# # ChangeLog for cpukit/libnetworking in rtems # # Generated by Trac 1.2.1.dev0 # 04/30/24 18:19:15 Fri, 10 Oct 2008 15:56:32 GMT Thomas Doerfler [06c3530] * cpukit/ChangeLog (modified) * cpukit/include/rtems/status-checks.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) libnetworking/rtems/rtems_glue.c: Copy nothing if ... Fri, 26 Sep 2008 15:03:29 GMT Eric Norum [ac337bc] * cpukit/ChangeLog (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) Final resolution of this "small" por t number change. Thu, 25 Sep 2008 19:54:26 GMT Joel Sherrill [0655f79] * cpukit/ChangeLog (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) 2008-09-25 Eric Norum * ... Wed, 24 Sep 2008 08:51:54 GMT Ralf Corsepius [3469329] * cpukit/ChangeLog (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) 2008-09-24 Ralf Corsépius * ... Tue, 23 Sep 2008 15:21:21 GMT Joel Sherrill [dba0264] * cpukit/ChangeLog (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) 2008-09-23 Eric Norum * ... Sun, 07 Sep 2008 15:34:30 GMT Ralf Corsepius [e4c4c42] * cpukit/libnetworking/netinet/in_cksum_arm.h (modified) Stop using old-style function definitions. Thu, 04 Sep 2008 14:20:51 GMT Ralf Corsepius [f002800e] * cpukit/libi2c/libi2c.c (modified) * cpukit/libi2c/libi2c.h (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) Use bool instead of boolean. Mon, 01 Sep 2008 07:02:00 GMT Ralf Corsepius [029c374c] * cpukit/httpd/asp.c (modified) * cpukit/httpd/balloc.c (modified) * cpukit/httpd/default.c (modified) * cpukit/httpd/emfdb.c (modified) * cpukit/httpd/form.c (modified) * cpukit/httpd/handler.c (modified) * cpukit/httpd/md5c.c (modified) * cpukit/httpd/security.c (modified) * cpukit/httpd/sock.c (modified) * cpukit/httpd/socket.c (modified) * cpukit/httpd/sym.c (modified) * cpukit/httpd/uemf.c (modified) * cpukit/httpd/um.c (modified) * cpukit/httpd/webmain.c (modified) * cpukit/httpd/webs.c (modified) * cpukit/httpd/websuemf.c (modified) * cpukit/libnetworking/libc/addr2ascii.c (modified) * cpukit/libnetworking/libc/ascii2addr.c (modified) * cpukit/libnetworking/libc/base64.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getnetbyht.c (modified) * cpukit/libnetworking/libc/getservbyport.c (modified) * cpukit/libnetworking/libc/getservent.c (modified) * cpukit/libnetworking/libc/herror.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/inet_lnaof.c (modified) * cpukit/libnetworking/libc/inet_netof.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/libc/inet_ntoa.c (modified) * cpukit/libnetworking/libc/inet_ntop.c (modified) * cpukit/libnetworking/libc/inet_pton.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/map_v4v6.c (modified) * cpukit/libnetworking/libc/res_comp.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_init.c (modified) * cpukit/libnetworking/libc/res_mkquery.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Stop using old-style function definitions. Mon, 01 Sep 2008 06:36:17 GMT Ralf Corsepius [dd967330] * cpukit/libnetworking/netinet/if_ether.c (modified) * cpukit/libnetworking/netinet/igmp.c (modified) * cpukit/libnetworking/netinet/in.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/ip_icmp.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/netinet/ip_output.c (modified) * cpukit/libnetworking/netinet/raw_ip.c (modified) * cpukit/libnetworking/netinet/tcp_debug.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/netinet/tcp_output.