Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit/libnetworking
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @ec0a346   03/11/03 11:47:17 Ralf Corsepius Merger from rtems-4-6-branch. 4.104.114.84.95
(edit) @7ac73e6   02/20/03 21:21:28 Joel Sherrill 2003-02-20 Till Straumann <strauman@…> PR … 4.104.114.84.95
(edit) @83e36d6b   02/11/03 22:58:08 Joel Sherrill 2003-02-11 Mike Siers <mikes@…> * rtems/rtems_glue.c: A … 4.104.114.84.95
(edit) @ccd81b60   02/11/03 11:47:49 Ralf Corsepius 2003-02-11 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @9b5c258   02/11/03 11:11:33 Ralf Corsepius 2003-02-11 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @8d3e9254   02/06/03 17:14:29 Joel Sherrill 2003-02-06 Mike Siers <mikes@…> PR 342/networking * … 4.104.114.84.95
(edit) @9da12bd   02/05/03 21:25:55 Joel Sherrill 2003-02-05 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
(edit) @450a06c   01/28/03 14:16:25 Joel Sherrill 2003-01-28 Joel Sherrill <joel@…> * Makefile.am: Add … 4.104.114.84.95
(edit) @9d647dfc   01/27/03 16:20:14 Joel Sherrill 2003-01-27 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @d6c3d56   01/15/03 10:51:32 Ralf Corsepius 2003-01-15 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @6bd96fc7   01/03/03 20:40:29 Joel Sherrill 2003-01-03 Jitendra Vegiraju <jvegiraju@…> * sys/queue.h: … 4.104.114.84.95
(edit) @36799d4   01/03/03 18:09:57 Joel Sherrill 2002-11-26 Chris Johns <cjohns@…> * Makefile.am: Added … 4.104.114.84.95
(edit) @b6e283de   12/19/02 03:47:16 WENorum Include netinet sources. 4.104.114.84.95
(edit) @dd695d81   12/12/02 12:15:00 Ralf Corsepius 2002-12-12 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @a3dfa39   12/11/02 15:34:58 Ralf Corsepius 2002-12-11 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @47c0220   11/19/02 22:23:50 Ralf Corsepius 2002-11-19 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @9eadce0   11/18/02 02:21:19 Ralf Corsepius 2002-11-18 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @471bcf0   11/15/02 14:55:12 Ralf Corsepius 2002-11-15 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @658ad56f   11/10/02 07:12:46 Chris Johns 2002-11-06 Chris Johns <ccj@…> * sys/select.h: Add C++ … 4.104.114.84.95
(edit) @8d3eba16   11/09/02 04:37:33 Chris Johns Need to be extern C for use by C++. 4.104.114.84.95
(edit) @76b6085f   11/02/02 16:27:43 Ralf Corsepius 2002-11-02 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @b31106f6   11/01/02 22:26:02 Joel Sherrill 2002-11-01 Joel Sherrill <joel@…> * ChangeLog?: Corrected. 4.104.114.84.95
(edit) @ce452f7   11/01/02 18:43:57 WENorum * empty log message * 4.104.114.84.95
(edit) @022fcc07   11/01/02 18:43:09 WENorum Till Straumann's patch to: use bootp option 129 to get command line … 4.104.114.84.95
(edit) @0647cc7   10/31/02 20:10:40 Joel Sherrill 2002-10-31 Joel Sherrill <joel@…> * libc/rcmd.c, … 4.104.114.84.95
(edit) @abef0f6   10/28/02 13:56:01 Joel Sherrill 2002-10-28 Joel Sherrill <joel@…> * Pass to eliminate … 4.104.114.84.95
(edit) @56a1ae36   10/25/02 06:18:56 Ralf Corsepius 2002-10-25 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @fa87598   10/25/02 04:36:19 Ralf Corsepius 2002-10-25 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @f8cb04a5   10/21/02 12:04:36 Ralf Corsepius 2002-10-21 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @7b93cedc   10/13/02 21:47:29 Ralf Corsepius 2002-10-13 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @a63efae   10/07/02 17:11:27 Joel Sherrill 2002-10-07 Eric Norum <eric.norum@…> * netinet/tcp_var.h: … 4.104.114.84.95
(edit) @3fb76805   10/04/02 14:47:11 Joel Sherrill 2002-10-04 Jay Monkman <jtm@…> * … 4.104.114.84.95
(edit) @ed15301c   10/04/02 13:25:31 Joel Sherrill 2002-10-04 Jay Monkman <jtm@…> * … 4.104.114.84.95
