# # ChangeLog for cpukit/librpc/src in rtems # # Generated by Trac 1.2.1.dev0 # 05/28/24 05:46:34 Wed, 25 May 2005 13:02:40 GMT Ralf Corsepius [fd6a994] * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/clnt_soc.h (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) More updates from FreeBSD. Wed, 25 May 2005 08:54:37 GMT Ralf Corsepius [ce1c8ea] * cpukit/librpc/src/rpc/auth_des.c (deleted) * cpukit/librpc/src/rpc/auth_time.c (deleted) * cpukit/librpc/src/rpc/authdes_prot.c (deleted) * cpukit/librpc/src/rpc/clnt_unix.c (deleted) * cpukit/librpc/src/rpc/crypt_client.c (deleted) * cpukit/librpc/src/rpc/des_crypt.c (deleted) * cpukit/librpc/src/rpc/des_soft.c (deleted) * cpukit/librpc/src/rpc/getpublickey.c (deleted) * cpukit/librpc/src/rpc/key_call.c (deleted) * cpukit/librpc/src/rpc/key_prot_xdr.c (deleted) * cpukit/librpc/src/rpc/svc_auth_des.c (deleted) * cpukit/librpc/src/rpc/svc_unix.c (deleted) Remove (Unused, obsolete). Wed, 25 May 2005 08:23:11 GMT Ralf Corsepius [41b326f7] * cpukit/librpc/src/rpc/PSD.doc/nfs.rfc.ms (deleted) * cpukit/librpc/src/rpc/PSD.doc/rpc.prog.ms (deleted) * cpukit/librpc/src/rpc/PSD.doc/rpc.rfc.ms (deleted) * cpukit/librpc/src/rpc/PSD.doc/rpcgen.ms (deleted) * cpukit/librpc/src/rpc/PSD.doc/xdr.nts.ms (deleted) * cpukit/librpc/src/rpc/PSD.doc/xdr.rfc.ms (deleted) Remove (unused, obsolete). Tue, 10 May 2005 08:56:46 GMT Ralf Corsepius [ea78ecad] * c/src/libnetworking/rtems_telnetd/telnetd.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/telnetd/telnetd.c (modified) socklen_t. Mon, 09 May 2005 13:12:13 GMT Ralf Corsepius [a7b4c36] * cpukit/librpc/src/rpc/bindresvport.c (modified) socklen_t. Mon, 02 May 2005 16:32:12 GMT Jennifer Averett [3eb71183] * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/librpc/src/xdr/xdr.c (modified) 2005-05-02 Jennifer Averett ... Thu, 03 Feb 2005 15:58:18 GMT Ralf Corsepius [0c20a46] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/types.h (modified) * cpukit/librpc/src/rpc/bindresvport.c (modified) 2005-02-03 Ralf Corsepius * ... Fri, 28 Jan 2005 02:15:33 GMT Ralf Corsepius [0c3a6d6] * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) Fix indentation. Sun, 09 Jan 2005 17:12:03 GMT Joel Sherrill [77b6a10] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/pmap_prot2.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) 2005-01-09 Joel Sherrill * ... Sat, 08 Jan 2005 06:01:35 GMT Ralf Corsepius [dab2d6eb] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/auth_des.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/src/rpc/auth_des.c (modified) * cpukit/librpc/src/rpc/auth_unix.c (modified) * cpukit/librpc/src/rpc/rpc_prot.c (modified) * cpukit/librpc/src/xdr/xdr.c (modified) 2005-01-07 Ralf Corsepius * ... Fri, 07 Jan 2005 11:22:50 GMT Ralf Corsepius [c9165ef0] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/auth.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/src/rpc/auth_none.c (modified) 2005-01-07 Ralf Corsepius * ... Sun, 21 Nov 2004 05:33:00 GMT Ralf Corsepius [5220ae2] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/types.h (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) 2004-11-21 Ralf Corsepius * ... Sun, 21 Nov 2004 04:45:39 GMT Ralf Corsepius [ddb56f4] * cpukit/ChangeLog (modified) * cpukit/librpc/include/rpc/rpc.h (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) 2004-11-21 Ralf Corsepius * ... Wed, 29 Sep 2004 20:34:01 GMT Joel Sherrill [ac200c1] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/libmisc/cpuuse/README (modified) * cpukit/libmisc/stackchk/README (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) 2004-09-29 Joel Sherrill * ... Thu, 23 Sep 2004 08:19:27 GMT Ralf Corsepius [e5c8049] * cpukit/ChangeLog (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) 2004-09-23 Ralf Corsepius * ... Thu, 15 Apr 2004 13:26:21 GMT Ralf Corsepius [3239698] * c/src/lib/libbsp/arm/arm_bare_bsp/include/bsp.h (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/include/registers.h (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/start/start.S (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/startup/exit.c (modified) * c/src/lib/libbsp/arm/armulator/console/console-io.c (modified) * c/src/lib/libbsp/arm/armulator/start/start.S (modified) * c/src/lib/libbsp/arm/armulator/startup/syscalls.c (modified) * c/src/lib/libbsp/arm/edb7312/console/uart.c (modified) * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) * c/src/lib/libbsp/arm/edb7312/irq/bsp_irq_init.c (modified) * c/src/lib/libbsp/arm/edb7312/start/start.S (modified) * c/src/lib/libbsp/arm/edb7312/timer/timer.c (modified) * c/src/lib/libbsp/arm/shared/comm/console.c (modified) * c/src/lib/libbsp/arm/shared/comm/uart.h (modified) * c/src/lib/libbsp/arm/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/arm/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/arm/vegaplus/include/bsp.h (modified) * c/src/lib/libbsp/arm/vegaplus/start/start.S (modified) * c/src/lib/libbsp/arm/vegaplus/startup/exit.c (modified) * c/src/lib/libbsp/c4x/c4xsim/console/debugio.c (modified) * c/src/lib/libbsp/c4x/c4xsim/timer/timer.c (modified) * c/src/lib/libbsp/h8300/h8sim/console/console-io.c (modified) * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) * c/src/lib/libbsp/i386/i386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/pc386/3c509/3c509.h (modified) * c/src/lib/libbsp/i386/pc386/clock/rtc.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/defkeymap.c (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vga.h (modified) * c/src/lib/libbsp/i386/pc386/console/i386kbd.h (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/console/keyboard.c (modified) * c/src/lib/libbsp/i386/pc386/console/mouse_parser.h (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/i386/pc386/console/ps2_drv.h (modified) * c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c (modified) * c/src/lib/libbsp/i386/pc386/console/ps2_mouse.h (modified) * c/src/lib/libbsp/i386/pc386/console/serial_mouse.h (modified) * c/src/lib/libbsp/i386/pc386/console/videoAsm.S (modified) * c/src/lib/libbsp/i386/pc386/console/vt.c (modified) * c/src/lib/libbsp/i386/pc386/ide/ide.c (modified) * c/src/lib/libbsp/i386/pc386/ide/idecfg.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (modified) * c/src/lib/libbsp/i386/pc386/start/start.S (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timerisr.S (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/i386/shared/comm/gdb_glue.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386_io.h (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.h (modified) * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) * c/src/lib/libbsp/i386/shared/comm/uart.h (modified) * c/src/lib/libbsp/i386/shared/pci/pcibios.h (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/rtc.c (modified) * c/src/lib/libbsp/i386/ts_386ex/include/wd80x3.h (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/debug_test.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/serial_gdb.h (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/init.c (modified) * c/src/lib/libbsp/i960/cvme961/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/cvme961/console/console.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/lock.c (modified) * c/src/lib/libbsp/i960/i960sim/console/console-io.c (modified) * c/src/lib/libbsp/i960/rxgen960/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/rxgen960/console/serial.c (modified) * c/src/lib/libbsp/i960/rxgen960/start/rxgen_romld.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/fault.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/fault.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/faultret.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/main.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/memchnl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/nulsystbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_prcb.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rommon.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.h (modified) * c/src/lib/libbsp/m68k/dmv152/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.S (modified) * c/src/lib/libbsp/m68k/gen68340/console/m340uart.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/m68340.h (modified) * c/src/lib/libbsp/m68k/gen68340/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.S (modified) * c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/start/start.S (modified) * c/src/lib/libbsp/m68k/mrm332/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/console.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.h (modified) * c/src/lib/libbsp/m68k/mrm332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mrm332/startup/start_c.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/page_table.c (modified) * c/src/lib/libbsp/m68k/mvme167/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/ods68302/start/debugreset.S (modified) * c/src/lib/libbsp/m68k/ods68302/start/reset.S (modified) * c/src/lib/libbsp/m68k/ods68302/startup/debugport.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/m68302scc.c (modified) * c/src/lib/libbsp/m68k/shared/gdbstub/m68k-stub.c (modified) * c/src/lib/libbsp/m68k/shared/setvec.c (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) * c/src/lib/libbsp/m68k/sim68000/start/start.S (modified) * c/src/lib/libbsp/mips/genmongoosev/start/mg5.h (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c (modified) * c/src/lib/libbsp/mips/jmr3904/console/console-io.c (modified) * c/src/lib/libbsp/mips/jmr3904/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/console/console.c (modified) * c/src/lib/libbsp/mips/p4000/console/led.S (modified) * c/src/lib/libbsp/mips/p4000/liblnk/lnklib.S (modified) * c/src/lib/libbsp/mips/p4000/startup/idtmem.S (modified) * c/src/lib/libbsp/mips/p4000/startup/idttlb.S (modified) * c/src/lib/libbsp/mips/p4000/startup/inittlb.c (modified) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/mips/shared/gdbstub/mips-stub.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/lock.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (modified) * c/src/lib/libbsp/or32/orp/start/start.S (modified) * c/src/lib/libbsp/or32/orp/startup/setvec.c (modified) * c/src/lib/libbsp/or32/orp/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/debugio.c (modified) * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/todcfg.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/canbus.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/console.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/eth_comm/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen405/dlentry/dlentry.S (modified) * c/src/lib/libbsp/powerpc/gen405/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/flashentry.S (modified) * c/src/lib/libbsp/powerpc/helas403/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/console/console.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ide/idecfg.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/console/console.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/if_hdlcsubr.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/start/start.S (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/config.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/debugio.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/ds1385.h (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/nvram.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/stk11c68.h (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/spurious.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/swap.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/universe.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/vectors.S (modified) * c/src/lib/libbsp/powerpc/psim/console/console-io.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/lock.c (modified) * c/src/lib/libbsp/powerpc/psim/start/start.S (modified) * c/src/lib/libbsp/powerpc/psim/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/psim/vectors/vectors.S (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.h (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c (modified) * c/src/lib/libbsp/powerpc/score603e/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.h (modified) * c/src/lib/libbsp/powerpc/score603e/console/console.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolereserveresources.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/tbl85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/gen2.h (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/spurious.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/vmeintr.c (modified) * c/src/lib/libbsp/powerpc/score603e/tod/tod.c (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/vectors.S (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/bootldr.h (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/em86.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/em86real.S (modified) * c/src/lib/libbsp/powerpc/shared/console/inch.c (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/i8259.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.c (modified) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.h (modified) * c/src/lib/libbsp/powerpc/shared/residual/residual.c (modified) * c/src/lib/libbsp/powerpc/shared/residual/residual.h (modified) * c/src/lib/libbsp/powerpc/shared/start/rtems_crti.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/sbrk.c (modified) * c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu.c (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu_asm.S (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ppccache.c (modified) * c/src/lib/libbsp/sh/gensh2/start/start.S (modified) * c/src/lib/libbsp/sh/gensh4/console/console.c (modified) * c/src/lib/libbsp/sh/gensh4/start/start.S (modified) * c/src/lib/libbsp/sh/shsim/trap34/console-io.c (modified) * c/src/lib/libbsp/sh/shsim/trap34/console-support.S (modified) * c/src/lib/libbsp/shared/bsppost.c (modified) * c/src/lib/libbsp/shared/console-polled.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shared/main.c (modified) * c/src/lib/libbsp/shared/sbrk.c (modified) * c/src/lib/libbsp/shared/setvec.c (modified) * c/src/lib/libbsp/shared/tod.c (modified) * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) * c/src/lib/libbsp/sparc/erc32/include/erc32.h (modified) * c/src/lib/libbsp/sparc/erc32/startup/erc32mec.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/leon/console/console.c (modified) * c/src/lib/libbsp/sparc/leon/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon/startup/setvec.c (modified) * c/src/lib/libbsp/unix/posix/startup/setvec.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ppccache.c (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * cpukit/libcsupport/include/motorola/mc68681.h (modified) * cpukit/libcsupport/include/sys/utsname.h (modified) * cpukit/libcsupport/include/zilog/z8036.h (modified) * cpukit/libcsupport/src/__getpid.c (modified) * cpukit/libcsupport/src/access.c (modified) * cpukit/libcsupport/src/assocnamebad.c (modified) * cpukit/libcsupport/src/eval.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/getegid.c (modified) * cpukit/libcsupport/src/getgroups.c (modified) * cpukit/libcsupport/src/getpid.c (modified) * cpukit/libcsupport/src/getppid.c (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/mkdir.c (modified) * cpukit/libcsupport/src/no_posix.c (modified) * cpukit/libcsupport/src/printk.c (modified) * cpukit/libcsupport/src/setsid.c (modified) * cpukit/libcsupport/src/symlink.c (modified) * cpukit/libcsupport/src/termiosreserveresources.c (modified) * cpukit/libcsupport/src/truncate.c (modified) * cpukit/libcsupport/src/ttyname.c (modified) * cpukit/libcsupport/src/ttyname_r.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/imfs/imfs_config.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_free.