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) * cpukit/libnetworking/netinet/tcp_timer.c (modified) * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) Stop using old-style function definitions. Mon, 01 Sep 2008 06:33:59 GMT Ralf Corsepius [2acc6ee] * cpukit/libnetworking/netinet/tcp_var.h (modified) Fix broken declaration of tcp_trace(). Mon, 01 Sep 2008 06:26:20 GMT Ralf Corsepius [f5a2f211] * cpukit/libnetworking/libc/res_comp.c (modified) * cpukit/libnetworking/netinet/igmp.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_proto.c (modified) * cpukit/libnetworking/netinet/tcp_debug.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/netinet/tcp_output.c (modified) * cpukit/libnetworking/netinet/tcp_timer.c (modified) Remove BSD "Add clause" (From FreeBSD). Mon, 01 Sep 2008 04:56:33 GMT Ralf Corsepius [42e10fa2] * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/libnetworking/net/radix.c (modified) * cpukit/libnetworking/net/raw_cb.c (modified) * cpukit/libnetworking/net/raw_usrreq.c (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/net/rtsock.c (modified) * cpukit/libnetworking/net/slcompress.c (modified) Stop using old-style function definitions. Mon, 01 Sep 2008 03:35:37 GMT Ralf Corsepius [fbf3f98] * cpukit/libnetworking/kern/uipc_domain.c (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) Stop using old-style function definitions. Wed, 27 Aug 2008 11:13:59 GMT Ralf Corsepius [c78ecb0] * cpukit/libnetworking/libc/getproto.c (modified) * cpukit/libnetworking/libc/getprotoent.c (modified) * cpukit/libnetworking/libc/getprotoname.c (modified) * cpukit/libnetworking/libc/getservbyname.c (modified) * cpukit/libnetworking/libc/inet_makeaddr.c (modified) * cpukit/libnetworking/libc/recv.c (modified) * cpukit/libnetworking/libc/send.c (modified) Stop using old-style function-definitions. Tue, 19 Aug 2008 18:47:54 GMT Joel Sherrill [930775d] * cpukit/ChangeLog (modified) * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) 2008-08-19 Joel Sherrill * ... Tue, 19 Aug 2008 06:34:44 GMT Ralf Corsepius [d82bd279] * cpukit/libnetworking/netinet/in_cksum_arm.h (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) Add missing prototypes. Mon, 18 Aug 2008 21:42:41 GMT Joel Sherrill [02aaec7] * cpukit/ChangeLog (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/libc/inet_ntoa.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_malloc_mbuf.c (modified) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (modified) * cpukit/libnetworking/sys/malloc.h (modified) 2008-08-18 Joel Sherrill * ... Mon, 18 Aug 2008 21:16:42 GMT Joel Sherrill [1487880d] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/serdbg/serdbg.c (modified) * cpukit/libmisc/serdbg/serdbg.h (modified) * cpukit/libnetworking/netinet/in_cksum_powerpc.h (modified) * cpukit/shttpd/compat_rtems.h (modified) 2008-08-18 Joel Sherrill * ... Mon, 18 Aug 2008 10:41:13 GMT Ralf Corsepius [bd4a776] * cpukit/ChangeLog (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) 2008-08-18 Ralf Corsepius * ... Mon, 18 Aug 2008 10:39:38 GMT Ralf Corsepius [d95b9e7e] * cpukit/libnetworking/netinet/in_cksum_i386.h (modified) Add missing prototype. Mon, 18 Aug 2008 07:22:23 GMT Ralf Corsepius [142025c] * c/src/lib/libbsp/mips/csb350/timer/timer.c (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/network/elnk.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) Add missing prototypes. Sun, 03 Aug 2008 04:27:50 GMT Ralf Corsepius [b5cc059] * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/pppd/rtemsmain.c (modified) * cpukit/zlib/crc32.c (modified) Add prototypes. Sat, 02 Aug 2008 05:37:10 GMT Ralf Corsepius [082d4a2] * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostbynis.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getnetbydns.c (modified) * cpukit/libnetworking/libc/getnetbynis.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/nsap_addr.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) Add missing prototypes. Fri, 01 Aug 2008 05:07:41 GMT Ralf Corsepius [e386ad72] * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.h (modified) * cpukit/libnetworking/netinet/ip_divert.c (modified) * cpukit/libnetworking/rtems/ftpfs.h (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/libnetworking/rtems/mkrootfs.h (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) Add missing prototypes. Wed, 02 Jul 2008 13:40:19 GMT Joel Sherrill [1fbd0baf] * cpukit/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getservbyname.c (modified) * cpukit/libnetworking/libc/getservbyport.c (modified) 2008-07-02 Joel Sherrill * ... Tue, 27 May 2008 10:33:22 GMT Thomas Doerfler [a184e5e] * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/if_pppvar.h (modified) Bugfix: Moved definition of ppp_softc into source file. Fri, 23 May 2008 21:48:06 GMT Till Straumann [793249a] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/ip_output.c (modified) 2008-05-23 Till Straumann ... Thu, 01 May 2008 02:57:49 GMT Chris Johns [50303df] * cpukit/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/preinstall.am (modified) * cpukit/libnetworking/rtems/dhcp.h (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (added) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.h (added) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2008-05-01 Maarten Van Es * ... Wed, 06 Feb 2008 16:59:31 GMT Joel Sherrill [4273e70] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/in_cksum_i386.h (modified) 2008-02-06 Joel Sherrill ... Tue, 05 Feb 2008 22:29:19 GMT Joel Sherrill [5c62b53] * cpukit/ChangeLog (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2008-02-05 Joel Sherrill * ... Sat, 22 Dec 2007 08:27:18 GMT Chris Johns [1ff9922] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/monitor/mon-network.c (modified) * cpukit/libmisc/shell/err.c (added) * cpukit/libmisc/shell/err.h (added) * cpukit/libmisc/shell/errx.c (added) * cpukit/libmisc/shell/extern-cp.h (added) * cpukit/libmisc/shell/fts.c (added) * cpukit/libmisc/shell/fts.h (added) * cpukit/libmisc/shell/main_cp.c (added) * cpukit/libmisc/shell/main_mount_nfs.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libmisc/shell/shellconfig.h (modified) * cpukit/libmisc/shell/utils-cp.c (added) * cpukit/libmisc/shell/verr.c (added) * cpukit/libmisc/shell/verrx.c (added) * cpukit/libmisc/shell/vwarn.c (added) * cpukit/libmisc/shell/vwarnx.c (added) * cpukit/libmisc/shell/warn.c (added) * cpukit/libmisc/shell/warnx.c (added) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/inline/rtems/score/coremutex.inl (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/telnetd/icmds.c (modified) 2007-12-22 Chris Johns * ... Mon, 17 Dec 2007 00:12:01 GMT Chris Johns [2eeb648c] * cpukit/ChangeLog (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/preinstall.am (modified) * cpukit/libmisc/shell/cat_file.