(edit) @6ca248c   10/02/02 17:35:29 Joel Sherrill 2002-10-02 Joel Sherrill <joel@…> * kern/uipc_socket.c: … 4.104.114.84.95
(edit) @bcac0cb   10/02/02 17:34:28 Joel Sherrill 2002-10-02 Eric Norum <eric.norum@…> * rtems/mkrootfs.c: As … 4.104.114.84.95
(edit) @f4ceef3e   09/16/02 11:55:43 Joel Sherrill 2002-09-16 Joel Sherrill <joel@…> * netinet/Makefile.am, … 4.104.114.84.95
(edit) @144b94f   09/14/02 18:31:06 Joel Sherrill 2002-09-14 Joel Sherrill <joel@…> * kern/uipc_socket.c: … 4.104.114.84.95
(edit) @ce2c216   09/14/02 18:18:50 Joel Sherrill 2002-09-14 Vyacheslav V. Burdjanadze <wr@…> * … 4.104.114.84.95
(edit) @6a2d7ee   09/02/02 06:26:03 Ralf Corsepius 2002-09-02 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @845f170a   08/20/02 15:53:52 Joel Sherrill 2002-08-20 Eric Norum <eric.norum@…> * rtems/rtems_glue.c: … 4.104.114.84.95
(edit) @68a368fc   08/09/02 12:45:10 Joel Sherrill 2002-08-09 Joel Sherrill <joel@…> * libc/getservent.c: Per … 4.104.114.84.95
(edit) @7a47bb5   08/07/02 15:37:33 Joel Sherrill 2002-08-07 Joel Sherrill <joel@…> * netinet/in.h: Per … 4.104.114.84.95
(edit) @d9ab6d3   08/02/02 00:48:03 Joel Sherrill 2002-08-01 Joel Sherrill <joel@…> * machine/param.h, … 4.104.114.84.95
(edit) @18dce91   08/01/02 16:15:37 Ralf Corsepius 2002-08-01 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @08943ebf   07/30/02 23:32:15 Joel Sherrill 2002-07-30 Joel Sherrill <joel@…> * sys/param.h: Removed … 4.104.114.84.95
(edit) @9fcd1a1c   07/30/02 23:31:00 Joel Sherrill 2002-07-30 Joel Sherrill <joel@…> * machine/types.h: … 4.104.114.84.95
(edit) @6fd2516   07/30/02 14:33:24 Joel Sherrill 2002-07-30 Jay Monkman <jtm@…> * … 4.104.114.84.95
(edit) @7b43151   07/24/02 13:25:50 Joel Sherrill 2002-07-24 Joel Sherrill <joel@…> * sys/select.h: Add a … 4.104.114.84.95
(edit) @ce75da6   07/24/02 13:25:06 Joel Sherrill 2002-07-24 Joel Sherrill <joel@…> * Makefile.am, … 4.104.114.84.95
(edit) @0e1dd41f   07/22/02 13:44:48 Ralf Corsepius 2002-07-22 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @eb4b28d   07/22/02 06:35:33 Ralf Corsepius 2002-07-22 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @74c402a2   07/17/02 17:08:48 Joel Sherrill 2002-07-17 Jay Monkman <jtm@…> * netinet/in.h, … 4.104.114.84.95
(edit) @705a0701   07/05/02 15:55:09 Ralf Corsepius 2002-07-05 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @8c746fe   07/01/02 09:59:55 Ralf Corsepius 2002-07-01 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @dda0bffc   06/27/02 21:59:23 Joel Sherrill 2002-06-27 Thomas Doerfler <Thomas.Doerfler@…> * … 4.104.114.84.95
(edit) @da8f88a   06/27/02 04:00:20 Ralf Corsepius 2002-06-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @89e6498   06/26/02 15:46:38 Ralf Corsepius 2002-06-26 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @75fb648b   06/18/02 12:33:23 Ralf Corsepius 2002-06-18 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @f22ebf0   06/17/02 09:12:00 Ralf Corsepius 2002-06-17 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @bfd1a53a   06/15/02 07:14:44 Ralf Corsepius 2002-06-02 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @158e2d7   05/30/02 12:25:38 Joel Sherrill 2002-05-30 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @8a79786   05/29/02 17:00:59 Joel Sherrill 2002-05-29 Ralf Corsepius <corsepiu@…> Relocate … 4.104.114.84.95
(edit) @e3eab02   05/28/02 16:20:54 Joel Sherrill 2002-05-18 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @c1f3fc04   05/17/02 18:28:26 Joel Sherrill 2002-05-16 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @c7286d94   05/14/02 18:02:47 Joel Sherrill 2002-05-14 Ralf Corsepius <corsepiu@…> * sys/ioctl.h: … 4.104.114.84.95
(edit) @06549dcf   05/14/02 17:35:55 Joel Sherrill 2001-05-14 Joel Sherrill <joel@…> * ChangeLog?: Corrected … 4.104.114.84.95