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unlink.c (modified) * cpukit/libfs/src/imfs/linearfile.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/monitor/mon-manager.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/mw-fb/mw_fb.c (modified) * cpukit/libmisc/serdbg/serdbg.c (modified) * cpukit/libmisc/serdbg/serdbgio.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/untar/untar.c (modified) * cpukit/libnetworking/bpfilter.h (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/machine/conf.h (modified) * cpukit/libnetworking/machine/cpu.h (modified) * cpukit/libnetworking/machine/limits.h (modified) * cpukit/libnetworking/machine/vmparam.h (modified) * cpukit/libnetworking/net/ppp.h (modified) * cpukit/libnetworking/netinet/igmp_var.h (modified) * cpukit/libnetworking/netinet/in_proto.c (modified) * cpukit/libnetworking/netinet/in_rmx.c (modified) * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) * cpukit/libnetworking/opt_ipfw.h (modified) * cpukit/libnetworking/opt_mrouting.h (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/librpc/include/rpcsvc/ypclnt.h (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/getrpcent.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/rpc_callmsg.c (modified) * cpukit/librpc/src/rpc/svc_auth_des.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/librpc/src/xdr/xdr_array.c (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/intr.h (modified) * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/ptimer.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/include/rtems/posix/timer.h (modified) * cpukit/posix/include/sched.h (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/condmp.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuegetattr.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/mqueuereceive.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesend.c (modified) * cpukit/posix/src/mqueuesetattr.c (modified) * cpukit/posix/src/mqueuetimedreceive.c (modified) * cpukit/posix/src/mqueuetimedsend.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/mutexattrdestroy.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/pause.c (modified) * cpukit/posix/src/psignalchecksignal.c (modified) * cpukit/posix/src/pthreadattrgetdetachstate.c (modified) * cpukit/posix/src/pthreadattrgetinheritsched.c (modified) * cpukit/posix/src/pthreadattrgetschedpolicy.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetcpuclockid.c (modified) * cpukit/posix/src/pthreadgetcputime.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadonce.c (modified) * cpukit/posix/src/pthreadsetcputime.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/semaphorenametoid.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigdelset.c (modified) * cpukit/posix/src/sigemptyset.c (modified) * cpukit/posix/src/sigfillset.c (modified) * cpukit/posix/src/sigismember.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/sigwait.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) * cpukit/posix/src/types.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/rtems/src/attr.c (modified) * cpukit/rtems/src/clocktodtoseconds.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/score/cpu/arm/asm.h (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) * cpukit/score/cpu/c4x/asm.h (modified) * cpukit/score/cpu/c4x/cpu_asm.S (modified) * cpukit/score/cpu/c4x/rtems/asm.h (modified) * cpukit/score/cpu/h8300/asm.h (modified) * cpukit/score/cpu/h8300/cpu_asm.S (modified) * cpukit/score/cpu/h8300/rtems/asm.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/registers.h (modified) * cpukit/score/cpu/i960/cpu_asm.S (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/mips/asm.h (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/iregdef.h (modified) * cpukit/score/cpu/mips/rtems/asm.h (modified) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (modified) * cpukit/score/cpu/no_cpu/asm.h (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/asm.h (modified) * cpukit/score/cpu/or32/asm.h (modified) * cpukit/score/cpu/or32/cpu_asm.c (modified) * cpukit/score/cpu/or32/rtems/asm.h (modified) * cpukit/score/cpu/powerpc/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/score/types.h (modified) * cpukit/score/cpu/sparc/asm.h (modified) * cpukit/score/cpu/sparc/rtems/asm.h (modified) * cpukit/score/cpu/unix/rtems/score/unix.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushsupp.c (modified) * cpukit/score/src/coremsgflushwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/coresemsurrender.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtoseconds.c (modified) * cpukit/score/src/coretodvalidate.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadqdequeue.c (modified) * cpukit/score/src/threadqdequeuefifo.c (modified) * cpukit/score/src/threadqdequeuepriority.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqenqueuefifo.c (modified) * cpukit/score/src/threadqenqueuepriority.c (modified) * cpukit/score/src/threadqextract.c (modified) * cpukit/score/src/threadqextractfifo.c (modified) * cpukit/score/src/threadqextractpriority.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadqfirstfifo.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadqtimeout.c (modified) * cpukit/score/src/threadreset.c (modified) * cpukit/score/src/threadrotatequeue.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/watchdogadjust.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * testsuites/itrontests/itronmbf01/init.c (modified) * testsuites/itrontests/itronmbox01/init.c (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask01/task1.c (modified) * testsuites/itrontests/itrontask02/dormant.c (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/init.c (modified) * testsuites/itrontests/itrontask03/preempt.c (modified) * testsuites/itrontests/itrontask04/init.c (modified) * testsuites/itrontests/itrontask04/task1.c (modified) * testsuites/itrontests/itrontask04/task3.c (modified) * testsuites/itrontests/itrontime01/init.c (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/psxtests/psx13/test.c (modified) * testsuites/psxtests/psxcancel/init.c (modified) * testsuites/psxtests/psxchroot01/test.c (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxmount/test.c (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxreaddir/test.c (modified) * testsuites/psxtests/psxsem01/init.c (modified) * testsuites/psxtests/psxsem01/system.h (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxtime/test.c (modified) * testsuites/psxtests/psxtimer/psxtimer.c (modified) * testsuites/samples/fileio/system.h (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/test1.c (modified) * testsuites/samples/unlimited/test2.c (modified) * testsuites/sptests/spfatal/fatal.c (modified) * testsuites/tmtests/tm26/task1.c (modified) Remove stray white spaces. Mon, 08 Mar 2004 16:26:41 GMT Ralf Corsepius [2609e83] * c/src/lib/libbsp/mips/genmongoosev/start/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/console/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/scitab/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/start/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/startup/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/wrapup/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh2/start/.cvsignore (deleted) * c/src/lib/libbsp/sh/shsim/start/.cvsignore (deleted) * c/src/lib/libbsp/sh/simsh4/start/.cvsignore (deleted) * c/src/lib/libbsp/shared/.cvsignore (deleted) * c/src/lib/libcpu/i960/include/.cvsignore (deleted) * c/src/lib/libcpu/m68k/m68040/fpsp/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/clock/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/console/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/include/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/mbus/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/timer/.cvsignore (deleted) * c/src/lib/libcpu/m68k/shared/cache/.cvsignore (deleted) * c/src/lib/libcpu/m68k/shared/misc/.cvsignore (deleted) * c/src/lib/libcpu/mips/clock/.cvsignore (deleted) * c/src/lib/libcpu/mips/shared/cache/.cvsignore (deleted) * c/src/lib/libcpu/mips/shared/interrupts/.cvsignore (deleted) * c/src/lib/libcpu/mips/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc505/ictrl/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc505/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc505/vectors/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/clock/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/clock/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/cpm/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/exceptions/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/include/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/mmu/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/clock/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/exceptions/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/include/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/mmu/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/clock/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/console/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/ictrl/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/tty_drv/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/vectors/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/shared/include/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/clock/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/delay/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/include/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/sci/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/score/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/timer/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/clock/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/include/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/sci/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/score/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/timer/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/clock/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/include/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/sci/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/score/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/timer/.cvsignore (deleted) * c/src/lib/libcpu/sparc/reg_win/.cvsignore (deleted) * c/src/lib/libcpu/sparc/syscall/.cvsignore (deleted) * c/src/librdbg/include/.cvsignore (deleted) * c/src/librdbg/src/.cvsignore (deleted) * c/src/librdbg/src/i386/.cvsignore (deleted) * c/src/librdbg/src/i386/any/.cvsignore (deleted) * c/src/librdbg/src/m68k/.cvsignore (deleted) * c/src/librdbg/src/m68k/any/.cvsignore (deleted) * c/src/librdbg/src/powerpc/.cvsignore (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/.cvsignore (deleted) * c/src/librtems++/include/.cvsignore (deleted) * c/src/librtems++/include/rtems++/.cvsignore (deleted) * c/src/librtems++/src/.cvsignore (deleted) * c/src/optman/rtems/.cvsignore (deleted) * c/src/optman/sapi/.cvsignore (deleted) * cpukit/include/.cvsignore (deleted) * cpukit/itron/include/.cvsignore (deleted) * cpukit/itron/include/itronsys/.cvsignore (deleted) * cpukit/itron/include/rtems/.cvsignore (deleted) * cpukit/itron/include/rtems/itron/.cvsignore (deleted) * cpukit/itron/inline/.cvsignore (deleted) * cpukit/itron/inline/rtems/.cvsignore (deleted) * cpukit/itron/inline/rtems/itron/.cvsignore (deleted) * cpukit/itron/macros/.cvsignore (deleted) * cpukit/itron/macros/rtems/.cvsignore (deleted) * cpukit/itron/macros/rtems/itron/.cvsignore (deleted) * cpukit/libblock/include/.cvsignore (deleted) * cpukit/libblock/include/rtems/.cvsignore (deleted) * cpukit/libblock/src/.cvsignore (deleted) * cpukit/libcsupport/include/.cvsignore (deleted) * cpukit/libcsupport/include/motorola/.cvsignore (deleted) * cpukit/libcsupport/include/rtems/.cvsignore (deleted) * cpukit/libcsupport/include/sys/.cvsignore (deleted) * cpukit/libcsupport/include/zilog/.cvsignore (deleted) * cpukit/libfs/src/.cvsignore (deleted) * cpukit/libmisc/capture/.cvsignore (deleted) * cpukit/libmisc/cpuuse/.cvsignore (deleted) * cpukit/libmisc/devnull/.cvsignore (deleted) * cpukit/libmisc/dummy/.cvsignore (deleted) * cpukit/libmisc/dumpbuf/.cvsignore (deleted) * cpukit/libmisc/fsmount/.cvsignore (deleted) * cpukit/libmisc/monitor/.cvsignore (deleted) * cpukit/libmisc/mw-fb/.cvsignore (deleted) * cpukit/libmisc/rtmonuse/.cvsignore (deleted) * cpukit/libmisc/serdbg/.cvsignore (deleted) * cpukit/libmisc/shell/.cvsignore (deleted) * cpukit/libmisc/stackchk/.cvsignore (deleted) * cpukit/libmisc/untar/.cvsignore (deleted) * cpukit/libnetworking/arpa/.cvsignore (deleted) * cpukit/libnetworking/kern/.cvsignore (deleted) * cpukit/libnetworking/lib/.cvsignore (deleted) * cpukit/libnetworking/libc/.cvsignore (deleted) * cpukit/libnetworking/machine/.cvsignore (deleted) * cpukit/libnetworking/net/.cvsignore (deleted) * cpukit/libnetworking/netinet/.cvsignore (deleted) * cpukit/libnetworking/nfs/.cvsignore (deleted) * cpukit/libnetworking/rtems/.cvsignore (deleted) * cpukit/libnetworking/sys/.cvsignore (deleted) * cpukit/libnetworking/vm/.cvsignore (deleted) * cpukit/librpc/include/.cvsignore (deleted) * cpukit/librpc/include/rpc/.cvsignore (deleted) * cpukit/librpc/include/rpcsvc/.cvsignore (deleted) * cpukit/librpc/src/.cvsignore (deleted) * cpukit/librpc/src/rpc/.cvsignore (deleted) * cpukit/librpc/src/rpc/PSD.doc/.cvsignore (deleted) * cpukit/librpc/src/xdr/.cvsignore (deleted) * cpukit/posix/include/.cvsignore (deleted) * cpukit/posix/include/rtems/.cvsignore (deleted) * cpukit/posix/include/rtems/posix/.cvsignore (deleted) * cpukit/posix/inline/.cvsignore (deleted) * cpukit/posix/inline/rtems/.cvsignore (deleted) * cpukit/posix/inline/rtems/posix/.cvsignore (deleted) * cpukit/posix/macros/.cvsignore (deleted) * cpukit/posix/macros/rtems/.cvsignore (deleted) * cpukit/posix/macros/rtems/posix/.cvsignore (deleted) * cpukit/rtems/include/.cvsignore (deleted) * cpukit/rtems/include/rtems/.cvsignore (deleted) * cpukit/rtems/include/rtems/rtems/.cvsignore (deleted) * cpukit/rtems/inline/.cvsignore (deleted) * cpukit/rtems/inline/rtems/.cvsignore (deleted) * cpukit/rtems/inline/rtems/rtems/.cvsignore (deleted) * cpukit/rtems/macros/.cvsignore (deleted) * cpukit/rtems/macros/rtems/.cvsignore (deleted) * cpukit/rtems/macros/rtems/rtems/.cvsignore (deleted) * cpukit/rtems/src/.cvsignore (deleted) * cpukit/score/cpu/arm/rtems/.cvsignore (deleted) * cpukit/score/cpu/arm/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/c4x/rtems/.cvsignore (deleted) * cpukit/score/cpu/c4x/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/h8300/rtems/.cvsignore (deleted) * cpukit/score/cpu/h8300/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/i386/rtems/.cvsignore (deleted) * cpukit/score/cpu/i386/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/i960/rtems/.cvsignore (deleted) * cpukit/score/cpu/i960/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/m68k/rtems/.cvsignore (deleted) * cpukit/score/cpu/m68k/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/mips/rtems/.cvsignore (deleted) * cpukit/score/cpu/mips/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/no_cpu/rtems/.cvsignore (deleted) * cpukit/score/cpu/no_cpu/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/or32/rtems/.cvsignore (deleted) * cpukit/score/cpu/or32/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/powerpc/rtems/.cvsignore (deleted) * cpukit/score/cpu/powerpc/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/sh/rtems/.cvsignore (deleted) * cpukit/score/cpu/sh/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/sparc/rtems/.cvsignore (deleted) * cpukit/score/cpu/sparc/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/unix/rtems/.cvsignore (deleted) * cpukit/score/include/.cvsignore (deleted) * cpukit/score/include/rtems/.cvsignore (deleted) * cpukit/score/inline/.cvsignore (deleted) * cpukit/score/inline/rtems/.cvsignore (deleted) * cpukit/score/inline/rtems/score/.cvsignore (deleted) * cpukit/score/macros/.cvsignore (deleted) * cpukit/score/macros/rtems/.cvsignore (deleted) * cpukit/score/macros/rtems/score/.cvsignore (deleted) * cpukit/score/src/.cvsignore (deleted) Unused. Fri, 05 Mar 2004 18:02:41 GMT Joel Sherrill [cb2f320] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getnetbyht.