# # ChangeLog for cpukit/librpc in rtems # # Generated by Trac 1.2.1.dev0 # 05/07/24 10:04:31 Thu, 04 Dec 2008 22:53:33 GMT Joel Sherrill [15e44fd] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/Makefile.am (modified) 2008-12-04 Jukka Pietarinen ... Wed, 05 Nov 2008 21:51:45 GMT Joel Sherrill [a2ddf1ca] * cpukit/ChangeLog (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) 2008-11-05 Joel Sherrill * ... Mon, 01 Sep 2008 11:32:18 GMT Ralf Corsepius [a66bc0f] * cpukit/librpc/src/rpc/auth_none.c (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/bindresvport.c (modified) * cpukit/librpc/src/rpc/clnt_generic.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/getrpcent.c (modified) * cpukit/librpc/src/rpc/netname.c (modified) * cpukit/librpc/src/rpc/netnamer.c (modified) * cpukit/librpc/src/rpc/pmap_clnt.c (modified) * cpukit/librpc/src/rpc/pmap_getmaps.c (modified) * cpukit/librpc/src/rpc/pmap_getport.c (modified) * cpukit/librpc/src/rpc/pmap_prot.c (modified) * cpukit/librpc/src/rpc/pmap_prot2.c (modified) * cpukit/librpc/src/rpc/rpc_callmsg.c (modified) * cpukit/librpc/src/rpc/svc_run.c (modified) * cpukit/librpc/src/xdr/xdr.c (modified) * cpukit/librpc/src/xdr/xdr_array.c (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/librpc/src/xdr/xdr_reference.c (modified) Stop using old-style function definitions. Mon, 18 Aug 2008 07:22:23 GMT Ralf Corsepius [142025c] * c/src/lib/libbsp/mips/csb350/timer/timer.c (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/network/elnk.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) Add missing prototypes. Fri, 01 Aug 2008 16:57:19 GMT Ralf Corsepius [0eeca97] * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) Cleanup. Fri, 01 Aug 2008 16:53:46 GMT Ralf Corsepius [38f9509] * cpukit/librpc/src/xdr/xdr_stdio.c (modified) Misc. ansifications. Add prototypes. Fri, 01 Aug 2008 16:44:07 GMT Ralf Corsepius [cd791626] * cpukit/librpc/src/xdr/xdr_mem.c (modified) * cpukit/librpc/src/xdr/xdr_rec.c (modified) * cpukit/librpc/src/xdr/xdr_sizeof.c (modified) Misc. ansifications. Add prototypes. Fri, 01 Aug 2008 16:05:37 GMT Ralf Corsepius [123116d] * cpukit/librpc/src/rpc/getrpcport.c (modified) Misc. ansifications. Fri, 01 Aug 2008 16:04:25 GMT Ralf Corsepius [9c873b1d] * cpukit/librpc/src/rpc/getrpcent.c (modified) Remove stray local decls. Misc. ansifications. Fri, 01 Aug 2008 15:58:16 GMT Ralf Corsepius [b5831567] * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/librpc/src/rpc/svc_auth_unix.c (modified) Misc. ansifications. Fri, 01 Aug 2008 15:51:19 GMT Ralf Corsepius [08ef2dd0] * cpukit/librpc/src/rpc/pmap_clnt.c (modified) Remove stray clnt_perror(). Fri, 01 Aug 2008 15:47:13 GMT Ralf Corsepius [8f926f1] * cpukit/librpc/src/rpc/clnt_tcp.c (modified) Add missing prototypes. Fri, 01 Aug 2008 15:16:38 GMT Ralf Corsepius [b03af1c2] * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) Add missing prototypes. Fri, 01 Aug 2008 14:29:11 GMT Ralf Corsepius [12c21c8] * cpukit/librpc/src/rpc/svc_raw.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) Add missing prototypes. Fri, 01 Aug 2008 14:14:22 GMT Ralf Corsepius [885e1e0] * cpukit/librpc/src/rpc/svc_udp.c (modified) Add missing prototypes. Fri, 01 Aug 2008 07:32:47 GMT Ralf Corsepius [624a038] * cpukit/librpc/src/rpc/svc.c (modified) Add missing prototypes. Fri, 01 Aug 2008 07:28:48 GMT Ralf Corsepius [7d7d5e8e] * cpukit/librpc/src/xdr/xdr_rec.c (modified) Remove register vars. Fri, 01 Aug 2008 07:25:35 GMT Ralf Corsepius [95b5e81] * cpukit/librpc/src/xdr/xdr_mem.c (modified) Misc. ansifications. Fri, 01 Aug 2008 07:04:10 GMT Ralf Corsepius [aec776a] * cpukit/librpc/src/rpc/svc_tcp.c (modified) Misc. ansifications. Fri, 01 Aug 2008 06:59:13 GMT Ralf Corsepius [d943f3a] * cpukit/librpc/src/rpc/clnt_tcp.c (modified) Cosmetics. Fri, 01 Aug 2008 06:56:33 GMT Ralf Corsepius [2d3d0272] * cpukit/librpc/src/rpc/clnt_tcp.c (modified) Misc. ansifications. Fri, 01 Aug 2008 06:50:12 GMT Ralf Corsepius [0c9f5db3] * cpukit/librpc/src/rpc/svc_raw.c (modified) Misc. ansifications. Fri, 01 Aug 2008 06:46:46 GMT Ralf Corsepius [a9b1804] * cpukit/librpc/src/rpc/svc_udp.c (modified) Cosmetics. Fri, 01 Aug 2008 06:45:22 GMT Ralf Corsepius [b8e5e75] * cpukit/librpc/src/rpc/svc_udp.c (modified) Cosmetics. Fri, 01 Aug 2008 06:44:23 GMT Ralf Corsepius [5a819557] * cpukit/librpc/src/rpc/svc_udp.c (modified) Cosmetics. Fri, 01 Aug 2008 06:39:51 GMT Ralf Corsepius [9d1596d6] * cpukit/librpc/src/xdr/xdr_rec.c (modified) Misc. ansifications. Fri, 01 Aug 2008 06:25:15 GMT Ralf Corsepius [3c412d9] * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) Add missing prototypes. Fri, 01 Aug 2008 06:19:45 GMT Ralf Corsepius [b6e23ea7] * cpukit/librpc/src/rpc/rpc_prot.c (modified) Misc. ansifications. Fri, 01 Aug 2008 06:15:43 GMT Ralf Corsepius [3a81d6d8] * cpukit/librpc/src/rpc/pmap_rmt.c (modified) More ansifications. Fri, 01 Aug 2008 06:12:05 GMT Ralf Corsepius [83516125] * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) Misc. ansifications. Fri, 01 Aug 2008 06:06:27 GMT Ralf Corsepius [18f1673] * cpukit/librpc/src/rpc/auth_unix.c (modified) Misc. ansifications. Add missing prototypes. Fri, 01 Aug 2008 05:59:32 GMT Ralf Corsepius [456ebf81] * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) Misc. ansifications. Fri, 01 Aug 2008 05:40:53 GMT Ralf Corsepius [22dd335a] * cpukit/librpc/include/rpc/pmap_clnt.h (modified) Fix oversight in previous patch. Fri, 01 Aug 2008 05:40:52 GMT Ralf Corsepius [9f4040a] * cpukit/librpc/include/rpc/auth_unix.h (modified) * cpukit/librpc/include/rpc/pmap_clnt.h (modified) * cpukit/librpc/include/rpc/pmap_prot.h (modified) * cpukit/librpc/include/rpc/pmap_rmt.h (modified) * cpukit/librpc/include/rpc/rpc_msg.h (modified) * cpukit/librpc/include/rpc/svc_auth.h (modified) * cpukit/librpc/include/rpcsvc/yp_prot.h (modified) * cpukit/librpc/include/rpcsvc/ypclnt.h (modified) * cpukit/librpc/include/rpcsvc/yppasswd.x (modified) * cpukit/librpc/src/rpc/netnamer.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/librpc/src/xdr/xdr_rec.c (modified) Eliminate __P(). Sat, 29 Mar 2008 05:08:24 GMT Chris Johns [5fd92cc] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/clnt.h (modified) 2008-03-29 Chris Johns * ... Thu, 10 May 2007 07:38:27 GMT Ralf Corsepius [30be2826] * cpukit/librpc/include/rpc/rpc_com.h (modified) Include instead of . Thu, 10 May 2007 07:29:14 GMT Ralf Corsepius [cd9564e] * cpukit/include/rtems/bsd/sys/queue.h (modified) * cpukit/libcsupport/include/sys/ioccom.h (modified) * cpukit/libnetworking/arpa/inet.h (modified) * cpukit/libnetworking/arpa/nameser.h (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/res_stubs.c (modified) * cpukit/libnetworking/machine/in_cksum.h (modified) * cpukit/libnetworking/net/ethernet.h (modified) * cpukit/libnetworking/net/if.h (modified) * cpukit/libnetworking/net/if_dl.h (modified) * cpukit/libnetworking/netdb.h (modified) * cpukit/libnetworking/netinet/ip.h (modified) * cpukit/libnetworking/netinet/tcp.h (modified) * cpukit/libnetworking/resolv.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/sys/libkern.h (modified) * cpukit/libnetworking/sys/mount.h (modified) * cpukit/libnetworking/sys/poll.h (modified) * cpukit/libnetworking/sys/socket.h (modified) * cpukit/libnetworking/sys/sysctl.h (modified) * cpukit/libnetworking/sys/syslog.h (modified) * cpukit/libnetworking/sys/uio.h (modified) * cpukit/libnetworking/sys/un.h (modified) * cpukit/librpc/include/rpc/auth.h (modified) * cpukit/librpc/include/rpc/auth_unix.h (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/clnt_soc.h (modified) * cpukit/librpc/include/rpc/pmap_clnt.h (modified) * cpukit/librpc/include/rpc/pmap_prot.h (modified) * cpukit/librpc/include/rpc/pmap_rmt.