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/main_alias.c (modified) * cpukit/libmisc/shell/main_cat.c (modified) * cpukit/libmisc/shell/main_cd.c (modified) * cpukit/libmisc/shell/main_chdir.c (modified) * cpukit/libmisc/shell/main_chmod.c (modified) * cpukit/libmisc/shell/main_chroot.c (modified) * cpukit/libmisc/shell/main_cpuuse.c (modified) * cpukit/libmisc/shell/main_date.c (modified) * cpukit/libmisc/shell/main_dir.c (modified) * cpukit/libmisc/shell/main_exit.c (modified) * cpukit/libmisc/shell/main_help.c (modified) * cpukit/libmisc/shell/main_id.c (modified) * cpukit/libmisc/shell/main_logoff.c (modified) * cpukit/libmisc/shell/main_ls.c (modified) * cpukit/libmisc/shell/main_mallocdump.c (modified) * cpukit/libmisc/shell/main_mdump.c (modified) * cpukit/libmisc/shell/main_medit.c (modified) * cpukit/libmisc/shell/main_mfill.c (modified) * cpukit/libmisc/shell/main_mkdir.c (modified) * cpukit/libmisc/shell/main_mmove.c (modified) * cpukit/libmisc/shell/main_mount.c (added) * cpukit/libmisc/shell/main_mount_ftp.c (added) * cpukit/libmisc/shell/main_mount_msdos.c (added) * cpukit/libmisc/shell/main_mount_nfs.c (added) * cpukit/libmisc/shell/main_mount_tftp.c (added) * cpukit/libmisc/shell/main_mwdump.c (modified) * cpukit/libmisc/shell/main_pwd.c (modified) * cpukit/libmisc/shell/main_rm.c (modified) * cpukit/libmisc/shell/main_rmdir.c (modified) * cpukit/libmisc/shell/main_stackuse.c (modified) * cpukit/libmisc/shell/main_tty.c (modified) * cpukit/libmisc/shell/main_umask.c (modified) * cpukit/libmisc/shell/main_whoami.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) * cpukit/libmisc/shell/shell_makeargs.c (modified) * cpukit/libmisc/shell/shellconfig.h (modified) * cpukit/libmisc/shell/str2int.c (modified) * cpukit/libmisc/shell/write_file.c (modified) * cpukit/libnetworking/rtems/ftpfs.h (modified) * cpukit/libnetworking/rtems/tftp.h (modified) 2007-12-17 Chris Johns * ... Tue, 27 Nov 2007 15:10:37 GMT Joel Sherrill [cf7ebcf] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) 2007-11-27 Joel Sherrill * ... Sat, 17 Nov 2007 19:38:08 GMT Till Straumann [247f83c] * cpukit/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2007-11-17 Till Straumann ... Mon, 15 Oct 2007 07:59:00 GMT Ralf Corsepius [807337d2] * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/netdb.h (modified) Adjust to POSIX. Minor updates from FreeBSD. Thu, 04 Oct 2007 16:08:35 GMT Ralf Corsepius [9aab34c] * cpukit/libnetworking/preinstall.am (modified) Regenerate. Thu, 04 Oct 2007 16:08:15 GMT Ralf Corsepius [b268e70] * cpukit/libnetworking/Makefile.am (modified) 2007-10-04 Keith Robertson , ... Thu, 04 Oct 2007 14:24:10 GMT Ralf Corsepius [0295725f] * cpukit/libnetworking/net/if.h (modified) Add if_nameindex etc. (from FreeBSD). Thu, 04 Oct 2007 14:23:45 GMT Ralf Corsepius [3d2a28d] * cpukit/libnetworking/ifaddrs.h (added) * cpukit/libnetworking/libc/getifaddrs.c (added) * cpukit/libnetworking/libc/if_indextoname.c (added) * cpukit/libnetworking/libc/if_nameindex.c (added) New (from FreeBSD) Mon, 24 Sep 2007 21:35:10 GMT Joel Sherrill [b5bf8cd1] * cpukit/ChangeLog (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/readv.c (added) * cpukit/libcsupport/src/writev.c (added) * cpukit/libnetworking/libc/herror.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/sys/uio.h (modified) * cpukit/telnetd/Makefile.am (modified) * cpukit/telnetd/README (modified) * cpukit/telnetd/preinstall.am (modified) * cpukit/telnetd/pty.c (modified) * cpukit/telnetd/telnetd.c (modified) 2007-09-24 Joel Sherrill ... Fri, 21 Sep 2007 15:34:10 GMT Joel Sherrill [6f57450] * cpukit/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/rtems/rtems_socketpair.c (added) 2007-09-21 Joel Sherrill * ... Sun, 16 Sep 2007 06:23:26 GMT Ralf Corsepius [e80aa4fa] * cpukit/ChangeLog (modified) * cpukit/libnetworking/net/ppp_defs.h (modified) 2007-09-16 Ralf Corsépius * ... Wed, 01 Aug 2007 00:44:05 GMT Joel Sherrill [51b6226] * cpukit/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2007-07-31 Joel Sherrill ... Mon, 30 Jul 2007 17:14:10 GMT Ralf Corsepius [3a8d083] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.h (modified) 2007-07-30 Ralf Corsépius * ... Thu, 21 Jun 2007 18:31:34 GMT Joel Sherrill [ff089035] * cpukit/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) 2007-06-21 Joel Sherrill * ... Thu, 21 Jun 2007 15:32:37 GMT Joel Sherrill [4ab3a29] * cpukit/ChangeLog (modified) * cpukit/libnetworking/rtems/mkrootfs.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) 2007-06-21 Joel Sherrill * ... Thu, 10 May 2007 07:45:16 GMT Ralf Corsepius [be94ff7] * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Include Thu, 10 May 2007 07:29:14 GMT Ralf Corsepius [cd9564e] * cpukit/include/rtems/bsd/sys/queue.h (modified) * cpukit/libcsupport/include/sys/ioccom.h (modified) * cpukit/libnetworking/arpa/inet.h (modified) * cpukit/libnetworking/arpa/nameser.h (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/res_stubs.c (modified) * cpukit/libnetworking/machine/in_cksum.h (modified) * cpukit/libnetworking/net/ethernet.h (modified) * cpukit/libnetworking/net/if.h (modified) * cpukit/libnetworking/net/if_dl.h (modified) * cpukit/libnetworking/netdb.h (modified) * cpukit/libnetworking/netinet/ip.h (modified) * cpukit/libnetworking/netinet/tcp.h (modified) * cpukit/libnetworking/resolv.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/sys/libkern.h (modified) * cpukit/libnetworking/sys/mount.h (modified) * cpukit/libnetworking/sys/poll.h (modified) * cpukit/libnetworking/sys/socket.h (modified) * cpukit/libnetworking/sys/sysctl.h (modified) * cpukit/libnetworking/sys/syslog.h (modified) * cpukit/libnetworking/sys/uio.h (modified) * cpukit/libnetworking/sys/un.h (modified) * cpukit/librpc/include/rpc/auth.h (modified) * cpukit/librpc/include/rpc/auth_unix.h (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/clnt_soc.h (modified) * cpukit/librpc/include/rpc/pmap_clnt.h (modified) * cpukit/librpc/include/rpc/pmap_prot.h (modified) * cpukit/librpc/include/rpc/pmap_rmt.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/include/rpc/svc_soc.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/include/rpcsvc/ypclnt.h (modified) Include instead of . Thu, 10 May 2007 06:42:09 GMT Ralf Corsepius [03a429ca] * cpukit/libnetworking/preinstall.am (modified) Regenerate. Thu, 10 May 2007 06:40:29 GMT Ralf Corsepius [39350cf] * cpukit/libnetworking/Makefile.am (modified) Reflect having removed sys/queue.h. Thu, 10 May 2007 06:40:07 GMT Ralf Corsepius [2016a986] * cpukit/libnetworking/sys/queue.h (deleted) Remove (moved to include/rtems/bsd/sys/queue.h). Thu, 10 May 2007 05:12:54 GMT Ralf Corsepius [c301570] * cpukit/libnetworking/kern/kern_subr.c (modified) * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/net/if.c (modified) * cpukit/libnetworking/net/raw_cb.c (modified) * cpukit/libnetworking/net/raw_usrreq.c (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/net/rtsock.c (modified) * cpukit/libnetworking/netinet/if_ether.c (modified) * cpukit/libnetworking/netinet/in.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/in_proto.c (modified) * cpukit/libnetworking/netinet/in_rmx.c (modified) * cpukit/libnetworking/netinet/ip_divert.c (modified) * cpukit/libnetworking/netinet/ip_fw.