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/map_v4v6.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/nsap_addr.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/net/radix.c (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/score/macros/rtems/score/chain.inl (modified) * cpukit/score/src/objectidtoname.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 17:58:51 GMT Joel Sherrill [b2b143f4] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getnetbyht.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/map_v4v6.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/nsap_addr.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/net/radix.c (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/rtems_rpc.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/macros/rtems/score/chain.inl (modified) * cpukit/score/src/objectidtoname.c (modified) 2004-03-05 Joel Sherrill * ... Thu, 27 Nov 2003 14:29:34 GMT Ralf Corsepius [69a6204c] * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/src/Makefile.am (deleted) * cpukit/librpc/src/rpc/Makefile.am (deleted) * cpukit/librpc/src/xdr/Makefile.am (deleted) 2003-11-27 Ralf Corsepius * ... Thu, 27 Nov 2003 09:35:40 GMT Ralf Corsepius [d16b2d3] * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/include/rpc/rpc.h (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rtems_rpc.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) * cpukit/librpc/src/rpc/svc_raw.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) 2003-11-27 Ralf Corsepius * ... Tue, 21 Oct 2003 04:01:46 GMT Ralf Corsepius [77469f86] * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) 2003-10-21 Ralf Corsepius * ... Tue, 08 Jul 2003 17:02:24 GMT Ralf Corsepius [3ad34cad] * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/configure.ac (deleted) * cpukit/librpc/src/Makefile.am (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) 2003-07-08 Ralf Corsepius * ... Mon, 04 Nov 2002 14:29:42 GMT Joel Sherrill [ce337500] * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) 2002-11-04 Joel Sherrill * ... Thu, 31 Oct 2002 20:17:37 GMT Joel Sherrill [e312d85] * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/src/rpc/svc_run.c (modified) 2002-10-31 Joel Sherrill * ... Mon, 28 Oct 2002 13:50:14 GMT Joel Sherrill [6f07dbc] * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) 2002-10-28 Joel Sherrill * ... Tue, 20 Aug 2002 15:56:25 GMT Joel Sherrill [e5fc1df] * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/src/xdr/xdr_stdio.c (modified) 2002-08-20 Joel Sherrill * ... Sun, 11 Aug 2002 04:16:22 GMT Ralf Corsepius [a78c319] * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) 2002-08-11 Ralf Corsepius * ... Tue, 30 Jul 2002 09:12:33 GMT Ralf Corsepius [6deb2f18] * cpukit/librpc/configure.ac (modified) * cpukit/librpc/include/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (deleted) * cpukit/librpc/include/rpcsvc/Makefile.am (deleted) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/Makefile.am (deleted) 2002-07-29 Ralf Corsepius * ... Tue, 23 Jul 2002 21:06:24 GMT Joel Sherrill [f6e7123d] * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/src/rpc/pmap_clnt.c (modified) 2002-07-23 Joel Sherrill * ... Mon, 22 Jul 2002 13:55:34 GMT Ralf Corsepius [83864ea] * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) 2002-07-22 Ralf Corsepius * ... Mon, 22 Jul 2002 09:53:18 GMT Ralf Corsepius [17e97568] * cpukit/librpc/src/xdr/Makefile.am (modified) 2002-07-22 Ralf Corsepius * ... Mon, 22 Jul 2002 09:36:06 GMT Ralf Corsepius [ae56a27] * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) 2002-07-22 Ralf Corsepius * ... Tue, 25 Jun 2002 17:41:49 GMT Ralf Corsepius [abc1167] * c/src/exec/librpc/ChangeLog (modified) * c/src/exec/librpc/Makefile.am (modified) * c/src/exec/librpc/configure.ac (modified) * c/src/exec/librpc/include/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/librpc/include/rpcsvc/Makefile.am (modified) * c/src/exec/librpc/src/Makefile.am (modified) * c/src/exec/librpc/src/rpc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/exec/librpc/src/xdr/Makefile.am (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/configure.ac (modified) * cpukit/librpc/include/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/librpc/include/rpcsvc/Makefile.am (modified) * cpukit/librpc/src/Makefile.am (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/Makefile.am (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) 2002-06-25 Ralf Corsepius * ... Thu, 28 Mar 2002 00:49:50 GMT Joel Sherrill [00a9ac1d] * c/src/exec/librpc/ChangeLog (modified) * c/src/exec/librpc/Makefile.am (modified) * c/src/exec/librpc/configure.ac (modified) * c/src/exec/librpc/include/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/librpc/include/rpcsvc/Makefile.am (modified) * c/src/exec/librpc/src/Makefile.am (modified) * c/src/exec/librpc/src/rpc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/exec/librpc/src/xdr/Makefile.am (modified) * c/src/librpc/ChangeLog (modified) * c/src/librpc/Makefile.am (modified) * c/src/librpc/configure.ac (modified) * c/src/librpc/include/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/include/rpcsvc/Makefile.am (modified) * c/src/librpc/src/Makefile.am (modified) * c/src/librpc/src/rpc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/librpc/src/xdr/Makefile.am (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/configure.ac (modified) * cpukit/librpc/include/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/librpc/include/rpcsvc/Makefile.am (modified) * cpukit/librpc/src/Makefile.am (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/Makefile.am (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) 2002-03-27 Ralf Corsepius * ... Tue, 31 Oct 2000 16:39:06 GMT Joel Sherrill [57cfaad] * c/src/exec/librpc/ChangeLog (modified) * c/src/exec/librpc/src/rpc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/auth_time.c (modified) * c/src/exec/librpc/src/rpc/clnt_simple.c (modified) * c/src/exec/librpc/src/rpc/clnt_tcp.c (modified) * c/src/exec/librpc/src/rpc/clnt_udp.c (modified) * c/src/exec/librpc/src/rpc/clnt_unix.c (modified) * c/src/exec/librpc/src/rpc/get_myaddress.c (modified) * c/src/exec/librpc/src/rpc/pmap_clnt.c (modified) * c/src/exec/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/exec/librpc/src/rpc/pmap_getport.c (modified) * c/src/exec/librpc/src/rpc/pmap_rmt.c (modified) * c/src/exec/librpc/src/rpc/rtime.c (modified) * c/src/exec/librpc/src/rpc/svc_tcp.c (modified) * c/src/exec/librpc/src/rpc/svc_udp.c (modified) * c/src/exec/librpc/src/rpc/svc_unix.c (modified) * c/src/librpc/ChangeLog (modified) * c/src/librpc/src/rpc/Makefile.am (modified) * c/src/librpc/src/rpc/auth_time.c (modified) * c/src/librpc/src/rpc/clnt_simple.c (modified) * c/src/librpc/src/rpc/clnt_tcp.c (modified) * c/src/librpc/src/rpc/clnt_udp.c (modified) * c/src/librpc/src/rpc/clnt_unix.c (modified) * c/src/librpc/src/rpc/get_myaddress.c (modified) * c/src/librpc/src/rpc/pmap_clnt.c (modified) * c/src/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/librpc/src/rpc/pmap_getport.c (modified) * c/src/librpc/src/rpc/pmap_rmt.c (modified) * c/src/librpc/src/rpc/rtime.c (modified) * c/src/librpc/src/rpc/svc_tcp.c (modified) * c/src/librpc/src/rpc/svc_udp.c (modified) * c/src/librpc/src/rpc/svc_unix.c (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/rpc/auth_time.c (modified) * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/clnt_unix.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/librpc/src/rpc/pmap_clnt.c (modified) * cpukit/librpc/src/rpc/pmap_getmaps.c (modified) * cpukit/librpc/src/rpc/pmap_getport.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/librpc/src/rpc/svc_unix.c (modified) 2000-10-30 Joel Sherrill * POSIX ... Fri, 22 Sep 2000 20:36:49 GMT Joel Sherrill [a74e94a2] * c/src/exec/librpc/ChangeLog (modified) * c/src/exec/librpc/src/xdr/xdr_float.c (modified) * c/src/librpc/ChangeLog (modified) * c/src/librpc/src/xdr/xdr_float.c (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) 2000-09-22 Joel Sherrill * ... Tue, 05 Sep 2000 16:08:02 GMT Joel Sherrill [7f2c3e3] * c/src/exec/librpc/ChangeLog (modified) * c/src/exec/librpc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/Makefile.am (modified) * c/src/exec/librpc/src/xdr/Makefile.am (modified) * c/src/librpc/ChangeLog (modified) * c/src/librpc/Makefile.am (modified) * c/src/librpc/src/rpc/Makefile.am (modified) * c/src/librpc/src/xdr/Makefile.am (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) 2000-09-04 Ralf Corsepius * ... Thu, 27 Jul 2000 06:17:44 GMT Joel Sherrill [2d354ea6] * c/src/exec/librpc/src/xdr/xdr_float.c (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/clock/.cvsignore (moved) * c/src/lib/libbsp/arm/arm_bare_bsp/clock/Makefile.am (added) * c/src/lib/libbsp/arm/arm_bare_bsp/clock/clockdrv.c (added) * c/src/lib/libbsp/arm/arm_bare_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/irq/Makefile.am (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/irq/irq.c (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/start/Makefile.am (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/startup/exit.c (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/arm/shared/Makefile.am (modified) * c/src/lib/libbsp/arm/shared/comm/console.c (modified) * c/src/lib/libbsp/arm/shared/io/Makefile.am (deleted) * c/src/lib/libbsp/arm/shared/io/bspio.h (deleted) * c/src/lib/libbsp/arm/shared/io/printk.c (deleted) * c/src/lib/libbsp/arm/shared/irq/irq_init.c (modified) * c/src/librpc/src/xdr/xdr_float.c (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) Minor problems addressed with the merger and with the arm_bare_bsp. ... Thu, 29 Jun 2000 22:35:17 GMT Joel Sherrill [bbc38ba] * c/src/exec/librpc/src/xdr/xdr_float.c (modified) * c/src/librpc/src/xdr/xdr_float.c (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) Added H8 as IEEE whether this is true or not. Thu, 29 Jun 2000 22:34:55 GMT Joel Sherrill [63db533] * c/src/exec/librpc/src/rpc/svc_auth.c (modified) * c/src/librpc/src/rpc/svc_auth.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) Disabled #ident since the h8300-rtems binutils do not like the ... Mon, 12 Jun 2000 15:00:15 GMT Joel Sherrill [df49c60] * Makefile.am (modified) * VERSION (modified) * aclocal/canonical-host.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/target.m4 (modified) * automake/host.am (added) * automake/local.am (modified) * automake/subdirs.am (modified) * bootstrap (modified) * c/Makefile.am (modified) * c/make/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/itron/src/eventflags.c (modified) * c/src/exec/itron/src/fmempool.c (modified) * c/src/exec/itron/src/itronsem.c (modified) * c/src/exec/itron/src/mbox.c (modified) * c/src/exec/itron/src/msgbuffer.c (modified) * c/src/exec/itron/src/port.c (modified) * c/src/exec/itron/src/vmempool.c (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/include/rtems/error.h (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/libcsupport/src/gxx_wrappers.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/scandir.c (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/exec/libcsupport/src/termiosreserveresources.c (modified) * c/src/exec/libcsupport/src/unmount.c (modified) * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/exec/libfs/src/imfs/imfs_creat.c (modified) * c/src/exec/libfs/src/imfs/imfs_directory.c (modified) * c/src/exec/libfs/src/imfs/imfs_stat.c (modified) * c/src/exec/libfs/src/imfs/imfs_utime.c (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/arpa/Makefile.am (modified) * c/src/exec/libnetworking/kern/Makefile.am (modified) * c/src/exec/libnetworking/lib/Makefile.am (modified) * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/exec/libnetworking/libc/Makefile.am (modified) * c/src/exec/libnetworking/machine/Makefile.am (modified) * c/src/exec/libnetworking/memory.h (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/net/if_loop.c (modified) * c/src/exec/libnetworking/netinet/Makefile.am (modified) * c/src/exec/libnetworking/netinet/in.h (modified) * c/src/exec/libnetworking/nfs/Makefile.am (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/libnetworking/sys/Makefile.am (modified) * c/src/exec/libnetworking/sys/un.h (modified) * c/src/exec/libnetworking/vm/Makefile.am (modified) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * c/src/exec/librpc/Makefile.am (modified) * c/src/exec/librpc/README_RTEMS (modified) * c/src/exec/librpc/include/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/librpc/include/rpc/auth.h (modified) * c/src/exec/librpc/include/rpc/auth_des.h (modified) * c/src/exec/librpc/include/rpc/auth_unix.h (modified) * c/src/exec/librpc/include/rpc/clnt.h (modified) * c/src/exec/librpc/include/rpc/des.h (modified) * c/src/exec/librpc/include/rpc/des_crypt.h (modified) * c/src/exec/librpc/include/rpc/pmap_clnt.h (modified) * c/src/exec/librpc/include/rpc/pmap_prot.h (modified) * c/src/exec/librpc/include/rpc/pmap_rmt.h (modified) * c/src/exec/librpc/include/rpc/rpc.h (modified) * c/src/exec/librpc/include/rpc/rpc_com.h (modified) * c/src/exec/librpc/include/rpc/rpc_msg.h (modified) * c/src/exec/librpc/include/rpc/svc.h (modified) * c/src/exec/librpc/include/rpc/svc_auth.h (modified) * c/src/exec/librpc/include/rpc/types.h (modified) * c/src/exec/librpc/include/rpc/xdr.h (modified) * c/src/exec/librpc/include/rpcsvc/.cvsignore (modified) * c/src/exec/librpc/include/rpcsvc/Makefile.am (modified) * c/src/exec/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/crypt.x (modified) * c/src/exec/librpc/include/rpcsvc/key_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/mount.x (modified) * c/src/exec/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/nis.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_db.h (modified) * c/src/exec/librpc/include/rpcsvc/nis_object.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/exec/librpc/include/rpcsvc/nislib.h (modified) * c/src/exec/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/rex.x (modified) * c/src/exec/librpc/include/rpcsvc/rnusers.x (modified) * c/src/exec/librpc/include/rpcsvc/rquota.x (modified) * c/src/exec/librpc/include/rpcsvc/rstat.x (modified) * c/src/exec/librpc/include/rpcsvc/rwall.x (modified) * c/src/exec/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/exec/librpc/include/rpcsvc/spray.x (modified) * c/src/exec/librpc/include/rpcsvc/yp.x (modified) * c/src/exec/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/exec/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/exec/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/exec/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/exec/librpc/src/Makefile.am (modified) * c/src/exec/librpc/src/rpc/DISCLAIMER (modified) * c/src/exec/librpc/src/rpc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/exec/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/exec/librpc/src/rpc/README (modified) * c/src/exec/librpc/src/rpc/auth_des.c (modified) * c/src/exec/librpc/src/rpc/auth_none.c (modified) * c/src/exec/librpc/src/rpc/auth_time.c (modified) * c/src/exec/librpc/src/rpc/auth_unix.c (modified) * c/src/exec/librpc/src/rpc/authdes_prot.c (modified) * c/src/exec/librpc/src/rpc/authunix_prot.c (modified) * c/src/exec/librpc/src/rpc/bindresvport.3 (modified) * c/src/exec/librpc/src/rpc/bindresvport.c (modified) * c/src/exec/librpc/src/rpc/clnt_generic.c (modified) * c/src/exec/librpc/src/rpc/clnt_perror.c (modified) * c/src/exec/librpc/src/rpc/clnt_raw.c (modified) * c/src/exec/librpc/src/rpc/clnt_simple.c (modified) * c/src/exec/librpc/src/rpc/clnt_tcp.c (modified) * c/src/exec/librpc/src/rpc/clnt_udp.c (modified) * c/src/exec/librpc/src/rpc/clnt_unix.c (modified) * c/src/exec/librpc/src/rpc/crypt_client.c (modified) * c/src/exec/librpc/src/rpc/des_crypt.3 (modified) * c/src/exec/librpc/src/rpc/des_crypt.c (modified) * c/src/exec/librpc/src/rpc/des_soft.c (modified) * c/src/exec/librpc/src/rpc/get_myaddress.c (modified) * c/src/exec/librpc/src/rpc/getpublickey.c (modified) * c/src/exec/librpc/src/rpc/getrpcent.3 (modified) * c/src/exec/librpc/src/rpc/getrpcent.c (modified) * c/src/exec/librpc/src/rpc/getrpcport.3 (modified) * c/src/exec/librpc/src/rpc/getrpcport.c (modified) * c/src/exec/librpc/src/rpc/key_call.c (modified) * c/src/exec/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/exec/librpc/src/rpc/netname.c (modified) * c/src/exec/librpc/src/rpc/netnamer.c (modified) * c/src/exec/librpc/src/rpc/pmap_clnt.c (modified) * c/src/exec/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/exec/librpc/src/rpc/pmap_getport.