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/include/rpc/svc_soc.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/include/rpcsvc/ypclnt.h (modified) Include instead of . Thu, 10 May 2007 05:14:55 GMT Ralf Corsepius [f75082d] * cpukit/librpc/src/xdr/xdr_float.c (modified) Include instead of . Tue, 08 May 2007 12:40:33 GMT Ralf Corsepius [32556fc] * cpukit/ChangeLog (modified) * cpukit/librpc/src/rpc/rtime.c (modified) 2007-05-08 Ralf Corsépius * ... Wed, 28 Mar 2007 16:03:44 GMT Ralf Corsepius [e2a23690] * cpukit/ChangeLog (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) 2007-03-28 Ralf Corsépius * ... Mon, 08 Jan 2007 08:43:28 GMT Ralf Corsepius [63a88eb] * c/src/ada/preinstall.am (modified) * c/src/lib/libbsp/arm/armulator/preinstall.am (modified) * c/src/lib/libbsp/arm/csb336/preinstall.am (modified) * c/src/lib/libbsp/arm/csb337/preinstall.am (modified) * c/src/lib/libbsp/arm/edb7312/preinstall.am (modified) * c/src/lib/libbsp/arm/gba/preinstall.am (modified) * c/src/lib/libbsp/arm/gp32/preinstall.am (modified) * c/src/lib/libbsp/bfin/eZKit533/preinstall.am (modified) * c/src/lib/libbsp/c4x/c4xsim/preinstall.am (modified) * c/src/lib/libbsp/h8300/h8sim/preinstall.am (modified) * c/src/lib/libbsp/i386/i386ex/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/ts_386ex/preinstall.am (modified) * c/src/lib/libbsp/m68k/av5282/preinstall.am (modified) * c/src/lib/libbsp/m68k/csb360/preinstall.am (modified) * c/src/lib/libbsp/m68k/dmv152/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68302/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68340/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68360/preinstall.am (modified) * c/src/lib/libbsp/m68k/idp/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5235/preinstall.am (modified) * c/src/lib/libbsp/m68k/mrm332/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme136/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme147/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme147s/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme162/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme167/preinstall.am (modified) * c/src/lib/libbsp/m68k/ods68302/preinstall.am (modified) * c/src/lib/libbsp/m68k/sim68000/preinstall.am (modified) * c/src/lib/libbsp/m68k/uC5282/preinstall.am (modified) * c/src/lib/libbsp/mips/csb350/preinstall.am (modified) * c/src/lib/libbsp/mips/genmongoosev/preinstall.am (modified) * c/src/lib/libbsp/mips/hurricane/preinstall.am (modified) * c/src/lib/libbsp/mips/jmr3904/preinstall.am (modified) * c/src/lib/libbsp/mips/rbtx4925/preinstall.am (modified) * c/src/lib/libbsp/mips/rbtx4938/preinstall.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/preinstall.am (modified) * c/src/lib/libbsp/powerpc/ep1a/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen405/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen5200/preinstall.am (modified) * c/src/lib/libbsp/powerpc/helas403/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/score603e/preinstall.am (modified) * c/src/lib/libbsp/powerpc/ss555/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh1/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh2/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh4/preinstall.am (modified) * c/src/lib/libbsp/sh/shsim/preinstall.am (modified) * c/src/lib/libbsp/sh/simsh4/preinstall.am (modified) * c/src/lib/libbsp/sparc/erc32/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/unix/posix/preinstall.am (modified) * c/src/lib/libcpu/arm/preinstall.am (modified) * c/src/lib/libcpu/i386/preinstall.am (modified) * c/src/lib/libcpu/m68k/preinstall.am (modified) * c/src/lib/libcpu/mips/preinstall.am (modified) * c/src/lib/libcpu/nios2/preinstall.am (modified) * c/src/lib/libcpu/powerpc/preinstall.am (modified) * c/src/lib/libcpu/sh/preinstall.am (modified) * c/src/lib/libcpu/sparc/preinstall.am (modified) * c/src/libchip/preinstall.am (modified) * c/src/librdbg/preinstall.am (modified) * c/src/librtems++/preinstall.am (modified) * c/src/optman/preinstall.am (modified) * c/src/wrapup/preinstall.am (modified) * cpukit/ftpd/preinstall.am (modified) * cpukit/httpd/preinstall.am (modified) * cpukit/itron/preinstall.am (modified) * cpukit/libcsupport/preinstall.am (modified) * cpukit/libnetworking/preinstall.am (modified) * cpukit/librpc/preinstall.am (modified) * cpukit/posix/preinstall.am (modified) * cpukit/pppd/preinstall.am (modified) * cpukit/preinstall.am (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/sapi/preinstall.am (modified) * cpukit/score/cpu/arm/preinstall.am (modified) * cpukit/score/cpu/avr/preinstall.am (modified) * cpukit/score/cpu/bfin/preinstall.am (modified) * cpukit/score/cpu/c4x/preinstall.am (modified) * cpukit/score/cpu/h8300/preinstall.am (modified) * cpukit/score/cpu/i386/preinstall.am (modified) * cpukit/score/cpu/m68k/preinstall.am (modified) * cpukit/score/cpu/mips/preinstall.am (modified) * cpukit/score/cpu/nios2/preinstall.am (modified) * cpukit/score/cpu/no_cpu/preinstall.am (modified) * cpukit/score/cpu/powerpc/preinstall.am (modified) * cpukit/score/cpu/sh/preinstall.am (modified) * cpukit/score/cpu/sparc/preinstall.am (modified) * cpukit/score/cpu/unix/preinstall.am (modified) * cpukit/score/preinstall.am (modified) * cpukit/telnetd/preinstall.am (modified) * cpukit/wrapup/preinstall.am (modified) * cpukit/zlib/preinstall.am (modified) Regenerate. Thu, 09 Nov 2006 10:28:59 GMT Ralf Corsepius [e4fec90] * cpukit/librpc/src/xdr/xdr_float.c (modified) Add bfin. Thu, 14 Sep 2006 19:09:06 GMT Joel Sherrill [90d2585a] * cpukit/ChangeLog (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/librpc/src/rpc/auth_none.c (modified) * cpukit/librpc/src/rpc/auth_unix.c (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/rpc_callmsg.c (modified) * cpukit/librpc/src/rpc/rpc_prot.c (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) 2006-09-14 Joel Sherrill * ... Fri, 01 Sep 2006 19:10:01 GMT Joel Sherrill [cf04e8ac] * cpukit/libcsupport/src/readdir.c (modified) * cpukit/libnetworking/net/if.h (modified) * cpukit/libnetworking/net/pppcompress.c (modified) * cpukit/libnetworking/net/raw_usrreq.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/ip.h (modified) * cpukit/libnetworking/netinet/ip_divert.c (modified) * cpukit/libnetworking/sys/mbuf.h (modified) * cpukit/librpc/src/xdr/xdr_rec.c (modified) * cpukit/librpc/src/xdr/xdr_sizeof.c (modified) * cpukit/score/include/rtems/score/tod.h (modified) *** empty log message *** Wed, 30 Aug 2006 13:18:40 GMT Joel Sherrill [48b1e29] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/utsname.