# # ChangeLog for cpukit/libnetworking in rtems # # Generated by Trac 1.2.1.dev0 # 05/06/24 09:33:45 Wed, 01 Dec 1999 16:00:38 GMT Joel Sherrill [5d3da15b] * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) Removed debugging printfs. Wed, 01 Dec 1999 15:54:17 GMT Joel Sherrill [017061c] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Patch from Eric Norum to fix a spot in the tftp ... Tue, 30 Nov 1999 22:14:28 GMT Joel Sherrill [42881534] * c/src/exec/libnetworking/net/if_ppp.h (added) * c/src/exec/libnetworking/net/ppp-comp.h (added) * c/src/libnetworking/net/if_ppp.h (added) * c/src/libnetworking/net/ppp-comp.h (added) * cpukit/libnetworking/net/if_ppp.h (added) * cpukit/libnetworking/net/ppp-comp.h (added) Added missing files from PPP port. Tue, 30 Nov 1999 22:12:50 GMT Joel Sherrill [d0950ad] * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/net/ppp_defs.h (added) * c/src/exec/libnetworking/sys/syslog.h (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/net/ppp_defs.h (added) * c/src/libnetworking/pppd/Makefile.in (added) * c/src/libnetworking/pppd/README (added) * c/src/libnetworking/pppd/STATUS (added) * c/src/libnetworking/pppd/auth.c (added) * c/src/libnetworking/pppd/cbcp.c (added) * c/src/libnetworking/pppd/cbcp.h (added) * c/src/libnetworking/pppd/ccp.c (added) * c/src/libnetworking/pppd/ccp.h (added) * c/src/libnetworking/pppd/chap.c (added) * c/src/libnetworking/pppd/chap.h (added) * c/src/libnetworking/pppd/chap_ms.c (added) * c/src/libnetworking/pppd/chap_ms.h (added) * c/src/libnetworking/pppd/chat.c (added) * c/src/libnetworking/pppd/demand.c (added) * c/src/libnetworking/pppd/fsm.c (added) * c/src/libnetworking/pppd/fsm.h (added) * c/src/libnetworking/pppd/ipcp.c (added) * c/src/libnetworking/pppd/ipcp.h (added) * c/src/libnetworking/pppd/ipxcp.c (added) * c/src/libnetworking/pppd/ipxcp.h (added) * c/src/libnetworking/pppd/lcp.c (added) * c/src/libnetworking/pppd/lcp.h (added) * c/src/libnetworking/pppd/magic.c (added) * c/src/libnetworking/pppd/magic.h (added) * c/src/libnetworking/pppd/main.c (added) * c/src/libnetworking/pppd/md4.c (added) * c/src/libnetworking/pppd/md4.h (added) * c/src/libnetworking/pppd/md5.c (added) * c/src/libnetworking/pppd/md5.h (added) * c/src/libnetworking/pppd/options.c (added) * c/src/libnetworking/pppd/patchlevel.h (added) * c/src/libnetworking/pppd/pathnames.h (added) * c/src/libnetworking/pppd/ppp_tty.c (added) * c/src/libnetworking/pppd/pppd.h (added) * c/src/libnetworking/pppd/rtems-ppp.c (added) * c/src/libnetworking/pppd/upap.c (added) * c/src/libnetworking/pppd/upap.h (added) * c/src/libnetworking/sys/syslog.h (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/net/ppp_defs.h (added) * cpukit/libnetworking/sys/syslog.h (modified) * cpukit/pppd/README (added) * cpukit/pppd/STATUS (added) * cpukit/pppd/auth.c (added) * cpukit/pppd/cbcp.c (added) * cpukit/pppd/cbcp.h (added) * cpukit/pppd/ccp.c (added) * cpukit/pppd/ccp.h (added) * cpukit/pppd/chap.c (added) * cpukit/pppd/chap.h (added) * cpukit/pppd/chap_ms.c (added) * cpukit/pppd/chap_ms.h (added) * cpukit/pppd/chat.c (added) * cpukit/pppd/demand.c (added) * cpukit/pppd/fsm.c (added) * cpukit/pppd/fsm.h (added) * cpukit/pppd/ipcp.c (added) * cpukit/pppd/ipcp.h (added) * cpukit/pppd/ipxcp.c (added) * cpukit/pppd/ipxcp.h (added) * cpukit/pppd/lcp.c (added) * cpukit/pppd/lcp.h (added) * cpukit/pppd/magic.c (added) * cpukit/pppd/magic.h (added) * cpukit/pppd/md4.c (added) * cpukit/pppd/md4.h (added) * cpukit/pppd/md5.c (added) * cpukit/pppd/md5.h (added) * cpukit/pppd/options.c (added) * cpukit/pppd/patchlevel.h (added) * cpukit/pppd/pathnames.h (added) * cpukit/pppd/pppd.h (added) * cpukit/pppd/upap.c (added) * cpukit/pppd/upap.h (added) Added port of ppp-2.3.5 from Tomasz Domin of ComArch ... Tue, 16 Nov 1999 16:14:37 GMT Joel Sherrill [65a38bc] * c/src/exec/libnetworking/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * cpukit/libnetworking/Makefile.am (modified) Web server uses the POSIX API. Therefor, it must be disabled when ... Wed, 10 Nov 1999 14:31:11 GMT Joel Sherrill [cbccd37] * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (added) * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (added) * c/src/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (added) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) Patch from Eric Norum which includes: ... Tue, 09 Nov 1999 03:43:47 GMT Joel Sherrill [a0af97d] * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to add NTP BOOTP support ... Wed, 27 Oct 1999 12:50:33 GMT Joel Sherrill [c1cdaa0] * c/src/exec/libnetworking/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/rtems_webserver/Makefile.in (added) * c/src/libnetworking/rtems_webserver/asp.c (added) * c/src/libnetworking/rtems_webserver/balloc.c (added) * c/src/libnetworking/rtems_webserver/default.c (added) * c/src/libnetworking/rtems_webserver/ej.h (added) * c/src/libnetworking/rtems_webserver/ejlex.c (added) * c/src/libnetworking/rtems_webserver/ejparse.c (added) * c/src/libnetworking/rtems_webserver/form.c (added) * c/src/libnetworking/rtems_webserver/h.c (added) * c/src/libnetworking/rtems_webserver/handler.c (added) * c/src/libnetworking/rtems_webserver/mime.c (added) * c/src/libnetworking/rtems_webserver/misc.c (added) * c/src/libnetworking/rtems_webserver/ringq.c (added) * c/src/libnetworking/rtems_webserver/rom.c (added) * c/src/libnetworking/rtems_webserver/rtems_webserver.h (added) * c/src/libnetworking/rtems_webserver/security.c (added) * c/src/libnetworking/rtems_webserver/socket.c (added) * c/src/libnetworking/rtems_webserver/sym.c (added) * c/src/libnetworking/rtems_webserver/uemf.c (added) * c/src/libnetworking/rtems_webserver/uemf.h (added) * c/src/libnetworking/rtems_webserver/url.c (added) * c/src/libnetworking/rtems_webserver/value.c (added) * c/src/libnetworking/rtems_webserver/wbase64.c (added) * c/src/libnetworking/rtems_webserver/webcomp.c (added) * c/src/libnetworking/rtems_webserver/webmain.c (added) * c/src/libnetworking/rtems_webserver/webpage.c (added) * c/src/libnetworking/rtems_webserver/webrom.c (added) * c/src/libnetworking/rtems_webserver/webs.c (added) * c/src/libnetworking/rtems_webserver/webs.h (added) * c/src/libnetworking/rtems_webserver/websuemf.c (added) * c/src/libnetworking/rtems_webserver/wsIntrn.h (added) * c/src/libnetworking/wrapup/Makefile.in (modified) * cpukit/httpd/Makefile.in (added) * cpukit/httpd/asp.c (added) * cpukit/httpd/balloc.c (added) * cpukit/httpd/default.c (added) * cpukit/httpd/ej.h (added) * cpukit/httpd/ejlex.c (added) * cpukit/httpd/ejparse.c (added) * cpukit/httpd/form.c (added) * cpukit/httpd/h.c (added) * cpukit/httpd/handler.c (added) * cpukit/httpd/mime.c (added) * cpukit/httpd/misc.c (added) * cpukit/httpd/ringq.c (added) * cpukit/httpd/rom.c (added) * cpukit/httpd/rtems_webserver.h (added) * cpukit/httpd/security.c (added) * cpukit/httpd/socket.c (added) * cpukit/httpd/sym.c (added) * cpukit/httpd/uemf.c (added) * cpukit/httpd/uemf.h (added) * cpukit/httpd/url.c (added) * cpukit/httpd/value.c (added) * cpukit/httpd/wbase64.c (added) * cpukit/httpd/webcomp.c (added) * cpukit/httpd/webmain.c (added) * cpukit/httpd/webpage.c (added) * cpukit/httpd/webrom.c (added) * cpukit/httpd/webs.c (added) * cpukit/httpd/webs.h (added) * cpukit/httpd/websuemf.c (added) * cpukit/httpd/wsIntrn.h (added) * cpukit/libnetworking/Makefile.am (modified) Patch from Emmanuel Raguet and Eric Valette ... Mon, 25 Oct 1999 16:09:45 GMT Joel Sherrill [8379ada7] * c/src/exec/libnetworking/netinet/ip_input.c (modified) * c/src/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) Patch from Eric Norum to address the following ... Wed, 06 Oct 1999 20:37:26 GMT Joel Sherrill [1b821242] * c/src/exec/libnetworking/rtems/rtems_select.c (modified) * c/src/exec/libnetworking/rtems/rtems_showroute.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/network/network.c (modified) * c/src/libnetworking/rtems/rtems_select.c (modified) * c/src/libnetworking/rtems/rtems_showroute.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Modified to avoid conflicts on definitions of malloc. newlib 1.8.2 ... Mon, 04 Oct 1999 19:15:14 GMT Joel Sherrill [811804fe] * Makefile.am (modified) * c/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/exec/Makefile.am (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/posix/Makefile.am (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/rtems/Makefile.am (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/Makefile.am (modified) * c/src/exec/posix/inline/rtems/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/macros/Makefile.am (modified) * c/src/exec/posix/macros/rtems/Makefile.am (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/rtems/Makefile.am (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/inline/Makefile.am (modified) * c/src/exec/rtems/inline/rtems/Makefile.am (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/sapi/Makefile.am (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/inline/Makefile.am (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/score/Makefile.am (modified) * c/src/exec/score/include/Makefile.am (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/inline/Makefile.am (modified) * c/src/exec/score/inline/rtems/Makefile.am (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/Makefile.am (modified) * c/src/exec/score/macros/rtems/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/wrapup/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/rdbg/Makefile.am (modified) * c/src/lib/include/rdbg/i386/Makefile.am (modified) * c/src/lib/include/rdbg/powerpc/Makefile.am (modified) * c/src/lib/include/rpc/Makefile.am (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libchip/Makefile.am (modified) * c/src/lib/libmisc/Makefile.am (modified) * c/src/lib/start/Makefile.am (modified) * c/src/libchip/Makefile.am (modified) * c/src/libmisc/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/custom/Makefile.am (modified) * c/src/tests/Makefile.am (modified) * c/src/tests/libtests/Makefile.am (modified) * c/src/tests/mptests/Makefile.am (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/samples/Makefile.am (modified) * c/src/tests/sptests/Makefile.am (modified) * c/src/tests/support/Makefile.am (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/tmtests/Makefile.am (modified) * c/src/tests/tmtests/include/Makefile.am (modified) * c/src/tests/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/posix/inline/Makefile.am (modified) * cpukit/posix/macros/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/rtems/inline/Makefile.am (modified) * cpukit/rtems/macros/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/Makefile.am (modified) * cpukit/sapi/inline/Makefile.am (modified) * cpukit/sapi/macros/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/Makefile.am (modified) * cpukit/score/inline/Makefile.am (modified) * cpukit/score/macros/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) * make/Makefile.am (modified) * make/Templates/Makefile.am (modified) * make/compilers/Makefile.am (modified) * make/custom/Makefile.am (modified) * testsuites/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/support/Makefile.am (modified) * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/include/Makefile.am (modified) * testsuites/tools/Makefile.am (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/unix/Makefile.am (modified) * tools/update/Makefile.am (modified) Patch from Ralf Corsepius to make fix bug ... Mon, 04 Oct 1999 18:40:53 GMT Joel Sherrill [cc63e08] * c/src/configure.in (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/libnetworking/CHANGELOG (deleted) * c/src/lib/libnetworking/Makefile.am (deleted) * c/src/lib/libnetworking/README (deleted) * c/src/lib/libnetworking/aclocal.m4 (deleted) * c/src/lib/libnetworking/arpa/ftp.h (deleted) * c/src/lib/libnetworking/arpa/inet.h (deleted) * c/src/lib/libnetworking/arpa/nameser.h (deleted) * c/src/lib/libnetworking/arpa/nameser_compat.h (deleted) * c/src/lib/libnetworking/arpa/telnet.h (deleted) * c/src/lib/libnetworking/bpfilter.h (deleted) * c/src/lib/libnetworking/configure (deleted) * c/src/lib/libnetworking/configure.in (deleted) * c/src/lib/libnetworking/include/Makefile.in (deleted) * c/src/lib/libnetworking/kern/Makefile.in (deleted) * c/src/lib/libnetworking/kern/kern_subr.c (deleted) * c/src/lib/libnetworking/kern/uipc_domain.c (deleted) * c/src/lib/libnetworking/kern/uipc_mbuf.c (deleted) * c/src/lib/libnetworking/kern/uipc_socket.c (deleted) * c/src/lib/libnetworking/kern/uipc_socket2.c (deleted) * c/src/lib/libnetworking/lib/Makefile.in (deleted) * c/src/lib/libnetworking/lib/README (deleted) * c/src/lib/libnetworking/lib/getprotoby.c (deleted) * c/src/lib/libnetworking/lib/syslog.c (deleted) * c/src/lib/libnetworking/lib/tftpDriver.c (deleted) * c/src/lib/libnetworking/libc/Makefile.in (deleted) * c/src/lib/libnetworking/libc/addr2ascii.3 (deleted) * c/src/lib/libnetworking/libc/addr2ascii.c (deleted) * c/src/lib/libnetworking/libc/ascii2addr.c (deleted) * c/src/lib/libnetworking/libc/base64.c (deleted) * c/src/lib/libnetworking/libc/byteorder.3 (deleted) * c/src/lib/libnetworking/libc/ether_addr.c (deleted) * c/src/lib/libnetworking/libc/ethers.3 (deleted) * c/src/lib/libnetworking/libc/gethostbydns.c (deleted) * c/src/lib/libnetworking/libc/gethostbyht.c (deleted) * c/src/lib/libnetworking/libc/gethostbyname.3 (deleted) * c/src/lib/libnetworking/libc/gethostbynis.c (deleted) * c/src/lib/libnetworking/libc/gethostnamadr.c (deleted) * c/src/lib/libnetworking/libc/gethostname.c (deleted) * c/src/lib/libnetworking/libc/getnetbydns.c (deleted) * c/src/lib/libnetworking/libc/getnetbyht.c (deleted) * c/src/lib/libnetworking/libc/getnetbynis.c (deleted) * c/src/lib/libnetworking/libc/getnetent.3 (deleted) * c/src/lib/libnetworking/libc/getnetnamadr.c (deleted) * c/src/lib/libnetworking/libc/getproto.c (deleted) * c/src/lib/libnetworking/libc/getprotoent.3 (deleted) * c/src/lib/libnetworking/libc/getprotoent.c (deleted) * c/src/lib/libnetworking/libc/getprotoname.c (deleted) * c/src/lib/libnetworking/libc/getservbyname.c (deleted) * c/src/lib/libnetworking/libc/getservbyport.c (deleted) * c/src/lib/libnetworking/libc/getservent.3 (deleted) * c/src/lib/libnetworking/libc/getservent.c (deleted) * c/src/lib/libnetworking/libc/herror.c (deleted) * c/src/lib/libnetworking/libc/inet.3 (deleted) * c/src/lib/libnetworking/libc/inet_addr.c (deleted) * c/src/lib/libnetworking/libc/inet_lnaof.c (deleted) * c/src/lib/libnetworking/libc/inet_makeaddr.c (deleted) * c/src/lib/libnetworking/libc/inet_net_ntop.c (deleted) * c/src/lib/libnetworking/libc/inet_net_pton.c (deleted) * c/src/lib/libnetworking/libc/inet_neta.c (deleted) * c/src/lib/libnetworking/libc/inet_netof.c (deleted) * c/src/lib/libnetworking/libc/inet_network.c (deleted) * c/src/lib/libnetworking/libc/inet_ntoa.c (deleted) * c/src/lib/libnetworking/libc/inet_ntop.c (deleted) * c/src/lib/libnetworking/libc/inet_pton.c (deleted) * c/src/lib/libnetworking/libc/iso_addr.3 (deleted) * c/src/lib/libnetworking/libc/iso_addr.c (deleted) * c/src/lib/libnetworking/libc/linkaddr.3 (deleted) * c/src/lib/libnetworking/libc/linkaddr.c (deleted) * c/src/lib/libnetworking/libc/map_v4v6.c (deleted) * c/src/lib/libnetworking/libc/ns.3 (deleted) * c/src/lib/libnetworking/libc/ns_addr.c (deleted) * c/src/lib/libnetworking/libc/ns_name.c (deleted) * c/src/lib/libnetworking/libc/ns_netint.c (deleted) * c/src/lib/libnetworking/libc/ns_ntoa.c (deleted) * c/src/lib/libnetworking/libc/ns_parse.c (deleted) * c/src/lib/libnetworking/libc/ns_print.c (deleted) * c/src/lib/libnetworking/libc/ns_ttl.c (deleted) * c/src/lib/libnetworking/libc/nsap_addr.c (deleted) * c/src/lib/libnetworking/libc/rcmd.3 (deleted) * c/src/lib/libnetworking/libc/rcmd.c (deleted) * c/src/lib/libnetworking/libc/recv.c (deleted) * c/src/lib/libnetworking/libc/res_comp.c (deleted) * c/src/lib/libnetworking/libc/res_config.h (deleted) * c/src/lib/libnetworking/libc/res_data.c (deleted) * c/src/lib/libnetworking/libc/res_debug.c (deleted) * c/src/lib/libnetworking/libc/res_init.c (deleted) * c/src/lib/libnetworking/libc/res_mkquery.c (deleted) * c/src/lib/libnetworking/libc/res_mkupdate.c (deleted) * c/src/lib/libnetworking/libc/res_query.c (deleted) * c/src/lib/libnetworking/libc/res_send.c (deleted) * c/src/lib/libnetworking/libc/res_stubs.c (deleted) * c/src/lib/libnetworking/libc/res_update.c (deleted) * c/src/lib/libnetworking/libc/resolver.3 (deleted) * c/src/lib/libnetworking/libc/send.c (deleted) * c/src/lib/libnetworking/libc/strsep.c (deleted) * c/src/lib/libnetworking/loop.h (deleted) * c/src/lib/libnetworking/machine/conf.h (deleted) * c/src/lib/libnetworking/machine/cpu.h (deleted) * c/src/lib/libnetworking/machine/cpufunc.h (deleted) * c/src/lib/libnetworking/machine/endian.h (deleted) * c/src/lib/libnetworking/machine/in_cksum.h (deleted) * c/src/lib/libnetworking/machine/limits.h (deleted) * c/src/lib/libnetworking/machine/param.h (deleted) * c/src/lib/libnetworking/machine/types.h (deleted) * c/src/lib/libnetworking/machine/vmparam.h (deleted) * c/src/lib/libnetworking/net/Makefile.in (deleted) * c/src/lib/libnetworking/net/bpf.h (deleted) * c/src/lib/libnetworking/net/ethernet.h (deleted) * c/src/lib/libnetworking/net/if.c (deleted) * c/src/lib/libnetworking/net/if.h (deleted) * c/src/lib/libnetworking/net/if_arp.h (deleted) * c/src/lib/libnetworking/net/if_dl.h (deleted) * c/src/lib/libnetworking/net/if_ethersubr.c (deleted) * c/src/lib/libnetworking/net/if_llc.h (deleted) * c/src/lib/libnetworking/net/if_loop.c (deleted) * c/src/lib/libnetworking/net/if_types.h (deleted) * c/src/lib/libnetworking/net/netisr.h (deleted) * c/src/lib/libnetworking/net/radix.c (deleted) * c/src/lib/libnetworking/net/radix.h (deleted) * c/src/lib/libnetworking/net/raw_cb.c (deleted) * c/src/lib/libnetworking/net/raw_cb.h (deleted) * c/src/lib/libnetworking/net/raw_usrreq.c (deleted) * c/src/lib/libnetworking/net/route.c (deleted) * c/src/lib/libnetworking/net/route.h (deleted) * c/src/lib/libnetworking/net/rtsock.c (deleted) * c/src/lib/libnetworking/netdb.h (deleted) * c/src/lib/libnetworking/netinet/Makefile.in (deleted) * c/src/lib/libnetworking/netinet/icmp_var.h (deleted) * c/src/lib/libnetworking/netinet/if_ether.c (deleted) * c/src/lib/libnetworking/netinet/if_ether.h (deleted) * c/src/lib/libnetworking/netinet/igmp.c (deleted) * c/src/lib/libnetworking/netinet/igmp.h (deleted) * c/src/lib/libnetworking/netinet/igmp_var.h (deleted) * c/src/lib/libnetworking/netinet/in.c (deleted) * c/src/lib/libnetworking/netinet/in.h (deleted) * c/src/lib/libnetworking/netinet/in_cksum.c (deleted) * c/src/lib/libnetworking/netinet/in_cksum_i386.c (deleted) * c/src/lib/libnetworking/netinet/in_cksum_m68k.c (deleted) * c/src/lib/libnetworking/netinet/in_cksum_powerpc.c (deleted) * c/src/lib/libnetworking/netinet/in_pcb.c (deleted) * c/src/lib/libnetworking/netinet/in_pcb.h (deleted) * c/src/lib/libnetworking/netinet/in_proto.c (deleted) * c/src/lib/libnetworking/netinet/in_rmx.c (deleted) * c/src/lib/libnetworking/netinet/in_systm.h (deleted) * c/src/lib/libnetworking/netinet/in_var.h (deleted) * c/src/lib/libnetworking/netinet/ip.h (deleted) * c/src/lib/libnetworking/netinet/ip_divert.c (deleted) * c/src/lib/libnetworking/netinet/ip_fw.c (deleted) * c/src/lib/libnetworking/netinet/ip_fw.h (deleted) * c/src/lib/libnetworking/netinet/ip_icmp.c (deleted) * c/src/lib/libnetworking/netinet/ip_icmp.h (deleted) * c/src/lib/libnetworking/netinet/ip_input.c (deleted) * c/src/lib/libnetworking/netinet/ip_mroute.c (deleted) * c/src/lib/libnetworking/netinet/ip_mroute.h (deleted) * c/src/lib/libnetworking/netinet/ip_output.c (deleted) * c/src/lib/libnetworking/netinet/ip_var.h (deleted) * c/src/lib/libnetworking/netinet/raw_ip.c (deleted) * c/src/lib/libnetworking/netinet/tcp.h (deleted) * c/src/lib/libnetworking/netinet/tcp_debug.c (deleted) * c/src/lib/libnetworking/netinet/tcp_debug.h (deleted) * c/src/lib/libnetworking/netinet/tcp_fsm.h (deleted) * c/src/lib/libnetworking/netinet/tcp_input.c (deleted) * c/src/lib/libnetworking/netinet/tcp_output.c (deleted) * c/src/lib/libnetworking/netinet/tcp_seq.h (deleted) * c/src/lib/libnetworking/netinet/tcp_subr.c (deleted) * c/src/lib/libnetworking/netinet/tcp_timer.c (deleted) * c/src/lib/libnetworking/netinet/tcp_timer.h (deleted) * c/src/lib/libnetworking/netinet/tcp_usrreq.c (deleted) * c/src/lib/libnetworking/netinet/tcp_var.h (deleted) * c/src/lib/libnetworking/netinet/tcpip.h (deleted) * c/src/lib/libnetworking/netinet/udp.h (deleted) * c/src/lib/libnetworking/netinet/udp_usrreq.c (deleted) * c/src/lib/libnetworking/netinet/udp_var.h (deleted) * c/src/lib/libnetworking/nfs/Makefile.in (deleted) * c/src/lib/libnetworking/nfs/bootp_subr.c (deleted) * c/src/lib/libnetworking/nfs/krpc.h (deleted) * c/src/lib/libnetworking/nfs/nfs.h (deleted) * c/src/lib/libnetworking/nfs/nfsdiskless.h (deleted) * c/src/lib/libnetworking/nfs/nfsproto.h (deleted) * c/src/lib/libnetworking/nfs/rpcv2.h (deleted) * c/src/lib/libnetworking/nfs/xdr_subs.h (deleted) * c/src/lib/libnetworking/opt_ipfw.h (deleted) * c/src/lib/libnetworking/opt_mrouting.h (deleted) * c/src/lib/libnetworking/opt_tcpdebug.h (deleted) * c/src/lib/libnetworking/poll.h (deleted) * c/src/lib/libnetworking/resolv.h (deleted) * c/src/lib/libnetworking/rtems/Makefile.in (deleted) * c/src/lib/libnetworking/rtems/issetugid.c (deleted) * c/src/lib/libnetworking/rtems/rtems_bootp.c (deleted) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (deleted) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (deleted) * c/src/lib/libnetworking/rtems/rtems_glue.c (deleted) * c/src/lib/libnetworking/rtems/rtems_select.c (deleted) * c/src/lib/libnetworking/rtems/rtems_showicmpstat.c (deleted) * c/src/lib/libnetworking/rtems/rtems_showifstat.c (deleted) * c/src/lib/libnetworking/rtems/rtems_showipstat.c (deleted) * c/src/lib/libnetworking/rtems/rtems_showmbuf.c (deleted) * c/src/lib/libnetworking/rtems/rtems_showroute.c (deleted) * c/src/lib/libnetworking/rtems/rtems_showtcpstat.c (deleted) * c/src/lib/libnetworking/rtems/rtems_showudpstat.c (deleted) * c/src/lib/libnetworking/rtems/rtems_syscall.c (deleted) * c/src/lib/libnetworking/rtems/sghostname.c (deleted) * c/src/lib/libnetworking/rtems/tftp.h (deleted) * c/src/lib/libnetworking/rtems_servers/Makefile.in (deleted) * c/src/lib/libnetworking/rtems_servers/ftpd.c (deleted) * c/src/lib/libnetworking/rtems_servers/ftpd.h (deleted) * c/src/lib/libnetworking/sys/buf.h (deleted) * c/src/lib/libnetworking/sys/callout.h (deleted) * c/src/lib/libnetworking/sys/cdefs.h (deleted) * c/src/lib/libnetworking/sys/conf.h (deleted) * c/src/lib/libnetworking/sys/domain.h (deleted) * c/src/lib/libnetworking/sys/filio.h (deleted) * c/src/lib/libnetworking/sys/ioccom.h (deleted) * c/src/lib/libnetworking/sys/ioctl.h (deleted) * c/src/lib/libnetworking/sys/kernel.h (deleted) * c/src/lib/libnetworking/sys/libkern.h (deleted) * c/src/lib/libnetworking/sys/malloc.h (deleted) * c/src/lib/libnetworking/sys/mbuf.h (deleted) * c/src/lib/libnetworking/sys/mount.h (deleted) * c/src/lib/libnetworking/sys/param.h (deleted) * c/src/lib/libnetworking/sys/proc.h (deleted) * c/src/lib/libnetworking/sys/protosw.h (deleted) * c/src/lib/libnetworking/sys/queue.h (deleted) * c/src/lib/libnetworking/sys/reboot.h (deleted) * c/src/lib/libnetworking/sys/resourcevar.h (deleted) * c/src/lib/libnetworking/sys/rtprio.h (deleted) * c/src/lib/libnetworking/sys/select.h (deleted) * c/src/lib/libnetworking/sys/signalvar.h (deleted) * c/src/lib/libnetworking/sys/socket.h (deleted) * c/src/lib/libnetworking/sys/socketvar.h (deleted) * c/src/lib/libnetworking/sys/sockio.h (deleted) * c/src/lib/libnetworking/sys/sysctl.h (deleted) * c/src/lib/libnetworking/sys/syslimits.h (deleted) * c/src/lib/libnetworking/sys/syslog.h (deleted) * c/src/lib/libnetworking/sys/systm.h (deleted) * c/src/lib/libnetworking/sys/ttycom.h (deleted) * c/src/lib/libnetworking/sys/ttydefaults.h (deleted) * c/src/lib/libnetworking/sys/ucred.h (deleted) * c/src/lib/libnetworking/sys/uio.h (deleted) * c/src/lib/libnetworking/syslog.h (deleted) * c/src/lib/libnetworking/vm/vm.h (deleted) * c/src/lib/libnetworking/vm/vm_extern.h (deleted) * c/src/lib/libnetworking/vm/vm_kern.h (deleted) * c/src/lib/libnetworking/vm/vm_param.h (deleted) * c/src/lib/libnetworking/wrapup/Makefile.in (deleted) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) Patch from Ralf Corsepius to make ... Mon, 04 Oct 1999 13:51:22 GMT Joel Sherrill [6fca2f5] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) Patch from Eric Norum . Comments follow: ... Tue, 07 Sep 1999 13:45:03 GMT Joel Sherrill [e1d8abb] * Makefile.in (modified) * aclocal/check-cxx.m4 (modified) * automake/local.am (modified) * c/Makefile.in (modified) * c/src/Makefile.am (modified) * c/src/Makefile.in (modified) * c/src/aclocal.m4 (modified) * c/src/configure (modified) * c/src/configure.in (modified) * c/src/exec/Makefile.am (added) * c/src/exec/Makefile.in (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/configure.in (modified) * c/src/exec/libcsupport/Makefile.am (added) * c/src/exec/libnetworking/Makefile.am (added) * c/src/exec/librpc/include/rpc/Makefile.am (added) * c/src/exec/posix/Makefile.am (added) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/configure.in (added) * c/src/exec/posix/include/Makefile.am (added) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.am (added) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (added) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.am (added) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.am (added) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.am (added) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (added) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.am (added) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.am (added) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (added) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.am (added) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.am (added) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.am (added) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (added) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.am (added) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.am (added) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (added) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.am (added) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.am (added) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (added) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/sapi/Makefile.am (added) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.am (added) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.am (added) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.am (added) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (added) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.am (added) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (added) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/score/Makefile.am (added) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/configure.in (added) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.am (added) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.am (added) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/inline/Makefile.am (added) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.am (added) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (added) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.am (added) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.am (added) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (added) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/wrapup/Makefile.am (added) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/lib/Makefile.am (added) * c/src/lib/Makefile.