# # ChangeLog for cpukit/libnetworking/rtems/rtems_glue.c in rtems # # Generated by Trac 1.2.1.dev0 # 05/17/24 23:43:43 Fri, 28 Jan 2005 19:52:19 GMT Eric Norum [547b04f] * cpukit/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Remove dead variable. Fri, 03 Dec 2004 05:07:56 GMT Ralf Corsepius [751c513] * cpukit/ChangeLog (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/radix.h (modified) * cpukit/libnetworking/netinet/if_ether.h (modified) * cpukit/libnetworking/netinet/igmp_var.h (modified) * cpukit/libnetworking/netinet/in_var.h (modified) * cpukit/libnetworking/netinet/tcp_timer.h (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2004-12-03 Ralf Corsepius * ... Sun, 18 Apr 2004 06:19:33 GMT Ralf Corsepius [429ba3b] * cpukit/libnetworking/rtems/ftpfs.h (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/libnetworking/rtems/mkrootfs.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/tftp.h (modified) Remove stray white spaces. Mon, 29 Mar 2004 22:11:51 GMT Ralf Corsepius [d8dbdc0] * cpukit/ChangeLog (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/machine/endian.h (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) 2004-03-29 Ralf Corsepius * ... Mon, 15 Sep 2003 14:04:37 GMT Jennifer Averett [a56c338] * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2003-09-15 Jay Monkman PR ... Tue, 25 Mar 2003 19:00:35 GMT Joel Sherrill [26cdc2a] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_malloc_starvation.c (added) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2002-03-25 Eric Norum PR ... Tue, 11 Feb 2003 22:58:08 GMT Joel Sherrill [83e36d6b] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2003-02-11 Mike Siers * ... Fri, 03 Jan 2003 18:09:57 GMT Joel Sherrill [36799d4] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/kern/kern_mib.c (added) * cpukit/libnetworking/kern/kern_sysctl.c (added) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/rtsock.c (modified) * cpukit/libnetworking/netinet/icmp_var.h (modified) * cpukit/libnetworking/netinet/if_ether.c (modified) * cpukit/libnetworking/netinet/igmp_var.h (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/in_pcb.h (modified) * cpukit/libnetworking/netinet/in_var.h (modified) * cpukit/libnetworking/netinet/ip_fw.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) * cpukit/libnetworking/netinet/tcp_var.h (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) * cpukit/libnetworking/netinet/udp_var.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/sys/kernel.h (modified) * cpukit/libnetworking/sys/linker_set.h (added) * cpukit/libnetworking/sys/queue.h (modified) * cpukit/libnetworking/sys/sysctl.h (modified) 2002-11-26 Chris Johns * ... Fri, 01 Nov 2002 18:43:57 GMT Eric Norum [ce452f7] * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) *** empty log message *** Fri, 04 Oct 2002 13:25:31 GMT Joel Sherrill [ed15301c] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2002-10-04 Jay Monkman * ... Tue, 20 Aug 2002 15:53:52 GMT Joel Sherrill [845f170a] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2002-08-20 Eric Norum * ... Thu, 19 Oct 2000 15:33:03 GMT Joel Sherrill [0da0dea] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2000-10-19 Antti P Miettinen ... Wed, 02 Aug 2000 21:12:36 GMT Joel Sherrill [0e08ff00] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to add optional support for ... Wed, 14 Jun 2000 17:18:18 GMT Joel Sherrill [6f93bb4] * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Chris Johns to enhance network ... Fri, 21 Jan 2000 15:11:40 GMT Joel Sherrill [4a9b897] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum at the request of Jake ... Tue, 09 Nov 1999 03:43:47 GMT Joel Sherrill [a0af97d] * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to add NTP BOOTP support ... Mon, 04 Oct 1999 13:51:22 GMT Joel Sherrill [6fca2f5] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) Patch from Eric Norum . Comments follow: ... Fri, 11 Jun 1999 14:11:44 GMT Joel Sherrill [a6f3cff] * c/src/exec/libnetworking/kern/uipc_socket.c (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/sys/socket.h (modified) * c/src/exec/libnetworking/sys/socketvar.h (modified) * c/src/lib/libnetworking/kern/uipc_socket.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/sys/socket.h (modified) * c/src/lib/libnetworking/sys/socketvar.h (modified) * c/src/libnetworking/kern/uipc_socket.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/sys/socket.h (modified) * c/src/libnetworking/sys/socketvar.h (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/sys/socket.h (modified) * cpukit/libnetworking/sys/socketvar.h (modified) Patch from Ian Lance Taylor : The select function ... Fri, 28 May 1999 18:21:25 GMT Joel Sherrill [f74abcf7] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Changes from Eric Norum to add a loop and limit on the length of time ... Fri, 28 May 1999 16:09:00 GMT Joel Sherrill [403d7b18] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Alignment corrected per Eric Norum's suggestion. Thu, 27 May 1999 18:03:50 GMT Joel Sherrill [11cdbeb] * c/src/exec/libnetworking/kern/uipc_mbuf.c (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/sys/mbuf.h (modified) * c/src/lib/libnetworking/kern/uipc_mbuf.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/sys/mbuf.h (modified) * c/src/libnetworking/kern/uipc_mbuf.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/sys/mbuf.h (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/sys/mbuf.h (modified) Patch from Eric Norum to eliminate a panic ... Tue, 27 Apr 1999 17:31:39 GMT Joel Sherrill [cfcb5a2] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to corrent a miscount in ... Thu, 01 Apr 1999 16:36:22 GMT Joel Sherrill [517660f1] * c/src/exec/libnetworking/machine/in_cksum.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/machine/in_cksum.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/machine/in_cksum.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/machine/in_cksum.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Moved sparc specific version of in_cksum_hdr to an inline routine ... Tue, 30 Mar 1999 17:43:51 GMT Joel Sherrill [ceb06d96] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Removed warning for `#ifdef' argument starts with punctuation. Tue, 23 Mar 1999 23:06:42 GMT Joel Sherrill [e828c2dd] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) SPARC optimized version of IP checksum header routine. Submitted by ... Tue, 23 Mar 1999 22:39:13 GMT Joel Sherrill [b6f5f93] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to improve parsing of ... Mon, 01 Mar 1999 22:40:08 GMT Joel Sherrill [73f6236] * c/src/exec/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/src/close.c (modified) * c/src/exec/libcsupport/src/fchmod.c (modified) * c/src/exec/libcsupport/src/fcntl.c (modified) * c/src/exec/libcsupport/src/fdatasync.c (modified) * c/src/exec/libcsupport/src/fpathconf.c (modified) * c/src/exec/libcsupport/src/fstat.c (modified) * c/src/exec/libcsupport/src/fsync.c (modified) * c/src/exec/libcsupport/src/ftruncate.c (modified) * c/src/exec/libcsupport/src/ioctl.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/libio_sockets.c (modified) * c/src/exec/libcsupport/src/lseek.c (modified) * c/src/exec/libcsupport/src/read.c (modified) * c/src/exec/libcsupport/src/write.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_select.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/include/rtems/libio_.h (modified) * c/src/lib/libc/close.c (modified) * c/src/lib/libc/fchmod.c (modified) * c/src/lib/libc/fcntl.c (modified) * c/src/lib/libc/fdatasync.c (modified) * c/src/lib/libc/fpathconf.c (modified) * c/src/lib/libc/fstat.c (modified) * c/src/lib/libc/fsync.c (modified) * c/src/lib/libc/ftruncate.c (modified) * c/src/lib/libc/ioctl.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/libio_.h (modified) * c/src/lib/libc/libio_sockets.c (modified) * c/src/lib/libc/lseek.c (modified) * c/src/lib/libc/read.c (modified) * c/src/lib/libc/write.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_select.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_select.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/fpathconf.c (modified) * cpukit/libcsupport/src/fstat.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/libio_sockets.