# # ChangeLog for cpukit/posix/src/mmap.c in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 16:40:25 Wed, 06 Sep 2017 05:31:48 GMT Sebastian Huber [694e946d] * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/posix/include/rtems/posix/mmanimpl.h (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/munmap.c (modified) libio: Remove special-case reference count The top-level IO library ... Fri, 25 Aug 2017 08:58:58 GMT Sebastian Huber [b2ed712] * c/src/lib/libbsp/arm/altera-cyclone-v/rtc/rtc.c (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) * c/src/lib/libbsp/arm/lpc176x/can/can.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc-read-blocks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc-write-blocks.c (modified) * c/src/lib/libbsp/arm/raspberrypi/console/console_select.c (modified) * c/src/lib/libbsp/arm/raspberrypi/misc/vc_defines.h (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c (modified) * c/src/lib/libbsp/arm/shared/arm-pl111-fb.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (modified) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (modified) * c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_framebuffer/framebuffer.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_versions/versions.c (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) * c/src/lib/libbsp/sparc/shared/analog/gradcdac.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c (modified) * c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c (modified) * c/src/lib/libbsp/sparc/shared/iommu/griommu.c (modified) * c/src/lib/libbsp/sparc/shared/l2c/l2c.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci2dma.c (modified) * c/src/lib/libbsp/sparc/shared/scrub/memscrub.c (modified) * c/src/lib/libbsp/sparc/shared/time/grctm.c (modified) * c/src/lib/libbsp/sparc/shared/time/spwcuc.c (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/sparc64/loader/main.c (modified) * c/src/lib/libcpu/bfin/bf52x/interrupt/interrupt.c (modified) * c/src/lib/libcpu/bfin/interrupt/interrupt.c (modified) * cpukit/dev/i2c/ti-lm25066a.c (modified) * cpukit/include/rtems/printer.h (modified) * cpukit/libcsupport/src/cfmakesane.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fchown.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-find-file.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libfs/src/imfs/imfs_linfile.c (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) * cpukit/libmisc/redirector/stdio-redirect.c (modified) * cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c (modified) * cpukit/libmisc/shell/main_md5.c (modified) * cpukit/libmisc/shell/main_rtrace.c (modified) * cpukit/libmisc/untar/untar_tgz.c (modified) * cpukit/libpci/pci_cfg_print_code.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/shmheap.c (modified) * cpukit/posix/src/shmwkspace.c (modified) * cpukit/score/src/threadq.c (modified) Include missing Update #2133. Mon, 24 Jul 2017 18:46:49 GMT Gedare Bloom [b264998] * cpukit/posix/include/rtems/posix/mmanimpl.h (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/munmap.c (modified) posix: replace mmap mappings lock with libio lock Use the libio ... Thu, 20 Jul 2017 05:25:55 GMT Sebastian Huber [b965f461] * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/munmap.c (modified) posix: Use unprotected chain operations Operarations are already ... Wed, 19 Jul 2017 14:59:16 GMT Kevin Kirspel [bb01a36] * cpukit/posix/src/mmap.c (modified) Fixed issue with searching mapped addresses The loop that checks if ... Thu, 29 Jun 2017 14:36:43 GMT Kevin Kirspel [c6bb1c33] * cpukit/dev/i2c/i2c-bus.c (modified) * cpukit/dev/i2c/i2c-dev.c (modified) * cpukit/dev/spi/spi-bus.c (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_handlers.c (modified) * cpukit/libfs/src/defaults/default_mmap.c (added) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (modified) * cpukit/libfs/src/imfs/imfs_dir_default.c (modified) * cpukit/libfs/src/imfs/imfs_dir_minimal.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_linfile.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/munmap.c (modified) * cpukit/posix/src/shmopen.c (modified) posix/mmap: Add support for file handler and MAP_ANON Added a mmap ... Tue, 16 May 2017 15:37:27 GMT Gedare Bloom [a330c5d] * cpukit/posix/src/mmap.c (modified) posix: clarify expression with parentheses Close #3010. Wed, 15 Mar 2017 18:31:00 GMT Gedare Bloom [87de70a2] * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/posix/include/rtems/posix/mmanimpl.h (modified) * cpukit/posix/include/rtems/posix/shm.h (modified) * cpukit/posix/include/rtems/posix/shmimpl.h (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/munmap.c (modified) * cpukit/posix/src/shmheap.c (modified) * cpukit/posix/src/shmopen.c (modified) * cpukit/posix/src/shmunlink.c (modified) * cpukit/posix/src/shmwkspace.c (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/psxtests/psxshm02/system.h (modified) posix/mman: add mmap support for shm objects Update #2859. Mon, 13 Mar 2017 16:00:35 GMT Chris Johns [8290f95c] * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/mmanimpl.h (added) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/munmap.c (modified) posix: Add mmap/unmap support for mapping files. This version of ... Fri, 12 Aug 2016 16:21:00 GMT Gedare Bloom [2b442a8e] * cpukit/posix/src/mmap.c (modified) posix: fix typo in mmap arguments Fri, 16 Oct 2015 06:21:48 GMT Sebastian Huber [f97536d] * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) * c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c (modified) * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/libblock/src/bdpart-mount.c (modified) * cpukit/libblock/src/bdpart-register.