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (added) * c/src/lib/include/Makefile.in (modified) * c/src/lib/include/motorola/Makefile.am (added) * c/src/lib/include/rdbg/Makefile.am (added) * c/src/lib/include/rdbg/i386/Makefile.am (added) * c/src/lib/include/rdbg/powerpc/Makefile.am (added) * c/src/lib/include/rpc/Makefile.am (added) * c/src/lib/include/sys/Makefile.am (added) * c/src/lib/include/zilog/Makefile.am (added) * c/src/lib/libbsp/Makefile.am.new (added) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/configure.in (added) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libchip/Makefile.am (added) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/configure.in (added) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/configure.in (added) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.in (modified) * c/src/lib/libmisc/Makefile.am (added) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/configure.in (added) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/untar/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.am (added) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/configure.in (added) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librdbg/configure.in (added) * c/src/lib/librdbg/i386/Makefile.in (modified) * c/src/lib/librdbg/i386/pc386/Makefile.in (modified) * c/src/lib/librdbg/powerpc/Makefile.in (modified) * c/src/lib/librdbg/powerpc/mcp750/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librpc/configure.in (added) * c/src/lib/start/Makefile.am (added) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/a29k/configure.in (added) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/i960/configure.in (added) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/m68k/configure.in (added) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/mips64orion/configure.in (added) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/start/sh/configure.in (added) * c/src/libchip/Makefile.am (added) * c/src/libchip/configure.in (added) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/Makefile.am (added) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/configure.in (added) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/untar/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.am (added) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/configure.in (added) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/include/rdbg/Makefile.am (added) * c/src/librdbg/include/rdbg/i386/Makefile.am (added) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (added) * c/src/librdbg/src/Makefile.in (modified) * c/src/librdbg/src/configure.in (added) * c/src/librdbg/src/i386/Makefile.in (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librdbg/src/powerpc/Makefile.in (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.in (modified) * c/src/librpc/include/rpc/Makefile.am (added) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/Makefile.am (added) * c/src/librtems++/Makefile.in (added) * c/src/librtems++/aclocal.m4 (added) * c/src/librtems++/configure (added) * c/src/librtems++/configure.in (added) * c/src/librtems++/include/Makefile.am (added) * c/src/librtems++/include/Makefile.in (added) * c/src/librtems++/include/rtems++/Makefile.am (added) * c/src/librtems++/include/rtems++/Makefile.in (added) * c/src/make/Makefile.in (modified) * c/src/make/aclocal.m4 (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/aclocal.m4 (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/aclocal.m4 (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * cpukit/Makefile.am (added) * cpukit/libcsupport/Makefile.am (added) * cpukit/libmisc/Makefile.am (added) * cpukit/libnetworking/Makefile.am (added) * cpukit/librpc/include/rpc/Makefile.am (added) * cpukit/posix/Makefile.am (added) * cpukit/posix/include/Makefile.am (added) * cpukit/posix/inline/Makefile.am (added) * cpukit/posix/macros/Makefile.am (added) * cpukit/rtems/Makefile.am (added) * cpukit/rtems/include/Makefile.am (added) * cpukit/rtems/inline/Makefile.am (added) * cpukit/rtems/macros/Makefile.am (added) * cpukit/sapi/Makefile.am (added) * cpukit/sapi/include/Makefile.am (added) * cpukit/sapi/inline/Makefile.am (added) * cpukit/sapi/macros/Makefile.am (added) * cpukit/score/Makefile.am (added) * cpukit/score/include/Makefile.am (added) * cpukit/score/inline/Makefile.am (added) * cpukit/score/macros/Makefile.am (added) * cpukit/wrapup/Makefile.am (added) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/Templates/Makefile.in (modified) * make/compilers/Makefile.in (modified) * make/custom/Makefile.in (modified) * tools/Makefile.in (modified) * tools/build/Makefile.in (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/configure (modified) * tools/cpu/configure.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) * tools/update/configure (modified) * tools/update/configure.in (modified) Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius ... Thu, 26 Aug 1999 20:52:40 GMT Joel Sherrill [e0c6f43] * c/src/exec/libnetworking/rtems/tftp.h (modified) * c/src/lib/libnetworking/rtems/tftp.h (modified) * c/src/libnetworking/rtems/tftp.h (modified) * cpukit/libnetworking/rtems/tftp.h (modified) Comment cleanup from Eric Norum . Mon, 23 Aug 1999 14:58:16 GMT Joel Sherrill [48abdc31] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/lib/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Patch from Eric Norum to readd the behavior where ... Mon, 12 Jul 1999 15:52:35 GMT Joel Sherrill [09ea257c] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/lib/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Patch from Eric Norum : I get the following ... Tue, 15 Jun 1999 22:16:30 GMT Joel Sherrill [937ab62c] * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/src/base_fs.c (modified) * c/src/exec/libcsupport/src/mount.c (modified) * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/libc/base_fs.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/mount.c (modified) * c/src/lib/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) After comments D. V. Henkel-Wallace , the interface ... Fri, 11 Jun 1999 14:11:44 GMT Joel Sherrill [a6f3cff] * c/src/exec/libnetworking/kern/uipc_socket.c (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/sys/socket.h (modified) * c/src/exec/libnetworking/sys/socketvar.h (modified) * c/src/lib/libnetworking/kern/uipc_socket.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/sys/socket.h (modified) * c/src/lib/libnetworking/sys/socketvar.h (modified) * c/src/libnetworking/kern/uipc_socket.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/sys/socket.h (modified) * c/src/libnetworking/sys/socketvar.h (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/sys/socket.h (modified) * cpukit/libnetworking/sys/socketvar.h (modified) Patch from Ian Lance Taylor : The select function ... Fri, 11 Jun 1999 14:06:13 GMT Joel Sherrill [0643693] * c/src/exec/libnetworking/rtems/rtems_select.c (modified) * c/src/lib/libnetworking/rtems/rtems_select.c (modified) * c/src/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) Patch from Eric Norum to fix bug reported by Ian ... Fri, 28 May 1999 18:21:25 GMT Joel Sherrill [f74abcf7] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Changes from Eric Norum to add a loop and limit on the length of time ... Fri, 28 May 1999 16:09:00 GMT Joel Sherrill [403d7b18] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Alignment corrected per Eric Norum's suggestion. Thu, 27 May 1999 18:03:50 GMT Joel Sherrill [11cdbeb] * c/src/exec/libnetworking/kern/uipc_mbuf.c (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/sys/mbuf.h (modified) * c/src/lib/libnetworking/kern/uipc_mbuf.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/sys/mbuf.h (modified) * c/src/libnetworking/kern/uipc_mbuf.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/sys/mbuf.h (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/sys/mbuf.h (modified) Patch from Eric Norum to eliminate a panic ... Thu, 20 May 1999 13:32:54 GMT Joel Sherrill [8bbaf3b] * c/src/exec/libnetworking/sys/mbuf.h (modified) * c/src/lib/libnetworking/sys/mbuf.h (modified) * c/src/libnetworking/sys/mbuf.h (modified) * cpukit/libnetworking/sys/mbuf.h (modified) Removed all post 4.0 changes. Mon, 17 May 1999 15:45:15 GMT Joel Sherrill [a238cc9] * c/src/exec/libnetworking/kern/uipc_domain.c (modified) * c/src/exec/libnetworking/kern/uipc_mbuf.c (modified) * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/lib/libnetworking/kern/uipc_domain.c (modified) * c/src/lib/libnetworking/kern/uipc_mbuf.c (modified) * c/src/lib/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/kern/uipc_domain.c (modified) * c/src/libnetworking/kern/uipc_mbuf.c (modified) * c/src/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/kern/uipc_domain.c (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) Patch from D. V. Henkel-Wallace to remove compiler ... Fri, 07 May 1999 16:30:44 GMT Joel Sherrill [acb644a6] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/lib/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Error reporting fixed by Jennifer. Tue, 27 Apr 1999 17:31:39 GMT Joel Sherrill [cfcb5a2] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to corrent a miscount in ... Mon, 19 Apr 1999 17:17:41 GMT Joel Sherrill [4186b3b] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/sys/ioccom.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/sys/ioccom.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Changed ioctl() prototype to be more like Linux/POSIX than BSD to ... Mon, 19 Apr 1999 15:27:21 GMT Joel Sherrill [ac91855d] * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) After discussion with Eric Norum , I added ... Thu, 01 Apr 1999 16:36:22 GMT Joel Sherrill [517660f1] * c/src/exec/libnetworking/machine/in_cksum.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/machine/in_cksum.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/machine/in_cksum.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/machine/in_cksum.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Moved sparc specific version of in_cksum_hdr to an inline routine ... Wed, 31 Mar 1999 20:51:07 GMT Joel Sherrill [efa0baa5] * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Patch from Eric Norum which changed the exit ... Tue, 30 Mar 1999 17:43:51 GMT Joel Sherrill [ceb06d96] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Removed warning for `#ifdef' argument starts with punctuation. Tue, 30 Mar 1999 15:40:29 GMT Joel Sherrill [6a4096b] * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Patch to add shutdown() routine from Tony R. Ambardar . Tue, 23 Mar 1999 23:06:42 GMT Joel Sherrill [e828c2dd] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) SPARC optimized version of IP checksum header routine. Submitted by ... Tue, 23 Mar 1999 22:39:13 GMT Joel Sherrill [b6f5f93] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to improve parsing of ... Fri, 19 Mar 1999 21:51:58 GMT Joel Sherrill [af020036] * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/src/fcntl.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/libc/fcntl.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Patch from Eric Norum that adds external ... Mon, 01 Mar 1999 22:40:08 GMT Joel Sherrill [73f6236] * c/src/exec/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/src/close.c (modified) * c/src/exec/libcsupport/src/fchmod.c (modified) * c/src/exec/libcsupport/src/fcntl.c (modified) * c/src/exec/libcsupport/src/fdatasync.c (modified) * c/src/exec/libcsupport/src/fpathconf.c (modified) * c/src/exec/libcsupport/src/fstat.c (modified) * c/src/exec/libcsupport/src/fsync.c (modified) * c/src/exec/libcsupport/src/ftruncate.c (modified) * c/src/exec/libcsupport/src/ioctl.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/libio_sockets.c (modified) * c/src/exec/libcsupport/src/lseek.c (modified) * c/src/exec/libcsupport/src/read.c (modified) * c/src/exec/libcsupport/src/write.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_select.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/include/rtems/libio_.h (modified) * c/src/lib/libc/close.c (modified) * c/src/lib/libc/fchmod.c (modified) * c/src/lib/libc/fcntl.c (modified) * c/src/lib/libc/fdatasync.c (modified) * c/src/lib/libc/fpathconf.c (modified) * c/src/lib/libc/fstat.c (modified) * c/src/lib/libc/fsync.c (modified) * c/src/lib/libc/ftruncate.c (modified) * c/src/lib/libc/ioctl.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/libio_.h (modified) * c/src/lib/libc/libio_sockets.c (modified) * c/src/lib/libc/lseek.c (modified) * c/src/lib/libc/read.c (modified) * c/src/lib/libc/write.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_select.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_select.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/fpathconf.c (modified) * cpukit/libcsupport/src/fstat.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/libio_sockets.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/write.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Patch from Eric Norum to eliminate external ... Fri, 05 Feb 1999 00:29:23 GMT Joel Sherrill [ecec2ba] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to correct bug induced by select() patch. Thu, 04 Feb 1999 15:00:14 GMT Joel Sherrill [354b00bc] * c/src/exec/libnetworking/sys/mbuf.h (modified) * c/src/lib/libnetworking/sys/mbuf.h (modified) * c/src/libnetworking/sys/mbuf.h (modified) * cpukit/libnetworking/sys/mbuf.h (modified) Added printf()'s that can be uncommented to trace MBUF operations. ... Thu, 04 Feb 1999 14:59:42 GMT Joel Sherrill [83c7b00] * c/src/exec/libnetworking/rtems/tftp.h (modified) * c/src/lib/libnetworking/rtems/tftp.h (modified) * c/src/libnetworking/rtems/tftp.h (modified) * cpukit/libnetworking/rtems/tftp.h (modified) Modifed to reflect transition from device driver to file system. Thu, 04 Feb 1999 14:58:01 GMT Joel Sherrill [d3c1060] * c/src/exec/libnetworking/net/if.h (modified) * c/src/lib/libnetworking/net/if.h (modified) * c/src/libnetworking/net/if.h (modified) * cpukit/libnetworking/net/if.h (modified) Added debug printf()'s that are commented out. Uncommenting these ... Thu, 04 Feb 1999 14:56:09 GMT Joel Sherrill [1564ca8] * c/src/exec/libnetworking/netinet/in_cksum_powerpc.c (modified) * c/src/lib/libnetworking/netinet/in_cksum_powerpc.c (modified) * c/src/libnetworking/netinet/in_cksum_powerpc.c (modified) * cpukit/libnetworking/netinet/in_cksum_powerpc.c (modified) * cpukit/libnetworking/netinet/in_cksum_powerpc.h (modified) Added PowerPC specific header checksum code. Thu, 04 Feb 1999 14:56:03 GMT Joel Sherrill [8cce445] * c/src/exec/libnetworking/machine/in_cksum.h (modified) * c/src/lib/libnetworking/machine/in_cksum.h (modified) * c/src/libnetworking/machine/in_cksum.h (modified) * cpukit/libnetworking/machine/in_cksum.h (modified) Added PowerPC specific header checksum code. Added volatile to i386 ... Thu, 04 Feb 1999 14:54:31 GMT Joel Sherrill [c1a37d3e] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/lib/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Debugged and now works except for handling of minor number. Thu, 04 Feb 1999 14:53:06 GMT Joel Sherrill [7c7fd4d] * c/src/exec/libnetworking/netinet/tcp_debug.c (modified) * c/src/exec/libnetworking/opt_tcpdebug.h (modified) * c/src/lib/libnetworking/netinet/tcp_debug.c (modified) * c/src/lib/libnetworking/opt_tcpdebug.h (modified) * c/src/libnetworking/netinet/tcp_debug.c (modified) * c/src/libnetworking/opt_tcpdebug.h (modified) * cpukit/libnetworking/netinet/tcp_debug.c (modified) * cpukit/libnetworking/opt_tcpdebug.h (modified) Modified to include comments on how to get TCPDEBUG turned on and ... Tue, 02 Feb 1999 21:15:15 GMT Joel Sherrill [13e11f6] * c/src/exec/libnetworking/netinet/ip_icmp.c (modified) * c/src/lib/libnetworking/netinet/ip_icmp.c (modified) * c/src/libnetworking/netinet/ip_icmp.c (modified) * cpukit/libnetworking/netinet/ip_icmp.c (modified) Added debug #define and commented it out. Tue, 02 Feb 1999 21:15:02 GMT Joel Sherrill [5d5f23b] * c/src/exec/libnetworking/netinet/in_cksum.c (modified) * c/src/lib/libnetworking/netinet/in_cksum.c (modified) * c/src/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) Added PowerPC specific in_cksum file. Tue, 02 Feb 1999 21:14:44 GMT Joel Sherrill [9b9c4dfd] * c/src/exec/libnetworking/netinet/in_cksum_powerpc.c (added) * c/src/lib/libnetworking/netinet/in_cksum_powerpc.c (added) * c/src/libnetworking/netinet/in_cksum_powerpc.c (added) * cpukit/libnetworking/netinet/in_cksum_powerpc.c (added) * cpukit/libnetworking/netinet/in_cksum_powerpc.h (added) New file. Based on the i386 version. Sun, 31 Jan 1999 20:50:49 GMT Joel Sherrill [7b158663] * c/src/exec/libnetworking/sys/mbuf.h (modified) * c/src/lib/libnetworking/sys/mbuf.h (modified) * c/src/libnetworking/sys/mbuf.h (modified) * cpukit/libnetworking/sys/mbuf.h (modified) Prepended macro variables with "_" to avoid name conflicts in expansions. Thu, 28 Jan 1999 18:42:34 GMT Joel Sherrill [cdf8a300] * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Patch from Eric Norum to avoid dereferencing ... Tue, 26 Jan 1999 01:50:31 GMT Joel Sherrill [39ba9122] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Changed prototype of rtems_bsdnet_makeFdForSocket to (void *) pointer ... Tue, 26 Jan 1999 01:49:56 GMT Joel Sherrill [887618b0] * c/src/exec/libnetworking/netinet/in_cksum.c (modified) * c/src/lib/libnetworking/netinet/in_cksum.c (modified) * c/src/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) Switched from printf() to puts(). Thu, 21 Jan 1999 22:25:43 GMT Joel Sherrill [94b3ee13] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/exec/libnetworking/libc/res_config.h (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_select.c (added) * c/src/exec/libnetworking/rtems/sghostname.c (modified) * c/src/lib/libnetworking/lib/tftpDriver.c (modified) * c/src/lib/libnetworking/libc/res_config.