@66da4844
11/18/14 09:09:30 |
Sebastian Huber |
shell: Print to stderr in TIME command
4.115
@7840b66
11/18/14 09:03:24 |
Sebastian Huber |
shell: Add initial commands and aliases only once
Make tables read-only.
4.115
@7a2c30f
11/17/14 14:58:26 |
Sebastian Huber |
shell: Simplify rtems_shell_add_cmd_struct()
4.115
@bac3d6d
11/17/14 14:42:57 |
Sebastian Huber |
shell: Rename HALT to SHUTDOWN command
Use a normal command for …
4.115
@fa028bb
11/17/14 10:55:27 |
Sebastian Huber |
shell: Do chroot() after successful login
4.115
@373ccbb9
11/17/14 13:55:38 |
Sebastian Huber |
shell: Use exiting once initialization
Avoid TOCTOU issues. Avoid …
4.115
@065d72ce
11/17/14 09:19:00 |
Sebastian Huber |
shell: Get supplementary group IDs in login check
4.115
@acf9a8d
11/14/14 13:31:54 |
Sebastian Huber |
shell: Use crypt_r() in rtems_shell_login_check()
Use '*" to disable …
4.115
@54998f6
11/04/14 22:05:44 |
Joel Sherrill |
shell/main_edit.c: Fix warnings
4.115
@4123e244
11/03/14 12:56:00 |
Jennifer Averett |
cpuuse: Resolve compile errors.
4.115
@8b11ff67
10/28/14 12:58:28 |
Jennifer Averett |
capture: Remove ctload command.
rtems_cpu_usage_top should be used …
4.115
@a7817010
09/29/14 15:21:00 |
Jennifer Averett |
libmisc: Add top to shell.
4.115
@6031da4
09/29/14 15:20:27 |
Jennifer Averett |
libmisc: Add top to cpuusage.
4.115
@05e4e599
09/04/14 18:49:04 |
Jennifer Averett |
capture: Removal of capture task tracking.
This patch removes …
4.115
@7c797a1
09/19/14 19:05:49 |
Jennifer Averett |
cpuuse: Move is_executing_on_a_core to threadimpl.h
4.115
@42c77e99
10/24/14 23:06:54 |
Chris Johns |
shell: Add an editor to the shell.
This is a small (21K on sparc) …
4.115
@9488c9d
10/13/14 21:14:09 |
Joel Sherrill |
libmisc/redirector/stdio-redirect.c: Use UL constants since usleep() …
4.115
@21021feb
10/16/14 13:15:03 |
Sebastian Huber |
shell: Print null mount table entry via LSOF
4.115
@cb513f0a
10/16/14 10:51:25 |
Sebastian Huber |
shell: Improve LSOF output
4.115
@388a4e4
10/12/14 21:05:31 |
Joel Sherrill |
libmisc/redirector/stdio-redirect.c: Use sleep not usleep and do not …
4.115
@308bb9b
10/12/14 21:09:20 |
Joel Sherrill |
shell/main_cp.c: Delete unused -rtems_shell_cp_exit()
4.115
@1c1b082
10/10/14 08:26:50 |
Sebastian Huber |
shell/lsof: Fix warnings
4.115
@56ed56a6
10/03/14 22:55:12 |
Chris Johns |
libmisc/shell: Remove the need for -lm when linking from the ping …
4.115
@c040b113
09/17/14 05:21:35 |
Sebastian Huber |
redirector: Rename rtems_stdio_redirect_t
Rename …
4.115
@2195a95f
09/16/14 22:40:48 |
Joel Sherrill |
Libmisc/Makefile?.am: Build with networking disabled
4.115
@b299960
09/14/14 23:10:45 |
Chris Johns |
shell: Add an md5 hash command for files.
This command lets you get …
4.115
@ebf9a05
09/14/14 22:50:28 |
Chris Johns |
libmisc: Add a stdio redirector helper.
This module makes it easy to …
4.115
@a8fa078
09/14/14 22:00:18 |
Chris Johns |
shell: Add a ping command.
The ping code is taken from a recent …
4.115
@2a86615
08/05/14 20:48:01 |
Jennifer Averett |
capture: Add support for variable length records.
4.115
@133962b
07/22/14 14:40:54 |
Jennifer Averett |
capture: Split user extension methods out.
4.115
@06ac8b71
09/03/14 14:59:37 |
Joel Sherrill |
shell.c: Add cast to match printf() expectations for width specifier
4.115
@463de59
04/16/14 14:42:37 |
Jennifer Averett |
capture: Fix capture engine to handle new extensions.
