# # ChangeLog for cpukit/libnetworking in rtems # # Generated by Trac 1.2.1.dev0 # 06/02/24 09:45:04 Tue, 19 Nov 2002 22:23:50 GMT Ralf Corsepius [47c0220] * c/src/ada/ChangeLog (modified) * cpukit/ada/ChangeLog (modified) * cpukit/ada/configure.ac (modified) * cpukit/itron/ChangeLog (modified) * cpukit/itron/configure.ac (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/configure.ac (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/configure.ac (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/configure.ac (modified) * cpukit/score/cpu/a29k/ChangeLog (modified) * cpukit/score/cpu/a29k/configure.ac (modified) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/configure.ac (modified) * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/configure.ac (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/configure.ac (modified) * cpukit/score/cpu/hppa1.1/ChangeLog (modified) * cpukit/score/cpu/hppa1.1/configure.ac (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/configure.ac (modified) * cpukit/score/cpu/i960/ChangeLog (modified) * cpukit/score/cpu/i960/configure.ac (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/configure.ac (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/configure.ac (modified) * cpukit/score/cpu/mips64orion/ChangeLog (modified) * cpukit/score/cpu/mips64orion/configure.ac (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/configure.ac (modified) * cpukit/score/cpu/or32/ChangeLog (modified) * cpukit/score/cpu/or32/configure.ac (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/configure.ac (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/configure.ac (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/configure.ac (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/configure.ac (modified) 2002-11-19 Ralf Corsepius * ... Mon, 18 Nov 2002 02:21:19 GMT Ralf Corsepius [9eadce0] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) 2002-11-18 Ralf Corsepius * ... Fri, 15 Nov 2002 14:55:12 GMT Ralf Corsepius [471bcf0] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (deleted) * cpukit/libnetworking/configure.ac (modified) * cpukit/libnetworking/machine/Makefile.am (deleted) * cpukit/libnetworking/sys/Makefile.am (deleted) * cpukit/libnetworking/vm/Makefile.am (deleted) 2002-11-15 Ralf Corsepius * ... Sun, 10 Nov 2002 07:12:46 GMT Chris Johns [658ad56f] * cpukit/libnetworking/ChangeLog (modified) 2002-11-06 Chris Johns * sys/select.h: Add ... Sat, 09 Nov 2002 04:37:33 GMT Chris Johns [8d3eba16] * cpukit/libnetworking/sys/select.h (modified) Need to be extern C for use by C++. Sat, 02 Nov 2002 16:27:43 GMT Ralf Corsepius [76b6085f] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) 2002-11-02 Ralf Corsepius * ... Fri, 01 Nov 2002 22:26:02 GMT Joel Sherrill [b31106f6] * ChangeLog (modified) * cpukit/ChangeLog (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/posix/ChangeLog (modified) 2002-11-01 Joel Sherrill * ... Fri, 01 Nov 2002 18:43:57 GMT Eric Norum [ce452f7] * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) *** empty log message *** Fri, 01 Nov 2002 18:43:09 GMT Eric Norum [022fcc07] * ChangeLog (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) Till Straumann's patch to: use bootp option 129 to get ... Thu, 31 Oct 2002 20:10:40 GMT Joel Sherrill [0647cc7] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/netinet/in_cksum_arm.c (modified) * cpukit/libnetworking/netinet/in_cksum_arm.h (modified) 2002-10-31 Joel Sherrill * ... Mon, 28 Oct 2002 13:56:01 GMT Joel Sherrill [abef0f6] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/syslog.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/inet_ntoa.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/net/rtsock.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) 2002-10-28 Joel Sherrill * Pass to ... Fri, 25 Oct 2002 06:18:56 GMT Ralf Corsepius [56a1ae36] * c/src/ada/ChangeLog (modified) * cpukit/ChangeLog (modified) * cpukit/ada/ChangeLog (modified) * cpukit/ada/configure.ac (modified) * cpukit/configure.ac (modified) * cpukit/itron/ChangeLog (modified) * cpukit/itron/configure.ac (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/configure.ac (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/configure.ac (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/configure.ac (modified) 2002-10-25 Ralf Corsepius * ... Fri, 25 Oct 2002 04:36:19 GMT Ralf Corsepius [fa87598] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) 2002-10-25 Ralf Corsepius * ... Mon, 21 Oct 2002 12:04:36 GMT Ralf Corsepius [f8cb04a5] * c/.cvsignore (modified) * c/ChangeLog (modified) * c/src/ada/.cvsignore (modified) * c/src/ada/ChangeLog (modified) * cpukit/.cvsignore (modified) * cpukit/ChangeLog (modified) * cpukit/ada/.cvsignore (modified) * cpukit/ada/ChangeLog (modified) * cpukit/itron/.cvsignore (modified) * cpukit/itron/ChangeLog (modified) * cpukit/libblock/.cvsignore (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libcsupport/.cvsignore (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libfs/.cvsignore (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libnetworking/.cvsignore (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/librpc/.cvsignore (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/posix/.cvsignore (modified) * cpukit/posix/ChangeLog (modified) * cpukit/score/cpu/a29k/.cvsignore (modified) * cpukit/score/cpu/a29k/ChangeLog (modified) * cpukit/score/cpu/arm/.cvsignore (modified) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/c4x/.cvsignore (modified) * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/h8300/.cvsignore (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/hppa1.1/.cvsignore (modified) * cpukit/score/cpu/hppa1.1/ChangeLog (modified) * cpukit/score/cpu/i386/.cvsignore (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i960/.cvsignore (modified) * cpukit/score/cpu/i960/ChangeLog (modified) * cpukit/score/cpu/m68k/.cvsignore (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/mips/.cvsignore (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips64orion/.cvsignore (modified) * cpukit/score/cpu/mips64orion/ChangeLog (modified) * cpukit/score/cpu/no_cpu/.cvsignore (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/or32/.cvsignore (modified) * cpukit/score/cpu/or32/ChangeLog (modified) * cpukit/score/cpu/powerpc/.cvsignore (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/sh/.cvsignore (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sparc/.cvsignore (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/unix/.cvsignore (modified) * cpukit/score/cpu/unix/ChangeLog (modified) 2002-10-21 Ralf Corsepius * ... Sun, 13 Oct 2002 21:47:29 GMT Ralf Corsepius [7b93cedc] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) 2002-10-13 Ralf Corsepius * ... Mon, 07 Oct 2002 17:11:27 GMT Joel Sherrill [a63efae] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/netinet/tcp_var.h (modified) 2002-10-07 Eric Norum * ... Fri, 04 Oct 2002 14:47:11 GMT Joel Sherrill [3fb76805] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/ip_icmp.h (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) * cpukit/libnetworking/netinet/tcp_var.h (modified) * cpukit/libnetworking/sys/queue.h (modified) 2002-10-04 Jay Monkman * ... Fri, 04 Oct 2002 13:25:31 GMT Joel Sherrill [ed15301c] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2002-10-04 Jay Monkman * ... Wed, 02 Oct 2002 17:35:29 GMT Joel Sherrill [6ca248c] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) 2002-10-02 Joel Sherrill * ... Wed, 02 Oct 2002 17:34:28 GMT Joel Sherrill [bcac0cb] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) 2002-10-02 Eric Norum * ... Mon, 16 Sep 2002 