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot2.c (modified) * c/src/exec/librpc/src/rpc/pmap_rmt.c (modified) * c/src/exec/librpc/src/rpc/publickey.3 (modified) * c/src/exec/librpc/src/rpc/publickey.5 (modified) * c/src/exec/librpc/src/rpc/rpc.3 (modified) * c/src/exec/librpc/src/rpc/rpc.5 (modified) * c/src/exec/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/exec/librpc/src/rpc/rpc_commondata.c (modified) * c/src/exec/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/exec/librpc/src/rpc/rpc_prot.c (modified) * c/src/exec/librpc/src/rpc/rpc_secure.3 (modified) * c/src/exec/librpc/src/rpc/rpcdname.c (modified) * c/src/exec/librpc/src/rpc/rstat.1 (modified) * c/src/exec/librpc/src/rpc/rstat_svc.8 (modified) * c/src/exec/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/exec/librpc/src/rpc/rtems_rpc.c (modified) * c/src/exec/librpc/src/rpc/rtime.3 (modified) * c/src/exec/librpc/src/rpc/rtime.c (modified) * c/src/exec/librpc/src/rpc/svc.c (modified) * c/src/exec/librpc/src/rpc/svc_auth.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_des.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/exec/librpc/src/rpc/svc_raw.c (modified) * c/src/exec/librpc/src/rpc/svc_run.c (modified) * c/src/exec/librpc/src/rpc/svc_simple.c (modified) * c/src/exec/librpc/src/rpc/svc_tcp.c (modified) * c/src/exec/librpc/src/rpc/svc_udp.c (modified) * c/src/exec/librpc/src/rpc/svc_unix.c (modified) * c/src/exec/librpc/src/xdr/Makefile.am (modified) * c/src/exec/librpc/src/xdr/xdr.3 (modified) * c/src/exec/librpc/src/xdr/xdr.c (modified) * c/src/exec/librpc/src/xdr/xdr_array.c (modified) * c/src/exec/librpc/src/xdr/xdr_float.c (modified) * c/src/exec/librpc/src/xdr/xdr_mem.c (modified) * c/src/exec/librpc/src/xdr/xdr_rec.c (modified) * c/src/exec/librpc/src/xdr/xdr_reference.c (modified) * c/src/exec/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/exec/librpc/src/xdr/xdr_stdio.c (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/pthread.h (deleted) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/posix/optman/Makefile.am (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/posix/src/mqueuecreatesupp.c (modified) * c/src/exec/posix/src/mqueuedeletesupp.c (modified) * c/src/exec/posix/src/mqueueunlink.c (modified) * c/src/exec/posix/src/pthread.c (modified) * c/src/exec/posix/src/pthreadcreate.c (modified) * c/src/exec/posix/src/sigtimedwait.c (modified) * c/src/exec/posix/src/waitpid.c (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/rtems/src/semdelete.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * c/src/exec/rtems/src/taskvariabledelete.c (modified) * c/src/exec/rtems/src/taskvariableget.c (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/include/rtems/README (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/a29k.h (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/m68k/qsm.h (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * c/src/exec/score/cpu/m68k/sim.h (modified) * c/src/exec/score/cpu/mips/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/mips.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/unix/rtems/score/unix.h (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/include/rtems/score/Makefile.am (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/exec/score/src/objectcopynamestring.c (modified) * c/src/exec/wrapup/itron/Makefile.am (modified) * c/src/exec/wrapup/posix/Makefile.am (modified) * c/src/exec/wrapup/rtems/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/console.h (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/rtems/error.h (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/a29k/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.am (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/bare/bsp_specs (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/bare/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/HOWTO (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/console.c (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/start.S (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/system.h (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/adasockets/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/README (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/misc/dotests (modified) * c/src/lib/libbsp/m68k/efi332/misc/gdbinit68 (modified) * c/src/lib/libbsp/m68k/efi332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/start.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/except_vect_332_ROM.S (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds_ROM (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/consolereserveresources.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/README (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/console/console-recording.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (modified) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/bsp_specs (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/bsp_specs (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/start.S (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bsp_specs (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/bsp_specs (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/bsp_specs (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/console.c (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/bsp_specs (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolereserveresources.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/irq_stub.S (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/README (modified) * c/src/lib/libbsp/sh/gensh2/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/start.S (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/shared/Makefile.am (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shmdr/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/consolereserveresources.c (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (modified) * c/src/lib/libbsp/unix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libc/error.h (modified) * c/src/lib/libc/gxx_wrappers.c (modified) * c/src/lib/libc/imfs.h (modified) * c/src/lib/libc/imfs_creat.c (modified) * c/src/lib/libc/imfs_directory.c (modified) * c/src/lib/libc/imfs_stat.c (modified) * c/src/lib/libc/imfs_utime.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/scandir.c (modified) * c/src/lib/libc/termios.c (modified) * c/src/lib/libc/termiosreserveresources.c (modified) * c/src/lib/libc/unmount.c (modified) * c/src/lib/libcpu/Makefile.am (modified) * c/src/lib/libcpu/a29k/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/mips/clock/Makefile.am (modified) * c/src/lib/libcpu/mips/timer/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/include/mpc860.h (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old-exceptions/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.am (modified) * c/src/lib/libcpu/sh/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/network/README.dec21140 (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libchip/serial/README.ns16550 (modified) * c/src/libchip/serial/STATUS (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) * c/src/libfs/src/imfs/imfs.h (modified) * c/src/libfs/src/imfs/imfs_creat.c (modified) * c/src/libfs/src/imfs/imfs_directory.c (modified) * c/src/libfs/src/imfs/imfs_stat.c (modified) * c/src/libfs/src/imfs/imfs_utime.c (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dummy/dummy.c (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/monitor/mon-server.c (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/arpa/Makefile.am (modified) * c/src/libnetworking/include/Makefile.am (modified) * c/src/libnetworking/kern/Makefile.am (modified) * c/src/libnetworking/lib/Makefile.am (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/machine/Makefile.am (modified) * c/src/libnetworking/memory.h (modified) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/net/if_loop.c (modified) * c/src/libnetworking/netinet/Makefile.am (modified) * c/src/libnetworking/netinet/in.h (modified) * c/src/libnetworking/nfs/Makefile.am (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/pppd/options.c (modified) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/rtems-ppp.c (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_servers/ftpd.c (modified) * c/src/libnetworking/rtems_webserver/Makefile.am (modified) * c/src/libnetworking/rtems_webserver/balloc.c (modified) * c/src/libnetworking/rtems_webserver/ejlex.c (modified) * c/src/libnetworking/rtems_webserver/handler.c (modified) * c/src/libnetworking/rtems_webserver/uemf.c (modified) * c/src/libnetworking/rtems_webserver/uemf.h (modified) * c/src/libnetworking/rtems_webserver/webs.c (modified) * c/src/libnetworking/sys/Makefile.am (modified) * c/src/libnetworking/sys/un.h (modified) * c/src/libnetworking/vm/Makefile.am (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/librpc/Makefile.am (modified) * c/src/librpc/README_RTEMS (modified) * c/src/librpc/configure.in (modified) * c/src/librpc/include/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/include/rpc/auth.h (modified) * c/src/librpc/include/rpc/auth_des.h (modified) * c/src/librpc/include/rpc/auth_unix.h (modified) * c/src/librpc/include/rpc/clnt.h (modified) * c/src/librpc/include/rpc/des.h (modified) * c/src/librpc/include/rpc/des_crypt.h (modified) * c/src/librpc/include/rpc/pmap_clnt.h (modified) * c/src/librpc/include/rpc/pmap_prot.h (modified) * c/src/librpc/include/rpc/pmap_rmt.h (modified) * c/src/librpc/include/rpc/rpc.h (modified) * c/src/librpc/include/rpc/rpc_com.h (modified) * c/src/librpc/include/rpc/rpc_msg.h (modified) * c/src/librpc/include/rpc/svc.h (modified) * c/src/librpc/include/rpc/svc_auth.h (modified) * c/src/librpc/include/rpc/types.h (modified) * c/src/librpc/include/rpc/xdr.h (modified) * c/src/librpc/include/rpcsvc/.cvsignore (modified) * c/src/librpc/include/rpcsvc/Makefile.am (modified) * c/src/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/librpc/include/rpcsvc/crypt.x (modified) * c/src/librpc/include/rpcsvc/key_prot.x (modified) * c/src/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/librpc/include/rpcsvc/mount.x (modified) * c/src/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/librpc/include/rpcsvc/nis.x (modified) * c/src/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/librpc/include/rpcsvc/nis_db.h (modified) * c/src/librpc/include/rpcsvc/nis_object.x (modified) * c/src/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/librpc/include/rpcsvc/nislib.h (modified) * c/src/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/librpc/include/rpcsvc/rex.x (modified) * c/src/librpc/include/rpcsvc/rnusers.x (modified) * c/src/librpc/include/rpcsvc/rquota.x (modified) * c/src/librpc/include/rpcsvc/rstat.x (modified) * c/src/librpc/include/rpcsvc/rwall.x (modified) * c/src/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/librpc/include/rpcsvc/spray.x (modified) * c/src/librpc/include/rpcsvc/yp.x (modified) * c/src/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/librpc/src/Makefile.am (modified) * c/src/librpc/src/rpc/DISCLAIMER (modified) * c/src/librpc/src/rpc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/librpc/src/rpc/README (modified) * c/src/librpc/src/rpc/auth_des.c (modified) * c/src/librpc/src/rpc/auth_none.c (modified) * c/src/librpc/src/rpc/auth_time.c (modified) * c/src/librpc/src/rpc/auth_unix.c (modified) * c/src/librpc/src/rpc/authdes_prot.c (modified) * c/src/librpc/src/rpc/authunix_prot.c (modified) * c/src/librpc/src/rpc/bindresvport.3 (modified) * c/src/librpc/src/rpc/bindresvport.c (modified) * c/src/librpc/src/rpc/clnt_generic.c (modified) * c/src/librpc/src/rpc/clnt_perror.c (modified) * c/src/librpc/src/rpc/clnt_raw.c (modified) * c/src/librpc/src/rpc/clnt_simple.c (modified) * c/src/librpc/src/rpc/clnt_tcp.c (modified) * c/src/librpc/src/rpc/clnt_udp.c (modified) * c/src/librpc/src/rpc/clnt_unix.c (modified) * c/src/librpc/src/rpc/crypt_client.c (modified) * c/src/librpc/src/rpc/des_crypt.3 (modified) * c/src/librpc/src/rpc/des_crypt.c (modified) * c/src/librpc/src/rpc/des_soft.c (modified) * c/src/librpc/src/rpc/get_myaddress.c (modified) * c/src/librpc/src/rpc/getpublickey.c (modified) * c/src/librpc/src/rpc/getrpcent.3 (modified) * c/src/librpc/src/rpc/getrpcent.c (modified) * c/src/librpc/src/rpc/getrpcport.3 (modified) * c/src/librpc/src/rpc/getrpcport.c (modified) * c/src/librpc/src/rpc/key_call.c (modified) * c/src/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/librpc/src/rpc/netname.c (modified) * c/src/librpc/src/rpc/netnamer.c (modified) * c/src/librpc/src/rpc/pmap_clnt.c (modified) * c/src/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/librpc/src/rpc/pmap_getport.c (modified) * c/src/librpc/src/rpc/pmap_prot.c (modified) * c/src/librpc/src/rpc/pmap_prot2.c (modified) * c/src/librpc/src/rpc/pmap_rmt.c (modified) * c/src/librpc/src/rpc/publickey.3 (modified) * c/src/librpc/src/rpc/publickey.5 (modified) * c/src/librpc/src/rpc/rpc.3 (modified) * c/src/librpc/src/rpc/rpc.5 (modified) * c/src/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/librpc/src/rpc/rpc_commondata.c (modified) * c/src/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/librpc/src/rpc/rpc_prot.c (modified) * c/src/librpc/src/rpc/rpc_secure.3 (modified) * c/src/librpc/src/rpc/rpcdname.c (modified) * c/src/librpc/src/rpc/rstat.1 (modified) * c/src/librpc/src/rpc/rstat_svc.8 (modified) * c/src/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/librpc/src/rpc/rtems_rpc.c (modified) * c/src/librpc/src/rpc/rtime.3 (modified) * c/src/librpc/src/rpc/rtime.c (modified) * c/src/librpc/src/rpc/svc.c (modified) * c/src/librpc/src/rpc/svc_auth.c (modified) * c/src/librpc/src/rpc/svc_auth_des.c (modified) * c/src/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/librpc/src/rpc/svc_raw.c (modified) * c/src/librpc/src/rpc/svc_run.c (modified) * c/src/librpc/src/rpc/svc_simple.c (modified) * c/src/librpc/src/rpc/svc_tcp.c (modified) * c/src/librpc/src/rpc/svc_udp.c (modified) * c/src/librpc/src/rpc/svc_unix.c (modified) * c/src/librpc/src/rpc_callmsg.c (deleted) * c/src/librpc/src/rpc_prot.c (deleted) * c/src/librpc/src/svc.c (deleted) * c/src/librpc/src/svc_auth.c (deleted) * c/src/librpc/src/svc_udp.c (deleted) * c/src/librpc/src/xdr.c (deleted) * c/src/librpc/src/xdr/Makefile.am (modified) * c/src/librpc/src/xdr/xdr.3 (modified) * c/src/librpc/src/xdr/xdr.c (modified) * c/src/librpc/src/xdr/xdr_array.c (modified) * c/src/librpc/src/xdr/xdr_float.c (modified) * c/src/librpc/src/xdr/xdr_mem.c (modified) * c/src/librpc/src/xdr/xdr_rec.c (modified) * c/src/librpc/src/xdr/xdr_reference.c (modified) * c/src/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/librpc/src/xdr/xdr_stdio.c (modified) * c/src/librpc/src/xdr_array.c (deleted) * c/src/librpc/src/xdr_mem.c (deleted) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/librtems++/src/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/README (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.am (modified) * c/src/make/host.cfg.in (modified) * c/src/make/leaf.