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/net/if_media.h (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) 2006-08-30 Joel Sherrill * ... Wed, 09 Aug 2006 21:03:27 GMT Joel Sherrill [60eae27d] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/Makefile.am (modified) 2006-08-09 Kolja Waschk * ... Sat, 14 Jan 2006 06:20:35 GMT Ralf Corsepius [2eb7d07e] * c/src/ada/preinstall.am (modified) * c/src/lib/libbsp/arm/armulator/preinstall.am (modified) * c/src/lib/libbsp/arm/csb336/preinstall.am (modified) * c/src/lib/libbsp/arm/csb337/preinstall.am (modified) * c/src/lib/libbsp/arm/edb7312/preinstall.am (modified) * c/src/lib/libbsp/arm/gba/preinstall.am (modified) * c/src/lib/libbsp/arm/gp32/preinstall.am (modified) * c/src/lib/libbsp/c4x/c4xsim/preinstall.am (modified) * c/src/lib/libbsp/h8300/h8sim/preinstall.am (modified) * c/src/lib/libbsp/i386/i386ex/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/ts_386ex/preinstall.am (modified) * c/src/lib/libbsp/m68k/av5282/preinstall.am (modified) * c/src/lib/libbsp/m68k/csb360/preinstall.am (modified) * c/src/lib/libbsp/m68k/dmv152/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68302/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68340/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68360/preinstall.am (modified) * c/src/lib/libbsp/m68k/idp/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5235/preinstall.am (modified) * c/src/lib/libbsp/m68k/mrm332/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme136/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme147/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme147s/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme162/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme167/preinstall.am (modified) * c/src/lib/libbsp/m68k/ods68302/preinstall.am (modified) * c/src/lib/libbsp/m68k/sim68000/preinstall.am (modified) * c/src/lib/libbsp/m68k/uC5282/preinstall.am (modified) * c/src/lib/libbsp/mips/csb350/preinstall.am (modified) * c/src/lib/libbsp/mips/genmongoosev/preinstall.am (modified) * c/src/lib/libbsp/mips/jmr3904/preinstall.am (modified) * c/src/lib/libbsp/mips/p4000/preinstall.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/preinstall.am (modified) * c/src/lib/libbsp/powerpc/ep1a/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen405/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen5200/preinstall.am (modified) * c/src/lib/libbsp/powerpc/helas403/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/score603e/preinstall.am (modified) * c/src/lib/libbsp/powerpc/ss555/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh1/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh2/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh4/preinstall.am (modified) * c/src/lib/libbsp/sh/shsim/preinstall.am (modified) * c/src/lib/libbsp/sh/simsh4/preinstall.am (modified) * c/src/lib/libbsp/sparc/erc32/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/unix/posix/preinstall.am (modified) * c/src/lib/libcpu/arm/preinstall.am (modified) * c/src/lib/libcpu/i386/preinstall.am (modified) * c/src/lib/libcpu/m68k/preinstall.am (modified) * c/src/lib/libcpu/mips/preinstall.am (modified) * c/src/lib/libcpu/powerpc/preinstall.am (modified) * c/src/lib/libcpu/sh/preinstall.am (modified) * c/src/lib/libcpu/sparc/preinstall.am (modified) * c/src/libchip/preinstall.am (modified) * c/src/librdbg/preinstall.am (modified) * c/src/librtems++/preinstall.am (modified) * cpukit/httpd/preinstall.am (modified) * cpukit/itron/preinstall.am (modified) * cpukit/libcsupport/preinstall.am (modified) * cpukit/libnetworking/preinstall.am (modified) * cpukit/librpc/preinstall.am (modified) * cpukit/posix/preinstall.am (modified) * cpukit/pppd/preinstall.am (modified) * cpukit/preinstall.am (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/sapi/preinstall.am (modified) * cpukit/score/cpu/arm/preinstall.am (modified) * cpukit/score/cpu/avr/preinstall.am (modified) * cpukit/score/cpu/c4x/preinstall.am (modified) * cpukit/score/cpu/h8300/preinstall.am (modified) * cpukit/score/cpu/i386/preinstall.am (modified) * cpukit/score/cpu/m68k/preinstall.am (modified) * cpukit/score/cpu/mips/preinstall.am (modified) * cpukit/score/cpu/no_cpu/preinstall.am (modified) * cpukit/score/cpu/powerpc/preinstall.am (modified) * cpukit/score/cpu/sh/preinstall.am (modified) * cpukit/score/cpu/sparc/preinstall.am (modified) * cpukit/score/cpu/unix/preinstall.am (modified) * cpukit/score/preinstall.am (modified) * cpukit/telnetd/preinstall.am (modified) * cpukit/zlib/preinstall.am (modified) Regenerate. Thu, 12 Jan 2006 10:02:32 GMT Ralf Corsepius [19a0136] * cpukit/httpd/preinstall.am (modified) * cpukit/librpc/preinstall.am (modified) * cpukit/posix/preinstall.am (modified) * cpukit/pppd/preinstall.am (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/sapi/preinstall.am (modified) * cpukit/score/cpu/powerpc/preinstall.am (modified) * cpukit/telnetd/preinstall.am (modified) * cpukit/zlib/preinstall.am (modified) Regenerate. Thu, 12 Jan 2006 09:57:43 GMT Ralf Corsepius [4e97166] * cpukit/Makefile.am (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/itron/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/avr/Makefile.am (modified) * cpukit/score/cpu/c4x/Makefile.am (modified) * cpukit/score/cpu/h8300/Makefile.am (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/telnetd/Makefile.am (modified) * cpukit/zlib/Makefile.am (modified) Remove all-local. Thu, 12 Jan 2006 04:24:13 GMT Ralf Corsepius [6ce2a66] * cpukit/httpd/preinstall.am (modified) * cpukit/librpc/preinstall.am (modified) * cpukit/posix/preinstall.am (modified) * cpukit/pppd/preinstall.am (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/sapi/preinstall.am (modified) * cpukit/score/cpu/arm/preinstall.am (modified) * cpukit/score/cpu/avr/preinstall.am (modified) * cpukit/score/cpu/c4x/preinstall.am (modified) * cpukit/score/cpu/h8300/preinstall.am (modified) * cpukit/score/cpu/i386/preinstall.am (modified) * cpukit/score/cpu/m68k/preinstall.am (modified) * cpukit/score/cpu/mips/preinstall.am (modified) * cpukit/score/cpu/no_cpu/preinstall.am (modified) * cpukit/score/cpu/powerpc/preinstall.am (modified) * cpukit/score/cpu/sh/preinstall.am (modified) * cpukit/score/cpu/sparc/preinstall.am (modified) * cpukit/score/cpu/unix/preinstall.am (modified) * cpukit/telnetd/preinstall.am (modified) * cpukit/wrapup/preinstall.am (modified) * cpukit/zlib/preinstall.am (modified) Regenerate. Thu, 12 Jan 2006 04:19:28 GMT Ralf Corsepius [dbe8e519] * cpukit/Makefile.am (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/itron/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libi2c/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/avr/Makefile.am (modified) * cpukit/score/cpu/c4x/Makefile.am (modified) * cpukit/score/cpu/h8300/Makefile.am (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/telnetd/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) * cpukit/zlib/Makefile.am (modified) Cleanups Fri, 09 Dec 2005 22:43:14 GMT Till Straumann [39941915] * cpukit/ChangeLog (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) 2005-11-02 Till Straumann ... Fri, 27 May 2005 00:37:13 GMT Joel Sherrill [9d16b9c] * cpukit/ChangeLog (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/librpc/src/rpc/pmap_getmaps.c (modified) * cpukit/librpc/src/rpc/pmap_getport.c (modified) 2005-05-26 Joel Sherrill * ... Wed, 25 May 2005 17:17:14 GMT Ralf Corsepius [9dcab59] * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) Use void* instead of caddr_t. Cosmetics from FreeBSD. Wed, 25 May 2005 15:24:59 GMT Ralf Corsepius [b322727c] * cpukit/librpc/preinstall.am (modified) Regenerate. Wed, 25 May 2005 15:23:22 GMT Ralf Corsepius [18b1aa4a] * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/include/rpc/rpc.h (modified) Reflect removing auth_des.h. Wed, 25 May 2005 15:22:45 GMT Ralf Corsepius [342fa58a] * cpukit/librpc/include/rpc/auth_des.h (deleted) Remove (Unused, unsupported). Wed, 25 May 2005 15:07:19 GMT Ralf Corsepius [12db3bda] * cpukit/librpc/include/rpc/rpc_com.h (modified) * cpukit/librpc/include/rpc/rpc_msg.h (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) Misc. fixes. Wed, 