11:55:43 GMT Joel Sherrill [f4ceef3e] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) 2002-09-16 Joel Sherrill * ... Sat, 14 Sep 2002 18:31:06 GMT Joel Sherrill [144b94f] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) 2002-09-14 Joel Sherrill * ... Sat, 14 Sep 2002 18:18:50 GMT Joel Sherrill [ce2c216] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) * cpukit/libnetworking/sys/mbuf.h (modified) 2002-09-14 Vyacheslav V. Burdjanadze * ... Mon, 02 Sep 2002 06:26:03 GMT Ralf Corsepius [6a2d7ee] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) 2002-09-02 Ralf Corsepius * ... Tue, 20 Aug 2002 15:53:52 GMT Joel Sherrill [845f170a] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2002-08-20 Eric Norum * ... Fri, 09 Aug 2002 12:45:10 GMT Joel Sherrill [68a368fc] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/libc/getservent.c (modified) 2002-08-09 Joel Sherrill * ... Wed, 07 Aug 2002 15:37:33 GMT Joel Sherrill [7a47bb5] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/netinet/in.h (modified) 2002-08-07 Joel Sherrill * ... Fri, 02 Aug 2002 00:48:03 GMT Joel Sherrill [d9ab6d3] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/machine/param.h (deleted) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/sys/syslimits.h (deleted) 2002-08-01 Joel Sherrill * ... Thu, 01 Aug 2002 16:15:37 GMT Ralf Corsepius [18dce91] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) 2002-08-01 Ralf Corsepius * ... Tue, 30 Jul 2002 23:32:15 GMT Joel Sherrill [08943ebf] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/sys/param.h (deleted) 2002-07-30 Joel Sherrill * ... Tue, 30 Jul 2002 23:31:00 GMT Joel Sherrill [9fcd1a1c] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/machine/endian.h (modified) * cpukit/libnetworking/machine/types.h (deleted) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/sys/systm.h (modified) 2002-07-30 Joel Sherrill * ... Tue, 30 Jul 2002 14:33:24 GMT Joel Sherrill [6fd2516] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum_arm.c (added) * cpukit/libnetworking/netinet/in_cksum_arm.h (added) 2002-07-30 Jay Monkman * ... Wed, 24 Jul 2002 13:25:50 GMT Joel Sherrill [7b43151] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/sys/select.h (modified) 2002-07-24 Joel Sherrill * ... Wed, 24 Jul 2002 13:25:06 GMT Joel Sherrill [ce75da6] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/libc/res_send.c (modified) 2002-07-24 Joel Sherrill * ... Mon, 22 Jul 2002 13:44:48 GMT Ralf Corsepius [0e1dd41f] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/kern/Makefile.am (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) 2002-07-22 Ralf Corsepius * ... Mon, 22 Jul 2002 06:35:33 GMT Ralf Corsepius [eb4b28d] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/kern/Makefile.am (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) 2002-07-22 Ralf Corsepius * ... Wed, 17 Jul 2002 17:08:48 GMT Joel Sherrill [74c402a2] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/netinet/in.h (modified) * c/src/exec/libnetworking/netinet/ip.h (modified) * c/src/exec/libnetworking/netinet/ip_var.h (modified) * c/src/exec/libnetworking/netinet/tcp.h (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/netinet/in.h (modified) * cpukit/libnetworking/netinet/ip.h (modified) * cpukit/libnetworking/netinet/ip_var.h (modified) * cpukit/libnetworking/netinet/tcp.h (modified) 2002-07-17 Jay Monkman * ... Fri, 05 Jul 2002 15:55:09 GMT Ralf Corsepius [705a0701] * c/src/exec/itron/ChangeLog (modified) * c/src/exec/itron/configure.ac (modified) * c/src/exec/libblock/ChangeLog (modified) * c/src/exec/libblock/configure.ac (modified) * c/src/exec/libcsupport/ChangeLog (modified) * c/src/exec/libcsupport/configure.ac (modified) * c/src/exec/libfs/ChangeLog (modified) * c/src/exec/libfs/configure.ac (modified) * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/configure.ac (modified) * c/src/exec/librpc/ChangeLog (modified) * c/src/exec/librpc/configure.ac (modified) * c/src/exec/posix/ChangeLog (modified) * c/src/exec/posix/configure.ac (modified) * cpukit/itron/ChangeLog (modified) * cpukit/itron/configure.ac (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/configure.ac (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/configure.ac (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/configure.ac (modified) 2002-07-05 Ralf Corsepius * ... Mon, 01 Jul 2002 09:59:55 GMT Ralf Corsepius [8c746fe] * c/src/exec/itron/ChangeLog (modified) * c/src/exec/itron/configure.ac (modified) * c/src/exec/libblock/ChangeLog (modified) * c/src/exec/libblock/configure.ac (modified) * c/src/exec/libcsupport/ChangeLog (modified) * c/src/exec/libcsupport/configure.ac (modified) * c/src/exec/libfs/ChangeLog (modified) * c/src/exec/libfs/configure.ac (modified) * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/configure.ac (modified) * c/src/exec/librpc/ChangeLog (modified) * c/src/exec/librpc/configure.ac (modified) * c/src/exec/posix/ChangeLog (modified) * c/src/exec/posix/configure.ac (modified) * c/src/exec/score/cpu/a29k/ChangeLog (modified) * c/src/exec/score/cpu/a29k/configure.ac (modified) * c/src/exec/score/cpu/arm/ChangeLog (modified) * c/src/exec/score/cpu/arm/configure.ac (modified) * c/src/exec/score/cpu/c4x/ChangeLog (modified) * c/src/exec/score/cpu/c4x/configure.ac (modified) * c/src/exec/score/cpu/h8300/ChangeLog (modified) * c/src/exec/score/cpu/h8300/configure.ac (modified) * c/src/exec/score/cpu/hppa1.1/ChangeLog (modified) * c/src/exec/score/cpu/hppa1.1/configure.ac (modified) * c/src/exec/score/cpu/i386/ChangeLog (modified) * c/src/exec/score/cpu/i386/configure.ac (modified) * c/src/exec/score/cpu/i960/ChangeLog (modified) * c/src/exec/score/cpu/i960/configure.ac (modified) * c/src/exec/score/cpu/m68k/ChangeLog (modified) * c/src/exec/score/cpu/m68k/configure.ac (modified) * c/src/exec/score/cpu/mips/ChangeLog (modified) * c/src/exec/score/cpu/mips/configure.ac (modified) * c/src/exec/score/cpu/mips64orion/ChangeLog (modified) * c/src/exec/score/cpu/mips64orion/configure.ac (modified) * c/src/exec/score/cpu/no_cpu/ChangeLog (modified) * c/src/exec/score/cpu/no_cpu/configure.ac (modified) * c/src/exec/score/cpu/or16/ChangeLog (modified) * c/src/exec/score/cpu/or16/configure.ac (modified) * c/src/exec/score/cpu/or32/ChangeLog (modified) * c/src/exec/score/cpu/or32/configure.ac (modified) * c/src/exec/score/cpu/powerpc/ChangeLog (modified) * c/src/exec/score/cpu/powerpc/configure.ac (modified) * c/src/exec/score/cpu/sh/ChangeLog (modified) * c/src/exec/score/cpu/sh/configure.ac (modified) * c/src/exec/score/cpu/sparc/ChangeLog (modified) * c/src/exec/score/cpu/sparc/configure.ac (modified) * c/src/exec/score/cpu/unix/ChangeLog (modified) * c/src/exec/score/cpu/unix/configure.ac (modified) * cpukit/itron/ChangeLog (modified) * cpukit/itron/configure.ac (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/configure.ac (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/configure.ac (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/configure.ac (modified) * cpukit/score/cpu/a29k/ChangeLog (modified) * cpukit/score/cpu/a29k/configure.ac (modified) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/configure.ac (modified) * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/configure.ac (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/configure.ac (modified) * cpukit/score/cpu/hppa1.1/ChangeLog (modified) * cpukit/score/cpu/hppa1.1/configure.ac (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/configure.ac (modified) * cpukit/score/cpu/i960/ChangeLog (modified) * cpukit/score/cpu/i960/configure.ac (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/configure.ac (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/configure.ac (modified) * cpukit/score/cpu/mips64orion/ChangeLog (modified) * cpukit/score/cpu/mips64orion/configure.ac (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/configure.ac (modified) * cpukit/score/cpu/or16/ChangeLog (modified) * cpukit/score/cpu/or16/configure.ac (modified) * cpukit/score/cpu/or32/ChangeLog (modified) * cpukit/score/cpu/or32/configure.ac (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/configure.ac (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/configure.ac (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/configure.ac (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/configure.ac (modified) 2002-07-01 Ralf Corsepius * ... Thu, 27 Jun 2002 21:59:23 GMT Joel Sherrill [dda0bffc] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/lib/Makefile.am (modified) * c/src/exec/libnetworking/lib/ftpfs.c (added) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/exec/libnetworking/rtems/ftpfs.h (added) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/lib/ftpfs.c (added) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/rtems/ftpfs.h (added) 2002-06-27 Thomas Doerfler ... Thu, 27 Jun 2002 04:00:20 GMT Ralf Corsepius [da8f88a] * c/src/exec/itron/ChangeLog (modified) * c/src/exec/itron/configure.ac (modified) * c/src/exec/libblock/ChangeLog (modified) * c/src/exec/libblock/configure.ac (modified) * c/src/exec/libcsupport/ChangeLog (modified) * c/src/exec/libcsupport/configure.ac (modified) * c/src/exec/libfs/ChangeLog (modified) * c/src/exec/libfs/configure.ac (modified) * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/configure.ac (modified) * c/src/exec/librpc/ChangeLog (modified) * c/src/exec/librpc/configure.ac (modified) * c/src/exec/posix/ChangeLog (modified) * c/src/exec/posix/configure.ac (modified) * cpukit/itron/ChangeLog (modified) * cpukit/itron/configure.ac (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/configure.ac (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/configure.ac (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/configure.ac (modified) 2002-06-27 Ralf Corsepius * ... Wed, 26 Jun 2002 15:46:38 GMT Ralf Corsepius [89e6498] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) 2002-06-26 Ralf Corsepius * ... Tue, 18 Jun 2002 12:33:23 GMT Ralf Corsepius [75fb648b] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) 2002-06-18 Ralf Corsepius * ... Mon, 17 Jun 2002 09:12:00 GMT Ralf Corsepius [f22ebf0] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/arpa/Makefile.am (modified) * c/src/exec/libnetworking/kern/Makefile.am (modified) * c/src/exec/libnetworking/lib/Makefile.am (modified) * c/src/exec/libnetworking/libc/Makefile.am (modified) * c/src/exec/libnetworking/machine/Makefile.am (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/netinet/Makefile.am (modified) * c/src/exec/libnetworking/nfs/Makefile.am (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/exec/libnetworking/sys/Makefile.am (modified) * c/src/exec/libnetworking/vm/Makefile.am (modified) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (modified) * cpukit/libnetworking/kern/Makefile.am (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/vm/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) 2002-06-17 Ralf Corsepius * ... Sat, 15 Jun 2002 07:14:44 GMT Ralf Corsepius [bfd1a53a] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) 2002-06-02 Ralf Corsepius * ... Thu, 30 May 2002 12:25:38 GMT Joel Sherrill [158e2d7] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/configure.ac (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/configure.ac (modified) 2002-05-30 Ralf Corsepius * ... Wed, 29 May 2002 17:00:59 GMT Joel Sherrill [8a79786] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/arpa/Makefile.am (modified) * c/src/exec/libnetworking/configure.ac (modified) * c/src/exec/libnetworking/kern/Makefile.am (modified) * c/src/exec/libnetworking/lib/Makefile.am (modified) * c/src/exec/libnetworking/libc/Makefile.am (modified) * c/src/exec/libnetworking/machine/Makefile.am (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/netinet/Makefile.am (modified) * c/src/exec/libnetworking/nfs/Makefile.am (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/exec/libnetworking/sys/Makefile.am (modified) * c/src/exec/libnetworking/vm/Makefile.am (modified) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/libnetworking/kern/Makefile.am (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/vm/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) 2002-05-29 Ralf Corsepius ... Tue, 28 May 2002 16:20:54 GMT Joel Sherrill [e3eab02] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/rtems_telnetd/pty.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/telnetd/pty.c (modified) 2002-05-18 Ralf Corsepius * ... Fri, 17 May 2002 18:28:26 GMT Joel Sherrill [c1f3fc04] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) 2002-05-16 Ralf Corsepius * ... Tue, 14 May 2002 18:02:47 GMT Joel Sherrill [c7286d94] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/sys/Makefile.am (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/sys/Makefile.am (modified) * c/src/libnetworking/sys/filio.h (deleted) * c/src/libnetworking/sys/ioctl.h (deleted) * c/src/libnetworking/sys/sockio.h (deleted) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/sys/Makefile.am (modified) 2002-05-14 Ralf Corsepius * ... Tue, 14 May 2002 17:35:55 GMT Joel Sherrill [06549dcf] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * cpukit/libnetworking/ChangeLog (modified) 2001-05-14 Joel Sherrill * ... Tue, 14 May 2002 17:35:16 GMT Joel Sherrill [1065f16] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libchip/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * cpukit/libnetworking/ChangeLog (modified) 2001-05-14 Till Straumann ... Tue, 14 May 2002 17:08:25 GMT Joel Sherrill [3ce2907] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * cpukit/libnetworking/ChangeLog (modified) 2001-05-14 Till Straumann ... Wed, 01 May 2002 23:09:37 GMT Joel Sherrill [51b39864] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/machine/in_cksum.h (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/machine/in_cksum.h (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/machine/in_cksum.h (modified) 2002-05-01 Eric Norum * ... Fri, 26 Apr 2002 21:34:58 GMT Joel Sherrill [d50c0d2] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/netinet/in_cksum_i386.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/netinet/in_cksum_i386.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/netinet/in_cksum_i386.c (modified) * cpukit/libnetworking/netinet/in_cksum_i386.h (modified) 2002-04-26 Eric Norum * ... Thu, 18 Apr 2002 22:24:04 GMT Joel Sherrill [a81a8f8] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/utils.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/pppd/utils.c (modified) 2002-04-18 Ralf Corsepius * ... Sat, 13 Apr 2002 16:41:43 GMT Joel Sherrill [5bfc8912] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) 2002-04-11 Chris Johns * ... Mon, 08 Apr 2002 18:27:31 GMT Joel Sherrill [25b4446] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * cpukit/libnetworking/ChangeLog (modified) 2002-04-06 Ralf Corsepius * ... Mon, 01 Apr 2002 13:27:46 GMT Joel Sherrill [51301198] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/libc/rcmd.