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/sapi/Makefile.am (modified) * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronhello/system.h (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/system.h (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/itronmbox01.scn (modified) * c/src/tests/itrontests/itronmbox01/system.h (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/init.c (modified) * c/src/tests/itrontests/itronsem01/system.h (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/system.h (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/itrontime01.scn (modified) * c/src/tests/itrontests/itrontime01/system.h (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/cpuuse/cpuuse.scn (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/malloctest/malloctest.scn (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/monitor/system.h (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/putenvtest/init.c (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/libtests/termios/README (modified) * c/src/tests/libtests/termios/init.c (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp14/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx01/psx01.scn (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx02/system.h (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx03/system.h (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx04/system.h (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx06/system.h (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx08/system.h (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx09/system.h (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx10/system.h (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx11/system.h (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx12/system.h (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) * c/src/tests/psxtests/psx13/main.c (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/system.h (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/main.c (modified) * c/src/tests/psxtests/psxfile01/psxfile01.scn (modified) * c/src/tests/psxtests/psxfile01/test.c (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmount/main.c (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/system.h (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/main.c (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/system.h (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxstat/main.c (modified) * c/src/tests/psxtests/psxstat/test.c (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtime/main.c (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/system.h (modified) * c/src/tests/samples/Makefile.am (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/minimum/init.c (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/samples/ticker/tasks.c (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/samples/unlimited/init.c (modified) * c/src/tests/samples/unlimited/system.h (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp25/sp25.scn (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp26/system.h (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp27/init.c (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp28/init.c (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/sp29/init.c (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/support/wrapup/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/system.h (modified) * c/src/tests/tmtests/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) * configure.in (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/httpd/balloc.c (modified) * cpukit/httpd/ejlex.c (modified) * cpukit/httpd/handler.c (modified) * cpukit/httpd/uemf.c (modified) * cpukit/httpd/uemf.h (modified) * cpukit/httpd/webs.c (modified) * cpukit/itron/include/Makefile.am (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/rtems/error.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termiosreserveresources.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/dummy/Makefile.am (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/dumpbuf/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (modified) * cpukit/libnetworking/kern/Makefile.am (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/memory.h (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/netinet/in.h (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/sys/un.h (modified) * cpukit/libnetworking/vm/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/README_RTEMS (modified) * cpukit/librpc/include/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/librpc/include/rpc/auth.h (modified) * cpukit/librpc/include/rpc/auth_des.h (modified) * cpukit/librpc/include/rpc/auth_unix.h (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/des.h (modified) * cpukit/librpc/include/rpc/des_crypt.h (modified) * cpukit/librpc/include/rpc/pmap_clnt.h (modified) * cpukit/librpc/include/rpc/pmap_prot.h (modified) * cpukit/librpc/include/rpc/pmap_rmt.h (modified) * cpukit/librpc/include/rpc/rpc.h (modified) * cpukit/librpc/include/rpc/rpc_com.h (modified) * cpukit/librpc/include/rpc/rpc_msg.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/include/rpc/svc_auth.h (modified) * cpukit/librpc/include/rpc/types.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/include/rpcsvc/.cvsignore (modified) * cpukit/librpc/include/rpcsvc/Makefile.am (modified) * cpukit/librpc/include/rpcsvc/bootparam_prot.x (modified) * cpukit/librpc/include/rpcsvc/crypt.x (modified) * cpukit/librpc/include/rpcsvc/key_prot.x (modified) * cpukit/librpc/include/rpcsvc/klm_prot.x (modified) * cpukit/librpc/include/rpcsvc/mount.x (modified) * cpukit/librpc/include/rpcsvc/nfs_prot.x (modified) * cpukit/librpc/include/rpcsvc/nis.x (modified) * cpukit/librpc/include/rpcsvc/nis_cache.x (modified) * cpukit/librpc/include/rpcsvc/nis_callback.x (modified) * cpukit/librpc/include/rpcsvc/nis_db.h (modified) * cpukit/librpc/include/rpcsvc/nis_object.x (modified) * cpukit/librpc/include/rpcsvc/nis_tags.h (modified) * cpukit/librpc/include/rpcsvc/nislib.h (modified) * cpukit/librpc/include/rpcsvc/nlm_prot.x (modified) * cpukit/librpc/include/rpcsvc/pmap_prot.x (modified) * cpukit/librpc/include/rpcsvc/rex.x (modified) * cpukit/librpc/include/rpcsvc/rnusers.x (modified) * cpukit/librpc/include/rpcsvc/rquota.x (modified) * cpukit/librpc/include/rpcsvc/rstat.x (modified) * cpukit/librpc/include/rpcsvc/rwall.x (modified) * cpukit/librpc/include/rpcsvc/sm_inter.x (modified) * cpukit/librpc/include/rpcsvc/spray.x (modified) * cpukit/librpc/include/rpcsvc/yp.x (modified) * cpukit/librpc/include/rpcsvc/yp_prot.h (modified) * cpukit/librpc/include/rpcsvc/ypclnt.h (modified) * cpukit/librpc/include/rpcsvc/yppasswd.x (modified) * cpukit/librpc/include/rpcsvc/ypupdate_prot.x (modified) * cpukit/librpc/include/rpcsvc/ypxfrd.x (modified) * cpukit/librpc/src/Makefile.am (modified) * cpukit/librpc/src/rpc/DISCLAIMER (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/.cvsignore (modified) * cpukit/librpc/src/rpc/PSD.doc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * cpukit/librpc/src/rpc/README (modified) * cpukit/librpc/src/rpc/auth_des.c (modified) * cpukit/librpc/src/rpc/auth_none.c (modified) * cpukit/librpc/src/rpc/auth_time.c (modified) * cpukit/librpc/src/rpc/auth_unix.c (modified) * cpukit/librpc/src/rpc/authdes_prot.c (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/bindresvport.3 (modified) * cpukit/librpc/src/rpc/bindresvport.c (modified) * cpukit/librpc/src/rpc/clnt_generic.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/clnt_unix.c (modified) * cpukit/librpc/src/rpc/crypt_client.c (modified) * cpukit/librpc/src/rpc/des_crypt.3 (modified) * cpukit/librpc/src/rpc/des_crypt.c (modified) * cpukit/librpc/src/rpc/des_soft.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/librpc/src/rpc/getpublickey.c (modified) * cpukit/librpc/src/rpc/getrpcent.3 (modified) * cpukit/librpc/src/rpc/getrpcent.c (modified) * cpukit/librpc/src/rpc/getrpcport.3 (modified) * cpukit/librpc/src/rpc/getrpcport.c (modified) * cpukit/librpc/src/rpc/key_call.c (modified) * cpukit/librpc/src/rpc/key_prot_xdr.c (modified) * cpukit/librpc/src/rpc/netname.c (modified) * cpukit/librpc/src/rpc/netnamer.c (modified) * cpukit/librpc/src/rpc/pmap_clnt.c (modified) * cpukit/librpc/src/rpc/pmap_getmaps.c (modified) * cpukit/librpc/src/rpc/pmap_getport.c (modified) * cpukit/librpc/src/rpc/pmap_prot.c (modified) * cpukit/librpc/src/rpc/pmap_prot2.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/publickey.3 (modified) * cpukit/librpc/src/rpc/publickey.5 (modified) * cpukit/librpc/src/rpc/rpc.3 (modified) * cpukit/librpc/src/rpc/rpc.5 (modified) * cpukit/librpc/src/rpc/rpc_callmsg.c (modified) * cpukit/librpc/src/rpc/rpc_commondata.c (modified) * cpukit/librpc/src/rpc/rpc_dtablesize.c (modified) * cpukit/librpc/src/rpc/rpc_prot.c (modified) * cpukit/librpc/src/rpc/rpc_secure.3 (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rstat.1 (modified) * cpukit/librpc/src/rpc/rstat_svc.8 (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/rtems_rpc.c (modified) * cpukit/librpc/src/rpc/rtime.3 (modified) * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) * cpukit/librpc/src/rpc/svc_auth_des.c (modified) * cpukit/librpc/src/rpc/svc_auth_unix.c (modified) * cpukit/librpc/src/rpc/svc_raw.c (modified) * cpukit/librpc/src/rpc/svc_run.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/librpc/src/rpc/svc_unix.c (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) * cpukit/librpc/src/xdr/xdr.3 (modified) * cpukit/librpc/src/xdr/xdr.c (modified) * cpukit/librpc/src/xdr/xdr_array.c (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/librpc/src/xdr/xdr_mem.c (modified) * cpukit/librpc/src/xdr/xdr_rec.c (modified) * cpukit/librpc/src/xdr/xdr_reference.c (modified) * cpukit/librpc/src/xdr/xdr_sizeof.c (modified) * cpukit/librpc/src/xdr/xdr_stdio.c (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/pppd.h (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) * cpukit/sapi/include/Makefile.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/README (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/cpu/a29k/Makefile.am (modified) * cpukit/score/cpu/a29k/rtems/score/a29k.h (modified) * cpukit/score/cpu/hppa1.1/Makefile.am (modified) * cpukit/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/sim.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/sim.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/mips64orion/Makefile.am (modified) * cpukit/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/rtems/score/unix.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/src/Makefile.am (modified) * cpukit/score/src/objectcopynamestring.c (modified) * make/Makefile.am (modified) * make/README (modified) * make/Templates/Makefile.am (modified) * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/compilers/Makefile.am (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Makefile.am (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * scripts-ada/.cvsignore (modified) * scripts-ada/Makefile.am (modified) * scripts-ada/binutils/.cvsignore (modified) * scripts-ada/binutils/Makefile.am (modified) * scripts-ada/binutils/binutils.spec.in (modified) * scripts-ada/buildall.in (modified) * scripts-ada/configure.in (modified) * scripts-ada/gdb/.cvsignore (modified) * scripts-ada/gdb/Makefile.am (modified) * scripts-ada/gdb/gdb.spec.in (modified) * scripts-ada/gnatnewlib/.cvsignore (modified) * scripts-ada/gnatnewlib/Makefile.am (modified) * scripts-ada/gnatnewlib/gnatnewlib.spec.in (modified) * scripts-ada/mkbinutilspec.in (modified) * scripts-ada/mkgdbspec.in (modified) * scripts-ada/mkgnatnewlibspec.in (modified) * scripts-ada/setup.def (modified) * scripts/Makefile.am (modified) * scripts/binutils/.cvsignore (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) * scripts/buildall.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/.cvsignore (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/README (added) * scripts/gccnewlib/base-chill.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-chill.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-objc.add (modified) * scripts/gdb/.cvsignore (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) * scripts/rtems/.cvsignore (modified) * scripts/rtems/Makefile.am (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup.def (modified) * testsuites/itrontests/itronhello/Makefile.am (modified) * testsuites/itrontests/itronhello/system.h (modified) * testsuites/itrontests/itronmbf01/Makefile.am (modified) * testsuites/itrontests/itronmbf01/system.h (modified) * testsuites/itrontests/itronmbox01/Makefile.am (modified) * testsuites/itrontests/itronmbox01/itronmbox01.scn (modified) * testsuites/itrontests/itronmbox01/system.h (modified) * testsuites/itrontests/itronsem01/Makefile.am (modified) * testsuites/itrontests/itronsem01/init.c (modified) * testsuites/itrontests/itronsem01/system.h (modified) * testsuites/itrontests/itrontask01/Makefile.am (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask02/Makefile.am (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/Makefile.am (modified) * testsuites/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask04/Makefile.am (modified) * testsuites/itrontests/itrontask04/system.h (modified) * testsuites/itrontests/itrontime01/Makefile.am (modified) * testsuites/itrontests/itrontime01/itrontime01.scn (modified) * testsuites/itrontests/itrontime01/system.h (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/cpuuse/cpuuse.scn (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/malloctest/malloctest.scn (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/putenvtest/init.c (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/libtests/termios/README (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx01/psx01.scn (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile01/psxfile01.scn (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxreaddir/main.c (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxsem01/system.h (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtime/main.c (modified) * testsuites/psxtests/psxtimer/Makefile.am (modified) * testsuites/psxtests/psxtimer/system.h (modified) * testsuites/samples/Makefile.am (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/system.h (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp25/sp25.scn (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp26/system.h (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp27/init.c (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp28/init.c (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/sp29/init.c (modified) * testsuites/sptests/spfatal/Makefile.am (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/tmitrontests/tmitronsem01/Makefile.am (modified) * testsuites/tmitrontests/tmitronsem01/system.h (modified) * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tools/Makefile.am (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/sh/shgen.c (modified) * tools/cpu/unix/Makefile.am (modified) * tools/cpu/unix/gensize.c (modified) * tools/update/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) * tools/update/cipolish (modified) * tools/update/rtems-polish.sh (modified) Merged from 4.5.0-beta3a Wed, 03 May 2000 13:55:42 GMT Joel