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/write.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Patch from Eric Norum to eliminate external ... Fri, 05 Feb 1999 00:29:23 GMT Joel Sherrill [ecec2ba] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to correct bug induced by select() patch. Thu, 10 Dec 1998 23:31:54 GMT Joel Sherrill [cca4400] * VERSION (modified) * c/src/exec/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/sys/sockio.h (modified) * c/src/exec/libcsupport/src/close.c (modified) * c/src/exec/libcsupport/src/fchmod.c (modified) * c/src/exec/libcsupport/src/fcntl.c (modified) * c/src/exec/libcsupport/src/fdatasync.c (modified) * c/src/exec/libcsupport/src/fpathconf.c (modified) * c/src/exec/libcsupport/src/fsync.c (modified) * c/src/exec/libcsupport/src/ftruncate.c (modified) * c/src/exec/libcsupport/src/ioctl.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/lseek.c (modified) * c/src/exec/libcsupport/src/read.c (modified) * c/src/exec/libcsupport/src/write.c (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/include/rtems/libio_.h (modified) * c/src/lib/include/sys/sockio.h (modified) * c/src/lib/libc/close.c (modified) * c/src/lib/libc/fchmod.c (modified) * c/src/lib/libc/fcntl.c (modified) * c/src/lib/libc/fdatasync.c (modified) * c/src/lib/libc/fpathconf.c (modified) * c/src/lib/libc/fsync.c (modified) * c/src/lib/libc/ftruncate.c (modified) * c/src/lib/libc/ioctl.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/libio_.h (modified) * c/src/lib/libc/lseek.c (modified) * c/src/lib/libc/read.c (modified) * c/src/lib/libc/write.c (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/sys/sockio.h (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/sys/sockio.h (modified) * configure (modified) * configure.in (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/sys/sockio.h (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/fpathconf.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/write.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Merged Eric Norum's select patch that was based on 4.0 and resolved ... Mon, 07 Dec 1998 17:42:52 GMT Joel Sherrill [91b1c8e6] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Patch from Ian Lance Taylor : RTEMS permits using ... Thu, 19 Nov 1998 17:35:49 GMT Joel Sherrill [847375f] * c/src/exec/libnetworking/kern/uipc_socket.c (modified) * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/sys/socketvar.h (modified) * c/src/exec/posix/src/psignal.c (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/src/thread.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/device-tree (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libnetworking/kern/uipc_socket.c (modified) * c/src/lib/libnetworking/nfs/bootp_subr.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/sys/socketvar.h (modified) * c/src/libnetworking/kern/uipc_socket.c (modified) * c/src/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/sys/socketvar.h (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/sys/socketvar.h (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/thread.c (modified) Patch from Eric Norum : 1) Socket ... Thu, 10 Sep 1998 12:23:08 GMT Joel Sherrill [109b17f4] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to fix a cryptic error ... Fri, 21 Aug 1998 13:04:55 GMT Joel Sherrill [33679ec4] * c/src/exec/libnetworking/libc/res_send.c (modified) * c/src/exec/libnetworking/netinet/ip_input.c (modified) * c/src/exec/libnetworking/netinet/ip_mroute.c (modified) * c/src/exec/libnetworking/netinet/tcp_input.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_showroute.c (modified) * c/src/lib/libnetworking/libc/res_send.c (modified) * c/src/lib/libnetworking/netinet/ip_input.c (modified) * c/src/lib/libnetworking/netinet/ip_mroute.c (modified) * c/src/lib/libnetworking/netinet/tcp_input.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_showroute.c (modified) * c/src/libnetworking/libc/res_send.c (modified) * c/src/libnetworking/netinet/ip_input.c (modified) * c/src/libnetworking/netinet/ip_mroute.c (modified) * c/src/libnetworking/netinet/tcp_input.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) All warnings removed. Thu, 20 Aug 1998 21:56:40 GMT Joel Sherrill [96b39164] * c/src/exec/libnetworking/README (modified) * c/src/exec/libnetworking/arpa/ftp.h (modified) * c/src/exec/libnetworking/arpa/telnet.h (modified) * c/src/exec/libnetworking/bpfilter.h (modified) * c/src/exec/libnetworking/lib/README (modified) * c/src/exec/libnetworking/lib/getprotoby.c (modified) * c/src/exec/libnetworking/libc/addr2ascii.3 (modified) * c/src/exec/libnetworking/libc/addr2ascii.c (modified) * c/src/exec/libnetworking/libc/ascii2addr.c (modified) * c/src/exec/libnetworking/libc/byteorder.3 (modified) * c/src/exec/libnetworking/libc/gethostname.c (modified) * c/src/exec/libnetworking/libc/getnetent.3 (modified) * c/src/exec/libnetworking/libc/getproto.c (modified) * c/src/exec/libnetworking/libc/getprotoent.3 (modified) * c/src/exec/libnetworking/libc/getprotoent.c (modified) * c/src/exec/libnetworking/libc/getprotoname.c (modified) * c/src/exec/libnetworking/libc/getservbyname.c (modified) * c/src/exec/libnetworking/libc/getservbyport.c (modified) * c/src/exec/libnetworking/libc/getservent.c (modified) * c/src/exec/libnetworking/libc/inet_lnaof.c (modified) * c/src/exec/libnetworking/libc/inet_makeaddr.c (modified) * c/src/exec/libnetworking/libc/inet_netof.c (modified) * c/src/exec/libnetworking/libc/inet_network.c (modified) * c/src/exec/libnetworking/libc/inet_ntoa.c (modified) * c/src/exec/libnetworking/libc/iso_addr.3 (modified) * c/src/exec/libnetworking/libc/iso_addr.c (modified) * c/src/exec/libnetworking/libc/linkaddr.c (modified) * c/src/exec/libnetworking/libc/ns_addr.c (modified) * c/src/exec/libnetworking/libc/ns_ntoa.c (modified) * c/src/exec/libnetworking/libc/rcmd.c (modified) * c/src/exec/libnetworking/libc/recv.c (modified) * c/src/exec/libnetworking/libc/res_config.h (modified) * c/src/exec/libnetworking/libc/resolver.3 (modified) * c/src/exec/libnetworking/libc/send.c (modified) * c/src/exec/libnetworking/libc/strsep.c (modified) * c/src/exec/libnetworking/loop.h (modified) * c/src/exec/libnetworking/machine/conf.h (modified) * c/src/exec/libnetworking/machine/cpu.h (modified) * c/src/exec/libnetworking/machine/cpufunc.h (modified) * c/src/exec/libnetworking/machine/endian.h (modified) * c/src/exec/libnetworking/machine/limits.h (modified) * c/src/exec/libnetworking/machine/param.h (modified) * c/src/exec/libnetworking/machine/types.h (modified) * c/src/exec/libnetworking/machine/vmparam.h (modified) * c/src/exec/libnetworking/opt_ipfw.h (modified) * c/src/exec/libnetworking/opt_mrouting.h (modified) * c/src/exec/libnetworking/opt_tcpdebug.h (modified) * c/src/exec/libnetworking/rtems/issetugid.c (modified) * c/src/exec/libnetworking/rtems/rtems_bootp.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_showicmpstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_showipstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_showmbuf.c (modified) * c/src/exec/libnetworking/rtems/rtems_showroute.c (modified) * c/src/exec/libnetworking/rtems/rtems_showtcpstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_showudpstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/libnetworking/rtems/sghostname.c (modified) * c/src/exec/libnetworking/sys/proc.h (modified) * c/src/exec/libnetworking/sys/resourcevar.h (modified) * c/src/exec/libnetworking/syslog.h (modified) * c/src/lib/libnetworking/CHANGELOG (modified) * c/src/lib/libnetworking/README (modified) * c/src/lib/libnetworking/arpa/ftp.h (modified) * c/src/lib/libnetworking/arpa/telnet.h (modified) * c/src/lib/libnetworking/bpfilter.h (modified) * c/src/lib/libnetworking/lib/README (modified) * c/src/lib/libnetworking/lib/getprotoby.c (modified) * c/src/lib/libnetworking/libc/addr2ascii.3 (modified) * c/src/lib/libnetworking/libc/addr2ascii.c (modified) * c/src/lib/libnetworking/libc/ascii2addr.c (modified) * c/src/lib/libnetworking/libc/byteorder.3 (modified) * c/src/lib/libnetworking/libc/gethostname.c (modified) * c/src/lib/libnetworking/libc/getnetent.3 (modified) * c/src/lib/libnetworking/libc/getproto.c (modified) * c/src/lib/libnetworking/libc/getprotoent.3 (modified) * c/src/lib/libnetworking/libc/getprotoent.c (modified) * c/src/lib/libnetworking/libc/getprotoname.c (modified) * c/src/lib/libnetworking/libc/getservbyname.c (modified) * c/src/lib/libnetworking/libc/getservbyport.c (modified) * c/src/lib/libnetworking/libc/getservent.c (modified) * c/src/lib/libnetworking/libc/inet_lnaof.c (modified) * c/src/lib/libnetworking/libc/inet_makeaddr.c (modified) * c/src/lib/libnetworking/libc/inet_netof.c (modified) * c/src/lib/libnetworking/libc/inet_network.c (modified) * c/src/lib/libnetworking/libc/inet_ntoa.c (modified) * c/src/lib/libnetworking/libc/iso_addr.3 (modified) * c/src/lib/libnetworking/libc/iso_addr.c (modified) * c/src/lib/libnetworking/libc/linkaddr.c (modified) * c/src/lib/libnetworking/libc/ns_addr.c (modified) * c/src/lib/libnetworking/libc/ns_ntoa.c (modified) * c/src/lib/libnetworking/libc/rcmd.c (modified) * c/src/lib/libnetworking/libc/recv.c (modified) * c/src/lib/libnetworking/libc/res_config.h (modified) * c/src/lib/libnetworking/libc/resolver.3 (modified) * c/src/lib/libnetworking/libc/send.c (modified) * c/src/lib/libnetworking/libc/strsep.c (modified) * c/src/lib/libnetworking/loop.h (modified) * c/src/lib/libnetworking/machine/conf.h (modified) * c/src/lib/libnetworking/machine/cpu.h (modified) * c/src/lib/libnetworking/machine/cpufunc.h (modified) * c/src/lib/libnetworking/machine/endian.h (modified) * c/src/lib/libnetworking/machine/limits.h (modified) * c/src/lib/libnetworking/machine/param.h (modified) * c/src/lib/libnetworking/machine/types.h (modified) * c/src/lib/libnetworking/machine/vmparam.h (modified) * c/src/lib/libnetworking/opt_ipfw.h (modified) * c/src/lib/libnetworking/opt_mrouting.h (modified) * c/src/lib/libnetworking/opt_tcpdebug.h (modified) * c/src/lib/libnetworking/rtems/issetugid.c (modified) * c/src/lib/libnetworking/rtems/rtems_bootp.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_showicmpstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_showipstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_showmbuf.c (modified) * c/src/lib/libnetworking/rtems/rtems_showroute.c (modified) * c/src/lib/libnetworking/rtems/rtems_showtcpstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_showudpstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/rtems/sghostname.c (modified) * c/src/lib/libnetworking/sys/proc.h (modified) * c/src/lib/libnetworking/sys/resourcevar.h (modified) * c/src/lib/libnetworking/syslog.h (modified) * c/src/libnetworking/CHANGELOG (modified) * c/src/libnetworking/README (modified) * c/src/libnetworking/arpa/ftp.h (modified) * c/src/libnetworking/arpa/telnet.h (modified) * c/src/libnetworking/bpfilter.h (modified) * c/src/libnetworking/lib/README (modified) * c/src/libnetworking/lib/getprotoby.c (modified) * c/src/libnetworking/libc/addr2ascii.3 (modified) * c/src/libnetworking/libc/addr2ascii.c (modified) * c/src/libnetworking/libc/ascii2addr.c (modified) * c/src/libnetworking/libc/byteorder.3 (modified) * c/src/libnetworking/libc/gethostname.c (modified) * c/src/libnetworking/libc/getnetent.3 (modified) * c/src/libnetworking/libc/getproto.c (modified) * c/src/libnetworking/libc/getprotoent.3 (modified) * c/src/libnetworking/libc/getprotoent.c (modified) * c/src/libnetworking/libc/getprotoname.c (modified) * c/src/libnetworking/libc/getservbyname.c (modified) * c/src/libnetworking/libc/getservbyport.c (modified) * c/src/libnetworking/libc/getservent.c (modified) * c/src/libnetworking/libc/inet_lnaof.c (modified) * c/src/libnetworking/libc/inet_makeaddr.c (modified) * c/src/libnetworking/libc/inet_netof.c (modified) * c/src/libnetworking/libc/inet_network.c (modified) * c/src/libnetworking/libc/inet_ntoa.c (modified) * c/src/libnetworking/libc/iso_addr.3 (modified) * c/src/libnetworking/libc/iso_addr.c (modified) * c/src/libnetworking/libc/linkaddr.c (modified) * c/src/libnetworking/libc/ns_addr.c (modified) * c/src/libnetworking/libc/ns_ntoa.c (modified) * c/src/libnetworking/libc/rcmd.c (modified) * c/src/libnetworking/libc/recv.c (modified) * c/src/libnetworking/libc/res_config.h (modified) * c/src/libnetworking/libc/resolver.3 (modified) * c/src/libnetworking/libc/send.c (modified) * c/src/libnetworking/libc/strsep.c (modified) * c/src/libnetworking/loop.h (modified) * c/src/libnetworking/machine/conf.h (modified) * c/src/libnetworking/machine/cpu.h (modified) * c/src/libnetworking/machine/cpufunc.h (modified) * c/src/libnetworking/machine/endian.h (modified) * c/src/libnetworking/machine/limits.h (modified) * c/src/libnetworking/machine/param.h (modified) * c/src/libnetworking/machine/types.h (modified) * c/src/libnetworking/machine/vmparam.h (modified) * c/src/libnetworking/opt_ipfw.h (modified) * c/src/libnetworking/opt_mrouting.h (modified) * c/src/libnetworking/opt_tcpdebug.h (modified) * c/src/libnetworking/rtems/issetugid.c (modified) * c/src/libnetworking/rtems/rtems_bootp.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_showicmpstat.c (modified) * c/src/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/libnetworking/rtems/rtems_showipstat.c (modified) * c/src/libnetworking/rtems/rtems_showmbuf.c (modified) * c/src/libnetworking/rtems/rtems_showroute.c (modified) * c/src/libnetworking/rtems/rtems_showtcpstat.c (modified) * c/src/libnetworking/rtems/rtems_showudpstat.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/sghostname.c (modified) * c/src/libnetworking/sys/proc.h (modified) * c/src/libnetworking/sys/resourcevar.h (modified) * c/src/libnetworking/syslog.h (modified) * cpukit/libnetworking/README (modified) * cpukit/libnetworking/arpa/ftp.h (modified) * cpukit/libnetworking/arpa/telnet.h (modified) * cpukit/libnetworking/bpfilter.h (modified) * cpukit/libnetworking/lib/README (modified) * cpukit/libnetworking/lib/getprotoby.c (modified) * cpukit/libnetworking/libc/addr2ascii.3 (modified) * cpukit/libnetworking/libc/addr2ascii.c (modified) * cpukit/libnetworking/libc/ascii2addr.c (modified) * cpukit/libnetworking/libc/byteorder.3 (modified) * cpukit/libnetworking/libc/gethostname.c (modified) * cpukit/libnetworking/libc/getnetent.3 (modified) * cpukit/libnetworking/libc/getproto.c (modified) * cpukit/libnetworking/libc/getprotoent.3 (modified) * cpukit/libnetworking/libc/getprotoent.c (modified) * cpukit/libnetworking/libc/getprotoname.c (modified) * cpukit/libnetworking/libc/getservbyname.c (modified) * cpukit/libnetworking/libc/getservbyport.c (modified) * cpukit/libnetworking/libc/getservent.c (modified) * cpukit/libnetworking/libc/inet_lnaof.c (modified) * cpukit/libnetworking/libc/inet_makeaddr.c (modified) * cpukit/libnetworking/libc/inet_netof.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/libc/inet_ntoa.c (modified) * cpukit/libnetworking/libc/iso_addr.3 (modified) * cpukit/libnetworking/libc/iso_addr.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/ns_addr.c (modified) * cpukit/libnetworking/libc/ns_ntoa.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/recv.c (modified) * cpukit/libnetworking/libc/res_config.h (modified) * cpukit/libnetworking/libc/resolver.3 (modified) * cpukit/libnetworking/libc/send.c (modified) * cpukit/libnetworking/libc/strsep.c (modified) * cpukit/libnetworking/loop.h (modified) * cpukit/libnetworking/machine/conf.h (modified) * cpukit/libnetworking/machine/cpu.h (modified) * cpukit/libnetworking/machine/cpufunc.h (modified) * cpukit/libnetworking/machine/endian.h (modified) * cpukit/libnetworking/machine/limits.h (modified) * cpukit/libnetworking/machine/param.h (modified) * cpukit/libnetworking/machine/types.h (modified) * cpukit/libnetworking/machine/vmparam.h (modified) * cpukit/libnetworking/opt_ipfw.h (modified) * cpukit/libnetworking/opt_mrouting.h (modified) * cpukit/libnetworking/opt_tcpdebug.h (modified) * cpukit/libnetworking/rtems/issetugid.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_showipstat.c (modified) * cpukit/libnetworking/rtems/rtems_showmbuf.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showudpstat.