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_select.c (added) * c/src/lib/libnetworking/rtems/sghostname.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/libc/res_config.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_select.c (added) * c/src/libnetworking/rtems/sghostname.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/libc/res_config.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_select.c (added) * cpukit/libnetworking/rtems/sghostname.c (modified) Made to compile after hacking tftp driver into beginnings of a mini- ... Tue, 19 Jan 1999 20:23:15 GMT Joel Sherrill [a7c4314d] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/lib/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Added comments for changing to a filesystem Mon, 04 Jan 1999 16:35:31 GMT Joel Sherrill [eb0d7ae] * c/src/exec/libnetworking/netinet/in_cksum_i386.c (modified) * c/src/lib/libnetworking/netinet/in_cksum_i386.c (modified) * c/src/libnetworking/netinet/in_cksum_i386.c (modified) * cpukit/libnetworking/netinet/in_cksum_i386.c (modified) * cpukit/libnetworking/netinet/in_cksum_i386.h (modified) Patch from D. V. Henkel-Wallace to use puts and ... Mon, 04 Jan 1999 16:30:06 GMT Joel Sherrill [88a0908] * c/src/exec/libnetworking/netinet/tcp_input.c (modified) * c/src/lib/libnetworking/netinet/tcp_input.c (modified) * c/src/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) Patch from D. V. Henkel-Wallace to fix braces ... Mon, 04 Jan 1999 16:28:49 GMT Joel Sherrill [60a2d689] * c/src/exec/libnetworking/net/route.h (modified) * c/src/lib/libnetworking/net/route.h (modified) * c/src/libnetworking/net/route.h (modified) * cpukit/libnetworking/net/route.h (modified) Patch from D. V. Henkel-Wallace to make macro nest ... Thu, 10 Dec 1998 23:31:54 GMT Joel Sherrill [cca4400] * VERSION (modified) * c/src/exec/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/sys/sockio.h (modified) * c/src/exec/libcsupport/src/close.c (modified) * c/src/exec/libcsupport/src/fchmod.c (modified) * c/src/exec/libcsupport/src/fcntl.c (modified) * c/src/exec/libcsupport/src/fdatasync.c (modified) * c/src/exec/libcsupport/src/fpathconf.c (modified) * c/src/exec/libcsupport/src/fsync.c (modified) * c/src/exec/libcsupport/src/ftruncate.c (modified) * c/src/exec/libcsupport/src/ioctl.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/lseek.c (modified) * c/src/exec/libcsupport/src/read.c (modified) * c/src/exec/libcsupport/src/write.c (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/include/rtems/libio_.h (modified) * c/src/lib/include/sys/sockio.h (modified) * c/src/lib/libc/close.c (modified) * c/src/lib/libc/fchmod.c (modified) * c/src/lib/libc/fcntl.c (modified) * c/src/lib/libc/fdatasync.c (modified) * c/src/lib/libc/fpathconf.c (modified) * c/src/lib/libc/fsync.c (modified) * c/src/lib/libc/ftruncate.c (modified) * c/src/lib/libc/ioctl.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/libio_.h (modified) * c/src/lib/libc/lseek.c (modified) * c/src/lib/libc/read.c (modified) * c/src/lib/libc/write.c (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/sys/sockio.h (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/sys/sockio.h (modified) * configure (modified) * configure.in (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/sys/sockio.h (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/fpathconf.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/write.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Merged Eric Norum's select patch that was based on 4.0 and resolved ... Thu, 10 Dec 1998 19:42:29 GMT Joel Sherrill [a3d0b8a] * c/src/exec/libcsupport/include/sys/sockio.h (modified) * c/src/exec/libnetworking/net/if.c (modified) * c/src/exec/libnetworking/net/if.h (modified) * c/src/exec/libnetworking/net/if_ethersubr.c (modified) * c/src/lib/include/sys/sockio.h (modified) * c/src/lib/libnetworking/net/if.c (modified) * c/src/lib/libnetworking/net/if.h (modified) * c/src/lib/libnetworking/net/if_ethersubr.c (modified) * c/src/lib/libnetworking/sys/sockio.h (modified) * c/src/libnetworking/net/if.c (modified) * c/src/libnetworking/net/if.h (modified) * c/src/libnetworking/net/if_ethersubr.c (modified) * c/src/libnetworking/sys/sockio.h (modified) * cpukit/libcsupport/include/sys/sockio.h (modified) * cpukit/libnetworking/net/if.c (modified) * cpukit/libnetworking/net/if.h (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) Patch from Ian Lance Taylor : From: Eric Norum ... Mon, 07 Dec 1998 17:42:52 GMT Joel Sherrill [91b1c8e6] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Patch from Ian Lance Taylor : RTEMS permits using ... Thu, 19 Nov 1998 17:35:49 GMT Joel Sherrill [847375f] * c/src/exec/libnetworking/kern/uipc_socket.c (modified) * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/sys/socketvar.h (modified) * c/src/exec/posix/src/psignal.c (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/src/thread.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/device-tree (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libnetworking/kern/uipc_socket.c (modified) * c/src/lib/libnetworking/nfs/bootp_subr.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/sys/socketvar.h (modified) * c/src/libnetworking/kern/uipc_socket.c (modified) * c/src/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/sys/socketvar.h (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/sys/socketvar.h (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/thread.c (modified) Patch from Eric Norum : 1) Socket ... Mon, 12 Oct 1998 17:21:12 GMT Joel Sherrill [b19cb17] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Added header files per request from Chris Johns to avoid problems in ... Tue, 29 Sep 1998 12:15:08 GMT Joel Sherrill [766ed7c] * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Patch from Eric Norum : Remember the ... Mon, 21 Sep 1998 00:46:00 GMT Joel Sherrill [718dc95] * c/src/exec/libnetworking/rtems/rtems_showroute.c (modified) * c/src/lib/libnetworking/rtems/rtems_showroute.c (modified) * c/src/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) Patch from Eric Norum : Here's a patch ... Mon, 21 Sep 1998 00:42:07 GMT Joel Sherrill [7ddcfb8c] * c/src/exec/libnetworking/netinet/in_cksum_m68k.c (modified) * c/src/lib/libnetworking/netinet/in_cksum_m68k.c (modified) * c/src/libnetworking/netinet/in_cksum_m68k.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.h (modified) Patch from Eric Norum and David Fiddes to put ColdFire support in ... Fri, 11 Sep 1998 13:12:04 GMT Joel Sherrill [b3956369] * c/src/exec/libnetworking/netinet/in_cksum_m68k.c (modified) * c/src/lib/libnetworking/netinet/in_cksum_m68k.c (modified) * c/src/libnetworking/netinet/in_cksum_m68k.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.h (modified) Patch from "David J. Fiddes" : I've ... Thu, 10 Sep 1998 12:43:00 GMT Joel Sherrill [23cdd84c] * c/src/exec/libnetworking/netinet/in_cksum_m68k.c (modified) * c/src/lib/libnetworking/netinet/in_cksum_m68k.c (modified) * c/src/libnetworking/netinet/in_cksum_m68k.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.h (modified) Patch from David Fiddes to make this compile ... Thu, 10 Sep 1998 12:23:08 GMT Joel Sherrill [109b17f4] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to fix a cryptic error ... Mon, 31 Aug 1998 23:09:17 GMT Joel Sherrill [4cf89a8] * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) Fixed spacing. More comments from Eric Norum need to be addressed. Mon, 31 Aug 1998 23:06:50 GMT Joel Sherrill [d9d75fc] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/network.c (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libc/newlibc.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) Patch from Emmanuel Raguet : I have reworked ... Fri, 21 Aug 1998 18:14:27 GMT Joel Sherrill [4de817d] * c/src/exec/libnetworking/netinet/in_cksum.c (modified) * c/src/exec/libnetworking/netinet/in_cksum_i386.c (added) * c/src/exec/libnetworking/netinet/in_cksum_m68k.c (added) * c/src/lib/libnetworking/netinet/in_cksum.c (modified) * c/src/lib/libnetworking/netinet/in_cksum_i386.c (added) * c/src/lib/libnetworking/netinet/in_cksum_m68k.c (added) * c/src/libnetworking/netinet/in_cksum.c (modified) * c/src/libnetworking/netinet/in_cksum_i386.c (added) * c/src/libnetworking/netinet/in_cksum_m68k.c (added) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum_i386.c (added) * cpukit/libnetworking/netinet/in_cksum_i386.h (added) * cpukit/libnetworking/netinet/in_cksum_m68k.c (added) * cpukit/libnetworking/netinet/in_cksum_m68k.h (added) Added i386 specific version of in_cksum.c and restructured the main ... Fri, 21 Aug 1998 17:37:01 GMT Joel Sherrill [617a1a2d] * c/src/exec/libnetworking/netinet/in_cksum.c (modified) * c/src/lib/libnetworking/netinet/in_cksum.c (modified) * c/src/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) Another missing piece. Thanks Eric. Fri, 21 Aug 1998 13:04:55 GMT Joel Sherrill [33679ec4] * c/src/exec/libnetworking/libc/res_send.c (modified) * c/src/exec/libnetworking/netinet/ip_input.c (modified) * c/src/exec/libnetworking/netinet/ip_mroute.c (modified) * c/src/exec/libnetworking/netinet/tcp_input.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_showroute.c (modified) * c/src/lib/libnetworking/libc/res_send.c (modified) * c/src/lib/libnetworking/netinet/ip_input.c (modified) * c/src/lib/libnetworking/netinet/ip_mroute.c (modified) * c/src/lib/libnetworking/netinet/tcp_input.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_showroute.c (modified) * c/src/libnetworking/libc/res_send.c (modified) * c/src/libnetworking/netinet/ip_input.c (modified) * c/src/libnetworking/netinet/ip_mroute.c (modified) * c/src/libnetworking/netinet/tcp_input.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) All warnings removed. Fri, 21 Aug 1998 12:51:29 GMT Joel Sherrill [ab09043a] * c/src/exec/libnetworking/libc/res_send.c (modified) * c/src/lib/libnetworking/libc/res_send.c (modified) * c/src/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) Fixed warning about pointer/integer conversion which turned out to be ... Thu, 20 Aug 1998 22:04:22 GMT Joel Sherrill [28e7d7fa] * c/Makefile.in (modified) * c/src/exec/libnetworking/arpa/inet.h (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/bare/README (modified) * c/src/lib/libbsp/bare/do-bare-bsp-build (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/network.c (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/README (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/arpa/inet.h (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libnetworking/arpa/inet.h (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/libnetworking/arpa/inet.h (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * make/Templates/Makefile.inc.in (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/target.cfg.in (modified) Patches from Eric Norum Thu, 20 Aug 1998 21:56:40 GMT Joel Sherrill [96b39164] * c/src/exec/libnetworking/README (modified) * c/src/exec/libnetworking/arpa/ftp.h (modified) * c/src/exec/libnetworking/arpa/telnet.h (modified) * c/src/exec/libnetworking/bpfilter.h (modified) * c/src/exec/libnetworking/lib/README (modified) * c/src/exec/libnetworking/lib/getprotoby.c (modified) * c/src/exec/libnetworking/libc/addr2ascii.3 (modified) * c/src/exec/libnetworking/libc/addr2ascii.c (modified) * c/src/exec/libnetworking/libc/ascii2addr.c (modified) * c/src/exec/libnetworking/libc/byteorder.3 (modified) * c/src/exec/libnetworking/libc/gethostname.c (modified) * c/src/exec/libnetworking/libc/getnetent.3 (modified) * c/src/exec/libnetworking/libc/getproto.c (modified) * c/src/exec/libnetworking/libc/getprotoent.3 (modified) * c/src/exec/libnetworking/libc/getprotoent.c (modified) * c/src/exec/libnetworking/libc/getprotoname.c (modified) * c/src/exec/libnetworking/libc/getservbyname.c (modified) * c/src/exec/libnetworking/libc/getservbyport.c (modified) * c/src/exec/libnetworking/libc/getservent.c (modified) * c/src/exec/libnetworking/libc/inet_lnaof.c (modified) * c/src/exec/libnetworking/libc/inet_makeaddr.c (modified) * c/src/exec/libnetworking/libc/inet_netof.c (modified) * c/src/exec/libnetworking/libc/inet_network.c (modified) * c/src/exec/libnetworking/libc/inet_ntoa.c (modified) * c/src/exec/libnetworking/libc/iso_addr.3 (modified) * c/src/exec/libnetworking/libc/iso_addr.c (modified) * c/src/exec/libnetworking/libc/linkaddr.c (modified) * c/src/exec/libnetworking/libc/ns_addr.c (modified) * c/src/exec/libnetworking/libc/ns_ntoa.c (modified) * c/src/exec/libnetworking/libc/rcmd.c (modified) * c/src/exec/libnetworking/libc/recv.c (modified) * c/src/exec/libnetworking/libc/res_config.h (modified) * c/src/exec/libnetworking/libc/resolver.3 (modified) * c/src/exec/libnetworking/libc/send.c (modified) * c/src/exec/libnetworking/libc/strsep.c (modified) * c/src/exec/libnetworking/loop.h (modified) * c/src/exec/libnetworking/machine/conf.h (modified) * c/src/exec/libnetworking/machine/cpu.h (modified) * c/src/exec/libnetworking/machine/cpufunc.h (modified) * c/src/exec/libnetworking/machine/endian.h (modified) * c/src/exec/libnetworking/machine/limits.h (modified) * c/src/exec/libnetworking/machine/param.h (modified) * c/src/exec/libnetworking/machine/types.h (modified) * c/src/exec/libnetworking/machine/vmparam.h (modified) * c/src/exec/libnetworking/opt_ipfw.h (modified) * c/src/exec/libnetworking/opt_mrouting.h (modified) * c/src/exec/libnetworking/opt_tcpdebug.h (modified) * c/src/exec/libnetworking/rtems/issetugid.c (modified) * c/src/exec/libnetworking/rtems/rtems_bootp.