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/netinet/ip_output.c (modified) * cpukit/libnetworking/netinet/raw_ip.c (modified) * cpukit/libnetworking/netinet/tcp_debug.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/netinet/tcp_output.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) * cpukit/libnetworking/netinet/tcp_timer.c (modified) * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_showipstat.c (modified) * cpukit/libnetworking/rtems/rtems_showmbuf.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showudpstat.c (modified) Include instead of . Thu, 10 May 2007 05:07:28 GMT Ralf Corsepius [8fc471a5] * cpukit/libnetworking/net/if.h (modified) * cpukit/libnetworking/net/if_media.h (modified) * cpukit/libnetworking/net/if_var.h (modified) * cpukit/libnetworking/net/raw_cb.h (modified) * cpukit/libnetworking/netinet/in_pcb.h (modified) * cpukit/libnetworking/netinet/in_var.h (modified) * cpukit/libnetworking/sys/mount.h (modified) * cpukit/libnetworking/sys/socketvar.h (modified) * cpukit/libnetworking/sys/sysctl.h (modified) Include instead of . Wed, 09 May 2007 17:32:27 GMT Ralf Corsepius [6e08cf7] * cpukit/libnetworking/preinstall.am (modified) Regenerate. Wed, 09 May 2007 16:38:32 GMT Ralf Corsepius [54802dc] * cpukit/libnetworking/Makefile.am (modified) Remove machine/endian.h. Wed, 09 May 2007 16:38:18 GMT Ralf Corsepius [f5a22134] * cpukit/libnetworking/machine/endian.h (deleted) Remove. Wed, 09 May 2007 16:35:03 GMT Ralf Corsepius [0f9861be] * cpukit/libnetworking/arpa/nameser_compat.h (modified) * cpukit/libnetworking/netinet/in.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Include instead of . Wed, 09 May 2007 15:56:13 GMT Ralf Corsepius [203ed7f] * cpukit/libcsupport/src/readdir.c (modified) * cpukit/libnetworking/net/slcompress.c (modified) * cpukit/pppd/md4.h (modified) * cpukit/pppd/md5.h (modified) * cpukit/pppd/pppd.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) Include instead of . Wed, 09 May 2007 15:31:39 GMT Ralf Corsepius [2bcd08b] * cpukit/ChangeLog (modified) * cpukit/libnetworking/machine/endian.h (modified) 2007-05-09 Ralf Corsépius * ... Tue, 08 May 2007 21:10:19 GMT Ralf Corsepius [5a2feead] * cpukit/ChangeLog (modified) * cpukit/libnetworking/machine/endian.h (modified) 2007-05-08 Ralf Corsépius * ... Tue, 08 May 2007 16:39:57 GMT Ralf Corsepius [70e624e] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netdb.h (modified) 2007-05-08 Ralf Corsépius * ... Tue, 08 May 2007 12:44:16 GMT Ralf Corsepius [678b3b06] * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/inet_net_ntop.c (modified) * cpukit/libnetworking/libc/inet_pton.c (modified) Eliminate __P. Fri, 30 Mar 2007 07:21:22 GMT Ralf Corsepius [26f8315] * cpukit/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) 2007-03-30 Ralf Corsépius * ... Fri, 30 Mar 2007 06:31:09 GMT Ralf Corsepius [ada4d9b] * cpukit/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) cosmetics. Fri, 30 Mar 2007 06:29:29 GMT Ralf Corsepius [0e609ca] * cpukit/libnetworking/Makefile.am (modified) Move libc/res_config.h to libnetworking_a_SOURCES (File is being ... Fri, 30 Mar 2007 06:28:33 GMT Ralf Corsepius [53d8e07c] * cpukit/libnetworking/libc/iso_addr.3 (deleted) * cpukit/libnetworking/libc/iso_addr.c (deleted) Remove (Unused). Fri, 30 Mar 2007 05:38:36 GMT Ralf Corsepius [e59dc210] * cpukit/libnetworking/Makefile.am (modified) Remove net/ppp-deflate.c, net/bsd-comp.c. Fri, 30 Mar 2007 05:38:16 GMT Ralf Corsepius [f8a6097] * cpukit/libnetworking/net/bsd-comp.c (deleted) * cpukit/libnetworking/net/ppp-deflate.c (deleted) Remove (Unused) Fri, 30 Mar 2007 05:15:58 GMT Ralf Corsepius [09fdb5e8] * cpukit/libnetworking/libc/addr2ascii.c (modified) * cpukit/libnetworking/libc/ascii2addr.c (modified) * cpukit/libnetworking/libc/base64.c (modified) * cpukit/libnetworking/libc/ether_addr.