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/libc/rcmd.c (modified) 2002-03-30 Ralf Corsepius * ... Thu, 28 Mar 2002 00:49:43 GMT Joel Sherrill [01d48bf8] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/arpa/Makefile.am (modified) * c/src/exec/libnetworking/configure.ac (modified) * c/src/exec/libnetworking/kern/Makefile.am (modified) * c/src/exec/libnetworking/lib/Makefile.am (modified) * c/src/exec/libnetworking/libc/Makefile.am (modified) * c/src/exec/libnetworking/machine/Makefile.am (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/netinet/Makefile.am (modified) * c/src/exec/libnetworking/nfs/Makefile.am (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/exec/libnetworking/sys/Makefile.am (modified) * c/src/exec/libnetworking/vm/Makefile.am (modified) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/arpa/Makefile.am (modified) * c/src/libnetworking/configure.ac (modified) * c/src/libnetworking/kern/Makefile.am (modified) * c/src/libnetworking/lib/Makefile.am (modified) * c/src/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/machine/Makefile.am (modified) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/netinet/Makefile.am (modified) * c/src/libnetworking/nfs/Makefile.am (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_telnetd/Makefile.am (modified) * c/src/libnetworking/rtems_webserver/Makefile.am (modified) * c/src/libnetworking/sys/Makefile.am (modified) * c/src/libnetworking/vm/Makefile.am (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/libnetworking/kern/Makefile.am (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/vm/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/telnetd/Makefile.am (modified) 2002-03-27 Ralf Corsepius * ... Wed, 27 Mar 2002 14:44:55 GMT Joel Sherrill [9b02fa65] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) 2002-03-27 Thomas.Doerfler@imd-systems.de * PR144 ... Wed, 27 Mar 2002 14:36:07 GMT Joel Sherrill [f4c118d] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/net/if_ppp.c (modified) * c/src/exec/libnetworking/net/if_pppvar.h (modified) * c/src/exec/libnetworking/net/ppp_tty.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/net/if_ppp.c (modified) * c/src/libnetworking/net/if_pppvar.h (modified) * c/src/libnetworking/net/ppp_tty.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/if_pppvar.h (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) 2002-03-27 Ilya Alexeev * PR162 ... Thu, 21 Mar 2002 15:01:32 GMT Joel Sherrill [fd55b7d] * c/src/exec/libblock/ChangeLog (modified) * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/net/if_ppp.c (modified) * c/src/exec/libnetworking/net/ppp_tty.c (modified) * c/src/libblock/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/net/if_ppp.c (modified) * c/src/libnetworking/net/ppp_tty.c (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) 2002-03-21 Ilya Alexeev * ... Wed, 20 Mar 2002 22:08:06 GMT Joel Sherrill [d7478774] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/libc/Makefile.am (modified) * c/src/exec/libnetworking/libc/rcmd.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/libc/rcmd.c (modified) 2001-03-20 Till Straumann ... Wed, 27 Feb 2002 22:43:31 GMT Joel Sherrill [cb1e8a46] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/net/if_ppp.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/net/if_ppp.c (modified) * c/src/libnetworking/pppd/auth.c (modified) * c/src/libnetworking/pppd/chat.c (modified) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/sys-rtems.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/pppd/auth.c (modified) * cpukit/pppd/chat.c (modified) * cpukit/pppd/pppd.h (modified) * cpukit/pppd/sys-rtems.c (modified) 2002-02-27 Ilya Alexeev * ... Wed, 27 Feb 2002 22:39:18 GMT Joel Sherrill [c52f1c7] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/net/radix.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/net/radix.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/net/radix.c (modified) 2002-02-27 Eric Norum * ... Fri, 01 Feb 2002 16:51:07 GMT Joel Sherrill [8e3caa5] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/rtemspppd.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/pppd/rtemspppd.c (modified) 2001-02-01 Mike Siers * ... Fri, 01 Feb 2002 14:04:45 GMT Joel Sherrill [485ed5cc] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/rtemsdialer.h (added) * cpukit/libnetworking/ChangeLog (modified) * cpukit/pppd/rtemsdialer.h (added) 2001-01-31 Mike Siers * ... Thu, 31 Jan 2002 21:42:11 GMT Joel Sherrill [0286b9f] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/configure.ac (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/net/bsd-comp.c (added) * c/src/exec/libnetworking/net/if_ppp.c (added) * c/src/exec/libnetworking/net/if_ppp.h (modified) * c/src/exec/libnetworking/net/if_pppvar.h (modified) * c/src/exec/libnetworking/net/ppp-comp.h (modified) * c/src/exec/libnetworking/net/ppp-deflate.c (added) * c/src/exec/libnetworking/net/ppp.h (added) * c/src/exec/libnetworking/net/ppp_defs.h (modified) * c/src/exec/libnetworking/net/ppp_tty.c (added) * c/src/exec/libnetworking/net/pppcompress.c (moved) * c/src/exec/libnetworking/net/zlib.c (added) * c/src/exec/libnetworking/net/zlib.h (added) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.ac (modified) * c/src/libnetworking/modem/.cvsignore (deleted) * c/src/libnetworking/modem/Makefile.am (deleted) * c/src/libnetworking/modem/ppp.h (deleted) * c/src/libnetworking/modem/ppp_tty.c (deleted) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/net/bsd-comp.c (added) * c/src/libnetworking/net/if_ppp.c (moved) * c/src/libnetworking/net/if_ppp.h (modified) * c/src/libnetworking/net/if_pppvar.h (modified) * c/src/libnetworking/net/ppp-comp.h (modified) * c/src/libnetworking/net/ppp-deflate.c (added) * c/src/libnetworking/net/ppp.h (added) * c/src/libnetworking/net/ppp_defs.h (modified) * c/src/libnetworking/net/ppp_tty.c (added) * c/src/libnetworking/net/pppcompress.c (added) * c/src/libnetworking/net/zlib.c (added) * c/src/libnetworking/net/zlib.h (added) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/pppd/README (modified) * c/src/libnetworking/pppd/STATUS (modified) * c/src/libnetworking/pppd/chap.h (modified) * c/src/libnetworking/pppd/chat.c (modified) * c/src/libnetworking/pppd/example/netconfig.h (modified) * c/src/libnetworking/pppd/fsm.c (modified) * c/src/libnetworking/pppd/fsm.h (modified) * c/src/libnetworking/pppd/ipcp.c (modified) * c/src/libnetworking/pppd/options.c (modified) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/rtemsmain.c (modified) * c/src/libnetworking/pppd/rtemspppd.c (modified) * c/src/libnetworking/pppd/rtemspppd.h (modified) * c/src/libnetworking/pppd/sys-rtems.c (modified) * c/src/libnetworking/pppd/upap.h (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/net/bsd-comp.c (added) * cpukit/libnetworking/net/if_ppp.c (added) * cpukit/libnetworking/net/if_ppp.h (modified) * cpukit/libnetworking/net/if_pppvar.h (modified) * cpukit/libnetworking/net/ppp-comp.h (modified) * cpukit/libnetworking/net/ppp-deflate.c (added) * cpukit/libnetworking/net/ppp.h (added) * cpukit/libnetworking/net/ppp_defs.h (modified) * cpukit/libnetworking/net/ppp_tty.c (added) * cpukit/libnetworking/net/pppcompress.c (added) * cpukit/libnetworking/net/zlib.c (added) * cpukit/libnetworking/net/zlib.h (added) * cpukit/libnetworking/wrapup/Makefile.am (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/README (modified) * cpukit/pppd/STATUS (modified) * cpukit/pppd/chap.h (modified) * cpukit/pppd/chat.c (modified) * cpukit/pppd/example/netconfig.h (modified) * cpukit/pppd/fsm.c (modified) * cpukit/pppd/fsm.h (modified) * cpukit/pppd/ipcp.c (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/pppd.h (modified) * cpukit/pppd/rtemsmain.c (modified) * cpukit/pppd/rtemspppd.c (modified) * cpukit/pppd/rtemspppd.h (modified) * cpukit/pppd/sys-rtems.c (modified) * cpukit/pppd/upap.h (modified) 2001-01-31 Mike Siers * Nice Update ... Tue, 22 Jan 2002 17:36:23 GMT Joel Sherrill [c8f05db] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/rtems_telnetd/pty.