4.115
@1af8634a
04/11/14 15:18:20 |
Jennifer Averett |
capture: Update comment block style in capture engine.
Doxygen added …
4.115
@bb58190
05/29/14 05:05:56 |
Chris Johns |
shell: Add rtems_shell_dup_current_env to get a default env.
Remove …
4.115
@5f0ab5cf
05/28/14 15:17:29 |
Sebastian Huber |
shell: Make rtems_global_shell_env public
Provide …
4.115
@f39f667a
05/14/14 11:50:48 |
Sebastian Huber |
score: Simplify _Thread_Change_priority()
The function to change a …
4.115
@c21c5912
05/14/14 09:11:05 |
Sebastian Huber |
score: Add STATES_RESTARTING
Use separate state for thread restart.
4.115
@0e8d55b0
05/14/14 09:06:40 |
Sebastian Huber |
monitor: Support STATES_MIGRATING
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@3380ee8
04/22/14 05:46:53 |
Sebastian Huber |
score: Use common names for per-CPU variables
Use "cpu" for an …
4.115
@2ca0a7b
04/11/14 13:41:27 |
Sebastian Huber |
capture: Use ISR lock for SMP support
4.115
@4bc8d2e
04/10/14 08:58:27 |
Sebastian Huber |
rtems: Rename rtems_smp_get_processor_count()
Rename …
4.115
@263f4bec
04/07/14 12:50:37 |
Sebastian Huber |
score: Statically initialize IO manager
This simplifies the RTEMS …
4.115
@03e89287
03/27/14 13:46:31 |
Sebastian Huber |
score: Delete CORE_mutex_Control::lock
The holder field is enough to …
4.115
@b1ce1161
03/27/14 13:29:00 |
Sebastian Huber |
score: Delete CORE_mutex_Control::holder_id
We can use the holder …
4.115
@1b1be254
03/25/14 09:54:49 |
Sebastian Huber |
score: Thread life cycle re-implementation
The thread deletion is now …
4.115
@a5ac9da
03/14/14 09:17:34 |
Sebastian Huber |
score: Add and use thread get/set CPU functions
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@6cd4a5c
03/19/14 16:17:39 |
Christian.Mauderer |
cpukit/shell: Replace task variables with posix keys.
Use posix keys …
4.115
@27545fca
10/30/13 15:33:35 |
ralf.kirchner |
network: Add help text for ifconfig
4.115
@66bf2cc9
12/19/13 00:54:53 |
allanh |
mw_uid: corrects uid_read_message short timeouts
4.115
@6a26e9b
12/24/13 07:08:29 |
Chris Johns |
cpukit/capture: Print the uptime and diff in ctrace.
Print the uptime …
4.115
@9f9c0bb
12/24/13 05:42:23 |
Chris Johns |
cpukit/capture: Use the new RTEMS API to get the uptime in …
4.115
@2bafb960
12/21/13 03:44:12 |
Daniel Ramirez |
rtems: classic api to/from core priority conversions
4.115
@db8a89e
12/19/13 08:01:23 |
Chris Johns |
cpukit/capture: Update the capture engine.
The capture did not work …
4.115
@259328a7
12/16/13 00:59:51 |
Chris Johns |
cpukit/shell: Control help break with SHELL_LINES env variable.
4.115
@77b1de22
11/22/13 23:09:44 |
Bryan Dunsmore |
gettimeofday: Add restrict keyword
4.115
@17ba419
11/14/13 14:56:46 |
Sebastian Huber |
monitor: Add support for BSD wakeup state
4.115
@db97feb5
09/23/13 13:22:02 |
Joel Sherrill |
internal.h/main_mdump.c: Convert main methods to static
4.115
@2cdace7
09/21/13 20:45:51 |
Joel Sherrill |
main_mv.c: Address set but not used warning
It looks like the paths …
4.115
@7071eb3
09/21/13 20:41:50 |
Joel Sherrill |
mouse_parser.c: Fix warning by properly checking return code
4.115
@36fdd0b
09/05/13 18:50:46 |
Gedare Bloom |
uuid: make integer arithmetic conversion explicit
Upcast …
4.115
@e075b388
09/05/13 18:10:52 |
Gedare Bloom |
untar: check return value from mkdir
Check the return value from …
4.115
@96654dc
09/05/13 16:15:27 |
Gedare Bloom |
shell: Out-of-bounds access
In case the length of cwd path plus the …
4.115
@df533f1
08/25/13 23:49:21 |
cynthia |
Stop a resource leak
