@db97feb5
09/23/13 13:22:02 |
Joel Sherrill |
internal.h/main_mdump.c: Convert main methods to static
4.115
@2cdace7
09/21/13 20:45:51 |
Joel Sherrill |
main_mv.c: Address set but not used warning
It looks like the paths …
4.115
@7071eb3
09/21/13 20:41:50 |
Joel Sherrill |
mouse_parser.c: Fix warning by properly checking return code
4.115
@36fdd0b
09/05/13 18:50:46 |
Gedare Bloom |
uuid: make integer arithmetic conversion explicit
Upcast …
4.115
@e075b388
09/05/13 18:10:52 |
Gedare Bloom |
untar: check return value from mkdir
Check the return value from …
4.115
@96654dc
09/05/13 16:15:27 |
Gedare Bloom |
shell: Out-of-bounds access
In case the length of cwd path plus the …
4.115
@df533f1
08/25/13 23:49:21 |
cynthia |
Stop a resource leak
Stops a resource leak in the event that the …
4.115
@ae75429
08/06/13 14:10:26 |
Sebastian Huber |
PR766: Delete RTEMS_VIOLATE_KERNEL_VISIBILITY
4.115
@ffa2defc
08/06/13 08:58:58 |
rdiezmail-rtems |
Fix compiler warnings
4.115
@f031df0e
07/31/13 11:42:07 |
Sebastian Huber |
score: Rename tod.h to todimpl.h
4.115
@fe52e7c0
07/26/13 12:10:25 |
Sebastian Huber |
smp: Add and use _Per_CPU_Get()
Add and use _Per_CPU_Get_by_index() …
4.115
@ff63d2d
07/26/13 12:04:22 |
Sebastian Huber |
smp: Use Thread_Control.is_executing
FIXME: This area needs proper …
4.115
@91404de
07/26/13 07:34:32 |
Sebastian Huber |
libmisc: Provide libutf8proc conditionally
4.115
@88c74ab
07/25/13 13:10:11 |
Sebastian Huber |
score: Merge tod implementation into one file
Delete …
4.115
@a2e3f33
07/24/13 11:50:54 |
Sebastian Huber |
score: Create object implementation header
Move implementation …
4.115
@fe6c170c
07/24/13 14:19:52 |
Sebastian Huber |
score: Create states implementation header
4.115
@39046f7
07/24/13 09:09:23 |
Sebastian Huber |
score: Merge sysstate API into one file
4.115
@1cb75cc
07/23/13 13:32:50 |
Sebastian Huber |
score: Merge wkspace API into one file
4.115
@c404828
07/23/13 12:56:00 |
Sebastian Huber |
rtems: Create tasks implementation header
4.115
@f6c7c57d
07/23/13 12:38:19 |
Sebastian Huber |
rtems: Create region implementation header
4.115
@8695cae
07/23/13 12:19:58 |
Sebastian Huber |
rtems: Create part implementation header
Move implementation specific …
4.115
@7660e8b3
07/23/13 11:32:58 |
Sebastian Huber |
Include missing <string.h>
4.115
@e151eb1
07/23/13 10:47:35 |
Sebastian Huber |
rtems: Create event implementation header
4.115
@63d229d6
07/23/13 09:12:52 |
Sebastian Huber |
rtems: Create attr implementation header
4.115
@ac252bdc
07/23/13 08:04:19 |
Sebastian Huber |
sapi: Create extension implementation header
4.115
@4b48ece0
07/22/13 08:21:03 |
Sebastian Huber |
score: Create watchdog implementation header
4.115
@0c5317d
07/19/13 12:33:56 |
Sebastian Huber |
posix: Create pthread implementation header
4.115
@a9515722
07/19/13 09:18:51 |
Sebastian Huber |
cpuuse: Add SMP support
4.115
@993a888
07/18/13 13:05:37 |
Sebastian Huber |
rtems: Create message queue implementation header
4.115
@1a30d442
07/22/13 07:18:17 |
Sebastian Huber |
libmisc: Use _Thread_Get_executing()
4.115
@f2d9fda
07/18/13 13:33:44 |
Sebastian Huber |
shell: Include missing header file
4.115
@2bbea657
07/17/13 11:52:00 |
Sebastian Huber |
rtems: Create semaphore implementation header
4.115
@ad83ea0
07/07/13 12:43:17 |
Sebastian Huber |
mouse: Add shared bsp_get_serial_mouse_device()
4.115
@a4006fee
