# # ChangeLog for cpukit/libmisc in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 06:26:11 Tue, 16 Jan 2024 23:49:29 GMT Kinsey Moore [07ee157] * cpukit/libmisc/uuid/gen_uuid.c (modified) cpukit/libmisc: Cast getpid() before shifting Cast getpid() before ... Tue, 16 Jan 2024 20:32:35 GMT Kinsey Moore [df8e3fc] * cpukit/libmisc/uuid/gen_uuid.c (modified) cpukit/libmisc/uuid: Check for invalid FD Wed, 13 Dec 2023 02:45:05 GMT Chris Johns [a9905de] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) rtems-fdt: Fix node property access on 64bit Wed, 13 Dec 2023 02:42:23 GMT Chris Johns [7260887] * cpukit/libmisc/shell/shell.c (modified) libmisc/shell: Work around tmux bug in row and column - Extend the ... Tue, 15 Aug 2023 00:47:45 GMT zack [7b33aa26] * cpukit/libmisc/regulator/regulator.c (modified) Address Regulator warning for no prototype for memset() Closes #4942. Wed, 05 Jul 2023 20:28:54 GMT Joel Sherrill [fd69308] * cpukit/include/rtems/regulator.h (added) * cpukit/include/rtems/regulatorimpl.h (added) * cpukit/libmisc/regulator/regulator.c (added) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/objregulator.yml (added) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/regulator01.yml (added) * testsuites/libtests/regulator01/regulator01.c (added) * testsuites/libtests/regulator01/regulator01.doc (added) * testsuites/libtests/regulator01/rtems_config.c (added) Add the Regulator Interface and test Updates #4924. The Regulator ... Fri, 26 May 2023 15:40:13 GMT Joel Sherrill [bb5dbff7] * cpukit/compression/xz/COPYING (moved) * cpukit/compression/xz/README (moved) * cpukit/compression/xz/xz_config.h (moved) * cpukit/compression/xz/xz_crc32.c (moved) * cpukit/compression/xz/xz_crc64.c (moved) * cpukit/compression/xz/xz_dec_lzma2.c (moved) * cpukit/compression/xz/xz_dec_stream.c (moved) * cpukit/compression/xz/xz_lzma2.h (moved) * cpukit/compression/xz/xz_private.h (moved) * cpukit/compression/xz/xz_stream.h (moved) * cpukit/compression/zlib/ChangeLog.zlib (moved) * cpukit/compression/zlib/FAQ (moved) * cpukit/compression/zlib/README (moved) * cpukit/compression/zlib/adler32.c (moved) * cpukit/compression/zlib/compress.c (moved) * cpukit/compression/zlib/crc32.c (moved) * cpukit/compression/zlib/crc32.h (moved) * cpukit/compression/zlib/deflate.c (moved) * cpukit/compression/zlib/deflate.h (moved) * cpukit/compression/zlib/doc/algorithm.txt (moved) * cpukit/compression/zlib/doc/rfc1950.txt (moved) * cpukit/compression/zlib/doc/rfc1951.txt (moved) * cpukit/compression/zlib/doc/rfc1952.txt (moved) * cpukit/compression/zlib/doc/txtvsbin.txt (moved) * cpukit/compression/zlib/gzclose.c (moved) * cpukit/compression/zlib/gzguts.h (moved) * cpukit/compression/zlib/gzlib.c (moved) * cpukit/compression/zlib/gzread.c (moved) * cpukit/compression/zlib/gzwrite.c (moved) * cpukit/compression/zlib/infback.c (moved) * cpukit/compression/zlib/inffast.c (moved) * cpukit/compression/zlib/inffast.h (moved) * cpukit/compression/zlib/inffixed.h (moved) * cpukit/compression/zlib/inflate.c (moved) * cpukit/compression/zlib/inflate.h (moved) * cpukit/compression/zlib/inftrees.c (moved) * cpukit/compression/zlib/inftrees.h (moved) * cpukit/compression/zlib/trees.c (moved) * cpukit/compression/zlib/trees.h (moved) * cpukit/compression/zlib/uncompr.c (moved) * cpukit/compression/zlib/zutil.c (moved) * cpukit/compression/zlib/zutil.h (moved) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/libz.yml (modified) Move various compression libraries into single subdirectory This ... Fri, 19 May 2023 06:18:25 GMT Sebastian Huber [bcef89f2] * bsps/aarch64/xilinx-versal/include/bsp/i2c.h (modified) * bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h (modified) * bsps/arm/altera-cyclone-v/console/console-config.c (modified) * bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.c (modified) * bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h (modified) * bsps/arm/altera-cyclone-v/i2c/i2cdrv.c (modified) * bsps/arm/altera-cyclone-v/include/bsp.h (modified) * bsps/arm/altera-cyclone-v/include/bsp/i2cdrv.h (modified) * bsps/arm/altera-cyclone-v/include/bsp/irq.h (modified) * bsps/arm/altera-cyclone-v/include/tm27.h (modified) * bsps/arm/altera-cyclone-v/rtc/rtc.c (modified) * bsps/arm/altera-cyclone-v/start/bspclean.c (modified) * bsps/arm/altera-cyclone-v/start/bspgetworkarea.c (modified) * bsps/arm/altera-cyclone-v/start/bspreset.c (modified) * bsps/arm/altera-cyclone-v/start/bspsmp.c (modified) * bsps/arm/altera-cyclone-v/start/bspstart.c (modified) * bsps/arm/altera-cyclone-v/start/bspstarthooks.c (modified) * bsps/arm/altera-cyclone-v/start/mmu-config.c (modified) * bsps/arm/atsam/clock/systick-freq.c (modified) * bsps/arm/atsam/console/console.c (modified) * bsps/arm/atsam/console/debug-console.c (modified) * bsps/arm/atsam/i2c/atsam_i2c_bus.c (modified) * bsps/arm/atsam/i2c/atsam_i2c_init.c (modified) * bsps/arm/atsam/include/bsp.h (modified) * bsps/arm/atsam/include/bsp/atsam-clock-config.h (modified) * bsps/arm/atsam/include/bsp/atsam-i2c.h (modified) * bsps/arm/atsam/include/bsp/atsam-spi.h (modified) * bsps/arm/atsam/include/bsp/i2c.h (modified) * bsps/arm/atsam/include/bsp/iocopy.h (modified) * bsps/arm/atsam/include/bsp/irq.h (modified) * bsps/arm/atsam/include/bsp/pin-config.h (modified) * bsps/arm/atsam/include/bsp/power.h (modified) * bsps/arm/atsam/include/bsp/sc16is752.h (modified) * bsps/arm/atsam/include/bsp/spi.h (modified) * bsps/arm/atsam/rtc/rtc-config.c (modified) * bsps/arm/atsam/spi/atsam_spi_bus.c (modified) * bsps/arm/atsam/spi/atsam_spi_init.c (modified) * bsps/arm/atsam/spi/sc16is752.c (modified) * bsps/arm/atsam/start/bspstart.c (modified) * bsps/arm/atsam/start/bspstarthooks.c (modified) * bsps/arm/atsam/start/getentropy-trng.c (modified) * bsps/arm/atsam/start/iocopy.c (modified) * bsps/arm/atsam/start/pin-config.c (modified) * bsps/arm/atsam/start/pmc-config.c (modified) * bsps/arm/atsam/start/power-clock.c (modified) * bsps/arm/atsam/start/power-rtc.c (modified) * bsps/arm/atsam/start/power-wait.c (modified) * bsps/arm/atsam/start/power.c (modified) * bsps/arm/atsam/start/restart.c (modified) * bsps/arm/atsam/start/sdram-config.c (modified) * bsps/arm/beagle/start/bspstart.c (modified) * bsps/arm/beagle/start/bspstarthooks.c (modified) * bsps/arm/beagle/start/bspstartmmu.c (modified) * bsps/arm/csb336/include/bsp/irq.h (modified) * bsps/arm/csb336/irq/irq.c (modified) * bsps/arm/csb337/include/bsp/irq.h (modified) * bsps/arm/csb337/irq/irq.c (modified) * bsps/arm/csb337/umon/tfsDriver.c (modified) * bsps/arm/edb7312/include/bsp/irq.h (modified) * bsps/arm/edb7312/irq/irq.c (modified) * bsps/arm/edb7312/start/start.S (modified) * bsps/arm/fvp/console/console.c (modified) * bsps/arm/fvp/console/printk-support.c (modified) * bsps/arm/fvp/include/bsp.h (modified) * bsps/arm/fvp/include/bsp/irq.h (modified) * bsps/arm/fvp/include/bsp/semihosting.h (modified) * bsps/arm/fvp/start/bspreset.c (modified) * bsps/arm/fvp/start/bspsmp.c (modified) * bsps/arm/fvp/start/bspstart.c (modified) * bsps/arm/fvp/start/bspstarthooks.c (modified) * bsps/arm/fvp/start/pmsa-sections.c (modified) * bsps/arm/gumstix/include/bsp/irq.h (modified) * bsps/arm/gumstix/irq/irq.c (modified) * bsps/arm/imx/console/console-config.c (modified) * bsps/arm/imx/i2c/imx-i2c.c (modified) * bsps/arm/imx/include/arm/freescale/imx/imx6ul_ccmreg.h (modified) * bsps/arm/imx/include/arm/freescale/imx/imx_ecspireg.h (modified) * bsps/arm/imx/include/arm/freescale/imx/imx_gpcreg.h (modified) * bsps/arm/imx/include/arm/freescale/imx/imx_i2creg.h (modified) * bsps/arm/imx/include/arm/freescale/imx/imx_srcreg.h (modified) * bsps/arm/imx/include/arm/freescale/imx/imx_uartreg.h (modified) * bsps/arm/imx/include/bsp.h (modified) * bsps/arm/imx/include/bsp/irq.h (modified) * bsps/arm/imx/include/tm27.h (modified) * bsps/arm/imx/spi/imx-ecspi.c (modified) * bsps/arm/imx/start/bspreset.c (modified) * bsps/arm/imx/start/bspsmp.c (modified) * bsps/arm/imx/start/bspstart.c (modified) * bsps/arm/imx/start/bspstarthooks.c (modified) * bsps/arm/imx/start/ccm.c (modified) * bsps/arm/imxrt/console/console.c (modified) * bsps/arm/imxrt/dts/imxrt1050-evkb.dts (modified) * bsps/arm/imxrt/i2c/imxrt-lpi2c.c (modified) * bsps/arm/imxrt/include/bsp.h (modified) * bsps/arm/imxrt/include/bsp/flash-headers.h (modified) * bsps/arm/imxrt/include/bsp/irq.h (modified) * bsps/arm/imxrt/include/fsl_device_registers.h (modified) * bsps/arm/imxrt/include/imxrt/imxrt1050-pinfunc.h (modified) * bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi (modified) * bsps/arm/imxrt/include/imxrt/lpspi.h (modified) * bsps/arm/imxrt/include/imxrt/memory.h (modified) * bsps/arm/imxrt/include/imxrt/mpu-config.h (modified) * bsps/arm/imxrt/spi/imxrt-lpspi.c (modified) * bsps/arm/imxrt/start/bspstart.c (modified) * bsps/arm/imxrt/start/bspstarthooks.c (modified) * bsps/arm/imxrt/start/clock-arm-pll-config.c (modified) * bsps/arm/imxrt/start/flash-boot-data.c (modified) * bsps/arm/imxrt/start/flash-flexspi-config.c (modified) * bsps/arm/imxrt/start/flash-ivt.c (modified) * bsps/arm/imxrt/start/imxrt-ffec-init.c (modified) * bsps/arm/imxrt/start/mpu-config.c (modified) * bsps/arm/include/bsp/arm-a9mpcore-irq.h (modified) * bsps/arm/include/bsp/arm-a9mpcore-regs.h (modified) * bsps/arm/include/bsp/arm-a9mpcore-start.h (modified) * bsps/arm/include/bsp/arm-cp15-start.h (modified) * bsps/arm/include/bsp/arm-errata.h (modified) * bsps/arm/include/bsp/arm-pl050-regs.h (modified) * bsps/arm/include/bsp/arm-pl050.h (modified) * bsps/arm/include/bsp/arm-pl111-fb.h (modified) * bsps/arm/include/bsp/arm-pl111-regs.h (modified) * bsps/arm/include/bsp/arm-release-id.h (modified) * bsps/arm/include/bsp/imx-gpio.h (modified) * bsps/arm/include/bsp/imx-iomux.h (modified) * bsps/arm/include/bsp/linker-symbols.h (modified) * bsps/arm/include/bsp/lpc-dma.h (modified) * bsps/arm/include/bsp/lpc-emc.h (modified) * bsps/arm/include/bsp/lpc-i2s.h (modified) * bsps/arm/include/bsp/lpc-lcd.h (modified) * bsps/arm/include/bsp/lpc-timer.h (modified) * bsps/arm/include/bsp/start.h (modified) * bsps/arm/include/dev/cache/arm-data-cache-loop-set-way.h (modified) * bsps/arm/lpc176x/console/console-config.c (modified) * bsps/arm/lpc176x/include/bsp.h (modified) * bsps/arm/lpc176x/include/bsp/dma.h (modified) * bsps/arm/lpc176x/include/bsp/irq.h (modified) * bsps/arm/lpc176x/include/bsp/lpc-clock-config.h (modified) * bsps/arm/lpc176x/include/bsp/system-clocks.h (modified) * bsps/arm/lpc176x/irq/irq.c (modified) * bsps/arm/lpc176x/rtc/rtc-config.c (modified) * bsps/arm/lpc176x/start/bspidle.c (modified) * bsps/arm/lpc176x/start/bspstart.c (modified) * bsps/arm/lpc176x/start/dma-copy.c (modified) * bsps/arm/lpc176x/start/dma.c (modified) * bsps/arm/lpc176x/start/restart.c (modified) * bsps/arm/lpc176x/start/system-clocks.c (modified) * bsps/arm/lpc24xx/console/console-config.c (modified) * bsps/arm/lpc24xx/console/uart-probe-1.c (modified) * bsps/arm/lpc24xx/console/uart-probe-2.c (modified) * bsps/arm/lpc24xx/console/uart-probe-3.c (modified) * bsps/arm/lpc24xx/fb/lcd.c (modified) * bsps/arm/lpc24xx/i2c/i2c.c (modified) * bsps/arm/lpc24xx/include/bsp.h (modified) * bsps/arm/lpc24xx/include/bsp/dma.h (modified) * bsps/arm/lpc24xx/include/bsp/i2c.h (modified) * bsps/arm/lpc24xx/include/bsp/io.h (modified) * bsps/arm/lpc24xx/include/bsp/irq.h (modified) * bsps/arm/lpc24xx/include/bsp/lcd.h (modified) * bsps/arm/lpc24xx/include/bsp/lpc-clock-config.h (modified) * bsps/arm/lpc24xx/include/bsp/lpc-ethernet-config.h (modified) * bsps/arm/lpc24xx/include/bsp/lpc17xx.h (modified) * bsps/arm/lpc24xx/include/bsp/lpc24xx.h (modified) * bsps/arm/lpc24xx/include/bsp/ssp.h (modified) * bsps/arm/lpc24xx/include/bsp/start-config.h (modified) * bsps/arm/lpc24xx/include/bsp/system-clocks.h (modified) * bsps/arm/lpc24xx/irq/irq-dispatch.c (modified) * bsps/arm/lpc24xx/irq/irq.c (modified) * bsps/arm/lpc24xx/rtc/rtc-config.c (modified) * bsps/arm/lpc24xx/spi/ssp.c (modified) * bsps/arm/lpc24xx/start/bspidle.c (modified) * bsps/arm/lpc24xx/start/bspreset-armv4.c (modified) * bsps/arm/lpc24xx/start/bspstart.c (modified) * bsps/arm/lpc24xx/start/bspstarthooks.c (modified) * bsps/arm/lpc24xx/start/dma-copy.c (modified) * bsps/arm/lpc24xx/start/dma.c (modified) * bsps/arm/lpc24xx/start/fb-config.c (modified) * bsps/arm/lpc24xx/start/io.c (modified) * bsps/arm/lpc24xx/start/restart.c (modified) * bsps/arm/lpc24xx/start/start-config-emc-dynamic.c (modified) * bsps/arm/lpc24xx/start/start-config-emc-static.c (modified) * bsps/arm/lpc24xx/start/start-config-mpu.c (modified) * bsps/arm/lpc24xx/start/start-config-pinsel.c (modified) * bsps/arm/lpc24xx/start/system-clocks.c (modified) * bsps/arm/lpc24xx/start/timer.c (modified) * bsps/arm/lpc32xx/console/console-config.c (modified) * bsps/arm/lpc32xx/console/hsu.c (modified) * bsps/arm/lpc32xx/i2c/i2c.c (modified) * bsps/arm/lpc32xx/include/bsp.h (modified) * bsps/arm/lpc32xx/include/bsp/boot.h (modified) * bsps/arm/lpc32xx/include/bsp/emc.h (modified) * bsps/arm/lpc32xx/include/bsp/hsu.h (modified) * bsps/arm/lpc32xx/include/bsp/i2c.h (modified) * bsps/arm/lpc32xx/include/bsp/irq.h (modified) * bsps/arm/lpc32xx/include/bsp/lpc-clock-config.h (modified) * bsps/arm/lpc32xx/include/bsp/lpc-ethernet-config.h (modified) * bsps/arm/lpc32xx/include/bsp/lpc32xx.h (modified) * bsps/arm/lpc32xx/include/bsp/mmu.h (modified) * bsps/arm/lpc32xx/include/bsp/nand-mlc.h (modified) * bsps/arm/lpc32xx/include/tm27.h (modified) * bsps/arm/lpc32xx/irq/irq.c (modified) * bsps/arm/lpc32xx/nand/nand-mlc-erase-block-safe.c (modified) * bsps/arm/lpc32xx/nand/nand-mlc-read-blocks.c (modified) * bsps/arm/lpc32xx/nand/nand-mlc-write-blocks.c (modified) * bsps/arm/lpc32xx/nand/nand-mlc.c (modified) * bsps/arm/lpc32xx/nand/nand-select.c (modified) * bsps/arm/lpc32xx/rtc/rtc-config.c (modified) * bsps/arm/lpc32xx/start/boot.c (modified) * bsps/arm/lpc32xx/start/bspidle.c (modified) * bsps/arm/lpc32xx/start/bspreset.c (modified) * bsps/arm/lpc32xx/start/bspstart.c (modified) * bsps/arm/lpc32xx/start/bspstarthooks.c (modified) * bsps/arm/lpc32xx/start/emc.c (modified) * bsps/arm/lpc32xx/start/restart.c (modified) * bsps/arm/lpc32xx/start/system-clocks.c (modified) * bsps/arm/lpc32xx/start/timer.c (modified) * bsps/arm/raspberrypi/include/bsp/mmu.h (modified) * bsps/arm/raspberrypi/irq/irq.c (modified) * bsps/arm/raspberrypi/start/bspsmp.c (modified) * bsps/arm/raspberrypi/start/bspsmp_init.c (modified) * bsps/arm/raspberrypi/start/bspstarthooks.c (modified) * bsps/arm/realview-pbx-a9/console/console-config.c (modified) * bsps/arm/realview-pbx-a9/console/console-polled.c (modified) * bsps/arm/realview-pbx-a9/include/bsp.h (modified) * bsps/arm/realview-pbx-a9/include/bsp/console.h (modified) * bsps/arm/realview-pbx-a9/include/bsp/irq.h (modified) * bsps/arm/realview-pbx-a9/include/tm27.h (modified) * bsps/arm/realview-pbx-a9/start/bspreset.c (modified) * bsps/arm/realview-pbx-a9/start/bspsmp.c (modified) * bsps/arm/realview-pbx-a9/start/bspstart.c (modified) * bsps/arm/realview-pbx-a9/start/bspstarthooks.c (modified) * bsps/arm/realview-pbx-a9/start/fb-config.c (modified) * bsps/arm/rtl22xx/include/bsp/irq.h (modified) * bsps/arm/rtl22xx/irq/irq.c (modified) * bsps/arm/shared/cache/cache-cp15.c (modified) * bsps/arm/shared/cache/cache-cp15.h (modified) * bsps/arm/shared/cache/cache-v7ar-disable-data.S (modified) * bsps/arm/shared/cache/cache-v7m.c (modified) * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-armv7m.c (modified) * bsps/arm/shared/clock/clock-nxp-lpc.c (modified) * bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c (modified) * bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c (modified) * bsps/arm/shared/cpucounter/cpucounter-armv7m.c (modified) * bsps/arm/shared/fb/arm-pl111.c (modified) * bsps/arm/shared/irq/irq-armv7m.c (modified) * bsps/arm/shared/pins/imx-gpio.c (modified) * bsps/arm/shared/serial/arm-pl050.c (modified) * bsps/arm/shared/start/arm-a9mpcore-smp.c (modified) * bsps/arm/shared/start/bsp-start-memcpy.S (modified) * bsps/arm/shared/start/bspreset-armv7m.c (modified) * bsps/arm/shared/start/linkcmds.armv4 (modified) * bsps/arm/shared/start/linkcmds.armv7m (modified) * bsps/arm/shared/start/linkcmds.base (modified) * bsps/arm/shared/start/start.S (modified) * bsps/arm/smdk2410/include/bsp/irq.h (modified) * bsps/arm/smdk2410/irq/irq.c (modified) * bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-bspstarthooks.c (modified) * bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-clk.c (modified) * bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-osc.c (modified) * bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-per.c (modified) * bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-bspstarthooks.c (modified) * bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-config-clk.c (modified) * bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-config-osc.c (modified) * bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-config-per.c (modified) * bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-bspstarthooks.c (modified) * bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c (modified) * bsps/arm/stm32h7/boards/stm/stm32h7b3i-dk/stm32h7-bspstarthooks.c (modified) * bsps/arm/stm32h7/boards/stm/stm32h7b3i-dk/stm32h7-config-clk.c (modified) * bsps/arm/stm32h7/boards/stm/stm32h7b3i-dk/stm32h7-config-osc.c (modified) * bsps/arm/stm32h7/boards/stm/stm32h7b3i-dk/stm32h7-config-per.c (modified) * bsps/arm/stm32h7/console/console-uart4-cfg.c (modified) * bsps/arm/stm32h7/console/console-uart4.c (modified) * bsps/arm/stm32h7/console/console-uart5-cfg.c (modified) * bsps/arm/stm32h7/console/console-uart5.c (modified) * bsps/arm/stm32h7/console/console-uart7-cfg.c (modified) * bsps/arm/stm32h7/console/console-uart7.c (modified) * bsps/arm/stm32h7/console/console-uart8-cfg.c (modified) * bsps/arm/stm32h7/console/console-uart8.c (modified) * bsps/arm/stm32h7/console/console-uart9-cfg.c (modified) * bsps/arm/stm32h7/console/console-uart9.c (modified) * bsps/arm/stm32h7/console/console-usart1-cfg.c (modified) * bsps/arm/stm32h7/console/console-usart1.c (modified) * bsps/arm/stm32h7/console/console-usart10-cfg.c (modified) * bsps/arm/stm32h7/console/console-usart10.c (modified) * bsps/arm/stm32h7/console/console-usart2-cfg.c (modified) * bsps/arm/stm32h7/console/console-usart2.c (modified) * bsps/arm/stm32h7/console/console-usart3-cfg.c (modified) * bsps/arm/stm32h7/console/console-usart3.c (modified) * bsps/arm/stm32h7/console/console-usart6-cfg.c (modified) * bsps/arm/stm32h7/console/console-usart6.c (modified) * bsps/arm/stm32h7/console/console.c (modified) * bsps/arm/stm32h7/console/printk-support.c (modified) * bsps/arm/stm32h7/include/bsp.h (modified) * bsps/arm/stm32h7/include/bsp/irq.h (modified) * bsps/arm/stm32h7/include/chip.h (modified) * bsps/arm/stm32h7/include/stm32h7/hal.h (modified) * bsps/arm/stm32h7/include/stm32h7/memory.h (modified) * bsps/arm/stm32h7/include/stm32h7/mpu-config.h (modified) * bsps/arm/stm32h7/start/bspstart.c (modified) * bsps/arm/stm32h7/start/bspstarthooks.c (modified) * bsps/arm/stm32h7/start/getentropy-rng.c (modified) * bsps/arm/stm32h7/start/mpu-config.c (modified) * bsps/arm/stm32h7/start/stm32h7-config-fls.c (modified) * bsps/arm/stm32h7/start/stm32h7-config-pwr.c (modified) * bsps/arm/stm32h7/start/stm32h7-hal-eth.c (modified) * bsps/arm/stm32h7/start/stm32h7-hal-sdmmc.c (modified) * bsps/arm/stm32h7/start/stm32h7-hal-uart.c (modified) * bsps/arm/stm32h7/start/stm32h7-hal.c (modified) * bsps/arm/tms570/clock/clock.c (modified) * bsps/arm/tms570/console/printk-support.c (modified) * bsps/arm/tms570/console/tms570-sci.c (modified) * bsps/arm/tms570/include/bsp/irq.h (modified) * bsps/arm/tms570/include/bsp/system-clocks.h (modified) * bsps/arm/tms570/include/bsp/tms570-rti.h (modified) * bsps/arm/tms570/include/bsp/tms570-sci-driver.h (modified) * bsps/arm/tms570/include/bsp/tms570-sci.h (modified) * bsps/arm/tms570/include/bsp/tms570-vim.h (modified) * bsps/arm/tms570/start/bspstarthooks.c (modified) * bsps/arm/xilinx-zynq/console/console-config.c (modified) * bsps/arm/xilinx-zynq/console/console-init.c (modified) * bsps/arm/xilinx-zynq/console/debug-console.c (modified) * bsps/arm/xilinx-zynq/include/bsp.h (modified) * bsps/arm/xilinx-zynq/include/bsp/i2c.h (modified) * bsps/arm/xilinx-zynq/include/bsp/irq.h (modified) * bsps/arm/xilinx-zynq/include/tm27.h (modified) * bsps/arm/xilinx-zynq/start/bspreset.c (modified) * bsps/arm/xilinx-zynq/start/bspsmp.c (modified) * bsps/arm/xilinx-zynq/start/bspstart.c (modified) * bsps/arm/xilinx-zynq/start/bspstarthooks.c (modified) * bsps/arm/xilinx-zynq/start/bspstartmmu.c (modified) * bsps/arm/xilinx-zynqmp/console/console-config.c (modified) * bsps/arm/xilinx-zynqmp/include/bsp.h (modified) * bsps/arm/xilinx-zynqmp/include/bsp/irq.h (modified) * bsps/arm/xilinx-zynqmp/include/tm27.h (modified) * bsps/arm/xilinx-zynqmp/start/bspreset.c (modified) * bsps/arm/xilinx-zynqmp/start/bspsmp.c (modified) * bsps/arm/xilinx-zynqmp/start/bspstart.c (modified) * bsps/arm/xilinx-zynqmp/start/bspstarthooks.c (modified) * bsps/arm/xilinx-zynqmp/start/bspstartmmu.c (modified) * bsps/i386/pc386/start/bspgetworkarea.c (modified) * bsps/i386/shared/irq/irq.c (modified) * bsps/i386/shared/irq/irq_init.c (modified) * bsps/include/bsp/bootcard.h (modified) * bsps/include/bsp/console-termios.h (modified) * bsps/include/bsp/default-initial-extension.h (modified) * bsps/include/bsp/fatal.h (modified) * bsps/include/bsp/fdt.h (modified) * bsps/include/bsp/irq-default.h (modified) * bsps/include/bsp/irq-generic.h (modified) * bsps/include/bsp/irq-info.h (modified) * bsps/include/bsp/stackalloc.h (modified) * bsps/include/bsp/u-boot.h (modified) * bsps/include/bsp/uart-output-char.h (modified) * bsps/include/bsp/utility.h (modified) * bsps/include/dev/i2c/cadence-i2c-regs.h (modified) * bsps/include/dev/i2c/cadence-i2c.h (modified) * bsps/include/dev/irq/arm-gic-irq.h (modified) * bsps/include/dev/irq/arm-gic-regs.h (modified) * bsps/include/dev/irq/arm-gic-tm27.h (modified) * bsps/include/dev/irq/arm-gic.h (modified) * bsps/include/dev/irq/arm-gicv3.h (modified) * bsps/include/dev/serial/arm-pl011-regs.h (modified) * bsps/include/dev/serial/arm-pl011.h (modified) * bsps/include/dev/serial/zynq-uart-regs.h (modified) * bsps/include/dev/serial/zynq-uart.h (modified) * bsps/include/fsl/edma.h (modified) * bsps/include/fsl/regs-edma.h (modified) * bsps/include/libchip/disp_hcms29xx.h (modified) * bsps/include/libchip/i2c-sc620.h (modified) * bsps/include/libchip/spi-flash-m25p40.h (modified) * bsps/include/libchip/spi-fram-fm25l256.h (modified) * bsps/include/libchip/spi-memdrv.h (modified) * bsps/include/libchip/spi-sd-card.h (modified) * bsps/lm32/include/bsp/irq.h (modified) * bsps/m68k/gen68360/spi/m360_spi.h (modified) * bsps/m68k/genmcf548x/README (modified) * bsps/m68k/genmcf548x/btimer/btimer.c (modified) * bsps/m68k/genmcf548x/clock/clock.c (modified) * bsps/m68k/genmcf548x/console/console.c (modified) * bsps/m68k/genmcf548x/include/bsp.h (modified) * bsps/m68k/genmcf548x/include/bsp/irq.h (modified) * bsps/m68k/genmcf548x/irq/intc-icr-init-values.c (modified) * bsps/m68k/genmcf548x/irq/irq.c (modified) * bsps/m68k/genmcf548x/mcdma/mcdma_glue.c (modified) * bsps/m68k/genmcf548x/start/bspstart.c (modified) * bsps/m68k/genmcf548x/start/cache.c (modified) * bsps/m68k/genmcf548x/start/init548x.c (modified) * bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 (modified) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine (modified) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash (modified) * bsps/m68k/genmcf548x/start/start.S (modified) * bsps/m68k/include/bsp/linker-symbols.h (modified) * bsps/m68k/include/mcf548x/mcdma_glue.h (modified) * bsps/m68k/include/mcf548x/mcf548x.h (modified) * bsps/m68k/shared/start/linkcmds.base (modified) * bsps/powerpc/gen5200/ata/ata-dma-pio-single.c (modified) * bsps/powerpc/gen5200/ata/ata-instance.c (modified) * bsps/powerpc/gen5200/ata/idecfg.c (modified) * bsps/powerpc/gen5200/ata/pcmcia_ide.c (modified) * bsps/powerpc/gen5200/ata/pcmcia_ide.h (modified) * bsps/powerpc/gen5200/bestcomm/bestcomm_glue.c (modified) * bsps/powerpc/gen5200/console/console.c (modified) * bsps/powerpc/gen5200/dev/mpc5200-ata.c (modified) * bsps/powerpc/gen5200/i2c/i2cdrv.c (modified) * bsps/powerpc/gen5200/i2c/mpc5200mbus.c (modified) * bsps/powerpc/gen5200/i2c/mpc5200mbus.h (modified) * bsps/powerpc/gen5200/include/bsp.h (modified) * bsps/powerpc/gen5200/include/bsp/ata.h (modified) * bsps/powerpc/gen5200/include/bsp/bestcomm.h (modified) * bsps/powerpc/gen5200/include/bsp/bestcomm/bestcomm_glue.h (modified) * bsps/powerpc/gen5200/include/bsp/bestcomm_ops.h (modified) * bsps/powerpc/gen5200/include/bsp/irq.h (modified) * bsps/powerpc/gen5200/include/bsp/mpc5200.h (modified) * bsps/powerpc/gen5200/include/bsp/mscan-base.h (modified) * bsps/powerpc/gen5200/include/bsp/mscan.h (modified) * bsps/powerpc/gen5200/include/bsp/nvram.h (modified) * bsps/powerpc/gen5200/include/bsp/slicetimer.h (modified) * bsps/powerpc/gen5200/include/bsp/u-boot-config.h (modified) * bsps/powerpc/gen5200/irq/irq.c (modified) * bsps/powerpc/gen5200/mscan/mscan-base.c (modified) * bsps/powerpc/gen5200/mscan/mscan.c (modified) * bsps/powerpc/gen5200/mscan/mscan_int.h (modified) * bsps/powerpc/gen5200/nvram/m93cxx.h (modified) * bsps/powerpc/gen5200/nvram/nvram.c (modified) * bsps/powerpc/gen5200/rtc/pcf8563.c (modified) * bsps/powerpc/gen5200/rtc/pcf8563.h (modified) * bsps/powerpc/gen5200/rtc/todcfg.c (modified) * bsps/powerpc/gen5200/slicetimer/slicetimer.c (modified) * bsps/powerpc/gen5200/start/bestcomm.c (modified) * bsps/powerpc/gen5200/start/bspstart.c (modified) * bsps/powerpc/gen5200/start/cpuinit.c (modified) * bsps/powerpc/gen5200/start/start.S (modified) * bsps/powerpc/gen83xx/console/console-config.c (modified) * bsps/powerpc/gen83xx/dev/gtm.c (modified) * bsps/powerpc/gen83xx/dev/mpc83xx_i2cdrv.c (modified) * bsps/powerpc/gen83xx/dev/mpc83xx_spidrv.c (modified) * bsps/powerpc/gen83xx/i2c/i2c_init.c (modified) * bsps/powerpc/gen83xx/include/bsp.h (modified) * bsps/powerpc/gen83xx/include/bsp/hwreg_vals.h (modified) * bsps/powerpc/gen83xx/include/bsp/irq.h (modified) * bsps/powerpc/gen83xx/include/bsp/tsec-config.h (modified) * bsps/powerpc/gen83xx/include/bsp/u-boot-config.h (modified) * bsps/powerpc/gen83xx/include/tm27.h (modified) * bsps/powerpc/gen83xx/irq/irq.c (modified) * bsps/powerpc/gen83xx/spi/spi_init.c (modified) * bsps/powerpc/gen83xx/start/bspreset.c (modified) * bsps/powerpc/gen83xx/start/bsprestart.c (modified) * bsps/powerpc/gen83xx/start/bspstart.c (modified) * bsps/powerpc/gen83xx/start/cpuinit.c (modified) * bsps/powerpc/gen83xx/start/start.S (modified) * bsps/powerpc/include/bsp/linker-symbols.h (modified) * bsps/powerpc/include/bsp/start.h (modified) * bsps/powerpc/include/bsp/tictac.h (modified) * bsps/powerpc/include/bsp/tsec.h (modified) * bsps/powerpc/include/bsp/vectors.h (modified) * bsps/powerpc/include/libcpu/powerpc-utility.h (modified) * bsps/powerpc/include/mpc83xx/gtm.h (modified) * bsps/powerpc/include/mpc83xx/mpc83xx_i2cdrv.h (modified) * bsps/powerpc/include/mpc83xx/mpc83xx_spidrv.h (modified) * bsps/powerpc/mpc55xxevb/README (modified) * bsps/powerpc/mpc55xxevb/clock/clock-config.c (modified) * bsps/powerpc/mpc55xxevb/console/console-config.c (modified) * bsps/powerpc/mpc55xxevb/console/console-esci.c (modified) * bsps/powerpc/mpc55xxevb/console/console-generic.c (modified) * bsps/powerpc/mpc55xxevb/console/console-linflex.c (modified) * bsps/powerpc/mpc55xxevb/dev/dspi.c (modified) * bsps/powerpc/mpc55xxevb/i2c/i2c_init.c (modified) * bsps/powerpc/mpc55xxevb/include/bsp.h (modified) * bsps/powerpc/mpc55xxevb/include/bsp/console-esci.h (modified) * bsps/powerpc/mpc55xxevb/include/bsp/console-generic.h (modified) * bsps/powerpc/mpc55xxevb/include/bsp/console-linflex.h (modified) * bsps/powerpc/mpc55xxevb/include/bsp/irq.h (modified) * bsps/powerpc/mpc55xxevb/include/bsp/mpc55xx-config.h (modified) * bsps/powerpc/mpc55xxevb/include/bsp/smsc9218i.