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_showicmpstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_showipstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_showmbuf.c (modified) * c/src/exec/libnetworking/rtems/rtems_showroute.c (modified) * c/src/exec/libnetworking/rtems/rtems_showtcpstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_showudpstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/libnetworking/rtems/sghostname.c (modified) * c/src/exec/libnetworking/sys/proc.h (modified) * c/src/exec/libnetworking/sys/resourcevar.h (modified) * c/src/exec/libnetworking/syslog.h (modified) * c/src/lib/libnetworking/CHANGELOG (modified) * c/src/lib/libnetworking/README (modified) * c/src/lib/libnetworking/arpa/ftp.h (modified) * c/src/lib/libnetworking/arpa/telnet.h (modified) * c/src/lib/libnetworking/bpfilter.h (modified) * c/src/lib/libnetworking/lib/README (modified) * c/src/lib/libnetworking/lib/getprotoby.c (modified) * c/src/lib/libnetworking/libc/addr2ascii.3 (modified) * c/src/lib/libnetworking/libc/addr2ascii.c (modified) * c/src/lib/libnetworking/libc/ascii2addr.c (modified) * c/src/lib/libnetworking/libc/byteorder.3 (modified) * c/src/lib/libnetworking/libc/gethostname.c (modified) * c/src/lib/libnetworking/libc/getnetent.3 (modified) * c/src/lib/libnetworking/libc/getproto.c (modified) * c/src/lib/libnetworking/libc/getprotoent.3 (modified) * c/src/lib/libnetworking/libc/getprotoent.c (modified) * c/src/lib/libnetworking/libc/getprotoname.c (modified) * c/src/lib/libnetworking/libc/getservbyname.c (modified) * c/src/lib/libnetworking/libc/getservbyport.c (modified) * c/src/lib/libnetworking/libc/getservent.c (modified) * c/src/lib/libnetworking/libc/inet_lnaof.c (modified) * c/src/lib/libnetworking/libc/inet_makeaddr.c (modified) * c/src/lib/libnetworking/libc/inet_netof.c (modified) * c/src/lib/libnetworking/libc/inet_network.c (modified) * c/src/lib/libnetworking/libc/inet_ntoa.c (modified) * c/src/lib/libnetworking/libc/iso_addr.3 (modified) * c/src/lib/libnetworking/libc/iso_addr.c (modified) * c/src/lib/libnetworking/libc/linkaddr.c (modified) * c/src/lib/libnetworking/libc/ns_addr.c (modified) * c/src/lib/libnetworking/libc/ns_ntoa.c (modified) * c/src/lib/libnetworking/libc/rcmd.c (modified) * c/src/lib/libnetworking/libc/recv.c (modified) * c/src/lib/libnetworking/libc/res_config.h (modified) * c/src/lib/libnetworking/libc/resolver.3 (modified) * c/src/lib/libnetworking/libc/send.c (modified) * c/src/lib/libnetworking/libc/strsep.c (modified) * c/src/lib/libnetworking/loop.h (modified) * c/src/lib/libnetworking/machine/conf.h (modified) * c/src/lib/libnetworking/machine/cpu.h (modified) * c/src/lib/libnetworking/machine/cpufunc.h (modified) * c/src/lib/libnetworking/machine/endian.h (modified) * c/src/lib/libnetworking/machine/limits.h (modified) * c/src/lib/libnetworking/machine/param.h (modified) * c/src/lib/libnetworking/machine/types.h (modified) * c/src/lib/libnetworking/machine/vmparam.h (modified) * c/src/lib/libnetworking/opt_ipfw.h (modified) * c/src/lib/libnetworking/opt_mrouting.h (modified) * c/src/lib/libnetworking/opt_tcpdebug.h (modified) * c/src/lib/libnetworking/rtems/issetugid.c (modified) * c/src/lib/libnetworking/rtems/rtems_bootp.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_showicmpstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_showipstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_showmbuf.c (modified) * c/src/lib/libnetworking/rtems/rtems_showroute.c (modified) * c/src/lib/libnetworking/rtems/rtems_showtcpstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_showudpstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/rtems/sghostname.c (modified) * c/src/lib/libnetworking/sys/proc.h (modified) * c/src/lib/libnetworking/sys/resourcevar.h (modified) * c/src/lib/libnetworking/syslog.h (modified) * c/src/libnetworking/CHANGELOG (modified) * c/src/libnetworking/README (modified) * c/src/libnetworking/arpa/ftp.h (modified) * c/src/libnetworking/arpa/telnet.h (modified) * c/src/libnetworking/bpfilter.h (modified) * c/src/libnetworking/lib/README (modified) * c/src/libnetworking/lib/getprotoby.c (modified) * c/src/libnetworking/libc/addr2ascii.3 (modified) * c/src/libnetworking/libc/addr2ascii.c (modified) * c/src/libnetworking/libc/ascii2addr.c (modified) * c/src/libnetworking/libc/byteorder.3 (modified) * c/src/libnetworking/libc/gethostname.c (modified) * c/src/libnetworking/libc/getnetent.3 (modified) * c/src/libnetworking/libc/getproto.c (modified) * c/src/libnetworking/libc/getprotoent.3 (modified) * c/src/libnetworking/libc/getprotoent.c (modified) * c/src/libnetworking/libc/getprotoname.c (modified) * c/src/libnetworking/libc/getservbyname.c (modified) * c/src/libnetworking/libc/getservbyport.c (modified) * c/src/libnetworking/libc/getservent.c (modified) * c/src/libnetworking/libc/inet_lnaof.c (modified) * c/src/libnetworking/libc/inet_makeaddr.c (modified) * c/src/libnetworking/libc/inet_netof.c (modified) * c/src/libnetworking/libc/inet_network.c (modified) * c/src/libnetworking/libc/inet_ntoa.c (modified) * c/src/libnetworking/libc/iso_addr.3 (modified) * c/src/libnetworking/libc/iso_addr.c (modified) * c/src/libnetworking/libc/linkaddr.c (modified) * c/src/libnetworking/libc/ns_addr.c (modified) * c/src/libnetworking/libc/ns_ntoa.c (modified) * c/src/libnetworking/libc/rcmd.c (modified) * c/src/libnetworking/libc/recv.c (modified) * c/src/libnetworking/libc/res_config.h (modified) * c/src/libnetworking/libc/resolver.3 (modified) * c/src/libnetworking/libc/send.c (modified) * c/src/libnetworking/libc/strsep.c (modified) * c/src/libnetworking/loop.h (modified) * c/src/libnetworking/machine/conf.h (modified) * c/src/libnetworking/machine/cpu.h (modified) * c/src/libnetworking/machine/cpufunc.h (modified) * c/src/libnetworking/machine/endian.h (modified) * c/src/libnetworking/machine/limits.h (modified) * c/src/libnetworking/machine/param.h (modified) * c/src/libnetworking/machine/types.h (modified) * c/src/libnetworking/machine/vmparam.h (modified) * c/src/libnetworking/opt_ipfw.h (modified) * c/src/libnetworking/opt_mrouting.h (modified) * c/src/libnetworking/opt_tcpdebug.h (modified) * c/src/libnetworking/rtems/issetugid.c (modified) * c/src/libnetworking/rtems/rtems_bootp.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_showicmpstat.c (modified) * c/src/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/libnetworking/rtems/rtems_showipstat.c (modified) * c/src/libnetworking/rtems/rtems_showmbuf.c (modified) * c/src/libnetworking/rtems/rtems_showroute.c (modified) * c/src/libnetworking/rtems/rtems_showtcpstat.c (modified) * c/src/libnetworking/rtems/rtems_showudpstat.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/sghostname.c (modified) * c/src/libnetworking/sys/proc.h (modified) * c/src/libnetworking/sys/resourcevar.h (modified) * c/src/libnetworking/syslog.h (modified) * cpukit/libnetworking/README (modified) * cpukit/libnetworking/arpa/ftp.h (modified) * cpukit/libnetworking/arpa/telnet.h (modified) * cpukit/libnetworking/bpfilter.h (modified) * cpukit/libnetworking/lib/README (modified) * cpukit/libnetworking/lib/getprotoby.c (modified) * cpukit/libnetworking/libc/addr2ascii.3 (modified) * cpukit/libnetworking/libc/addr2ascii.c (modified) * cpukit/libnetworking/libc/ascii2addr.c (modified) * cpukit/libnetworking/libc/byteorder.3 (modified) * cpukit/libnetworking/libc/gethostname.c (modified) * cpukit/libnetworking/libc/getnetent.3 (modified) * cpukit/libnetworking/libc/getproto.c (modified) * cpukit/libnetworking/libc/getprotoent.3 (modified) * cpukit/libnetworking/libc/getprotoent.c (modified) * cpukit/libnetworking/libc/getprotoname.c (modified) * cpukit/libnetworking/libc/getservbyname.c (modified) * cpukit/libnetworking/libc/getservbyport.c (modified) * cpukit/libnetworking/libc/getservent.c (modified) * cpukit/libnetworking/libc/inet_lnaof.c (modified) * cpukit/libnetworking/libc/inet_makeaddr.c (modified) * cpukit/libnetworking/libc/inet_netof.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/libc/inet_ntoa.c (modified) * cpukit/libnetworking/libc/iso_addr.3 (modified) * cpukit/libnetworking/libc/iso_addr.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/ns_addr.c (modified) * cpukit/libnetworking/libc/ns_ntoa.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/recv.c (modified) * cpukit/libnetworking/libc/res_config.h (modified) * cpukit/libnetworking/libc/resolver.3 (modified) * cpukit/libnetworking/libc/send.c (modified) * cpukit/libnetworking/libc/strsep.c (modified) * cpukit/libnetworking/loop.h (modified) * cpukit/libnetworking/machine/conf.h (modified) * cpukit/libnetworking/machine/cpu.h (modified) * cpukit/libnetworking/machine/cpufunc.h (modified) * cpukit/libnetworking/machine/endian.h (modified) * cpukit/libnetworking/machine/limits.h (modified) * cpukit/libnetworking/machine/param.h (modified) * cpukit/libnetworking/machine/types.h (modified) * cpukit/libnetworking/machine/vmparam.h (modified) * cpukit/libnetworking/opt_ipfw.h (modified) * cpukit/libnetworking/opt_mrouting.h (modified) * cpukit/libnetworking/opt_tcpdebug.h (modified) * cpukit/libnetworking/rtems/issetugid.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_showipstat.c (modified) * cpukit/libnetworking/rtems/rtems_showmbuf.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showudpstat.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/sghostname.c (modified) * cpukit/libnetworking/sys/proc.h (modified) * cpukit/libnetworking/sys/resourcevar.h (modified) * cpukit/libnetworking/syslog.h (modified) Added CVS Ids Thu, 20 Aug 1998 21:47:37 GMT Joel Sherrill [ff0f694d] * c/src/exec/libnetworking/kern/uipc_domain.c (modified) * c/src/exec/libnetworking/kern/uipc_socket.c (modified) * c/src/exec/libnetworking/lib/getprotoby.c (modified) * c/src/exec/libnetworking/lib/syslog.c (modified) * c/src/exec/libnetworking/libc/base64.c (modified) * c/src/exec/libnetworking/libc/gethostbydns.c (modified) * c/src/exec/libnetworking/libc/gethostnamadr.c (modified) * c/src/exec/libnetworking/libc/inet_addr.c (modified) * c/src/exec/libnetworking/libc/ns_name.c (modified) * c/src/exec/libnetworking/libc/ns_netint.c (modified) * c/src/exec/libnetworking/libc/ns_parse.c (modified) * c/src/exec/libnetworking/libc/ns_print.c (modified) * c/src/exec/libnetworking/libc/ns_ttl.c (modified) * c/src/exec/libnetworking/libc/res_config.h (modified) * c/src/exec/libnetworking/libc/res_debug.c (modified) * c/src/exec/libnetworking/libc/res_init.c (modified) * c/src/exec/libnetworking/libc/res_mkupdate.c (modified) * c/src/exec/libnetworking/libc/res_query.c (modified) * c/src/exec/libnetworking/libc/res_send.c (modified) * c/src/exec/libnetworking/libc/res_update.c (modified) * c/src/exec/libnetworking/libc/strsep.c (modified) * c/src/exec/libnetworking/net/if_ethersubr.c (modified) * c/src/exec/libnetworking/net/route.c (modified) * c/src/exec/libnetworking/net/rtsock.c (modified) * c/src/exec/libnetworking/netinet/in_pcb.c (modified) * c/src/exec/libnetworking/netinet/tcp_debug.c (modified) * c/src/exec/libnetworking/netinet/tcp_subr.c (modified) * c/src/exec/libnetworking/netinet/udp_usrreq.c (modified) * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/libnetworking/sys/libkern.h (modified) * c/src/exec/libnetworking/sys/param.h (modified) * c/src/exec/libnetworking/sys/syslimits.h (modified) * c/src/lib/libnetworking/kern/uipc_domain.c (modified) * c/src/lib/libnetworking/kern/uipc_socket.c (modified) * c/src/lib/libnetworking/lib/getprotoby.c (modified) * c/src/lib/libnetworking/lib/syslog.c (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/libc/base64.c (modified) * c/src/lib/libnetworking/libc/gethostbydns.c (modified) * c/src/lib/libnetworking/libc/gethostnamadr.c (modified) * c/src/lib/libnetworking/libc/inet_addr.c (modified) * c/src/lib/libnetworking/libc/ns_name.c (modified) * c/src/lib/libnetworking/libc/ns_netint.c (modified) * c/src/lib/libnetworking/libc/ns_parse.c (modified) * c/src/lib/libnetworking/libc/ns_print.c (modified) * c/src/lib/libnetworking/libc/ns_ttl.c (modified) * c/src/lib/libnetworking/libc/res_config.h (modified) * c/src/lib/libnetworking/libc/res_debug.c (modified) * c/src/lib/libnetworking/libc/res_init.c (modified) * c/src/lib/libnetworking/libc/res_mkupdate.c (modified) * c/src/lib/libnetworking/libc/res_query.c (modified) * c/src/lib/libnetworking/libc/res_send.c (modified) * c/src/lib/libnetworking/libc/res_update.c (modified) * c/src/lib/libnetworking/libc/strsep.c (modified) * c/src/lib/libnetworking/net/if_ethersubr.c (modified) * c/src/lib/libnetworking/net/route.c (modified) * c/src/lib/libnetworking/net/rtsock.c (modified) * c/src/lib/libnetworking/netinet/in_pcb.c (modified) * c/src/lib/libnetworking/netinet/tcp_debug.c (modified) * c/src/lib/libnetworking/netinet/tcp_subr.c (modified) * c/src/lib/libnetworking/netinet/udp_usrreq.c (modified) * c/src/lib/libnetworking/nfs/bootp_subr.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/sys/libkern.h (modified) * c/src/lib/libnetworking/sys/param.h (modified) * c/src/lib/libnetworking/sys/syslimits.h (modified) * c/src/libnetworking/kern/uipc_domain.c (modified) * c/src/libnetworking/kern/uipc_socket.c (modified) * c/src/libnetworking/lib/getprotoby.c (modified) * c/src/libnetworking/lib/syslog.c (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/libc/base64.c (modified) * c/src/libnetworking/libc/gethostbydns.c (modified) * c/src/libnetworking/libc/gethostnamadr.c (modified) * c/src/libnetworking/libc/inet_addr.c (modified) * c/src/libnetworking/libc/ns_name.c (modified) * c/src/libnetworking/libc/ns_netint.c (modified) * c/src/libnetworking/libc/ns_parse.c (modified) * c/src/libnetworking/libc/ns_print.c (modified) * c/src/libnetworking/libc/ns_ttl.c (modified) * c/src/libnetworking/libc/res_config.h (modified) * c/src/libnetworking/libc/res_debug.c (modified) * c/src/libnetworking/libc/res_init.c (modified) * c/src/libnetworking/libc/res_mkupdate.c (modified) * c/src/libnetworking/libc/res_query.c (modified) * c/src/libnetworking/libc/res_send.c (modified) * c/src/libnetworking/libc/res_update.c (modified) * c/src/libnetworking/libc/strsep.c (modified) * c/src/libnetworking/net/if_ethersubr.c (modified) * c/src/libnetworking/net/route.c (modified) * c/src/libnetworking/net/rtsock.c (modified) * c/src/libnetworking/netinet/in_pcb.c (modified) * c/src/libnetworking/netinet/tcp_debug.c (modified) * c/src/libnetworking/netinet/tcp_subr.c (modified) * c/src/libnetworking/netinet/udp_usrreq.c (modified) * c/src/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/sys/libkern.h (modified) * c/src/libnetworking/sys/param.h (modified) * c/src/libnetworking/sys/syslimits.h (modified) * cpukit/libnetworking/kern/uipc_domain.c (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/lib/getprotoby.c (modified) * cpukit/libnetworking/lib/syslog.c (modified) * cpukit/libnetworking/libc/base64.