(edit) @1065f16   05/14/02 17:35:16 Joel Sherrill 2001-05-14 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @3ce2907   05/14/02 17:08:25 Joel Sherrill 2001-05-14 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @51b39864   05/01/02 23:09:37 Joel Sherrill 2002-05-01 Eric Norum <eric.norum@…> * machine/in_cksum.h: … 4.104.114.84.95
(edit) @d50c0d2   04/26/02 21:34:58 Joel Sherrill 2002-04-26 Eric Norum <eric.norum@…> * … 4.104.114.84.95
(edit) @a81a8f8   04/18/02 22:24:04 Joel Sherrill 2002-04-18 Ralf Corsepius <corsepiu@…> * pppd/utils.c: … 4.104.114.84.95
(edit) @5bfc8912   04/13/02 16:41:43 Joel Sherrill 2002-04-11 Chris Johns <ccj@…> * … 4.104.114.84.95
(edit) @25b4446   04/08/02 18:27:31 Joel Sherrill 2002-04-06 Ralf Corsepius <corsepiu@…> * ChangeLog?: Fix … 4.104.114.84.95
(edit) @51301198   04/01/02 13:27:46 Joel Sherrill 2002-03-30 Ralf Corsepius <corsepiu@…> * libc/rcmd.c: … 4.104.114.84.95
(edit) @01d48bf8   03/28/02 00:49:43 Joel Sherrill 2002-03-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @9b02fa65   03/27/02 14:44:55 Joel Sherrill 2002-03-27 Thomas.Doerfler@… * PR144 * … 4.104.114.84.95
(edit) @f4c118d   03/27/02 14:36:07 Joel Sherrill 2002-03-27 Ilya Alexeev <ilya@…> * PR162 * … 4.104.114.84.95
(edit) @fd55b7d   03/21/02 15:01:32 Joel Sherrill 2002-03-21 Ilya Alexeev <ilya@…> * … 4.104.114.84.95
(edit) @d7478774   03/20/02 22:08:06 Joel Sherrill 2001-03-20 Till Straumann <strauman@…> * PR158 * … 4.104.114.84.95
(edit) @cb1e8a46   02/27/02 22:43:31 Joel Sherrill 2002-02-27 Ilya Alexeev <ilya@…> * net/if_ppp.c, … 4.104.114.84.95
(edit) @c52f1c7   02/27/02 22:39:18 Joel Sherrill 2002-02-27 Eric Norum <eric.norum@…> * net/radix.c: Properly … 4.104.114.84.95
(edit) @8e3caa5   02/01/02 16:51:07 Joel Sherrill 2001-02-01 Mike Siers <mikes@…> * pppd/rtemspppd.c … 4.104.114.84.95
(edit) @485ed5cc   02/01/02 14:04:45 Joel Sherrill 2001-01-31 Mike Siers <mikes@…> * pppd/rtemsdialer.h: New … 4.104.114.84.95
(edit) @0286b9f   01/31/02 21:42:11 Joel Sherrill 2001-01-31 Mike Siers <mikes@…> * Nice Update of PPPD … 4.104.114.84.95
(edit) @c8f05db   01/22/02 17:36:23 Joel Sherrill 2002-01-21 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @cf42e735   01/16/02 22:50:04 Joel Sherrill 2001-01-16 Eric Norum <eric.norum@…> * … 4.104.114.84.95
(edit) @ab1ed86   01/06/02 20:09:55 Joel Sherrill 2002-02-05 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @d4651e4   01/04/02 18:25:27 Joel Sherrill 2002-02-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @2539cdc   12/19/01 18:11:07 Joel Sherrill 2001-12-18 Eric Norum <eric.norum@…> * lib/tftpDriver.c: … 4.104.114.84.95
(edit) @86d9ca2   12/07/01 12:59:12 Joel Sherrill 2001-12-07 Eric Norum <eric.norum@…> * lib/tftpDriver.c: … 4.104.114.84.95
(edit) @4efd0f66   11/26/01 14:34:00 Joel Sherrill 2001-11-26 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @dfe5a4e3   10/18/01 18:48:55 Joel Sherrill 2001-10-18 Eric Norum <eric.norum@…> * lib/tftpDriver.c: … 4.104.114.84.95
(edit) @cc13fa3   10/12/01 21:03:15 Joel Sherrill 2001-10-12 Joel Sherrill <joel@…> * rootfs/mkrootfs.c, … 4.104.114.84.95
(edit) @d7aecdc   10/12/01 18:47:00 Joel Sherrill 2001-10-11 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @aee474b   10/12/01 13:43:05 Joel Sherrill 2001-10-12 Mike Siers <mikes@…> * Update to stable working … 4.104.114.84.95
(edit) @df25c998   10/11/01 19:36:23 Joel Sherrill 2001-10-11 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @1ef8e3d4   09/27/01 13:31:56 Joel Sherrill 2001-09-27 Eric Norum <eric.norum@…> * lib/tftpDriver.c: Add … 4.104.114.84.95
(edit) @b68e01c5   09/27/01 13:28:22 Joel Sherrill 2001-09-23 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @0d30932   09/24/01 18:29:46 Joel Sherrill 2001-09-22 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @5400f07   09/19/01 17:40:37 Joel Sherrill 2001-09-19 Eric Norum <eric.norum@…> * lib/tftpDriver.c: Add … 4.104.114.84.95