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/dspi.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/edma.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/emios.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/fsl-mpc551x.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/fsl-mpc555x.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/fsl-mpc556x.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/fsl-mpc564xL.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/fsl-mpc5668.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/fsl-mpc567x.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/mpc55xx.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/reg-defs.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/regs-edma.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/regs-mmu.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/regs.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/siu.h (modified) * bsps/powerpc/mpc55xxevb/include/mpc55xx/watchdog.h (modified) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (modified) * bsps/powerpc/mpc55xxevb/start/bspreset.c (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/copy.S (modified) * bsps/powerpc/mpc55xxevb/start/edma.c (modified) * bsps/powerpc/mpc55xxevb/start/emios.c (modified) * bsps/powerpc/mpc55xxevb/start/exc-vector-base.S (modified) * bsps/powerpc/mpc55xxevb/start/get-system-clock.c (modified) * bsps/powerpc/mpc55xxevb/start/idle-thread.c (modified) * bsps/powerpc/mpc55xxevb/start/irq.c (modified) * bsps/powerpc/mpc55xxevb/start/restart.c (modified) * bsps/powerpc/mpc55xxevb/start/sd-card-init.c (modified) * bsps/powerpc/mpc55xxevb/start/siu.c (modified) * bsps/powerpc/mpc55xxevb/start/start-cache.S (modified) * bsps/powerpc/mpc55xxevb/start/start-clock.c (modified) * bsps/powerpc/mpc55xxevb/start/start-config-clock.c (modified) * bsps/powerpc/mpc55xxevb/start/start-config-ebi-cs-cal.c (modified) * bsps/powerpc/mpc55xxevb/start/start-config-ebi-cs.c (modified) * bsps/powerpc/mpc55xxevb/start/start-config-ebi.c (modified) * bsps/powerpc/mpc55xxevb/start/start-config-mmu-early.c (modified) * bsps/powerpc/mpc55xxevb/start/start-config-mmu.c (modified) * bsps/powerpc/mpc55xxevb/start/start-config-siu-pcr.c (modified) * bsps/powerpc/mpc55xxevb/start/start-early.c (modified) * bsps/powerpc/mpc55xxevb/start/start-flash.S (modified) * bsps/powerpc/mpc55xxevb/start/start-prologue.c (modified) * bsps/powerpc/mpc55xxevb/start/start-watchdog.c (modified) * bsps/powerpc/mpc55xxevb/start/start.S (modified) * bsps/powerpc/qemuppc/irq/irq_init.c (modified) * bsps/powerpc/qoriq/btimer/btimer.c (modified) * bsps/powerpc/qoriq/clock/clock-config.c (modified) * bsps/powerpc/qoriq/console/console-config.c (modified) * bsps/powerpc/qoriq/console/uart-bridge-master.c (modified) * bsps/powerpc/qoriq/console/uart-bridge-slave.c (modified) * bsps/powerpc/qoriq/include/bsp.h (modified) * bsps/powerpc/qoriq/include/bsp/VMEConfig.h (modified) * bsps/powerpc/qoriq/include/bsp/intercom.h (modified) * bsps/powerpc/qoriq/include/bsp/irq.h (modified) * bsps/powerpc/qoriq/include/bsp/mmu.h (modified) * bsps/powerpc/qoriq/include/bsp/qoriq.h (modified) * bsps/powerpc/qoriq/include/bsp/tsec-config.h (modified) * bsps/powerpc/qoriq/include/bsp/uart-bridge.h (modified) * bsps/powerpc/qoriq/include/tm27.h (modified) * bsps/powerpc/qoriq/irq/irq.c (modified) * bsps/powerpc/qoriq/mpci/intercom-mpci.c (modified) * bsps/powerpc/qoriq/mpci/intercom.c (modified) * bsps/powerpc/qoriq/mpci/lock.S (modified) * bsps/powerpc/qoriq/rtc/rtc-config.c (modified) * bsps/powerpc/qoriq/start/bspreset.c (modified) * bsps/powerpc/qoriq/start/bsprestart.c (modified) * bsps/powerpc/qoriq/start/bspsmp.c (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/epapr_hcalls.S (modified) * bsps/powerpc/qoriq/start/l1cache.S (modified) * bsps/powerpc/qoriq/start/l2cache.S (modified) * bsps/powerpc/qoriq/start/mmu-config.c (modified) * bsps/powerpc/qoriq/start/mmu-tlb1.S (modified) * bsps/powerpc/qoriq/start/mmu.c (modified) * bsps/powerpc/qoriq/start/portal.c (modified) * bsps/powerpc/qoriq/start/restart.S (modified) * bsps/powerpc/qoriq/start/start.S (modified) * bsps/powerpc/shared/clock/clock.c (modified) * bsps/powerpc/shared/cpu_asm.S (modified) * bsps/powerpc/shared/exceptions/ppc-code-copy.c (modified) * bsps/powerpc/shared/exceptions/ppc-exc-handler-table.c (modified) * bsps/powerpc/shared/exceptions/ppc_exc_address.c (modified) * bsps/powerpc/shared/exceptions/ppc_exc_alignment.c (modified) * bsps/powerpc/shared/exceptions/ppc_exc_async_normal.S (modified) * bsps/powerpc/shared/exceptions/ppc_exc_categories.c (modified) * bsps/powerpc/shared/exceptions/ppc_exc_fatal.S (modified) * bsps/powerpc/shared/exceptions/ppc_exc_initialize.c (modified) * bsps/powerpc/shared/exceptions/ppc_exc_naked.S (modified) * bsps/powerpc/shared/exceptions/ppc_exc_prologue.c (modified) * bsps/powerpc/shared/start/bsp-start-zero.S (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * bsps/powerpc/shared/start/memcpy.c (modified) * bsps/powerpc/shared/start/rtems_crti.S (modified) * bsps/powerpc/shared/start/rtems_crtn.S (modified) * bsps/powerpc/shared/start/tictac.c (modified) * bsps/powerpc/t32mppc/clock/clock-config.c (modified) * bsps/powerpc/t32mppc/console/console.c (modified) * bsps/powerpc/t32mppc/include/bsp.h (modified) * bsps/powerpc/t32mppc/include/bsp/irq.h (modified) * bsps/powerpc/t32mppc/irq/irq.c (modified) * bsps/powerpc/t32mppc/start/bspreset.c (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/t32mppc/start/start.S (modified) * bsps/powerpc/tqm8xx/btimer/btimer.c (modified) * bsps/powerpc/tqm8xx/console/console.c (modified) * bsps/powerpc/tqm8xx/include/bsp.h (modified) * bsps/powerpc/tqm8xx/include/bsp/8xx_immap.h (modified) * bsps/powerpc/tqm8xx/include/bsp/irq.h (modified) * bsps/powerpc/tqm8xx/include/bsp/spi.h (modified) * bsps/powerpc/tqm8xx/include/bsp/tqm.h (modified) * bsps/powerpc/tqm8xx/irq/irq.c (modified) * bsps/powerpc/tqm8xx/spi/spi.c (modified) * bsps/powerpc/tqm8xx/start/bspgetworkarea.c (modified) * bsps/powerpc/tqm8xx/start/bspstart.c (modified) * bsps/powerpc/tqm8xx/start/mmutlbtab.c (modified) * bsps/powerpc/tqm8xx/start/start.S (modified) * bsps/powerpc/virtex/include/bsp/irq.h (modified) * bsps/powerpc/virtex/irq/irq_init.c (modified) * bsps/powerpc/virtex/start/start.S (modified) * bsps/powerpc/virtex4/include/bsp/irq.h (modified) * bsps/powerpc/virtex4/irq/irq_init.c (modified) * bsps/powerpc/virtex5/include/bsp/irq.h (modified) * bsps/powerpc/virtex5/irq/irq_init.c (modified) * bsps/riscv/griscv/clock/clockdrv.c (modified) * bsps/riscv/griscv/include/bsp/irq.h (modified) * bsps/riscv/griscv/irq/irq.c (modified) * bsps/riscv/griscv/start/bsp_fatal_halt.c (modified) * bsps/riscv/griscv/start/bspsmp.c (modified) * bsps/riscv/griscv/start/bspstart.c (modified) * bsps/riscv/noel/console/console-config.c (modified) * bsps/riscv/noel/include/bsp/irq.h (modified) * bsps/riscv/noel/include/bsp/riscv.h (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/console/console-config.c (modified) * bsps/riscv/riscv/include/bsp/irq.h (modified) * bsps/riscv/riscv/include/bsp/riscv.h (modified) * bsps/riscv/riscv/include/dev/serial/htif.h (modified) * bsps/riscv/riscv/include/tm27.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bsp_fatal_halt.c (modified) * bsps/riscv/riscv/start/bspsmp.c (modified) * bsps/riscv/riscv/start/bspstart.c (modified) * bsps/riscv/shared/start/start.S (modified) * bsps/sh/gensh1/console/scitab.c (modified) * bsps/sh/gensh2/console/scitab.c (modified) * bsps/shared/cache/cacheimpl.h (modified) * bsps/shared/dev/btimer/btimer-cpucounter.c (modified) * bsps/shared/dev/clock/arm-generic-timer.c (modified) * bsps/shared/dev/cpucounter/cpucounterfrequency.c (modified) * bsps/shared/dev/cpucounter/cpucounterread.c (modified) * bsps/shared/dev/display/disp_fonts.h (modified) * bsps/shared/dev/display/disp_hcms29xx.c (modified) * bsps/shared/dev/display/font_hcms29xx.c (modified) * bsps/shared/dev/display/font_hcms29xx.h (modified) * bsps/shared/dev/dma/fsl-edma.c (modified) * bsps/shared/dev/getentropy/getentropy-cpucounter.c (modified) * bsps/shared/dev/i2c/cadence-i2c.c (modified) * bsps/shared/dev/i2c/i2c-sc620.c (modified) * bsps/shared/dev/i2c/spi-flash-m25p40.c (modified) * bsps/shared/dev/i2c/spi-fram-fm25l256.c (modified) * bsps/shared/dev/i2c/spi-memdrv.c (modified) * bsps/shared/dev/i2c/spi-sd-card.c (modified) * bsps/shared/dev/ide/ata_util.c (modified) * bsps/shared/dev/irq/arm-gicv2-get-attributes.c (modified) * bsps/shared/dev/irq/arm-gicv2.c (modified) * bsps/shared/dev/serial/arm-pl011.c (modified) * bsps/shared/dev/serial/console-output-char.c (modified) * bsps/shared/dev/serial/console-termios-init.c (modified) * bsps/shared/dev/serial/console-termios.c (modified) * bsps/shared/dev/serial/getserialmouseps2.c (modified) * bsps/shared/dev/serial/uart-output-char.c (modified) * bsps/shared/dev/serial/zynq-uart-polled.c (modified) * bsps/shared/dev/serial/zynq-uart.c (modified) * bsps/shared/irq/irq-affinity.c (modified) * bsps/shared/irq/irq-default-handler.c (modified) * bsps/shared/irq/irq-default.c (modified) * bsps/shared/irq/irq-enable-disable.c (modified) * bsps/shared/irq/irq-entry-remove.c (modified) * bsps/shared/irq/irq-generic.c (modified) * bsps/shared/irq/irq-handler-install.c (modified) * bsps/shared/irq/irq-handler-iterate.c (modified) * bsps/shared/irq/irq-handler-remove.c (modified) * bsps/shared/irq/irq-info.c (modified) * bsps/shared/irq/irq-legacy.c (modified) * bsps/shared/irq/irq-lock.c (modified) * bsps/shared/irq/irq-raise-clear.c (modified) * bsps/shared/irq/irq-record.c (modified) * bsps/shared/irq/irq-server.c (modified) * bsps/shared/irq/irq-shell.c (modified) * bsps/shared/start/bsp-fdt.c (modified) * bsps/shared/start/bsp-uboot-board-info.c (modified) * bsps/shared/start/bspgetworkarea-default.c (modified) * bsps/shared/start/gettargethash-default.c (modified) * bsps/shared/start/mallocinitmulti.c (modified) * bsps/shared/start/mallocinitone.c (modified) * bsps/shared/start/stackalloc.c (modified) * bsps/shared/start/wkspaceinitmulti.c (modified) * bsps/shared/start/wkspaceinitone.c (modified) * bsps/sparc/erc32/start/bspsmp.c (modified) * bsps/sparc/leon3/clock/ckinit.c (modified) * bsps/sparc/leon3/start/bspclean.c (modified) * bsps/sparc/leon3/start/cache.c (modified) * bsps/sparc/leon3/start/cpucounter.c (modified) * bsps/sparc/leon3/start/eirq.c (modified) * bsps/sparc/shared/start/bspgetworkarea.c (modified) * bsps/x86_64/amd64/start/start.S (modified) * cpukit/dev/i2c/eeprom.c (modified) * cpukit/dev/i2c/gpio-nxp-pca9535.c (modified) * cpukit/dev/i2c/i2c-bus.c (modified) * cpukit/dev/i2c/i2c-dev.c (modified) * cpukit/dev/i2c/sensor-lm75a.c (modified) * cpukit/dev/i2c/switch-nxp-pca9548a.c (modified) * cpukit/dev/serial/sc16is752-regs.h (modified) * cpukit/dev/serial/sc16is752-spi.c (modified) * cpukit/dev/serial/sc16is752.c (modified) * cpukit/dev/spi/spi-bus.c (modified) * cpukit/doxygen/appl-config.h (modified) * cpukit/doxygen/hash-algorithms.h (modified) * cpukit/doxygen/top-level-groups.h (modified) * cpukit/dtc/libfdt/fdt_addresses.c (modified) * cpukit/ftpd/ftpd-init.c (modified) * cpukit/include/dev/i2c/eeprom.h (modified) * cpukit/include/dev/i2c/gpio-nxp-pca9535.h (modified) * cpukit/include/dev/i2c/i2c.h (modified) * cpukit/include/dev/i2c/sensor-lm75a.h (modified) * cpukit/include/dev/i2c/switch-nxp-pca9548a.h (modified) * cpukit/include/dev/serial/sc16is752.h (modified) * cpukit/include/dev/spi/spi.h (modified) * cpukit/include/endian.h (modified) * cpukit/include/linux/i2c-dev.h (modified) * cpukit/include/linux/i2c.h (modified) * cpukit/include/linux/rbtree.h (modified) * cpukit/include/linux/spi/spidev.h (modified) * cpukit/include/machine/_kernel_cpuset.h (modified) * cpukit/include/machine/_kernel_mman.h (modified) * cpukit/include/machine/_kernel_param.h (modified) * cpukit/include/machine/_kernel_time.h (modified) * cpukit/include/machine/_kernel_types.h (modified) * cpukit/include/machine/_timecounter.h (modified) * cpukit/include/rtems.h (modified) * cpukit/include/rtems/bdbuf.h (modified) * cpukit/include/rtems/bdpart.h (modified) * cpukit/include/rtems/bsd.h (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/chain.h (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/bdbuf.h (modified) * cpukit/include/rtems/confdefs/bsp.h (modified) * cpukit/include/rtems/confdefs/clock.h (modified) * cpukit/include/rtems/confdefs/console.h (modified) * cpukit/include/rtems/confdefs/extensions.h (modified) * cpukit/include/rtems/confdefs/inittask.h (modified) * cpukit/include/rtems/confdefs/initthread.h (modified) * cpukit/include/rtems/confdefs/iodrivers.h (modified) * cpukit/include/rtems/confdefs/libio.h (modified) * cpukit/include/rtems/confdefs/malloc.h (modified) * cpukit/include/rtems/confdefs/mpci.h (modified) * cpukit/include/rtems/confdefs/newlib.h (modified) * cpukit/include/rtems/confdefs/objectsclassic.h (modified) * cpukit/include/rtems/confdefs/objectsposix.h (modified) * cpukit/include/rtems/confdefs/obsolete.h (modified) * cpukit/include/rtems/confdefs/percpu.h (modified) * cpukit/include/rtems/confdefs/scheduler.h (modified) * cpukit/include/rtems/confdefs/threads.h (modified) * cpukit/include/rtems/confdefs/unlimited.h (modified) * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/confdefs/wkspacesupport.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/counter.h (modified) * cpukit/include/rtems/cpuuse.h (modified) * cpukit/include/rtems/devzero.h (modified) * cpukit/include/rtems/dosfs.h (modified) * cpukit/include/rtems/extension.h (modified) * cpukit/include/rtems/fatal.h (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/include/rtems/ftpfs.h (modified) * cpukit/include/rtems/imfsimpl.h (modified) * cpukit/include/rtems/init.h (modified) * cpukit/include/rtems/io.h (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/include/rtems/jffs2.h (modified) * cpukit/include/rtems/libio.h (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/include/rtems/linkersets.h (modified) * cpukit/include/rtems/mallocinitmulti.h (modified) * cpukit/include/rtems/mallocinitone.h (modified) * cpukit/include/rtems/media.h (modified) * cpukit/include/rtems/posix/barrierimpl.h (modified) * cpukit/include/rtems/posix/key.h (modified) * cpukit/include/rtems/posix/keyimpl.h (modified) * cpukit/include/rtems/posix/spinlockimpl.h (modified) * cpukit/include/rtems/profiling.h (modified) * cpukit/include/rtems/rbheap.h (modified) * cpukit/include/rtems/record.h (modified) * cpukit/include/rtems/recordclient.h (modified) * cpukit/include/rtems/recorddata.h (modified) * cpukit/include/rtems/recorddump.h (modified) * cpukit/include/rtems/recordserver.h (modified) * cpukit/include/rtems/rtems/asr.h (modified) * cpukit/include/rtems/rtems/attr.h (modified) * cpukit/include/rtems/rtems/barrier.h (modified) * cpukit/include/rtems/rtems/cache.h (modified) * cpukit/include/rtems/rtems/clock.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/include/rtems/rtems/dpmem.h (modified) * cpukit/include/rtems/rtems/event.h (modified) * cpukit/include/rtems/rtems/intr.h (modified) * cpukit/include/rtems/rtems/message.h (modified) * cpukit/include/rtems/rtems/modes.h (modified) * cpukit/include/rtems/rtems/mp.h (modified) * cpukit/include/rtems/rtems/object.h (modified) * cpukit/include/rtems/rtems/objectimpl.h (modified) * cpukit/include/rtems/rtems/options.h (modified) * cpukit/include/rtems/rtems/part.h (modified) * cpukit/include/rtems/rtems/ratemon.h (modified) * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/rtems/region.h (modified) * cpukit/include/rtems/rtems/scheduler.h (modified) * cpukit/include/rtems/rtems/sem.h (modified) * cpukit/include/rtems/rtems/signal.h (modified) * cpukit/include/rtems/rtems/status.h (modified) * cpukit/include/rtems/rtems/support.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/timer.h (modified) * cpukit/include/rtems/rtems/timerdata.h (modified) * cpukit/include/rtems/rtems/timerimpl.h (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/include/rtems/scheduler.h (modified) * cpukit/include/rtems/score/assert.h (modified) * cpukit/include/rtems/score/basedefs.h (modified) * cpukit/include/rtems/score/chain.h (modified) * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/include/rtems/score/coremsgbuffer.h (modified) * cpukit/include/rtems/score/cpustdatomic.h (modified) * cpukit/include/rtems/score/gcov.h (modified) * cpukit/include/rtems/score/hash.h (modified) * cpukit/include/rtems/score/io.h (modified) * cpukit/include/rtems/score/isrlock.h (modified) * cpukit/include/rtems/score/memory.h (modified) * cpukit/include/rtems/score/mrsp.h (modified) * cpukit/include/rtems/score/mrspimpl.h (modified) * cpukit/include/rtems/score/muteximpl.h (modified) * cpukit/include/rtems/score/onceimpl.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/percpudata.h (modified) * cpukit/include/rtems/score/priority.h (modified) * cpukit/include/rtems/score/priorityimpl.h (modified) * cpukit/include/rtems/score/processormask.h (modified) * cpukit/include/rtems/score/profiling.h (modified) * cpukit/include/rtems/score/schedulercbsimpl.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulernode.h (modified) * cpukit/include/rtems/score/schedulernodeimpl.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulersmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/include/rtems/score/scheduleruniimpl.h (modified) * cpukit/include/rtems/score/semaphoreimpl.h (modified) * cpukit/include/rtems/score/smpbarrier.h (modified) * cpukit/include/rtems/score/smplock.h (modified) * cpukit/include/rtems/score/smplockmcs.h (modified) * cpukit/include/rtems/score/smplockseq.h (modified) * cpukit/include/rtems/score/smplockstats.h (modified) * cpukit/include/rtems/score/smplockticket.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/include/rtems/score/status.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadcpubudget.h (modified) * cpukit/include/rtems/score/threadidledata.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadqops.h (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/timecounterimpl.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/include/rtems/score/wkspacedata.h (modified) * cpukit/include/rtems/score/wkspaceinitmulti.h (modified) * cpukit/include/rtems/score/wkspaceinitone.h (modified) * cpukit/include/rtems/sparse-disk.h (modified) * cpukit/include/rtems/status-checks.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/include/rtems/telnetd.h (modified) * cpukit/include/rtems/test-info.h (modified) * cpukit/include/rtems/test-scheduler.h (modified) * cpukit/include/rtems/test.h (modified) * cpukit/include/rtems/tftp.h (modified) * cpukit/include/rtems/thread.h (modified) * cpukit/include/rtems/timecounter.h (modified) * cpukit/include/rtems/userenv.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/bdpart-create.c (modified) * cpukit/libblock/src/bdpart-dump.c (modified) * cpukit/libblock/src/bdpart-read.c (modified) * cpukit/libblock/src/bdpart-register.c (modified) * cpukit/libblock/src/bdpart-sort.c (modified) * cpukit/libblock/src/bdpart-write.c (modified) * cpukit/libblock/src/blkdev-blkstats.c (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libblock/src/blkdev-ops.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (modified) * cpukit/libblock/src/diskdevs-init.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/media-desc.c (modified) * cpukit/libblock/src/media-dev-ident.c (modified) * cpukit/libblock/src/media-path.c (modified) * cpukit/libblock/src/media-server.c (modified) * cpukit/libblock/src/media.c (modified) * cpukit/libblock/src/ramdisk-init.c (modified) * cpukit/libblock/src/ramdisk-register.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/libblock/src/sparse-disk.c (modified) * cpukit/libcrypt/crypt.c (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libcsupport/src/_rename_r.c (modified) * cpukit/libcsupport/src/alignedalloc.c (modified) * cpukit/libcsupport/src/arc4random_getentropy_fail.c (modified) * cpukit/libcsupport/src/assoc32tostring.c (modified) * cpukit/libcsupport/src/assocthreadstatestostring.c (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/cachecoherentalloc.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chown.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/clock.c (modified) * cpukit/libcsupport/src/clonenode.c (modified) * cpukit/libcsupport/src/consolesimple.c (modified) * cpukit/libcsupport/src/consolesimple.h (modified) * cpukit/libcsupport/src/consolesimpleread.c (modified) * cpukit/libcsupport/src/consolesimpletask.c (modified) * cpukit/libcsupport/src/fchdir.c (modified) * cpukit/libcsupport/src/freenode.c (modified) * cpukit/libcsupport/src/gcovfork.c (modified) * cpukit/libcsupport/src/getreentglobal.c (modified) * cpukit/libcsupport/src/libio_exit.c (modified) * cpukit/libcsupport/src/libiozeroiops.c (modified) * cpukit/libcsupport/src/mallocdirtydefault.c (modified) * cpukit/libcsupport/src/mallocextenddefault.c (modified) * cpukit/libcsupport/src/mallocheap.c (modified) * cpukit/libcsupport/src/mount-mgr.c (modified) * cpukit/libcsupport/src/mount-mktgt.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/printerfprintfputc.c (modified) * cpukit/libcsupport/src/printertask.c (modified) * cpukit/libcsupport/src/printf_plugin.c (modified) * cpukit/libcsupport/src/pwdgrp.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libcsupport/src/rtems_heap_extend.c (modified) * cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c (modified) * cpukit/libcsupport/src/rtems_heap_greedy.c (modified) * cpukit/libcsupport/src/rtems_heap_null_extend.c (modified) * cpukit/libcsupport/src/rtems_mkdir.c (modified) * cpukit/libcsupport/src/rtems_put_char.c (modified) * cpukit/libcsupport/src/rtems_putc.c (modified) * cpukit/libcsupport/src/rtemscalloc.c (modified) * cpukit/libcsupport/src/setgroups.c (modified) * cpukit/libcsupport/src/sup_fs_check_permissions.