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/ns_name.c (modified) * cpukit/libnetworking/libc/ns_netint.c (modified) * cpukit/libnetworking/libc/ns_parse.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/res_config.h (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_init.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/libc/strsep.c (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/net/rtsock.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/tcp_debug.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/sys/libkern.h (modified) * cpukit/libnetworking/sys/param.h (modified) * cpukit/libnetworking/sys/syslimits.h (modified) Fixed many warnings. Thu, 20 Aug 1998 14:37:17 GMT Joel Sherrill [3f098aed] * c/src/exec/libnetworking/machine/conf.h (added) * c/src/exec/libnetworking/machine/cpu.h (added) * c/src/exec/libnetworking/machine/cpufunc.h (added) * c/src/exec/libnetworking/machine/endian.h (added) * c/src/exec/libnetworking/machine/in_cksum.h (added) * c/src/exec/libnetworking/machine/limits.h (added) * c/src/exec/libnetworking/machine/param.h (added) * c/src/exec/libnetworking/machine/types.h (added) * c/src/exec/libnetworking/machine/vmparam.h (added) * c/src/lib/libnetworking/include/Makefile.in (added) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/machine/conf.h (added) * c/src/lib/libnetworking/machine/cpu.h (added) * c/src/lib/libnetworking/machine/cpufunc.h (added) * c/src/lib/libnetworking/machine/endian.h (added) * c/src/lib/libnetworking/machine/in_cksum.h (added) * c/src/lib/libnetworking/machine/limits.h (added) * c/src/lib/libnetworking/machine/param.h (added) * c/src/lib/libnetworking/machine/types.h (added) * c/src/lib/libnetworking/machine/vmparam.h (added) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (added) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/machine/conf.h (added) * c/src/libnetworking/machine/cpu.h (added) * c/src/libnetworking/machine/cpufunc.h (added) * c/src/libnetworking/machine/endian.h (added) * c/src/libnetworking/machine/in_cksum.h (added) * c/src/libnetworking/machine/limits.h (added) * c/src/libnetworking/machine/param.h (added) * c/src/libnetworking/machine/types.h (added) * c/src/libnetworking/machine/vmparam.h (added) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * cpukit/libnetworking/machine/conf.h (added) * cpukit/libnetworking/machine/cpu.h (added) * cpukit/libnetworking/machine/cpufunc.h (added) * cpukit/libnetworking/machine/endian.h (added) * cpukit/libnetworking/machine/in_cksum.h (added) * cpukit/libnetworking/machine/limits.h (added) * cpukit/libnetworking/machine/param.h (added) * cpukit/libnetworking/machine/types.h (added) * cpukit/libnetworking/machine/vmparam.h (added) FreeBSD stack compiles for the first time (except libc/strsep.c). Wed, 19 Aug 1998 21:32:28 GMT Joel Sherrill [39e6e65a] * c/src/exec/libcsupport/include/sys/filio.h (added) * c/src/exec/libcsupport/include/sys/ioctl.h (added) * c/src/exec/libcsupport/include/sys/sockio.h (added) * c/src/exec/libnetworking/README (added) * c/src/exec/libnetworking/arpa/ftp.h (added) * c/src/exec/libnetworking/arpa/inet.h (added) * c/src/exec/libnetworking/arpa/nameser.h (added) * c/src/exec/libnetworking/arpa/nameser_compat.h (added) * c/src/exec/libnetworking/arpa/telnet.h (added) * c/src/exec/libnetworking/bpfilter.h (added) * c/src/exec/libnetworking/kern/kern_subr.c (added) * c/src/exec/libnetworking/kern/uipc_domain.c (added) * c/src/exec/libnetworking/kern/uipc_mbuf.c (added) * c/src/exec/libnetworking/kern/uipc_socket.c (added) * c/src/exec/libnetworking/kern/uipc_socket2.c (added) * c/src/exec/libnetworking/lib/README (added) * c/src/exec/libnetworking/lib/getprotoby.c (added) * c/src/exec/libnetworking/lib/syslog.c (added) * c/src/exec/libnetworking/lib/tftpDriver.c (added) * c/src/exec/libnetworking/libc/addr2ascii.3 (added) * c/src/exec/libnetworking/libc/addr2ascii.c (added) * c/src/exec/libnetworking/libc/ascii2addr.c (added) * c/src/exec/libnetworking/libc/base64.c (added) * c/src/exec/libnetworking/libc/byteorder.3 (added) * c/src/exec/libnetworking/libc/ether_addr.c (added) * c/src/exec/libnetworking/libc/ethers.3 (added) * c/src/exec/libnetworking/libc/gethostbydns.c (added) * c/src/exec/libnetworking/libc/gethostbyht.c (added) * c/src/exec/libnetworking/libc/gethostbyname.3 (added) * c/src/exec/libnetworking/libc/gethostbynis.c (added) * c/src/exec/libnetworking/libc/gethostnamadr.c (added) * c/src/exec/libnetworking/libc/gethostname.c (added) * c/src/exec/libnetworking/libc/getnetbydns.c (added) * c/src/exec/libnetworking/libc/getnetbyht.c (added) * c/src/exec/libnetworking/libc/getnetbynis.c (added) * c/src/exec/libnetworking/libc/getnetent.3 (added) * c/src/exec/libnetworking/libc/getnetnamadr.c (added) * c/src/exec/libnetworking/libc/getproto.c (added) * c/src/exec/libnetworking/libc/getprotoent.3 (added) * c/src/exec/libnetworking/libc/getprotoent.c (added) * c/src/exec/libnetworking/libc/getprotoname.c (added) * c/src/exec/libnetworking/libc/getservbyname.c (added) * c/src/exec/libnetworking/libc/getservbyport.c (added) * c/src/exec/libnetworking/libc/getservent.3 (added) * c/src/exec/libnetworking/libc/getservent.c (added) * c/src/exec/libnetworking/libc/herror.c (added) * c/src/exec/libnetworking/libc/inet.3 (added) * c/src/exec/libnetworking/libc/inet_addr.c (added) * c/src/exec/libnetworking/libc/inet_lnaof.c (added) * c/src/exec/libnetworking/libc/inet_makeaddr.c (added) * c/src/exec/libnetworking/libc/inet_net_ntop.c (added) * c/src/exec/libnetworking/libc/inet_net_pton.c (added) * c/src/exec/libnetworking/libc/inet_neta.c (added) * c/src/exec/libnetworking/libc/inet_netof.c (added) * c/src/exec/libnetworking/libc/inet_network.c (added) * c/src/exec/libnetworking/libc/inet_ntoa.c (added) * c/src/exec/libnetworking/libc/inet_ntop.c (added) * c/src/exec/libnetworking/libc/inet_pton.c (added) * c/src/exec/libnetworking/libc/iso_addr.3 (added) * c/src/exec/libnetworking/libc/iso_addr.c (added) * c/src/exec/libnetworking/libc/linkaddr.3 (added) * c/src/exec/libnetworking/libc/linkaddr.c (added) * c/src/exec/libnetworking/libc/map_v4v6.c (added) * c/src/exec/libnetworking/libc/ns.3 (added) * c/src/exec/libnetworking/libc/ns_addr.c (added) * c/src/exec/libnetworking/libc/ns_name.c (added) * c/src/exec/libnetworking/libc/ns_netint.c (added) * c/src/exec/libnetworking/libc/ns_ntoa.c (added) * c/src/exec/libnetworking/libc/ns_parse.c (added) * c/src/exec/libnetworking/libc/ns_print.c (added) * c/src/exec/libnetworking/libc/ns_ttl.c (added) * c/src/exec/libnetworking/libc/nsap_addr.c (added) * c/src/exec/libnetworking/libc/rcmd.3 (added) * c/src/exec/libnetworking/libc/rcmd.c (added) * c/src/exec/libnetworking/libc/recv.c (added) * c/src/exec/libnetworking/libc/res_comp.c (added) * c/src/exec/libnetworking/libc/res_config.h (added) * c/src/exec/libnetworking/libc/res_data.c (added) * c/src/exec/libnetworking/libc/res_debug.c (added) * c/src/exec/libnetworking/libc/res_init.c (added) * c/src/exec/libnetworking/libc/res_mkquery.c (added) * c/src/exec/libnetworking/libc/res_mkupdate.c (added) * c/src/exec/libnetworking/libc/res_query.c (added) * c/src/exec/libnetworking/libc/res_send.c (added) * c/src/exec/libnetworking/libc/res_stubs.c (added) * c/src/exec/libnetworking/libc/res_update.c (added) * c/src/exec/libnetworking/libc/resolver.3 (added) * c/src/exec/libnetworking/libc/send.c (added) * c/src/exec/libnetworking/libc/strsep.c (added) * c/src/exec/libnetworking/loop.h (added) * c/src/exec/libnetworking/net/bpf.h (added) * c/src/exec/libnetworking/net/ethernet.h (added) * c/src/exec/libnetworking/net/if.c (added) * c/src/exec/libnetworking/net/if.h (added) * c/src/exec/libnetworking/net/if_arp.h (added) * c/src/exec/libnetworking/net/if_dl.h (added) * c/src/exec/libnetworking/net/if_ethersubr.c (added) * c/src/exec/libnetworking/net/if_llc.h (added) * c/src/exec/libnetworking/net/if_loop.c (added) * c/src/exec/libnetworking/net/if_types.h (added) * c/src/exec/libnetworking/net/netisr.h (added) * c/src/exec/libnetworking/net/radix.c (added) * c/src/exec/libnetworking/net/radix.h (added) * c/src/exec/libnetworking/net/raw_cb.c (added) * c/src/exec/libnetworking/net/raw_cb.h (added) * c/src/exec/libnetworking/net/raw_usrreq.c (added) * c/src/exec/libnetworking/net/route.c (added) * c/src/exec/libnetworking/net/route.h (added) * c/src/exec/libnetworking/net/rtsock.c (added) * c/src/exec/libnetworking/netdb.h (added) * c/src/exec/libnetworking/netinet/icmp_var.h (added) * c/src/exec/libnetworking/netinet/if_ether.c (added) * c/src/exec/libnetworking/netinet/if_ether.h (added) * c/src/exec/libnetworking/netinet/igmp.c (added) * c/src/exec/libnetworking/netinet/igmp.h (added) * c/src/exec/libnetworking/netinet/igmp_var.h (added) * c/src/exec/libnetworking/netinet/in.c (added) * c/src/exec/libnetworking/netinet/in.h (added) * c/src/exec/libnetworking/netinet/in_cksum.c (added) * c/src/exec/libnetworking/netinet/in_pcb.c (added) * c/src/exec/libnetworking/netinet/in_pcb.h (added) * c/src/exec/libnetworking/netinet/in_proto.c (added) * c/src/exec/libnetworking/netinet/in_rmx.c (added) * c/src/exec/libnetworking/netinet/in_systm.h (added) * c/src/exec/libnetworking/netinet/in_var.h (added) * c/src/exec/libnetworking/netinet/ip.h (added) * c/src/exec/libnetworking/netinet/ip_divert.c (added) * c/src/exec/libnetworking/netinet/ip_fw.c (added) * c/src/exec/libnetworking/netinet/ip_fw.h (added) * c/src/exec/libnetworking/netinet/ip_icmp.c (added) * c/src/exec/libnetworking/netinet/ip_icmp.h (added) * c/src/exec/libnetworking/netinet/ip_input.c (added) * c/src/exec/libnetworking/netinet/ip_mroute.c (added) * c/src/exec/libnetworking/netinet/ip_mroute.h (added) * c/src/exec/libnetworking/netinet/ip_output.c (added) * c/src/exec/libnetworking/netinet/ip_var.h (added) * c/src/exec/libnetworking/netinet/raw_ip.c (added) * c/src/exec/libnetworking/netinet/tcp.h (added) * c/src/exec/libnetworking/netinet/tcp_debug.c (added) * c/src/exec/libnetworking/netinet/tcp_debug.h (added) * c/src/exec/libnetworking/netinet/tcp_fsm.h (added) * c/src/exec/libnetworking/netinet/tcp_input.c (added) * c/src/exec/libnetworking/netinet/tcp_output.c (added) * c/src/exec/libnetworking/netinet/tcp_seq.h (added) * c/src/exec/libnetworking/netinet/tcp_subr.c (added) * c/src/exec/libnetworking/netinet/tcp_timer.c (added) * c/src/exec/libnetworking/netinet/tcp_timer.h (added) * c/src/exec/libnetworking/netinet/tcp_usrreq.c (added) * c/src/exec/libnetworking/netinet/tcp_var.h (added) * c/src/exec/libnetworking/netinet/tcpip.h (added) * c/src/exec/libnetworking/netinet/udp.h (added) * c/src/exec/libnetworking/netinet/udp_usrreq.c (added) * c/src/exec/libnetworking/netinet/udp_var.h (added) * c/src/exec/libnetworking/nfs/bootp_subr.c (added) * c/src/exec/libnetworking/nfs/krpc.h (added) * c/src/exec/libnetworking/nfs/nfs.h (added) * c/src/exec/libnetworking/nfs/nfsdiskless.h (added) * c/src/exec/libnetworking/nfs/nfsproto.h (added) * c/src/exec/libnetworking/nfs/rpcv2.h (added) * c/src/exec/libnetworking/nfs/xdr_subs.h (added) * c/src/exec/libnetworking/opt_ipfw.h (added) * c/src/exec/libnetworking/opt_mrouting.h (added) * c/src/exec/libnetworking/opt_tcpdebug.h (added) * c/src/exec/libnetworking/poll.h (added) * c/src/exec/libnetworking/resolv.h (added) * c/src/exec/libnetworking/rtems/issetugid.c (added) * c/src/exec/libnetworking/rtems/rtems_bootp.c (added) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (added) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (added) * c/src/exec/libnetworking/rtems/rtems_glue.c (added) * c/src/exec/libnetworking/rtems/rtems_showicmpstat.c (added) * c/src/exec/libnetworking/rtems/rtems_showifstat.c (added) * c/src/exec/libnetworking/rtems/rtems_showipstat.c (added) * c/src/exec/libnetworking/rtems/rtems_showmbuf.c (added) * c/src/exec/libnetworking/rtems/rtems_showroute.c (added) * c/src/exec/libnetworking/rtems/rtems_showtcpstat.c (added) * c/src/exec/libnetworking/rtems/rtems_showudpstat.c (added) * c/src/exec/libnetworking/rtems/rtems_syscall.c (added) * c/src/exec/libnetworking/rtems/sghostname.c (added) * c/src/exec/libnetworking/rtems/tftp.h (added) * c/src/exec/libnetworking/sys/buf.h (added) * c/src/exec/libnetworking/sys/callout.h (added) * c/src/exec/libnetworking/sys/conf.h (added) * c/src/exec/libnetworking/sys/domain.h (added) * c/src/exec/libnetworking/sys/kernel.h (added) * c/src/exec/libnetworking/sys/libkern.h (added) * c/src/exec/libnetworking/sys/malloc.h (added) * c/src/exec/libnetworking/sys/mbuf.h (added) * c/src/exec/libnetworking/sys/mount.h (added) * c/src/exec/libnetworking/sys/param.h (added) * c/src/exec/libnetworking/sys/proc.h (added) * c/src/exec/libnetworking/sys/protosw.h (added) * c/src/exec/libnetworking/sys/queue.h (added) * c/src/exec/libnetworking/sys/reboot.h (added) * c/src/exec/libnetworking/sys/resourcevar.h (added) * c/src/exec/libnetworking/sys/rtprio.h (added) * c/src/exec/libnetworking/sys/select.h (added) * c/src/exec/libnetworking/sys/signalvar.h (added) * c/src/exec/libnetworking/sys/socket.h (added) * c/src/exec/libnetworking/sys/socketvar.h (added) * c/src/exec/libnetworking/sys/sysctl.h (added) * c/src/exec/libnetworking/sys/syslimits.h (added) * c/src/exec/libnetworking/sys/syslog.h (added) * c/src/exec/libnetworking/sys/systm.h (added) * c/src/exec/libnetworking/sys/ttydefaults.h (added) * c/src/exec/libnetworking/sys/ucred.h (added) * c/src/exec/libnetworking/sys/uio.h (added) * c/src/exec/libnetworking/syslog.h (added) * c/src/exec/libnetworking/vm/vm.h (added) * c/src/exec/libnetworking/vm/vm_extern.h (added) * c/src/exec/libnetworking/vm/vm_kern.h (added) * c/src/exec/libnetworking/vm/vm_param.h (added) * c/src/lib/include/sys/filio.h (added) * c/src/lib/include/sys/ioctl.h (added) * c/src/lib/include/sys/sockio.h (added) * c/src/lib/libnetworking/CHANGELOG (added) * c/src/lib/libnetworking/README (added) * c/src/lib/libnetworking/arpa/ftp.h (added) * c/src/lib/libnetworking/arpa/inet.h (added) * c/src/lib/libnetworking/arpa/nameser.h (added) * c/src/lib/libnetworking/arpa/nameser_compat.h (added) * c/src/lib/libnetworking/arpa/telnet.h (added) * c/src/lib/libnetworking/bpfilter.h (added) * c/src/lib/libnetworking/kern/kern_subr.c (added) * c/src/lib/libnetworking/kern/uipc_domain.c (added) * c/src/lib/libnetworking/kern/uipc_mbuf.c (added) * c/src/lib/libnetworking/kern/uipc_socket.c (added) * c/src/lib/libnetworking/kern/uipc_socket2.c (added) * c/src/lib/libnetworking/lib/README (added) * c/src/lib/libnetworking/lib/getprotoby.c (added) * c/src/lib/libnetworking/lib/syslog.c (added) * c/src/lib/libnetworking/lib/tftpDriver.c (added) * c/src/lib/libnetworking/libc/addr2ascii.3 (added) * c/src/lib/libnetworking/libc/addr2ascii.c (added) * c/src/lib/libnetworking/libc/ascii2addr.c (added) * c/src/lib/libnetworking/libc/base64.c (added) * c/src/lib/libnetworking/libc/byteorder.3 (added) * c/src/lib/libnetworking/libc/ether_addr.c (added) * c/src/lib/libnetworking/libc/ethers.3 (added) * c/src/lib/libnetworking/libc/gethostbydns.c (added) * c/src/lib/libnetworking/libc/gethostbyht.c (added) * c/src/lib/libnetworking/libc/gethostbyname.3 (added) * c/src/lib/libnetworking/libc/gethostbynis.c (added) * c/src/lib/libnetworking/libc/gethostnamadr.c (added) * c/src/lib/libnetworking/libc/gethostname.c (added) * c/src/lib/libnetworking/libc/getnetbydns.c (added) * c/src/lib/libnetworking/libc/getnetbyht.c (added) * c/src/lib/libnetworking/libc/getnetbynis.c (added) * c/src/lib/libnetworking/libc/getnetent.3 (added) * c/src/lib/libnetworking/libc/getnetnamadr.c (added) * c/src/lib/libnetworking/libc/getproto.c (added) * c/src/lib/libnetworking/libc/getprotoent.3 (added) * c/src/lib/libnetworking/libc/getprotoent.c (added) * c/src/lib/libnetworking/libc/getprotoname.c (added) * c/src/lib/libnetworking/libc/getservbyname.c (added) * c/src/lib/libnetworking/libc/getservbyport.c (added) * c/src/lib/libnetworking/libc/getservent.3 (added) * c/src/lib/libnetworking/libc/getservent.c (added) * c/src/lib/libnetworking/libc/herror.c (added) * c/src/lib/libnetworking/libc/inet.3 (added) * c/src/lib/libnetworking/libc/inet_addr.c (added) * c/src/lib/libnetworking/libc/inet_lnaof.c (added) * c/src/lib/libnetworking/libc/inet_makeaddr.c (added) * c/src/lib/libnetworking/libc/inet_net_ntop.c (added) * c/src/lib/libnetworking/libc/inet_net_pton.c (added) * c/src/lib/libnetworking/libc/inet_neta.c (added) * c/src/lib/libnetworking/libc/inet_netof.c (added) * c/src/lib/libnetworking/libc/inet_network.c (added) * c/src/lib/libnetworking/libc/inet_ntoa.c (added) * c/src/lib/libnetworking/libc/inet_ntop.c (added) * c/src/lib/libnetworking/libc/inet_pton.c (added) * c/src/lib/libnetworking/libc/iso_addr.3 (added) * c/src/lib/libnetworking/libc/iso_addr.c (added) * c/src/lib/libnetworking/libc/linkaddr.3 (added) * c/src/lib/libnetworking/libc/linkaddr.c (added) * c/src/lib/libnetworking/libc/map_v4v6.c (added) * c/src/lib/libnetworking/libc/ns.3 (added) * c/src/lib/libnetworking/libc/ns_addr.c (added) * c/src/lib/libnetworking/libc/ns_name.c (added) * c/src/lib/libnetworking/libc/ns_netint.c (added) * c/src/lib/libnetworking/libc/ns_ntoa.c (added) * c/src/lib/libnetworking/libc/ns_parse.c (added) * c/src/lib/libnetworking/libc/ns_print.c (added) * c/src/lib/libnetworking/libc/ns_ttl.c (added) * c/src/lib/libnetworking/libc/nsap_addr.c (added) * c/src/lib/libnetworking/libc/rcmd.3 (added) * c/src/lib/libnetworking/libc/rcmd.c (added) * c/src/lib/libnetworking/libc/recv.c (added) * c/src/lib/libnetworking/libc/res_comp.c (added) * c/src/lib/libnetworking/libc/res_config.h (added) * c/src/lib/libnetworking/libc/res_data.c (added) * c/src/lib/libnetworking/libc/res_debug.c (added) * c/src/lib/libnetworking/libc/res_init.c (added) * c/src/lib/libnetworking/libc/res_mkquery.c (added) * c/src/lib/libnetworking/libc/res_mkupdate.c (added) * c/src/lib/libnetworking/libc/res_query.c (added) * c/src/lib/libnetworking/libc/res_send.c (added) * c/src/lib/libnetworking/libc/res_stubs.c (added) * c/src/lib/libnetworking/libc/res_update.c (added) * c/src/lib/libnetworking/libc/resolver.3 (added) * c/src/lib/libnetworking/libc/send.c (added) * c/src/lib/libnetworking/libc/strsep.c (added) * c/src/lib/libnetworking/loop.h (added) * c/src/lib/libnetworking/net/bpf.h (added) * c/src/lib/libnetworking/net/ethernet.h (added) * c/src/lib/libnetworking/net/if.c (added) * c/src/lib/libnetworking/net/if.h (added) * c/src/lib/libnetworking/net/if_arp.h (added) * c/src/lib/libnetworking/net/if_dl.h (added) * c/src/lib/libnetworking/net/if_ethersubr.c (added) * c/src/lib/libnetworking/net/if_llc.h (added) * c/src/lib/libnetworking/net/if_loop.c (added) * c/src/lib/libnetworking/net/if_types.h (added) * c/src/lib/libnetworking/net/netisr.h (added) * c/src/lib/libnetworking/net/radix.c (added) * c/src/lib/libnetworking/net/radix.h (added) * c/src/lib/libnetworking/net/raw_cb.c (added) * c/src/lib/libnetworking/net/raw_cb.h (added) * c/src/lib/libnetworking/net/raw_usrreq.c (added) * c/src/lib/libnetworking/net/route.c (added) * c/src/lib/libnetworking/net/route.h (added) * c/src/lib/libnetworking/net/rtsock.c (added) * c/src/lib/libnetworking/netdb.h (added) * c/src/lib/libnetworking/netinet/icmp_var.h (added) * c/src/lib/libnetworking/netinet/if_ether.c (added) * c/src/lib/libnetworking/netinet/if_ether.h (added) * c/src/lib/libnetworking/netinet/igmp.c (added) * c/src/lib/libnetworking/netinet/igmp.h (added) * c/src/lib/libnetworking/netinet/igmp_var.h (added) * c/src/lib/libnetworking/netinet/in.c (added) * c/src/lib/libnetworking/netinet/in.h (added) * c/src/lib/libnetworking/netinet/in_cksum.c (added) * c/src/lib/libnetworking/netinet/in_pcb.c (added) * c/src/lib/libnetworking/netinet/in_pcb.h (added) * c/src/lib/libnetworking/netinet/in_proto.c (added) * c/src/lib/libnetworking/netinet/in_rmx.c (added) * c/src/lib/libnetworking/netinet/in_systm.h (added) * c/src/lib/libnetworking/netinet/in_var.h (added) * c/src/lib/libnetworking/netinet/ip.h (added) * c/src/lib/libnetworking/netinet/ip_divert.c (added) * c/src/lib/libnetworking/netinet/ip_fw.c (added) * c/src/lib/libnetworking/netinet/ip_fw.h (added) * c/src/lib/libnetworking/netinet/ip_icmp.c (added) * c/src/lib/libnetworking/netinet/ip_icmp.h (added) * c/src/lib/libnetworking/netinet/ip_input.c (added) * c/src/lib/libnetworking/netinet/ip_mroute.c (added) * c/src/lib/libnetworking/netinet/ip_mroute.h (added) * c/src/lib/libnetworking/netinet/ip_output.c (added) * c/src/lib/libnetworking/netinet/ip_var.h (added) * c/src/lib/libnetworking/netinet/raw_ip.c (added) * c/src/lib/libnetworking/netinet/tcp.h (added) * c/src/lib/libnetworking/netinet/tcp_debug.c (added) * c/src/lib/libnetworking/netinet/tcp_debug.h (added) * c/src/lib/libnetworking/netinet/tcp_fsm.h (added) * c/src/lib/libnetworking/netinet/tcp_input.c (added) * c/src/lib/libnetworking/netinet/tcp_output.c (added) * c/src/lib/libnetworking/netinet/tcp_seq.h (added) * c/src/lib/libnetworking/netinet/tcp_subr.c (added) * c/src/lib/libnetworking/netinet/tcp_timer.c (added) * c/src/lib/libnetworking/netinet/tcp_timer.h (added) * c/src/lib/libnetworking/netinet/tcp_usrreq.c (added) * c/src/lib/libnetworking/netinet/tcp_var.h (added) * c/src/lib/libnetworking/netinet/tcpip.h (added) * c/src/lib/libnetworking/netinet/udp.h (added) * c/src/lib/libnetworking/netinet/udp_usrreq.c (added) * c/src/lib/libnetworking/netinet/udp_var.h (added) * c/src/lib/libnetworking/nfs/bootp_subr.c (added) * c/src/lib/libnetworking/nfs/krpc.h (added) * c/src/lib/libnetworking/nfs/nfs.h (added) * c/src/lib/libnetworking/nfs/nfsdiskless.h (added) * c/src/lib/libnetworking/nfs/nfsproto.h (added) * c/src/lib/libnetworking/nfs/rpcv2.h (added) * c/src/lib/libnetworking/nfs/xdr_subs.h (added) * c/src/lib/libnetworking/opt_ipfw.h (added) * c/src/lib/libnetworking/opt_mrouting.h (added) * c/src/lib/libnetworking/opt_tcpdebug.h (added) * c/src/lib/libnetworking/poll.h (added) * c/src/lib/libnetworking/resolv.h (added) * c/src/lib/libnetworking/rtems/issetugid.c (added) * c/src/lib/libnetworking/rtems/rtems_bootp.c (added) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (added) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (added) * c/src/lib/libnetworking/rtems/rtems_glue.c (added) * c/src/lib/libnetworking/rtems/rtems_showicmpstat.c (added) * c/src/lib/libnetworking/rtems/rtems_showifstat.c (added) * c/src/lib/libnetworking/rtems/rtems_showipstat.c (added) * c/src/lib/libnetworking/rtems/rtems_showmbuf.c (added) * c/src/lib/libnetworking/rtems/rtems_showroute.c (added) * c/src/lib/libnetworking/rtems/rtems_showtcpstat.c (added) * c/src/lib/libnetworking/rtems/rtems_showudpstat.c (added) * c/src/lib/libnetworking/rtems/rtems_syscall.c (added) * c/src/lib/libnetworking/rtems/sghostname.c (added) * c/src/lib/libnetworking/rtems/tftp.h (added) * c/src/lib/libnetworking/sys/buf.h (added) * c/src/lib/libnetworking/sys/callout.h (added) * c/src/lib/libnetworking/sys/cdefs.h (added) * c/src/lib/libnetworking/sys/conf.h (added) * c/src/lib/libnetworking/sys/domain.h (added) * c/src/lib/libnetworking/sys/filio.h (added) * c/src/lib/libnetworking/sys/ioccom.h (added) * c/src/lib/libnetworking/sys/ioctl.h (added) * c/src/lib/libnetworking/sys/kernel.h (added) * c/src/lib/libnetworking/sys/libkern.h (added) * c/src/lib/libnetworking/sys/malloc.h (added) * c/src/lib/libnetworking/sys/mbuf.h (added) * c/src/lib/libnetworking/sys/mount.h (added) * c/src/lib/libnetworking/sys/param.h (added) * c/src/lib/libnetworking/sys/proc.h (added) * c/src/lib/libnetworking/sys/protosw.h (added) * c/src/lib/libnetworking/sys/queue.h (added) * c/src/lib/libnetworking/sys/reboot.h (added) * c/src/lib/libnetworking/sys/resourcevar.h (added) * c/src/lib/libnetworking/sys/rtprio.h (added) * c/src/lib/libnetworking/sys/select.h (added) * c/src/lib/libnetworking/sys/signalvar.h (added) * c/src/lib/libnetworking/sys/socket.h (added) * c/src/lib/libnetworking/sys/socketvar.h (added) * c/src/lib/libnetworking/sys/sockio.h (added) * c/src/lib/libnetworking/sys/sysctl.h (added) * c/src/lib/libnetworking/sys/syslimits.h (added) * c/src/lib/libnetworking/sys/syslog.h (added) * c/src/lib/libnetworking/sys/systm.h (added) * c/src/lib/libnetworking/sys/ttycom.h (added) * c/src/lib/libnetworking/sys/ttydefaults.h (added) * c/src/lib/libnetworking/sys/ucred.h (added) * c/src/lib/libnetworking/sys/uio.h (added) * c/src/lib/libnetworking/syslog.h (added) * c/src/lib/libnetworking/vm/vm.h (added) * c/src/lib/libnetworking/vm/vm_extern.h (added) * c/src/lib/libnetworking/vm/vm_kern.h (added) * c/src/lib/libnetworking/vm/vm_param.h (added) * c/src/libnetworking/CHANGELOG (added) * c/src/libnetworking/README (added) * c/src/libnetworking/arpa/ftp.h (added) * c/src/libnetworking/arpa/inet.h (added) * c/src/libnetworking/arpa/nameser.h (added) * c/src/libnetworking/arpa/nameser_compat.h (added) * c/src/libnetworking/arpa/telnet.h (added) * c/src/libnetworking/bpfilter.h (added) * c/src/libnetworking/kern/kern_subr.c (added) * c/src/libnetworking/kern/uipc_domain.c (added) * c/src/libnetworking/kern/uipc_mbuf.c (added) * c/src/libnetworking/kern/uipc_socket.c (added) * c/src/libnetworking/kern/uipc_socket2.c (added) * c/src/libnetworking/lib/README (added) * c/src/libnetworking/lib/getprotoby.c (added) * c/src/libnetworking/lib/syslog.c (added) * c/src/libnetworking/lib/tftpDriver.c (added) * c/src/libnetworking/libc/addr2ascii.3 (added) * c/src/libnetworking/libc/addr2ascii.c (added) * c/src/libnetworking/libc/ascii2addr.c (added) * c/src/libnetworking/libc/base64.c (added) * c/src/libnetworking/libc/byteorder.3 (added) * c/src/libnetworking/libc/ether_addr.c (added) * c/src/libnetworking/libc/ethers.3 (added) * c/src/libnetworking/libc/gethostbydns.c (added) * c/src/libnetworking/libc/gethostbyht.c (added) * c/src/libnetworking/libc/gethostbyname.3 (added) * c/src/libnetworking/libc/gethostbynis.c (added) * c/src/libnetworking/libc/gethostnamadr.c (added) * c/src/libnetworking/libc/gethostname.c (added) * c/src/libnetworking/libc/getnetbydns.c (added) * c/src/libnetworking/libc/getnetbyht.c (added) * c/src/libnetworking/libc/getnetbynis.c (added) * c/src/libnetworking/libc/getnetent.3 (added) * c/src/libnetworking/libc/getnetnamadr.c (added) * c/src/libnetworking/libc/getproto.c (added) * c/src/libnetworking/libc/getprotoent.3 (added) * c/src/libnetworking/libc/getprotoent.c (added) * c/src/libnetworking/libc/getprotoname.c (added) * c/src/libnetworking/libc/getservbyname.c (added) * c/src/libnetworking/libc/getservbyport.c (added) * c/src/libnetworking/libc/getservent.3 (added) * c/src/libnetworking/libc/getservent.c (added) * c/src/libnetworking/libc/herror.c (added) * c/src/libnetworking/libc/inet.3 (added) * c/src/libnetworking/libc/inet_addr.c (added) * c/src/libnetworking/libc/inet_lnaof.c (added) * c/src/libnetworking/libc/inet_makeaddr.c (added) * c/src/libnetworking/libc/inet_net_ntop.c (added) * c/src/libnetworking/libc/inet_net_pton.c (added) * c/src/libnetworking/libc/inet_neta.c (added) * c/src/libnetworking/libc/inet_netof.c (added) * c/src/libnetworking/libc/inet_network.c (added) * c/src/libnetworking/libc/inet_ntoa.c (added) * c/src/libnetworking/libc/inet_ntop.c (added) * c/src/libnetworking/libc/inet_pton.c (added) * c/src/libnetworking/libc/iso_addr.3 (added) * c/src/libnetworking/libc/iso_addr.c (added) * c/src/libnetworking/libc/linkaddr.3 (added) * c/src/libnetworking/libc/linkaddr.c (added) * c/src/libnetworking/libc/map_v4v6.c (added) * c/src/libnetworking/libc/ns.3 (added) * c/src/libnetworking/libc/ns_addr.c (added) * c/src/libnetworking/libc/ns_name.c (added) * c/src/libnetworking/libc/ns_netint.c (added) * c/src/libnetworking/libc/ns_ntoa.c (added) * c/src/libnetworking/libc/ns_parse.c (added) * c/src/libnetworking/libc/ns_print.c (added) * c/src/libnetworking/libc/ns_ttl.c (added) * c/src/libnetworking/libc/nsap_addr.c (added) * c/src/libnetworking/libc/rcmd.3 (added) * c/src/libnetworking/libc/rcmd.c (added) * c/src/libnetworking/libc/recv.c (added) * c/src/libnetworking/libc/res_comp.c (added) * c/src/libnetworking/libc/res_config.h (added) * c/src/libnetworking/libc/res_data.c (added) * c/src/libnetworking/libc/res_debug.c (added) * c/src/libnetworking/libc/res_init.c (added) * c/src/libnetworking/libc/res_mkquery.c (added) * c/src/libnetworking/libc/res_mkupdate.c (added) * c/src/libnetworking/libc/res_query.c (added) * c/src/libnetworking/libc/res_send.c (added) * c/src/libnetworking/libc/res_stubs.c (added) * c/src/libnetworking/libc/res_update.c (added) * c/src/libnetworking/libc/resolver.3 (added) * c/src/libnetworking/libc/send.c (added) * c/src/libnetworking/libc/strsep.c (added) * c/src/libnetworking/loop.h (added) * c/src/libnetworking/net/bpf.h (added) * c/src/libnetworking/net/ethernet.h (added) * c/src/libnetworking/net/if.c (added) * c/src/libnetworking/net/if.h (added) * c/src/libnetworking/net/if_arp.h (added) * c/src/libnetworking/net/if_dl.h (added) * c/src/libnetworking/net/if_ethersubr.c (added) * c/src/libnetworking/net/if_llc.h (added) * c/src/libnetworking/net/if_loop.c (added) * c/src/libnetworking/net/if_types.h (added) * c/src/libnetworking/net/netisr.h (added) * c/src/libnetworking/net/radix.c (added) * c/src/libnetworking/net/radix.h (added) * c/src/libnetworking/net/raw_cb.c (added) * c/src/libnetworking/net/raw_cb.h (added) * c/src/libnetworking/net/raw_usrreq.c (added) * c/src/libnetworking/net/route.c (added) * c/src/libnetworking/net/route.h (added) * c/src/libnetworking/net/rtsock.c (added) * c/src/libnetworking/netdb.h (added) * c/src/libnetworking/netinet/icmp_var.h (added) * c/src/libnetworking/netinet/if_ether.c (added) * c/src/libnetworking/netinet/if_ether.h (added) * c/src/libnetworking/netinet/igmp.c (added) * c/src/libnetworking/netinet/igmp.h (added) * c/src/libnetworking/netinet/igmp_var.h (added) * c/src/libnetworking/netinet/in.c (added) * c/src/libnetworking/netinet/in.h (added) * c/src/libnetworking/netinet/in_cksum.c (added) * c/src/libnetworking/netinet/in_pcb.c (added) * c/src/libnetworking/netinet/in_pcb.h (added) * c/src/libnetworking/netinet/in_proto.c (added) * c/src/libnetworking/netinet/in_rmx.c (added) * c/src/libnetworking/netinet/in_systm.h (added) * c/src/libnetworking/netinet/in_var.h (added) * c/src/libnetworking/netinet/ip.h (added) * c/src/libnetworking/netinet/ip_divert.c (added) * c/src/libnetworking/netinet/ip_fw.c (added) * c/src/libnetworking/netinet/ip_fw.h (added) * c/src/libnetworking/netinet/ip_icmp.c (added) * c/src/libnetworking/netinet/ip_icmp.h (added) * c/src/libnetworking/netinet/ip_input.c (added) * c/src/libnetworking/netinet/ip_mroute.c (added) * c/src/libnetworking/netinet/ip_mroute.h (added) * c/src/libnetworking/netinet/ip_output.c (added) * c/src/libnetworking/netinet/ip_var.h (added) * c/src/libnetworking/netinet/raw_ip.c (added) * c/src/libnetworking/netinet/tcp.h (added) * c/src/libnetworking/netinet/tcp_debug.c (added) * c/src/libnetworking/netinet/tcp_debug.h (added) * c/src/libnetworking/netinet/tcp_fsm.h (added) * c/src/libnetworking/netinet/tcp_input.c (added) * c/src/libnetworking/netinet/tcp_output.c (added) * c/src/libnetworking/netinet/tcp_seq.h (added) * c/src/libnetworking/netinet/tcp_subr.c (added) * c/src/libnetworking/netinet/tcp_timer.c (added) * c/src/libnetworking/netinet/tcp_timer.h (added) * c/src/libnetworking/netinet/tcp_usrreq.c (added) * c/src/libnetworking/netinet/tcp_var.h (added) * c/src/libnetworking/netinet/tcpip.h (added) * c/src/libnetworking/netinet/udp.h (added) * c/src/libnetworking/netinet/udp_usrreq.c (added) * c/src/libnetworking/netinet/udp_var.h (added) * c/src/libnetworking/nfs/bootp_subr.c (added) * c/src/libnetworking/nfs/krpc.h (added) * c/src/libnetworking/nfs/nfs.h (added) * c/src/libnetworking/nfs/nfsdiskless.h (added) * c/src/libnetworking/nfs/nfsproto.h (added) * c/src/libnetworking/nfs/rpcv2.h (added) * c/src/libnetworking/nfs/xdr_subs.h (added) * c/src/libnetworking/opt_ipfw.h (added) * c/src/libnetworking/opt_mrouting.h (added) * c/src/libnetworking/opt_tcpdebug.h (added) * c/src/libnetworking/poll.h (added) * c/src/libnetworking/resolv.h (added) * c/src/libnetworking/rtems/issetugid.c (added) * c/src/libnetworking/rtems/rtems_bootp.c (added) * c/src/libnetworking/rtems/rtems_bsdnet.h (added) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (added) * c/src/libnetworking/rtems/rtems_glue.c (added) * c/src/libnetworking/rtems/rtems_showicmpstat.c (added) * c/src/libnetworking/rtems/rtems_showifstat.c (added) * c/src/libnetworking/rtems/rtems_showipstat.c (added) * c/src/libnetworking/rtems/rtems_showmbuf.c (added) * c/src/libnetworking/rtems/rtems_showroute.c (added) * c/src/libnetworking/rtems/rtems_showtcpstat.c (added) * c/src/libnetworking/rtems/rtems_showudpstat.c (added) * c/src/libnetworking/rtems/rtems_syscall.c (added) * c/src/libnetworking/rtems/sghostname.c (added) * c/src/libnetworking/rtems/tftp.h (added) * c/src/libnetworking/sys/buf.h (added) * c/src/libnetworking/sys/callout.h (added) * c/src/libnetworking/sys/cdefs.h (added) * c/src/libnetworking/sys/conf.h (added) * c/src/libnetworking/sys/domain.h (added) * c/src/libnetworking/sys/filio.h (added) * c/src/libnetworking/sys/ioccom.h (added) * c/src/libnetworking/sys/ioctl.h (added) * c/src/libnetworking/sys/kernel.h (added) * c/src/libnetworking/sys/libkern.h (added) * c/src/libnetworking/sys/malloc.h (added) * c/src/libnetworking/sys/mbuf.h (added) * c/src/libnetworking/sys/mount.h (added) * c/src/libnetworking/sys/param.h (added) * c/src/libnetworking/sys/proc.h (added) * c/src/libnetworking/sys/protosw.h (added) * c/src/libnetworking/sys/queue.h (added) * c/src/libnetworking/sys/reboot.h (added) * c/src/libnetworking/sys/resourcevar.h (added) * c/src/libnetworking/sys/rtprio.h (added) * c/src/libnetworking/sys/select.h (added) * c/src/libnetworking/sys/signalvar.h (added) * c/src/libnetworking/sys/socket.h (added) * c/src/libnetworking/sys/socketvar.h (added) * c/src/libnetworking/sys/sockio.h (added) * c/src/libnetworking/sys/sysctl.h (added) * c/src/libnetworking/sys/syslimits.h (added) * c/src/libnetworking/sys/syslog.h (added) * c/src/libnetworking/sys/systm.h (added) * c/src/libnetworking/sys/ttycom.h (added) * c/src/libnetworking/sys/ttydefaults.h (added) * c/src/libnetworking/sys/ucred.h (added) * c/src/libnetworking/sys/uio.h (added) * c/src/libnetworking/syslog.h (added) * c/src/libnetworking/vm/vm.h (added) * c/src/libnetworking/vm/vm_extern.h (added) * c/src/libnetworking/vm/vm_kern.h (added) * c/src/libnetworking/vm/vm_param.h (added) * cpukit/libcsupport/include/sys/filio.h (added) * cpukit/libcsupport/include/sys/ioctl.h (added) * cpukit/libcsupport/include/sys/sockio.h (added) * cpukit/libnetworking/README (added) * cpukit/libnetworking/arpa/ftp.h (added) * cpukit/libnetworking/arpa/inet.h (added) * cpukit/libnetworking/arpa/nameser.h (added) * cpukit/libnetworking/arpa/nameser_compat.h (added) * cpukit/libnetworking/arpa/telnet.h (added) * cpukit/libnetworking/bpfilter.h (added) * cpukit/libnetworking/kern/kern_subr.c (added) * cpukit/libnetworking/kern/uipc_domain.c (added) * cpukit/libnetworking/kern/uipc_mbuf.c (added) * cpukit/libnetworking/kern/uipc_socket.c (added) * cpukit/libnetworking/kern/uipc_socket2.c (added) * cpukit/libnetworking/lib/README (added) * cpukit/libnetworking/lib/getprotoby.c (added) * cpukit/libnetworking/lib/syslog.c (added) * cpukit/libnetworking/lib/tftpDriver.c (added) * cpukit/libnetworking/libc/addr2ascii.3 (added) * cpukit/libnetworking/libc/addr2ascii.c (added) * cpukit/libnetworking/libc/ascii2addr.c (added) * cpukit/libnetworking/libc/base64.c (added) * cpukit/libnetworking/libc/byteorder.3 (added) * cpukit/libnetworking/libc/ether_addr.c (added) * cpukit/libnetworking/libc/ethers.3 (added) * cpukit/libnetworking/libc/gethostbydns.c (added) * cpukit/libnetworking/libc/gethostbyht.c (added) * cpukit/libnetworking/libc/gethostbyname.3 (added) * cpukit/libnetworking/libc/gethostbynis.c (added) * cpukit/libnetworking/libc/gethostnamadr.c (added) * cpukit/libnetworking/libc/gethostname.c (added) * cpukit/libnetworking/libc/getnetbydns.c (added) * cpukit/libnetworking/libc/getnetbyht.c (added) * cpukit/libnetworking/libc/getnetbynis.c (added) * cpukit/libnetworking/libc/getnetent.3 (added) * cpukit/libnetworking/libc/getnetnamadr.c (added) * cpukit/libnetworking/libc/getproto.c (added) * cpukit/libnetworking/libc/getprotoent.3 (added) * cpukit/libnetworking/libc/getprotoent.c (added) * cpukit/libnetworking/libc/getprotoname.c (added) * cpukit/libnetworking/libc/getservbyname.c (added) * cpukit/libnetworking/libc/getservbyport.c (added) * cpukit/libnetworking/libc/getservent.3 (added) * cpukit/libnetworking/libc/getservent.c (added) * cpukit/libnetworking/libc/herror.c (added) * cpukit/libnetworking/libc/inet.3 (added) * cpukit/libnetworking/libc/inet_addr.c (added) * cpukit/libnetworking/libc/inet_lnaof.c (added) * cpukit/libnetworking/libc/inet_makeaddr.c (added) * cpukit/libnetworking/libc/inet_net_ntop.c (added) * cpukit/libnetworking/libc/inet_net_pton.c (added) * cpukit/libnetworking/libc/inet_neta.c (added) * cpukit/libnetworking/libc/inet_netof.c (added) * cpukit/libnetworking/libc/inet_network.c (added) * cpukit/libnetworking/libc/inet_ntoa.c (added) * cpukit/libnetworking/libc/inet_ntop.c (added) * cpukit/libnetworking/libc/inet_pton.c (added) * cpukit/libnetworking/libc/iso_addr.3 (added) * cpukit/libnetworking/libc/iso_addr.c (added) * cpukit/libnetworking/libc/linkaddr.3 (added) * cpukit/libnetworking/libc/linkaddr.c (added) * cpukit/libnetworking/libc/map_v4v6.c (added) * cpukit/libnetworking/libc/ns.3 (added) * cpukit/libnetworking/libc/ns_addr.c (added) * cpukit/libnetworking/libc/ns_name.c (added) * cpukit/libnetworking/libc/ns_netint.c (added) * cpukit/libnetworking/libc/ns_ntoa.c (added) * cpukit/libnetworking/libc/ns_parse.c (added) * cpukit/libnetworking/libc/ns_print.c (added) * cpukit/libnetworking/libc/ns_ttl.c (added) * cpukit/libnetworking/libc/nsap_addr.c (added) * cpukit/libnetworking/libc/rcmd.3 (added) * cpukit/libnetworking/libc/rcmd.c (added) * cpukit/libnetworking/libc/recv.c (added) * cpukit/libnetworking/libc/res_comp.c (added) * cpukit/libnetworking/libc/res_config.h (added) * cpukit/libnetworking/libc/res_data.c (added) * cpukit/libnetworking/libc/res_debug.c (added) * cpukit/libnetworking/libc/res_init.c (added) * cpukit/libnetworking/libc/res_mkquery.c (added) * cpukit/libnetworking/libc/res_mkupdate.c (added) * cpukit/libnetworking/libc/res_query.c (added) * cpukit/libnetworking/libc/res_send.c (added) * cpukit/libnetworking/libc/res_stubs.c (added) * cpukit/libnetworking/libc/res_update.c (added) * cpukit/libnetworking/libc/resolver.3 (added) * cpukit/libnetworking/libc/send.c (added) * cpukit/libnetworking/libc/strsep.c (added) * cpukit/libnetworking/loop.h (added) * cpukit/libnetworking/net/bpf.h (added) * cpukit/libnetworking/net/ethernet.h (added) * cpukit/libnetworking/net/if.c (added) * cpukit/libnetworking/net/if.h (added) * cpukit/libnetworking/net/if_arp.h (added) * cpukit/libnetworking/net/if_dl.h (added) * cpukit/libnetworking/net/if_ethersubr.c (added) * cpukit/libnetworking/net/if_llc.h (added) * cpukit/libnetworking/net/if_loop.c (added) * cpukit/libnetworking/net/if_types.h (added) * cpukit/libnetworking/net/netisr.h (added) * cpukit/libnetworking/net/radix.c (added) * cpukit/libnetworking/net/radix.h (added) * cpukit/libnetworking/net/raw_cb.c (added) * cpukit/libnetworking/net/raw_cb.h (added) * cpukit/libnetworking/net/raw_usrreq.c (added) * cpukit/libnetworking/net/route.c (added) * cpukit/libnetworking/net/route.h (added) * cpukit/libnetworking/net/rtsock.c (added) * cpukit/libnetworking/netdb.h (added) * cpukit/libnetworking/netinet/icmp_var.h (added) * cpukit/libnetworking/netinet/if_ether.c (added) * cpukit/libnetworking/netinet/if_ether.h (added) * cpukit/libnetworking/netinet/igmp.c (added) * cpukit/libnetworking/netinet/igmp.h (added) * cpukit/libnetworking/netinet/igmp_var.h (added) * cpukit/libnetworking/netinet/in.c (added) * cpukit/libnetworking/netinet/in.h (added) * cpukit/libnetworking/netinet/in_cksum.c (added) * cpukit/libnetworking/netinet/in_pcb.c (added) * cpukit/libnetworking/netinet/in_pcb.h (added) * cpukit/libnetworking/netinet/in_proto.c (added) * cpukit/libnetworking/netinet/in_rmx.c (added) * cpukit/libnetworking/netinet/in_systm.h (added) * cpukit/libnetworking/netinet/in_var.h (added) * cpukit/libnetworking/netinet/ip.h (added) * cpukit/libnetworking/netinet/ip_divert.c (added) * cpukit/libnetworking/netinet/ip_fw.c (added) * cpukit/libnetworking/netinet/ip_fw.h (added) * cpukit/libnetworking/netinet/ip_icmp.c (added) * cpukit/libnetworking/netinet/ip_icmp.h (added) * cpukit/libnetworking/netinet/ip_input.c (added) * cpukit/libnetworking/netinet/ip_mroute.c (added) * cpukit/libnetworking/netinet/ip_mroute.h (added) * cpukit/libnetworking/netinet/ip_output.c (added) * cpukit/libnetworking/netinet/ip_var.h (added) * cpukit/libnetworking/netinet/raw_ip.c (added) * cpukit/libnetworking/netinet/tcp.h (added) * cpukit/libnetworking/netinet/tcp_debug.c (added) * cpukit/libnetworking/netinet/tcp_debug.h (added) * cpukit/libnetworking/netinet/tcp_fsm.h (added) * cpukit/libnetworking/netinet/tcp_input.c (added) * cpukit/libnetworking/netinet/tcp_output.c (added) * cpukit/libnetworking/netinet/tcp_seq.h (added) * cpukit/libnetworking/netinet/tcp_subr.c (added) * cpukit/libnetworking/netinet/tcp_timer.c (added) * cpukit/libnetworking/netinet/tcp_timer.h (added) * cpukit/libnetworking/netinet/tcp_usrreq.c (added) * cpukit/libnetworking/netinet/tcp_var.h (added) * cpukit/libnetworking/netinet/tcpip.h (added) * cpukit/libnetworking/netinet/udp.h (added) * cpukit/libnetworking/netinet/udp_usrreq.c (added) * cpukit/libnetworking/netinet/udp_var.h (added) * cpukit/libnetworking/nfs/bootp_subr.c (added) * cpukit/libnetworking/nfs/krpc.h (added) * cpukit/libnetworking/nfs/nfs.h (added) * cpukit/libnetworking/nfs/nfsdiskless.h (added) * cpukit/libnetworking/nfs/nfsproto.h (added) * cpukit/libnetworking/nfs/rpcv2.h (added) * cpukit/libnetworking/nfs/xdr_subs.h (added) * cpukit/libnetworking/opt_ipfw.h (added) * cpukit/libnetworking/opt_mrouting.h (added) * cpukit/libnetworking/opt_tcpdebug.h (added) * cpukit/libnetworking/poll.h (added) * cpukit/libnetworking/resolv.h (added) * cpukit/libnetworking/rtems/issetugid.c (added) * cpukit/libnetworking/rtems/rtems_bootp.c (added) * cpukit/libnetworking/rtems/rtems_bsdnet.h (added) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (added) * cpukit/libnetworking/rtems/rtems_glue.c (added) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (added) * cpukit/libnetworking/rtems/rtems_showifstat.c (added) * cpukit/libnetworking/rtems/rtems_showipstat.c (added) * cpukit/libnetworking/rtems/rtems_showmbuf.c (added) * cpukit/libnetworking/rtems/rtems_showroute.c (added) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (added) * cpukit/libnetworking/rtems/rtems_showudpstat.c (added) * cpukit/libnetworking/rtems/rtems_syscall.c (added) * cpukit/libnetworking/rtems/sghostname.c (added) * cpukit/libnetworking/rtems/tftp.h (added) * cpukit/libnetworking/sys/buf.h (added) * cpukit/libnetworking/sys/callout.h (added) * cpukit/libnetworking/sys/conf.h (added) * cpukit/libnetworking/sys/domain.h (added) * cpukit/libnetworking/sys/kernel.h (added) * cpukit/libnetworking/sys/libkern.h (added) * cpukit/libnetworking/sys/malloc.h (added) * cpukit/libnetworking/sys/mbuf.h (added) * cpukit/libnetworking/sys/mount.h (added) * cpukit/libnetworking/sys/param.h (added) * cpukit/libnetworking/sys/proc.h (added) * cpukit/libnetworking/sys/protosw.h (added) * cpukit/libnetworking/sys/queue.h (added) * cpukit/libnetworking/sys/reboot.h (added) * cpukit/libnetworking/sys/resourcevar.h (added) * cpukit/libnetworking/sys/rtprio.h (added) * cpukit/libnetworking/sys/select.h (added) * cpukit/libnetworking/sys/signalvar.h (added) * cpukit/libnetworking/sys/socket.h (added) * cpukit/libnetworking/sys/socketvar.h (added) * cpukit/libnetworking/sys/sysctl.h (added) * cpukit/libnetworking/sys/syslimits.h (added) * cpukit/libnetworking/sys/syslog.h (added) * cpukit/libnetworking/sys/systm.h (added) * cpukit/libnetworking/sys/ttydefaults.h (added) * cpukit/libnetworking/sys/ucred.h (added) * cpukit/libnetworking/sys/uio.h (added) * cpukit/libnetworking/syslog.h (added) * cpukit/libnetworking/vm/vm.h (added) * cpukit/libnetworking/vm/vm_extern.h (added) * cpukit/libnetworking/vm/vm_kern.h (added) * cpukit/libnetworking/vm/vm_param.h (added) Base files