25 May 2005 13:56:50 GMT Ralf Corsepius [c11cb9a5] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/src/rpc/svc.c (modified) More updates from FreeBSD. Wed, 25 May 2005 13:02:40 GMT Ralf Corsepius [fd6a994] * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/clnt_soc.h (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) More updates from FreeBSD. Wed, 25 May 2005 12:25:50 GMT Ralf Corsepius [b3da5b1] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/svc.h (modified) 2005-05-25 Ralf Corsepius * ... Wed, 25 May 2005 11:33:47 GMT Ralf Corsepius [50e3b3f] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/clnt.h (modified) 2005-05-25 Ralf Corsepius * ... Wed, 25 May 2005 10:15:52 GMT Ralf Corsepius [d730986] * cpukit/librpc/preinstall.am (modified) Regenerate. Wed, 25 May 2005 10:15:22 GMT Ralf Corsepius [e9e2469] * cpukit/ChangeLog (modified) * cpukit/librpc/Makefile.am (modified) 2005-05-25 Ralf Corsepius * ... Wed, 25 May 2005 10:05:42 GMT Ralf Corsepius [a8ad6a0] * cpukit/librpc/include/rpc/clnt_soc.h (added) * cpukit/librpc/include/rpc/svc_soc.h (added) New. Wed, 25 May 2005 09:49:57 GMT Ralf Corsepius [9029782] * cpukit/librpc/preinstall.am (modified) Regenerate. Wed, 25 May 2005 09:49:22 GMT Ralf Corsepius [b3a3982] * cpukit/librpc/Makefile.am (modified) 2005-05-25 Ralf Corsepius * ... Wed, 25 May 2005 09:48:27 GMT Ralf Corsepius [9d770ab5] * cpukit/librpc/include/rpc/des_crypt.h (deleted) Remove (Unused, unsupported) Wed, 25 May 2005 09:41:55 GMT Ralf Corsepius [351b0a1] * cpukit/ChangeLog (modified) * cpukit/librpc/Makefile.am (modified) 2005-05-25 Ralf Corsepius * ... Wed, 25 May 2005 09:41:29 GMT Ralf Corsepius [f6a55f20] * cpukit/librpc/preinstall.am (modified) Regenerate. Wed, 25 May 2005 09:40:15 GMT Ralf Corsepius [8ba22b5] * cpukit/librpc/include/rpc/des.h (deleted) Remove (Unused, unsupported). Wed, 25 May 2005 08:58:09 GMT Ralf Corsepius [fc2d29d] * cpukit/ChangeLog (modified) * cpukit/librpc/Makefile.am (modified) 2005-05-25 Ralf Corsepius * ... Wed, 25 May 2005 08:54:37 GMT Ralf Corsepius [ce1c8ea] * cpukit/librpc/src/rpc/auth_des.c (deleted) * cpukit/librpc/src/rpc/auth_time.c (deleted) * cpukit/librpc/src/rpc/authdes_prot.c (deleted) * cpukit/librpc/src/rpc/clnt_unix.c (deleted) * cpukit/librpc/src/rpc/crypt_client.c (deleted) * cpukit/librpc/src/rpc/des_crypt.c (deleted) * cpukit/librpc/src/rpc/des_soft.c (deleted) * cpukit/librpc/src/rpc/getpublickey.c (deleted) * cpukit/librpc/src/rpc/key_call.c (deleted) * cpukit/librpc/src/rpc/key_prot_xdr.c (deleted) * cpukit/librpc/src/rpc/svc_auth_des.c (deleted) * cpukit/librpc/src/rpc/svc_unix.c (deleted) Remove (Unused, obsolete). Wed, 25 May 2005 08:24:10 GMT Ralf Corsepius [f724f4f4] * cpukit/ChangeLog (modified) * cpukit/librpc/Makefile.am (modified) 2005-05-25 Ralf Corsepius * ... Wed, 25 May 2005 08:23:11 GMT Ralf Corsepius [41b326f7] * cpukit/librpc/src/rpc/PSD.doc/nfs.rfc.ms (deleted) * cpukit/librpc/src/rpc/PSD.doc/rpc.prog.ms (deleted) * cpukit/librpc/src/rpc/PSD.doc/rpc.rfc.ms (deleted) * cpukit/librpc/src/rpc/PSD.doc/rpcgen.ms (deleted) * cpukit/librpc/src/rpc/PSD.doc/xdr.nts.ms (deleted) * cpukit/librpc/src/rpc/PSD.doc/xdr.rfc.ms (deleted) Remove (unused, obsolete). Tue, 10 May 2005 08:56:46 GMT Ralf Corsepius [ea78ecad] * c/src/libnetworking/rtems_telnetd/telnetd.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/telnetd/telnetd.c (modified) socklen_t. Tue, 10 May 2005 08:56:01 GMT Ralf Corsepius [94c76bc] * cpukit/librpc/include/rpc/svc.h (modified) Cosmetical update from FreeBSD. Mon, 09 May 2005 13:12:13 GMT Ralf Corsepius [a7b4c36] * cpukit/librpc/src/rpc/bindresvport.c (modified) socklen_t. Mon, 02 May 2005 16:32:12 GMT Jennifer Averett [3eb71183] * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/librpc/src/xdr/xdr.c (modified) 2005-05-02 Jennifer Averett ... Sat, 19 Feb 2005 17:08:36 GMT Ralf Corsepius [476114f5] * cpukit/ftpd/preinstall.am (modified) * cpukit/httpd/preinstall.am (modified) * cpukit/itron/preinstall.am (modified) * cpukit/libcsupport/preinstall.am (modified) * cpukit/libnetworking/preinstall.am (modified) * cpukit/librpc/preinstall.am (modified) * cpukit/posix/preinstall.am (modified) * cpukit/preinstall.am (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/sapi/preinstall.am (modified) * cpukit/score/cpu/arm/preinstall.am (modified) * cpukit/score/cpu/avr/preinstall.am (modified) * cpukit/score/cpu/c4x/preinstall.am (modified) * cpukit/score/cpu/h8300/preinstall.am (modified) * cpukit/score/cpu/i386/preinstall.am (modified) * cpukit/score/cpu/m68k/preinstall.am (modified) * cpukit/score/cpu/mips/preinstall.am (modified) * cpukit/score/cpu/no_cpu/preinstall.am (modified) * cpukit/score/cpu/or32/preinstall.am (modified) * cpukit/score/cpu/powerpc/preinstall.am (modified) * cpukit/score/cpu/sh/preinstall.am (modified) * cpukit/score/cpu/sparc/preinstall.am (modified) * cpukit/score/cpu/unix/preinstall.am (modified) * cpukit/score/preinstall.am (modified) * cpukit/wrapup/preinstall.am (modified) Auto-generated update. Tue, 08 Feb 2005 17:33:42 GMT Ralf Corsepius [b265fdc] * cpukit/ChangeLog (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/preinstall.am (added) 2005-02-08 Ralf Corsepius * ... Thu, 03 Feb 2005 16:26:35 GMT Ralf Corsepius [2538e7ae] * cpukit/ChangeLog (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/include/rpc/clnt_stat.h (added) * cpukit/librpc/include/rpc/rpc.h (modified) * cpukit/librpc/include/rpc/rpcent.h (added) 2005-02-03 Ralf Corsepius * ... Thu, 03 Feb 2005 15:58:18 GMT Ralf Corsepius [0c20a46] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/types.h (modified) * cpukit/librpc/src/rpc/bindresvport.c (modified) 2005-02-03 Ralf Corsepius * ... Fri, 28 Jan 2005 02:15:33 GMT Ralf Corsepius [0c3a6d6] * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) Fix indentation. Sun, 09 Jan 2005 17:12:03 GMT Joel Sherrill [77b6a10] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/pmap_prot2.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) 2005-01-09 Joel Sherrill * ... Sat, 08 Jan 2005 06:01:35 GMT Ralf Corsepius [dab2d6eb] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/auth_des.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/src/rpc/auth_des.c (modified) * cpukit/librpc/src/rpc/auth_unix.c (modified) * cpukit/librpc/src/rpc/rpc_prot.c (modified) * cpukit/librpc/src/xdr/xdr.c (modified) 2005-01-07 Ralf Corsepius * ... Fri, 07 Jan 2005 11:22:50 GMT Ralf Corsepius [c9165ef0] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/auth.