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/telnetd/pty.c (modified) 2002-01-21 Ralf Corsepius * ... Wed, 16 Jan 2002 22:50:04 GMT Joel Sherrill [cf42e735] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) 2001-01-16 Eric Norum * ... Sun, 06 Jan 2002 20:09:55 GMT Joel Sherrill [ab1ed86] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/sys-rtems.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/pppd/sys-rtems.c (modified) 2002-02-05 Ralf Corsepius * ... Fri, 04 Jan 2002 18:25:27 GMT Joel Sherrill [d4651e4] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) 2002-02-04 Ralf Corsepius * ... Wed, 19 Dec 2001 18:11:07 GMT Joel Sherrill [2539cdc] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) 2001-12-18 Eric Norum * ... Fri, 07 Dec 2001 12:59:12 GMT Joel Sherrill [86d9ca2] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) 2001-12-07 Eric Norum * ... Mon, 26 Nov 2001 14:34:00 GMT Joel Sherrill [4efd0f66] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/arpa/Makefile.am (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/arpa/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/arpa/Makefile.am (modified) 2001-11-26 Ralf Corsepius * ... Thu, 18 Oct 2001 18:48:55 GMT Joel Sherrill [dfe5a4e3] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) 2001-10-18 Eric Norum * ... Fri, 12 Oct 2001 21:03:15 GMT Joel Sherrill [cc13fa3] * c/src/exec/libnetworking/rtems/mkrootfs.c (modified) * c/src/exec/libnetworking/rtems/mkrootfs.h (modified) * c/src/libmisc/ChangeLog (modified) * c/src/libmisc/rootfs/mkrootfs.c (modified) * c/src/libmisc/rootfs/mkrootfs.h (modified) * c/src/libnetworking/rtems/mkrootfs.c (modified) * c/src/libnetworking/rtems/mkrootfs.h (modified) * cpukit/libmisc/ChangeLog (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/libnetworking/rtems/mkrootfs.h (modified) 2001-10-12 Joel Sherrill * ... Fri, 12 Oct 2001 18:47:00 GMT Joel Sherrill [d7aecdc] * c/src/configure.ac (added) * c/src/exec/libcsupport/configure.ac (added) * c/src/exec/libfs/configure.ac (added) * c/src/exec/libnetworking/configure.ac (added) * c/src/exec/librpc/configure.ac (added) * c/src/exec/score/cpu/sh/configure.ac (added) * c/src/exec/score/cpu/sparc/configure.ac (added) * c/src/lib/configure.ac (added) * c/src/lib/libbsp/a29k/configure.ac (added) * c/src/lib/libbsp/a29k/portsw/configure.ac (added) * c/src/lib/libbsp/arm/arm_bare_bsp/configure.ac (added) * c/src/lib/libbsp/arm/armulator/configure.ac (added) * c/src/lib/libbsp/arm/configure.ac (added) * c/src/lib/libbsp/arm/vegaplus/configure.ac (added) * c/src/lib/libbsp/bare/configure.ac (added) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (added) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (added) * c/src/lib/libbsp/c4x/configure.ac (added) * c/src/lib/libbsp/configure.ac (added) * c/src/lib/libbsp/h8300/configure.ac (added) * c/src/lib/libbsp/h8300/h8sim/configure.ac (added) * c/src/lib/libbsp/hppa1.1/configure.ac (added) * c/src/lib/libbsp/hppa1.1/simhppa/configure.ac (added) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.ac (added) * c/src/lib/libbsp/i386/configure.ac (added) * c/src/lib/libbsp/i386/i386ex/configure.ac (added) * c/src/lib/libbsp/i386/pc386/configure.ac (added) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (added) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (added) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (added) * c/src/lib/libbsp/i960/configure.ac (added) * c/src/lib/libbsp/i960/cvme961/configure.ac (added) * c/src/lib/libbsp/i960/i960sim/configure.ac (added) * c/src/lib/libbsp/i960/rxgen960/configure.ac (added) * c/src/lib/libbsp/m68k/configure.ac (added) * c/src/lib/libbsp/m68k/dmv152/configure.ac (added) * c/src/lib/libbsp/m68k/efi332/configure.ac (added) * c/src/lib/libbsp/m68k/efi68k/configure.ac (added) * c/src/lib/libbsp/m68k/gen68302/configure.ac (added) * c/src/lib/libbsp/m68k/gen68340/configure.ac (added) * c/src/lib/libbsp/m68k/gen68360/configure.ac (added) * c/src/lib/libbsp/m68k/idp/configure.ac (added) * c/src/lib/libbsp/m68k/mrm332/configure.ac (added) * c/src/lib/libbsp/m68k/mvme136/configure.ac (added) * c/src/lib/libbsp/m68k/mvme147/configure.ac (added) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (added) * c/src/lib/libbsp/m68k/mvme162/configure.ac (added) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (added) * c/src/lib/libbsp/m68k/mvme167/configure.ac (added) * c/src/lib/libbsp/m68k/ods68302/configure.ac (added) * c/src/lib/libbsp/m68k/sim68000/configure.ac (added) * c/src/lib/libbsp/mips/configure.ac (added) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (added) * c/src/lib/libbsp/mips/jmr3904/configure.ac (added) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (added) * c/src/lib/libbsp/mips/p4000/configure.ac (added) * c/src/lib/libbsp/mips64orion/configure.ac (added) * c/src/lib/libbsp/mips64orion/p4000/configure.ac (added) * c/src/lib/libbsp/no_cpu/configure.ac (added) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (added) * c/src/lib/libbsp/powerpc/configure.ac (added) * c/src/lib/libbsp/powerpc/dmv177/configure.ac (added) * c/src/lib/libbsp/powerpc/eth_comm/configure.ac (added) * c/src/lib/libbsp/powerpc/helas403/configure.ac (added) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (added) * c/src/lib/libbsp/powerpc/papyrus/configure.ac (added) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.ac (added) * c/src/lib/libbsp/powerpc/psim/configure.ac (added) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (added) * c/src/lib/libbsp/powerpc/score603e/configure.ac (added) * c/src/lib/libbsp/sh/configure.ac (added) * c/src/lib/libbsp/sh/gensh1/configure.ac (added) * c/src/lib/libbsp/sh/gensh2/configure.ac (added) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (added) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sparc/configure.ac (added) * c/src/lib/libbsp/sparc/erc32/configure.ac (added) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (added) * c/src/lib/libbsp/sparc/leon/configure.ac (added) * c/src/lib/libbsp/sparc/leon/tools/configure.ac (added) * c/src/lib/libbsp/unix/configure.ac (added) * c/src/lib/libbsp/unix/posix/configure.ac (added) * c/src/lib/libbsp/unix/posix/tools/configure.ac (added) * c/src/lib/libcpu/a29k/configure.ac (added) * c/src/lib/libcpu/configure.ac (added) * c/src/lib/libcpu/hppa1.1/configure.ac (added) * c/src/lib/libcpu/i386/configure.ac (added) * c/src/lib/libcpu/i960/configure.ac (added) * c/src/lib/libcpu/m68k/configure.ac (added) * c/src/lib/libcpu/mips/configure.ac (added) * c/src/lib/libcpu/mips64orion/configure.ac (added) * c/src/lib/libcpu/powerpc/configure.ac (added) * c/src/lib/libcpu/sh/configure.ac (added) * c/src/lib/libcpu/sh/sh7032/configure.ac (added) * c/src/lib/libcpu/sh/sh7045/configure.ac (added) * c/src/lib/libcpu/sh/sh7750/configure.ac (modified) * c/src/lib/libcpu/sparc/configure.ac (added) * c/src/libchip/configure.ac (added) * c/src/libfs/configure.ac (added) * c/src/libmisc/configure.ac (added) * c/src/libnetworking/configure.ac (added) * c/src/librdbg/configure.ac (added) * c/src/librpc/configure.ac (added) * c/src/librtems++/configure.ac (added) * c/src/make/configure.ac (added) * c/src/tests/configure.ac (added) * c/src/tests/itrontests/configure.ac (added) * c/src/tests/libtests/configure.ac (added) * c/src/tests/mptests/configure.ac (added) * c/src/tests/psxtests/configure.ac (added) * c/src/tests/samples/configure.ac (added) * c/src/tests/sptests/configure.ac (added) * c/src/tests/support/configure.ac (added) * c/src/tests/tmitrontests/configure.ac (added) * c/src/tests/tmtests/configure.ac (added) * c/src/tests/tools/configure.ac (added) * c/src/tests/tools/generic/configure.ac (added) * c/src/wrapup/configure.ac (added) * contrib/cygwin/configure.ac (added) * cpukit/libcsupport/configure.ac (added) * cpukit/libfs/configure.ac (added) * cpukit/libmisc/configure.ac (added) * cpukit/libnetworking/configure.ac (added) * cpukit/librpc/configure.ac (added) * cpukit/score/cpu/powerpc/configure.ac (added) * cpukit/score/cpu/sh/configure.ac (added) * cpukit/score/cpu/sparc/configure.ac (added) * scripts-ada/configure.ac (added) * scripts/configure.ac (added) * testsuites/configure.ac (added) * testsuites/itrontests/configure.ac (added) * testsuites/libtests/configure.ac (added) * testsuites/mptests/configure.ac (added) * testsuites/psxtests/configure.ac (added) * testsuites/samples/configure.ac (added) * testsuites/sptests/configure.ac (added) * testsuites/support/configure.ac (added) * testsuites/tmitrontests/configure.ac (added) * testsuites/tmtests/configure.ac (added) * testsuites/tools/configure.ac (added) * testsuites/tools/generic/configure.ac (added) * tools/build/configure.ac (added) * tools/cpu/configure.ac (added) * tools/cpu/generic/configure.ac (added) * tools/cpu/hppa1.1/configure.ac (added) * tools/cpu/sh/configure.ac (added) * tools/cpu/unix/configure.ac (added) * tools/update/configure.ac (added) 2001-10-11 Ralf Corsepius * ... Fri, 12 Oct 2001 13:43:05 GMT Joel Sherrill [aee474b] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/README (modified) * c/src/libnetworking/pppd/STATUS (modified) * c/src/libnetworking/pppd/cbcp.c (modified) * c/src/libnetworking/pppd/cbcp.h (modified) * c/src/libnetworking/pppd/chat.c (modified) * c/src/libnetworking/pppd/example/README (modified) * c/src/libnetworking/pppd/example/pppd.options (added) * c/src/libnetworking/pppd/modem_example/16550.h (deleted) * c/src/libnetworking/pppd/modem_example/README (deleted) * c/src/libnetworking/pppd/modem_example/modem.c (deleted) * c/src/libnetworking/pppd/modem_example/modem.h (deleted) * c/src/libnetworking/pppd/modem_example/ppp.c (deleted) * c/src/libnetworking/pppd/modem_example/ppp.h (deleted) * c/src/libnetworking/pppd/modem_example/pppcompress.c (deleted) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/rtemsmain.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/pppd/README (modified) * cpukit/pppd/STATUS (modified) * cpukit/pppd/cbcp.c (modified) * cpukit/pppd/cbcp.h (modified) * cpukit/pppd/chat.c (modified) * cpukit/pppd/example/README (modified) * cpukit/pppd/example/pppd.options (added) * cpukit/pppd/pppd.h (modified) * cpukit/pppd/rtemsmain.c (modified) 2001-10-12 Mike Siers * Update to ... Thu, 11 Oct 2001 19:36:23 GMT Joel Sherrill [df25c998] * c/src/.cvsignore (modified) * c/src/ChangeLog (modified) * c/src/exec/libcsupport/.cvsignore (modified) * c/src/exec/libfs/.cvsignore (modified) * c/src/exec/libfs/ChangeLog (modified) * c/src/exec/libnetworking/.cvsignore (modified) * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/librpc/.cvsignore (modified) * c/src/exec/librpc/ChangeLog (modified) * c/src/exec/score/cpu/powerpc/.cvsignore (modified) * c/src/exec/score/cpu/powerpc/ChangeLog (modified) * c/src/exec/score/cpu/sh/.cvsignore (modified) * c/src/exec/score/cpu/sh/ChangeLog (modified) * c/src/exec/score/cpu/sparc/.cvsignore (modified) * c/src/exec/score/cpu/sparc/ChangeLog (modified) * c/src/exec/score/cpu/unix/.cvsignore (modified) * c/src/exec/score/cpu/unix/ChangeLog (modified) * c/src/lib/.cvsignore (modified) * c/src/lib/ChangeLog (modified) * c/src/lib/libbsp/.cvsignore (modified) * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/a29k/.cvsignore (modified) * c/src/lib/libbsp/a29k/ChangeLog (modified) * c/src/lib/libbsp/a29k/portsw/.cvsignore (modified) * c/src/lib/libbsp/a29k/portsw/ChangeLog (modified) * c/src/lib/libbsp/arm/.cvsignore (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/.cvsignore (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/.cvsignore (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/.cvsignore (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/bare/.cvsignore (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/c4x/.cvsignore (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/.cvsignore (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/.cvsignore (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/h8300/.cvsignore (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/.cvsignore (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/.cvsignore (modified) * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/.cvsignore (modified) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/.cvsignore (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/.cvsignore (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/.cvsignore (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/.cvsignore (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/.cvsignore (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/.cvsignore (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/.cvsignore (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i960/.cvsignore (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/.cvsignore (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/.cvsignore (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/.cvsignore (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/m68k/.cvsignore (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/.cvsignore (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/.cvsignore (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/.cvsignore (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/.cvsignore (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/.cvsignore (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/.cvsignore (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/.cvsignore (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/.cvsignore (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/.cvsignore (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/.cvsignore (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/mips/.cvsignore (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/.cvsignore (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/.cvsignore (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/.cvsignore (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/.cvsignore (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/.cvsignore (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/.cvsignore (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/.cvsignore (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/.cvsignore (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/powerpc/.cvsignore (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/.cvsignore (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/.cvsignore (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/.cvsignore (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/.cvsignore (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/.cvsignore (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/papyrus/.cvsignore (modified) * c/src/lib/libbsp/powerpc/papyrus/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/.cvsignore (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/.cvsignore (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/.cvsignore (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/.cvsignore (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sparc/.cvsignore (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/.cvsignore (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/.cvsignore (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/.cvsignore (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/.cvsignore (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/.cvsignore (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/.cvsignore (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/.cvsignore (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libcpu/.cvsignore (modified) * c/src/lib/libcpu/ChangeLog (modified) * c/src/lib/libcpu/a29k/.cvsignore (modified) * c/src/lib/libcpu/a29k/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/.cvsignore (modified) * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/i386/.cvsignore (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i960/.cvsignore (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/m68k/.cvsignore (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/mips/.cvsignore (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/.cvsignore (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/powerpc/.cvsignore (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/sh/.cvsignore (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/.cvsignore (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/.cvsignore (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sparc/.cvsignore (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/libchip/.cvsignore (modified) * c/src/libchip/ChangeLog (modified) * c/src/libfs/.cvsignore (modified) * c/src/libfs/ChangeLog (modified) * c/src/libmisc/.cvsignore (modified) * c/src/libmisc/ChangeLog (modified) * c/src/libnetworking/.cvsignore (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/librdbg/.cvsignore (modified) * c/src/librdbg/ChangeLog (modified) * c/src/librpc/.cvsignore (modified) * c/src/librpc/ChangeLog (modified) * c/src/librtems++/.cvsignore (modified) * c/src/librtems++/ChangeLog (modified) * c/src/make/.cvsignore (modified) * c/src/make/ChangeLog (modified) * c/src/tests/.cvsignore (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/itrontests/.cvsignore (modified) * c/src/tests/itrontests/ChangeLog (modified) * c/src/tests/libtests/.cvsignore (modified) * c/src/tests/libtests/ChangeLog (modified) * c/src/tests/mptests/.cvsignore (modified) * c/src/tests/mptests/ChangeLog (modified) * c/src/tests/psxtests/.cvsignore (modified) * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/samples/.cvsignore (modified) * c/src/tests/samples/ChangeLog (modified) * c/src/tests/sptests/.cvsignore (modified) * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/support/.cvsignore (modified) * c/src/tests/support/ChangeLog (modified) * c/src/tests/tmitrontests/.cvsignore (modified) * c/src/tests/tmitrontests/ChangeLog (modified) * c/src/tests/tmtests/.cvsignore (modified) * c/src/tests/tmtests/ChangeLog (modified) * c/src/tests/tools/.cvsignore (modified) * c/src/tests/tools/ChangeLog (modified) * c/src/tests/tools/generic/.cvsignore (modified) * c/src/tests/tools/generic/ChangeLog (modified) * c/src/wrapup/.cvsignore (modified) * c/src/wrapup/ChangeLog (modified) * contrib/cygwin/.cvsignore (modified) * contrib/cygwin/ChangeLog (modified) * cpukit/libcsupport/.cvsignore (modified) * cpukit/libfs/.cvsignore (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libmisc/.cvsignore (modified) * cpukit/libmisc/ChangeLog (modified) * cpukit/libnetworking/.cvsignore (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/librpc/.cvsignore (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/.cvsignore (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/sh/.cvsignore (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sparc/.cvsignore (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/unix/.cvsignore (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * scripts-ada/.cvsignore (modified) * scripts-ada/ChangeLog (modified) * scripts/.cvsignore (modified) * scripts/ChangeLog (modified) * testsuites/.cvsignore (modified) * testsuites/ChangeLog (modified) * testsuites/itrontests/.cvsignore (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/libtests/.cvsignore (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/mptests/.cvsignore (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/psxtests/.cvsignore (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/samples/.cvsignore (modified) * testsuites/samples/ChangeLog (modified) * testsuites/sptests/.cvsignore (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/support/.cvsignore (modified) * testsuites/support/ChangeLog (modified) * testsuites/tmitrontests/.cvsignore (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmtests/.cvsignore (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tools/.cvsignore (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/generic/.cvsignore (modified) * testsuites/tools/generic/ChangeLog (modified) * tools/build/.cvsignore (modified) * tools/build/ChangeLog (modified) * tools/cpu/.cvsignore (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/generic/.cvsignore (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/hppa1.1/.cvsignore (modified) * tools/cpu/hppa1.1/ChangeLog (modified) * tools/cpu/sh/.cvsignore (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/unix/.cvsignore (modified) * tools/cpu/unix/ChangeLog (modified) * tools/update/.cvsignore (modified) * tools/update/ChangeLog (modified) 2001-10-11 Ralf Corsepius * ... Thu, 27 Sep 2001 13:31:56 GMT Joel Sherrill [1ef8e3d4] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) 2001-09-27 Eric Norum * ... Thu, 27 Sep 2001 13:28:22 GMT Joel Sherrill [b68e01c5] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/arpa/Makefile.am (modified) * c/src/exec/libnetworking/machine/Makefile.am (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/netinet/Makefile.am (modified) * c/src/exec/libnetworking/nfs/Makefile.am (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/exec/libnetworking/sys/Makefile.am (modified) * c/src/exec/libnetworking/vm/Makefile.am (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/arpa/Makefile.am (modified) * c/src/libnetworking/machine/Makefile.am (modified) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/netinet/Makefile.am (modified) * c/src/libnetworking/nfs/Makefile.am (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_telnetd/Makefile.am (modified) * c/src/libnetworking/rtems_webserver/Makefile.am (modified) * c/src/libnetworking/sys/Makefile.am (modified) * c/src/libnetworking/vm/Makefile.am (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/arpa/Makefile.am (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/vm/Makefile.am (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/telnetd/Makefile.am (modified) 2001-09-23 Ralf Corsepius * ... Mon, 24 Sep 2001 18:29:46 GMT Joel Sherrill [0d30932] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) 2001-09-22 Ralf Corsepius * ... Wed, 19 Sep 2001 17:40:37 GMT Joel Sherrill [5400f07] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) 2001-09-19 Eric Norum * ... Wed, 19 Sep 2001 17:30:38 GMT Joel Sherrill [4bde2394] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/exec/libnetworking/rtems/rtems_bootp.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/rtems/rtems_bootp.