06/28/13 19:25:30 |
Sebastian Huber |
mouse: Include missing header file
4.115
@edde99b
06/14/13 12:26:34 |
Sebastian Huber |
score: Rename rtems_smp_get_number_of_processors()
Rename in …
4.115
@46b7f921
02/26/13 11:00:34 |
ralf.kirchner |
libmisc: Add utf8proc-v1.1.5
utf8proc is a small library for …
4.115
@7bb71c7
05/16/13 09:24:09 |
Andrey Mozzhuhin |
shell: Add df command
4.115
@d2d09eac
05/15/13 13:14:28 |
Andreas Heinig |
shell: Fix NULL pointer access
4.115
@7571a23
01/27/13 14:10:39 |
Sebastian Huber |
sapi: PR1911: Add CONFIGURE_DISABLE_BSP_SETTINGS
4.115
@e858f70
01/10/13 23:06:06 |
Joel Sherrill |
cpukit: Fix many Doxygen warnings
4.115
@b697bc6
01/10/13 21:06:42 |
Joel Sherrill |
cpukit: Use Consistent Beginning of Doxygen Group Notation
This is …
4.115
@a15eaaf
01/10/13 19:20:34 |
Joel Sherrill |
cpukit: Doxygen group fixes and many warnings addressed
The output of …
4.115
@a163882
01/04/13 19:09:14 |
kolaveridi87 |
libmisc: Doxygen Clean Up Task #1
Conflicts occured durning this patch …
4.115
@3cf4031
12/28/12 23:48:12 |
alexivanov97 |
Header File Doxygen Enhancement Task #1
4.115
@f3255a6
12/28/12 17:30:27 |
matkallada |
Header File Doxygen Enhancement Task #11
4.115
@c5782a2
12/28/12 17:16:29 |
matkallada |
Header File Doxygen Enhancement Task #7
4.115
@9ab091e
12/28/12 16:35:32 |
matkallada |
Header File Doxygen Enhancement Task #2
4.115
@f11858ac
12/28/12 16:34:13 |
Joel Sherrill |
libmisc/mouse: Doxygen Group Clean Up
4.115
@b8fc260f
12/28/12 15:48:37 |
Joel Sherrill |
Miscellaneous Doxygen clean-up
4.115
@f5f2676
12/21/12 17:13:06 |
matkallada |
libmisc: Doxygen Enhancement Task #1
4.115
@148e3de6
12/19/12 14:51:38 |
matkallada |
libmisc: Doxygen Enhancement Task #2
4.115
@ea4f072
12/14/12 09:23:30 |
Sebastian Huber |
shell: Remove interface down warning in ifconfig
Whether an interface …
4.115
@a0bc1dc
12/05/12 12:58:19 |
ralf.kirchner |
dosfs: Delete fattype parameter for msdos_format()
Delete fattype …
4.115
@5b8d935a
12/05/12 13:11:26 |
ralf.kirchner |
dosfs: Add skip_alignment for msdos_format()
Add skip_alignment …
4.115
@22e98377
11/30/12 23:52:51 |
Ric Claus |
Support additional shell keystrokes.
Emacs style keystrokes Ctrl-B, …
4.115
@8219438
11/30/12 23:50:40 |
Ric Claus |
Updated mount usage line.
The mount usage line didn't mention the '-o …
4.115
@fcfef0e
11/30/12 23:49:57 |
Ric Claus |
Updated mkdos options string.
The usage statement for the mkdos …
4.115
@f12e021c
11/29/12 13:12:01 |
ralf.kirchner |
Filesystem: Documentation
4.115
@5adf02e5
11/20/12 09:37:16 |
Sebastian Huber |
monitor: Typo
4.115
@a12f7e9
11/14/12 14:10:46 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_STACK_CHECKER
4.115
@ed8be1ae
11/06/12 12:46:03 |
Sebastian Huber |
monitor: Add const qualifier
4.115
@682b819
11/06/12 12:43:32 |
Sebastian Huber |
monitor: Avoid unused function
4.115
@5e86086
11/06/12 09:34:42 |
Sebastian Huber |
sapi: Use rtems_config*_get_microseconds_per_tick
4.115
@7a1e92a1
11/02/12 10:43:34 |
Sebastian Huber |
monitor: Support for system events
4.115
@990575c
10/30/12 15:18:36 |
Sebastian Huber |
rtems: Reusable event implementation
Change event implementation to …
4.115
@47a3cd8
08/09/12 14:48:00 |
Sebastian Huber |
score: Work area initialization API change
The work areas (RTEMS work …
4.115
@b1c4e92
10/19/12 08:05:48 |
Ralf Corsepius |
Make uid_buttons static.
