@c8cd4ff
01/23/15 11:56:53 |
Sebastian Huber |
libnetworking: Fix memset() call
Close #2244.
4.115
@c625a641
12/21/14 19:12:28 |
Sebastian Huber |
Filesystem: Delete node type operation
Use the fstat handler instead.
4.115
@f87ede5
01/15/15 13:13:19 |
Sebastian Huber |
libnetworking: Fix close of active sockets
Send a special event to …
4.115
@51c88e8b
01/16/15 08:08:23 |
Sebastian Huber |
libnetworking: Delete dead code
The so_uid is always 0 in RTEMS.
4.115
@f2f39f3c
01/16/15 08:05:15 |
Sebastian Huber |
libnetworking: Avoid spurious event delivery
The so_pgid field …
4.115
@ac6e8c4
01/15/15 10:30:13 |
Sebastian Huber |
libnetworking: Simplify sbwait()
4.115
@da10694
12/24/14 03:14:50 |
dufault |
libnetworking: Make rtems_dhcp_failsafe() run time configurable
4.115
@69e3f27
11/14/14 07:58:00 |
cederman |
net: Add network task affinity config
This patch adds a default …
4.115
@7ae1c30
10/31/14 05:20:02 |
Chris Johns |
libnetworking: Fix the sethostname decl to match newlib.
4.115
@3e1bf78
10/08/14 09:43:10 |
Sebastian Huber |
ppp: PR1943: Avoid NULL pointer access
Waiting for mbufs at this …
4.115
@044cf4d7
10/08/14 06:11:28 |
Sebastian Huber |
ppp: Add ppp_unit()
This makes porting to the new network stack easier.
4.115
@77dd9a4
10/07/14 14:25:43 |
Sebastian Huber |
ppp: Nothing to transmit hint for Termios driver
4.115
@7fd5e89
10/07/14 14:28:04 |
Sebastian Huber |
termios: Partially hide rtems_termios_tty
Move interrupt lock to …
4.115
@805360b
09/23/14 12:20:35 |
Sebastian Huber |
pppd: Fix warnings
4.115
@33739be
09/30/14 09:25:57 |
Sebastian Huber |
libnetworking: Update due to Termios changes
4.115
@5787188
08/20/14 23:47:02 |
Joel Sherrill |
Add configuration to detect toolset has sigaltstack() prototype
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@a418b2f
03/03/14 07:38:10 |
Sebastian Huber |
libnetworking: Typo
4.115
@a32f996b
01/20/14 02:00:35 |
Nick Withers |
Don't use unsafe buffer operations
Don't use unsafe buffer …
4.115
@2b03a62
11/01/13 13:59:41 |
Jim Panetta |
NTP: Sync time correctly when receiving broadcast updates
1) The …
4.115
@56bea43
12/16/13 13:26:29 |
Sebastian Huber |
Filesystem: Use default kqfilter and poll handler
4.115
@2f68778
12/16/13 12:44:13 |
Sebastian Huber |
Filesystem: Add readv/writev handlers
The readv() and writev() …
4.115
@663ffd0e
12/10/13 01:37:05 |
Chris Johns |
PR2161: Set the source port to SYSLOG in the syslog socket.
4.115
@14876018
11/21/13 00:24:48 |
Daniel Ramirez |
select.h, rtems_select.c, nds select: Add restrict keyword
4.115
@ae75429
08/06/13 14:10:26 |
Sebastian Huber |
PR766: Delete RTEMS_VIOLATE_KERNEL_VISIBILITY
4.115
@88c74ab
07/25/13 13:10:11 |
Sebastian Huber |
score: Merge tod implementation into one file
Delete …
4.115
@f6f4943
07/22/13 15:26:23 |
Sebastian Huber |
network: SMP support for network semaphore
4.115
@ca1d84e
07/18/13 13:33:28 |
Sebastian Huber |
network: Include missing header file
4.115
@95e09afa
07/17/13 13:53:17 |
Sebastian Huber |
score: Avoid direct usage of _Thread_Executing
Pass the executing …
4.115
@20e239c2
07/17/13 12:23:14 |
Sebastian Huber |
score: Create mutex implementation header
Move implementation …
4.115
@2bbea657
07/17/13 11:52:00 |
Sebastian Huber |
rtems: Create semaphore implementation header
4.115
@6520aef1
06/20/13 15:52:16 |
Joel Sherrill |
sparc in_cksum: Use sparc which is available in -ansi mode
4.115
@1f4ee30
06/15/13 22:13:41 |
Jiri Gaisler |
Added in_cksum_sparc.h to optimize IP checksum calculations for SPARC.