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/sghostname.c (modified) * cpukit/libnetworking/sys/proc.h (modified) * cpukit/libnetworking/sys/resourcevar.h (modified) * cpukit/libnetworking/syslog.h (modified) Added CVS Ids Wed, 19 Aug 1998 21:32:28 GMT Joel Sherrill [39e6e65a] * c/src/exec/libcsupport/include/sys/filio.h (added) * c/src/exec/libcsupport/include/sys/ioctl.h (added) * c/src/exec/libcsupport/include/sys/sockio.h (added) * c/src/exec/libnetworking/README (added) * c/src/exec/libnetworking/arpa/ftp.h (added) * c/src/exec/libnetworking/arpa/inet.h (added) * c/src/exec/libnetworking/arpa/nameser.h (added) * c/src/exec/libnetworking/arpa/nameser_compat.h (added) * c/src/exec/libnetworking/arpa/telnet.h (added) * c/src/exec/libnetworking/bpfilter.h (added) * c/src/exec/libnetworking/kern/kern_subr.c (added) * c/src/exec/libnetworking/kern/uipc_domain.c (added) * c/src/exec/libnetworking/kern/uipc_mbuf.c (added) * c/src/exec/libnetworking/kern/uipc_socket.c (added) * c/src/exec/libnetworking/kern/uipc_socket2.c (added) * c/src/exec/libnetworking/lib/README (added) * c/src/exec/libnetworking/lib/getprotoby.c (added) * c/src/exec/libnetworking/lib/syslog.c (added) * c/src/exec/libnetworking/lib/tftpDriver.c (added) * c/src/exec/libnetworking/libc/addr2ascii.3 (added) * c/src/exec/libnetworking/libc/addr2ascii.c (added) * c/src/exec/libnetworking/libc/ascii2addr.c (added) * c/src/exec/libnetworking/libc/base64.c (added) * c/src/exec/libnetworking/libc/byteorder.3 (added) * c/src/exec/libnetworking/libc/ether_addr.c (added) * c/src/exec/libnetworking/libc/ethers.3 (added) * c/src/exec/libnetworking/libc/gethostbydns.c (added) * c/src/exec/libnetworking/libc/gethostbyht.c (added) * c/src/exec/libnetworking/libc/gethostbyname.3 (added) * c/src/exec/libnetworking/libc/gethostbynis.c (added) * c/src/exec/libnetworking/libc/gethostnamadr.c (added) * c/src/exec/libnetworking/libc/gethostname.c (added) * c/src/exec/libnetworking/libc/getnetbydns.c (added) * c/src/exec/libnetworking/libc/getnetbyht.c (added) * c/src/exec/libnetworking/libc/getnetbynis.c (added) * c/src/exec/libnetworking/libc/getnetent.3 (added) * c/src/exec/libnetworking/libc/getnetnamadr.c (added) * c/src/exec/libnetworking/libc/getproto.c (added) * c/src/exec/libnetworking/libc/getprotoent.3 (added) * c/src/exec/libnetworking/libc/getprotoent.c (added) * c/src/exec/libnetworking/libc/getprotoname.c (added) * c/src/exec/libnetworking/libc/getservbyname.c (added) * c/src/exec/libnetworking/libc/getservbyport.c (added) * c/src/exec/libnetworking/libc/getservent.3 (added) * c/src/exec/libnetworking/libc/getservent.c (added) * c/src/exec/libnetworking/libc/herror.c (added) * c/src/exec/libnetworking/libc/inet.3 (added) * c/src/exec/libnetworking/libc/inet_addr.c (added) * c/src/exec/libnetworking/libc/inet_lnaof.c (added) * c/src/exec/libnetworking/libc/inet_makeaddr.c (added) * c/src/exec/libnetworking/libc/inet_net_ntop.c (added) * c/src/exec/libnetworking/libc/inet_net_pton.c (added) * c/src/exec/libnetworking/libc/inet_neta.c (added) * c/src/exec/libnetworking/libc/inet_netof.c (added) * c/src/exec/libnetworking/libc/inet_network.c (added) * c/src/exec/libnetworking/libc/inet_ntoa.c (added) * c/src/exec/libnetworking/libc/inet_ntop.c (added) * c/src/exec/libnetworking/libc/inet_pton.c (added) * c/src/exec/libnetworking/libc/iso_addr.3 (added) * c/src/exec/libnetworking/libc/iso_addr.c (added) * c/src/exec/libnetworking/libc/linkaddr.3 (added) * c/src/exec/libnetworking/libc/linkaddr.c (added) * c/src/exec/libnetworking/libc/map_v4v6.c (added) * c/src/exec/libnetworking/libc/ns.3 (added) * c/src/exec/libnetworking/libc/ns_addr.c (added) * c/src/exec/libnetworking/libc/ns_name.c (added) * c/src/exec/libnetworking/libc/ns_netint.c (added) * c/src/exec/libnetworking/libc/ns_ntoa.c (added) * c/src/exec/libnetworking/libc/ns_parse.c (added) * c/src/exec/libnetworking/libc/ns_print.c (added) * c/src/exec/libnetworking/libc/ns_ttl.c (added) * c/src/exec/libnetworking/libc/nsap_addr.c (added) * c/src/exec/libnetworking/libc/rcmd.3 (added) * c/src/exec/libnetworking/libc/rcmd.c (added) * c/src/exec/libnetworking/libc/recv.c (added) * c/src/exec/libnetworking/libc/res_comp.c (added) * c/src/exec/libnetworking/libc/res_config.h (added) * c/src/exec/libnetworking/libc/res_data.c (added) * c/src/exec/libnetworking/libc/res_debug.c (added) * c/src/exec/libnetworking/libc/res_init.c (added) * c/src/exec/libnetworking/libc/res_mkquery.c (added) * c/src/exec/libnetworking/libc/res_mkupdate.c (added) * c/src/exec/libnetworking/libc/res_query.c (added) * c/src/exec/libnetworking/libc/res_send.c (added) * c/src/exec/libnetworking/libc/res_stubs.c (added) * c/src/exec/libnetworking/libc/res_update.c (added) * c/src/exec/libnetworking/libc/resolver.3 (added) * c/src/exec/libnetworking/libc/send.c (added) * c/src/exec/libnetworking/libc/strsep.c (added) * c/src/exec/libnetworking/loop.h (added) * c/src/exec/libnetworking/net/bpf.h (added) * c/src/exec/libnetworking/net/ethernet.h (added) * c/src/exec/libnetworking/net/if.c (added) * c/src/exec/libnetworking/net/if.h (added) * c/src/exec/libnetworking/net/if_arp.h (added) * c/src/exec/libnetworking/net/if_dl.h (added) * c/src/exec/libnetworking/net/if_ethersubr.c (added) * c/src/exec/libnetworking/net/if_llc.h (added) * c/src/exec/libnetworking/net/if_loop.c (added) * c/src/exec/libnetworking/net/if_types.h (added) * c/src/exec/libnetworking/net/netisr.h (added) * c/src/exec/libnetworking/net/radix.c (added) * c/src/exec/libnetworking/net/radix.h (added) * c/src/exec/libnetworking/net/raw_cb.c (added) * c/src/exec/libnetworking/net/raw_cb.h (added) * c/src/exec/libnetworking/net/raw_usrreq.c (added) * c/src/exec/libnetworking/net/route.c (added) * c/src/exec/libnetworking/net/route.h (added) * c/src/exec/libnetworking/net/rtsock.c (added) * c/src/exec/libnetworking/netdb.h (added) * c/src/exec/libnetworking/netinet/icmp_var.h (added) * c/src/exec/libnetworking/netinet/if_ether.c (added) * c/src/exec/libnetworking/netinet/if_ether.h (added) * c/src/exec/libnetworking/netinet/igmp.c (added) * c/src/exec/libnetworking/netinet/igmp.h (added) * c/src/exec/libnetworking/netinet/igmp_var.h (added) * c/src/exec/libnetworking/netinet/in.c (added) * c/src/exec/libnetworking/netinet/in.h (added) * c/src/exec/libnetworking/netinet/in_cksum.c (added) * c/src/exec/libnetworking/netinet/in_pcb.c (added) * c/src/exec/libnetworking/netinet/in_pcb.h (added) * c/src/exec/libnetworking/netinet/in_proto.c (added) * c/src/exec/libnetworking/netinet/in_rmx.c (added) * c/src/exec/libnetworking/netinet/in_systm.h (added) * c/src/exec/libnetworking/netinet/in_var.h (added) * c/src/exec/libnetworking/netinet/ip.h (added) * c/src/exec/libnetworking/netinet/ip_divert.c (added) * c/src/exec/libnetworking/netinet/ip_fw.c (added) * c/src/exec/libnetworking/netinet/ip_fw.h (added) * c/src/exec/libnetworking/netinet/ip_icmp.c (added) * c/src/exec/libnetworking/netinet/ip_icmp.h (added) * c/src/exec/libnetworking/netinet/ip_input.c (added) * c/src/exec/libnetworking/netinet/ip_mroute.c (added) * c/src/exec/libnetworking/netinet/ip_mroute.h (added) * c/src/exec/libnetworking/netinet/ip_output.c (added) * c/src/exec/libnetworking/netinet/ip_var.h (added) * c/src/exec/libnetworking/netinet/raw_ip.c (added) * c/src/exec/libnetworking/netinet/tcp.h (added) * c/src/exec/libnetworking/netinet/tcp_debug.c (added) * c/src/exec/libnetworking/netinet/tcp_debug.h (added) * c/src/exec/libnetworking/netinet/tcp_fsm.h (added) * c/src/exec/libnetworking/netinet/tcp_input.c (added) * c/src/exec/libnetworking/netinet/tcp_output.c (added) * c/src/exec/libnetworking/netinet/tcp_seq.h (added) * c/src/exec/libnetworking/netinet/tcp_subr.c (added) * c/src/exec/libnetworking/netinet/tcp_timer.c (added) * c/src/exec/libnetworking/netinet/tcp_timer.h (added) * c/src/exec/libnetworking/netinet/tcp_usrreq.c (added) * c/src/exec/libnetworking/netinet/tcp_var.h (added) * c/src/exec/libnetworking/netinet/tcpip.h (added) * c/src/exec/libnetworking/netinet/udp.h (added) * c/src/exec/libnetworking/netinet/udp_usrreq.c (added) * c/src/exec/libnetworking/netinet/udp_var.h (added) * c/src/exec/libnetworking/nfs/bootp_subr.c (added) * c/src/exec/libnetworking/nfs/krpc.h (added) * c/src/exec/libnetworking/nfs/nfs.h (added) * c/src/exec/libnetworking/nfs/nfsdiskless.h (added) * c/src/exec/libnetworking/nfs/nfsproto.h (added) * c/src/exec/libnetworking/nfs/rpcv2.h (added) * c/src/exec/libnetworking/nfs/xdr_subs.h (added) * c/src/exec/libnetworking/opt_ipfw.h (added) * c/src/exec/libnetworking/opt_mrouting.h (added) * c/src/exec/libnetworking/opt_tcpdebug.h (added) * c/src/exec/libnetworking/poll.h (added) * c/src/exec/libnetworking/resolv.h (added) * c/src/exec/libnetworking/rtems/issetugid.c (added) * c/src/exec/libnetworking/rtems/rtems_bootp.c (added) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (added) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (added) * c/src/exec/libnetworking/rtems/rtems_glue.c (added) * c/src/exec/libnetworking/rtems/rtems_showicmpstat.c (added) * c/src/exec/libnetworking/rtems/rtems_showifstat.c (added) * c/src/exec/libnetworking/rtems/rtems_showipstat.c (added) * c/src/exec/libnetworking/rtems/rtems_showmbuf.c (added) * c/src/exec/libnetworking/rtems/rtems_showroute.c (added) * c/src/exec/libnetworking/rtems/rtems_showtcpstat.c (added) * c/src/exec/libnetworking/rtems/rtems_showudpstat.c (added) * c/src/exec/libnetworking/rtems/rtems_syscall.c (added) * c/src/exec/libnetworking/rtems/sghostname.c (added) * c/src/exec/libnetworking/rtems/tftp.h (added) * c/src/exec/libnetworking/sys/buf.h (added) * c/src/exec/libnetworking/sys/callout.h (added) * c/src/exec/libnetworking/sys/conf.h (added) * c/src/exec/libnetworking/sys/domain.h (added) * c/src/exec/libnetworking/sys/kernel.h (added) * c/src/exec/libnetworking/sys/libkern.h (added) * c/src/exec/libnetworking/sys/malloc.h (added) * c/src/exec/libnetworking/sys/mbuf.h (added) * c/src/exec/libnetworking/sys/mount.h (added) * c/src/exec/libnetworking/sys/param.h (added) * c/src/exec/libnetworking/sys/proc.h (added) * c/src/exec/libnetworking/sys/protosw.h (added) * c/src/exec/libnetworking/sys/queue.h (added) * c/src/exec/libnetworking/sys/reboot.h (added) * c/src/exec/libnetworking/sys/resourcevar.h (added) * c/src/exec/libnetworking/sys/rtprio.h (added) * c/src/exec/libnetworking/sys/select.h (added) * c/src/exec/libnetworking/sys/signalvar.h (added) * c/src/exec/libnetworking/sys/socket.h (added) * c/src/exec/libnetworking/sys/socketvar.h (added) * c/src/exec/libnetworking/sys/sysctl.h (added) * c/src/exec/libnetworking/sys/syslimits.h (added) * c/src/exec/libnetworking/sys/syslog.h (added) * c/src/exec/libnetworking/sys/systm.h (added) * c/src/exec/libnetworking/sys/ttydefaults.h (added) * c/src/exec/libnetworking/sys/ucred.h (added) * c/src/exec/libnetworking/sys/uio.h (added) * c/src/exec/libnetworking/syslog.h (added) * c/src/exec/libnetworking/vm/vm.h (added) * c/src/exec/libnetworking/vm/vm_extern.h (added) * c/src/exec/libnetworking/vm/vm_kern.h (added) * c/src/exec/libnetworking/vm/vm_param.h (added) * c/src/lib/include/sys/filio.h (added) * c/src/lib/include/sys/ioctl.h (added) * c/src/lib/include/sys/sockio.h (added) * c/src/lib/libnetworking/CHANGELOG (added) * c/src/lib/libnetworking/README (added) * c/src/lib/libnetworking/arpa/ftp.h (added) * c/src/lib/libnetworking/arpa/inet.h (added) * c/src/lib/libnetworking/arpa/nameser.h (added) * c/src/lib/libnetworking/arpa/nameser_compat.h (added) * c/src/lib/libnetworking/arpa/telnet.h (added) * c/src/lib/libnetworking/bpfilter.h (added) * c/src/lib/libnetworking/kern/kern_subr.c (added) * c/src/lib/libnetworking/kern/uipc_domain.c (added) * c/src/lib/libnetworking/kern/uipc_mbuf.c (added) * c/src/lib/libnetworking/kern/uipc_socket.c (added) * c/src/lib/libnetworking/kern/uipc_socket2.c (added) * c/src/lib/libnetworking/lib/README (added) * c/src/lib/libnetworking/lib/getprotoby.c (added) * c/src/lib/libnetworking/lib/syslog.c (added) * c/src/lib/libnetworking/lib/tftpDriver.c (added) * c/src/lib/libnetworking/libc/addr2ascii.3 (added) * c/src/lib/libnetworking/libc/addr2ascii.c (added) * c/src/lib/libnetworking/libc/ascii2addr.c (added) * c/src/lib/libnetworking/libc/base64.c (added) * c/src/lib/libnetworking/libc/byteorder.3 (added) * c/src/lib/libnetworking/libc/ether_addr.c (added) * c/src/lib/libnetworking/libc/ethers.3 (added) * c/src/lib/libnetworking/libc/gethostbydns.c (added) * c/src/lib/libnetworking/libc/gethostbyht.c (added) * c/src/lib/libnetworking/libc/gethostbyname.3 (added) * c/src/lib/libnetworking/libc/gethostbynis.c (added) * c/src/lib/libnetworking/libc/gethostnamadr.c (added) * c/src/lib/libnetworking/libc/gethostname.c (added) * c/src/lib/libnetworking/libc/getnetbydns.c (added) * c/src/lib/libnetworking/libc/getnetbyht.c (added) * c/src/lib/libnetworking/libc/getnetbynis.c (added) * c/src/lib/libnetworking/libc/getnetent.3 (added) * c/src/lib/libnetworking/libc/getnetnamadr.c (added) * c/src/lib/libnetworking/libc/getproto.c (added) * c/src/lib/libnetworking/libc/getprotoent.3 (added) * c/src/lib/libnetworking/libc/getprotoent.c (added) * c/src/lib/libnetworking/libc/getprotoname.c (added) * c/src/lib/libnetworking/libc/getservbyname.c (added) * c/src/lib/libnetworking/libc/getservbyport.c (added) * c/src/lib/libnetworking/libc/getservent.3 (added) * c/src/lib/libnetworking/libc/getservent.c (added) * c/src/lib/libnetworking/libc/herror.c (added) * c/src/lib/libnetworking/libc/inet.3 (added) * c/src/lib/libnetworking/libc/inet_addr.c (added) * c/src/lib/libnetworking/libc/inet_lnaof.c (added) * c/src/lib/libnetworking/libc/inet_makeaddr.c (added) * c/src/lib/libnetworking/libc/inet_net_ntop.c (added) * c/src/lib/libnetworking/libc/inet_net_pton.c (added) * c/src/lib/libnetworking/libc/inet_neta.c (added) * c/src/lib/libnetworking/libc/inet_netof.c (added) * c/src/lib/libnetworking/libc/inet_network.c (added) * c/src/lib/libnetworking/libc/inet_ntoa.c (added) * c/src/lib/libnetworking/libc/inet_ntop.c (added) * c/src/lib/libnetworking/libc/inet_pton.c (added) * c/src/lib/libnetworking/libc/iso_addr.3 (added) * c/src/lib/libnetworking/libc/iso_addr.c (added) * c/src/lib/libnetworking/libc/linkaddr.3 (added) * c/src/lib/libnetworking/libc/linkaddr.c (added) * c/src/lib/libnetworking/libc/map_v4v6.c (added) * c/src/lib/libnetworking/libc/ns.3 (added) * c/src/lib/libnetworking/libc/ns_addr.c (added) * c/src/lib/libnetworking/libc/ns_name.c (added) * c/src/lib/libnetworking/libc/ns_netint.c (added) * c/src/lib/libnetworking/libc/ns_ntoa.c (added) * c/src/lib/libnetworking/libc/ns_parse.c (added) * c/src/lib/libnetworking/libc/ns_print.c (added) * c/src/lib/libnetworking/libc/ns_ttl.c (added) * c/src/lib/libnetworking/libc/nsap_addr.c (added) * c/src/lib/libnetworking/libc/rcmd.3 (added) * c/src/lib/libnetworking/libc/rcmd.c (added) * c/src/lib/libnetworking/libc/recv.c (added) * c/src/lib/libnetworking/libc/res_comp.c (added) * c/src/lib/libnetworking/libc/res_config.h (added) * c/src/lib/libnetworking/libc/res_data.c (added) * c/src/lib/libnetworking/libc/res_debug.c (added) * c/src/lib/libnetworking/libc/res_init.c (added) * c/src/lib/libnetworking/libc/res_mkquery.c (added) * c/src/lib/libnetworking/libc/res_mkupdate.c (added) * c/src/lib/libnetworking/libc/res_query.c (added) * c/src/lib/libnetworking/libc/res_send.c (added) * c/src/lib/libnetworking/libc/res_stubs.c (added) * c/src/lib/libnetworking/libc/res_update.c (added) * c/src/lib/libnetworking/libc/resolver.3 (added) * c/src/lib/libnetworking/libc/send.c (added) * c/src/lib/libnetworking/libc/strsep.c (added) * c/src/lib/libnetworking/loop.h (added) * c/src/lib/libnetworking/net/bpf.h (added) * c/src/lib/libnetworking/net/ethernet.h (added) * c/src/lib/libnetworking/net/if.c (added) * c/src/lib/libnetworking/net/if.h (added) * c/src/lib/libnetworking/net/if_arp.h (added) * c/src/lib/libnetworking/net/if_dl.h (added) * c/src/lib/libnetworking/net/if_ethersubr.c (added) * c/src/lib/libnetworking/net/if_llc.h (added) * c/src/lib/libnetworking/net/if_loop.c (added) * c/src/lib/libnetworking/net/if_types.h (added) * c/src/lib/libnetworking/net/netisr.h (added) * c/src/lib/libnetworking/net/radix.c (added) * c/src/lib/libnetworking/net/radix.h (added) * c/src/lib/libnetworking/net/raw_cb.c (added) * c/src/lib/libnetworking/net/raw_cb.h (added) * c/src/lib/libnetworking/net/raw_usrreq.c (added) * c/src/lib/libnetworking/net/route.c (added) * c/src/lib/libnetworking/net/route.h (added) * c/src/lib/libnetworking/net/rtsock.c (added) * c/src/lib/libnetworking/netdb.h (added) * c/src/lib/libnetworking/netinet/icmp_var.h (added) * c/src/lib/libnetworking/netinet/if_ether.c (added) * c/src/lib/libnetworking/netinet/if_ether.h (added) * c/src/lib/libnetworking/netinet/igmp.c (added) * c/src/lib/libnetworking/netinet/igmp.h (added) * c/src/lib/libnetworking/netinet/igmp_var.h (added) * c/src/lib/libnetworking/netinet/in.c (added) * c/src/lib/libnetworking/netinet/in.h (added) * c/src/lib/libnetworking/netinet/in_cksum.c (added) * c/src/lib/libnetworking/netinet/in_pcb.c (added) * c/src/lib/libnetworking/netinet/in_pcb.h (added) * c/src/lib/libnetworking/netinet/in_proto.c (added) * c/src/lib/libnetworking/netinet/in_rmx.c (added) * c/src/lib/libnetworking/netinet/in_systm.h (added) * c/src/lib/libnetworking/netinet/in_var.h (added) * c/src/lib/libnetworking/netinet/ip.h (added) * c/src/lib/libnetworking/netinet/ip_divert.c (added) * c/src/lib/libnetworking/netinet/ip_fw.c (added) * c/src/lib/libnetworking/netinet/ip_fw.h (added) * c/src/lib/libnetworking/netinet/ip_icmp.c (added) * c/src/lib/libnetworking/netinet/ip_icmp.h (added) * c/src/lib/libnetworking/netinet/ip_input.c (added) * c/src/lib/libnetworking/netinet/ip_mroute.c (added) * c/src/lib/libnetworking/netinet/ip_mroute.h (added) * c/src/lib/libnetworking/netinet/ip_output.c (added) * c/src/lib/libnetworking/netinet/ip_var.h (added) * c/src/lib/libnetworking/netinet/raw_ip.c (added) * c/src/lib/libnetworking/netinet/tcp.h (added) * c/src/lib/libnetworking/netinet/tcp_debug.c (added) * c/src/lib/libnetworking/netinet/tcp_debug.h (added) * c/src/lib/libnetworking/netinet/tcp_fsm.h (added) * c/src/lib/libnetworking/netinet/tcp_input.c (added) * c/src/lib/libnetworking/netinet/tcp_output.c (added) * c/src/lib/libnetworking/netinet/tcp_seq.h (added) * c/src/lib/libnetworking/netinet/tcp_subr.c (added) * c/src/lib/libnetworking/netinet/tcp_timer.c (added) * c/src/lib/libnetworking/netinet/tcp_timer.h (added) * c/src/lib/libnetworking/netinet/tcp_usrreq.c (added) * c/src/lib/libnetworking/netinet/tcp_var.h (added) * c/src/lib/libnetworking/netinet/tcpip.h (added) * c/src/lib/libnetworking/netinet/udp.h (added) * c/src/lib/libnetworking/netinet/udp_usrreq.c (added) * c/src/lib/libnetworking/netinet/udp_var.h (added) * c/src/lib/libnetworking/nfs/bootp_subr.c (added) * c/src/lib/libnetworking/nfs/krpc.h (added) * c/src/lib/libnetworking/nfs/nfs.h (added) * c/src/lib/libnetworking/nfs/nfsdiskless.h (added) * c/src/lib/libnetworking/nfs/nfsproto.h (added) * c/src/lib/libnetworking/nfs/rpcv2.h (added) * c/src/lib/libnetworking/nfs/xdr_subs.h (added) * c/src/lib/libnetworking/opt_ipfw.h (added) * c/src/lib/libnetworking/opt_mrouting.h (added) * c/src/lib/libnetworking/opt_tcpdebug.h (added) * c/src/lib/libnetworking/poll.h (added) * c/src/lib/libnetworking/resolv.h (added) * c/src/lib/libnetworking/rtems/issetugid.c (added) * c/src/lib/libnetworking/rtems/rtems_bootp.c (added) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (added) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (added) * c/src/lib/libnetworking/rtems/rtems_glue.c (added) * c/src/lib/libnetworking/rtems/rtems_showicmpstat.c (added) * c/src/lib/libnetworking/rtems/rtems_showifstat.c (added) * c/src/lib/libnetworking/rtems/rtems_showipstat.c (added) * c/src/lib/libnetworking/rtems/rtems_showmbuf.c (added) * c/src/lib/libnetworking/rtems/rtems_showroute.c (added) * c/src/lib/libnetworking/rtems/rtems_showtcpstat.c (added) * c/src/lib/libnetworking/rtems/rtems_showudpstat.c (added) * c/src/lib/libnetworking/rtems/rtems_syscall.c (added) * c/src/lib/libnetworking/rtems/sghostname.c (added) * c/src/lib/libnetworking/rtems/tftp.h (added) * c/src/lib/libnetworking/sys/buf.h (added) * c/src/lib/libnetworking/sys/callout.h (added) * c/src/lib/libnetworking/sys/cdefs.h (added) * c/src/lib/libnetworking/sys/conf.h (added) * c/src/lib/libnetworking/sys/domain.h (added) * c/src/lib/libnetworking/sys/filio.h (added) * c/src/lib/libnetworking/sys/ioccom.h (added) * c/src/lib/libnetworking/sys/ioctl.h (added) * c/src/lib/libnetworking/sys/kernel.h (added) * c/src/lib/libnetworking/sys/libkern.h (added) * c/src/lib/libnetworking/sys/malloc.h (added) * c/src/lib/libnetworking/sys/mbuf.h (added) * c/src/lib/libnetworking/sys/mount.h (added) * c/src/lib/libnetworking/sys/param.h (added) * c/src/lib/libnetworking/sys/proc.h (added) * c/src/lib/libnetworking/sys/protosw.h (added) * c/src/lib/libnetworking/sys/queue.h (added) * c/src/lib/libnetworking/sys/reboot.h (added) * c/src/lib/libnetworking/sys/resourcevar.h (added) * c/src/lib/libnetworking/sys/rtprio.h (added) * c/src/lib/libnetworking/sys/select.h (added) * c/src/lib/libnetworking/sys/signalvar.h (added) * c/src/lib/libnetworking/sys/socket.h (added) * c/src/lib/libnetworking/sys/socketvar.h (added) * c/src/lib/libnetworking/sys/sockio.h (added) * c/src/lib/libnetworking/sys/sysctl.h (added) * c/src/lib/libnetworking/sys/syslimits.h (added) * c/src/lib/libnetworking/sys/syslog.h (added) * c/src/lib/libnetworking/sys/systm.h (added) * c/src/lib/libnetworking/sys/ttycom.h (added) * c/src/lib/libnetworking/sys/ttydefaults.h (added) * c/src/lib/libnetworking/sys/ucred.h (added) * c/src/lib/libnetworking/sys/uio.h (added) * c/src/lib/libnetworking/syslog.h (added) * c/src/lib/libnetworking/vm/vm.h (added) * c/src/lib/libnetworking/vm/vm_extern.h (added) * c/src/lib/libnetworking/vm/vm_kern.h (added) * c/src/lib/libnetworking/vm/vm_param.h (added) * c/src/libnetworking/CHANGELOG (added) * c/src/libnetworking/README (added) * c/src/libnetworking/arpa/ftp.h (added) * c/src/libnetworking/arpa/inet.h (added) * c/src/libnetworking/arpa/nameser.h (added) * c/src/libnetworking/arpa/nameser_compat.h (added) * c/src/libnetworking/arpa/telnet.h (added) * c/src/libnetworking/bpfilter.h (added) * c/src/libnetworking/kern/kern_subr.c (added) * c/src/libnetworking/kern/uipc_domain.c (added) * c/src/libnetworking/kern/uipc_mbuf.c (added) * c/src/libnetworking/kern/uipc_socket.c (added) * c/src/libnetworking/kern/uipc_socket2.c (added) * c/src/libnetworking/lib/README (added) * c/src/libnetworking/lib/getprotoby.c (added) * c/src/libnetworking/lib/syslog.c (added) * c/src/libnetworking/lib/tftpDriver.c (added) * c/src/libnetworking/libc/addr2ascii.3 (added) * c/src/libnetworking/libc/addr2ascii.c (added) * c/src/libnetworking/libc/ascii2addr.c (added) * c/src/libnetworking/libc/base64.c (added) * c/src/libnetworking/libc/byteorder.3 (added) * c/src/libnetworking/libc/ether_addr.c (added) * c/src/libnetworking/libc/ethers.3 (added) * c/src/libnetworking/libc/gethostbydns.c (added) * c/src/libnetworking/libc/gethostbyht.c (added) * c/src/libnetworking/libc/gethostbyname.3 (added) * c/src/libnetworking/libc/gethostbynis.c (added) * c/src/libnetworking/libc/gethostnamadr.c (added) * c/src/libnetworking/libc/gethostname.c (added) * c/src/libnetworking/libc/getnetbydns.c (added) * c/src/libnetworking/libc/getnetbyht.c (added) * c/src/libnetworking/libc/getnetbynis.c (added) * c/src/libnetworking/libc/getnetent.3 (added) * c/src/libnetworking/libc/getnetnamadr.c (added) * c/src/libnetworking/libc/getproto.c (added) * c/src/libnetworking/libc/getprotoent.3 (added) * c/src/libnetworking/libc/getprotoent.c (added) * c/src/libnetworking/libc/getprotoname.c (added) * c/src/libnetworking/libc/getservbyname.c (added) * c/src/libnetworking/libc/getservbyport.c (added) * c/src/libnetworking/libc/getservent.3 (added) * c/src/libnetworking/libc/getservent.c (added) * c/src/libnetworking/libc/herror.c (added) * c/src/libnetworking/libc/inet.3 (added) * c/src/libnetworking/libc/inet_addr.c (added) * c/src/libnetworking/libc/inet_lnaof.c (added) * c/src/libnetworking/libc/inet_makeaddr.c (added) * c/src/libnetworking/libc/inet_net_ntop.c (added) * c/src/libnetworking/libc/inet_net_pton.c (added) * c/src/libnetworking/libc/inet_neta.c (added) * c/src/libnetworking/libc/inet_netof.c (added) * c/src/libnetworking/libc/inet_network.c (added) * c/src/libnetworking/libc/inet_ntoa.c (added) * c/src/libnetworking/libc/inet_ntop.c (added) * c/src/libnetworking/libc/inet_pton.c (added) * c/src/libnetworking/libc/iso_addr.3 (added) * c/src/libnetworking/libc/iso_addr.c (added) * c/src/libnetworking/libc/linkaddr.3 (added) * c/src/libnetworking/libc/linkaddr.c (added) * c/src/libnetworking/libc/map_v4v6.c (added) * c/src/libnetworking/libc/ns.3 (added) * c/src/libnetworking/libc/ns_addr.c (added) * c/src/libnetworking/libc/ns_name.c (added) * c/src/libnetworking/libc/ns_netint.c (added) * c/src/libnetworking/libc/ns_ntoa.c (added) * c/src/libnetworking/libc/ns_parse.c (added) * c/src/libnetworking/libc/ns_print.c (added) * c/src/libnetworking/libc/ns_ttl.c (added) * c/src/libnetworking/libc/nsap_addr.c (added) * c/src/libnetworking/libc/rcmd.3 (added) * c/src/libnetworking/libc/rcmd.c (added) * c/src/libnetworking/libc/recv.c (added) * c/src/libnetworking/libc/res_comp.c (added) * c/src/libnetworking/libc/res_config.h (added) * c/src/libnetworking/libc/res_data.c (added) * c/src/libnetworking/libc/res_debug.c (added) * c/src/libnetworking/libc/res_init.c (added) * c/src/libnetworking/libc/res_mkquery.c (added) * c/src/libnetworking/libc/res_mkupdate.c (added) * c/src/libnetworking/libc/res_query.c (added) * c/src/libnetworking/libc/res_send.c (added) * c/src/libnetworking/libc/res_stubs.c (added) * c/src/libnetworking/libc/res_update.c (added) * c/src/libnetworking/libc/resolver.3 (added) * c/src/libnetworking/libc/send.c (added) * c/src/libnetworking/libc/strsep.c (added) * c/src/libnetworking/loop.h (added) * c/src/libnetworking/net/bpf.h (added) * c/src/libnetworking/net/ethernet.h (added) * c/src/libnetworking/net/if.c (added) * c/src/libnetworking/net/if.h (added) * c/src/libnetworking/net/if_arp.h (added) * c/src/libnetworking/net/if_dl.h (added) * c/src/libnetworking/net/if_ethersubr.c (added) * c/src/libnetworking/net/if_llc.h (added) * c/src/libnetworking/net/if_loop.c (added) * c/src/libnetworking/net/if_types.h (added) * c/src/libnetworking/net/netisr.h (added) * c/src/libnetworking/net/radix.c (added) * c/src/libnetworking/net/radix.h (added) * c/src/libnetworking/net/raw_cb.c (added) * c/src/libnetworking/net/raw_cb.h (added) * c/src/libnetworking/net/raw_usrreq.c (added) * c/src/libnetworking/net/route.c (added) * c/src/libnetworking/net/route.h (added) * c/src/libnetworking/net/rtsock.c (added) * c/src/libnetworking/netdb.h (added) * c/src/libnetworking/netinet/icmp_var.h (added) * c/src/libnetworking/netinet/if_ether.c (added) * c/src/libnetworking/netinet/if_ether.h (added) * c/src/libnetworking/netinet/igmp.c (added) * c/src/libnetworking/netinet/igmp.h (added) * c/src/libnetworking/netinet/igmp_var.h (added) * c/src/libnetworking/netinet/in.c (added) * c/src/libnetworking/netinet/in.h (added) * c/src/libnetworking/netinet/in_cksum.c (added) * c/src/libnetworking/netinet/in_pcb.c (added) * c/src/libnetworking/netinet/in_pcb.h (added) * c/src/libnetworking/netinet/in_proto.c (added) * c/src/libnetworking/netinet/in_rmx.c (added) * c/src/libnetworking/netinet/in_systm.h (added) * c/src/libnetworking/netinet/in_var.h (added) * c/src/libnetworking/netinet/ip.h (added) * c/src/libnetworking/netinet/ip_divert.c (added) * c/src/libnetworking/netinet/ip_fw.c (added) * c/src/libnetworking/netinet/ip_fw.h (added) * c/src/libnetworking/netinet/ip_icmp.c (added) * c/src/libnetworking/netinet/ip_icmp.h (added) * c/src/libnetworking/netinet/ip_input.c (added) * c/src/libnetworking/netinet/ip_mroute.c (added) * c/src/libnetworking/netinet/ip_mroute.h (added) * c/src/libnetworking/netinet/ip_output.c (added) * c/src/libnetworking/netinet/ip_var.h (added) * c/src/libnetworking/netinet/raw_ip.c (added) * c/src/libnetworking/netinet/tcp.h (added) * c/src/libnetworking/netinet/tcp_debug.c (added) * c/src/libnetworking/netinet/tcp_debug.h (added) * c/src/libnetworking/netinet/tcp_fsm.h (added) * c/src/libnetworking/netinet/tcp_input.c (added) * c/src/libnetworking/netinet/tcp_output.c (added) * c/src/libnetworking/netinet/tcp_seq.h (added) * c/src/libnetworking/netinet/tcp_subr.c (added) * c/src/libnetworking/netinet/tcp_timer.c (added) * c/src/libnetworking/netinet/tcp_timer.h (added) * c/src/libnetworking/netinet/tcp_usrreq.c (added) * c/src/libnetworking/netinet/tcp_var.h (added) * c/src/libnetworking/netinet/tcpip.h (added) * c/src/libnetworking/netinet/udp.h (added) * c/src/libnetworking/netinet/udp_usrreq.c (added) * c/src/libnetworking/netinet/udp_var.h (added) * c/src/libnetworking/nfs/bootp_subr.c (added) * c/src/libnetworking/nfs/krpc.h (added) * c/src/libnetworking/nfs/nfs.h (added) * c/src/libnetworking/nfs/nfsdiskless.h (added) * c/src/libnetworking/nfs/nfsproto.h (added) * c/src/libnetworking/nfs/rpcv2.h (added) * c/src/libnetworking/nfs/xdr_subs.h (added) * c/src/libnetworking/opt_ipfw.h (added) * c/src/libnetworking/opt_mrouting.h (added) * c/src/libnetworking/opt_tcpdebug.h (added) * c/src/libnetworking/poll.h (added) * c/src/libnetworking/resolv.h (added) * c/src/libnetworking/rtems/issetugid.c (added) * c/src/libnetworking/rtems/rtems_bootp.c (added) * c/src/libnetworking/rtems/rtems_bsdnet.h (added) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (added) * c/src/libnetworking/rtems/rtems_glue.c (added) * c/src/libnetworking/rtems/rtems_showicmpstat.c (added) * c/src/libnetworking/rtems/rtems_showifstat.c (added) * c/src/libnetworking/rtems/rtems_showipstat.c (added) * c/src/libnetworking/rtems/rtems_showmbuf.c (added) * c/src/libnetworking/rtems/rtems_showroute.c (added) * c/src/libnetworking/rtems/rtems_showtcpstat.c (added) * c/src/libnetworking/rtems/rtems_showudpstat.c (added) * c/src/libnetworking/rtems/rtems_syscall.c (added) * c/src/libnetworking/rtems/sghostname.c (added) * c/src/libnetworking/rtems/tftp.h (added) * c/src/libnetworking/sys/buf.h (added) * c/src/libnetworking/sys/callout.h (added) * c/src/libnetworking/sys/cdefs.h (added) * c/src/libnetworking/sys/conf.h (added) * c/src/libnetworking/sys/domain.h (added) * c/src/libnetworking/sys/filio.h (added) * c/src/libnetworking/sys/ioccom.h (added) * c/src/libnetworking/sys/ioctl.h (added) * c/src/libnetworking/sys/kernel.h (added) * c/src/libnetworking/sys/libkern.h (added) * c/src/libnetworking/sys/malloc.h (added) * c/src/libnetworking/sys/mbuf.h (added) * c/src/libnetworking/sys/mount.h (added) * c/src/libnetworking/sys/param.h (added) * c/src/libnetworking/sys/proc.h (added) * c/src/libnetworking/sys/protosw.h (added) * c/src/libnetworking/sys/queue.h (added) * c/src/libnetworking/sys/reboot.h (added) * c/src/libnetworking/sys/resourcevar.h (added) * c/src/libnetworking/sys/rtprio.h (added) * c/src/libnetworking/sys/select.h (added) * c/src/libnetworking/sys/signalvar.h (added) * c/src/libnetworking/sys/socket.h (added) * c/src/libnetworking/sys/socketvar.h (added) * c/src/libnetworking/sys/sockio.h (added) * c/src/libnetworking/sys/sysctl.h (added) * c/src/libnetworking/sys/syslimits.h (added) * c/src/libnetworking/sys/syslog.h (added) * c/src/libnetworking/sys/systm.h (added) * c/src/libnetworking/sys/ttycom.h (added) * c/src/libnetworking/sys/ttydefaults.h (added) * c/src/libnetworking/sys/ucred.h (added) * c/src/libnetworking/sys/uio.h (added) * c/src/libnetworking/syslog.h (added) * c/src/libnetworking/vm/vm.h (added) * c/src/libnetworking/vm/vm_extern.h (added) * c/src/libnetworking/vm/vm_kern.h (added) * c/src/libnetworking/vm/vm_param.h (added) * cpukit/libcsupport/include/sys/filio.h (added) * cpukit/libcsupport/include/sys/ioctl.h (added) * cpukit/libcsupport/include/sys/sockio.h (added) * cpukit/libnetworking/README (added) * cpukit/libnetworking/arpa/ftp.h (added) * cpukit/libnetworking/arpa/inet.h (added) * cpukit/libnetworking/arpa/nameser.h (added) * cpukit/libnetworking/arpa/nameser_compat.h (added) * cpukit/libnetworking/arpa/telnet.h (added) * cpukit/libnetworking/bpfilter.h (added) * cpukit/libnetworking/kern/kern_subr.c (added) * cpukit/libnetworking/kern/uipc_domain.c (added) * cpukit/libnetworking/kern/uipc_mbuf.c (added) * cpukit/libnetworking/kern/uipc_socket.c (added) * cpukit/libnetworking/kern/uipc_socket2.c (added) * cpukit/libnetworking/lib/README (added) * cpukit/libnetworking/lib/getprotoby.c (added) * cpukit/libnetworking/lib/syslog.c (added) * cpukit/libnetworking/lib/tftpDriver.c (added) * cpukit/libnetworking/libc/addr2ascii.3 (added) * cpukit/libnetworking/libc/addr2ascii.c (added) * cpukit/libnetworking/libc/ascii2addr.c (added) * cpukit/libnetworking/libc/base64.c (added) * cpukit/libnetworking/libc/byteorder.3 (added) * cpukit/libnetworking/libc/ether_addr.c (added) * cpukit/libnetworking/libc/ethers.3 (added) * cpukit/libnetworking/libc/gethostbydns.c (added) * cpukit/libnetworking/libc/gethostbyht.c (added) * cpukit/libnetworking/libc/gethostbyname.3 (added) * cpukit/libnetworking/libc/gethostbynis.c (added) * cpukit/libnetworking/libc/gethostnamadr.c (added) * cpukit/libnetworking/libc/gethostname.c (added) * cpukit/libnetworking/libc/getnetbydns.c (added) * cpukit/libnetworking/libc/getnetbyht.c (added) * cpukit/libnetworking/libc/getnetbynis.c (added) * cpukit/libnetworking/libc/getnetent.3 (added) * cpukit/libnetworking/libc/getnetnamadr.c (added) * cpukit/libnetworking/libc/getproto.c (added) * cpukit/libnetworking/libc/getprotoent.3 (added) * cpukit/libnetworking/libc/getprotoent.c (added) * cpukit/libnetworking/libc/getprotoname.c (added) * cpukit/libnetworking/libc/getservbyname.c (added) * cpukit/libnetworking/libc/getservbyport.c (added) * cpukit/libnetworking/libc/getservent.3 (added) * cpukit/libnetworking/libc/getservent.c (added) * cpukit/libnetworking/libc/herror.c (added) * cpukit/libnetworking/libc/inet.3 (added) * cpukit/libnetworking/libc/inet_addr.c (added) * cpukit/libnetworking/libc/inet_lnaof.c (added) * cpukit/libnetworking/libc/inet_makeaddr.c (added) * cpukit/libnetworking/libc/inet_net_ntop.c (added) * cpukit/libnetworking/libc/inet_net_pton.c (added) * cpukit/libnetworking/libc/inet_neta.c (added) * cpukit/libnetworking/libc/inet_netof.c (added) * cpukit/libnetworking/libc/inet_network.c (added) * cpukit/libnetworking/libc/inet_ntoa.c (added) * cpukit/libnetworking/libc/inet_ntop.c (added) * cpukit/libnetworking/libc/inet_pton.c (added) * cpukit/libnetworking/libc/iso_addr.3 (added) * cpukit/libnetworking/libc/iso_addr.c (added) * cpukit/libnetworking/libc/linkaddr.3 (added) * cpukit/libnetworking/libc/linkaddr.c (added) * cpukit/libnetworking/libc/map_v4v6.c (added) * cpukit/libnetworking/libc/ns.3 (added) * cpukit/libnetworking/libc/ns_addr.c (added) * cpukit/libnetworking/libc/ns_name.c (added) * cpukit/libnetworking/libc/ns_netint.c (added) * cpukit/libnetworking/libc/ns_ntoa.c (added) * cpukit/libnetworking/libc/ns_parse.c (added) * cpukit/libnetworking/libc/ns_print.c (added) * cpukit/libnetworking/libc/ns_ttl.c (added) * cpukit/libnetworking/libc/nsap_addr.c (added) * cpukit/libnetworking/libc/rcmd.3 (added) * cpukit/libnetworking/libc/rcmd.c (added) * cpukit/libnetworking/libc/recv.c (added) * cpukit/libnetworking/libc/res_comp.c (added) * cpukit/libnetworking/libc/res_config.h (added) * cpukit/libnetworking/libc/res_data.c (added) * cpukit/libnetworking/libc/res_debug.c (added) * cpukit/libnetworking/libc/res_init.c (added) * cpukit/libnetworking/libc/res_mkquery.c (added) * cpukit/libnetworking/libc/res_mkupdate.c (added) * cpukit/libnetworking/libc/res_query.c (added) * cpukit/libnetworking/libc/res_send.c (added) * cpukit/libnetworking/libc/res_stubs.c (added) * cpukit/libnetworking/libc/res_update.c (added) * cpukit/libnetworking/libc/resolver.3 (added) * cpukit/libnetworking/libc/send.c (added) * cpukit/libnetworking/libc/strsep.c (added) * cpukit/libnetworking/loop.h (added) * cpukit/libnetworking/net/bpf.h (added) * cpukit/libnetworking/net/ethernet.h (added) * cpukit/libnetworking/net/if.c (added) * cpukit/libnetworking/net/if.h (added) * cpukit/libnetworking/net/if_arp.h (added) * cpukit/libnetworking/net/if_dl.h (added) * cpukit/libnetworking/net/if_ethersubr.c (added) * cpukit/libnetworking/net/if_llc.h (added) * cpukit/libnetworking/net/if_loop.c (added) * cpukit/libnetworking/net/if_types.h (added) * cpukit/libnetworking/net/netisr.h (added) * cpukit/libnetworking/net/radix.c (added) * cpukit/libnetworking/net/radix.h (added) * cpukit/libnetworking/net/raw_cb.c (added) * cpukit/libnetworking/net/raw_cb.h (added) * cpukit/libnetworking/net/raw_usrreq.c (added) * cpukit/libnetworking/net/route.c (added) * cpukit/libnetworking/net/route.h (added) * cpukit/libnetworking/net/rtsock.c (added) * cpukit/libnetworking/netdb.h (added) * cpukit/libnetworking/netinet/icmp_var.h (added) * cpukit/libnetworking/netinet/if_ether.c (added) * cpukit/libnetworking/netinet/if_ether.h (added) * cpukit/libnetworking/netinet/igmp.c (added) * cpukit/libnetworking/netinet/igmp.h (added) * cpukit/libnetworking/netinet/igmp_var.h (added) * cpukit/libnetworking/netinet/in.c (added) * cpukit/libnetworking/netinet/in.h (added) * cpukit/libnetworking/netinet/in_cksum.c (added) * cpukit/libnetworking/netinet/in_pcb.c (added) * cpukit/libnetworking/netinet/in_pcb.h (added) * cpukit/libnetworking/netinet/in_proto.c (added) * cpukit/libnetworking/netinet/in_rmx.c (added) * cpukit/libnetworking/netinet/in_systm.h (added) * cpukit/libnetworking/netinet/in_var.h (added) * cpukit/libnetworking/netinet/ip.h (added) * cpukit/libnetworking/netinet/ip_divert.c (added) * cpukit/libnetworking/netinet/ip_fw.c (added) * cpukit/libnetworking/netinet/ip_fw.h (added) * cpukit/libnetworking/netinet/ip_icmp.c (added) * cpukit/libnetworking/netinet/ip_icmp.h (added) * cpukit/libnetworking/netinet/ip_input.c (added) * cpukit/libnetworking/netinet/ip_mroute.c (added) * cpukit/libnetworking/netinet/ip_mroute.h (added) * cpukit/libnetworking/netinet/ip_output.c (added) * cpukit/libnetworking/netinet/ip_var.h (added) * cpukit/libnetworking/netinet/raw_ip.c (added) * cpukit/libnetworking/netinet/tcp.h (added) * cpukit/libnetworking/netinet/tcp_debug.c (added) * cpukit/libnetworking/netinet/tcp_debug.h (added) * cpukit/libnetworking/netinet/tcp_fsm.h (added) * cpukit/libnetworking/netinet/tcp_input.c (added) * cpukit/libnetworking/netinet/tcp_output.c (added) * cpukit/libnetworking/netinet/tcp_seq.h (added) * cpukit/libnetworking/netinet/tcp_subr.c (added) * cpukit/libnetworking/netinet/tcp_timer.c (added) * cpukit/libnetworking/netinet/tcp_timer.h (added) * cpukit/libnetworking/netinet/tcp_usrreq.c (added) * cpukit/libnetworking/netinet/tcp_var.h (added) * cpukit/libnetworking/netinet/tcpip.h (added) * cpukit/libnetworking/netinet/udp.h (added) * cpukit/libnetworking/netinet/udp_usrreq.c (added) * cpukit/libnetworking/netinet/udp_var.h (added) * cpukit/libnetworking/nfs/bootp_subr.c (added) * cpukit/libnetworking/nfs/krpc.h (added) * cpukit/libnetworking/nfs/nfs.h (added) * cpukit/libnetworking/nfs/nfsdiskless.h (added) * cpukit/libnetworking/nfs/nfsproto.h (added) * cpukit/libnetworking/nfs/rpcv2.h (added) * cpukit/libnetworking/nfs/xdr_subs.h (added) * cpukit/libnetworking/opt_ipfw.h (added) * cpukit/libnetworking/opt_mrouting.h (added) * cpukit/libnetworking/opt_tcpdebug.h (added) * cpukit/libnetworking/poll.h (added) * cpukit/libnetworking/resolv.h (added) * cpukit/libnetworking/rtems/issetugid.c (added) * cpukit/libnetworking/rtems/rtems_bootp.c (added) * cpukit/libnetworking/rtems/rtems_bsdnet.h (added) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (added) * cpukit/libnetworking/rtems/rtems_glue.c (added) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (added) * cpukit/libnetworking/rtems/rtems_showifstat.c (added) * cpukit/libnetworking/rtems/rtems_showipstat.c (added) * cpukit/libnetworking/rtems/rtems_showmbuf.c (added) * cpukit/libnetworking/rtems/rtems_showroute.c (added) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (added) * cpukit/libnetworking/rtems/rtems_showudpstat.c (added) * cpukit/libnetworking/rtems/rtems_syscall.c (added) * cpukit/libnetworking/rtems/sghostname.c (added) * cpukit/libnetworking/rtems/tftp.h (added) * cpukit/libnetworking/sys/buf.h (added) * cpukit/libnetworking/sys/callout.h (added) * cpukit/libnetworking/sys/conf.h (added) * cpukit/libnetworking/sys/domain.h (added) * cpukit/libnetworking/sys/kernel.h (added) * cpukit/libnetworking/sys/libkern.h (added) * cpukit/libnetworking/sys/malloc.h (added) * cpukit/libnetworking/sys/mbuf.h (added) * cpukit/libnetworking/sys/mount.h (added) * cpukit/libnetworking/sys/param.h (added) * cpukit/libnetworking/sys/proc.h (added) * cpukit/libnetworking/sys/protosw.h (added) * cpukit/libnetworking/sys/queue.h (added) * cpukit/libnetworking/sys/reboot.h (added) * cpukit/libnetworking/sys/resourcevar.h (added) * cpukit/libnetworking/sys/rtprio.h (added) * cpukit/libnetworking/sys/select.h (added) * cpukit/libnetworking/sys/signalvar.h (added) * cpukit/libnetworking/sys/socket.h (added) * cpukit/libnetworking/sys/socketvar.h (added) * cpukit/libnetworking/sys/sysctl.h (added) * cpukit/libnetworking/sys/syslimits.h (added) * cpukit/libnetworking/sys/syslog.h (added) * cpukit/libnetworking/sys/systm.h (added) * cpukit/libnetworking/sys/ttydefaults.h (added) * cpukit/libnetworking/sys/ucred.h (added) * cpukit/libnetworking/sys/uio.h (added) * cpukit/libnetworking/syslog.h (added) * cpukit/libnetworking/vm/vm.h (added) * cpukit/libnetworking/vm/vm_extern.h (added) * cpukit/libnetworking/vm/vm_kern.h (added) * cpukit/libnetworking/vm/vm_param.h (added) Base files