Reorder include-files.
Remove stray blanks.
4.115
@d3c86023
09/05/12 17:25:38 |
Joel Sherrill |
shell/dd-misc.c: Rename unused to avoid conflict with new <sys/cdefs.h>
4.115
@1c554014
07/19/12 14:14:53 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@9f527308
06/12/12 07:46:09 |
Sebastian Huber |
libblock: Add block device statistics
4.115
@721fe34
05/31/12 20:34:36 |
Joel Sherrill |
Fix C files which had two semi-colons at EOL
4.115
@4acbff6
05/23/12 09:39:05 |
Sebastian Huber |
shell/lsof: Use fprintf() instead of printk()
4.115
@65c6425
05/03/12 17:24:46 |
Joel Sherrill |
Remove CVS Id Strings (manual edits after script)
These modifications …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@4648ade
02/17/12 21:29:58 |
Ric Claus |
PR 2021 - mdump address problem with volatile
4.115
@c649976
02/28/12 12:28:42 |
Sebastian Huber |
libblock: New block IO control support functions
4.115
@3b7c123
03/13/12 10:33:51 |
Sebastian Huber |
Filesystem: Reference counting for locations
o A new data structure …
4.115
@002affc
02/13/12 15:40:54 |
Sebastian Huber |
Avoid NULL pointer access
4.115
@fdcf6c11
02/03/12 22:05:50 |
Joel Sherrill |
PR 2001/shell - medit command argument parsing correction
"medit" …
4.115
@6d1a1d3
02/02/12 21:02:16 |
Joel Sherrill |
PR 2012 - mdump/wdump shell cmds handle length arg incorrectly; add …
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@13a69b9
12/06/11 15:22:13 |
Ralf Corsepius |
2011-12-06 Ralf Corsépius <ralf.corsepius@…>
4.115
@01d79ed
12/06/11 08:02:31 |
Ralf Corsepius |
4.115
@3ab21dce
12/06/11 08:00:24 |
Ralf Corsepius |
4.115
@6425dc5
12/06/11 07:34:48 |
Ralf Corsepius |
4.115
@e8f0541
12/05/11 17:31:19 |
Ralf Corsepius |
2011-12-05 Ralf Corsépius <ralf.corsepius@…>
4.115
@060092c0
12/05/11 16:53:55 |
Ralf Corsepius |
4.115
@32f5014b
12/05/11 09:46:57 |
Ralf Corsepius |
4.115
@3237e88
12/05/11 05:04:49 |
Ralf Corsepius |
4.115
@a8ed055
12/04/11 18:27:40 |
Ralf Corsepius |
2011-12-04 Ralf Corsépius <ralf.corsepius@…>
4.115
@4326cdee
12/04/11 18:25:45 |
Ralf Corsepius |
4.115
@cb2464b
12/04/11 18:22:14 |
Ralf Corsepius |
4.115
@d7417a51
12/04/11 18:20:23 |
Ralf Corsepius |
4.115
@5383441c
12/04/11 18:18:52 |
Ralf Corsepius |
4.115
@94547d1
12/04/11 11:57:51 |
Ralf Corsepius |
4.115
@3421e520
12/04/11 10:22:51 |
Ralf Corsepius |
* libmisc/shell/main_help.c: Make rtems_shell_help_cmd, …
4.115
@f1d9293e
12/04/11 09:51:48 |
Ralf Corsepius |
4.115
@9cfd222
12/04/11 09:42:29 |
Ralf Corsepius |
4.115
@26597fc1
12/04/11 09:39:44 |
Ralf Corsepius |
4.115
@3cada05b
12/04/11 08:53:25 |
Ralf Corsepius |
4.115