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostbynis.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/gethostname.c (modified) * cpukit/libnetworking/libc/getnetbydns.c (modified) * cpukit/libnetworking/libc/getnetbyht.c (modified) * cpukit/libnetworking/libc/getnetbynis.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/getproto.c (modified) * cpukit/libnetworking/libc/getprotoent.c (modified) * cpukit/libnetworking/libc/getprotoname.c (modified) * cpukit/libnetworking/libc/getservbyname.c (modified) * cpukit/libnetworking/libc/getservbyport.c (modified) * cpukit/libnetworking/libc/getservent.c (modified) * cpukit/libnetworking/libc/herror.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/inet_lnaof.c (modified) * cpukit/libnetworking/libc/inet_makeaddr.c (modified) * cpukit/libnetworking/libc/inet_net_ntop.c (modified) * cpukit/libnetworking/libc/inet_net_pton.c (modified) * cpukit/libnetworking/libc/inet_neta.c (modified) * cpukit/libnetworking/libc/inet_netof.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/libc/inet_ntoa.c (modified) * cpukit/libnetworking/libc/inet_ntop.c (modified) * cpukit/libnetworking/libc/inet_pton.c (modified) * cpukit/libnetworking/libc/iso_addr.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/map_v4v6.c (modified) * cpukit/libnetworking/libc/ns_addr.c (modified) * cpukit/libnetworking/libc/ns_name.c (modified) * cpukit/libnetworking/libc/ns_netint.c (modified) * cpukit/libnetworking/libc/ns_ntoa.c (modified) * cpukit/libnetworking/libc/ns_parse.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/nsap_addr.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/recv.c (modified) * cpukit/libnetworking/libc/res_comp.c (modified) * cpukit/libnetworking/libc/res_data.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_init.c (modified) * cpukit/libnetworking/libc/res_mkquery.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_stubs.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/libc/send.c (modified) * cpukit/libnetworking/libc/strsep.c (modified) Eliminate SCCS, LINT. Add HAVE_CONFIG_H. Thu, 29 Mar 2007 14:31:08 GMT Ralf Corsepius [491f63a] * cpukit/libnetworking/netinet/ip_icmp.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_output.c (modified) Further _IP_VHL removal preps. Thu, 29 Mar 2007 14:28:49 GMT Ralf Corsepius [ef0b69d1] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/ip.h (modified) 2007-03-29 Ralf Corsépius * ... Thu, 29 Mar 2007 14:27:48 GMT Ralf Corsepius [6209041] * cpukit/ChangeLog (modified) * cpukit/libnetworking/net/netisr.h (modified) 2007-03-29 Ralf Corsépius * ... Thu, 29 Mar 2007 14:25:40 GMT Ralf Corsepius [0f0318e] * cpukit/ChangeLog (modified) * cpukit/libnetworking/libc/strsep.c (modified) 2007-03-29 Ralf Corsépius * ... Thu, 29 Mar 2007 08:39:21 GMT Ralf Corsepius [dbd2c7d] * cpukit/ChangeLog (modified) * cpukit/libnetworking/libc/rcmd.c (modified) 2007-03-29 Ralf Corsépius * ... Thu, 29 Mar 2007 08:06:14 GMT Ralf Corsepius [e546ace] * cpukit/libnetworking/sys/select.h (modified) Remove selrecord, selwakeup (Unused). Thu, 29 Mar 2007 07:50:03 GMT Ralf Corsepius [f94e799e] * cpukit/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_output.c (modified) Preps to eliminate _IP_VHL (Abandoned in FreeBSD). Misc mergers from ... Thu, 29 Mar 2007 07:47:15 GMT Ralf Corsepius [4939788] * cpukit/libnetworking/netinet/ip_icmp.c (modified) Preps to eliminate _IP_VHL (Abandoned in FreeBSD). Thu, 29 Mar 2007 05:21:31 GMT Ralf Corsepius [7ff51b00] * cpukit/libnetworking/netinet/raw_ip.