Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit/posix/include
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @c5858ef   01/05/00 17:16:02 Jennifer.Averett Added priority conversion between POSIX and core priorities. 4.104.114.84.95
(edit) @1d9a2fc   11/29/99 15:45:11 Joel Sherrill Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @fba12eb6   11/23/99 13:29:04 Joel Sherrill Patch rtems-rc-19991117-11.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @9608320   11/22/99 13:41:11 Joel Sherrill Patch rtems-rc-19991117-4.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @08311cc3   11/17/99 17:51:34 Joel Sherrill Updated copyright notice. 4.104.114.84.95
(edit) @2b2ab1c   11/03/99 12:51:09 Joel Sherrill Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since … 4.104.114.84.95
(edit) @2b295183   11/03/99 12:47:16 Joel Sherrill Added prototype of _POSIX_Semaphore_Delete to avoid warnings. 4.104.114.84.95
(edit) @0a3946f   11/03/99 12:46:58 Joel Sherrill Added prototype of POSIX_Thread_cancel_run to avoid warnings. 4.104.114.84.95
(edit) @07e0743   11/02/99 19:11:16 Joel Sherrill Final tuning required to drop out POSIX timers. 4.104.114.84.95
(edit) @68003979   11/02/99 19:04:51 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @98dca75   11/02/99 18:25:26 Joel Sherrill Split condition variables into multiple files. 4.104.114.84.95
(edit) @799c767   11/02/99 18:00:15 Joel Sherrill Split the POSIX semaphore manager into multiple files. 4.104.114.84.95
(edit) @96c041c   11/02/99 17:19:23 Joel Sherrill Split mutex.c into multiple files. 4.104.114.84.95
(edit) @8a5f2ca   11/02/99 17:18:58 Joel Sherrill Split mqueue into multiple files. 4.104.114.84.95
(edit) @733a248   11/02/99 15:27:38 Joel Sherrill Added #define for SEM_FAILED. 4.104.114.84.95
(edit) @9d3a44b   11/02/99 15:27:20 Joel Sherrill Added include of <sys/siginfo.h>. 4.104.114.84.95
(edit) @f2422aa   11/02/99 15:26:46 Joel Sherrill Added message queues and semaphores. 4.104.114.84.95
(edit) @811804fe   10/04/99 19:15:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to make fix bug … 4.104.114.84.95
(edit) @e1d8abb   09/07/99 13:45:03 Joel Sherrill Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @16775a5   05/07/99 16:36:29 Joel Sherrill Patch from Jiri Gaisler <jgais@…> to allow stacksize of … 4.104.114.84.95
(edit) @c7aa9d6   04/26/99 18:22:08 Joel Sherrill Repairing damage and recovering changes including C++ wrappers.. 4.104.114.84.95
(edit) @c8cfdcfe   04/26/99 18:04:46 Joel Sherrill Recovered changes since CVS file was corrupted. 4.104.114.84.95
(edit) @d0f53fe   04/15/99 18:54:01 Joel Sherrill Enabled cancellation information in POSIX API thread extension structure. 4.104.114.84.95
(edit) @5c6c4c2   03/30/99 17:41:26 Joel Sherrill Fixed typo where _POSIX_signals_Clear_process_signals was not … 4.104.114.84.95
(edit) @e069cdc3   03/01/99 15:18:26 Joel Sherrill Part of the automake VI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @0747e2d   02/03/99 16:22:18 Joel Sherrill POSIX Timers submitted by Juan Zamorano Flores … 4.104.114.84.95
(edit) @07d880f4   01/31/99 20:45:31 Joel Sherrill Split psignal.c into many more files. This reduced the amount of … 4.104.114.84.95
(edit) @535db3ae   01/25/99 23:20:39 Joel Sherrill Added enough prototypes to allow most of POSIX Threads Manager to be … 4.104.114.84.95
(edit) @97e2729d   11/23/98 17:38:09 Joel Sherrill Added --disable-multiprocessing flag and modified a lot of files to … 4.104.114.84.95
(edit) @9f0dfea   04/27/98 13:46:18 Joel Sherrill Changed POSIX_SIGNALS_h to RTEMS_POSIX_SIGNALS_h to avoid conflict … 4.104.114.84.95
(edit) @a456074d   04/03/98 18:44:44 Joel Sherrill Made these have real constants. 4.104.114.84.95
(edit) @60b791ad   02/17/98 23:46:28 Joel Sherrill updated copyright to 1998 4.104.114.84.95
(edit) @98e4ebf5   10/08/97 15:45:54 Joel Sherrill Fixed typo in the pointer to the license terms. 4.104.114.84.95
(edit) @a14d2af   07/09/97 23:52:08 Joel Sherrill Changed name from entry to thread_entry to be more compatible with Ada … 4.104.114.84.95
(edit) @03f2154e   04/22/97 17:20:27 Joel Sherrill headers updated to reflect new style copyright notice as part of … 4.104.114.84.95