4.115
@d8e44ec
02/05/13 17:03:30 |
hill |
nios2: Add optimized IP checksum support
4.115
@b63c8f9
01/28/13 09:23:28 |
Sebastian Huber |
ftpfs: Fix SIZE command handling
It is invalid to issue a SIZE …
4.115
@bb679b3
01/23/13 19:09:18 |
Joel Sherrill |
Move <memory.h> and <sys/uio.h> to non-networking directory
These two …
4.115
@b697bc6
01/10/13 21:06:42 |
Joel Sherrill |
cpukit: Use Consistent Beginning of Doxygen Group Notation
This is …
4.115
@3cf4031
12/28/12 23:48:12 |
alexivanov97 |
Header File Doxygen Enhancement Task #1
4.115
@1edaa5f
12/14/12 11:01:47 |
Sebastian Huber |
libnetworking: Make functions public
Make functions …
4.115
@82eb2c4
11/22/12 13:08:38 |
Sebastian Huber |
ftpfs: Fix NULL pointer access
4.115
@fe0f24e
11/21/12 14:27:43 |
Sebastian Huber |
ftpfs: Use SIZE command
4.115
@ad5e070
11/21/12 14:47:46 |
Sebastian Huber |
ftpfs: Open control connection during path eval
4.115
@be6f505
11/21/12 11:20:14 |
Sebastian Huber |
ftpfs: Format
4.115
@3fbcadf
11/16/12 13:17:31 |
Sebastian Huber |
libnetworking: Use rtems_clock_get_uptime_seconds
This reduces the …
4.115
@94eb1bb
11/16/12 13:16:03 |
Sebastian Huber |
libnetworking: Use rtems_clock_get_uptime_timeval
4.115
@8cbd90c
11/02/12 13:45:50 |
Sebastian Huber |
libnetworking: Disconnect after mbuf shortage
The missing disconnect …
4.115
@b3cee28a
11/02/12 10:46:08 |
Sebastian Huber |
libnetworking: Avoid deadlock during starvation
4.115
@26e90fb1
10/30/12 16:42:17 |
Sebastian Huber |
libnetworking: Use system events
Add reserved system events …
4.115
@38feeefd
07/17/12 12:22:12 |
Sebastian Huber |
libnetworking: Silence set but not used warnings
4.115
@6c18c97
05/22/12 10:06:20 |
Sebastien Bourdeauducq |
network/bootp: PR2031: Add and use header file
4.115
@7aba2ea
05/22/12 09:20:07 |
network/dhcp: PR1841: Fix DNS processing in DHCP
4.115
@0a95800a
05/15/12 08:27:46 |
Sebastian Huber |
Filesystem: Change pathconf_limits_and_options
The …
4.115
@da154e14
05/14/12 14:55:41 |
Sebastian Huber |
Filesystem: Move operations to mount table entry
The scope of the …
4.115
@df01da67
05/14/12 11:16:31 |
Sebastian Huber |
Filesystem: Use ioctl_command_t
4.115
@65c6425
05/03/12 17:24:46 |
Joel Sherrill |
Remove CVS Id Strings (manual edits after script)
These modifications …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@33a105fb
05/07/12 16:08:48 |
Joel Sherrill |
Revert: Remove CVS Ids
See …
4.115
@ee32f67a
05/04/12 06:55:28 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@58f6655
04/03/12 14:15:34 |
Sebastian Huber |
networking: socket to/from file descriptor
o Move …
4.115
@2563410
03/13/12 08:22:11 |
Sebastian Huber |
Filesystem: Rename defines
o Removed RTEMS_LIBIO_PERMS_SEARCH.
o …
4.115
@4116fce6
02/24/12 16:39:27 |
Sebastian Huber |
Filesystem: New defaults fsync_h and fdatasync_h
New defaults …
4.115
@3b7c123
03/13/12 10:33:51 |
Sebastian Huber |
Filesystem: Reference counting for locations
o A new data structure …
4.115
@7f2036aa
03/02/12 12:01:07 |
Ralf Corsepius |
2012-03-02 Ralf Corsépius <ralf.corsepius@…>
4.115
@396b80e
03/02/12 08:31:38 |
Ralf Corsepius |
* configure.ac: …
4.115
@f14327a2
02/15/12 08:59:55 |
Sebastian Huber |
Fixed incorrect error path
The inet_aton() function returns non-zero …
4.115
@8c85ca3
02/14/12 15:46:04 |
Sebastian Huber |
Avoid buffer overflow and misaligned memory access
4.115
@1052242
02/02/12 14:45:16 |
Sebastian Huber |
Removed fpathconf file system node handler.