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/src/rpc/auth_none.c (modified) 2005-01-07 Ralf Corsepius * ... Fri, 07 Jan 2005 07:46:15 GMT Ralf Corsepius [8faf4bd] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) 2005-01-07 Ralf Corsepius * ... Fri, 07 Jan 2005 06:05:49 GMT Ralf Corsepius [a369ade] * cpukit/ChangeLog (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/itron/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/score/Makefile.am (modified) 2005-01-07 Ralf Corsepius * ... Sat, 01 Jan 2005 10:41:29 GMT Ralf Corsepius [846a4af] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/itron/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) 2005-01-01 Ralf Corsepius * ... Sun, 21 Nov 2004 05:33:00 GMT Ralf Corsepius [5220ae2] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/types.h (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) 2004-11-21 Ralf Corsepius * ... Sun, 21 Nov 2004 04:45:39 GMT Ralf Corsepius [ddb56f4] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/rpc.h (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) 2004-11-21 Ralf Corsepius * ... Fri, 29 Oct 2004 10:38:40 GMT Ralf Corsepius [9929e2d] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/src/coremsg.c (modified) 2004-10-29 Ralf Corsepius * ... Mon, 25 Oct 2004 19:22:07 GMT Eric Norum [4db99d8a] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/xdr.h (modified) No kernel/user distinction. Wed, 29 Sep 2004 20:34:01 GMT Joel Sherrill [ac200c1] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/libmisc/cpuuse/README (modified) * cpukit/libmisc/stackchk/README (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) 2004-09-29 Joel Sherrill * ... Thu, 23 Sep 2004 08:19:27 GMT Ralf Corsepius [e5c8049] * cpukit/ChangeLog (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) 2004-09-23 Ralf Corsepius * ... Thu, 15 Apr 2004 13:41:26 GMT Ralf Corsepius [9532e55] * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/librpc/include/rpcsvc/key_prot.x (modified) * cpukit/librpc/include/rpcsvc/nfs_prot.x (modified) * cpukit/librpc/include/rpcsvc/nlm_prot.x (modified) * cpukit/librpc/include/rpcsvc/pmap_prot.x (modified) * cpukit/librpc/include/rpcsvc/rnusers.x (modified) Remove stray white spaces. Thu, 15 Apr 2004 13:26:21 GMT Ralf Corsepius [3239698] * c/src/lib/libbsp/arm/arm_bare_bsp/include/bsp.h (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/include/registers.h (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/start/start.S (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/startup/exit.c (modified) * c/src/lib/libbsp/arm/armulator/console/console-io.c (modified) * c/src/lib/libbsp/arm/armulator/start/start.S (modified) * c/src/lib/libbsp/arm/armulator/startup/syscalls.c (modified) * c/src/lib/libbsp/arm/edb7312/console/uart.c (modified) * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) * c/src/lib/libbsp/arm/edb7312/irq/bsp_irq_init.c (modified) * c/src/lib/libbsp/arm/edb7312/start/start.S (modified) * c/src/lib/libbsp/arm/edb7312/timer/timer.c (modified) * c/src/lib/libbsp/arm/shared/comm/console.c (modified) * c/src/lib/libbsp/arm/shared/comm/uart.h (modified) * c/src/lib/libbsp/arm/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/arm/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/arm/vegaplus/include/bsp.h (modified) * c/src/lib/libbsp/arm/vegaplus/start/start.S (modified) * c/src/lib/libbsp/arm/vegaplus/startup/exit.c (modified) * c/src/lib/libbsp/c4x/c4xsim/console/debugio.c (modified) * c/src/lib/libbsp/c4x/c4xsim/timer/timer.c (modified) * c/src/lib/libbsp/h8300/h8sim/console/console-io.c (modified) * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) * c/src/lib/libbsp/i386/i386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/pc386/3c509/3c509.h (modified) * c/src/lib/libbsp/i386/pc386/clock/rtc.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/defkeymap.c (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vga.h (modified) * c/src/lib/libbsp/i386/pc386/console/i386kbd.h (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/console/keyboard.c (modified) * c/src/lib/libbsp/i386/pc386/console/mouse_parser.h (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/i386/pc386/console/ps2_drv.h (modified) * c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c (modified) * c/src/lib/libbsp/i386/pc386/console/ps2_mouse.h (modified) * c/src/lib/libbsp/i386/pc386/console/serial_mouse.h (modified) * c/src/lib/libbsp/i386/pc386/console/videoAsm.S (modified) * c/src/lib/libbsp/i386/pc386/console/vt.c (modified) * c/src/lib/libbsp/i386/pc386/ide/ide.c (modified) * c/src/lib/libbsp/i386/pc386/ide/idecfg.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (modified) * c/src/lib/libbsp/i386/pc386/start/start.S (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timerisr.S (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/i386/shared/comm/gdb_glue.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386_io.h (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.h (modified) * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) * c/src/lib/libbsp/i386/shared/comm/uart.h (modified) * c/src/lib/libbsp/i386/shared/pci/pcibios.h (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/rtc.c (modified) * c/src/lib/libbsp/i386/ts_386ex/include/wd80x3.h (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/debug_test.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/serial_gdb.h (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/init.c (modified) * c/src/lib/libbsp/i960/cvme961/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/cvme961/console/console.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/lock.c (modified) * c/src/lib/libbsp/i960/i960sim/console/console-io.c (modified) * c/src/lib/libbsp/i960/rxgen960/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/rxgen960/console/serial.c (modified) * c/src/lib/libbsp/i960/rxgen960/start/rxgen_romld.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/fault.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/fault.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/faultret.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/main.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/memchnl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/nulsystbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_prcb.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rommon.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.h (modified) * c/src/lib/libbsp/m68k/dmv152/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.S (modified) * c/src/lib/libbsp/m68k/gen68340/console/m340uart.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/m68340.h (modified) * c/src/lib/libbsp/m68k/gen68340/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.S (modified) * c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/start/start.S (modified) * c/src/lib/libbsp/m68k/mrm332/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/console.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.h (modified) * c/src/lib/libbsp/m68k/mrm332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mrm332/startup/start_c.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/page_table.c (modified) * c/src/lib/libbsp/m68k/mvme167/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/ods68302/start/debugreset.S (modified) * c/src/lib/libbsp/m68k/ods68302/start/reset.S (modified) * c/src/lib/libbsp/m68k/ods68302/startup/debugport.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/m68302scc.c (modified) * c/src/lib/libbsp/m68k/shared/gdbstub/m68k-stub.c (modified) * c/src/lib/libbsp/m68k/shared/setvec.c (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) * c/src/lib/libbsp/m68k/sim68000/start/start.S (modified) * c/src/lib/libbsp/mips/genmongoosev/start/mg5.h (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c (modified) * c/src/lib/libbsp/mips/jmr3904/console/console-io.c (modified) * c/src/lib/libbsp/mips/jmr3904/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/console/console.c (modified) * c/src/lib/libbsp/mips/p4000/console/led.S (modified) * c/src/lib/libbsp/mips/p4000/liblnk/lnklib.S (modified) * c/src/lib/libbsp/mips/p4000/startup/idtmem.S (modified) * c/src/lib/libbsp/mips/p4000/startup/idttlb.S (modified) * c/src/lib/libbsp/mips/p4000/startup/inittlb.c (modified) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/mips/shared/gdbstub/mips-stub.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/lock.