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/media-server.c (modified) * cpukit/libblock/src/media.c (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-config.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/_calloc_r.c (modified) * cpukit/libcsupport/src/_free_r.c (modified) * cpukit/libcsupport/src/_malloc_r.c (modified) * cpukit/libcsupport/src/_realloc_r.c (modified) * cpukit/libcsupport/src/_rename_r.c (modified) * cpukit/libcsupport/src/assocnamebad.c (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/envlock.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/flockfile.c (modified) * cpukit/libcsupport/src/fstat.c (modified) * cpukit/libcsupport/src/ftrylockfile.c (modified) * cpukit/libcsupport/src/funlockfile.c (modified) * cpukit/libcsupport/src/getpid.c (modified) * cpukit/libcsupport/src/isatty_r.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/newlibc_reent.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/printk_plugin.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/rtems_heap_null_extend.c (modified) * cpukit/libcsupport/src/setpgid.c (modified) * cpukit/libcsupport/src/stat.c (modified) * cpukit/libcsupport/src/tcflow.c (modified) * cpukit/libcsupport/src/tcgetpgrp.c (modified) * cpukit/libcsupport/src/tcsendbreak.c (modified) * cpukit/libcsupport/src/tcsetpgrp.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/write_r.c (modified) * cpukit/libfs/src/nfsclient/src/dirutils.c (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/devnull/devnull.c (modified) * cpukit/libmisc/devnull/devzero.c (modified) * cpukit/libmisc/fb/mw_uid.c (modified) * cpukit/libmisc/monitor/mon-command.c (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/libmisc/monitor/mon-driver.c (modified) * cpukit/libmisc/monitor/mon-extension.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-network.c (modified) * cpukit/libmisc/monitor/mon-part.c (modified) * cpukit/libmisc/monitor/mon-queue.c (modified) * cpukit/libmisc/monitor/mon-region.c (modified) * cpukit/libmisc/monitor/mon-sema.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/serdbg/termios_printk.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/err.h (modified) * cpukit/libmisc/shell/extern-cp.h (modified) * cpukit/libmisc/shell/extern-ls.h (modified) * cpukit/libmisc/shell/hexdump-odsyntax.c (modified) * cpukit/libmisc/shell/main_dd.c (modified) * cpukit/libmisc/shell/main_halt.c (modified) * cpukit/libmisc/shell/main_id.c (modified) * cpukit/libmisc/shell/main_logoff.c (modified) * cpukit/libmisc/shell/main_mount_nfs.c (modified) * cpukit/libmisc/shell/main_pwd.c (modified) * cpukit/libmisc/shell/main_stackuse.c (modified) * cpukit/libmisc/shell/main_tty.c (modified) * cpukit/libmisc/shell/main_whoami.c (modified) * cpukit/libmisc/shell/main_wkspaceinfo.c (modified) * cpukit/libmisc/shell/shell_script.c (modified) * cpukit/libmisc/shell/utils-cp.c (modified) * cpukit/libmisc/shell/utils-ls.c (modified) * cpukit/libmisc/shell/verr.c (modified) * cpukit/libmisc/shell/verrx.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/posix/src/_execve.c (modified) * cpukit/posix/src/aio_suspend.c (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/lio_listio.c (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/mprotect.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/munmap.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadatfork.c (modified) * cpukit/posix/src/sched_getparam.c (modified) * cpukit/posix/src/sched_getscheduler.c (modified) * cpukit/posix/src/sched_setparam.c (modified) * cpukit/posix/src/sched_setscheduler.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/timertsr.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/score/include/rtems/score/basedefs.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapgetinfo.c (modified) * cpukit/score/src/heapnoextend.c (modified) * cpukit/score/src/threadqflush.c (modified) * testsuites/libtests/devfs04/test_driver.c (modified) * testsuites/libtests/deviceio01/test_driver.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/sptests/spfatal_support/consume_sems.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) basdefs.h: Add and use RTEMS_UNUSED Thu, 12 Mar 2015 08:04:21 GMT Daniel Cederman [b0f8bb4e] * cpukit/posix/src/mmap.c (modified) posix: Return error code if mmap is used Thu, 12 Mar 2015 08:04:20 GMT Daniel Cederman [d88b0b78] * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/munmap.c (modified) posix: Move function to file with matching name mmap was previously ... Thu, 06 Nov 2014 22:16:56 GMT Joel Sherrill [287843f] * cpukit/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/sys/mman.h (added) * cpukit/posix/src/mmap.c (added) * cpukit/posix/src/mprotect.c (modified) * cpukit/posix/src/munmap.c (added) * cpukit/preinstall.am (modified) sys/mman.h: New file. Clean up and add supporting stubs * ...