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path_generic.c (modified) * cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c (modified) * cpukit/libcsupport/src/sup_fs_location.c (modified) * cpukit/libcsupport/src/sup_fs_mount_iterate.c (modified) * cpukit/libcsupport/src/sup_fs_next_token.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libcsupport/src/uenvgetgroups.c (modified) * cpukit/libcsupport/src/vprintk.c (modified) * cpukit/libfs/src/defaults/default_are_nodes_equal.c (modified) * cpukit/libfs/src/defaults/default_clone.c (modified) * cpukit/libfs/src/defaults/default_eval_path.c (modified) * cpukit/libfs/src/defaults/default_fsync_success.c (modified) * cpukit/libfs/src/defaults/default_ftruncate_directory.c (modified) * cpukit/libfs/src/defaults/default_handlers.c (modified) * cpukit/libfs/src/defaults/default_kqfilter.c (modified) * cpukit/libfs/src/defaults/default_lock_and_unlock.c (modified) * cpukit/libfs/src/defaults/default_lseek_directory.c (modified) * cpukit/libfs/src/defaults/default_lseek_file.c (modified) * cpukit/libfs/src/defaults/default_ops.c (modified) * cpukit/libfs/src/defaults/default_poll.c (modified) * cpukit/libfs/src/defaults/default_readv.c (modified) * cpukit/libfs/src/defaults/default_writev.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_conv.c (modified) * cpukit/libfs/src/dosfs/msdos_conv_default.c (modified) * cpukit/libfs/src/dosfs/msdos_conv_utf8.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/ftpfs/ftpfs.c (modified) * cpukit/libfs/src/ftpfs/tftpDriver.c (modified) * cpukit/libfs/src/ftpfs/tftp_driver.h (modified) * cpukit/libfs/src/ftpfs/tftpfs.c (modified) * cpukit/libfs/src/imfs/imfs_add_node.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_eval_devfs.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_make_linfile.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_node.c (modified) * cpukit/libfs/src/imfs/imfs_node_destroy_default.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/jffs2/include/linux/kernel-rtems.h (modified) * cpukit/libfs/src/jffs2/src/compr.c (modified) * cpukit/libfs/src/jffs2/src/dir-rtems.c (modified) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/jffs2/src/os-rtems.h (modified) * cpukit/libfs/src/jffs2/src/rtems-jffs2-config.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libi2c/libi2c.c (modified) * cpukit/libmisc/cpuuse/cpuinforeport.c (modified) * cpukit/libmisc/devnull/devzero.c (modified) * cpukit/libmisc/shell/login_check.c (modified) * cpukit/libmisc/shell/login_prompt.c (modified) * cpukit/libmisc/shell/main_blkstats.c (modified) * cpukit/libmisc/shell/main_cmdchmod.c (modified) * cpukit/libmisc/shell/main_cmdchown.c (modified) * cpukit/libmisc/shell/main_cmdls.c (modified) * cpukit/libmisc/shell/main_cpuinfo.c (modified) * cpukit/libmisc/shell/main_i2cdetect.c (modified) * cpukit/libmisc/shell/main_i2cget.c (modified) * cpukit/libmisc/shell/main_i2cset.c (modified) * cpukit/libmisc/shell/main_lsof.c (modified) * cpukit/libmisc/shell/main_profreport.c (modified) * cpukit/libmisc/shell/main_rtc.c (modified) * cpukit/libmisc/shell/main_spi.c (modified) * cpukit/libmisc/shell/shell-wait-for-input.c (modified) * cpukit/libmisc/untar/untar_tgz.c (modified) * cpukit/libstdthreads/cnd.c (modified) * cpukit/libstdthreads/mtx.c (modified) * cpukit/libtest/t-test-busy-tick.c (modified) * cpukit/libtest/t-test-busy.c (modified) * cpukit/libtest/t-test-checks-eno.c (modified) * cpukit/libtest/t-test-checks-psx.c (modified) * cpukit/libtest/t-test-checks.c (modified) * cpukit/libtest/t-test-hash-sha256.c (modified) * cpukit/libtest/t-test-interrupt.c (modified) * cpukit/libtest/t-test-rtems-context.c (modified) * cpukit/libtest/t-test-rtems-fds.c (modified) * cpukit/libtest/t-test-rtems-heap.c (modified) * cpukit/libtest/t-test-rtems-measure.c (modified) * cpukit/libtest/t-test-rtems-memory.c (modified) * cpukit/libtest/t-test-rtems-objs.c (modified) * cpukit/libtest/t-test-rtems-posix-keys.c (modified) * cpukit/libtest/t-test-rtems.c (modified) * cpukit/libtest/t-test-rtems.h (modified) * cpukit/libtest/t-test-scheduler.c (modified) * cpukit/libtest/t-test-thread-switch.c (modified) * cpukit/libtest/t-test-time.c (modified) * cpukit/libtest/t-test.c (modified) * cpukit/libtest/testbeginend.c (modified) * cpukit/libtest/testbusy.c (modified) * cpukit/libtest/testextension.c (modified) * cpukit/libtest/testgcovbspreset.c (modified) * cpukit/libtest/testgcovcpufatalhalt.c (modified) * cpukit/libtest/testgcovdumpinfo.c (modified) * cpukit/libtest/testparallel.c (modified) * cpukit/libtest/testrun.c (modified) * cpukit/libtrace/record/record-client.c (modified) * cpukit/libtrace/record/record-dump-base64.c (modified) * cpukit/libtrace/record/record-dump-fatal.c (modified) * cpukit/libtrace/record/record-dump-zbase64.c (modified) * cpukit/libtrace/record/record-dump-zfatal.c (modified) * cpukit/libtrace/record/record-dump.c (modified) * cpukit/libtrace/record/record-server.c (modified) * cpukit/libtrace/record/record-stream-header.c (modified) * cpukit/libtrace/record/record-sysinit.c (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record-userext.c (modified) * cpukit/libtrace/record/record-util.c (modified) * cpukit/libtrace/record/record.c (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keydelete.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/posix/src/keyzerokvp.c (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueueconfig.c (modified) * cpukit/posix/src/pbarrierdestroy.c (modified) * cpukit/posix/src/pbarrierinit.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/posix/src/psignalconfig.c (modified) * cpukit/posix/src/pspindestroy.c (modified) * cpukit/posix/src/pspininit.c (modified) * cpukit/posix/src/pspinlock.c (modified) * cpukit/posix/src/pspinunlock.c (modified) * cpukit/posix/src/psxsemaphore.c (modified) * cpukit/posix/src/psxsemaphoreconfig.c (modified) * cpukit/posix/src/psxtimerconfig.c (modified) * cpukit/posix/src/pthreadconfig.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetnamenp.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadsetnamenp.c (modified) * cpukit/posix/src/pthreadsetschedprio.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/setcancelstate.c (modified) * cpukit/posix/src/setcanceltype.c (modified) * cpukit/posix/src/shm.c (modified) * cpukit/posix/src/shmconfig.c (modified) * cpukit/posix/src/shmops.c (modified) * cpukit/posix/src/testcancel.c (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/barrierident.c (modified) * cpukit/rtems/src/clockgettickssinceboot.c (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/getapiconfig.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemondelete.c (modified) * cpukit/rtems/src/ratemongetstatistics.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/rtemsmaxprio.c (modified) * cpukit/rtems/src/rtemsnametoid.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetmaxprio.c (modified) * cpukit/rtems/src/schedulergetprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessormax.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (modified) * cpukit/rtems/src/schedulermapfromposix.c (modified) * cpukit/rtems/src/schedulermaptoposix.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/rtems/src/statustext.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/taskconstructuser.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/taskexit.c (modified) * cpukit/rtems/src/taskgetpriority.c (modified) * cpukit/rtems/src/taskgetscheduler.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitdefault.c (modified) * cpukit/rtems/src/taskiterate.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/rtems/src/workspacegreedy.c (modified) * cpukit/sapi/src/chainappendnotify.c (modified) * cpukit/sapi/src/chaingetnotify.c (modified) * cpukit/sapi/src/chaingetwait.c (modified) * cpukit/sapi/src/chainprependnotify.c (modified) * cpukit/sapi/src/chainprotected.c (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * cpukit/sapi/src/delaynano.c (modified) * cpukit/sapi/src/delayticks.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/extensionident.c (modified) * cpukit/sapi/src/fatalsrctext.c (modified) * cpukit/sapi/src/getbuildlabel.c (modified) * cpukit/sapi/src/getconfigmax.c (modified) * cpukit/sapi/src/getcopyrightnotice.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/sapi/src/iodefault.c (modified) * cpukit/sapi/src/ioregisterdriver.c (modified) * cpukit/sapi/src/panic.c (modified) * cpukit/sapi/src/profilingiterate.c (modified) * cpukit/sapi/src/profilingreportxml.c (modified) * cpukit/sapi/src/rbheap.c (modified) * cpukit/sapi/src/sysinitverbose.c (modified) * cpukit/sapi/src/tcsimpleinstall.c (modified) * cpukit/score/cpu/aarch64/include/rtems/score/aarch64-system-registers.h (modified) * cpukit/score/cpu/arm/__aeabi_read_tp.c (modified) * cpukit/score/cpu/arm/__tls_get_addr.c (modified) * cpukit/score/cpu/arm/aarch32-psma-init-default.c (modified) * cpukit/score/cpu/arm/aarch32-psma-init.c (modified) * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) * cpukit/score/cpu/arm/arm-exception-default.c (modified) * cpukit/score/cpu/arm/arm-exception-frame-print.c (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (modified) * cpukit/score/cpu/arm/armv4-sync-synchronize.c (modified) * cpukit/score/cpu/arm/armv7-thread-idle.c (modified) * cpukit/score/cpu/arm/armv7m-exception-default.c (modified) * cpukit/score/cpu/arm/armv7m-initialize.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) * cpukit/score/cpu/arm/include/rtems/score/aarch32-pmsa.h (modified) * cpukit/score/cpu/arm/include/rtems/score/aarch32-system-registers.h (modified) * cpukit/score/cpu/arm/include/rtems/score/armv4.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/bfin/bfin-exception-frame-print.c (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/lm32/lm32-exception-frame-print.c (modified) * cpukit/score/cpu/m68k/__m68k_read_tp.c (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/m68k/m68k-exception-frame-print.c (modified) * cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h (modified) * cpukit/score/cpu/nios2/nios2-context-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-context-switch.S (modified) * cpukit/score/cpu/nios2/nios2-context-validate.S (modified) * cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S (modified) * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-exception-frame-print.c (modified) * cpukit/score/cpu/nios2/nios2-fatal-halt.c (modified) * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) * cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c (modified) * cpukit/score/cpu/nios2/nios2-isr-set-level.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-add-region.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-configuration.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-descriptor.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-reset.c (modified) * cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c (modified) * cpukit/score/cpu/no_cpu/cpucounterfrequency.c (modified) * cpukit/score/cpu/no_cpu/cpucounterread.c (modified) * cpukit/score/cpu/no_cpu/cpuidle.c (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/riscv/riscv-context-validate.S (modified) * cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S (modified) * cpukit/score/cpu/riscv/riscv-counter.S (modified) * cpukit/score/cpu/riscv/riscv-exception-frame-print.c (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) * cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sh/sh-exception-frame-print.c (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h (modified) * cpukit/score/cpu/sparc/sparc-bad-trap.S (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) * cpukit/score/cpu/sparc/sparc-counter-asm.S (modified) * cpukit/score/cpu/sparc/sparc-exception-frame-print.c (modified) * cpukit/score/cpu/sparc/sparc-isr-handler.S (modified) * cpukit/score/cpu/sparc/syscall.S (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c (modified) * cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/v850/v850-exception-frame-print.c (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/src/allocatormutex.c (modified) * cpukit/score/src/chainnodecount.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/configstackspacesize.c (modified) * cpukit/score/src/coremsgwkspace.c (modified) * cpukit/score/src/coretodcheck.c (modified) * cpukit/score/src/debugisthreaddispatchingallowed.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/gcovdumpinfo.c (modified) * cpukit/score/src/gcovdumpinfobase64.c (modified) * cpukit/score/src/gcovinfoset.c (modified) * cpukit/score/src/hash.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapgreedy.c (modified) * cpukit/score/src/heapiterate.c (modified) * cpukit/score/src/heapnoextend.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * cpukit/score/src/iobase64.c (modified) * cpukit/score/src/ioprintf.c (modified) * cpukit/score/src/iorelax.c (modified) * cpukit/score/src/isrisinprogress.c (modified) * cpukit/score/src/isrvectortable.c (modified) * cpukit/score/src/libatomic.c (modified) * cpukit/score/src/memoryallocate.c (modified) * cpukit/score/src/memorydirtyfreeareas.c (modified) * cpukit/score/src/memoryfill.c (modified) * cpukit/score/src/memorynoinit.c (modified) * cpukit/score/src/memoryzerobeforeuse.c (modified) * cpukit/score/src/memoryzerofreeareas.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/objectactivecount.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectallocatenone.c (modified) * cpukit/score/src/objectallocatestatic.c (modified) * cpukit/score/src/objectallocateunlimited.c (modified) * cpukit/score/src/objectfreenothing.c (modified) * cpukit/score/src/objectfreestatic.c (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/once.c (modified) * cpukit/score/src/opt_compat.h (modified) * cpukit/score/src/opt_ffclock.h (modified) * cpukit/score/src/opt_ntp.h (modified) * cpukit/score/src/percpuasm.c (modified) * cpukit/score/src/percpudata.c (modified) * cpukit/score/src/percpujobs.c (modified) * cpukit/score/src/percpustatewait.c (modified) * cpukit/score/src/pheapiterate.c (modified) * cpukit/score/src/processormaskcopy.c (modified) * cpukit/score/src/profilingisrentryexit.c (modified) * cpukit/score/src/profilingsmplock.c (modified) * cpukit/score/src/rbtreeappend.c (modified) * cpukit/score/src/rbtreeiterate.c (modified) * cpukit/score/src/rbtreemax.c (modified) * cpukit/score/src/rbtreemin.c (modified) * cpukit/score/src/rbtreenext.c (modified) * cpukit/score/src/rbtreepostorder.c (modified) * cpukit/score/src/rbtreeprepend.c (modified) * cpukit/score/src/rbtreeprev.c (modified) * cpukit/score/src/rbtreereplace.c (modified) * cpukit/score/src/sched.c (modified) * cpukit/score/src/schedulerdefaultmakecleansticky.c (modified) * cpukit/score/src/schedulerdefaultmappriority.c (modified) * cpukit/score/src/schedulerdefaultpinunpin.c (modified) * cpukit/score/src/schedulerdefaultpinunpindonothing.c (modified) * cpukit/score/src/schedulerdefaultschedule.c (modified) * cpukit/score/src/schedulerdefaultstartidle.c (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulergetaffinity.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersmp.c (modified) * cpukit/score/src/schedulersmpstartidle.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/smpbarrierwait.c (modified) * cpukit/score/src/smpbroadcastaction.c (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) * cpukit/score/src/smpothercastaction.c (modified) * cpukit/score/src/smpsynchronize.c (modified) * cpukit/score/src/smpunicastaction.c (modified) * cpukit/score/src/stackallocator.c (modified) * cpukit/score/src/stackallocatorforidlewkspace.c (modified) * cpukit/score/src/stackallocatorfree.c (modified) * cpukit/score/src/stackallocatorinit.c (modified) * cpukit/score/src/threadallocateunlimited.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadentryadaptoridle.c (modified) * cpukit/score/src/threadentryadaptornumeric.c (modified) * cpukit/score/src/threadentryadaptorpointer.c (modified) * cpukit/score/src/threadexhausttimeslice.c (modified) * cpukit/score/src/threadgetcputimeused.c (modified) * cpukit/score/src/threadgetcputimeusedafterreset.c (modified) * cpukit/score/src/threadidledefault.c (modified) * cpukit/score/src/threaditerate.c (modified) * cpukit/score/src/threadname.c (modified) * cpukit/score/src/threadplaindispatch.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqextract.c (modified) * cpukit/score/src/threadqgetnameandid.c (modified) * cpukit/score/src/threadqops.c (modified) * cpukit/score/src/threadqtimeout.c (modified) * cpukit/score/src/threadresettimeslice.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadscheduler.c (modified) * cpukit/score/src/threadselfid.c (modified) * cpukit/score/src/threadunpin.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) * cpukit/score/src/threadyield.c (modified) * cpukit/score/src/tlsallocsize.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogtick.c (modified) * cpukit/score/src/watchdogtimeslicedefault.c (modified) * cpukit/score/src/wkspace.c (modified) * cpukit/score/src/wkspaceisunifieddefault.c (modified) * cpukit/score/src/wkspacemallocinitdefault.c (modified) * cpukit/score/src/wkspacemallocinitunified.c (modified) * cpukit/score/src/wkstringduplicate.c (modified) * cpukit/telnetd/check_passwd.c (modified) * cpukit/telnetd/telnetd-init.c (modified) * cpukit/telnetd/telnetd.c (modified) * spec/build/bsps/aarch64/xilinx-versal/optconminor.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/abi.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/objsmp.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/opta9periphclk.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optcachedata.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optcacheinst.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optclkfastidle.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optconcfg.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optconuart1.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optfdten.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/opti2cspeed.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optnoi2c.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optresetvec.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optuartbaud.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optuartirq.yml (modified) * spec/build/bsps/arm/atsam/abi.yml (modified) * spec/build/bsps/arm/atsam/bspatsam.yml (modified) * spec/build/bsps/arm/atsam/linkcmds.yml (modified) * spec/build/bsps/arm/atsam/optchgclksram.yml (modified) * spec/build/bsps/arm/atsam/optchip.yml (modified) * spec/build/bsps/arm/atsam/optconbaud.yml (modified) * spec/build/bsps/arm/atsam/optconidx.yml (modified) * spec/build/bsps/arm/atsam/optconirq.yml (modified) * spec/build/bsps/arm/atsam/optcontype.yml (modified) * spec/build/bsps/arm/atsam/optmck.yml (modified) * spec/build/bsps/arm/atsam/optnocachesz.yml (modified) * spec/build/bsps/arm/atsam/optnullsz.yml (modified) * spec/build/bsps/arm/atsam/optoscmain.yml (modified) * spec/build/bsps/arm/atsam/optqspiflashsz.yml (modified) * spec/build/bsps/arm/atsam/optsdram.yml (modified) * spec/build/bsps/arm/atsam/opttcmsz.yml (modified) * spec/build/bsps/arm/atsam/optusextal.yml (modified) * spec/build/bsps/arm/atsam/tstatsamv.yml (modified) * spec/build/bsps/arm/beagle/abi.yml (modified) * spec/build/bsps/arm/beagle/bspboardorig.yml (modified) * spec/build/bsps/arm/beagle/bspboardxm.yml (modified) * spec/build/bsps/arm/beagle/bspboneblack.yml (modified) * spec/build/bsps/arm/beagle/bspbonewhite.yml (modified) * spec/build/bsps/arm/beagle/grp.yml (modified) * spec/build/bsps/arm/beagle/obj.yml (modified) * spec/build/bsps/arm/beagle/optam335x.yml (modified) * spec/build/bsps/arm/beagle/optconbaud.yml (modified) * spec/build/bsps/arm/beagle/optconpoll.yml (modified) * spec/build/bsps/arm/beagle/optdebug.yml (modified) * spec/build/bsps/arm/beagle/optdm3730.yml (modified) * spec/build/bsps/arm/csb336/abi.yml (modified) * spec/build/bsps/arm/csb336/bspcsb336.yml (modified) * spec/build/bsps/arm/csb336/start.yml (modified) * spec/build/bsps/arm/csb337/abi.yml (modified) * spec/build/bsps/arm/csb337/bspcsb337.yml (modified) * spec/build/bsps/arm/csb337/bspcsb637.yml (modified) * spec/build/bsps/arm/csb337/bspkit637v6.yml (modified) * spec/build/bsps/arm/csb337/grp.yml (modified) * spec/build/bsps/arm/csb337/obj.yml (modified) * spec/build/bsps/arm/csb337/objlcd.yml (modified) * spec/build/bsps/arm/csb337/objumon.yml (modified) * spec/build/bsps/arm/csb337/objumoncon.yml (modified) * spec/build/bsps/arm/csb337/optcsb637.yml (modified) * spec/build/bsps/arm/csb337/optenlcd.yml (modified) * spec/build/bsps/arm/csb337/optenumon.yml (modified) * spec/build/bsps/arm/csb337/optenumoncon.yml (modified) * spec/build/bsps/arm/csb337/optenusart0.yml (modified) * spec/build/bsps/arm/csb337/optenusart1.yml (modified) * spec/build/bsps/arm/csb337/optenusart2.yml (modified) * spec/build/bsps/arm/csb337/optenusart3.yml (modified) * spec/build/bsps/arm/csb337/start.yml (modified) * spec/build/bsps/arm/edb7312/abi.yml (modified) * spec/build/bsps/arm/edb7312/bspedb7312.yml (modified) * spec/build/bsps/arm/edb7312/optskyeye.yml (modified) * spec/build/bsps/arm/edb7312/start.yml (modified) * spec/build/bsps/arm/fvp/abi.yml (modified) * spec/build/bsps/arm/fvp/bspcortexr52.yml (modified) * spec/build/bsps/arm/fvp/grp.yml (modified) * spec/build/bsps/arm/fvp/linkcmds.yml (modified) * spec/build/bsps/arm/fvp/obj.yml (modified) * spec/build/bsps/arm/fvp/objsmp.yml (modified) * spec/build/bsps/arm/fvp/optdevbegin.yml (modified) * spec/build/bsps/arm/fvp/optdevsize.yml (modified) * spec/build/bsps/arm/fvp/optdrambegin.yml (modified) * spec/build/bsps/arm/fvp/optdramsize.yml (modified) * spec/build/bsps/arm/fvp/optnullsize.yml (modified) * spec/build/bsps/arm/grp.yml (modified) * spec/build/bsps/arm/gumstix/abi.yml (modified) * spec/build/bsps/arm/gumstix/bspgumstix.yml (modified) * spec/build/bsps/arm/gumstix/optskyeye.yml (modified) * spec/build/bsps/arm/gumstix/start.yml (modified) * spec/build/bsps/arm/imx/abi.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/imx/objsmp.yml (modified) * spec/build/bsps/arm/imx/optcachedata.yml (modified) * spec/build/bsps/arm/imx/optcacheinst.yml (modified) * spec/build/bsps/arm/imx/optccmahb.yml (modified) * spec/build/bsps/arm/imx/optcmmecspi.yml (modified) * spec/build/bsps/arm/imx/optcmmipg.yml (modified) * spec/build/bsps/arm/imx/optcmmsdhci.yml (modified) * spec/build/bsps/arm/imx/optcmmuart.yml (modified) * spec/build/bsps/arm/imx/optconirq.yml (modified) * spec/build/bsps/arm/imx/optresetvec.yml (modified) * spec/build/bsps/arm/imxrt/abi.yml (modified) * spec/build/bsps/arm/imxrt/bspimxrt.yml (modified) * spec/build/bsps/arm/imxrt/linkcmds.yml (modified) * spec/build/bsps/arm/imxrt/linkcmdsmemory.yml (modified) * spec/build/bsps/arm/imxrt/optfsledmaemlm.yml (modified) * spec/build/bsps/arm/imxrt/optlinkcmds.yml (modified) * spec/build/bsps/arm/imxrt/optmemdtcmsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemextramnocachesz.yml (modified) * spec/build/bsps/arm/imxrt/optmemextramorigin.yml (modified) * spec/build/bsps/arm/imxrt/optmemextramsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemflashcfgsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemflashivtsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemflashorigin.yml (modified) * spec/build/bsps/arm/imxrt/optmemflashsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemitcmsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemnullsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemocramnocachesz.yml (modified) * spec/build/bsps/arm/imxrt/optmemocramsz.yml (modified) * spec/build/bsps/arm/lm3s69xx/abi.yml (modified) * spec/build/bsps/arm/lm3s69xx/bsplm3s3749.yml (modified) * spec/build/bsps/arm/lm3s69xx/bsplm3s6965.yml (modified) * spec/build/bsps/arm/lm3s69xx/bsplm4f120.yml (modified) * spec/build/bsps/arm/lm3s69xx/bspqemu.yml (modified) * spec/build/bsps/arm/lm3s69xx/grp.yml (modified) * spec/build/bsps/arm/lm3s69xx/obj.yml (modified) * spec/build/bsps/arm/lm3s69xx/optenuart0.yml (modified) * spec/build/bsps/arm/lm3s69xx/optenuart1.yml (modified) * spec/build/bsps/arm/lm3s69xx/optenuart2.yml (modified) * spec/build/bsps/arm/lm3s69xx/optgpioahb.yml (modified) * spec/build/bsps/arm/lm3s69xx/optgpionum.yml (modified) * spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml (modified) * spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml (modified) * spec/build/bsps/arm/lm3s69xx/optlm4f120.yml (modified) * spec/build/bsps/arm/lm3s69xx/optssiblks.yml (modified) * spec/build/bsps/arm/lm3s69xx/optssiclk.yml (modified) * spec/build/bsps/arm/lm3s69xx/optsysclk.yml (modified) * spec/build/bsps/arm/lm3s69xx/optuartbaud.yml (modified) * spec/build/bsps/arm/lm3s69xx/optudma.yml (modified) * spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml (modified) * spec/build/bsps/arm/lm3s69xx/tstlm3s3749.yml (modified) * spec/build/bsps/arm/lm3s69xx/tstlm3s6965.yml (modified) * spec/build/bsps/arm/lm3s69xx/tstlm4f120.yml (modified) * spec/build/bsps/arm/lpc176x/abi.yml (modified) * spec/build/bsps/arm/lpc176x/bsplpc1768mbed.yml (modified) * spec/build/bsps/arm/lpc176x/bsplpc1768mbedahbram.yml (modified) * spec/build/bsps/arm/lpc176x/bsplpc1768mbedahbrameth.yml (modified) * spec/build/bsps/arm/lpc176x/grp.yml (modified) * spec/build/bsps/arm/lpc176x/obj.yml (modified) * spec/build/bsps/arm/lpc176x/optcclk.yml (modified) * spec/build/bsps/arm/lpc176x/optconcfg.yml (modified) * spec/build/bsps/arm/lpc176x/optdmachn.yml (modified) * spec/build/bsps/arm/lpc176x/optlpc1768.yml (modified) * spec/build/bsps/arm/lpc176x/optmintskstksz.yml (modified) * spec/build/bsps/arm/lpc176x/optoscmain.yml (modified) * spec/build/bsps/arm/lpc176x/optoscrtc.yml (modified) * spec/build/bsps/arm/lpc176x/optpclkdiv.yml (modified) * spec/build/bsps/arm/lpc176x/optstopgpdma.yml (modified) * spec/build/bsps/arm/lpc176x/optstopusb.yml (modified) * spec/build/bsps/arm/lpc176x/optuart1cfg.yml (modified) * spec/build/bsps/arm/lpc176x/optuartbaud.yml (modified) * spec/build/bsps/arm/lpc176x/tstlpc1768mbed.yml (modified) * spec/build/bsps/arm/lpc176x/tstlpc1768mbedahbram.yml (modified) * spec/build/bsps/arm/lpc176x/tstlpc1768mbedahbrameth.yml (modified) * spec/build/bsps/arm/lpc24xx/abi.yml (modified) * spec/build/bsps/arm/lpc24xx/bsplpc17xxearam.yml (modified) * spec/build/bsps/arm/lpc24xx/bsplpc17xxearomint.yml (modified) * spec/build/bsps/arm/lpc24xx/bsplpc17xxplx800ram.yml (modified) * spec/build/bsps/arm/lpc24xx/bsplpc17xxplx800romint.yml (modified) * spec/build/bsps/arm/lpc24xx/bsplpc2362.yml (modified) * spec/build/bsps/arm/lpc24xx/bsplpc23xxtli800.yml (modified) * spec/build/bsps/arm/lpc24xx/bsplpc24xxea.yml (modified) * spec/build/bsps/arm/lpc24xx/bsplpc40xxearam.yml (modified) * spec/build/bsps/arm/lpc24xx/bsplpc40xxearomint.yml (modified) * spec/build/bsps/arm/lpc24xx/bspncsram.yml (modified) * spec/build/bsps/arm/lpc24xx/bspncsromext.yml (modified) * spec/build/bsps/arm/lpc24xx/bspncsromint.yml (modified) * spec/build/bsps/arm/lpc24xx/bspplx800ram.yml (modified) * spec/build/bsps/arm/lpc24xx/bspplx800romint.yml (modified) * spec/build/bsps/arm/lpc24xx/grp.yml (modified) * spec/build/bsps/arm/lpc24xx/obj.yml (modified) * spec/build/bsps/arm/lpc24xx/optcclk.yml (modified) * spec/build/bsps/arm/lpc24xx/optconcfg.yml (modified) * spec/build/bsps/arm/lpc24xx/optdmachn.