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) Preps to eliminate _IP_VHL (Abandoned in FreeBSD). Thu, 29 Mar 2007 05:18:26 GMT Ralf Corsepius [0c67b436] * cpukit/libnetworking/netinet/ip_output.c (modified) Partial update from FreeBSD. Thu, 29 Mar 2007 05:16:42 GMT Ralf Corsepius [e67b6ea1] * cpukit/libnetworking/netinet/ip_fw.c (modified) Eliminate __P(). Wed, 28 Mar 2007 15:47:20 GMT Ralf Corsepius [6898ed4] * cpukit/libnetworking/preinstall.am (modified) Regenerate. Wed, 28 Mar 2007 15:46:37 GMT Ralf Corsepius [014255f8] * cpukit/libnetworking/net/ppp-comp.h (deleted) * cpukit/libnetworking/sys/buf.h (deleted) Remove (Unused). Wed, 28 Mar 2007 15:46:18 GMT Ralf Corsepius [1e4e5f21] * cpukit/libnetworking/Makefile.am (modified) Remove net/ppp-comp.h. Wed, 28 Mar 2007 15:44:02 GMT Ralf Corsepius [e21508b5] * cpukit/libnetworking/preinstall.am (modified) Regenerate. Wed, 28 Mar 2007 15:43:44 GMT Ralf Corsepius [462fb64] * cpukit/libnetworking/Makefile.am (modified) Remove sys/buf.h. Wed, 28 Mar 2007 15:34:23 GMT Ralf Corsepius [816f4222] * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) Include instead of . Wed, 28 Mar 2007 05:36:38 GMT Ralf Corsepius [387cc207] * cpukit/libnetworking/netinet/ip_output.c (modified) Use uint32_t optlen. Wed, 28 Mar 2007 05:23:18 GMT Ralf Corsepius [e5d6315e] * cpukit/libnetworking/netinet/igmp.c (modified) * cpukit/libnetworking/netinet/in.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/ip_output.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) Eliminate __P(). Wed, 28 Mar 2007 04:48:01 GMT Ralf Corsepius [d506dff] * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) Reflect changes to sys/protosw.h. Wed, 28 Mar 2007 04:47:30 GMT Ralf Corsepius [1a795c31] * cpukit/libnetworking/sys/protosw.h (modified) Change int args to intptr_t because they are casted to pointers. Wed, 28 Mar 2007 04:43:04 GMT Ralf Corsepius [fa768df] * cpukit/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 04:40:36 GMT Ralf Corsepius [0b07d87] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 04:38:00 GMT Ralf Corsepius [239d981f] * cpukit/libnetworking/netinet/in_rmx.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) Eliminate __P(). Wed, 28 Mar 2007 03:08:08 GMT Ralf Corsepius [652f618] * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) Eliminate __P(). Wed, 28 Mar 2007 02:42:47 GMT Ralf Corsepius [dcefab6] * cpukit/libnetworking/kern/uipc_domain.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Eliminate __P(). Wed, 28 Mar 2007 02:20:23 GMT Ralf Corsepius [bd6dfc9a] * cpukit/libnetworking/preinstall.am (modified) Regenerate. Wed, 28 Mar 2007 02:19:04 GMT Ralf Corsepius [47a8868] * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) Use net/slcompress.h instead of net/pppcompress.h. Wed, 28 Mar 2007 02:16:27 GMT Ralf Corsepius [179c2c33] * cpukit/libnetworking/net/slcompress.h (modified) Cosmetics from FreeBSD. Wed, 28 Mar 2007 02:15:57 GMT Ralf Corsepius [c85f596b] * cpukit/libnetworking/Makefile.am (modified) Remove net/pppcompress.c, net/pppcompress.h. Wed, 28 Mar 2007 02:15:38 GMT Ralf Corsepius [a0a45be] * cpukit/libnetworking/net/pppcompress.c (deleted) * cpukit/libnetworking/net/pppcompress.h (deleted) Remove (Abandoned in FreeBSD).