Sherrill [31aa66a8] * c/src/exec/librpc/src/rpc/rtems_portmapper.c (added) * c/src/exec/librpc/src/rpc/rtems_rpc.c (added) * c/src/librpc/src/rpc/rtems_portmapper.c (added) * c/src/librpc/src/rpc/rtems_rpc.c (added) * cpukit/librpc/src/rpc/rtems_portmapper.c (added) * cpukit/librpc/src/rpc/rtems_rpc.c (added) Added on 4.5 branch. Mon, 01 May 2000 14:57:46 GMT Joel Sherrill [f3c096a] * c/src/exec/librpc/include/rpcsvc/.cvsignore (added) * c/src/exec/librpc/include/rpcsvc/Makefile.am (added) * c/src/exec/librpc/src/rpc/PSD.doc/.cvsignore (added) * c/src/exec/librpc/src/rpc/PSD.doc/Makefile.am (added) * c/src/librpc/include/rpcsvc/.cvsignore (added) * c/src/librpc/include/rpcsvc/Makefile.am (added) * c/src/librpc/src/rpc/PSD.doc/.cvsignore (added) * c/src/librpc/src/rpc/PSD.doc/Makefile.am (added) * cpukit/librpc/include/rpcsvc/.cvsignore (added) * cpukit/librpc/include/rpcsvc/Makefile.am (added) * cpukit/librpc/src/rpc/PSD.doc/.cvsignore (added) * cpukit/librpc/src/rpc/PSD.doc/Makefile.am (added) Added on 4.5-branch Sat, 29 Apr 2000 19:41:47 GMT Joel Sherrill [84a90acf] * c/src/exec/librpc/src/rpc/.cvsignore (added) * c/src/exec/librpc/src/xdr/.cvsignore (added) * c/src/librpc/src/rpc/.cvsignore (added) * c/src/librpc/src/xdr/.cvsignore (added) * cpukit/librpc/src/rpc/.cvsignore (added) * cpukit/librpc/src/xdr/.cvsignore (added) New files. Sat, 29 Apr 2000 19:04:37 GMT Joel Sherrill [5ad350a4] * c/src/exec/librpc/src/rpc/DISCLAIMER (added) * c/src/exec/librpc/src/rpc/Makefile.am (added) * c/src/exec/librpc/src/rpc/PSD.doc/nfs.rfc.ms (added) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.prog.ms (added) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.rfc.ms (added) * c/src/exec/librpc/src/rpc/PSD.doc/rpcgen.ms (added) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.nts.ms (added) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.rfc.ms (added) * c/src/exec/librpc/src/rpc/README (added) * c/src/exec/librpc/src/rpc/auth_des.c (added) * c/src/exec/librpc/src/rpc/auth_none.c (added) * c/src/exec/librpc/src/rpc/auth_time.c (added) * c/src/exec/librpc/src/rpc/auth_unix.c (added) * c/src/exec/librpc/src/rpc/authdes_prot.c (added) * c/src/exec/librpc/src/rpc/authunix_prot.c (added) * c/src/exec/librpc/src/rpc/bindresvport.3 (added) * c/src/exec/librpc/src/rpc/bindresvport.c (added) * c/src/exec/librpc/src/rpc/clnt_generic.c (added) * c/src/exec/librpc/src/rpc/clnt_perror.c (added) * c/src/exec/librpc/src/rpc/clnt_raw.c (added) * c/src/exec/librpc/src/rpc/clnt_simple.c (added) * c/src/exec/librpc/src/rpc/clnt_tcp.c (added) * c/src/exec/librpc/src/rpc/clnt_udp.c (added) * c/src/exec/librpc/src/rpc/clnt_unix.c (added) * c/src/exec/librpc/src/rpc/crypt_client.c (added) * c/src/exec/librpc/src/rpc/des_crypt.3 (added) * c/src/exec/librpc/src/rpc/des_crypt.c (added) * c/src/exec/librpc/src/rpc/des_soft.c (added) * c/src/exec/librpc/src/rpc/get_myaddress.c (added) * c/src/exec/librpc/src/rpc/getpublickey.c (added) * c/src/exec/librpc/src/rpc/getrpcent.3 (added) * c/src/exec/librpc/src/rpc/getrpcent.c (added) * c/src/exec/librpc/src/rpc/getrpcport.3 (added) * c/src/exec/librpc/src/rpc/getrpcport.c (added) * c/src/exec/librpc/src/rpc/key_call.c (added) * c/src/exec/librpc/src/rpc/key_prot_xdr.c (added) * c/src/exec/librpc/src/rpc/netname.c (added) * c/src/exec/librpc/src/rpc/netnamer.c (added) * c/src/exec/librpc/src/rpc/pmap_clnt.c (added) * c/src/exec/librpc/src/rpc/pmap_getmaps.c (added) * c/src/exec/librpc/src/rpc/pmap_getport.c (added) * c/src/exec/librpc/src/rpc/pmap_prot.c (added) * c/src/exec/librpc/src/rpc/pmap_prot2.c (added) * c/src/exec/librpc/src/rpc/pmap_rmt.c (added) * c/src/exec/librpc/src/rpc/publickey.3 (added) * c/src/exec/librpc/src/rpc/publickey.5 (added) * c/src/exec/librpc/src/rpc/rpc.3 (added) * c/src/exec/librpc/src/rpc/rpc.5 (added) * c/src/exec/librpc/src/rpc/rpc_callmsg.c (added) * c/src/exec/librpc/src/rpc/rpc_commondata.c (added) * c/src/exec/librpc/src/rpc/rpc_dtablesize.c (added) * c/src/exec/librpc/src/rpc/rpc_prot.c (added) * c/src/exec/librpc/src/rpc/rpc_secure.3 (added) * c/src/exec/librpc/src/rpc/rpcdname.c (added) * c/src/exec/librpc/src/rpc/rstat.1 (added) * c/src/exec/librpc/src/rpc/rstat_svc.8 (added) * c/src/exec/librpc/src/rpc/rtime.3 (added) * c/src/exec/librpc/src/rpc/rtime.c (added) * c/src/exec/librpc/src/rpc/svc.c (added) * c/src/exec/librpc/src/rpc/svc_auth.c (added) * c/src/exec/librpc/src/rpc/svc_auth_des.c (added) * c/src/exec/librpc/src/rpc/svc_auth_unix.c (added) * c/src/exec/librpc/src/rpc/svc_raw.c (added) * c/src/exec/librpc/src/rpc/svc_run.c (added) * c/src/exec/librpc/src/rpc/svc_simple.c (added) * c/src/exec/librpc/src/rpc/svc_tcp.c (added) * c/src/exec/librpc/src/rpc/svc_udp.c (added) * c/src/exec/librpc/src/rpc/svc_unix.c (added) * c/src/exec/librpc/src/xdr/Makefile.am (added) * c/src/exec/librpc/src/xdr/xdr.3 (added) * c/src/exec/librpc/src/xdr/xdr.c (added) * c/src/exec/librpc/src/xdr/xdr_array.c (added) * c/src/exec/librpc/src/xdr/xdr_float.c (added) * c/src/exec/librpc/src/xdr/xdr_mem.c (added) * c/src/exec/librpc/src/xdr/xdr_rec.c (added) * c/src/exec/librpc/src/xdr/xdr_reference.c (added) * c/src/exec/librpc/src/xdr/xdr_sizeof.c (added) * c/src/exec/librpc/src/xdr/xdr_stdio.c (added) * c/src/librpc/src/rpc/DISCLAIMER (added) * c/src/librpc/src/rpc/Makefile.am (added) * c/src/librpc/src/rpc/PSD.doc/nfs.rfc.ms (added) * c/src/librpc/src/rpc/PSD.doc/rpc.prog.ms (added) * c/src/librpc/src/rpc/PSD.doc/rpc.rfc.ms (added) * c/src/librpc/src/rpc/PSD.doc/rpcgen.ms (added) * c/src/librpc/src/rpc/PSD.doc/xdr.nts.ms (added) * c/src/librpc/src/rpc/PSD.doc/xdr.rfc.ms (added) * c/src/librpc/src/rpc/README (added) * c/src/librpc/src/rpc/auth_des.c (added) * c/src/librpc/src/rpc/auth_none.c (added) * c/src/librpc/src/rpc/auth_time.c (added) * c/src/librpc/src/rpc/auth_unix.c (added) * c/src/librpc/src/rpc/authdes_prot.c (added) * c/src/librpc/src/rpc/authunix_prot.c (added) * c/src/librpc/src/rpc/bindresvport.3 (added) * c/src/librpc/src/rpc/bindresvport.c (added) * c/src/librpc/src/rpc/clnt_generic.c (added) * c/src/librpc/src/rpc/clnt_perror.c (added) * c/src/librpc/src/rpc/clnt_raw.c (added) * c/src/librpc/src/rpc/clnt_simple.c (added) * c/src/librpc/src/rpc/clnt_tcp.c (added) * c/src/librpc/src/rpc/clnt_udp.c (added) * c/src/librpc/src/rpc/clnt_unix.c (added) * c/src/librpc/src/rpc/crypt_client.c (added) * c/src/librpc/src/rpc/des_crypt.3 (added) * c/src/librpc/src/rpc/des_crypt.c (added) * c/src/librpc/src/rpc/des_soft.c (added) * c/src/librpc/src/rpc/get_myaddress.c (added) * c/src/librpc/src/rpc/getpublickey.c (added) * c/src/librpc/src/rpc/getrpcent.3 (added) * c/src/librpc/src/rpc/getrpcent.c (added) * c/src/librpc/src/rpc/getrpcport.3 (added) * c/src/librpc/src/rpc/getrpcport.c (added) * c/src/librpc/src/rpc/key_call.c (added) * c/src/librpc/src/rpc/key_prot_xdr.c (added) * c/src/librpc/src/rpc/netname.c (added) * c/src/librpc/src/rpc/netnamer.c (added) * c/src/librpc/src/rpc/pmap_clnt.c (added) * c/src/librpc/src/rpc/pmap_getmaps.c (added) * c/src/librpc/src/rpc/pmap_getport.c (added) * c/src/librpc/src/rpc/pmap_prot.c (added) * c/src/librpc/src/rpc/pmap_prot2.c (added) * c/src/librpc/src/rpc/pmap_rmt.c (added) * c/src/librpc/src/rpc/publickey.3 (added) * c/src/librpc/src/rpc/publickey.5 (added) * c/src/librpc/src/rpc/rpc.3 (added) * c/src/librpc/src/rpc/rpc.5 (added) * c/src/librpc/src/rpc/rpc_callmsg.c (added) * c/src/librpc/src/rpc/rpc_commondata.c (added) * c/src/librpc/src/rpc/rpc_dtablesize.c (added) * c/src/librpc/src/rpc/rpc_prot.c (added) * c/src/librpc/src/rpc/rpc_secure.3 (added) * c/src/librpc/src/rpc/rpcdname.c (added) * c/src/librpc/src/rpc/rstat.1 (added) * c/src/librpc/src/rpc/rstat_svc.8 (added) * c/src/librpc/src/rpc/rtime.3 (added) * c/src/librpc/src/rpc/rtime.c (added) * c/src/librpc/src/rpc/svc.c (added) * c/src/librpc/src/rpc/svc_auth.c (added) * c/src/librpc/src/rpc/svc_auth_des.c (added) * c/src/librpc/src/rpc/svc_auth_unix.c (added) * c/src/librpc/src/rpc/svc_raw.c (added) * c/src/librpc/src/rpc/svc_run.c (added) * c/src/librpc/src/rpc/svc_simple.c (added) * c/src/librpc/src/rpc/svc_tcp.c (added) * c/src/librpc/src/rpc/svc_udp.c (added) * c/src/librpc/src/rpc/svc_unix.c (added) * c/src/librpc/src/xdr/Makefile.am (added) * c/src/librpc/src/xdr/xdr.3 (added) * c/src/librpc/src/xdr/xdr.c (added) * c/src/librpc/src/xdr/xdr_array.c (added) * c/src/librpc/src/xdr/xdr_float.c (added) * c/src/librpc/src/xdr/xdr_mem.c (added) * c/src/librpc/src/xdr/xdr_rec.c (added) * c/src/librpc/src/xdr/xdr_reference.c (added) * c/src/librpc/src/xdr/xdr_sizeof.c (added) * c/src/librpc/src/xdr/xdr_stdio.c (added) * cpukit/librpc/src/rpc/DISCLAIMER (added) * cpukit/librpc/src/rpc/Makefile.am (added) * cpukit/librpc/src/rpc/PSD.doc/nfs.rfc.ms (added) * cpukit/librpc/src/rpc/PSD.doc/rpc.prog.ms (added) * cpukit/librpc/src/rpc/PSD.doc/rpc.rfc.ms (added) * cpukit/librpc/src/rpc/PSD.doc/rpcgen.ms (added) * cpukit/librpc/src/rpc/PSD.doc/xdr.nts.ms (added) * cpukit/librpc/src/rpc/PSD.doc/xdr.rfc.ms (added) * cpukit/librpc/src/rpc/README (added) * cpukit/librpc/src/rpc/auth_des.c (added) * cpukit/librpc/src/rpc/auth_none.c (added) * cpukit/librpc/src/rpc/auth_time.c (added) * cpukit/librpc/src/rpc/auth_unix.c (added) * cpukit/librpc/src/rpc/authdes_prot.c (added) * cpukit/librpc/src/rpc/authunix_prot.c (added) * cpukit/librpc/src/rpc/bindresvport.3 (added) * cpukit/librpc/src/rpc/bindresvport.c (added) * cpukit/librpc/src/rpc/clnt_generic.c (added) * cpukit/librpc/src/rpc/clnt_perror.c (added) * cpukit/librpc/src/rpc/clnt_raw.c (added) * cpukit/librpc/src/rpc/clnt_simple.c (added) * cpukit/librpc/src/rpc/clnt_tcp.c (added) * cpukit/librpc/src/rpc/clnt_udp.c (added) * cpukit/librpc/src/rpc/clnt_unix.c (added) * cpukit/librpc/src/rpc/crypt_client.c (added) * cpukit/librpc/src/rpc/des_crypt.3 (added) * cpukit/librpc/src/rpc/des_crypt.c (added) * cpukit/librpc/src/rpc/des_soft.c (added) * cpukit/librpc/src/rpc/get_myaddress.c (added) * cpukit/librpc/src/rpc/getpublickey.c (added) * cpukit/librpc/src/rpc/getrpcent.3 (added) * cpukit/librpc/src/rpc/getrpcent.c (added) * cpukit/librpc/src/rpc/getrpcport.3 (added) * cpukit/librpc/src/rpc/getrpcport.c (added) * cpukit/librpc/src/rpc/key_call.c (added) * cpukit/librpc/src/rpc/key_prot_xdr.c (added) * cpukit/librpc/src/rpc/netname.c (added) * cpukit/librpc/src/rpc/netnamer.c (added) * cpukit/librpc/src/rpc/pmap_clnt.c (added) * cpukit/librpc/src/rpc/pmap_getmaps.c (added) * cpukit/librpc/src/rpc/pmap_getport.c (added) * cpukit/librpc/src/rpc/pmap_prot.c (added) * cpukit/librpc/src/rpc/pmap_prot2.c (added) * cpukit/librpc/src/rpc/pmap_rmt.c (added) * cpukit/librpc/src/rpc/publickey.3 (added) * cpukit/librpc/src/rpc/publickey.5 (added) * cpukit/librpc/src/rpc/rpc.3 (added) * cpukit/librpc/src/rpc/rpc.5 (added) * cpukit/librpc/src/rpc/rpc_callmsg.c (added) * cpukit/librpc/src/rpc/rpc_commondata.c (added) * cpukit/librpc/src/rpc/rpc_dtablesize.c (added) * cpukit/librpc/src/rpc/rpc_prot.c (added) * cpukit/librpc/src/rpc/rpc_secure.3 (added) * cpukit/librpc/src/rpc/rpcdname.c (added) * cpukit/librpc/src/rpc/rstat.1 (added) * cpukit/librpc/src/rpc/rstat_svc.8 (added) * cpukit/librpc/src/rpc/rtime.3 (added) * cpukit/librpc/src/rpc/rtime.c (added) * cpukit/librpc/src/rpc/svc.c (added) * cpukit/librpc/src/rpc/svc_auth.c (added) * cpukit/librpc/src/rpc/svc_auth_des.c (added) * cpukit/librpc/src/rpc/svc_auth_unix.c (added) * cpukit/librpc/src/rpc/svc_raw.c (added) * cpukit/librpc/src/rpc/svc_run.c (added) * cpukit/librpc/src/rpc/svc_simple.c (added) * cpukit/librpc/src/rpc/svc_tcp.c (added) * cpukit/librpc/src/rpc/svc_udp.c (added) * cpukit/librpc/src/rpc/svc_unix.c (added) * cpukit/librpc/src/xdr/Makefile.am (added) * cpukit/librpc/src/xdr/xdr.3 (added) * cpukit/librpc/src/xdr/xdr.c (added) * cpukit/librpc/src/xdr/xdr_array.c (added) * cpukit/librpc/src/xdr/xdr_float.c (added) * cpukit/librpc/src/xdr/xdr_mem.c (added) * cpukit/librpc/src/xdr/xdr_rec.c (added) * cpukit/librpc/src/xdr/xdr_reference.c (added) * cpukit/librpc/src/xdr/xdr_sizeof.c (added) * cpukit/librpc/src/xdr/xdr_stdio.c (added) New files added as part of librpc upgrade. Thu, 13 Apr 2000 14:37:14 GMT Joel Sherrill [bf85b19] * c/.cvsignore (added) * c/make/.cvsignore (added) * c/src/.cvsignore (added) * c/src/exec/itron/.cvsignore (added) * c/src/exec/itron/include/.cvsignore (added) * c/src/exec/itron/include/itronsys/.cvsignore (added) * c/src/exec/itron/include/rtems/.cvsignore (added) * c/src/exec/itron/include/rtems/itron/.cvsignore (added) * c/src/exec/itron/inline/.cvsignore (added) * c/src/exec/itron/inline/rtems/.cvsignore (added) * c/src/exec/itron/inline/rtems/itron/.cvsignore (added) * c/src/exec/itron/src/.cvsignore (added) * c/src/exec/libcsupport/.cvsignore (added) * c/src/exec/libnetworking/.cvsignore (added) * c/src/exec/libnetworking/arpa/.cvsignore (added) * c/src/exec/libnetworking/kern/.cvsignore (added) * c/src/exec/libnetworking/lib/.cvsignore (added) * c/src/exec/libnetworking/libc/.cvsignore (added) * c/src/exec/libnetworking/machine/.cvsignore (added) * c/src/exec/libnetworking/net/.cvsignore (added) * c/src/exec/libnetworking/netinet/.cvsignore (added) * c/src/exec/libnetworking/nfs/.cvsignore (added) * c/src/exec/libnetworking/rtems/.cvsignore (added) * c/src/exec/libnetworking/sys/.cvsignore (added) * c/src/exec/libnetworking/vm/.cvsignore (added) * c/src/exec/libnetworking/wrapup/.cvsignore (added) * c/src/exec/librpc/.cvsignore (added) * c/src/exec/librpc/include/.cvsignore (added) * c/src/exec/librpc/include/rpc/.cvsignore (added) * c/src/exec/librpc/src/.cvsignore (added) * c/src/exec/posix/.cvsignore (added) * c/src/exec/posix/include/.cvsignore (added) * c/src/exec/posix/include/rtems/.cvsignore (added) * c/src/exec/posix/include/rtems/posix/.cvsignore (added) * c/src/exec/posix/include/sys/.cvsignore (added) * c/src/exec/posix/inline/.cvsignore (added) * c/src/exec/posix/inline/rtems/.cvsignore (added) * c/src/exec/posix/inline/rtems/posix/.cvsignore (added) * c/src/exec/posix/macros/.cvsignore (added) * c/src/exec/posix/macros/rtems/.cvsignore (added) * c/src/exec/posix/macros/rtems/posix/.cvsignore (added) * c/src/exec/posix/optman/.cvsignore (added) * c/src/exec/posix/src/.cvsignore (added) * c/src/exec/rtems/.cvsignore (added) * c/src/exec/rtems/include/.cvsignore (added) * c/src/exec/rtems/include/rtems/.cvsignore (added) * c/src/exec/rtems/include/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/inline/.cvsignore (added) * c/src/exec/rtems/inline/rtems/.cvsignore (added) * c/src/exec/rtems/inline/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/macros/.cvsignore (added) * c/src/exec/rtems/macros/rtems/.cvsignore (added) * c/src/exec/rtems/macros/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/optman/.cvsignore (added) * c/src/exec/rtems/src/.cvsignore (added) * c/src/exec/sapi/.cvsignore (added) * c/src/exec/sapi/include/.cvsignore (added) * c/src/exec/sapi/include/rtems/.cvsignore (added) * c/src/exec/sapi/inline/.cvsignore (added) * c/src/exec/sapi/inline/rtems/.cvsignore (added) * c/src/exec/sapi/macros/.cvsignore (added) * c/src/exec/sapi/macros/rtems/.cvsignore (added) * c/src/exec/sapi/optman/.cvsignore (added) * c/src/exec/sapi/src/.cvsignore (added) * c/src/exec/score/cpu/a29k/.cvsignore (added) * c/src/exec/score/cpu/a29k/rtems/.cvsignore (added) * c/src/exec/score/cpu/a29k/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/rtems/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/i386/.cvsignore (added) * c/src/exec/score/cpu/i386/rtems/.cvsignore (added) * c/src/exec/score/cpu/i386/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/i960/.cvsignore (added) * c/src/exec/score/cpu/i960/rtems/.cvsignore (added) * c/src/exec/score/cpu/i960/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/m68k/.cvsignore (added) * c/src/exec/score/cpu/m68k/rtems/.cvsignore (added) * c/src/exec/score/cpu/m68k/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/mips/.cvsignore (added) * c/src/exec/score/cpu/mips/rtems/.cvsignore (added) * c/src/exec/score/cpu/mips/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/rtems/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/rtems/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/.cvsignore (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/.cvsignore (added) * c/src/exec/score/cpu/powerpc/shared/.cvsignore (added) * c/src/lib/.cvsignore (added) * c/src/lib/libbsp/.cvsignore (added) * c/src/lib/libbsp/powerpc/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/motorola/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/openpic/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/pci/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/residual/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/start/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/vectors/.cvsignore (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/.cvsignore (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/.cvsignore (added) * c/src/lib/libbsp/sh/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/console/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/include/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/scitab/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/start/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/startup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/wrapup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/console/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/include/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/scitab/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/start/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/startup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/wrapup/.cvsignore (added) * c/src/lib/libbsp/sh/shared/.cvsignore (added) * c/src/lib/libbsp/shmdr/.cvsignore (added) * c/src/lib/libbsp/sparc/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/clock/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/console/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/gnatsupp/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/include/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/start/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/startup/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/timer/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/tools/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/wrapup/.cvsignore (added) * c/src/lib/libbsp/unix/.cvsignore (added) * c/src/lib/libbsp/unix/posix/.cvsignore (added) * c/src/lib/libbsp/unix/posix/clock/.cvsignore (added) * c/src/lib/libbsp/unix/posix/console/.cvsignore (added) * c/src/lib/libbsp/unix/posix/include/.cvsignore (added) * c/src/lib/libbsp/unix/posix/shmsupp/.cvsignore (added) * c/src/lib/libbsp/unix/posix/startup/.cvsignore (added) * c/src/lib/libbsp/unix/posix/timer/.cvsignore (added) * c/src/lib/libbsp/unix/posix/tools/.cvsignore (added) * c/src/lib/libbsp/unix/posix/wrapup/.cvsignore (added) * c/src/lib/libc/.cvsignore (added) * c/src/lib/libcpu/.cvsignore (added) * c/src/lib/libcpu/a29k/.cvsignore (added) * c/src/lib/libcpu/a29k/clock/.cvsignore (added) * c/src/lib/libcpu/a29k/timer/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/clock/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/include/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/milli/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/semaphore/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/timer/.cvsignore (added) * c/src/lib/libcpu/i386/.cvsignore (added) * c/src/lib/libcpu/m68k/.cvsignore (added) * c/src/lib/libcpu/m68k/m68040/.cvsignore (added) * c/src/lib/libcpu/m68k/m68040/fpsp/.cvsignore (added) * c/src/lib/libcpu/mips/.cvsignore (added) * c/src/lib/libcpu/mips/clock/.cvsignore (added) * c/src/lib/libcpu/mips/timer/.cvsignore (added) * c/src/lib/libcpu/mips64orion/.cvsignore (added) * c/src/lib/libcpu/mips64orion/clock/.cvsignore (added) * c/src/lib/libcpu/mips64orion/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/console-generic/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/include/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/console-generic/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/include/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/new_exception_processing/.cvsignore (added) * c/src/lib/libcpu/powerpc/old_exception_processing/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/console/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/ictrl/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/shared/.cvsignore (added) * c/src/lib/libcpu/powerpc/wrapup/.cvsignore (added) * c/src/lib/libcpu/sh/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/clock/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/delay/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/include/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/null/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/sci/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/timer/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/clock/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/include/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/null/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/sci/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/timer/.cvsignore (added) * c/src/lib/libcpu/sparc/.cvsignore (added) * c/src/lib/libcpu/sparc/reg_win/.cvsignore (added) * c/src/lib/libcpu/sparc/syscall/.cvsignore (added) * c/src/libchip/.cvsignore (added) * c/src/libchip/network/.cvsignore (added) * c/src/libchip/rtc/.cvsignore (added) * c/src/libchip/serial/.cvsignore (added) * c/src/libchip/shmdr/.cvsignore (added) * c/src/libmisc/.cvsignore (added) * c/src/libmisc/cpuuse/.cvsignore (added) * c/src/libmisc/dummy/.cvsignore (added) * c/src/libmisc/dumpbuf/.cvsignore (added) * c/src/libmisc/monitor/.cvsignore (added) * c/src/libmisc/rtmonuse/.cvsignore (added) * c/src/libmisc/stackchk/.cvsignore (added) * c/src/libmisc/untar/.cvsignore (added) * c/src/libmisc/wrapup/.cvsignore (added) * c/src/libnetworking/.cvsignore (added) * c/src/libnetworking/arpa/.cvsignore (added) * c/src/libnetworking/include/.cvsignore (added) * c/src/libnetworking/kern/.cvsignore (added) * c/src/libnetworking/lib/.cvsignore (added) * c/src/libnetworking/libc/.cvsignore (added) * c/src/libnetworking/machine/.cvsignore (added) * c/src/libnetworking/net/.cvsignore (added) * c/src/libnetworking/netinet/.cvsignore (added) * c/src/libnetworking/nfs/.cvsignore (added) * c/src/libnetworking/pppd/.cvsignore (added) * c/src/libnetworking/rtems/.cvsignore (added) * c/src/libnetworking/rtems_servers/.cvsignore (added) * c/src/libnetworking/rtems_webserver/.cvsignore (added) * c/src/libnetworking/sys/.cvsignore (added) * c/src/libnetworking/vm/.cvsignore (added) * c/src/libnetworking/wrapup/.cvsignore (added) * c/src/librdbg/.cvsignore (added) * c/src/librdbg/include/.cvsignore (added) * c/src/librdbg/include/rdbg/.cvsignore (added) * c/src/librdbg/include/rdbg/i386/.cvsignore (added) * c/src/librdbg/include/rdbg/powerpc/.cvsignore (added) * c/src/librdbg/src/.cvsignore (added) * c/src/librdbg/src/i386/.cvsignore (added) * c/src/librdbg/src/i386/any/.cvsignore (added) * c/src/librdbg/src/powerpc/.cvsignore (added) * c/src/librdbg/src/powerpc/mcp750/.cvsignore (added) * c/src/librdbg/src/powerpc/new_exception_processing/.cvsignore (added) * c/src/librpc/.cvsignore (added) * c/src/librpc/include/.cvsignore (added) * c/src/librpc/include/rpc/.cvsignore (added) * c/src/librpc/src/.cvsignore (added) * c/src/librtems++/.cvsignore (added) * c/src/librtems++/include/.cvsignore (added) * c/src/librtems++/include/rtems++/.cvsignore (added) * c/src/librtems++/src/.cvsignore (added) * c/src/make/.cvsignore (added) * c/src/make/compilers/.cvsignore (added) * c/src/make/custom/.cvsignore (added) * c/src/tests/.cvsignore (added) * c/src/tests/itrontests/.cvsignore (added) * c/src/tests/itrontests/itronhello/.cvsignore (added) * c/src/tests/itrontests/itronmbf01/.cvsignore (added) * c/src/tests/itrontests/itronmbox01/.cvsignore (added) * c/src/tests/itrontests/itronsem01/.cvsignore (added) * c/src/tests/itrontests/itrontask01/.cvsignore (added) * c/src/tests/itrontests/itrontask02/.cvsignore (added) * c/src/tests/itrontests/itrontask03/.cvsignore (added) * c/src/tests/itrontests/itrontask04/.cvsignore (added) * c/src/tests/itrontests/itrontime01/.cvsignore (added) * c/src/tests/libtests/.cvsignore (added) * c/src/tests/libtests/cpuuse/.cvsignore (added) * c/src/tests/libtests/malloctest/.cvsignore (added) * c/src/tests/libtests/monitor/.cvsignore (added) * c/src/tests/libtests/putenvtest/.cvsignore (added) * c/src/tests/libtests/rtems++/.cvsignore (added) * c/src/tests/libtests/rtmonuse/.cvsignore (added) * c/src/tests/libtests/stackchk/.cvsignore (added) * c/src/tests/libtests/termios/.cvsignore (added) * c/src/tests/mptests/.cvsignore (added) * c/src/tests/mptests/mp01/.cvsignore (added) * c/src/tests/mptests/mp01/node1/.cvsignore (added) * c/src/tests/mptests/mp01/node2/.cvsignore (added) * c/src/tests/mptests/mp02/.cvsignore (added) * c/src/tests/mptests/mp02/node1/.cvsignore (added) * c/src/tests/mptests/mp02/node2/.cvsignore (added) * c/src/tests/mptests/mp03/.cvsignore (added) * c/src/tests/mptests/mp03/node1/.cvsignore (added) * c/src/tests/mptests/mp03/node2/.cvsignore (added) * c/src/tests/mptests/mp04/.cvsignore (added) * c/src/tests/mptests/mp04/node1/.cvsignore (added) * c/src/tests/mptests/mp04/node2/.cvsignore (added) * c/src/tests/mptests/mp05/.cvsignore (added) * c/src/tests/mptests/mp05/node1/.cvsignore (added) * c/src/tests/mptests/mp05/node2/.cvsignore (added) * c/src/tests/mptests/mp06/.cvsignore (added) * c/src/tests/mptests/mp06/node1/.cvsignore (added) * c/src/tests/mptests/mp06/node2/.cvsignore (added) * c/src/tests/mptests/mp07/.cvsignore (added) * c/src/tests/mptests/mp07/node1/.cvsignore (added) * c/src/tests/mptests/mp07/node2/.cvsignore (added) * c/src/tests/mptests/mp08/.cvsignore (added) * c/src/tests/mptests/mp08/node1/.cvsignore (added) * c/src/tests/mptests/mp08/node2/.cvsignore (added) * c/src/tests/mptests/mp09/.cvsignore (added) * c/src/tests/mptests/mp09/node1/.cvsignore (added) * c/src/tests/mptests/mp09/node2/.cvsignore (added) * c/src/tests/mptests/mp10/.cvsignore (added) * c/src/tests/mptests/mp10/node1/.cvsignore (added) * c/src/tests/mptests/mp10/node2/.cvsignore (added) * c/src/tests/mptests/mp11/.cvsignore (added) * c/src/tests/mptests/mp11/node1/.cvsignore (added) * c/src/tests/mptests/mp11/node2/.cvsignore (added) * c/src/tests/mptests/mp12/.cvsignore (added) * c/src/tests/mptests/mp12/node1/.cvsignore (added) * c/src/tests/mptests/mp12/node2/.cvsignore (added) * c/src/tests/mptests/mp13/.cvsignore (added) * c/src/tests/mptests/mp13/node1/.cvsignore (added) * c/src/tests/mptests/mp13/node2/.cvsignore (added) * c/src/tests/mptests/mp14/.cvsignore (added) * c/src/tests/mptests/mp14/node1/.cvsignore (added) * c/src/tests/mptests/mp14/node2/.cvsignore (added) * c/src/tests/psxtests/.cvsignore (added) * c/src/tests/psxtests/include/.cvsignore (added) * c/src/tests/psxtests/psx01/.cvsignore (added) * c/src/tests/psxtests/psx02/.cvsignore (added) * c/src/tests/psxtests/psx03/.cvsignore (added) * c/src/tests/psxtests/psx04/.cvsignore (added) * c/src/tests/psxtests/psx05/.cvsignore (added) * c/src/tests/psxtests/psx06/.cvsignore (added) * c/src/tests/psxtests/psx07/.cvsignore (added) * c/src/tests/psxtests/psx08/.cvsignore (added) * c/src/tests/psxtests/psx09/.cvsignore (added) * c/src/tests/psxtests/psx10/.cvsignore (added) * c/src/tests/psxtests/psx11/.cvsignore (added) * c/src/tests/psxtests/psx12/.cvsignore (added) * c/src/tests/psxtests/psx13/.cvsignore (added) * c/src/tests/psxtests/psxcancel/.cvsignore (added) * c/src/tests/psxtests/psxfile01/.cvsignore (added) * c/src/tests/psxtests/psxhdrs/.cvsignore (added) * c/src/tests/psxtests/psxmount/.cvsignore (added) * c/src/tests/psxtests/psxmsgq01/.cvsignore (added) * c/src/tests/psxtests/psxreaddir/.cvsignore (added) * c/src/tests/psxtests/psxsem01/.cvsignore (added) * c/src/tests/psxtests/psxstat/.cvsignore (added) * c/src/tests/psxtests/psxtime/.cvsignore (added) * c/src/tests/psxtests/psxtimer/.cvsignore (added) * c/src/tests/samples/.cvsignore (added) * c/src/tests/samples/base_mp/.cvsignore (added) * c/src/tests/samples/base_mp/node1/.cvsignore (added) * c/src/tests/samples/base_mp/node2/.cvsignore (added) * c/src/tests/samples/base_sp/.cvsignore (added) * c/src/tests/samples/cdtest/.cvsignore (added) * c/src/tests/samples/hello/.cvsignore (added) * c/src/tests/samples/minimum/.cvsignore (added) * c/src/tests/samples/paranoia/.cvsignore (added) * c/src/tests/samples/ticker/.cvsignore (added) * c/src/tests/samples/unlimited/.cvsignore (added) * c/src/tests/sptests/.cvsignore (added) * c/src/tests/sptests/sp01/.cvsignore (added) * c/src/tests/sptests/sp02/.cvsignore (added) * c/src/tests/sptests/sp03/.cvsignore (added) * c/src/tests/sptests/sp04/.cvsignore (added) * c/src/tests/sptests/sp05/.cvsignore (added) * c/src/tests/sptests/sp06/.cvsignore (added) * c/src/tests/sptests/sp07/.cvsignore (added) * c/src/tests/sptests/sp08/.cvsignore (added) * c/src/tests/sptests/sp09/.cvsignore (added) * c/src/tests/sptests/sp11/.cvsignore (added) * c/src/tests/sptests/sp12/.cvsignore (added) * c/src/tests/sptests/sp13/.cvsignore (added) * c/src/tests/sptests/sp14/.cvsignore (added) * c/src/tests/sptests/sp15/.cvsignore (added) * c/src/tests/sptests/sp16/.cvsignore (added) * c/src/tests/sptests/sp17/.cvsignore (added) * c/src/tests/sptests/sp19/.cvsignore (added) * c/src/tests/sptests/sp20/.cvsignore (added) * c/src/tests/sptests/sp21/.cvsignore (added) * c/src/tests/sptests/sp22/.cvsignore (added) * c/src/tests/sptests/sp23/.cvsignore (added) * c/src/tests/sptests/sp24/.cvsignore (added) * c/src/tests/sptests/sp25/.cvsignore (added) * c/src/tests/sptests/sp26/.cvsignore (added) * c/src/tests/sptests/sp27/.cvsignore (added) * c/src/tests/sptests/sp28/.cvsignore (added) * c/src/tests/sptests/sp29/.cvsignore (added) * c/src/tests/sptests/spfatal/.cvsignore (added) * c/src/tests/sptests/spsize/.cvsignore (added) * c/src/tests/support/.cvsignore (added) * c/src/tests/support/include/.cvsignore (added) * c/src/tests/support/stubdr/.cvsignore (added) * c/src/tests/support/wrapup/.cvsignore (added) * c/src/tests/tmitrontests/.cvsignore (added) * c/src/tests/tmitrontests/include/.cvsignore (added) * c/src/tests/tmitrontests/tmitronsem01/.cvsignore (added) * c/src/tests/tmtests/.cvsignore (added) * c/src/tests/tmtests/include/.cvsignore (added) * c/src/tests/tmtests/tm01/.cvsignore (added) * c/src/tests/tmtests/tm02/.cvsignore (added) * c/src/tests/tmtests/tm03/.cvsignore (added) * c/src/tests/tmtests/tm04/.cvsignore (added) * c/src/tests/tmtests/tm05/.cvsignore (added) * c/src/tests/tmtests/tm06/.cvsignore (added) * c/src/tests/tmtests/tm07/.cvsignore (added) * c/src/tests/tmtests/tm08/.cvsignore (added) * c/src/tests/tmtests/tm09/.cvsignore (added) * c/src/tests/tmtests/tm10/.cvsignore (added) * c/src/tests/tmtests/tm11/.cvsignore (added) * c/src/tests/tmtests/tm12/.cvsignore (added) * c/src/tests/tmtests/tm13/.cvsignore (added) * c/src/tests/tmtests/tm14/.cvsignore (added) * c/src/tests/tmtests/tm15/.cvsignore (added) * c/src/tests/tmtests/tm16/.cvsignore (added) * c/src/tests/tmtests/tm17/.cvsignore (added) * c/src/tests/tmtests/tm18/.cvsignore (added) * c/src/tests/tmtests/tm19/.cvsignore (added) * c/src/tests/tmtests/tm20/.cvsignore (added) * c/src/tests/tmtests/tm21/.cvsignore (added) * c/src/tests/tmtests/tm22/.cvsignore (added) * c/src/tests/tmtests/tm23/.cvsignore (added) * c/src/tests/tmtests/tm24/.cvsignore (added) * c/src/tests/tmtests/tm25/.cvsignore (added) * c/src/tests/tmtests/tm26/.cvsignore (added) * c/src/tests/tmtests/tm27/.cvsignore (added) * c/src/tests/tmtests/tm28/.cvsignore (added) * c/src/tests/tmtests/tm29/.cvsignore (added) * c/src/tests/tmtests/tmck/.cvsignore (added) * c/src/tests/tmtests/tmoverhd/.cvsignore (added) * c/src/tests/tools/.cvsignore (added) * c/src/tests/tools/generic/.cvsignore (added) * c/src/wrapup/.cvsignore (added) * cpukit/httpd/.cvsignore (added) * cpukit/itron/.cvsignore (added) * cpukit/itron/include/.cvsignore (added) * cpukit/itron/include/itronsys/.cvsignore (added) * cpukit/itron/include/rtems/.cvsignore (added) * cpukit/itron/include/rtems/itron/.cvsignore (added) * cpukit/itron/inline/.cvsignore (added) * cpukit/itron/inline/rtems/.cvsignore (added) * cpukit/itron/inline/rtems/itron/.cvsignore (added) * cpukit/itron/src/.cvsignore (added) * cpukit/libcsupport/.cvsignore (added) * cpukit/libmisc/.cvsignore (added) * cpukit/libmisc/cpuuse/.cvsignore (added) * cpukit/libmisc/dummy/.cvsignore (added) * cpukit/libmisc/dumpbuf/.cvsignore (added) * cpukit/libmisc/monitor/.cvsignore (added) * cpukit/libmisc/rtmonuse/.cvsignore (added) * cpukit/libmisc/stackchk/.cvsignore (added) * cpukit/libmisc/untar/.cvsignore (added) * cpukit/libmisc/wrapup/.cvsignore (added) * cpukit/libnetworking/.cvsignore (added) * cpukit/libnetworking/arpa/.cvsignore (added) * cpukit/libnetworking/kern/.cvsignore (added) * cpukit/libnetworking/lib/.cvsignore (added) * cpukit/libnetworking/libc/.cvsignore (added) * cpukit/libnetworking/machine/.cvsignore (added) * cpukit/libnetworking/net/.cvsignore (added) * cpukit/libnetworking/netinet/.cvsignore (added) * cpukit/libnetworking/nfs/.cvsignore (added) * cpukit/libnetworking/rtems/.cvsignore (added) * cpukit/libnetworking/sys/.cvsignore (added) * cpukit/libnetworking/vm/.cvsignore (added) * cpukit/libnetworking/wrapup/.cvsignore (added) * cpukit/librpc/.cvsignore (added) * cpukit/librpc/include/.cvsignore (added) * cpukit/librpc/include/rpc/.cvsignore (added) * cpukit/librpc/src/.cvsignore (added) * cpukit/posix/.cvsignore (added) * cpukit/posix/include/.cvsignore (added) * cpukit/posix/include/rtems/.cvsignore (added) * cpukit/posix/include/rtems/posix/.cvsignore (added) * cpukit/posix/inline/.cvsignore (added) * cpukit/posix/inline/rtems/.cvsignore (added) * cpukit/posix/inline/rtems/posix/.cvsignore (added) * cpukit/posix/macros/.cvsignore (added) * cpukit/posix/macros/rtems/.cvsignore (added) * cpukit/posix/macros/rtems/posix/.cvsignore (added) * cpukit/posix/src/.cvsignore (added) * cpukit/rtems/.cvsignore (added) * cpukit/rtems/include/.cvsignore (added) * cpukit/rtems/include/rtems/.cvsignore (added) * cpukit/rtems/include/rtems/rtems/.cvsignore (added) * cpukit/rtems/inline/.cvsignore (added) * cpukit/rtems/inline/rtems/.cvsignore (added) * cpukit/rtems/inline/rtems/rtems/.cvsignore (added) * cpukit/rtems/macros/.cvsignore (added) * cpukit/rtems/macros/rtems/.cvsignore (added) * cpukit/rtems/macros/rtems/rtems/.cvsignore (added) * cpukit/rtems/src/.cvsignore (added) * cpukit/sapi/.cvsignore (added) * cpukit/sapi/include/.cvsignore (added) * cpukit/sapi/include/rtems/.cvsignore (added) * cpukit/sapi/inline/.cvsignore (added) * cpukit/sapi/inline/rtems/.cvsignore (added) * cpukit/sapi/macros/.cvsignore (added) * cpukit/sapi/macros/rtems/.cvsignore (added) * cpukit/sapi/src/.cvsignore (added) * cpukit/score/cpu/a29k/.cvsignore (added) * cpukit/score/cpu/a29k/rtems/.cvsignore (added) * cpukit/score/cpu/a29k/rtems/score/.cvsignore (added) * cpukit/score/cpu/hppa1.1/.cvsignore (added) * cpukit/score/cpu/hppa1.1/rtems/.cvsignore (added) * cpukit/score/cpu/hppa1.1/rtems/score/.cvsignore (added) * cpukit/score/cpu/i386/.cvsignore (added) * cpukit/score/cpu/i386/rtems/.cvsignore (added) * cpukit/score/cpu/i386/rtems/score/.cvsignore (added) * cpukit/score/cpu/i960/.cvsignore (added) * cpukit/score/cpu/i960/rtems/.cvsignore (added) * cpukit/score/cpu/i960/rtems/score/.cvsignore (added) * cpukit/score/cpu/m68k/.cvsignore (added) * cpukit/score/cpu/m68k/rtems/.cvsignore (added) * cpukit/score/cpu/m68k/rtems/score/.cvsignore (added) * cpukit/score/cpu/mips/.cvsignore (added) * cpukit/score/cpu/mips/rtems/.cvsignore (added) * cpukit/score/cpu/mips/rtems/score/.cvsignore (added) * cpukit/score/cpu/mips64orion/.cvsignore (added) * cpukit/score/cpu/mips64orion/rtems/.cvsignore (added) * cpukit/score/cpu/mips64orion/rtems/score/.cvsignore (added) * cpukit/score/cpu/no_cpu/.cvsignore (added) * cpukit/score/cpu/no_cpu/rtems/.cvsignore (added) * cpukit/score/cpu/no_cpu/rtems/score/.cvsignore (added) * doc/.cvsignore (added) * make/.cvsignore (added) * make/Templates/.cvsignore (added) * make/compilers/.cvsignore (added) * make/custom/.cvsignore (added) * scripts-ada/.cvsignore (added) * scripts-ada/binutils/.cvsignore (added) * scripts-ada/gdb/.cvsignore (added) * scripts-ada/gnatnewlib/.cvsignore (added) * scripts/.cvsignore (added) * scripts/binutils/.cvsignore (added) * scripts/gccnewlib/.cvsignore (added) * scripts/gdb/.cvsignore (added) * scripts/rtems/.cvsignore (added) * testsuites/.cvsignore (added) * testsuites/itrontests/.cvsignore (added) * testsuites/itrontests/itronhello/.cvsignore (added) * testsuites/itrontests/itronmbf01/.cvsignore (added) * testsuites/itrontests/itronmbox01/.cvsignore (added) * testsuites/itrontests/itronsem01/.cvsignore (added) * testsuites/itrontests/itrontask01/.cvsignore (added) * testsuites/itrontests/itrontask02/.cvsignore (added) * testsuites/itrontests/itrontask03/.cvsignore (added) * testsuites/itrontests/itrontask04/.cvsignore (added) * testsuites/itrontests/itrontime01/.cvsignore (added) * testsuites/libtests/.cvsignore (added) * testsuites/libtests/cpuuse/.cvsignore (added) * testsuites/libtests/malloctest/.cvsignore (added) * testsuites/libtests/monitor/.cvsignore (added) * testsuites/libtests/putenvtest/.cvsignore (added) * testsuites/libtests/rtems++/.cvsignore (added) * testsuites/libtests/rtmonuse/.cvsignore (added) * testsuites/libtests/stackchk/.cvsignore (added) * testsuites/libtests/termios/.cvsignore (added) * testsuites/mptests/.cvsignore (added) * testsuites/mptests/mp01/.cvsignore (added) * testsuites/mptests/mp01/node1/.cvsignore (added) * testsuites/mptests/mp01/node2/.cvsignore (added) * testsuites/mptests/mp02/.cvsignore (added) * testsuites/mptests/mp02/node1/.cvsignore (added) * testsuites/mptests/mp02/node2/.cvsignore (added) * testsuites/mptests/mp03/.cvsignore (added) * testsuites/mptests/mp03/node1/.cvsignore (added) * testsuites/mptests/mp03/node2/.cvsignore (added) * testsuites/mptests/mp04/.cvsignore (added) * testsuites/mptests/mp04/node1/.cvsignore (added) * testsuites/mptests/mp04/node2/.cvsignore (added) * testsuites/mptests/mp05/.cvsignore (added) * testsuites/mptests/mp05/node1/.cvsignore (added) * testsuites/mptests/mp05/node2/.cvsignore (added) * testsuites/mptests/mp06/.cvsignore (added) * testsuites/mptests/mp06/node1/.cvsignore (added) * testsuites/mptests/mp06/node2/.cvsignore (added) * testsuites/mptests/mp07/.cvsignore (added) * testsuites/mptests/mp07/node1/.cvsignore (added) * testsuites/mptests/mp07/node2/.cvsignore (added) * testsuites/mptests/mp08/.cvsignore (added) * testsuites/mptests/mp08/node1/.cvsignore (added) * testsuites/mptests/mp08/node2/.cvsignore (added) * testsuites/mptests/mp09/.cvsignore (added) * testsuites/mptests/mp09/node1/.cvsignore (added) * testsuites/mptests/mp09/node2/.cvsignore (added) * testsuites/mptests/mp10/.cvsignore (added) * testsuites/mptests/mp10/node1/.cvsignore (added) * testsuites/mptests/mp10/node2/.cvsignore (added) * testsuites/mptests/mp11/.cvsignore (added) * testsuites/mptests/mp11/node1/.cvsignore (added) * testsuites/mptests/mp11/node2/.cvsignore (added) * testsuites/mptests/mp12/.cvsignore (added) * testsuites/mptests/mp12/node1/.cvsignore (added) * testsuites/mptests/mp12/node2/.cvsignore (added) * testsuites/mptests/mp13/.cvsignore (added) * testsuites/mptests/mp13/node1/.cvsignore (added) * testsuites/mptests/mp13/node2/.cvsignore (added) * testsuites/mptests/mp14/.cvsignore (added) * testsuites/mptests/mp14/node1/.cvsignore (added) * testsuites/mptests/mp14/node2/.cvsignore (added) * testsuites/psxtests/.cvsignore (added) * testsuites/psxtests/include/.cvsignore (added) * testsuites/psxtests/psx01/.cvsignore (added) * testsuites/psxtests/psx02/.cvsignore (added) * testsuites/psxtests/psx03/.cvsignore (added) * testsuites/psxtests/psx04/.cvsignore (added) * testsuites/psxtests/psx05/.cvsignore (added) * testsuites/psxtests/psx06/.cvsignore (added) * testsuites/psxtests/psx07/.cvsignore (added) * testsuites/psxtests/psx08/.cvsignore (added) * testsuites/psxtests/psx09/.cvsignore (added) * testsuites/psxtests/psx10/.cvsignore (added) * testsuites/psxtests/psx11/.cvsignore (added) * testsuites/psxtests/psx12/.cvsignore (added) * testsuites/psxtests/psx13/.cvsignore (added) * testsuites/psxtests/psxcancel/.cvsignore (added) * testsuites/psxtests/psxfile01/.cvsignore (added) * testsuites/psxtests/psxhdrs/.cvsignore (added) * testsuites/psxtests/psxmount/.cvsignore (added) * testsuites/psxtests/psxmsgq01/.cvsignore (added) * testsuites/psxtests/psxreaddir/.cvsignore (added) * testsuites/psxtests/psxsem01/.cvsignore (added) * testsuites/psxtests/psxstat/.cvsignore (added) * testsuites/psxtests/psxtime/.cvsignore (added) * testsuites/psxtests/psxtimer/.cvsignore (added) * testsuites/samples/.cvsignore (added) * testsuites/samples/base_mp/.cvsignore (added) * testsuites/samples/base_mp/node1/.cvsignore (added) * testsuites/samples/base_mp/node2/.cvsignore (added) * testsuites/samples/base_sp/.cvsignore (added) * testsuites/samples/cdtest/.cvsignore (added) * testsuites/samples/hello/.cvsignore (added) * testsuites/samples/minimum/.cvsignore (added) * testsuites/samples/paranoia/.cvsignore (added) * testsuites/samples/ticker/.cvsignore (added) * testsuites/samples/unlimited/.cvsignore (added) * testsuites/sptests/.cvsignore (added) * testsuites/sptests/sp01/.cvsignore (added) * testsuites/sptests/sp02/.cvsignore (added) * testsuites/sptests/sp03/.cvsignore (added) * testsuites/sptests/sp04/.cvsignore (added) * testsuites/sptests/sp05/.cvsignore (added) * testsuites/sptests/sp06/.cvsignore (added) * testsuites/sptests/sp07/.cvsignore (added) * testsuites/sptests/sp08/.cvsignore (added) * testsuites/sptests/sp09/.cvsignore (added) * testsuites/sptests/sp11/.cvsignore (added) * testsuites/sptests/sp12/.cvsignore (added) * testsuites/sptests/sp13/.cvsignore (added) * testsuites/sptests/sp14/.cvsignore (added) * testsuites/sptests/sp15/.cvsignore (added) * testsuites/sptests/sp16/.cvsignore (added) * testsuites/sptests/sp17/.cvsignore (added) * testsuites/sptests/sp19/.cvsignore (added) * testsuites/sptests/sp20/.cvsignore (added) * testsuites/sptests/sp21/.cvsignore (added) * testsuites/sptests/sp22/.cvsignore (added) * testsuites/sptests/sp23/.cvsignore (added) * testsuites/sptests/sp24/.cvsignore (added) * testsuites/sptests/sp25/.cvsignore (added) * testsuites/sptests/sp26/.cvsignore (added) * testsuites/sptests/sp27/.cvsignore (added) * testsuites/sptests/sp28/.cvsignore (added) * testsuites/sptests/sp29/.cvsignore (added) * testsuites/sptests/spfatal/.cvsignore (added) * testsuites/sptests/spsize/.cvsignore (added) * testsuites/support/.cvsignore (added) * testsuites/support/include/.cvsignore (added) * testsuites/tmitrontests/.cvsignore (added) * testsuites/tmitrontests/include/.cvsignore (added) * testsuites/tmitrontests/tmitronsem01/.cvsignore (added) * testsuites/tmtests/.cvsignore (added) * testsuites/tmtests/include/.cvsignore (added) * testsuites/tmtests/tm01/.cvsignore (added) * testsuites/tmtests/tm02/.cvsignore (added) * testsuites/tmtests/tm03/.cvsignore (added) * testsuites/tmtests/tm04/.cvsignore (added) * testsuites/tmtests/tm05/.cvsignore (added) * testsuites/tmtests/tm06/.cvsignore (added) * testsuites/tmtests/tm07/.cvsignore (added) * testsuites/tmtests/tm08/.cvsignore (added) * testsuites/tmtests/tm09/.cvsignore (added) * testsuites/tmtests/tm10/.cvsignore (added) * testsuites/tmtests/tm11/.cvsignore (added) * testsuites/tmtests/tm12/.cvsignore (added) * testsuites/tmtests/tm13/.cvsignore (added) * testsuites/tmtests/tm14/.cvsignore (added) * testsuites/tmtests/tm15/.cvsignore (added) * testsuites/tmtests/tm16/.cvsignore (added) * testsuites/tmtests/tm17/.cvsignore (added) * testsuites/tmtests/tm18/.cvsignore (added) * testsuites/tmtests/tm19/.cvsignore (added) * testsuites/tmtests/tm20/.cvsignore (added) * testsuites/tmtests/tm21/.cvsignore (added) * testsuites/tmtests/tm22/.cvsignore (added) * testsuites/tmtests/tm23/.cvsignore (added) * testsuites/tmtests/tm24/.cvsignore (added) * testsuites/tmtests/tm25/.cvsignore (added) * testsuites/tmtests/tm26/.cvsignore (added) * testsuites/tmtests/tm27/.cvsignore (added) * testsuites/tmtests/tm28/.cvsignore (added) * testsuites/tmtests/tm29/.cvsignore (added) * testsuites/tmtests/tmck/.cvsignore (added) * testsuites/tmtests/tmoverhd/.cvsignore (added) * testsuites/tools/.cvsignore (added) * testsuites/tools/generic/.cvsignore (added) * tools/.cvsignore (added) * tools/build/.cvsignore (added) * tools/cpu/.cvsignore (added) * tools/cpu/generic/.cvsignore (added) * tools/cpu/hppa1.1/.cvsignore (added) * tools/cpu/sh/.cvsignore (added) * tools/cpu/unix/.cvsignore (added) * tools/update/.cvsignore (added) Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius [4e36a2f] * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/librpc/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/mips/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/shared/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/console/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/include/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/liblnk/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/start/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/startup/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/wrapup/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (added) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/configure.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (added) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (added) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/sh/shared/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (added) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (added) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (deleted) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips/clock/Makefile.am (modified) * c/src/lib/libcpu/mips/timer/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/librpc/src/Makefile.am (modified) * cpukit/libmisc/dummy/Makefile.am (modified) * cpukit/libmisc/dumpbuf/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/librpc/src/Makefile.am (modified) * cpukit/score/cpu/a29k/Makefile.am (modified) * cpukit/score/cpu/hppa1.1/Makefile.am (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips64orion/Makefile.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/score/src/Makefile.am (modified) Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from ... Tue, 23 Nov 1999 14:10:05 GMT Joel Sherrill [23e3f642] * automake/lib.am (added) * c/src/exec/librpc/src/Makefile.am (added) * c/src/librdbg/src/i386/any/Makefile.am (added) * c/src/librdbg/src/i386/pc386/Makefile.am (added) * c/src/librpc/src/Makefile.am (added) * c/src/librtems++/src/Makefile.am (added) * c/src/tests/samples/sample.am (added) * c/src/tests/sptests/spsize/size.scn (added) * c/src/tests/tmtests/tmtests.am (added) * c/src/wrapup/Makefile.am (added) * cpukit/librpc/src/Makefile.am (added) * testsuites/samples/sample.am (added) * testsuites/sptests/spsize/size.scn (added) * testsuites/tmtests/tmtests.am (added) Missed in previous automake conversion patches from Ralf Corsepius ...