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) 2001-09-19 Chris Johns * ... Wed, 19 Sep 2001 17:29:42 GMT Joel Sherrill [d34d2e69] * c/src/exec/libnetworking/rtems/mkrootfs.c (added) * c/src/exec/libnetworking/rtems/mkrootfs.h (added) * c/src/libmisc/ChangeLog (modified) * c/src/libmisc/Makefile.am (modified) * c/src/libmisc/configure.in (modified) * c/src/libmisc/rootfs/.cvsignore (added) * c/src/libmisc/rootfs/Makefile.am (added) * c/src/libmisc/rootfs/mkrootfs.c (added) * c/src/libmisc/rootfs/mkrootfs.h (added) * c/src/libnetworking/rtems/mkrootfs.c (added) * c/src/libnetworking/rtems/mkrootfs.h (added) * cpukit/libmisc/ChangeLog (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libnetworking/rtems/mkrootfs.c (added) * cpukit/libnetworking/rtems/mkrootfs.h (added) 2001-09-19 Chris Johns * Added support ... Fri, 17 Aug 2001 20:17:18 GMT Joel Sherrill [1946544] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/STATUS (modified) * c/src/libnetworking/pppd/cbcp.c (added) * c/src/libnetworking/pppd/cbcp.h (added) * cpukit/libnetworking/ChangeLog (modified) * cpukit/pppd/STATUS (modified) * cpukit/pppd/cbcp.c (added) * cpukit/pppd/cbcp.h (added) 2001-08-16 Mike Siers * ... Thu, 16 Aug 2001 21:01:31 GMT Joel Sherrill [b8575ab] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/example/Makefile-user (moved) * c/src/libnetworking/pppd/example/README (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/pppd/example/Makefile-user (added) * cpukit/pppd/example/README (modified) 2001-08-16 Joel Sherrill * ... Thu, 16 Aug 2001 20:42:09 GMT Joel Sherrill [2f1b930] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/net/if_ppp.h (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/modem/ppp_tty.c (modified) * c/src/libnetworking/net/if_ppp.h (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/pppd/README (modified) * c/src/libnetworking/pppd/STATUS (modified) * c/src/libnetworking/pppd/auth.c (modified) * c/src/libnetworking/pppd/cbcp.c (deleted) * c/src/libnetworking/pppd/cbcp.h (deleted) * c/src/libnetworking/pppd/ccp.c (modified) * c/src/libnetworking/pppd/ccp.h (modified) * c/src/libnetworking/pppd/chap.c (modified) * c/src/libnetworking/pppd/chap.h (modified) * c/src/libnetworking/pppd/chap_ms.c (modified) * c/src/libnetworking/pppd/chat.c (modified) * c/src/libnetworking/pppd/demand.c (modified) * c/src/libnetworking/pppd/example/Makefile (added) * c/src/libnetworking/pppd/example/README (added) * c/src/libnetworking/pppd/example/init.c (added) * c/src/libnetworking/pppd/example/netconfig.h (added) * c/src/libnetworking/pppd/example/ppp.conf (added) * c/src/libnetworking/pppd/example/pppdapp.c (added) * c/src/libnetworking/pppd/example/system.h (added) * c/src/libnetworking/pppd/fsm.c (modified) * c/src/libnetworking/pppd/fsm.h (modified) * c/src/libnetworking/pppd/ipcp.c (modified) * c/src/libnetworking/pppd/ipcp.h (modified) * c/src/libnetworking/pppd/ipxcp.c (modified) * c/src/libnetworking/pppd/ipxcp.h (modified) * c/src/libnetworking/pppd/lcp.c (modified) * c/src/libnetworking/pppd/lcp.h (modified) * c/src/libnetworking/pppd/magic.c (modified) * c/src/libnetworking/pppd/main.c (deleted) * c/src/libnetworking/pppd/options.c (modified) * c/src/libnetworking/pppd/patchlevel.h (modified) * c/src/libnetworking/pppd/pathnames.h (modified) * c/src/libnetworking/pppd/ppp_tty.c (deleted) * c/src/libnetworking/pppd/pppd.8 (added) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/pppmain.c (deleted) * c/src/libnetworking/pppd/rtemsmain.c (added) * c/src/libnetworking/pppd/rtemspppd.c (added) * c/src/libnetworking/pppd/rtemspppd.h (added) * c/src/libnetworking/pppd/sys-rtems.c (moved) * c/src/libnetworking/pppd/upap.c (modified) * c/src/libnetworking/pppd/upap.h (modified) * c/src/libnetworking/pppd/utils.c (added) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/net/if_ppp.h (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/README (modified) * cpukit/pppd/STATUS (modified) * cpukit/pppd/auth.c (modified) * cpukit/pppd/cbcp.c (deleted) * cpukit/pppd/cbcp.h (deleted) * cpukit/pppd/ccp.c (modified) * cpukit/pppd/ccp.h (modified) * cpukit/pppd/chap.c (modified) * cpukit/pppd/chap.h (modified) * cpukit/pppd/chap_ms.c (modified) * cpukit/pppd/chat.c (modified) * cpukit/pppd/demand.c (modified) * cpukit/pppd/example/README (added) * cpukit/pppd/example/init.c (added) * cpukit/pppd/example/netconfig.h (added) * cpukit/pppd/example/ppp.conf (added) * cpukit/pppd/example/pppdapp.c (added) * cpukit/pppd/example/system.h (added) * cpukit/pppd/fsm.c (modified) * cpukit/pppd/fsm.h (modified) * cpukit/pppd/ipcp.c (modified) * cpukit/pppd/ipcp.h (modified) * cpukit/pppd/ipxcp.c (modified) * cpukit/pppd/ipxcp.h (modified) * cpukit/pppd/lcp.c (modified) * cpukit/pppd/lcp.h (modified) * cpukit/pppd/magic.c (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/patchlevel.h (modified) * cpukit/pppd/pathnames.h (modified) * cpukit/pppd/pppd.8 (added) * cpukit/pppd/pppd.h (modified) * cpukit/pppd/rtemsmain.c (added) * cpukit/pppd/rtemspppd.c (added) * cpukit/pppd/rtemspppd.h (added) * cpukit/pppd/sys-rtems.c (added) * cpukit/pppd/upap.c (modified) * cpukit/pppd/upap.h (modified) * cpukit/pppd/utils.c (added) 2001-08-16 Mike Siers * Update of ... Thu, 16 Aug 2001 18:49:28 GMT Joel Sherrill [bfe5d15] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/rtems_telnetd/.cvsignore (added) * cpukit/libnetworking/ChangeLog (modified) 2001-08-16 Joel Sherrill * ... Thu, 09 Aug 2001 22:06:51 GMT Joel Sherrill [bd520203] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_servers/telnetd.h (deleted) * c/src/libnetworking/rtems_telnetd/Makefile.am (added) * c/src/libnetworking/rtems_telnetd/README (added) * c/src/libnetworking/rtems_telnetd/icmds.c (added) * c/src/libnetworking/rtems_telnetd/pty.c (added) * c/src/libnetworking/rtems_telnetd/pty.h (added) * c/src/libnetworking/rtems_telnetd/telnetd.c (moved) * c/src/libnetworking/rtems_telnetd/telnetd.h (added) * c/src/libnetworking/wrapup/Makefile.am (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) * cpukit/telnetd/Makefile.am (added) * cpukit/telnetd/README (added) * cpukit/telnetd/icmds.c (added) * cpukit/telnetd/pty.c (added) * cpukit/telnetd/pty.h (added) * cpukit/telnetd/telnetd.c (added) * cpukit/telnetd/telnetd.h (added) 2001-08-09 Fernando-Ruiz Casas ... Mon, 18 Jun 2001 22:36:09 GMT Joel Sherrill [1a7ea60] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) 2001-05-26 Ralf Corsepius * ... Thu, 14 Jun 2001 13:35:47 GMT Joel Sherrill [451198be] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) 2001-06-14 Joel Sherrill * ... Thu, 10 May 2001 13:03:32 GMT Joel Sherrill [d85594d] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/libc/Makefile.am (modified) 2001-05-09 Ralf Corsepius * ... Tue, 24 Apr 2001 21:02:03 GMT Joel Sherrill [126405d9] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) 2000-04-24 Eric Norum * ... Fri, 20 Apr 2001 20:32:08 GMT Joel Sherrill [6fa6367] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/modem/ppp.c (modified) * c/src/libnetworking/pppd/STATUS (modified) * c/src/libnetworking/pppd/main.c (modified) * c/src/libnetworking/pppd/modem_example/modem.c (modified) * c/src/libnetworking/pppd/modem_example/ppp.c (modified) * c/src/libnetworking/pppd/pppmain.c (modified) * c/src/libnetworking/pppd/rtems-ppp.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/pppd/STATUS (modified) 2001-04-20 Radzislaw Galler * ... Fri, 20 Apr 2001 19:17:08 GMT Joel Sherrill [a8c33268] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/rtems_servers/ftpd.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/libnetworking/ChangeLog (modified) 2001-04-20 Jake Janovetz * ... Thu, 15 Mar 2001 13:42:58 GMT Joel Sherrill [a2cc545e] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/include/.cvsignore (deleted) * cpukit/libnetworking/ChangeLog (modified) 2001-03-15 Ralf Corsepiu * ... Mon, 05 Mar 2001 23:01:43 GMT Joel Sherrill [07fbfced] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/rtems_servers/ftpd.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/libnetworking/ChangeLog (modified) 2001-01-31 Sergei Organov * ...