There existed no calling …
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@56059905
12/08/11 05:09:04 |
Ralf Corsepius |
2011-12-08 Ralf Corsépius <ralf.corsepius@…>
4.115
@a1399ba
12/07/11 06:49:32 |
Ralf Corsepius |
2011-12-07 Ralf Corsépius <ralf.corsepius@…>
PR …
4.115
@5876a99
12/07/11 06:46:19 |
Ralf Corsepius |
4.115
@ce373088
12/07/11 05:19:07 |
Ralf Corsepius |
4.115
@a7fa55ca
12/01/11 08:26:49 |
Ralf Corsepius |
2011-12-01 Ralf Corsépius <ralf.corsepius@…>
4.115
@4aa59b1
11/30/11 05:30:49 |
Ralf Corsepius |
2011-11-30 Ralf Corsépius <ralf.corsepius@…>
4.115
@984c4c49
11/06/11 12:00:04 |
Ralf Corsepius |
2011-11-06 Ralf Corsépius <ralf.corsepius@…>
4.115
@9356119
10/20/11 13:54:45 |
Ralf Corsepius |
2011-10-20 Ralf Corsépius <ralf.corsepius@…>
4.115
@9c337c6
10/20/11 10:52:59 |
Ralf Corsepius |
4.115
@7c770856
10/18/11 09:01:23 |
Ralf Corsepius |
2011-10-18 Ralf Corsépius <ralf.corsepius@…>
4.115
@75e454c0
10/02/11 05:23:46 |
Ralf Corsepius |
2011-10-02 Ralf Corsépius <ralf.corsepius@…>
4.115
@add4f336
07/21/11 15:35:13 |
Sebastian Huber |
2011-07-21 Sebastian Huber <sebastian.huber@…>
4.115
@8f6ef478
07/18/11 15:25:33 |
Sebastian Huber |
2011-07-18 Sebastian Huber <sebastian.huber@…>
4.115
@067489b
07/14/11 19:16:09 |
Joel Sherrill |
2011-07-14 Gene Smith <gene.smith@…>
PR 1381/networking
4.115
@9f816ad4
07/07/11 06:55:48 |
Sebastian Huber |
2011-07-08 Sebastian Huber <sebastian.huber@…>
4.115
@21242c2
06/24/11 17:52:58 |
Joel Sherrill |
2011-06-24 Joel Sherrill <joel.sherrill@…>
4.115
@f73cdd5b
05/18/11 05:13:07 |
Ralf Corsepius |
2011-05-18 Ralf Corsépius <ralf.corsepius@…>
4.115
@77dc5a2
05/17/11 14:30:34 |
Ralf Corsepius |
2011-05-16 Ralf Corsépius <ralf.corsepius@…>
4.115
@7d2e930
05/16/11 14:31:49 |
Ralf Corsepius |
4.115
@f6015bd
05/13/11 15:56:21 |
Ralf Corsepius |
Make self-contained.
4.115
@7e1d1e4
05/12/11 04:10:20 |
Ralf Corsepius |
4.115
@c7d0d86
05/11/11 14:35:03 |
Ralf Corsepius |
4.115
@ee613aa
03/24/11 09:36:14 |
Ralf Corsepius |
Include <sys/cdefs.h> (Eliminate rtems/bsd/sys/cdefs.h).
4.115
@223fd16b
03/24/11 09:28:32 |
Ralf Corsepius |
2011-03-24 Ralf Corsépius <ralf.corsepius@…>
4.115
@ddbfa05
03/02/11 14:39:32 |
Ralf Corsepius |
Use <sys/queue.h> instead of <rtems/bsd/sys/queue.h.
4.115
@3611eba
03/02/11 14:18:27 |
Ralf Corsepius |
4.115
@db4219ea
03/02/11 12:06:46 |
Ralf Corsepius |
4.115
@ebe6edbc
02/25/11 10:38:17 |
Sebastian Huber |
2011-02-25 Sebastian Huber <sebastian.huber@…>
4.115
@ee7f2f7b
02/24/11 14:57:34 |
Ralf Corsepius |
2011-02-24 Ralf Corsépius <ralf.corsepius@…>
4.115
@460674d9
02/24/11 06:48:52 |
Ralf Corsepius |
4.115
@241a4c31
02/23/11 14:38:25 |
Ralf Corsepius |
2011-02-23 Ralf Corsépius <ralf.corsepius@…>
4.115
@546c4737
02/23/11 14:36:05 |
Ralf Corsepius |
4.115