Stops a resource leak in the event that the …
4.115
@ae75429
08/06/13 14:10:26 |
Sebastian Huber |
PR766: Delete RTEMS_VIOLATE_KERNEL_VISIBILITY
4.115
@ffa2defc
08/06/13 08:58:58 |
rdiezmail-rtems |
Fix compiler warnings
4.115
@f031df0e
07/31/13 11:42:07 |
Sebastian Huber |
score: Rename tod.h to todimpl.h
4.115
@fe52e7c0
07/26/13 12:10:25 |
Sebastian Huber |
smp: Add and use _Per_CPU_Get()
Add and use _Per_CPU_Get_by_index() …
4.115
@ff63d2d
07/26/13 12:04:22 |
Sebastian Huber |
smp: Use Thread_Control.is_executing
FIXME: This area needs proper …
4.115
@91404de
07/26/13 07:34:32 |
Sebastian Huber |
libmisc: Provide libutf8proc conditionally
4.115
@88c74ab
07/25/13 13:10:11 |
Sebastian Huber |
score: Merge tod implementation into one file
Delete …
4.115
@a2e3f33
07/24/13 11:50:54 |
Sebastian Huber |
score: Create object implementation header
Move implementation …
4.115
@fe6c170c
07/24/13 14:19:52 |
Sebastian Huber |
score: Create states implementation header
4.115
@39046f7
07/24/13 09:09:23 |
Sebastian Huber |
score: Merge sysstate API into one file
4.115
@1cb75cc
07/23/13 13:32:50 |
Sebastian Huber |
score: Merge wkspace API into one file
4.115
@c404828
07/23/13 12:56:00 |
Sebastian Huber |
rtems: Create tasks implementation header
4.115
@f6c7c57d
07/23/13 12:38:19 |
Sebastian Huber |
rtems: Create region implementation header
4.115
@8695cae
07/23/13 12:19:58 |
Sebastian Huber |
rtems: Create part implementation header
Move implementation specific …
4.115
@7660e8b3
07/23/13 11:32:58 |
Sebastian Huber |
Include missing <string.h>
4.115
@e151eb1
07/23/13 10:47:35 |
Sebastian Huber |
rtems: Create event implementation header
4.115
@63d229d6
07/23/13 09:12:52 |
Sebastian Huber |
rtems: Create attr implementation header
4.115
@ac252bdc
07/23/13 08:04:19 |
Sebastian Huber |
sapi: Create extension implementation header
4.115
@4b48ece0
07/22/13 08:21:03 |
Sebastian Huber |
score: Create watchdog implementation header
4.115
@0c5317d
07/19/13 12:33:56 |
Sebastian Huber |
posix: Create pthread implementation header
4.115
@a9515722
07/19/13 09:18:51 |
Sebastian Huber |
cpuuse: Add SMP support
4.115
@993a888
07/18/13 13:05:37 |
Sebastian Huber |
rtems: Create message queue implementation header
4.115
@1a30d442
07/22/13 07:18:17 |
Sebastian Huber |
libmisc: Use _Thread_Get_executing()
4.115
@f2d9fda
07/18/13 13:33:44 |
Sebastian Huber |
shell: Include missing header file
4.115
@2bbea657
07/17/13 11:52:00 |
Sebastian Huber |
rtems: Create semaphore implementation header
4.115
@ad83ea0
07/07/13 12:43:17 |
Sebastian Huber |
mouse: Add shared bsp_get_serial_mouse_device()
4.115
@a4006fee
06/28/13 19:25:30 |
Sebastian Huber |
mouse: Include missing header file
4.115
@edde99b
06/14/13 12:26:34 |
Sebastian Huber |
score: Rename rtems_smp_get_number_of_processors()
Rename in …
4.115
@46b7f921
02/26/13 11:00:34 |
ralf.kirchner |
libmisc: Add utf8proc-v1.1.5
utf8proc is a small library for …
4.115
@7bb71c7
05/16/13 09:24:09 |
Andrey Mozzhuhin |
shell: Add df command
4.115
@d2d09eac
05/15/13 13:14:28 |
Andreas Heinig |
shell: Fix NULL pointer access
4.115
@7571a23
01/27/13 14:10:39 |
Sebastian Huber |
sapi: PR1911: Add CONFIGURE_DISABLE_BSP_SETTINGS
4.115
@e858f70
01/10/13 23:06:06 |
Joel Sherrill |
cpukit: Fix many Doxygen warnings
4.115
@b697bc6
01/10/13 21:06:42 |
Joel Sherrill |
cpukit: Use Consistent Beginning of Doxygen Group Notation
This is …
4.115
@a15eaaf
01/10/13 19:20:34 |
Joel Sherrill |
cpukit: Doxygen group fixes and many warnings addressed
The output of …
4.115