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcis42s32800b.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcis42s32800d7.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcm29w160e.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcm29w320e70.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcsst39vf3201.yml (modified) * spec/build/bsps/arm/lpc24xx/optemctest.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcw9825g2jb75i.yml (modified) * spec/build/bsps/arm/lpc24xx/optethdownpin.yml (modified) * spec/build/bsps/arm/lpc24xx/optethrmii.yml (modified) * spec/build/bsps/arm/lpc24xx/optheapext.yml (modified) * spec/build/bsps/arm/lpc24xx/optoscmain.yml (modified) * spec/build/bsps/arm/lpc24xx/optoscrtc.yml (modified) * spec/build/bsps/arm/lpc24xx/optotgi2c.yml (modified) * spec/build/bsps/arm/lpc24xx/optpclkdiv.yml (modified) * spec/build/bsps/arm/lpc24xx/optresetvec.yml (modified) * spec/build/bsps/arm/lpc24xx/optstopeth.yml (modified) * spec/build/bsps/arm/lpc24xx/optstopgpdma.yml (modified) * spec/build/bsps/arm/lpc24xx/optstopusb.yml (modified) * spec/build/bsps/arm/lpc24xx/optuart1cfg.yml (modified) * spec/build/bsps/arm/lpc24xx/optuart2cfg.yml (modified) * spec/build/bsps/arm/lpc24xx/optuart3cfg.yml (modified) * spec/build/bsps/arm/lpc24xx/optuartbaud.yml (modified) * spec/build/bsps/arm/lpc24xx/tstlpc17xxearomint.yml (modified) * spec/build/bsps/arm/lpc24xx/tstlpc17xxplx800romint.yml (modified) * spec/build/bsps/arm/lpc24xx/tstlpc23xx.yml (modified) * spec/build/bsps/arm/lpc24xx/tstlpc40xxearomint.yml (modified) * spec/build/bsps/arm/lpc24xx/tstncsromint.yml (modified) * spec/build/bsps/arm/lpc24xx/tstplx800romint.yml (modified) * spec/build/bsps/arm/lpc32xx/abi.yml (modified) * spec/build/bsps/arm/lpc32xx/bsplpc32xxmzx.yml (modified) * spec/build/bsps/arm/lpc32xx/bspmzxstage1.yml (modified) * spec/build/bsps/arm/lpc32xx/bspmzxstage2.yml (modified) * spec/build/bsps/arm/lpc32xx/bspphycore.yml (modified) * spec/build/bsps/arm/lpc32xx/grp.yml (modified) * spec/build/bsps/arm/lpc32xx/obj.yml (modified) * spec/build/bsps/arm/lpc32xx/optdismmu.yml (modified) * spec/build/bsps/arm/lpc32xx/optdisroprot.yml (modified) * spec/build/bsps/arm/lpc32xx/optdisrwdc.yml (modified) * spec/build/bsps/arm/lpc32xx/optdmachn.yml (modified) * spec/build/bsps/arm/lpc32xx/optenwdgrst.yml (modified) * spec/build/bsps/arm/lpc32xx/optethrmii.yml (modified) * spec/build/bsps/arm/lpc32xx/optoscmain.yml (modified) * spec/build/bsps/arm/lpc32xx/optoscrtc.yml (modified) * spec/build/bsps/arm/lpc32xx/optotgi2c.yml (modified) * spec/build/bsps/arm/lpc32xx/optotgvbus.yml (modified) * spec/build/bsps/arm/lpc32xx/optperiphclk.yml (modified) * spec/build/bsps/arm/lpc32xx/optresetvec.yml (modified) * spec/build/bsps/arm/lpc32xx/optscratchsz.yml (modified) * spec/build/bsps/arm/lpc32xx/optstopeth.yml (modified) * spec/build/bsps/arm/lpc32xx/optstopgpdma.yml (modified) * spec/build/bsps/arm/lpc32xx/optstopusb.yml (modified) * spec/build/bsps/arm/lpc32xx/optu3clk.yml (modified) * spec/build/bsps/arm/lpc32xx/optu4clk.yml (modified) * spec/build/bsps/arm/lpc32xx/optu5clk.yml (modified) * spec/build/bsps/arm/lpc32xx/optu6clk.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart1baud.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart2baud.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart3baud.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart4baud.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart5baud.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart6baud.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart7baud.yml (modified) * spec/build/bsps/arm/lpc32xx/tstmzxstage1.yml (modified) * spec/build/bsps/arm/opta9periphclk.yml (modified) * spec/build/bsps/arm/optgiccpuif.yml (modified) * spec/build/bsps/arm/optgicdist.yml (modified) * spec/build/bsps/arm/optgicredist.yml (modified) * spec/build/bsps/arm/optgicspicount.yml (modified) * spec/build/bsps/arm/optgtfreq.yml (modified) * spec/build/bsps/arm/optgtsysbase.yml (modified) * spec/build/bsps/arm/optgtsyscntcr.yml (modified) * spec/build/bsps/arm/optgtusevirt.yml (modified) * spec/build/bsps/arm/optmmusmallpages.yml (modified) * spec/build/bsps/arm/optmmusz.yml (modified) * spec/build/bsps/arm/raspberrypi/abi.yml (modified) * spec/build/bsps/arm/raspberrypi/bspraspberrypi.yml (modified) * spec/build/bsps/arm/raspberrypi/bspraspberrypi2.yml (modified) * spec/build/bsps/arm/raspberrypi/grp.yml (modified) * spec/build/bsps/arm/raspberrypi/linkcmds.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/arm/raspberrypi/objsmp.yml (modified) * spec/build/bsps/arm/raspberrypi/opti2ciomode.yml (modified) * spec/build/bsps/arm/raspberrypi/optnocachelen.yml (modified) * spec/build/bsps/arm/raspberrypi/optramlen.yml (modified) * spec/build/bsps/arm/raspberrypi/optresetvec.yml (modified) * spec/build/bsps/arm/raspberrypi/optrpi2.yml (modified) * spec/build/bsps/arm/raspberrypi/optspiiomode.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/abi.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/objsmp.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/opta9periphclk.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/optcachedata.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/optcacheinst.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/optclkbootcpu.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/optclkfastidle.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/optresetvec.yml (modified) * spec/build/bsps/arm/rtl22xx/abi.yml (modified) * spec/build/bsps/arm/rtl22xx/bsprtl22xx.yml (modified) * spec/build/bsps/arm/rtl22xx/bsprtl22xxt.yml (modified) * spec/build/bsps/arm/rtl22xx/grp.yml (modified) * spec/build/bsps/arm/rtl22xx/obj.yml (modified) * spec/build/bsps/arm/rtl22xx/optskyeye.yml (modified) * spec/build/bsps/arm/rtl22xx/start.yml (modified) * spec/build/bsps/arm/rtl22xx/tstrtl22xx.yml (modified) * spec/build/bsps/arm/rtl22xx/tstrtl22xxt.yml (modified) * spec/build/bsps/arm/smdk2410/abi.yml (modified) * spec/build/bsps/arm/smdk2410/bspsmdk2410.yml (modified) * spec/build/bsps/arm/smdk2410/optcpus3c2410.yml (modified) * spec/build/bsps/arm/smdk2410/optskyeye.yml (modified) * spec/build/bsps/arm/smdk2410/start.yml (modified) * spec/build/bsps/arm/start.yml (modified) * spec/build/bsps/arm/stm32f4/abi.yml (modified) * spec/build/bsps/arm/stm32f4/bspstm32f105rc.yml (modified) * spec/build/bsps/arm/stm32f4/bspstm32f4.yml (modified) * spec/build/bsps/arm/stm32f4/grp.yml (modified) * spec/build/bsps/arm/stm32f4/obj.yml (modified) * spec/build/bsps/arm/stm32f4/opteni2c1.yml (modified) * spec/build/bsps/arm/stm32f4/opteni2c2.yml (modified) * spec/build/bsps/arm/stm32f4/optenuart4.yml (modified) * spec/build/bsps/arm/stm32f4/optenuart5.yml (modified) * spec/build/bsps/arm/stm32f4/optenusart1.yml (modified) * spec/build/bsps/arm/stm32f4/optenusart2.yml (modified) * spec/build/bsps/arm/stm32f4/optenusart3.yml (modified) * spec/build/bsps/arm/stm32f4/optenusart6.yml (modified) * spec/build/bsps/arm/stm32f4/optf10xxx.yml (modified) * spec/build/bsps/arm/stm32f4/optf4xxxx.yml (modified) * spec/build/bsps/arm/stm32f4/opthclk.yml (modified) * spec/build/bsps/arm/stm32f4/optoschse.yml (modified) * spec/build/bsps/arm/stm32f4/optpclk1.yml (modified) * spec/build/bsps/arm/stm32f4/optpclk2.yml (modified) * spec/build/bsps/arm/stm32f4/optsysclk.yml (modified) * spec/build/bsps/arm/stm32f4/optusartbaud.yml (modified) * spec/build/bsps/arm/stm32f4/tststm32f105rc.yml (modified) * spec/build/bsps/arm/stm32h7/abi.yml (modified) * spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml (modified) * spec/build/bsps/arm/stm32h7/bspstm32h7.yml (modified) * spec/build/bsps/arm/stm32h7/grp.yml (modified) * spec/build/bsps/arm/stm32h7/linkcmds.yml (modified) * spec/build/bsps/arm/stm32h7/linkcmdsflash.yml (modified) * spec/build/bsps/arm/stm32h7/linkcmdsflashsdram.yml (modified) * spec/build/bsps/arm/stm32h7/linkcmdsmemory.yml (modified) * spec/build/bsps/arm/stm32h7/linkcmdssdram.yml (modified) * spec/build/bsps/arm/stm32h7/linkcmdssram.yml (modified) * spec/build/bsps/arm/stm32h7/linkcmdssramsdram.yml (modified) * spec/build/bsps/arm/stm32h7/obj.yml (modified) * spec/build/bsps/arm/stm32h7/optenmpualign.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart4.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart5.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart7.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart8.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart9.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart1.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart10.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart2.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart3.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart6.yml (modified) * spec/build/bsps/arm/stm32h7/optethgpiobregs.yml (modified) * spec/build/bsps/arm/stm32h7/optethgpiogregs.yml (modified) * spec/build/bsps/arm/stm32h7/opthse.yml (modified) * spec/build/bsps/arm/stm32h7/optlinkcmds.yml (modified) * spec/build/bsps/arm/stm32h7/optmemdtcmsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemflashorigin.yml (modified) * spec/build/bsps/arm/stm32h7/optmemflashsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemitcmsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemnandsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemnorsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemnullsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemperipheralsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemquadspisz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsdram2sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsram1sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsram2sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsram3sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsram4sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsramaxisz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsrambackupsz.yml (modified) * spec/build/bsps/arm/stm32h7/optprintkinstance.yml (modified) * spec/build/bsps/arm/stm32h7/optusart1gpiopins.yml (modified) * spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml (modified) * spec/build/bsps/arm/stm32h7/optusart3gpiopins.yml (modified) * spec/build/bsps/arm/stm32h7/optusart3gpioregs.yml (modified) * spec/build/bsps/arm/stm32h7/optvariant.yml (modified) * spec/build/bsps/arm/stm32h7/tststm32h757i-eval.yml (modified) * spec/build/bsps/arm/tms570/abi.yml (modified) * spec/build/bsps/arm/tms570/bspls3137hdk.yml (modified) * spec/build/bsps/arm/tms570/bspls3137hdkintram.yml (modified) * spec/build/bsps/arm/tms570/bspls3137hdksdram.yml (modified) * spec/build/bsps/arm/tms570/bspls3137hdkwithloader.yml (modified) * spec/build/bsps/arm/tms570/grp.yml (modified) * spec/build/bsps/arm/tms570/obj.yml (modified) * spec/build/bsps/arm/tms570/objhwinit.yml (modified) * spec/build/bsps/arm/tms570/objnohwinit.yml (modified) * spec/build/bsps/arm/tms570/optcclk.yml (modified) * spec/build/bsps/arm/tms570/optconirq.yml (modified) * spec/build/bsps/arm/tms570/optlinkflags.yml (modified) * spec/build/bsps/arm/tms570/optlowinit.yml (modified) * spec/build/bsps/arm/tms570/optmintskstksz.yml (modified) * spec/build/bsps/arm/tms570/optoscmain.yml (modified) * spec/build/bsps/arm/tms570/optoscrtc.yml (modified) * spec/build/bsps/arm/tms570/optreginit.yml (modified) * spec/build/bsps/arm/tms570/optscibaud.yml (modified) * spec/build/bsps/arm/tms570/opttms570ls3137.yml (modified) * spec/build/bsps/arm/tms570/tstls3137hdkintram.yml (modified) * spec/build/bsps/arm/xen/abi.yml (modified) * spec/build/bsps/arm/xen/bspxen.yml (modified) * spec/build/bsps/arm/xen/linkcmds.yml (modified) * spec/build/bsps/arm/xen/optgentmunmask.yml (modified) * spec/build/bsps/arm/xen/optloadoff.yml (modified) * spec/build/bsps/arm/xen/optnocachelen.yml (modified) * spec/build/bsps/arm/xen/optramlen.yml (modified) * spec/build/bsps/arm/xen/optramori.yml (modified) * spec/build/bsps/arm/xen/optzimghdr.yml (modified) * spec/build/bsps/arm/xilinx-zynq/abi.yml (modified) * spec/build/bsps/arm/xilinx-zynq/bspqemu.yml (modified) * spec/build/bsps/arm/xilinx-zynq/bspzc702.yml (modified) * spec/build/bsps/arm/xilinx-zynq/bspzc706.yml (modified) * spec/build/bsps/arm/xilinx-zynq/bspzedboard.yml (modified) * spec/build/bsps/arm/xilinx-zynq/grp.yml (modified) * spec/build/bsps/arm/xilinx-zynq/linkcmds.yml (modified) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) * spec/build/bsps/arm/xilinx-zynq/objsmp.yml (modified) * spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optcachedata.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optcacheinst.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optclkcpu1x.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optclkfastidle.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optclkuart.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optconirq.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optint0len.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optint0ori.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optint1len.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optint1ori.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optnocachelen.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optramlen.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optramori.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optresetvec.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/abi.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/linkcmds.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/objsmp.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optcachedata.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optcacheinst.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optclkfastidle.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optclkuart.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optconirq.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optint0len.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optint0ori.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optint1len.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optint1ori.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optnocachelen.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optramlen.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optramori.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optresetvec.yml (modified) * spec/build/bsps/bfin/TLL6527M/abi.yml (modified) * spec/build/bsps/bfin/TLL6527M/bsptll6527m.yml (modified) * spec/build/bsps/bfin/TLL6527M/optconbaud.yml (modified) * spec/build/bsps/bfin/TLL6527M/optconirq.yml (modified) * spec/build/bsps/bfin/TLL6527M/optirqtbl.yml (modified) * spec/build/bsps/bfin/TLL6527M/optskyeye.yml (modified) * spec/build/bsps/bfin/TLL6527M/optuartdma.yml (modified) * spec/build/bsps/bfin/bf537Stamp/abi.yml (modified) * spec/build/bsps/bfin/bf537Stamp/bspbf537stamp.yml (modified) * spec/build/bsps/bfin/bf537Stamp/optconirq.yml (modified) * spec/build/bsps/bfin/bf537Stamp/optskyeye.yml (modified) * spec/build/bsps/bfin/bf537Stamp/start.yml (modified) * spec/build/bsps/bfin/eZKit533/abi.yml (modified) * spec/build/bsps/bfin/eZKit533/bspezkit533.yml (modified) * spec/build/bsps/bfin/eZKit533/optconirq.yml (modified) * spec/build/bsps/bfin/eZKit533/optskyeye.yml (modified) * spec/build/bsps/bfin/grp.yml (modified) * spec/build/bsps/bfin/obj.yml (modified) * spec/build/bsps/bfin/start.yml (modified) * spec/build/bsps/bspopts.yml (modified) * spec/build/bsps/dev/irq/objarmgicv3.yml (modified) * spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml (modified) * spec/build/bsps/dev/irq/optarmgic-icc-bpr1.yml (modified) * spec/build/bsps/dev/irq/optarmgic-icc-ctrl.yml (modified) * spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml (modified) * spec/build/bsps/dev/irq/optarmgic-icc-igrpen1.yml (modified) * spec/build/bsps/dev/irq/optarmgic-icc-pmr.yml (modified) * spec/build/bsps/dev/irq/optarmgic-icc-sre.yml (modified) * spec/build/bsps/grpmake.yml (modified) * spec/build/bsps/i386/grp.yml (modified) * spec/build/bsps/i386/pc386/abi.yml (modified) * spec/build/bsps/i386/pc386/bsppc386.yml (modified) * spec/build/bsps/i386/pc386/bsppc486.yml (modified) * spec/build/bsps/i386/pc386/bsppc586.yml (modified) * spec/build/bsps/i386/pc386/bsppc586sse.yml (modified) * spec/build/bsps/i386/pc386/bsppc686.yml (modified) * spec/build/bsps/i386/pc386/bsppcp4.yml (modified) * spec/build/bsps/i386/pc386/grp.yml (modified) * spec/build/bsps/i386/pc386/obj.yml (modified) * spec/build/bsps/i386/pc386/objide.yml (modified) * spec/build/bsps/i386/pc386/objsmp.yml (modified) * spec/build/bsps/i386/pc386/objsmpstart.yml (modified) * spec/build/bsps/i386/pc386/objvga.yml (modified) * spec/build/bsps/i386/pc386/objvgacir.yml (modified) * spec/build/bsps/i386/pc386/objvgavbe.yml (modified) * spec/build/bsps/i386/pc386/objvgavga.yml (modified) * spec/build/bsps/i386/pc386/optcirrus.yml (modified) * spec/build/bsps/i386/pc386/optclk8253.yml (modified) * spec/build/bsps/i386/pc386/optclktsc.yml (modified) * spec/build/bsps/i386/pc386/optconcom1.yml (modified) * spec/build/bsps/i386/pc386/optencom14.yml (modified) * spec/build/bsps/i386/pc386/optenide.yml (modified) * spec/build/bsps/i386/pc386/optenvga.yml (modified) * spec/build/bsps/i386/pc386/optgdbstub.yml (modified) * spec/build/bsps/i386/pc386/optgdtdesc.yml (modified) * spec/build/bsps/i386/pc386/optidepriifc.yml (modified) * spec/build/bsps/i386/pc386/optidesecifc.yml (modified) * spec/build/bsps/i386/pc386/optrelocaddr.yml (modified) * spec/build/bsps/i386/pc386/optvberm.yml (modified) * spec/build/bsps/i386/pc386/optvga.yml (modified) * spec/build/bsps/i386/pc386/optvideo80x50.yml (modified) * spec/build/bsps/i386/pc386/start.yml (modified) * spec/build/bsps/i386/pc386/tst-xfail-val.yml (modified) * spec/build/bsps/linkcmds.yml (modified) * spec/build/bsps/lm32/grp.yml (modified) * spec/build/bsps/lm32/lm32_evr/abi.yml (modified) * spec/build/bsps/lm32/lm32_evr/bspgdbsim.yml (modified) * spec/build/bsps/lm32/lm32_evr/bsplm32evr.yml (modified) * spec/build/bsps/lm32/lm32_evr/grp.yml (modified) * spec/build/bsps/lm32/lm32_evr/obj.yml (modified) * spec/build/bsps/lm32/lm32_evr/optsim.yml (modified) * spec/build/bsps/lm32/milkymist/abi.yml (modified) * spec/build/bsps/lm32/milkymist/bspmilkymist.yml (modified) * spec/build/bsps/lm32/milkymist/optsim.yml (modified) * spec/build/bsps/lm32/start.yml (modified) * spec/build/bsps/m68k/av5282/abi.yml (modified) * spec/build/bsps/m68k/av5282/bspav5282.yml (modified) * spec/build/bsps/m68k/av5282/start.yml (modified) * spec/build/bsps/m68k/csb360/abi.yml (modified) * spec/build/bsps/m68k/csb360/bspcsb360.yml (modified) * spec/build/bsps/m68k/csb360/start.yml (modified) * spec/build/bsps/m68k/gen68340/abi.yml (modified) * spec/build/bsps/m68k/gen68340/bspgen68340.yml (modified) * spec/build/bsps/m68k/gen68340/start.yml (modified) * spec/build/bsps/m68k/gen68360/abi.yml (modified) * spec/build/bsps/m68k/gen68360/bspgen68360.yml (modified) * spec/build/bsps/m68k/gen68360/bspgen68360040.yml (modified) * spec/build/bsps/m68k/gen68360/bsppgh360.yml (modified) * spec/build/bsps/m68k/gen68360/grp.yml (modified) * spec/build/bsps/m68k/gen68360/obj.yml (modified) * spec/build/bsps/m68k/gen68360/opt68360.yml (modified) * spec/build/bsps/m68k/gen68360/opt68360x040.yml (modified) * spec/build/bsps/m68k/gen68360/optpgh360.yml (modified) * spec/build/bsps/m68k/gen68360/start.yml (modified) * spec/build/bsps/m68k/genmcf548x/abi.yml (modified) * spec/build/bsps/m68k/genmcf548x/bspcobra5475.yml (modified) * spec/build/bsps/m68k/genmcf548x/bspm5484fireengine.yml (modified) * spec/build/bsps/m68k/genmcf548x/grp.yml (modified) * spec/build/bsps/m68k/genmcf548x/obj.yml (modified) * spec/build/bsps/m68k/genmcf548x/optcpuclk.yml (modified) * spec/build/bsps/m68k/genmcf548x/optdbug.yml (modified) * spec/build/bsps/m68k/genmcf548x/optlowinit.yml (modified) * spec/build/bsps/m68k/genmcf548x/optm5484fireengine.yml (modified) * spec/build/bsps/m68k/genmcf548x/start.yml (modified) * spec/build/bsps/m68k/grp.yml (modified) * spec/build/bsps/m68k/mcf5206elite/abi.yml (modified) * spec/build/bsps/m68k/mcf5206elite/bspmcf5206elite.yml (modified) * spec/build/bsps/m68k/mcf5206elite/start.yml (modified) * spec/build/bsps/m68k/mcf5206elite/tstmcf5206elite.yml (modified) * spec/build/bsps/m68k/mcf52235/abi.yml (modified) * spec/build/bsps/m68k/mcf52235/bspmcf52235.yml (modified) * spec/build/bsps/m68k/mcf52235/start.yml (modified) * spec/build/bsps/m68k/mcf52235/tstmcf52235.yml (modified) * spec/build/bsps/m68k/mcf5225x/abi.yml (modified) * spec/build/bsps/m68k/mcf5225x/bspmcf5225x.yml (modified) * spec/build/bsps/m68k/mcf5225x/start.yml (modified) * spec/build/bsps/m68k/mcf5225x/tstmcf5225x.yml (modified) * spec/build/bsps/m68k/mcf5235/abi.yml (modified) * spec/build/bsps/m68k/mcf5235/bspmcf5235.yml (modified) * spec/build/bsps/m68k/mcf5235/start.yml (modified) * spec/build/bsps/m68k/mcf5329/abi.yml (modified) * spec/build/bsps/m68k/mcf5329/bspmcf5329.yml (modified) * spec/build/bsps/m68k/mcf5329/start.yml (modified) * spec/build/bsps/m68k/mrm332/abi.yml (modified) * spec/build/bsps/m68k/mrm332/bspmrm332.yml (modified) * spec/build/bsps/m68k/mrm332/start.yml (modified) * spec/build/bsps/m68k/mrm332/tstmrm332.yml (modified) * spec/build/bsps/m68k/mvme147/abi.yml (modified) * spec/build/bsps/m68k/mvme147/bspmvme147.yml (modified) * spec/build/bsps/m68k/mvme147s/abi.yml (modified) * spec/build/bsps/m68k/mvme147s/bspmvme147s.yml (modified) * spec/build/bsps/m68k/mvme147s/objmpci.yml (modified) * spec/build/bsps/m68k/mvme162/abi.yml (modified) * spec/build/bsps/m68k/mvme162/bspmvme162.yml (modified) * spec/build/bsps/m68k/mvme162/bspmvme162lx.yml (modified) * spec/build/bsps/m68k/mvme162/grp.yml (modified) * spec/build/bsps/m68k/mvme162/obj.yml (modified) * spec/build/bsps/m68k/mvme162/tstmvme162.yml (modified) * spec/build/bsps/m68k/mvme162/tstmvme162lx.yml (modified) * spec/build/bsps/m68k/mvme167/abi.yml (modified) * spec/build/bsps/m68k/mvme167/bspmvme167.yml (modified) * spec/build/bsps/m68k/mvme167/optconminor.yml (modified) * spec/build/bsps/m68k/mvme167/optintlvl.yml (modified) * spec/build/bsps/m68k/mvme167/optiomode.yml (modified) * spec/build/bsps/m68k/mvme167/optmvme167.yml (modified) * spec/build/bsps/m68k/mvme167/optprintkminor.yml (modified) * spec/build/bsps/m68k/mvme167/optuseterm.yml (modified) * spec/build/bsps/m68k/objfpsp.yml (modified) * spec/build/bsps/m68k/start.yml (modified) * spec/build/bsps/m68k/uC5282/abi.yml (modified) * spec/build/bsps/m68k/uC5282/bspuc5282.yml (modified) * spec/build/bsps/m68k/uC5282/start.yml (modified) * spec/build/bsps/makebsp.yml (modified) * spec/build/bsps/makecustom.yml (modified) * spec/build/bsps/makeinc.yml (modified) * spec/build/bsps/maketarget.yml (modified) * spec/build/bsps/mips/csb350/abi.yml (modified) * spec/build/bsps/mips/csb350/bspcsb350.yml (modified) * spec/build/bsps/mips/csb350/start.yml (modified) * spec/build/bsps/mips/grp.yml (modified) * spec/build/bsps/mips/hurricane/abi.yml (modified) * spec/build/bsps/mips/hurricane/bsphurricane.yml (modified) * spec/build/bsps/mips/hurricane/optrm52xx.yml (modified) * spec/build/bsps/mips/hurricane/optusc320.yml (modified) * spec/build/bsps/mips/hurricane/start.yml (modified) * spec/build/bsps/mips/jmr3904/abi.yml (modified) * spec/build/bsps/mips/jmr3904/bspjmr3904.yml (modified) * spec/build/bsps/mips/jmr3904/start.yml (modified) * spec/build/bsps/mips/jmr3904/tstjmr3904.yml (modified) * spec/build/bsps/mips/malta/abi.yml (modified) * spec/build/bsps/mips/malta/bspmalta.yml (modified) * spec/build/bsps/mips/malta/start.yml (modified) * spec/build/bsps/mips/rbtx4925/abi.yml (modified) * spec/build/bsps/mips/rbtx4925/bsprbtx4925.yml (modified) * spec/build/bsps/mips/rbtx4925/opttx49xx.yml (modified) * spec/build/bsps/mips/rbtx4925/start.yml (modified) * spec/build/bsps/mips/rbtx4938/abi.yml (modified) * spec/build/bsps/mips/rbtx4938/bsprbtx4938.yml (modified) * spec/build/bsps/mips/rbtx4938/start.yml (modified) * spec/build/bsps/moxie/moxiesim/abi.yml (modified) * spec/build/bsps/moxie/moxiesim/bspmoxiesim.yml (modified) * spec/build/bsps/moxie/moxiesim/start.yml (modified) * spec/build/bsps/nios2/nios2_iss/abi.yml (modified) * spec/build/bsps/nios2/nios2_iss/bspnios2iss.yml (modified) * spec/build/bsps/nios2/nios2_iss/start.yml (modified) * spec/build/bsps/obj.yml (modified) * spec/build/bsps/objdevfsledma.yml (modified) * spec/build/bsps/objgrlib.yml (modified) * spec/build/bsps/objgrlibnosmp.yml (modified) * spec/build/bsps/objirq.yml (modified) * spec/build/bsps/objirqdflt.yml (modified) * spec/build/bsps/objmem.yml (modified) * spec/build/bsps/objmpci.yml (modified) * spec/build/bsps/objnosmp.yml (modified) * spec/build/bsps/optabi.yml (modified) * spec/build/bsps/optasflags.yml (modified) * spec/build/bsps/optbsp.yml (modified) * spec/build/bsps/optbspoptflags.yml (modified) * spec/build/bsps/optcachedata.yml (modified) * spec/build/bsps/optcacheinst.yml (modified) * spec/build/bsps/optcflags.yml (modified) * spec/build/bsps/optclkbootcpu.yml (modified) * spec/build/bsps/optclkfastidle.yml (modified) * spec/build/bsps/optconminor.yml (modified) * spec/build/bsps/optconsolebaud.yml (modified) * spec/build/bsps/optconsoleirq.yml (modified) * spec/build/bsps/optcpukitoptflags.yml (modified) * spec/build/bsps/optdtb.yml (modified) * spec/build/bsps/optfatalverb.yml (modified) * spec/build/bsps/optfdtcpyro.yml (modified) * spec/build/bsps/optfdtmxsz.yml (modified) * spec/build/bsps/optfdtro.yml (modified) * spec/build/bsps/optfdtuboot.yml (modified) * spec/build/bsps/optincludes.yml (modified) * spec/build/bsps/optldflags.yml (modified) * spec/build/bsps/optldflagsbsp.yml (modified) * spec/build/bsps/optlinkflags.yml (modified) * spec/build/bsps/optmake.yml (modified) * spec/build/bsps/optmakelegacy.yml (modified) * spec/build/bsps/opto0.yml (modified) * spec/build/bsps/opto1.yml (modified) * spec/build/bsps/opto2.yml (modified) * spec/build/bsps/optobjcopy.yml (modified) * spec/build/bsps/optog.yml (modified) * spec/build/bsps/optos.yml (modified) * spec/build/bsps/optprintexcpt.yml (modified) * spec/build/bsps/optreset.yml (modified) * spec/build/bsps/optresetkey.yml (modified) * spec/build/bsps/optstarthyp.yml (modified) * spec/build/bsps/opttestoptflags.yml (modified) * spec/build/bsps/or1k/generic_or1k/abi.yml (modified) * spec/build/bsps/or1k/generic_or1k/bspgenericor1k.yml (modified) * spec/build/bsps/or1k/generic_or1k/optperiphclk.yml (modified) * spec/build/bsps/or1k/generic_or1k/optresetvec.yml (modified) * spec/build/bsps/or1k/generic_or1k/start.yml (modified) * spec/build/bsps/or1k/grp.yml (modified) * spec/build/bsps/pkgconfig.yml (modified) * spec/build/bsps/powerpc/beatnik/abi.yml (modified) * spec/build/bsps/powerpc/beatnik/bspbeatnik.yml (modified) * spec/build/bsps/powerpc/beatnik/optsbrk.yml (modified) * spec/build/bsps/powerpc/crti.yml (modified) * spec/build/bsps/powerpc/crtn.yml (modified) * spec/build/bsps/powerpc/gen5200/abi.yml (modified) * spec/build/bsps/powerpc/gen5200/bspicecube.yml (modified) * spec/build/bsps/powerpc/gen5200/bsppm520cr825.yml (modified) * spec/build/bsps/powerpc/gen5200/bsppm520ze30.yml (modified) * spec/build/bsps/powerpc/gen5200/grp.yml (modified) * spec/build/bsps/powerpc/gen5200/obj.yml (modified) * spec/build/bsps/powerpc/gen5200/optbenchirq.yml (modified) * spec/build/bsps/powerpc/gen5200/optenirqnest.yml (modified) * spec/build/bsps/powerpc/gen5200/optgpiomsk.yml (modified) * spec/build/bsps/powerpc/gen5200/optgpioval.yml (modified) * spec/build/bsps/powerpc/gen5200/opticecub.yml (modified) * spec/build/bsps/powerpc/gen5200/optpm520cr825.yml (modified) * spec/build/bsps/powerpc/gen5200/optpm520ze30.yml (modified) * spec/build/bsps/powerpc/gen5200/optprintkminor.yml (modified) * spec/build/bsps/powerpc/gen5200/optpscgps.yml (modified) * spec/build/bsps/powerpc/gen5200/optsinglechar.yml (modified) * spec/build/bsps/powerpc/gen5200/optuartmsk.yml (modified) * spec/build/bsps/powerpc/gen5200/optuartstermirq.yml (modified) * spec/build/bsps/powerpc/gen5200/optuboot.yml (modified) * spec/build/bsps/powerpc/gen5200/start.yml (modified) * spec/build/bsps/powerpc/gen83xx/abi.yml (modified) * spec/build/bsps/powerpc/gen83xx/bspbruid.yml (modified) * spec/build/bsps/powerpc/gen83xx/bsphsccm01.yml (modified) * spec/build/bsps/powerpc/gen83xx/bspmpc8309som.yml (modified) * spec/build/bsps/powerpc/gen83xx/bspmpc8313erdb.yml (modified) * spec/build/bsps/powerpc/gen83xx/bspmpc8349eamds.yml (modified) * spec/build/bsps/powerpc/gen83xx/grp.yml (modified) * spec/build/bsps/powerpc/gen83xx/obj.yml (modified) * spec/build/bsps/powerpc/gen83xx/optbruid.yml (modified) * spec/build/bsps/powerpc/gen83xx/optchiptype.yml (modified) * spec/build/bsps/powerpc/gen83xx/opthsccm01.yml (modified) * spec/build/bsps/powerpc/gen83xx/optirqnest.yml (modified) * spec/build/bsps/powerpc/gen83xx/optmpc8309som.yml (modified) * spec/build/bsps/powerpc/gen83xx/optmpc8313erdb.yml (modified) * spec/build/bsps/powerpc/gen83xx/optmpc8349eamds.yml (modified) * spec/build/bsps/powerpc/gen83xx/optnandcs0.yml (modified) * spec/build/bsps/powerpc/gen83xx/optnet0phy.yml (modified) * spec/build/bsps/powerpc/gen83xx/optuart2.yml (modified) * spec/build/bsps/powerpc/gen83xx/optuartirq.yml (modified) * spec/build/bsps/powerpc/gen83xx/optuboot.yml (modified) * spec/build/bsps/powerpc/gen83xx/optulpi.yml (modified) * spec/build/bsps/powerpc/gen83xx/start.yml (modified) * spec/build/bsps/powerpc/grp.yml (modified) * spec/build/bsps/powerpc/motld.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/abi.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/boot.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/bspmcp750.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/bspmtx603e.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/bspmvme2100.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/bspmvme2307.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/bspqemu.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/bspqemualtivec.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/grp.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/obj.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/optmpc603e.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/optmpc750.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/optmpc8240.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/optqemu.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/optsbrk.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/qemufakerom.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/abi.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/bspgwlcfm.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/bspmpc5566evb.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/bspmpc5643levb.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/bspmpc5668g.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/bspmpc5674fevb.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/bspphycorempc5554.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/grp.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optbootflg.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optcachewritethru.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optchipfam.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optchiptype.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optclkemios.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optclkpit.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optconbaud.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optconminor.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optearlystksz.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/opteepromname.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/opteeprompath.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optemiosprescal.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optenstartpro.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optesciirq.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optexcbooke.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optexcfixdhdlr.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optfmpllesyncr1.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optfmpllprediv.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optgwlcfm.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optirqtblsz.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optlowinit.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optmpc5566evb.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optmpc5674fevb.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optnullprot.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optphycorempc5554.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optrefclk.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc91111.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9111enaddr.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ibige.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218iled.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinirq.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinrst.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218irxchn.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218itxchn.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsysclk.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsysclkdiv.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/start.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/tstgwlcfm.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/tstmpc5643levb.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/abi.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/bspmpc8260ads.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/optconminor.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/optdisphandstat.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/optprintkminor.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/optuartsiomode.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/optuartsterm.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/start.yml (modified) * spec/build/bsps/powerpc/mvme3100/abi.yml (modified) * spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml (modified) * spec/build/bsps/powerpc/mvme3100/optsbrk.yml (modified) * spec/build/bsps/powerpc/mvme3100/start.yml (modified) * spec/build/bsps/powerpc/mvme5500/abi.yml (modified) * spec/build/bsps/powerpc/mvme5500/bspmvme5500.yml (modified) * spec/build/bsps/powerpc/mvme5500/optsbrk.yml (modified) * spec/build/bsps/powerpc/mvme5500/start.yml (modified) * spec/build/bsps/powerpc/obj.yml (modified) * spec/build/bsps/powerpc/objexc.yml (modified) * spec/build/bsps/powerpc/objmem.yml (modified) * spec/build/bsps/powerpc/objvme.yml (modified) * spec/build/bsps/powerpc/psim/abi.yml (modified) * spec/build/bsps/powerpc/psim/bsppsim.yml (modified) * spec/build/bsps/powerpc/psim/objmpci.yml (modified) * spec/build/bsps/powerpc/psim/optclkfastidle.yml (modified) * spec/build/bsps/powerpc/psim/optsbrk.yml (modified) * spec/build/bsps/powerpc/psim/optsprg.yml (modified) * spec/build/bsps/powerpc/psim/optvecbase.yml (modified) * spec/build/bsps/powerpc/psim/start.yml (modified) * spec/build/bsps/powerpc/qemuppc/abi.yml (modified) * spec/build/bsps/powerpc/qemuppc/bspqemuppc.yml (modified) * spec/build/bsps/powerpc/qemuppc/start.yml (modified) * spec/build/bsps/powerpc/qoriq/abi.yml (modified) * spec/build/bsps/powerpc/qoriq/bspcore0.yml (modified) * spec/build/bsps/powerpc/qoriq/bspcore1.yml (modified) * spec/build/bsps/powerpc/qoriq/bspe500.yml (modified) * spec/build/bsps/powerpc/qoriq/bspe650032.yml (modified) * spec/build/bsps/powerpc/qoriq/bspe650064.yml (modified) * spec/build/bsps/powerpc/qoriq/grp.yml (modified) * spec/build/bsps/powerpc/qoriq/obj.yml (modified) * spec/build/bsps/powerpc/qoriq/objsmp.yml (modified) * spec/build/bsps/powerpc/qoriq/optbucsr.yml (modified) * spec/build/bsps/powerpc/qoriq/optbusclkdiv.yml (modified) * spec/build/bsps/powerpc/qoriq/optcachealign.yml (modified) * spec/build/bsps/powerpc/qoriq/optcacheblktouch.yml (modified) * spec/build/bsps/powerpc/qoriq/optcachedatal1sz.yml (modified) * spec/build/bsps/powerpc/qoriq/optcachedatal2sz.yml (modified) * spec/build/bsps/powerpc/qoriq/optcacheinstl1sz.yml (modified) * spec/build/bsps/powerpc/qoriq/optcacheinstl2sz.yml (modified) * spec/build/bsps/powerpc/qoriq/optchipnum.yml (modified) * spec/build/bsps/powerpc/qoriq/optchipser.yml (modified) * spec/build/bsps/powerpc/qoriq/optclktmctr.yml (modified) * spec/build/bsps/powerpc/qoriq/optclktmr.yml (modified) * spec/build/bsps/powerpc/qoriq/optcpucnt.yml (modified) * spec/build/bsps/powerpc/qoriq/optetsec1phy.yml (modified) * spec/build/bsps/powerpc/qoriq/optetsec2phy.yml (modified) * spec/build/bsps/powerpc/qoriq/optetsec3phy.yml (modified) * spec/build/bsps/powerpc/qoriq/optexcbooke.yml (modified) * spec/build/bsps/powerpc/qoriq/optexcfixdhdlr.yml (modified) * spec/build/bsps/powerpc/qoriq/opthid0.yml (modified) * spec/build/bsps/powerpc/qoriq/opthyp.yml (modified) * spec/build/bsps/powerpc/qoriq/opthypguest.yml (modified) * spec/build/bsps/powerpc/qoriq/opticombegin.yml (modified) * spec/build/bsps/powerpc/qoriq/opticomsz.yml (modified) * spec/build/bsps/powerpc/qoriq/optmas7.yml (modified) * spec/build/bsps/powerpc/qoriq/optmsr.yml (modified) * spec/build/bsps/powerpc/qoriq/optspefscr.yml (modified) * spec/build/bsps/powerpc/qoriq/optthrdcnt.yml (modified) * spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml (modified) * spec/build/bsps/powerpc/qoriq/optuart0en.yml (modified) * spec/build/bsps/powerpc/qoriq/optuart1en.yml (modified) * spec/build/bsps/powerpc/qoriq/optuartbrg0en.yml (modified) * spec/build/bsps/powerpc/qoriq/optuartbrg1en.yml (modified) * spec/build/bsps/powerpc/qoriq/optuartbrgmas.yml (modified) * spec/build/bsps/powerpc/qoriq/optuartbrgpri.yml (modified) * spec/build/bsps/powerpc/qoriq/optuartbrgslv.yml (modified) * spec/build/bsps/powerpc/qoriq/optuartirq.yml (modified) * spec/build/bsps/powerpc/qoriq/start.yml (modified) * spec/build/bsps/powerpc/ss555/abi.yml (modified) * spec/build/bsps/powerpc/ss555/bspss555.yml (modified) * spec/build/bsps/powerpc/ss555/optconminor.yml (modified) * spec/build/bsps/powerpc/ss555/optprintkminor.yml (modified) * spec/build/bsps/powerpc/ss555/optuartsiomode.yml (modified) * spec/build/bsps/powerpc/ss555/optuartsterm.yml (modified) * spec/build/bsps/powerpc/ss555/optwdgtimeout.yml (modified) * spec/build/bsps/powerpc/ss555/start.yml (modified) * spec/build/bsps/powerpc/start.yml (modified) * spec/build/bsps/powerpc/t32mppc/abi.yml (modified) * spec/build/bsps/powerpc/t32mppc/bspt32mppc.yml (modified) * spec/build/bsps/powerpc/t32mppc/objsmp.yml (modified) * spec/build/bsps/powerpc/t32mppc/optexcbooke.yml (modified) * spec/build/bsps/powerpc/t32mppc/optexcfixdhdlr.yml (modified) * spec/build/bsps/powerpc/t32mppc/start.yml (modified) * spec/build/bsps/powerpc/tqm8xx/abi.yml (modified) * spec/build/bsps/powerpc/tqm8xx/bsppghplus.yml (modified) * spec/build/bsps/powerpc/tqm8xx/bspstk8xx.yml (modified) * spec/build/bsps/powerpc/tqm8xx/grp.yml (modified) * spec/build/bsps/powerpc/tqm8xx/obj.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconchn.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconscc1.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconscc2.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconscc3.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconscc4.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconsmc1.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconsmc2.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optnetfec.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optnetscc.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optprintkchn.yml (modified) * spec/build/bsps/powerpc/tqm8xx/start.yml (modified) * spec/build/bsps/powerpc/vecentry.yml (modified) * spec/build/bsps/powerpc/virtex/abi.yml (modified) * spec/build/bsps/powerpc/virtex/bspvirtex.yml (modified) * spec/build/bsps/powerpc/virtex/linkcmds.yml (modified) * spec/build/bsps/powerpc/virtex/optconirq.yml (modified) * spec/build/bsps/powerpc/virtex/optfastramlen.yml (modified) * spec/build/bsps/powerpc/virtex/optfastramorg.yml (modified) * spec/build/bsps/powerpc/virtex/optramlen.yml (modified) * spec/build/bsps/powerpc/virtex/optramorg.yml (modified) * spec/build/bsps/powerpc/virtex/optresetlen.yml (modified) * spec/build/bsps/powerpc/virtex/optresetorg.yml (modified) * spec/build/bsps/powerpc/virtex/optxparam.yml (modified) * spec/build/bsps/powerpc/virtex/start.yml (modified) * spec/build/bsps/powerpc/virtex4/abi.yml (modified) * spec/build/bsps/powerpc/virtex4/bspvirtex4.yml (modified) * spec/build/bsps/powerpc/virtex4/optppccachedata.yml (modified) * spec/build/bsps/powerpc/virtex4/optsprg.yml (modified) * spec/build/bsps/powerpc/virtex4/optvecbase.yml (modified) * spec/build/bsps/powerpc/virtex4/start.yml (modified) * spec/build/bsps/powerpc/virtex5/abi.yml (modified) * spec/build/bsps/powerpc/virtex5/bspvirtex5.yml (modified) * spec/build/bsps/powerpc/virtex5/optppccachedata.yml (modified) * spec/build/bsps/powerpc/virtex5/optsprg.yml (modified) * spec/build/bsps/powerpc/virtex5/optvecbase.yml (modified) * spec/build/bsps/powerpc/virtex5/start.yml (modified) * spec/build/bsps/riscv/griscv/abi.yml (modified) * spec/build/bsps/riscv/griscv/bspgriscv.yml (modified) * spec/build/bsps/riscv/griscv/bspgrv32i.yml (modified) * spec/build/bsps/riscv/griscv/bspgrv32im.yml (modified) * spec/build/bsps/riscv/griscv/bspgrv32imac.yml (modified) * spec/build/bsps/riscv/griscv/bspgrv32imafdc.yml (modified) * spec/build/bsps/riscv/griscv/grp.yml (modified) * spec/build/bsps/riscv/griscv/obj.yml (modified) * spec/build/bsps/riscv/griscv/objsmp.yml (modified) * spec/build/bsps/riscv/grp.yml (modified) * spec/build/bsps/riscv/linkcmds.yml (modified) * spec/build/bsps/riscv/linkcmdsbase.yml (modified) * spec/build/bsps/riscv/noel/abi.yml (modified) * spec/build/bsps/riscv/noel/bspnoel32im.yml (modified) * spec/build/bsps/riscv/noel/bspnoel32imafd.yml (modified) * spec/build/bsps/riscv/noel/bspnoel64imac.yml (modified) * spec/build/bsps/riscv/noel/bspnoel64imafd.yml (modified) * spec/build/bsps/riscv/noel/bspnoel64imafdc.yml (modified) * spec/build/bsps/riscv/noel/grp.yml (modified) * spec/build/bsps/riscv/noel/obj.yml (modified) * spec/build/bsps/riscv/noel/objsmp.yml (modified) * spec/build/bsps/riscv/optextirqmax.yml (modified) * spec/build/bsps/riscv/optrambegin.yml (modified) * spec/build/bsps/riscv/optramsize.yml (modified) * spec/build/bsps/riscv/riscv/abi.yml (modified) * spec/build/bsps/riscv/riscv/bspfrdme310arty.yml (modified) * spec/build/bsps/riscv/riscv/bspmpfs64imafdc.yml (modified) * spec/build/bsps/riscv/riscv/bsprv32i.yml (modified) * spec/build/bsps/riscv/riscv/bsprv32iac.yml (modified) * spec/build/bsps/riscv/riscv/bsprv32im.yml (modified) * spec/build/bsps/riscv/riscv/bsprv32imac.yml (modified) * spec/build/bsps/riscv/riscv/bsprv32imafc.yml (modified) * spec/build/bsps/riscv/riscv/bsprv32imafd.yml (modified) * spec/build/bsps/riscv/riscv/bsprv32imafdc.yml (modified) * spec/build/bsps/riscv/riscv/bsprv64imac.yml (modified) * spec/build/bsps/riscv/riscv/bsprv64imafd.yml (modified) * spec/build/bsps/riscv/riscv/bsprv64imafdc.yml (modified) * spec/build/bsps/riscv/riscv/grp.yml (modified) * spec/build/bsps/riscv/riscv/obj.yml (modified) * spec/build/bsps/riscv/riscv/objsmp.yml (modified) * spec/build/bsps/riscv/riscv/optfrdme310arty.yml (modified) * spec/build/bsps/riscv/riscv/opthtif.yml (modified) * spec/build/bsps/riscv/riscv/optmpfs.yml (modified) * spec/build/bsps/riscv/riscv/optns16550max.yml (modified) * spec/build/bsps/riscv/riscv/optsifiveuart.yml (modified) * spec/build/bsps/riscv/start.yml (modified) * spec/build/bsps/sh/gensh1/abi.yml (modified) * spec/build/bsps/sh/gensh1/bspgensh1.yml (modified) * spec/build/bsps/sh/gensh1/optcpuclk.yml (modified) * spec/build/bsps/sh/gensh1/optlowinit.yml (modified) * spec/build/bsps/sh/gensh1/start.yml (modified) * spec/build/bsps/sh/gensh1/tstgensh1.yml (modified) * spec/build/bsps/sh/gensh2/abi.yml (modified) * spec/build/bsps/sh/gensh2/bspgensh2.yml (modified) * spec/build/bsps/sh/gensh2/optcpuclk.yml (modified) * spec/build/bsps/sh/gensh2/optevb.yml (modified) * spec/build/bsps/sh/gensh2/optlowinit.yml (modified) * spec/build/bsps/sh/gensh2/start.yml (modified) * spec/build/bsps/sh/gensh2/tstgensh2.yml (modified) * spec/build/bsps/sh/gensh4/abi.yml (modified) * spec/build/bsps/sh/gensh4/bspgensh4.yml (modified) * spec/build/bsps/sh/gensh4/optcpuclk.yml (modified) * spec/build/bsps/sh/gensh4/optcpydata.yml (modified) * spec/build/bsps/sh/gensh4/optlowinit.yml (modified) * spec/build/bsps/sh/gensh4/start.yml (modified) * spec/build/bsps/sh/shsim/abi.yml (modified) * spec/build/bsps/sh/shsim/bspsimsh1.yml (modified) * spec/build/bsps/sh/shsim/bspsimsh2.yml (modified) * spec/build/bsps/sh/shsim/bspsimsh2e.yml (modified) * spec/build/bsps/sh/shsim/bspsimsh4.yml (modified) * spec/build/bsps/sh/shsim/grp.yml (modified) * spec/build/bsps/sh/shsim/obj.yml (modified) * spec/build/bsps/sh/shsim/optcpuclk.yml (modified) * spec/build/bsps/sh/shsim/optlowinit.yml (modified) * spec/build/bsps/sh/shsim/start.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh1.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2e.