for set time of day
Update #2555.
Update #2630.
5
@3888771
04/27/16 19:32:23 |
Sebastian Huber |
score: Streamline set time of day functions
Rename _TOD_Set() into …
5
@c8982e5
04/26/16 19:20:31 |
Sebastian Huber |
posix: Simplify message queues
The mq_open() function returns a …
5
@7e66865e
04/29/16 09:05:36 |
Sebastian Huber |
score: Move message notification
Move message notification to end of …
5
@99112f7
04/27/16 14:21:07 |
Sebastian Huber |
score: _CORE_message_queue_Submit()
Move lock acquire to caller of …
5
@b0eba5ed
04/27/16 14:20:05 |
Sebastian Huber |
5
@7580995
04/26/16 19:18:52 |
Sebastian Huber |
score: _CORE_message_queue_Close()
5
@dd6c28e
04/25/16 14:25:04 |
Sebastian Huber |
posix: Delete POSIX_Message_queue_Control::named
Delete unused …
5
@49c293f4
04/25/16 14:23:13 |
Sebastian Huber |
posix: POSIX_Message_queue_Control::process_shared
Delete unused …
5
@3e36a167
04/25/16 04:33:28 |
Sebastian Huber |
posix: _POSIX_Message_queue_Create_support()
Make …
5
@7f4ee2b
04/22/16 12:37:13 |
Sebastian Huber |
posix: Avoid Giant lock for condition variables
Update #2555.
5
@84a53988
04/21/16 04:32:16 |
Sebastian Huber |
score: Avoid Giant lock for CORE rwlock
Update #2555.
5
@f27383a
04/20/16 12:01:02 |
Sebastian Huber |
score: Avoid Giant lock for barriers
Use …
5
@2dd5e6fb
04/20/16 04:43:11 |
Sebastian Huber |
posix: Use _Objects_Get_local() for semaphores
This simplifies the …
5
@4025a60f
04/19/16 15:02:54 |
Sebastian Huber |
score: Avoid Giant lock for CORE mtx/sem
Avoid Giant lock for CORE …
5
@b5a21bf1
04/20/16 04:15:07 |
Sebastian Huber |
posix: Avoid Giant lock in sem_getvalue()
Update #2555.
5
@cca2d8ab
04/19/16 13:09:29 |
Sebastian Huber |
score: Rename _CORE_RWLock_Obtain()
Rename …
5
@3d0c4005
04/19/16 13:07:39 |
Sebastian Huber |
score: Rename _CORE_barrier_Wait()
Rename _CORE_barrier_Wait() into …
5
@f05eeb2
04/19/16 11:39:00 |
Sebastian Huber |
score: Simplify _Objects_Initialize_information()
Remove unused …
5
@48b04fc3
04/19/16 04:28:03 |
Sebastian Huber |
posix: Avoid Giant lock for mutexes
Delete _POSIX_Mutex_Get(). Use …
5
@b8bdced1
04/18/16 15:21:43 |
Sebastian Huber |
posix: Simplify _POSIX_Mutex_Get_interrupt_disable
Remove superfluous …
5
@beba41b
04/18/16 15:10:03 |
Sebastian Huber |
posix: _POSIX_Condition_variables_Wait_support()
Simplify …
5