(edit) @6881e0c   04/15/97 18:02:18 Joel Sherrill Reduced number of POSIX thread priorities from 255 to 254 to avoid … 4.104.114.84.95
(edit) @ded66f8   09/17/96 21:26:25 Joel Sherrill added prototype for _POSIX_Timespec_subtract 4.104.114.84.95
(edit) @ed5a518   09/08/96 16:21:16 Joel Sherrill moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be … 4.104.114.84.95
(edit) @57dae56   08/15/96 18:56:09 Joel Sherrill added constant to indicate there is no mutex associated with this … 4.104.114.84.95
(edit) @3b97b7a0   08/12/96 18:58:12 Mark.Johannes mutex.h: removes the promotion of core status code to POSXI status codes 4.104.114.84.95
(edit) @b1af454   08/12/96 17:41:37 Mark.Johannes mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status 4.104.114.84.95
(edit) @f55d898   08/08/96 16:51:14 Joel Sherrill added ss_high_priority field to support sporadic server. 4.104.114.84.95
(edit) @503dc058   07/03/96 14:20:03 Joel Sherrill switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" 4.104.114.84.95
(edit) @7f13a932   06/14/96 15:49:31 Joel Sherrill fields for init threads stuff said tasks. 4.104.114.84.95
(edit) @25a882a6   06/13/96 20:45:38 Joel Sherrill config.h: added maximum_queued_signals. psignal.h: fixed typo. 4.104.114.84.95
(edit) @7fc3029   06/13/96 16:39:28 Joel Sherrill added prototype for manager initialization routine. 4.104.114.84.95
(edit) @20d099e   06/11/96 22:51:59 Joel Sherrill deleted field for signals_global_pending. 4.104.114.84.95
(edit) @d0baf81   06/11/96 16:00:06 Joel Sherrill new file. 4.104.114.84.95
(edit) @494740c   06/10/96 21:04:14 Joel Sherrill added psignal.h 4.104.114.84.95
(edit) @d03f192   06/10/96 20:46:36 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @fce2e9d   06/06/96 21:27:33 Joel Sherrill in newlib now 4.104.114.84.95
(edit) @ed10d76   06/06/96 14:52:53 Joel Sherrill added Sporadic_timer field to support sporadic server 4.104.114.84.95
(edit) @09c1e31d   06/05/96 14:43:52 Joel Sherrill added comments to priority.h to document the definition of posix … 4.104.114.84.95
(edit) @12c77ab   06/04/96 16:14:55 Joel Sherrill added scheduling policy and parameter information 4.104.114.84.95
(edit) @552a345d   06/03/96 22:07:14 Joel Sherrill added thread queue for list of threads waiting to join. 4.104.114.84.95
(edit) @4427a64   06/03/96 21:06:12 Joel Sherrill deleted POSIX threads typedef masking Thread_Control 4.104.114.84.95
(edit) @5b748a1   06/03/96 17:32:19 Joel Sherrill renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval 4.104.114.84.95
(edit) @a3828359   06/03/96 16:29:35 Joel Sherrill added constant for seconds between posix epoch (1970) and rtems epoch … 4.104.114.84.95
(edit) @b927fba   05/31/96 18:59:57 Joel Sherrill commented out cancel handlers related items. 4.104.114.84.95
(edit) @dd32d883   05/29/96 22:46:05 Joel Sherrill posix initialization threads table was misnamed "posix initialization … 4.104.114.84.95
(edit) @ece8c9a   05/29/96 19:28:01 Joel Sherrill first cut at pthread_create 4.104.114.84.95
(edit) @e941ea13   05/29/96 16:54:24 Joel Sherrill added entry point for posix initialization threads to the posix … 4.104.114.84.95
(edit) @c627b2a3   05/28/96 21:40:52 Joel Sherrill split the inclusion of "EXTERN" data based on whether it was sapi, … 4.104.114.84.95
(edit) @5a18e04   05/28/96 19:28:32 Joel Sherrill added initial set of api extension callouts 4.104.114.84.95
(edit) @47d6b140   05/28/96 16:32:55 Joel Sherrill commented out interrupt support 4.104.114.84.95
(edit) @52d9e4d1   05/28/96 16:16:11 Joel Sherrill added maximum keys 4.104.114.84.95
(edit) @e6d4b1d   05/28/96 13:13:34 Joel Sherrill added initial posix configuration support 4.104.114.84.95
(edit) @05195890   05/22/96 22:31:51 Joel Sherrill These files have been modified in the initial pass at getting the … 4.104.114.84.95
(edit) @9700578   10/30/95 21:54:45 Joel Sherrill SPARC port passes all tests 4.104.114.84.95
(edit) @eb5a7e07   10/06/95 20:48:38 Joel Sherrill fixed missing CVS IDs 4.104.114.84.95
(add) @5e9b32b   09/26/95 19:27:15 Joel Sherrill posix support initially added 4.104.114.84.95