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (modified) * c/src/lib/libbsp/or32/orp/start/start.S (modified) * c/src/lib/libbsp/or32/orp/startup/setvec.c (modified) * c/src/lib/libbsp/or32/orp/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/debugio.c (modified) * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/todcfg.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/canbus.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/console.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/eth_comm/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen405/dlentry/dlentry.S (modified) * c/src/lib/libbsp/powerpc/gen405/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/flashentry.S (modified) * c/src/lib/libbsp/powerpc/helas403/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/console/console.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ide/idecfg.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/console/console.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/if_hdlcsubr.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/start/start.S (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/config.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/debugio.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/ds1385.h (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/nvram.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/stk11c68.h (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/spurious.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/swap.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/universe.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/vectors.S (modified) * c/src/lib/libbsp/powerpc/psim/console/console-io.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/lock.c (modified) * c/src/lib/libbsp/powerpc/psim/start/start.S (modified) * c/src/lib/libbsp/powerpc/psim/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/psim/vectors/vectors.S (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.h (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c (modified) * c/src/lib/libbsp/powerpc/score603e/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.h (modified) * c/src/lib/libbsp/powerpc/score603e/console/console.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolereserveresources.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/tbl85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/gen2.h (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/spurious.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/vmeintr.c (modified) * c/src/lib/libbsp/powerpc/score603e/tod/tod.c (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/vectors.S (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/bootldr.h (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/em86.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/em86real.S (modified) * c/src/lib/libbsp/powerpc/shared/console/inch.c (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/i8259.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.c (modified) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.h (modified) * c/src/lib/libbsp/powerpc/shared/residual/residual.c (modified) * c/src/lib/libbsp/powerpc/shared/residual/residual.h (modified) * c/src/lib/libbsp/powerpc/shared/start/rtems_crti.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/sbrk.c (modified) * c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu.c (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu_asm.S (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ppccache.c (modified) * c/src/lib/libbsp/sh/gensh2/start/start.S (modified) * c/src/lib/libbsp/sh/gensh4/console/console.c (modified) * c/src/lib/libbsp/sh/gensh4/start/start.S (modified) * c/src/lib/libbsp/sh/shsim/trap34/console-io.c (modified) * c/src/lib/libbsp/sh/shsim/trap34/console-support.S (modified) * c/src/lib/libbsp/shared/bsppost.c (modified) * c/src/lib/libbsp/shared/console-polled.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shared/main.c (modified) * c/src/lib/libbsp/shared/sbrk.c (modified) * c/src/lib/libbsp/shared/setvec.c (modified) * c/src/lib/libbsp/shared/tod.c (modified) * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) * c/src/lib/libbsp/sparc/erc32/include/erc32.h (modified) * c/src/lib/libbsp/sparc/erc32/startup/erc32mec.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/leon/console/console.c (modified) * c/src/lib/libbsp/sparc/leon/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon/startup/setvec.c (modified) * c/src/lib/libbsp/unix/posix/startup/setvec.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ppccache.c (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * cpukit/libcsupport/include/motorola/mc68681.h (modified) * cpukit/libcsupport/include/sys/utsname.h (modified) * cpukit/libcsupport/include/zilog/z8036.h (modified) * cpukit/libcsupport/src/__getpid.c (modified) * cpukit/libcsupport/src/access.c (modified) * cpukit/libcsupport/src/assocnamebad.c (modified) * cpukit/libcsupport/src/eval.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/getegid.c (modified) * cpukit/libcsupport/src/getgroups.c (modified) * cpukit/libcsupport/src/getpid.c (modified) * cpukit/libcsupport/src/getppid.c (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/mkdir.c (modified) * cpukit/libcsupport/src/no_posix.c (modified) * cpukit/libcsupport/src/printk.c (modified) * cpukit/libcsupport/src/setsid.c (modified) * cpukit/libcsupport/src/symlink.c (modified) * cpukit/libcsupport/src/termiosreserveresources.c (modified) * cpukit/libcsupport/src/truncate.c (modified) * cpukit/libcsupport/src/ttyname.c (modified) * cpukit/libcsupport/src/ttyname_r.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/imfs/imfs_config.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_free.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unlink.c (modified) * cpukit/libfs/src/imfs/linearfile.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/monitor/mon-manager.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/mw-fb/mw_fb.c (modified) * cpukit/libmisc/serdbg/serdbg.c (modified) * cpukit/libmisc/serdbg/serdbgio.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/untar/untar.c (modified) * cpukit/libnetworking/bpfilter.h (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/machine/conf.h (modified) * cpukit/libnetworking/machine/cpu.h (modified) * cpukit/libnetworking/machine/limits.h (modified) * cpukit/libnetworking/machine/vmparam.h (modified) * cpukit/libnetworking/net/ppp.h (modified) * cpukit/libnetworking/netinet/igmp_var.h (modified) * cpukit/libnetworking/netinet/in_proto.c (modified) * cpukit/libnetworking/netinet/in_rmx.c (modified) * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) * cpukit/libnetworking/opt_ipfw.h (modified) * cpukit/libnetworking/opt_mrouting.h (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/librpc/include/rpcsvc/ypclnt.h (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/getrpcent.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/rpc_callmsg.c (modified) * cpukit/librpc/src/rpc/svc_auth_des.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/librpc/src/xdr/xdr_array.c (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/intr.h (modified) * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/ptimer.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/include/rtems/posix/timer.h (modified) * cpukit/posix/include/sched.h (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/condmp.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuegetattr.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/mqueuereceive.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesend.c (modified) * cpukit/posix/src/mqueuesetattr.c (modified) * cpukit/posix/src/mqueuetimedreceive.c (modified) * cpukit/posix/src/mqueuetimedsend.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/mutexattrdestroy.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/pause.c (modified) * cpukit/posix/src/psignalchecksignal.c (modified) * cpukit/posix/src/pthreadattrgetdetachstate.c (modified) * cpukit/posix/src/pthreadattrgetinheritsched.c (modified) * cpukit/posix/src/pthreadattrgetschedpolicy.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetcpuclockid.c (modified) * cpukit/posix/src/pthreadgetcputime.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadonce.c (modified) * cpukit/posix/src/pthreadsetcputime.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/semaphorenametoid.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigdelset.c (modified) * cpukit/posix/src/sigemptyset.c (modified) * cpukit/posix/src/sigfillset.c (modified) * cpukit/posix/src/sigismember.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/sigwait.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) * cpukit/posix/src/types.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/rtems/src/attr.c (modified) * cpukit/rtems/src/clocktodtoseconds.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/score/cpu/arm/asm.h (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) * cpukit/score/cpu/c4x/asm.h (modified) * cpukit/score/cpu/c4x/cpu_asm.S (modified) * cpukit/score/cpu/c4x/rtems/asm.h (modified) * cpukit/score/cpu/h8300/asm.h (modified) * cpukit/score/cpu/h8300/cpu_asm.S (modified) * cpukit/score/cpu/h8300/rtems/asm.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/registers.h (modified) * cpukit/score/cpu/i960/cpu_asm.S (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/mips/asm.h (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/iregdef.h (modified) * cpukit/score/cpu/mips/rtems/asm.h (modified) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (modified) * cpukit/score/cpu/no_cpu/asm.h (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/asm.h (modified) * cpukit/score/cpu/or32/asm.h (modified) * cpukit/score/cpu/or32/cpu_asm.c (modified) * cpukit/score/cpu/or32/rtems/asm.h (modified) * cpukit/score/cpu/powerpc/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/score/types.h (modified) * cpukit/score/cpu/sparc/asm.h (modified) * cpukit/score/cpu/sparc/rtems/asm.h (modified) * cpukit/score/cpu/unix/rtems/score/unix.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushsupp.c (modified) * cpukit/score/src/coremsgflushwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/coresemsurrender.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtoseconds.c (modified) * cpukit/score/src/coretodvalidate.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadqdequeue.c (modified) * cpukit/score/src/threadqdequeuefifo.c (modified) * cpukit/score/src/threadqdequeuepriority.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqenqueuefifo.c (modified) * cpukit/score/src/threadqenqueuepriority.c (modified) * cpukit/score/src/threadqextract.c (modified) * cpukit/score/src/threadqextractfifo.c (modified) * cpukit/score/src/threadqextractpriority.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadqfirstfifo.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadqtimeout.c (modified) * cpukit/score/src/threadreset.c (modified) * cpukit/score/src/threadrotatequeue.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/watchdogadjust.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * testsuites/itrontests/itronmbf01/init.c (modified) * testsuites/itrontests/itronmbox01/init.c (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask01/task1.c (modified) * testsuites/itrontests/itrontask02/dormant.c (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/init.c (modified) * testsuites/itrontests/itrontask03/preempt.c (modified) * testsuites/itrontests/itrontask04/init.c (modified) * testsuites/itrontests/itrontask04/task1.c (modified) * testsuites/itrontests/itrontask04/task3.c (modified) * testsuites/itrontests/itrontime01/init.c (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/psxtests/psx13/test.c (modified) * testsuites/psxtests/psxcancel/init.c (modified) * testsuites/psxtests/psxchroot01/test.c (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxmount/test.c (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxreaddir/test.c (modified) * testsuites/psxtests/psxsem01/init.c (modified) * testsuites/psxtests/psxsem01/system.h (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxtime/test.c (modified) * testsuites/psxtests/psxtimer/psxtimer.c (modified) * testsuites/samples/fileio/system.h (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/test1.c (modified) * testsuites/samples/unlimited/test2.c (modified) * testsuites/sptests/spfatal/fatal.c (modified) * testsuites/tmtests/tm26/task1.c (modified) Remove stray white spaces. Mon, 08 Mar 2004 16:26:41 GMT Ralf Corsepius [2609e83] * c/src/lib/libbsp/mips/genmongoosev/start/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/console/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/scitab/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/start/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/startup/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/wrapup/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh2/start/.cvsignore (deleted) * c/src/lib/libbsp/sh/shsim/start/.cvsignore (deleted) * c/src/lib/libbsp/sh/simsh4/start/.cvsignore (deleted) * c/src/lib/libbsp/shared/.cvsignore (deleted) * c/src/lib/libcpu/i960/include/.cvsignore (deleted) * c/src/lib/libcpu/m68k/m68040/fpsp/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/clock/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/console/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/include/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/mbus/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/timer/.cvsignore (deleted) * c/src/lib/libcpu/m68k/shared/cache/.cvsignore (deleted) * c/src/lib/libcpu/m68k/shared/misc/.cvsignore (deleted) * c/src/lib/libcpu/mips/clock/.cvsignore (deleted) * c/src/lib/libcpu/mips/shared/cache/.cvsignore (deleted) * c/src/lib/libcpu/mips/shared/interrupts/.cvsignore (deleted) * c/src/lib/libcpu/mips/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc505/ictrl/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc505/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc505/vectors/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/clock/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/clock/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/cpm/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/exceptions/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/include/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/mmu/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/clock/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/exceptions/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/include/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/mmu/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/clock/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/console/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/ictrl/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/tty_drv/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/vectors/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/shared/include/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/clock/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/delay/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/include/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/sci/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/score/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/timer/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/clock/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/include/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/sci/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/score/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/timer/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/clock/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/include/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/sci/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/score/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/timer/.cvsignore (deleted) * c/src/lib/libcpu/sparc/reg_win/.cvsignore (deleted) * c/src/lib/libcpu/sparc/syscall/.cvsignore (deleted) * c/src/librdbg/include/.cvsignore (deleted) * c/src/librdbg/src/.cvsignore (deleted) * c/src/librdbg/src/i386/.cvsignore (deleted) * c/src/librdbg/src/i386/any/.cvsignore (deleted) * c/src/librdbg/src/m68k/.cvsignore (deleted) * c/src/librdbg/src/m68k/any/.cvsignore (deleted) * c/src/librdbg/src/powerpc/.cvsignore (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/.cvsignore (deleted) * c/src/librtems++/include/.cvsignore (deleted) * c/src/librtems++/include/rtems++/.cvsignore (deleted) * c/src/librtems++/src/.cvsignore (deleted) * c/src/optman/rtems/.cvsignore (deleted) * c/src/optman/sapi/.cvsignore (deleted) * cpukit/include/.cvsignore (deleted) * cpukit/itron/include/.cvsignore (deleted) * cpukit/itron/include/itronsys/.cvsignore (deleted) * cpukit/itron/include/rtems/.cvsignore (deleted) * cpukit/itron/include/rtems/itron/.cvsignore (deleted) * cpukit/itron/inline/.cvsignore (deleted) * cpukit/itron/inline/rtems/.cvsignore (deleted) * cpukit/itron/inline/rtems/itron/.cvsignore (deleted) * cpukit/itron/macros/.cvsignore (deleted) * cpukit/itron/macros/rtems/.cvsignore (deleted) * cpukit/itron/macros/rtems/itron/.cvsignore (deleted) * cpukit/libblock/include/.cvsignore (deleted) * cpukit/libblock/include/rtems/.cvsignore (deleted) * cpukit/libblock/src/.cvsignore (deleted) * cpukit/libcsupport/include/.cvsignore (deleted) * cpukit/libcsupport/include/motorola/.cvsignore (deleted) * cpukit/libcsupport/include/rtems/.cvsignore (deleted) * cpukit/libcsupport/include/sys/.cvsignore (deleted) * cpukit/libcsupport/include/zilog/.cvsignore (deleted) * cpukit/libfs/src/.cvsignore (deleted) * cpukit/libmisc/capture/.cvsignore (deleted) * cpukit/libmisc/cpuuse/.cvsignore (deleted) * cpukit/libmisc/devnull/.cvsignore (deleted) * cpukit/libmisc/dummy/.cvsignore (deleted) * cpukit/libmisc/dumpbuf/.cvsignore (deleted) * cpukit/libmisc/fsmount/.cvsignore (deleted) * cpukit/libmisc/monitor/.cvsignore (deleted) * cpukit/libmisc/mw-fb/.cvsignore (deleted) * cpukit/libmisc/rtmonuse/.cvsignore (deleted) * cpukit/libmisc/serdbg/.cvsignore (deleted) * cpukit/libmisc/shell/.cvsignore (deleted) * cpukit/libmisc/stackchk/.cvsignore (deleted) * cpukit/libmisc/untar/.cvsignore (deleted) * cpukit/libnetworking/arpa/.cvsignore (deleted) * cpukit/libnetworking/kern/.cvsignore (deleted) * cpukit/libnetworking/lib/.cvsignore (deleted) * cpukit/libnetworking/libc/.cvsignore (deleted) * cpukit/libnetworking/machine/.cvsignore (deleted) * cpukit/libnetworking/net/.cvsignore (deleted) * cpukit/libnetworking/netinet/.cvsignore (deleted) * cpukit/libnetworking/nfs/.cvsignore (deleted) * cpukit/libnetworking/rtems/.cvsignore (deleted) * cpukit/libnetworking/sys/.cvsignore (deleted) * cpukit/libnetworking/vm/.cvsignore (deleted) * cpukit/librpc/include/.cvsignore (deleted) * cpukit/librpc/include/rpc/.cvsignore (deleted) * cpukit/librpc/include/rpcsvc/.cvsignore (deleted) * cpukit/librpc/src/.cvsignore (deleted) * cpukit/librpc/src/rpc/.cvsignore (deleted) * cpukit/librpc/src/rpc/PSD.doc/.cvsignore (deleted) * cpukit/librpc/src/xdr/.cvsignore (deleted) * cpukit/posix/include/.cvsignore (deleted) * cpukit/posix/include/rtems/.cvsignore (deleted) * cpukit/posix/include/rtems/posix/.cvsignore (deleted) * cpukit/posix/inline/.cvsignore (deleted) * cpukit/posix/inline/rtems/.cvsignore (deleted) * cpukit/posix/inline/rtems/posix/.cvsignore (deleted) * cpukit/posix/macros/.cvsignore (deleted) * cpukit/posix/macros/rtems/.cvsignore (deleted) * cpukit/posix/macros/rtems/posix/.cvsignore (deleted) * cpukit/rtems/include/.cvsignore (deleted) * cpukit/rtems/include/rtems/.cvsignore (deleted) * cpukit/rtems/include/rtems/rtems/.cvsignore (deleted) * cpukit/rtems/inline/.cvsignore (deleted) * cpukit/rtems/inline/rtems/.cvsignore (deleted) * cpukit/rtems/inline/rtems/rtems/.cvsignore (deleted) * cpukit/rtems/macros/.cvsignore (deleted) * cpukit/rtems/macros/rtems/.cvsignore (deleted) * cpukit/rtems/macros/rtems/rtems/.cvsignore (deleted) * cpukit/rtems/src/.cvsignore (deleted) * cpukit/score/cpu/arm/rtems/.cvsignore (deleted) * cpukit/score/cpu/arm/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/c4x/rtems/.cvsignore (deleted) * cpukit/score/cpu/c4x/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/h8300/rtems/.cvsignore (deleted) * cpukit/score/cpu/h8300/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/i386/rtems/.cvsignore (deleted) * cpukit/score/cpu/i386/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/i960/rtems/.cvsignore (deleted) * cpukit/score/cpu/i960/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/m68k/rtems/.cvsignore (deleted) * cpukit/score/cpu/m68k/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/mips/rtems/.cvsignore (deleted) * cpukit/score/cpu/mips/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/no_cpu/rtems/.cvsignore (deleted) * cpukit/score/cpu/no_cpu/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/or32/rtems/.cvsignore (deleted) * cpukit/score/cpu/or32/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/powerpc/rtems/.cvsignore (deleted) * cpukit/score/cpu/powerpc/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/sh/rtems/.cvsignore (deleted) * cpukit/score/cpu/sh/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/sparc/rtems/.cvsignore (deleted) * cpukit/score/cpu/sparc/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/unix/rtems/.cvsignore (deleted) * cpukit/score/include/.cvsignore (deleted) * cpukit/score/include/rtems/.cvsignore (deleted) * cpukit/score/inline/.cvsignore (deleted) * cpukit/score/inline/rtems/.cvsignore (deleted) * cpukit/score/inline/rtems/score/.cvsignore (deleted) * cpukit/score/macros/.cvsignore (deleted) * cpukit/score/macros/rtems/.cvsignore (deleted) * cpukit/score/macros/rtems/score/.cvsignore (deleted) * cpukit/score/src/.cvsignore (deleted) Unused. Fri, 05 Mar 2004 18:02:41 GMT Joel Sherrill [cb2f320] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getnetbyht.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/map_v4v6.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/nsap_addr.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/net/radix.c (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/score/macros/rtems/score/chain.inl (modified) * cpukit/score/src/objectidtoname.c (modified) 2004-03-05 Joel Sherrill * ...