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh4.yml (modified) * spec/build/bsps/sparc/erc32/abi.yml (modified) * spec/build/bsps/sparc/erc32/bsperc32.yml (modified) * spec/build/bsps/sparc/erc32/objsmp.yml (modified) * spec/build/bsps/sparc/erc32/optconirq.yml (modified) * spec/build/bsps/sparc/erc32/optpwrdwnhlt.yml (modified) * spec/build/bsps/sparc/grp.yml (modified) * spec/build/bsps/sparc/leon2/abi.yml (modified) * spec/build/bsps/sparc/leon2/bspat697f.yml (modified) * spec/build/bsps/sparc/leon2/bspleon2.yml (modified) * spec/build/bsps/sparc/leon2/grp.yml (modified) * spec/build/bsps/sparc/leon2/obj.yml (modified) * spec/build/bsps/sparc/leon2/objsmp.yml (modified) * spec/build/bsps/sparc/leon2/optconirq.yml (modified) * spec/build/bsps/sparc/leon2/optpwrdwnhlt.yml (modified) * spec/build/bsps/sparc/leon3/abi.yml (modified) * spec/build/bsps/sparc/leon3/bspgr712rc.yml (modified) * spec/build/bsps/sparc/leon3/bspgr740.yml (modified) * spec/build/bsps/sparc/leon3/bspleon3.yml (modified) * spec/build/bsps/sparc/leon3/bsput699.yml (modified) * spec/build/bsps/sparc/leon3/bsput700.yml (modified) * spec/build/bsps/sparc/leon3/grp.yml (modified) * spec/build/bsps/sparc/leon3/obj.yml (modified) * spec/build/bsps/sparc/leon3/objmpci.yml (modified) * spec/build/bsps/sparc/leon3/objsmp.yml (modified) * spec/build/bsps/sparc/leon3/optconirq.yml (modified) * spec/build/bsps/sparc/leon3/optleon3smp.yml (modified) * spec/build/bsps/sparc/leon3/optpwrdwnhlt.yml (modified) * spec/build/bsps/sparc/objmem.yml (modified) * spec/build/bsps/sparc/start.yml (modified) * spec/build/bsps/sparc64/grp.yml (modified) * spec/build/bsps/sparc64/niagara/abi.yml (modified) * spec/build/bsps/sparc64/niagara/bspniagara.yml (modified) * spec/build/bsps/sparc64/start.yml (modified) * spec/build/bsps/sparc64/usiii/abi.yml (modified) * spec/build/bsps/sparc64/usiii/bspusiii.yml (modified) * spec/build/bsps/sparc64/usiii/optclkfastidle.yml (modified) * spec/build/bsps/tst-xfail-dl06.yml (modified) * spec/build/bsps/tst-xfail-intr.yml (modified) * spec/build/bsps/tst.yml (modified) * spec/build/bsps/tstnoiconv.yml (modified) * spec/build/bsps/tstnointrcrit.yml (modified) * spec/build/bsps/tstnojffs2.yml (modified) * spec/build/bsps/tstnolibdl.yml (modified) * spec/build/bsps/tstnorfs.yml (modified) * spec/build/bsps/tstreqtick.yml (modified) * spec/build/bsps/tstsmallmem.yml (modified) * spec/build/bsps/v850/gdbv850sim/abi.yml (modified) * spec/build/bsps/v850/gdbv850sim/bspv850e1sim.yml (modified) * spec/build/bsps/v850/gdbv850sim/bspv850e2sim.yml (modified) * spec/build/bsps/v850/gdbv850sim/bspv850e2v3sim.yml (modified) * spec/build/bsps/v850/gdbv850sim/bspv850esim.yml (modified) * spec/build/bsps/v850/gdbv850sim/bspv850essim.yml (modified) * spec/build/bsps/v850/gdbv850sim/bspv850sim.yml (modified) * spec/build/bsps/v850/gdbv850sim/grp.yml (modified) * spec/build/bsps/v850/gdbv850sim/obj.yml (modified) * spec/build/bsps/v850/gdbv850sim/start.yml (modified) * spec/build/bsps/x86_64/amd64/abi.yml (modified) * spec/build/bsps/x86_64/amd64/bspamd64.yml (modified) * spec/build/bsps/x86_64/amd64/bspamd64efi.yml (modified) * spec/build/bsps/x86_64/amd64/efiabi.yml (modified) * spec/build/bsps/x86_64/amd64/start.yml (modified) * spec/build/bsps/x86_64/grp.yml (modified) * spec/build/cpukit/cfgattrgetaff.yml (modified) * spec/build/cpukit/cfgattrgetgrdsz.yml (modified) * spec/build/cpukit/cfgattrgetstack.yml (modified) * spec/build/cpukit/cfgattrsetaff.yml (modified) * spec/build/cpukit/cfgattrsetgrdsz.yml (modified) * spec/build/cpukit/cfgattrsetstack.yml (modified) * spec/build/cpukit/cfgcfghdr.yml (modified) * spec/build/cpukit/cfgcleanupctx.yml (modified) * spec/build/cpukit/cfggetaff.yml (modified) * spec/build/cpukit/cfggetattr.yml (modified) * spec/build/cpukit/cfghdr.yml (modified) * spec/build/cpukit/cfginttypes.yml (modified) * spec/build/cpukit/cfgmemory.yml (modified) * spec/build/cpukit/cfgnewlib.yml (modified) * spec/build/cpukit/cfgpmtxceilcnst.yml (modified) * spec/build/cpukit/cfgprionode.yml (modified) * spec/build/cpukit/cfgpshdprmcnst.yml (modified) * spec/build/cpukit/cfgrcmd.yml (modified) * spec/build/cpukit/cfgsetaff.yml (modified) * spec/build/cpukit/cfgstdatomic.yml (modified) * spec/build/cpukit/cfgstdint.yml (modified) * spec/build/cpukit/cfgstdlib.yml (modified) * spec/build/cpukit/cfgstring.yml (modified) * spec/build/cpukit/cfgstrings.yml (modified) * spec/build/cpukit/cfgsysstat.yml (modified) * spec/build/cpukit/cfgsystypes.yml (modified) * spec/build/cpukit/cfgszoff.yml (modified) * spec/build/cpukit/cfgszsize.yml (modified) * spec/build/cpukit/cfgsztime.yml (modified) * spec/build/cpukit/cfgunistd.yml (modified) * spec/build/cpukit/cpuarm.yml (modified) * spec/build/cpukit/cpubfin.yml (modified) * spec/build/cpukit/cpui386.yml (modified) * spec/build/cpukit/cpulm32.yml (modified) * spec/build/cpukit/cpum68k.yml (modified) * spec/build/cpukit/cpumips.yml (modified) * spec/build/cpukit/cpumoxie.yml (modified) * spec/build/cpukit/cpunios2.yml (modified) * spec/build/cpukit/cpuopts.yml (modified) * spec/build/cpukit/cpuor1k.yml (modified) * spec/build/cpukit/cpupowerpc.yml (modified) * spec/build/cpukit/cpuriscv.yml (modified) * spec/build/cpukit/cpush.yml (modified) * spec/build/cpukit/cpusparc.yml (modified) * spec/build/cpukit/cpusparc64.yml (modified) * spec/build/cpukit/cpuv850.yml (modified) * spec/build/cpukit/cpux8664.yml (modified) * spec/build/cpukit/grp.yml (modified) * spec/build/cpukit/libdebugger.yml (modified) * spec/build/cpukit/libftpd.yml (modified) * spec/build/cpukit/libftpfs.yml (modified) * spec/build/cpukit/libjffs2.yml (modified) * spec/build/cpukit/libmghttpd.yml (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/librtemsdfltcfg.yml (modified) * spec/build/cpukit/librtemstest.yml (modified) * spec/build/cpukit/libtelnetd.yml (modified) * spec/build/cpukit/libtftpfs.yml (modified) * spec/build/cpukit/libz.yml (modified) * spec/build/cpukit/objdbgarm.yml (modified) * spec/build/cpukit/objdbgi386.yml (modified) * spec/build/cpukit/objdl.yml (modified) * spec/build/cpukit/objdlarm.yml (modified) * spec/build/cpukit/objdli386.yml (modified) * spec/build/cpukit/objdlm68k.yml (modified) * spec/build/cpukit/objdlmips.yml (modified) * spec/build/cpukit/objdlmoxie.yml (modified) * spec/build/cpukit/objdlpowerpc.yml (modified) * spec/build/cpukit/objdlsparc.yml (modified) * spec/build/cpukit/objdrvmgr.yml (modified) * spec/build/cpukit/objgnat.yml (modified) * spec/build/cpukit/objmpci.yml (modified) * spec/build/cpukit/objpci.yml (modified) * spec/build/cpukit/objpsxsgnl.yml (modified) * spec/build/cpukit/objshell.yml (modified) * spec/build/cpukit/objsmp.yml (modified) * spec/build/cpukit/objutf8.yml (modified) * spec/build/cpukit/optada.yml (modified) * spec/build/cpukit/optarflags.yml (modified) * spec/build/cpukit/optboothartid.yml (modified) * spec/build/cpukit/optbuildlabel.yml (modified) * spec/build/cpukit/optclang.yml (modified) * spec/build/cpukit/optcoverage.yml (modified) * spec/build/cpukit/optcoveragecflags.yml (modified) * spec/build/cpukit/optcoverageldflags.yml (modified) * spec/build/cpukit/optdebug.yml (modified) * spec/build/cpukit/optdrvmgr.yml (modified) * spec/build/cpukit/optgcc.yml (modified) * spec/build/cpukit/optincludes.yml (modified) * spec/build/cpukit/optinstall.yml (modified) * spec/build/cpukit/optlibdl.yml (modified) * spec/build/cpukit/optmpci.yml (modified) * spec/build/cpukit/optnewlib.yml (modified) * spec/build/cpukit/optnocoveragecflags.yml (modified) * spec/build/cpukit/optnocoverageldflags.yml (modified) * spec/build/cpukit/optparavirt.yml (modified) * spec/build/cpukit/optposix.yml (modified) * spec/build/cpukit/optprofiling.yml (modified) * spec/build/cpukit/optsmp.yml (modified) * spec/build/cpukit/optszblkcnt.yml (modified) * spec/build/cpukit/optszblksize.yml (modified) * spec/build/cpukit/optszmode.yml (modified) * spec/build/cpukit/optszoff.yml (modified) * spec/build/cpukit/optsztime.yml (modified) * spec/build/cpukit/optvermaj.yml (modified) * spec/build/cpukit/optvermin.yml (modified) * spec/build/cpukit/optverrev.yml (modified) * spec/build/cpukit/optversion.yml (modified) * spec/build/cpukit/optwarn.yml (modified) * spec/build/cpukit/optwarncc.yml (modified) * spec/build/cpukit/optwarncxx.yml (modified) * spec/build/cpukit/vckey.yml (modified) * spec/build/grp.yml (modified) * spec/build/testsuites/ada/adabasesp.yml (modified) * spec/build/testsuites/ada/adahello.yml (modified) * spec/build/testsuites/ada/adamp01node1.yml (modified) * spec/build/testsuites/ada/adamp01node2.yml (modified) * spec/build/testsuites/ada/adamp03node1.yml (modified) * spec/build/testsuites/ada/adamp03node2.yml (modified) * spec/build/testsuites/ada/adamp04node1.yml (modified) * spec/build/testsuites/ada/adamp04node2.yml (modified) * spec/build/testsuites/ada/adamp05node1.yml (modified) * spec/build/testsuites/ada/adamp05node2.yml (modified) * spec/build/testsuites/ada/adamp06node1.yml (modified) * spec/build/testsuites/ada/adamp06node2.yml (modified) * spec/build/testsuites/ada/adamp07node1.yml (modified) * spec/build/testsuites/ada/adamp07node2.yml (modified) * spec/build/testsuites/ada/adamp08node1.yml (modified) * spec/build/testsuites/ada/adamp08node2.yml (modified) * spec/build/testsuites/ada/adamp09node1.yml (modified) * spec/build/testsuites/ada/adamp09node2.yml (modified) * spec/build/testsuites/ada/adamp10node1.yml (modified) * spec/build/testsuites/ada/adamp10node2.yml (modified) * spec/build/testsuites/ada/adamp11node1.yml (modified) * spec/build/testsuites/ada/adamp11node2.yml (modified) * spec/build/testsuites/ada/adamp12node1.yml (modified) * spec/build/testsuites/ada/adamp12node2.yml (modified) * spec/build/testsuites/ada/adamp13node1.yml (modified) * spec/build/testsuites/ada/adamp13node2.yml (modified) * spec/build/testsuites/ada/adamp14node1.yml (modified) * spec/build/testsuites/ada/adamp14node2.yml (modified) * spec/build/testsuites/ada/adansecs.yml (modified) * spec/build/testsuites/ada/adasp01.yml (modified) * spec/build/testsuites/ada/adasp02.yml (modified) * spec/build/testsuites/ada/adasp03.yml (modified) * spec/build/testsuites/ada/adasp04.yml (modified) * spec/build/testsuites/ada/adasp05.yml (modified) * spec/build/testsuites/ada/adasp06.yml (modified) * spec/build/testsuites/ada/adasp07.yml (modified) * spec/build/testsuites/ada/adasp08.yml (modified) * spec/build/testsuites/ada/adasp09.yml (modified) * spec/build/testsuites/ada/adasp11.yml (modified) * spec/build/testsuites/ada/adasp12.yml (modified) * spec/build/testsuites/ada/adasp13.yml (modified) * spec/build/testsuites/ada/adasp14.yml (modified) * spec/build/testsuites/ada/adasp15.yml (modified) * spec/build/testsuites/ada/adasp16.yml (modified) * spec/build/testsuites/ada/adasp17.yml (modified) * spec/build/testsuites/ada/adasp19.yml (modified) * spec/build/testsuites/ada/adasp20.yml (modified) * spec/build/testsuites/ada/adasp22.yml (modified) * spec/build/testsuites/ada/adasp23.yml (modified) * spec/build/testsuites/ada/adasp24.yml (modified) * spec/build/testsuites/ada/adasp25.yml (modified) * spec/build/testsuites/ada/adaspatcb01.yml (modified) * spec/build/testsuites/ada/adaspname01.yml (modified) * spec/build/testsuites/ada/adaticker.yml (modified) * spec/build/testsuites/ada/adatm01.yml (modified) * spec/build/testsuites/ada/adatm02.yml (modified) * spec/build/testsuites/ada/adatm03.yml (modified) * spec/build/testsuites/ada/adatm04.yml (modified) * spec/build/testsuites/ada/adatm05.yml (modified) * spec/build/testsuites/ada/adatm06.yml (modified) * spec/build/testsuites/ada/adatm07.yml (modified) * spec/build/testsuites/ada/adatm08.yml (modified) * spec/build/testsuites/ada/adatm09.yml (modified) * spec/build/testsuites/ada/adatm10.yml (modified) * spec/build/testsuites/ada/adatm11.yml (modified) * spec/build/testsuites/ada/adatm12.yml (modified) * spec/build/testsuites/ada/adatm13.yml (modified) * spec/build/testsuites/ada/adatm14.yml (modified) * spec/build/testsuites/ada/adatm15.yml (modified) * spec/build/testsuites/ada/adatm16.yml (modified) * spec/build/testsuites/ada/adatm17.yml (modified) * spec/build/testsuites/ada/adatm18.yml (modified) * spec/build/testsuites/ada/adatm19.yml (modified) * spec/build/testsuites/ada/adatm20.yml (modified) * spec/build/testsuites/ada/adatm21.yml (modified) * spec/build/testsuites/ada/adatm22.yml (modified) * spec/build/testsuites/ada/adatm23.yml (modified) * spec/build/testsuites/ada/adatm24.yml (modified) * spec/build/testsuites/ada/adatm25.yml (modified) * spec/build/testsuites/ada/adatm28.yml (modified) * spec/build/testsuites/ada/adatm29.yml (modified) * spec/build/testsuites/ada/adatmck.yml (modified) * spec/build/testsuites/ada/grp.yml (modified) * spec/build/testsuites/ada/optgnat.yml (modified) * spec/build/testsuites/benchmarks/dhrystone.yml (modified) * spec/build/testsuites/benchmarks/grp.yml (modified) * spec/build/testsuites/benchmarks/linpack.yml (modified) * spec/build/testsuites/benchmarks/whetstone.yml (modified) * spec/build/testsuites/fstests/fsbdpart01.yml (modified) * spec/build/testsuites/fstests/fsclose01.yml (modified) * spec/build/testsuites/fstests/fsdosfsformat01.yml (modified) * spec/build/testsuites/fstests/fsdosfsname01.yml (modified) * spec/build/testsuites/fstests/fsdosfsname02.yml (modified) * spec/build/testsuites/fstests/fsdosfssync01.yml (modified) * spec/build/testsuites/fstests/fsdosfswrite01.yml (modified) * spec/build/testsuites/fstests/fsfseeko01.yml (modified) * spec/build/testsuites/fstests/fsimfsconfig01.yml (modified) * spec/build/testsuites/fstests/fsimfsconfig02.yml (modified) * spec/build/testsuites/fstests/fsimfsconfig03.yml (modified) * spec/build/testsuites/fstests/fsimfsgeneric01.yml (modified) * spec/build/testsuites/fstests/fsjffs2gc01.yml (modified) * spec/build/testsuites/fstests/fsnofs01.yml (modified) * spec/build/testsuites/fstests/fsrfsbitmap01.yml (modified) * spec/build/testsuites/fstests/fsrofs01.yml (modified) * spec/build/testsuites/fstests/grp.yml (modified) * spec/build/testsuites/fstests/imfsfserror.yml (modified) * spec/build/testsuites/fstests/imfsfslink.yml (modified) * spec/build/testsuites/fstests/imfsfspatheval.yml (modified) * spec/build/testsuites/fstests/imfsfspermission.yml (modified) * spec/build/testsuites/fstests/imfsfsrdwr.yml (modified) * spec/build/testsuites/fstests/imfsfsscandir01.yml (modified) * spec/build/testsuites/fstests/imfsfssymlink.yml (modified) * spec/build/testsuites/fstests/imfsfstime.yml (modified) * spec/build/testsuites/fstests/jffs2fserror.yml (modified) * spec/build/testsuites/fstests/jffs2fslink.yml (modified) * spec/build/testsuites/fstests/jffs2fspatheval.yml (modified) * spec/build/testsuites/fstests/jffs2fspermission.yml (modified) * spec/build/testsuites/fstests/jffs2fsrdwr.yml (modified) * spec/build/testsuites/fstests/jffs2fsscandir01.yml (modified) * spec/build/testsuites/fstests/jffs2fssymlink.yml (modified) * spec/build/testsuites/fstests/jffs2fstime.yml (modified) * spec/build/testsuites/fstests/libdosfs.yml (modified) * spec/build/testsuites/fstests/libimfs.yml (modified) * spec/build/testsuites/fstests/libjffs2.yml (modified) * spec/build/testsuites/fstests/libmimfs.yml (modified) * spec/build/testsuites/fstests/librfs.yml (modified) * spec/build/testsuites/fstests/mdosfsfserror.yml (modified) * spec/build/testsuites/fstests/mdosfsfspatheval.yml (modified) * spec/build/testsuites/fstests/mdosfsfsrdwr.yml (modified) * spec/build/testsuites/fstests/mdosfsfsscandir01.yml (modified) * spec/build/testsuites/fstests/mdosfsfsstatvfs.yml (modified) * spec/build/testsuites/fstests/mdosfsfstime.yml (modified) * spec/build/testsuites/fstests/mimfsfserror.yml (modified) * spec/build/testsuites/fstests/mimfsfslink.yml (modified) * spec/build/testsuites/fstests/mimfsfspatheval.yml (modified) * spec/build/testsuites/fstests/mimfsfspermission.yml (modified) * spec/build/testsuites/fstests/mimfsfsrdwr.yml (modified) * spec/build/testsuites/fstests/mimfsfsrename.yml (modified) * spec/build/testsuites/fstests/mimfsfsscandir01.yml (modified) * spec/build/testsuites/fstests/mimfsfssymlink.yml (modified) * spec/build/testsuites/fstests/mimfsfstime.yml (modified) * spec/build/testsuites/fstests/mrfsfserror.yml (modified) * spec/build/testsuites/fstests/mrfsfsfpathconf.yml (modified) * spec/build/testsuites/fstests/mrfsfslink.yml (modified) * spec/build/testsuites/fstests/mrfsfspatheval.yml (modified) * spec/build/testsuites/fstests/mrfsfspermission.yml (modified) * spec/build/testsuites/fstests/mrfsfsrdwr.yml (modified) * spec/build/testsuites/fstests/mrfsfsrename.yml (modified) * spec/build/testsuites/fstests/mrfsfsscandir01.yml (modified) * spec/build/testsuites/fstests/mrfsfssymlink.yml (modified) * spec/build/testsuites/fstests/mrfsfstime.yml (modified) * spec/build/testsuites/fstests/tftpfs.yml (modified) * spec/build/testsuites/grp.yml (modified) * spec/build/testsuites/libtests/block01.yml (modified) * spec/build/testsuites/libtests/block02.yml (modified) * spec/build/testsuites/libtests/block03.yml (modified) * spec/build/testsuites/libtests/block04.yml (modified) * spec/build/testsuites/libtests/block05.yml (modified) * spec/build/testsuites/libtests/block06.yml (modified) * spec/build/testsuites/libtests/block07.yml (modified) * spec/build/testsuites/libtests/block08.yml (modified) * spec/build/testsuites/libtests/block09.yml (modified) * spec/build/testsuites/libtests/block10.yml (modified) * spec/build/testsuites/libtests/block11.yml (modified) * spec/build/testsuites/libtests/block12.yml (modified) * spec/build/testsuites/libtests/block13.yml (modified) * spec/build/testsuites/libtests/block14.yml (modified) * spec/build/testsuites/libtests/block15.yml (modified) * spec/build/testsuites/libtests/block16.yml (modified) * spec/build/testsuites/libtests/block17.yml (modified) * spec/build/testsuites/libtests/bspcmdline01.yml (modified) * spec/build/testsuites/libtests/calloc.yml (modified) * spec/build/testsuites/libtests/capture01.yml (modified) * spec/build/testsuites/libtests/clockgettime.yml (modified) * spec/build/testsuites/libtests/close.yml (modified) * spec/build/testsuites/libtests/complex.yml (modified) * spec/build/testsuites/libtests/cpuuse.yml (modified) * spec/build/testsuites/libtests/crypt01.yml (modified) * spec/build/testsuites/libtests/debugger01.yml (modified) * spec/build/testsuites/libtests/defaultconfig01.yml (modified) * spec/build/testsuites/libtests/devfs01.yml (modified) * spec/build/testsuites/libtests/devfs04.yml (modified) * spec/build/testsuites/libtests/deviceio01.yml (modified) * spec/build/testsuites/libtests/devnullfatal01.yml (modified) * spec/build/testsuites/libtests/dl01.yml (modified) * spec/build/testsuites/libtests/dl02.yml (modified) * spec/build/testsuites/libtests/dl03.yml (modified) * spec/build/testsuites/libtests/dl04.yml (modified) * spec/build/testsuites/libtests/dl05.yml (modified) * spec/build/testsuites/libtests/dl06.yml (modified) * spec/build/testsuites/libtests/dl07.yml (modified) * spec/build/testsuites/libtests/dl08.yml (modified) * spec/build/testsuites/libtests/dl09.yml (modified) * spec/build/testsuites/libtests/dl10.yml (modified) * spec/build/testsuites/libtests/dumpbuf01.yml (modified) * spec/build/testsuites/libtests/dup2.yml (modified) * spec/build/testsuites/libtests/exit01.yml (modified) * spec/build/testsuites/libtests/exit02.yml (modified) * spec/build/testsuites/libtests/fcntl.yml (modified) * spec/build/testsuites/libtests/flashdisk01.yml (modified) * spec/build/testsuites/libtests/flockfile.yml (modified) * spec/build/testsuites/libtests/fork.yml (modified) * spec/build/testsuites/libtests/free.yml (modified) * spec/build/testsuites/libtests/fstat.yml (modified) * spec/build/testsuites/libtests/ftrylockfile.yml (modified) * spec/build/testsuites/libtests/funlockfile.yml (modified) * spec/build/testsuites/libtests/getentropy01.yml (modified) * spec/build/testsuites/libtests/getlogin.yml (modified) * spec/build/testsuites/libtests/getpwnam.yml (modified) * spec/build/testsuites/libtests/getpwuid.yml (modified) * spec/build/testsuites/libtests/gettimeofday.yml (modified) * spec/build/testsuites/libtests/getuid.yml (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/heapwalk.yml (modified) * spec/build/testsuites/libtests/htonl.yml (modified) * spec/build/testsuites/libtests/i2c01.yml (modified) * spec/build/testsuites/libtests/iconv.yml (modified) * spec/build/testsuites/libtests/iconvclose.yml (modified) * spec/build/testsuites/libtests/iconvopen.yml (modified) * spec/build/testsuites/libtests/irqs01.yml (modified) * spec/build/testsuites/libtests/kill.yml (modified) * spec/build/testsuites/libtests/libdl081.yml (modified) * spec/build/testsuites/libtests/libdl082.yml (modified) * spec/build/testsuites/libtests/libdl101.yml (modified) * spec/build/testsuites/libtests/libdl102.yml (modified) * spec/build/testsuites/libtests/libfdt01.yml (modified) * spec/build/testsuites/libtests/longjmp.yml (modified) * spec/build/testsuites/libtests/lseek.yml (modified) * spec/build/testsuites/libtests/lstat.yml (modified) * spec/build/testsuites/libtests/malloc.yml (modified) * spec/build/testsuites/libtests/malloc02.yml (modified) * spec/build/testsuites/libtests/malloc03.yml (modified) * spec/build/testsuites/libtests/malloc04.yml (modified) * spec/build/testsuites/libtests/malloctest.yml (modified) * spec/build/testsuites/libtests/math.yml (modified) * spec/build/testsuites/libtests/mathf.yml (modified) * spec/build/testsuites/libtests/mathl.yml (modified) * spec/build/testsuites/libtests/md501.yml (modified) * spec/build/testsuites/libtests/monitor.yml (modified) * spec/build/testsuites/libtests/monitor02.yml (modified) * spec/build/testsuites/libtests/mouse01.yml (modified) * spec/build/testsuites/libtests/nanosleep.yml (modified) * spec/build/testsuites/libtests/newlib01.yml (modified) * spec/build/testsuites/libtests/open.yml (modified) * spec/build/testsuites/libtests/optrtemsld.yml (modified) * spec/build/testsuites/libtests/optrtemssyms.yml (modified) * spec/build/testsuites/libtests/pipe.yml (modified) * spec/build/testsuites/libtests/posix.yml (modified) * spec/build/testsuites/libtests/posixmemalign.yml (modified) * spec/build/testsuites/libtests/putenvtest.yml (modified) * spec/build/testsuites/libtests/pwdgrp01.yml (modified) * spec/build/testsuites/libtests/pwdgrp02.yml (modified) * spec/build/testsuites/libtests/rbheap01.yml (modified) * spec/build/testsuites/libtests/read.yml (modified) * spec/build/testsuites/libtests/readv.yml (modified) * spec/build/testsuites/libtests/realloc.yml (modified) * spec/build/testsuites/libtests/record01.yml (modified) * spec/build/testsuites/libtests/record02.yml (modified) * spec/build/testsuites/libtests/rtmonuse.yml (modified) * spec/build/testsuites/libtests/setjmp.yml (modified) * spec/build/testsuites/libtests/sha.yml (modified) * spec/build/testsuites/libtests/shell01.yml (modified) * spec/build/testsuites/libtests/sigaddset.yml (modified) * spec/build/testsuites/libtests/sigdelset.yml (modified) * spec/build/testsuites/libtests/sigemptyset.yml (modified) * spec/build/testsuites/libtests/sigfillset.yml (modified) * spec/build/testsuites/libtests/sigismember.yml (modified) * spec/build/testsuites/libtests/sigprocmask.yml (modified) * spec/build/testsuites/libtests/sparsedisk01.yml (modified) * spec/build/testsuites/libtests/spi01.yml (modified) * spec/build/testsuites/libtests/stackchk.yml (modified) * spec/build/testsuites/libtests/stackchk01.yml (modified) * spec/build/testsuites/libtests/stat.yml (modified) * spec/build/testsuites/libtests/stringto01.yml (modified) * spec/build/testsuites/libtests/tar01.yml (modified) * spec/build/testsuites/libtests/tar02.yml (modified) * spec/build/testsuites/libtests/tar03.yml (modified) * spec/build/testsuites/libtests/termios.yml (modified) * spec/build/testsuites/libtests/termios01.yml (modified) * spec/build/testsuites/libtests/termios02.yml (modified) * spec/build/testsuites/libtests/termios03.yml (modified) * spec/build/testsuites/libtests/termios04.yml (modified) * spec/build/testsuites/libtests/termios05.yml (modified) * spec/build/testsuites/libtests/termios06.yml (modified) * spec/build/testsuites/libtests/termios07.yml (modified) * spec/build/testsuites/libtests/termios08.yml (modified) * spec/build/testsuites/libtests/termios09.yml (modified) * spec/build/testsuites/libtests/termios10.yml (modified) * spec/build/testsuites/libtests/termios11.yml (modified) * spec/build/testsuites/libtests/top.yml (modified) * spec/build/testsuites/libtests/ttest01.yml (modified) * spec/build/testsuites/libtests/ttest02.yml (modified) * spec/build/testsuites/libtests/tztest.yml (modified) * spec/build/testsuites/libtests/uid01.yml (modified) * spec/build/testsuites/libtests/unlink.yml (modified) * spec/build/testsuites/libtests/utf8proc01.yml (modified) * spec/build/testsuites/libtests/vfork.yml (modified) * spec/build/testsuites/libtests/wait.yml (modified) * spec/build/testsuites/libtests/waitpid.yml (modified) * spec/build/testsuites/libtests/write.yml (modified) * spec/build/testsuites/libtests/writev.yml (modified) * spec/build/testsuites/mptests/grp.yml (modified) * spec/build/testsuites/mptests/mp01.yml (modified) * spec/build/testsuites/mptests/mp01node1.yml (modified) * spec/build/testsuites/mptests/mp01node2.yml (modified) * spec/build/testsuites/mptests/mp03.yml (modified) * spec/build/testsuites/mptests/mp03node1.yml (modified) * spec/build/testsuites/mptests/mp03node2.yml (modified) * spec/build/testsuites/mptests/mp04.yml (modified) * spec/build/testsuites/mptests/mp04node1.yml (modified) * spec/build/testsuites/mptests/mp04node2.yml (modified) * spec/build/testsuites/mptests/mp05.yml (modified) * spec/build/testsuites/mptests/mp05node1.yml (modified) * spec/build/testsuites/mptests/mp05node2.yml (modified) * spec/build/testsuites/mptests/mp06.yml (modified) * spec/build/testsuites/mptests/mp06node1.yml (modified) * spec/build/testsuites/mptests/mp06node2.yml (modified) * spec/build/testsuites/mptests/mp07.yml (modified) * spec/build/testsuites/mptests/mp07node1.yml (modified) * spec/build/testsuites/mptests/mp07node2.yml (modified) * spec/build/testsuites/mptests/mp08.yml (modified) * spec/build/testsuites/mptests/mp08node1.yml (modified) * spec/build/testsuites/mptests/mp08node2.yml (modified) * spec/build/testsuites/mptests/mp09.yml (modified) * spec/build/testsuites/mptests/mp09node1.yml (modified) * spec/build/testsuites/mptests/mp09node2.yml (modified) * spec/build/testsuites/mptests/mp10.yml (modified) * spec/build/testsuites/mptests/mp10node1.yml (modified) * spec/build/testsuites/mptests/mp10node2.yml (modified) * spec/build/testsuites/mptests/mp11.yml (modified) * spec/build/testsuites/mptests/mp11node1.yml (modified) * spec/build/testsuites/mptests/mp11node2.yml (modified) * spec/build/testsuites/mptests/mp12.yml (modified) * spec/build/testsuites/mptests/mp12node1.yml (modified) * spec/build/testsuites/mptests/mp12node2.yml (modified) * spec/build/testsuites/mptests/mp13.yml (modified) * spec/build/testsuites/mptests/mp13node1.yml (modified) * spec/build/testsuites/mptests/mp13node2.yml (modified) * spec/build/testsuites/mptests/mp14.yml (modified) * spec/build/testsuites/mptests/mp14node1.yml (modified) * spec/build/testsuites/mptests/mp14node2.yml (modified) * spec/build/testsuites/optada.yml (modified) * spec/build/testsuites/optall.yml (modified) * spec/build/testsuites/optbenchmarks.yml (modified) * spec/build/testsuites/optbin2c.yml (modified) * spec/build/testsuites/optfs.yml (modified) * spec/build/testsuites/optgzip.yml (modified) * spec/build/testsuites/optlib.yml (modified) * spec/build/testsuites/optmp.yml (modified) * spec/build/testsuites/optpsx.yml (modified) * spec/build/testsuites/optpsxtm.yml (modified) * spec/build/testsuites/optrhs.yml (modified) * spec/build/testsuites/optsamples.yml (modified) * spec/build/testsuites/optsmp.yml (modified) * spec/build/testsuites/optsp.yml (modified) * spec/build/testsuites/opttm.yml (modified) * spec/build/testsuites/optunit.yml (modified) * spec/build/testsuites/optvalidation.yml (modified) * spec/build/testsuites/optverbosity.yml (modified) * spec/build/testsuites/optxz.yml (modified) * spec/build/testsuites/psxtests/grp.yml (modified) * spec/build/testsuites/psxtests/libpsxhdrs.yml (modified) * spec/build/testsuites/psxtests/psx01.yml (modified) * spec/build/testsuites/psxtests/psx02.yml (modified) * spec/build/testsuites/psxtests/psx03.yml (modified) * spec/build/testsuites/psxtests/psx04.yml (modified) * spec/build/testsuites/psxtests/psx05.yml (modified) * spec/build/testsuites/psxtests/psx06.yml (modified) * spec/build/testsuites/psxtests/psx07.yml (modified) * spec/build/testsuites/psxtests/psx08.yml (modified) * spec/build/testsuites/psxtests/psx09.yml (modified) * spec/build/testsuites/psxtests/psx10.yml (modified) * spec/build/testsuites/psxtests/psx11.yml (modified) * spec/build/testsuites/psxtests/psx12.yml (modified) * spec/build/testsuites/psxtests/psx13.yml (modified) * spec/build/testsuites/psxtests/psx14.yml (modified) * spec/build/testsuites/psxtests/psx15.yml (modified) * spec/build/testsuites/psxtests/psx16.yml (modified) * spec/build/testsuites/psxtests/psxaio01.yml (modified) * spec/build/testsuites/psxtests/psxaio02.yml (modified) * spec/build/testsuites/psxtests/psxaio03.yml (modified) * spec/build/testsuites/psxtests/psxalarm01.yml (modified) * spec/build/testsuites/psxtests/psxautoinit01.yml (modified) * spec/build/testsuites/psxtests/psxautoinit02.yml (modified) * spec/build/testsuites/psxtests/psxbarrier01.yml (modified) * spec/build/testsuites/psxtests/psxcancel.yml (modified) * spec/build/testsuites/psxtests/psxcancel01.yml (modified) * spec/build/testsuites/psxtests/psxchroot01.yml (modified) * spec/build/testsuites/psxtests/psxclassic01.yml (modified) * spec/build/testsuites/psxtests/psxcleanup.yml (modified) * spec/build/testsuites/psxtests/psxcleanup01.yml (modified) * spec/build/testsuites/psxtests/psxcleanup02.yml (modified) * spec/build/testsuites/psxtests/psxclock.yml (modified) * spec/build/testsuites/psxtests/psxclock01.yml (modified) * spec/build/testsuites/psxtests/psxclockrealtime01.yml (modified) * spec/build/testsuites/psxtests/psxconcurrency01.yml (modified) * spec/build/testsuites/psxtests/psxcond01.yml (modified) * spec/build/testsuites/psxtests/psxcond02.yml (modified) * spec/build/testsuites/psxtests/psxconfig01.yml (modified) * spec/build/testsuites/psxtests/psxdevctl01.yml (modified) * spec/build/testsuites/psxtests/psxeintrjoin.yml (modified) * spec/build/testsuites/psxtests/psxenosys.yml (modified) * spec/build/testsuites/psxtests/psxfatal01.yml (modified) * spec/build/testsuites/psxtests/psxfatal02.yml (modified) * spec/build/testsuites/psxtests/psxfatalsupport.yml (modified) * spec/build/testsuites/psxtests/psxfchx01.yml (modified) * spec/build/testsuites/psxtests/psxfenv01.yml (modified) * spec/build/testsuites/psxtests/psxfile01.yml (modified) * spec/build/testsuites/psxtests/psxfile02.yml (modified) * spec/build/testsuites/psxtests/psxfilelock01.yml (modified) * spec/build/testsuites/psxtests/psxgetattrnp01.yml (modified) * spec/build/testsuites/psxtests/psxgetrusage01.yml (modified) * spec/build/testsuites/psxtests/psxglobalcon01.yml (modified) * spec/build/testsuites/psxtests/psxglobalcon02.yml (modified) * spec/build/testsuites/psxtests/psxhdrs.yml (modified) * spec/build/testsuites/psxtests/psxid01.yml (modified) * spec/build/testsuites/psxtests/psximfs01.yml (modified) * spec/build/testsuites/psxtests/psximfs02.yml (modified) * spec/build/testsuites/psxtests/psxintrcritical01.yml (modified) * spec/build/testsuites/psxtests/psxinttypes01.yml (modified) * spec/build/testsuites/psxtests/psxitimer.yml (modified) * spec/build/testsuites/psxtests/psxkey01.yml (modified) * spec/build/testsuites/psxtests/psxkey02.yml (modified) * spec/build/testsuites/psxtests/psxkey03.yml (modified) * spec/build/testsuites/psxtests/psxkey04.yml (modified) * spec/build/testsuites/psxtests/psxkey05.yml (modified) * spec/build/testsuites/psxtests/psxkey06.yml (modified) * spec/build/testsuites/psxtests/psxkey07.yml (modified) * spec/build/testsuites/psxtests/psxkey08.yml (modified) * spec/build/testsuites/psxtests/psxkey09.yml (modified) * spec/build/testsuites/psxtests/psxkey10.yml (modified) * spec/build/testsuites/psxtests/psxmmap01.yml (modified) * spec/build/testsuites/psxtests/psxmount.yml (modified) * spec/build/testsuites/psxtests/psxmsgq01.yml (modified) * spec/build/testsuites/psxtests/psxmsgq02.yml (modified) * spec/build/testsuites/psxtests/psxmsgq03.yml (modified) * spec/build/testsuites/psxtests/psxmsgq04.yml (modified) * spec/build/testsuites/psxtests/psxmutexattr01.yml (modified) * spec/build/testsuites/psxtests/psxndbm01.yml (modified) * spec/build/testsuites/psxtests/psxobj01.yml (modified) * spec/build/testsuites/psxtests/psxonce01.yml (modified) * spec/build/testsuites/psxtests/psxpasswd01.yml (modified) * spec/build/testsuites/psxtests/psxpasswd02.yml (modified) * spec/build/testsuites/psxtests/psxpipe01.yml (modified) * spec/build/testsuites/psxtests/psxrdwrv.yml (modified) * spec/build/testsuites/psxtests/psxreaddir.yml (modified) * spec/build/testsuites/psxtests/psxrwlock01.yml (modified) * spec/build/testsuites/psxtests/psxsem01.yml (modified) * spec/build/testsuites/psxtests/psxshm01.yml (modified) * spec/build/testsuites/psxtests/psxshm02.yml (modified) * spec/build/testsuites/psxtests/psxsignal01.yml (modified) * spec/build/testsuites/psxtests/psxsignal02.yml (modified) * spec/build/testsuites/psxtests/psxsignal03.yml (modified) * spec/build/testsuites/psxtests/psxsignal04.yml (modified) * spec/build/testsuites/psxtests/psxsignal05.yml (modified) * spec/build/testsuites/psxtests/psxsignal06.yml (modified) * spec/build/testsuites/psxtests/psxsignal07.yml (modified) * spec/build/testsuites/psxtests/psxsignal08.yml (modified) * spec/build/testsuites/psxtests/psxspin01.yml (modified) * spec/build/testsuites/psxtests/psxstack01.yml (modified) * spec/build/testsuites/psxtests/psxstack02.yml (modified) * spec/build/testsuites/psxtests/psxstat.yml (modified) * spec/build/testsuites/psxtests/psxstrsignal01.yml (modified) * spec/build/testsuites/psxtests/psxsysconf.yml (modified) * spec/build/testsuites/psxtests/psxthreadname01.yml (modified) * spec/build/testsuites/psxtests/psxtime.yml (modified) * spec/build/testsuites/psxtests/psxtimer01.yml (modified) * spec/build/testsuites/psxtests/psxtimer02.yml (modified) * spec/build/testsuites/psxtests/psxtimes01.yml (modified) * spec/build/testsuites/psxtests/psxualarm.yml (modified) * spec/build/testsuites/psxtests/psxusleep.yml (modified) * spec/build/testsuites/psxtmtests/grp.yml (modified) * spec/build/testsuites/psxtmtests/psxtmbarrier01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmbarrier02.yml (modified) * spec/build/testsuites/psxtmtests/psxtmbarrier03.yml (modified) * spec/build/testsuites/psxtmtests/psxtmbarrier04.yml (modified) * spec/build/testsuites/psxtmtests/psxtmbarrierattr01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmcleanup01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmclocknanosleep01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmclocknanosleep02.yml (modified) * spec/build/testsuites/psxtmtests/psxtmclocknanosleep03.yml (modified) * spec/build/testsuites/psxtmtests/psxtmcond01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmcond02.yml (modified) * spec/build/testsuites/psxtmtests/psxtmcond03.yml (modified) * spec/build/testsuites/psxtmtests/psxtmcond04.yml (modified) * spec/build/testsuites/psxtmtests/psxtmcond05.yml (modified) * spec/build/testsuites/psxtmtests/psxtmcond06.yml (modified) * spec/build/testsuites/psxtmtests/psxtmcond07.yml (modified) * spec/build/testsuites/psxtmtests/psxtmcond08.yml (modified) * spec/build/testsuites/psxtmtests/psxtmcond09.yml (modified) * spec/build/testsuites/psxtmtests/psxtmcond10.yml (modified) * spec/build/testsuites/psxtmtests/psxtmkey01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmkey02.yml (modified) * spec/build/testsuites/psxtmtests/psxtmmq01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmmqrcvblock01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmmqrcvblock02.yml (modified) * spec/build/testsuites/psxtmtests/psxtmmutex01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmmutex02.yml (modified) * spec/build/testsuites/psxtmtests/psxtmmutex03.yml (modified) * spec/build/testsuites/psxtmtests/psxtmmutex04.yml (modified) * spec/build/testsuites/psxtmtests/psxtmmutex05.yml (modified) * spec/build/testsuites/psxtmtests/psxtmmutex06.yml (modified) * spec/build/testsuites/psxtmtests/psxtmmutex07.yml (modified) * spec/build/testsuites/psxtmtests/psxtmmutexattr01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmnanosleep01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmnanosleep02.yml (modified) * spec/build/testsuites/psxtmtests/psxtmonce01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmrwlock01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmrwlock02.yml (modified) * spec/build/testsuites/psxtmtests/psxtmrwlock03.yml (modified) * spec/build/testsuites/psxtmtests/psxtmrwlock04.yml (modified) * spec/build/testsuites/psxtmtests/psxtmrwlock05.yml (modified) * spec/build/testsuites/psxtmtests/psxtmrwlock06.yml (modified) * spec/build/testsuites/psxtmtests/psxtmrwlock07.yml (modified) * spec/build/testsuites/psxtmtests/psxtmsem01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmsem02.yml (modified) * spec/build/testsuites/psxtmtests/psxtmsem03.yml (modified) * spec/build/testsuites/psxtmtests/psxtmsem04.yml (modified) * spec/build/testsuites/psxtmtests/psxtmsem05.yml (modified) * spec/build/testsuites/psxtmtests/psxtmsleep01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmsleep02.yml (modified) * spec/build/testsuites/psxtmtests/psxtmthread01.yml (modified) * spec/build/testsuites/psxtmtests/psxtmthread02.yml (modified) * spec/build/testsuites/psxtmtests/psxtmthread03.yml (modified) * spec/build/testsuites/psxtmtests/psxtmthread04.yml (modified) * spec/build/testsuites/psxtmtests/psxtmthread05.yml (modified) * spec/build/testsuites/psxtmtests/psxtmthread06.yml (modified) * spec/build/testsuites/psxtmtests/psxtmthreadattr01.yml (modified) * spec/build/testsuites/rhealstone/grp.yml (modified) * spec/build/testsuites/rhealstone/rhdeadlockbrk.yml (modified) * spec/build/testsuites/rhealstone/rhilatency.yml (modified) * spec/build/testsuites/rhealstone/rhmlatency.yml (modified) * spec/build/testsuites/rhealstone/rhsemshuffle.yml (modified) * spec/build/testsuites/rhealstone/rhtaskpreempt.yml (modified) * spec/build/testsuites/rhealstone/rhtaskswitch.yml (modified) * spec/build/testsuites/samples/basempnode1.yml (modified) * spec/build/testsuites/samples/basempnode2.yml (modified) * spec/build/testsuites/samples/basesp.yml (modified) * spec/build/testsuites/samples/capture.yml (modified) * spec/build/testsuites/samples/cdtest.yml (modified) * spec/build/testsuites/samples/fileio.yml (modified) * spec/build/testsuites/samples/grp.yml (modified) * spec/build/testsuites/samples/hello.yml (modified) * spec/build/testsuites/samples/iostream.yml (modified) * spec/build/testsuites/samples/minimum.yml (modified) * spec/build/testsuites/samples/nsecs.yml (modified) * spec/build/testsuites/samples/paranoia.yml (modified) * spec/build/testsuites/samples/ticker.yml (modified) * spec/build/testsuites/samples/unlimited.yml (modified) * spec/build/testsuites/smptests/grp.yml (modified) * spec/build/testsuites/smptests/smp01.yml (modified) * spec/build/testsuites/smptests/smp02.yml (modified) * spec/build/testsuites/smptests/smp03.yml (modified) * spec/build/testsuites/smptests/smp05.yml (modified) * spec/build/testsuites/smptests/smp07.yml (modified) * spec/build/testsuites/smptests/smp08.yml (modified) * spec/build/testsuites/smptests/smp09.yml (modified) * spec/build/testsuites/smptests/smpaffinity01.yml (modified) * spec/build/testsuites/smptests/smpatomic01.yml (modified) * spec/build/testsuites/smptests/smpcache01.yml (modified) * spec/build/testsuites/smptests/smpcapture01.yml (modified) * spec/build/testsuites/smptests/smpcapture02.yml (modified) * spec/build/testsuites/smptests/smpclock01.yml (modified) * spec/build/testsuites/smptests/smpfatal01.yml (modified) * spec/build/testsuites/smptests/smpfatal02.yml (modified) * spec/build/testsuites/smptests/smpfatal03.yml (modified) * spec/build/testsuites/smptests/smpfatal04.yml (modified) * spec/build/testsuites/smptests/smpfatal05.yml (modified) * spec/build/testsuites/smptests/smpfatal06.yml (modified) * spec/build/testsuites/smptests/smpfatal08.yml (modified) * spec/build/testsuites/smptests/smpfatal09.yml (modified) * spec/build/testsuites/smptests/smpipi01.yml (modified) * spec/build/testsuites/smptests/smpirqs01.yml (modified) * spec/build/testsuites/smptests/smpload01.yml (modified) * spec/build/testsuites/smptests/smplock01.yml (modified) * spec/build/testsuites/smptests/smpmigration01.yml (modified) * spec/build/testsuites/smptests/smpmigration02.yml (modified) * spec/build/testsuites/smptests/smpmrsp01.yml (modified) * spec/build/testsuites/smptests/smpmulticast01.yml (modified) * spec/build/testsuites/smptests/smpmutex01.yml (modified) * spec/build/testsuites/smptests/smpmutex02.yml (modified) * spec/build/testsuites/smptests/smpopenmp01.yml (modified) * spec/build/testsuites/smptests/smppsxaffinity01.yml (modified) * spec/build/testsuites/smptests/smppsxaffinity02.yml (modified) * spec/build/testsuites/smptests/smppsxmutex01.yml (modified) * spec/build/testsuites/smptests/smppsxsignal01.yml (modified) * spec/build/testsuites/smptests/smpschedaffinity01.yml (modified) * spec/build/testsuites/smptests/smpschedaffinity02.yml (modified) * spec/build/testsuites/smptests/smpschedaffinity03.yml (modified) * spec/build/testsuites/smptests/smpschedaffinity04.yml (modified) * spec/build/testsuites/smptests/smpschedaffinity05.yml (modified) * spec/build/testsuites/smptests/smpschededf01.yml (modified) * spec/build/testsuites/smptests/smpschededf02.yml (modified) * spec/build/testsuites/smptests/smpschededf03.yml (modified) * spec/build/testsuites/smptests/smpschededf04.yml (modified) * spec/build/testsuites/smptests/smpschedsem01.yml (modified) * spec/build/testsuites/smptests/smpscheduler01.yml (modified) * spec/build/testsuites/smptests/smpscheduler02.yml (modified) * spec/build/testsuites/smptests/smpscheduler03.yml (modified) * spec/build/testsuites/smptests/smpscheduler04.yml (modified) * spec/build/testsuites/smptests/smpscheduler05.yml (modified) * spec/build/testsuites/smptests/smpscheduler06.yml (modified) * spec/build/testsuites/smptests/smpscheduler07.yml (modified) * spec/build/testsuites/smptests/smpsignal01.yml (modified) * spec/build/testsuites/smptests/smpstart01.yml (modified) * spec/build/testsuites/smptests/smpstrongapa01.yml (modified) * spec/build/testsuites/smptests/smpswitchextension01.yml (modified) * spec/build/testsuites/smptests/smpthreadlife01.yml (modified) * spec/build/testsuites/smptests/smpthreadpin01.yml (modified) * spec/build/testsuites/smptests/smpunsupported01.yml (modified) * spec/build/testsuites/smptests/smpwakeafter01.yml (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/libsplinkersets01.yml (modified) * spec/build/testsuites/sptests/sp01.yml (modified) * spec/build/testsuites/sptests/sp02.yml (modified) * spec/build/testsuites/sptests/sp03.yml (modified) * spec/build/testsuites/sptests/sp04.yml (modified) * spec/build/testsuites/sptests/sp05.yml (modified) * spec/build/testsuites/sptests/sp06.yml (modified) * spec/build/testsuites/sptests/sp07.yml (modified) * spec/build/testsuites/sptests/sp08.yml (modified) * spec/build/testsuites/sptests/sp11.yml (modified) * spec/build/testsuites/sptests/sp12.yml (modified) * spec/build/testsuites/sptests/sp13.yml (modified) * spec/build/testsuites/sptests/sp14.yml (modified) * spec/build/testsuites/sptests/sp15.yml (modified) * spec/build/testsuites/sptests/sp16.yml (modified) * spec/build/testsuites/sptests/sp17.yml (modified) * spec/build/testsuites/sptests/sp18.yml (modified) * spec/build/testsuites/sptests/sp19.yml (modified) * spec/build/testsuites/sptests/sp20.yml (modified) * spec/build/testsuites/sptests/sp2038.yml (modified) * spec/build/testsuites/sptests/sp21.yml (modified) * spec/build/testsuites/sptests/sp22.yml (modified) * spec/build/testsuites/sptests/sp23.yml (modified) * spec/build/testsuites/sptests/sp24.yml (modified) * spec/build/testsuites/sptests/sp25.yml (modified) * spec/build/testsuites/sptests/sp26.yml (modified) * spec/build/testsuites/sptests/sp27.yml (modified) * spec/build/testsuites/sptests/sp27a.yml (modified) * spec/build/testsuites/sptests/sp29.yml (modified) * spec/build/testsuites/sptests/sp30.yml (modified) * spec/build/testsuites/sptests/sp31.yml (modified) * spec/build/testsuites/sptests/sp32.yml (modified) * spec/build/testsuites/sptests/sp33.yml (modified) * spec/build/testsuites/sptests/sp34.yml (modified) * spec/build/testsuites/sptests/sp35.yml (modified) * spec/build/testsuites/sptests/sp36.yml (modified) * spec/build/testsuites/sptests/sp37.yml (modified) * spec/build/testsuites/sptests/sp38.yml (modified) * spec/build/testsuites/sptests/sp40.yml (modified) * spec/build/testsuites/sptests/sp41.yml (modified) * spec/build/testsuites/sptests/sp42.yml (modified) * spec/build/testsuites/sptests/sp43.yml (modified) * spec/build/testsuites/sptests/sp44.yml (modified) * spec/build/testsuites/sptests/sp45.yml (modified) * spec/build/testsuites/sptests/sp46.yml (modified) * spec/build/testsuites/sptests/sp47.yml (modified) * spec/build/testsuites/sptests/sp48.yml (modified) * spec/build/testsuites/sptests/sp49.yml (modified) * spec/build/testsuites/sptests/sp50.yml (modified) * spec/build/testsuites/sptests/sp51.yml (modified) * spec/build/testsuites/sptests/sp52.yml (modified) * spec/build/testsuites/sptests/sp53.yml (modified) * spec/build/testsuites/sptests/sp54.yml (modified) * spec/build/testsuites/sptests/sp55.yml (modified) * spec/build/testsuites/sptests/sp56.yml (modified) * spec/build/testsuites/sptests/sp57.yml (modified) * spec/build/testsuites/sptests/sp58.yml (modified) * spec/build/testsuites/sptests/sp59.yml (modified) * spec/build/testsuites/sptests/sp60.yml (modified) * spec/build/testsuites/sptests/sp62.yml (modified) * spec/build/testsuites/sptests/sp63.yml (modified) * spec/build/testsuites/sptests/sp64.yml (modified) * spec/build/testsuites/sptests/sp65.yml (modified) * spec/build/testsuites/sptests/sp66.yml (modified) * spec/build/testsuites/sptests/sp67.yml (modified) * spec/build/testsuites/sptests/sp68.yml (modified) * spec/build/testsuites/sptests/sp69.yml (modified) * spec/build/testsuites/sptests/sp70.yml (modified) * spec/build/testsuites/sptests/sp71.yml (modified) * spec/build/testsuites/sptests/sp72.yml (modified) * spec/build/testsuites/sptests/sp73.yml (modified) * spec/build/testsuites/sptests/sp74.yml (modified) * spec/build/testsuites/sptests/sp75.yml (modified) * spec/build/testsuites/sptests/sp76.yml (modified) * spec/build/testsuites/sptests/sp77.yml (modified) * spec/build/testsuites/sptests/spassoc01.yml (modified) * spec/build/testsuites/sptests/spatomic01.yml (modified) * spec/build/testsuites/sptests/spcache01.yml (modified) * spec/build/testsuites/sptests/spcbssched01.yml (modified) * spec/build/testsuites/sptests/spcbssched02.yml (modified) * spec/build/testsuites/sptests/spcbssched03.yml (modified) * spec/build/testsuites/sptests/spchain.yml (modified) * spec/build/testsuites/sptests/spclockerr01.yml (modified) * spec/build/testsuites/sptests/spclockerr02.yml (modified) * spec/build/testsuites/sptests/spclocktodhook01.yml (modified) * spec/build/testsuites/sptests/spconfig01.yml (modified) * spec/build/testsuites/sptests/spconfig02.yml (modified) * spec/build/testsuites/sptests/spconsole01.yml (modified) * spec/build/testsuites/sptests/spcontext01.yml (modified) * spec/build/testsuites/sptests/spcpucounter01.yml (modified) * spec/build/testsuites/sptests/spcpuset01.yml (modified) * spec/build/testsuites/sptests/spcxx01.yml (modified) * spec/build/testsuites/sptests/spedfsched01.yml (modified) * spec/build/testsuites/sptests/spedfsched02.yml (modified) * spec/build/testsuites/sptests/spedfsched03.yml (modified) * spec/build/testsuites/sptests/spedfsched04.yml (modified) * spec/build/testsuites/sptests/sperror01.yml (modified) * spec/build/testsuites/sptests/sperror02.yml (modified) * spec/build/testsuites/sptests/sperror03.yml (modified) * spec/build/testsuites/sptests/speventerr03.yml (modified) * spec/build/testsuites/sptests/speventsystem01.yml (modified) * spec/build/testsuites/sptests/speventtransient01.yml (modified) * spec/build/testsuites/sptests/spextensions01.yml (modified) * spec/build/testsuites/sptests/spfatal01.yml (modified) * spec/build/testsuites/sptests/spfatal03.yml (modified) * spec/build/testsuites/sptests/spfatal04.yml (modified) * spec/build/testsuites/sptests/spfatal05.yml (modified) * spec/build/testsuites/sptests/spfatal07.yml (modified) * spec/build/testsuites/sptests/spfatal09.yml (modified) * spec/build/testsuites/sptests/spfatal10.yml (modified) * spec/build/testsuites/sptests/spfatal11.yml (modified) * spec/build/testsuites/sptests/spfatal12.yml (modified) * spec/build/testsuites/sptests/spfatal13.yml (modified) * spec/build/testsuites/sptests/spfatal14.yml (modified) * spec/build/testsuites/sptests/spfatal15.yml (modified) * spec/build/testsuites/sptests/spfatal16.yml (modified) * spec/build/testsuites/sptests/spfatal17.yml (modified) * spec/build/testsuites/sptests/spfatal18.yml (modified) * spec/build/testsuites/sptests/spfatal19.yml (modified) * spec/build/testsuites/sptests/spfatal20.yml (modified) * spec/build/testsuites/sptests/spfatal26.yml (modified) * spec/build/testsuites/sptests/spfatal28.yml (modified) * spec/build/testsuites/sptests/spfatal29.yml (modified) * spec/build/testsuites/sptests/spfatal30.yml (modified) * spec/build/testsuites/sptests/spfatal31.yml (modified) * spec/build/testsuites/sptests/spfatal32.yml (modified) * spec/build/testsuites/sptests/spfatal33.yml (modified) * spec/build/testsuites/sptests/spfatal34.yml (modified) * spec/build/testsuites/sptests/spfatal36.yml (modified) * spec/build/testsuites/sptests/spfatalsupport.yml (modified) * spec/build/testsuites/sptests/spfifo01.yml (modified) * spec/build/testsuites/sptests/spfifo02.yml (modified) * spec/build/testsuites/sptests/spfifo03.yml (modified) * spec/build/testsuites/sptests/spfifo04.yml (modified) * spec/build/testsuites/sptests/spfifo05.yml (modified) * spec/build/testsuites/sptests/spfreechain01.yml (modified) * spec/build/testsuites/sptests/spglobalcon01.yml (modified) * spec/build/testsuites/sptests/spglobalcon02.yml (modified) * spec/build/testsuites/sptests/spheapprot.yml (modified) * spec/build/testsuites/sptests/spinternalerror01.yml (modified) * spec/build/testsuites/sptests/spinternalerror02.yml (modified) * spec/build/testsuites/sptests/spintrcritical01.yml (modified) * spec/build/testsuites/sptests/spintrcritical02.yml (modified) * spec/build/testsuites/sptests/spintrcritical03.yml (modified) * spec/build/testsuites/sptests/spintrcritical04.yml (modified) * spec/build/testsuites/sptests/spintrcritical05.yml (modified) * spec/build/testsuites/sptests/spintrcritical08.yml (modified) * spec/build/testsuites/sptests/spintrcritical09.yml (modified) * spec/build/testsuites/sptests/spintrcritical10.yml (modified) * spec/build/testsuites/sptests/spintrcritical11.yml (modified) * spec/build/testsuites/sptests/spintrcritical12.yml (modified) * spec/build/testsuites/sptests/spintrcritical13.yml (modified) * spec/build/testsuites/sptests/spintrcritical14.yml (modified) * spec/build/testsuites/sptests/spintrcritical15.yml (modified) * spec/build/testsuites/sptests/spintrcritical16.yml (modified) * spec/build/testsuites/sptests/spintrcritical18.yml (modified) * spec/build/testsuites/sptests/spintrcritical20.yml (modified) * spec/build/testsuites/sptests/spintrcritical21.yml (modified) * spec/build/testsuites/sptests/spintrcritical22.yml (modified) * spec/build/testsuites/sptests/spintrcritical23.yml (modified) * spec/build/testsuites/sptests/spintrcritical24.yml (modified) * spec/build/testsuites/sptests/spintrerr01.yml (modified) * spec/build/testsuites/sptests/splinkersets01.yml (modified) * spec/build/testsuites/sptests/spmisc01.yml (modified) * spec/build/testsuites/sptests/spmkdir.yml (modified) * spec/build/testsuites/sptests/spmountmgr01.yml (modified) * spec/build/testsuites/sptests/spmrsp01.yml (modified) * spec/build/testsuites/sptests/spmsgqerr01.yml (modified) * spec/build/testsuites/sptests/spmsgqerr02.yml (modified) * spec/build/testsuites/sptests/spmutex01.yml (modified) * spec/build/testsuites/sptests/spnsext01.yml (modified) * spec/build/testsuites/sptests/spntp01.yml (modified) * spec/build/testsuites/sptests/spobjgetnext.yml (modified) * spec/build/testsuites/sptests/sppagesize.yml (modified) * spec/build/testsuites/sptests/sppartitionerr01.yml (modified) * spec/build/testsuites/sptests/sppercpudata01.yml (modified) * spec/build/testsuites/sptests/spporterr01.yml (modified) * spec/build/testsuites/sptests/spprintk.yml (modified) * spec/build/testsuites/sptests/spprivenv01.yml (modified) * spec/build/testsuites/sptests/spprofiling01.yml (modified) * spec/build/testsuites/sptests/spqreslib.yml (modified) * spec/build/testsuites/sptests/spratemonerr01.yml (modified) * spec/build/testsuites/sptests/sprbtree01.yml (modified) * spec/build/testsuites/sptests/spregionerr01.yml (modified) * spec/build/testsuites/sptests/sprmsched01.yml (modified) * spec/build/testsuites/sptests/sprmsched02.yml (modified) * spec/build/testsuites/sptests/spscheduler01.yml (modified) * spec/build/testsuites/sptests/spsem01.yml (modified) * spec/build/testsuites/sptests/spsem02.yml (modified) * spec/build/testsuites/sptests/spsem03.yml (modified) * spec/build/testsuites/sptests/spsemerr01.yml (modified) * spec/build/testsuites/sptests/spsemerr02.yml (modified) * spec/build/testsuites/sptests/spsignalerr01.yml (modified) * spec/build/testsuites/sptests/spsimplesched01.yml (modified) * spec/build/testsuites/sptests/spsimplesched02.yml (modified) * spec/build/testsuites/sptests/spsimplesched03.yml (modified) * spec/build/testsuites/sptests/spsize.yml (modified) * spec/build/testsuites/sptests/spstdc17.yml (modified) * spec/build/testsuites/sptests/spstdthreads01.yml (modified) * spec/build/testsuites/sptests/spstkalloc.yml (modified) * spec/build/testsuites/sptests/spstkalloc02.yml (modified) * spec/build/testsuites/sptests/spstkalloc03.yml (modified) * spec/build/testsuites/sptests/spstkalloc04.yml (modified) * spec/build/testsuites/sptests/spsysinit01.yml (modified) * spec/build/testsuites/sptests/spsyslock01.yml (modified) * spec/build/testsuites/sptests/sptaskerr01.yml (modified) * spec/build/testsuites/sptests/sptaskerr02.yml (modified) * spec/build/testsuites/sptests/sptaskerr03.yml (modified) * spec/build/testsuites/sptests/sptaskerr04.yml (modified) * spec/build/testsuites/sptests/sptasknopreempt01.yml (modified) * spec/build/testsuites/sptests/spthread01.yml (modified) * spec/build/testsuites/sptests/spthreadlife01.yml (modified) * spec/build/testsuites/sptests/spthreadq01.yml (modified) * spec/build/testsuites/sptests/sptimecounter01.yml (modified) * spec/build/testsuites/sptests/sptimecounter02.yml (modified) * spec/build/testsuites/sptests/sptimecounter03.yml (modified) * spec/build/testsuites/sptests/sptimecounter04.yml (modified) * spec/build/testsuites/sptests/sptimererr01.yml (modified) * spec/build/testsuites/sptests/sptimererr02.yml (modified) * spec/build/testsuites/sptests/sptimerserver01.yml (modified) * spec/build/testsuites/sptests/sptimespec01.yml (modified) * spec/build/testsuites/sptests/sptls01.yml (modified) * spec/build/testsuites/sptests/sptls02.yml (modified) * spec/build/testsuites/sptests/sptls03.yml (modified) * spec/build/testsuites/sptests/sptls04.yml (modified) * spec/build/testsuites/sptests/spunlimited01.yml (modified) * spec/build/testsuites/sptests/spversion01.yml (modified) * spec/build/testsuites/sptests/spwatchdog.yml (modified) * spec/build/testsuites/sptests/spwkspace.yml (modified) * spec/build/testsuites/testopts.yml (modified) * spec/build/testsuites/tmtests/grp.yml (modified) * spec/build/testsuites/tmtests/tm01.yml (modified) * spec/build/testsuites/tmtests/tm02.yml (modified) * spec/build/testsuites/tmtests/tm03.yml (modified) * spec/build/testsuites/tmtests/tm04.yml (modified) * spec/build/testsuites/tmtests/tm05.yml (modified) * spec/build/testsuites/tmtests/tm06.yml (modified) * spec/build/testsuites/tmtests/tm07.yml (modified) * spec/build/testsuites/tmtests/tm08.yml (modified) * spec/build/testsuites/tmtests/tm09.yml (modified) * spec/build/testsuites/tmtests/tm10.yml (modified) * spec/build/testsuites/tmtests/tm11.yml (modified) * spec/build/testsuites/tmtests/tm12.yml (modified) * spec/build/testsuites/tmtests/tm13.yml (modified) * spec/build/testsuites/tmtests/tm14.yml (modified) * spec/build/testsuites/tmtests/tm15.yml (modified) * spec/build/testsuites/tmtests/tm16.yml (modified) * spec/build/testsuites/tmtests/tm17.yml (modified) * spec/build/testsuites/tmtests/tm18.yml (modified) * spec/build/testsuites/tmtests/tm19.yml (modified) * spec/build/testsuites/tmtests/tm20.yml (modified) * spec/build/testsuites/tmtests/tm21.yml (modified) * spec/build/testsuites/tmtests/tm22.yml (modified) * spec/build/testsuites/tmtests/tm23.yml (modified) * spec/build/testsuites/tmtests/tm24.yml (modified) * spec/build/testsuites/tmtests/tm25.yml (modified) * spec/build/testsuites/tmtests/tm26.yml (modified) * spec/build/testsuites/tmtests/tm27.yml (modified) * spec/build/testsuites/tmtests/tm28.yml (modified) * spec/build/testsuites/tmtests/tm29.yml (modified) * spec/build/testsuites/tmtests/tm30.yml (modified) * spec/build/testsuites/tmtests/tm31.yml (modified) * spec/build/testsuites/tmtests/tm32.yml (modified) * spec/build/testsuites/tmtests/tm33.yml (modified) * spec/build/testsuites/tmtests/tm34.yml (modified) * spec/build/testsuites/tmtests/tm35.yml (modified) * spec/build/testsuites/tmtests/tm36.yml (modified) * spec/build/testsuites/tmtests/tmck.yml (modified) * spec/build/testsuites/tmtests/tmcontext01.yml (modified) * spec/build/testsuites/tmtests/tmfine01.yml (modified) * spec/build/testsuites/tmtests/tmonetoone.yml (modified) * spec/build/testsuites/tmtests/tmtimer01.yml (modified) * spec/build/testsuites/unit/grp.yml (modified) * spec/build/testsuites/unit/unit-no-clock-0.yml (modified) * spec/build/testsuites/validation/fatal-boot-processor-not-assigned-to-scheduler.yml (modified) * spec/build/testsuites/validation/fatal-idle-thread-create-failed.yml (modified) * spec/build/testsuites/validation/fatal-idle-thread-stack-too-small.yml (modified) * spec/build/testsuites/validation/fatal-init-task-construct-failed.yml (modified) * spec/build/testsuites/validation/fatal-mandatory-processor-not-present.yml (modified) * spec/build/testsuites/validation/fatal-scheduler-requires-exactly-one-processor.yml (modified) * spec/build/testsuites/validation/fatal-smp.yml (modified) * spec/build/testsuites/validation/fatal-start-of-mandatory-processor-failed.yml (modified) * spec/build/testsuites/validation/fatal-start-on-not-online-processor.yml (modified) * spec/build/testsuites/validation/fatal-too-large-tls-size.yml (modified) * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/libvalidation.yml (modified) * spec/build/testsuites/validation/objnodebug.yml (modified) * spec/build/testsuites/validation/objpreinitarray.yml (modified) * spec/build/testsuites/validation/performance-no-clock-0.yml (modified) * spec/build/testsuites/validation/terminate.yml (modified) * spec/build/testsuites/validation/userext.yml (modified) * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-1.yml (modified) * spec/build/testsuites/validation/validation-acfg-0.yml (modified) * spec/build/testsuites/validation/validation-acfg-1.yml (modified) * spec/build/testsuites/validation/validation-cache.yml (modified) * spec/build/testsuites/validation/validation-intr.yml (modified) * spec/build/testsuites/validation/validation-io-kernel.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-non-smp.yml (modified) * spec/build/testsuites/validation/validation-one-cpu-0.yml (modified) * spec/build/testsuites/validation/validation-one-cpu-1.yml (modified) * spec/build/testsuites/validation/validation-smp-one-cpu-0.yml (modified) * spec/build/testsuites/validation/validation-smp-only-0.yml (modified) * spec/build/testsuites/validation/validation-smp-only-2.yml (modified) * spec/build/testsuites/validation/validation-timecounter-0.yml (modified) * spec/build/testsuites/validation/validation-timecounter-1.yml (modified) * spec/build/testsuites/validation/validation-timecounter-smp-0.yml (modified) * spec/build/testsuites/validation/validation-tls-0.yml (modified) * spec/build/testsuites/validation/validation-tls-1.yml (modified) * testsuites/ada/sptests/spatcb01/init.c (modified) * testsuites/ada/sptests/spatcb01/spatcb01.adb (modified) * testsuites/benchmarks/dhrystone/init.c (modified) * testsuites/benchmarks/linpack/init.c (modified) * testsuites/benchmarks/whetstone/init.c (modified) * testsuites/build/bin/fake-rtems5-ar (modified) * testsuites/build/bin/fake-rtems5-gcc (modified) * testsuites/build/bin/fake-rtems5-ld (modified) * testsuites/build/test.py (modified) * testsuites/fstests/fsbdpart01/init.c (modified) * testsuites/fstests/fsclose01/init.c (modified) * testsuites/fstests/fsdosfsformat01/init.c (modified) * testsuites/fstests/fsdosfsname01/create_files.cs (modified) * testsuites/fstests/fsdosfsname01/create_image.sh (modified) * testsuites/fstests/fsdosfsname01/image_bin_le_multibyte.h (modified) * testsuites/fstests/fsdosfsname01/image_bin_le_singlebyte.h (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) * testsuites/fstests/fsdosfsname02/init.c (modified) * testsuites/fstests/fsdosfssync01/init.c (modified) * testsuites/fstests/fsdosfswrite01/init.c (modified) * testsuites/fstests/fsfseeko01/init.c (modified) * testsuites/fstests/fsimfsconfig01/init.c (modified) * testsuites/fstests/fsimfsconfig02/init.c (modified) * testsuites/fstests/fsimfsconfig03/init.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) * testsuites/fstests/fsjffs2gc01/init.c (modified) * testsuites/fstests/fsnofs01/init.c (modified) * testsuites/fstests/fsrofs01/init.c (modified) * testsuites/fstests/jffs2_support/fs_config.h (modified) * testsuites/fstests/jffs2_support/fs_support.c (modified) * testsuites/fstests/tftpfs/init.c (modified) * testsuites/fstests/tftpfs/tftpfs_interactions.c (modified) * testsuites/fstests/tftpfs/tftpfs_interactions.h (modified) * testsuites/fstests/tftpfs/tftpfs_udp_network_fake.c (modified) * testsuites/fstests/tftpfs/tftpfs_udp_network_fake.h (modified) * testsuites/libtests/block01/block01.doc (modified) * testsuites/libtests/block01/init.c (modified) * testsuites/libtests/block02/block02.doc (modified) * testsuites/libtests/block02/init.c (modified) * testsuites/libtests/block03/block03.doc (modified) * testsuites/libtests/block03/init.c (modified) * testsuites/libtests/block04/block04.doc (modified) * testsuites/libtests/block04/init.c (modified) * testsuites/libtests/block05/block05.doc (modified) * testsuites/libtests/block05/init.c (modified) * testsuites/libtests/block07/block07.doc (modified) * testsuites/libtests/block07/init.c (modified) * testsuites/libtests/block09/block09.doc (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/block10.doc (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/libtests/block11/init.c (modified) * testsuites/libtests/block12/init.c (modified) * testsuites/libtests/block13/init.c (modified) * testsuites/libtests/block14/init.c (modified) * testsuites/libtests/block15/init.c (modified) * testsuites/libtests/block16/init.c (modified) * testsuites/libtests/block17/init.c (modified) * testsuites/libtests/crypt01/init.c (modified) * testsuites/libtests/defaultconfig01/init.c (modified) * testsuites/libtests/devfs01/init.c (modified) * testsuites/libtests/exit01/init.c (modified) * testsuites/libtests/exit02/init.c (modified) * testsuites/libtests/exit03/init.c (modified) * testsuites/libtests/exit03/stdio.cc (modified) * testsuites/libtests/flashdisk01/init.c (modified) * testsuites/libtests/flashdisk01/test-file-system.c (modified) * testsuites/libtests/flashdisk01/test-file-system.h (modified) * testsuites/libtests/getentropy01/init.c (modified) * testsuites/libtests/heapwalk/init.c (modified) * testsuites/libtests/i2c01/init.c (modified) * testsuites/libtests/irqs01/init.c (modified) * testsuites/libtests/libfdt01/init.c (modified) * testsuites/libtests/libfdt01/some.dts (modified) * testsuites/libtests/malloctest/init.c (modified) * testsuites/libtests/md501/init.c (modified) * testsuites/libtests/newlib01/init.c (modified) * testsuites/libtests/ofw01/some.dts (modified) * testsuites/libtests/pwdgrp01/init.c (modified) * testsuites/libtests/pwdgrp02/init.c (modified) * testsuites/libtests/rbheap01/init.c (modified) * testsuites/libtests/record01/init.c (modified) * testsuites/libtests/record02/init.c (modified) * testsuites/libtests/sha/init.c (modified) * testsuites/libtests/shell01/init.c (modified) * testsuites/libtests/sparsedisk01/init.c (modified) * testsuites/libtests/spi01/init.c (modified) * testsuites/libtests/termios09/init.c (modified) * testsuites/libtests/ttest01/init.c (modified) * testsuites/libtests/ttest01/t-self-test.h (modified) * testsuites/libtests/ttest01/test-assert.c (modified) * testsuites/libtests/ttest01/test-checks.c (modified) * testsuites/libtests/ttest01/test-destructor.c (modified) * testsuites/libtests/ttest01/test-eno.c (modified) * testsuites/libtests/ttest01/test-example.c (modified) * testsuites/libtests/ttest01/test-fixture.c (modified) * testsuites/libtests/ttest01/test-leak.c (modified) * testsuites/libtests/ttest01/test-log.c (modified) * testsuites/libtests/ttest01/test-malloc.c (modified) * testsuites/libtests/ttest01/test-plan.c (modified) * testsuites/libtests/ttest01/test-psx.c (modified) * testsuites/libtests/ttest01/test-rtems.c (modified) * testsuites/libtests/ttest01/test-simple.c (modified) * testsuites/libtests/ttest01/test-step.c (modified) * testsuites/libtests/ttest01/test-task-context.c (modified) * testsuites/libtests/ttest01/test-time.c (modified) * testsuites/libtests/ttest01/test-verbosity.c (modified) * testsuites/libtests/ttest02/init.c (modified) * testsuites/libtests/utf8proc01/init.c (modified) * testsuites/psxtests/psx08/init.c (modified) * testsuites/psxtests/psx15/init.c (modified) * testsuites/psxtests/psxbarrier01/test.c (modified) * testsuites/psxtests/psxchroot01/test.c (modified) * testsuites/psxtests/psxcleanup02/init.c (modified) * testsuites/psxtests/psxcleanup02/main.c (modified) * testsuites/psxtests/psxclockrealtime01/init.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxconfig01/psxconfig01.doc (modified) * testsuites/psxtests/psxftw01/init.c (modified) * testsuites/psxtests/psxglobalcon01/init.cc (modified) * testsuites/psxtests/psxglobalcon02/init.cc (modified) * testsuites/psxtests/psxintrcritical01/init.c (modified) * testsuites/psxtests/psxmount/test.c (modified) * testsuites/psxtests/psxonce01/init.c (modified) * testsuites/psxtests/psxonce01/psxonce01.doc (modified) * testsuites/psxtests/psxthreadname01/init.c (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpclock01/init.c (modified) * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) * testsuites/smptests/smpfatal03/init.c (modified) * testsuites/smptests/smpfatal04/init.c (modified) * testsuites/smptests/smpfatal05/init.c (modified) * testsuites/smptests/smpfatal06/init.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) * testsuites/smptests/smpfatal09/init.c (modified) * testsuites/smptests/smpipi01/init.c (modified) * testsuites/smptests/smpirqs01/init.c (modified) * testsuites/smptests/smpload01/init.c (modified) * testsuites/smptests/smplock01/init.c (modified) * testsuites/smptests/smplock01/smplock01fair.py (modified) * testsuites/smptests/smplock01/smplock01perf.py (modified) * testsuites/smptests/smpmigration01/init.c (modified) * testsuites/smptests/smpmigration02/init.c (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) * testsuites/smptests/smpmutex01/init.c (modified) * testsuites/smptests/smpmutex02/init.c (modified) * testsuites/smptests/smpopenmp01/init.c (modified) * testsuites/smptests/smpopenmp01/smpopenmp01.py (modified) * testsuites/smptests/smppsxmutex01/init.c (modified) * testsuites/smptests/smppsxsignal01/init.c (modified) * testsuites/smptests/smpschededf01/init.c (modified) * testsuites/smptests/smpschededf02/init.c (modified) * testsuites/smptests/smpschededf03/init.c (modified) * testsuites/smptests/smpschededf04/init.c (modified) * testsuites/smptests/smpscheduler01/init.c (modified) * testsuites/smptests/smpscheduler02/init.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/smptests/smpscheduler03/test.c (modified) * testsuites/smptests/smpscheduler04/init.c (modified) * testsuites/smptests/smpscheduler05/init.c (modified) * testsuites/smptests/smpscheduler06/init.c (modified) * testsuites/smptests/smpscheduler07/init.c (modified) * testsuites/smptests/smpsignal01/init.c (modified) * testsuites/smptests/smpstart01/init.c (modified) * testsuites/smptests/smpstrongapa01/init.c (modified) * testsuites/smptests/smpswitchextension01/init.c (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) * testsuites/smptests/smpthreadpin01/init.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) * testsuites/smptests/smpwakeafter01/init.c (modified) * testsuites/sptests/sp2038/init.c (modified) * testsuites/sptests/sp2038/sp2038.doc (modified) * testsuites/sptests/sp31/task1.c (modified) * testsuites/sptests/sp40/init.c (modified) * testsuites/sptests/sp68/init.c (modified) * testsuites/sptests/sp68/sp68.doc (modified) * testsuites/sptests/spatomic01/init.c (modified) * testsuites/sptests/spcache01/init.c (modified) * testsuites/sptests/spconfig01/init.c (modified) * testsuites/sptests/spconfig02/init.c (modified) * testsuites/sptests/spconsole01/init.c (modified) * testsuites/sptests/spcontext01/init.c (modified) * testsuites/sptests/spcpucounter01/init.c (modified) * testsuites/sptests/spcxx01/init.cc (modified) * testsuites/sptests/speventsystem01/init.c (modified) * testsuites/sptests/speventtransient01/init.c (modified) * testsuites/sptests/spextensions01/init.c (modified) * testsuites/sptests/spfatal26/init.c (modified) * testsuites/sptests/spfatal28/init.c (modified) * testsuites/sptests/spfatal29/init.c (modified) * testsuites/sptests/spfatal30/init.c (modified) * testsuites/sptests/spfatal31/init.c (modified) * testsuites/sptests/spfatal32/init.c (modified) * testsuites/sptests/spfatal33/init.c (modified) * testsuites/sptests/spfatal34/init.c (modified) * testsuites/sptests/spfatal36/init.c (modified) * testsuites/sptests/spglobalcon01/init.cc (modified) * testsuites/sptests/spglobalcon02/init.c (modified) * testsuites/sptests/spheapprot/init.c (modified) * testsuites/sptests/spheapprot/spheapprot.doc (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spintrcritical01/spintrcritical01impl.h (modified) * testsuites/sptests/spintrcritical08/init.c (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical11/spintrcritical11impl.h (modified) * testsuites/sptests/spintrcritical13/spintrcritical13impl.h (modified) * testsuites/sptests/spintrcritical15/init.c (modified) * testsuites/sptests/spintrcritical16/init.c (modified) * testsuites/sptests/spintrcritical18/init.c (modified) * testsuites/sptests/spintrcritical20/init.c (modified) * testsuites/sptests/spintrcritical21/init.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) * testsuites/sptests/spintrcritical23/init.c (modified) * testsuites/sptests/spintrcritical24/init.c (modified) * testsuites/sptests/splinkersets01/content.c (modified) * testsuites/sptests/splinkersets01/init.c (modified) * testsuites/sptests/splinkersets01/item-a.c (modified) * testsuites/sptests/splinkersets01/item-ca.c (modified) * testsuites/sptests/splinkersets01/sets.c (modified) * testsuites/sptests/splinkersets01/splinkersets01.h (modified) * testsuites/sptests/spmisc01/init.c (modified) * testsuites/sptests/spmisc01/spmisc01.h (modified) * testsuites/sptests/spmisc01/strong.c (modified) * testsuites/sptests/spmkdir/init.c (modified) * testsuites/sptests/spmrsp01/init.c (modified) * testsuites/sptests/spmutex01/init.c (modified) * testsuites/sptests/spnsext01/init.c (modified) * testsuites/sptests/spnsext01/spnsext01.doc (modified) * testsuites/sptests/spntp01/init.c (modified) * testsuites/sptests/sppercpudata01/init.c (modified) * testsuites/sptests/sppercpudata01/item.c (modified) * testsuites/sptests/sppercpudata01/sppercpudata01.h (modified) * testsuites/sptests/spprofiling01/init.c (modified) * testsuites/sptests/spscheduler01/init.c (modified) * testsuites/sptests/spsem03/init.c (modified) * testsuites/sptests/spstdthreads01/init.c (modified) * testsuites/sptests/spstkalloc02/init.c (modified) * testsuites/sptests/spstkalloc02/spstkalloc02.doc (modified) * testsuites/sptests/spsysinit01/init.c (modified) * testsuites/sptests/spsyslock01/init.c (modified) * testsuites/sptests/sptasknopreempt01/init.c (modified) * testsuites/sptests/spthread01/init.c (modified) * testsuites/sptests/spthreadlife01/init.c (modified) * testsuites/sptests/spthreadq01/init.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) * testsuites/sptests/sptimecounter01/sptimecounter01.doc (modified) * testsuites/sptests/sptimecounter02/init.c (modified) * testsuites/sptests/sptimecounter02/sptimecounter02.py (modified) * testsuites/sptests/sptimecounter03/init.c (modified) * testsuites/sptests/sptimecounter04/init.c (modified) * testsuites/sptests/sptimerserver01/init.c (modified) * testsuites/sptests/sptls01/init.c (modified) * testsuites/sptests/sptls02/init.cc (modified) * testsuites/sptests/sptls02/sptls02.h (modified) * testsuites/sptests/sptls02/var.cc (modified) * testsuites/sptests/sptls03/init.c (modified) * testsuites/sptests/sptls04/init.c (modified) * testsuites/sptests/sptls04/sptls04.h (modified) * testsuites/sptests/sptls04/tls.c (modified) * testsuites/sptests/spunlimited01/init.c (modified) * testsuites/tmtests/tmcontext01/init.c (modified) * testsuites/tmtests/tmcontext01/plot.py (modified) * testsuites/tmtests/tmfine01/init.c (modified) * testsuites/tmtests/tmfine01/tmfine01.py (modified) * testsuites/tmtests/tmonetoone/init.c (modified) * testsuites/tmtests/tmtimer01/init.c (modified) * testsuites/tmtests/tmtimer01/plot.py (modified) * testsuites/unit/tc-misaligned-builtin-memcpy.c (modified) * testsuites/unit/tc-score-rbtree.c (modified) * testsuites/unit/ts-unit-no-clock-0.c (modified) * testsuites/validation/tc-acfg-appl-does-not-need-clock-driver.c (modified) * testsuites/validation/tc-acfg-appl-needs-clock-driver.c (modified) * testsuites/validation/tc-acfg-default.c (modified) * testsuites/validation/tc-acfg-disabled-bsp-settings.c (modified) * testsuites/validation/tc-acfg-one-cpu.c (modified) * testsuites/validation/tc-acfg-scheduler-edf-smp.c (modified) * testsuites/validation/tc-acfg-scheduler-table-entries-one-cpu.c (modified) * testsuites/validation/tc-acfg.c (modified) * testsuites/validation/tc-attr.c (modified) * testsuites/validation/tc-barrier-create.c (modified) * testsuites/validation/tc-barrier-delete.c (modified) * testsuites/validation/tc-barrier-ident.c (modified) * testsuites/validation/tc-barrier-performance.c (modified) * testsuites/validation/tc-barrier-release.c (modified) * testsuites/validation/tc-barrier-wait.c (modified) * testsuites/validation/tc-basedefs-no-debug.c (modified) * testsuites/validation/tc-basedefs-pendant.c (modified) * testsuites/validation/tc-basedefs-pendant.h (modified) * testsuites/validation/tc-basedefs.c (modified) * testsuites/validation/tc-bsp-interrupt-handler-dispatch-unchecked.c (modified) * testsuites/validation/tc-c.c (modified) * testsuites/validation/tc-cache.c (modified) * testsuites/validation/tc-clock-get-tod.c (modified) * testsuites/validation/tc-clock-get-uptime.c (modified) * testsuites/validation/tc-clock-nanosleep.c (modified) * testsuites/validation/tc-clock-set.c (modified) * testsuites/validation/tc-clock.c (modified) * testsuites/validation/tc-cpuuse.c (modified) * testsuites/validation/tc-event-performance.c (modified) * testsuites/validation/tc-event-send-receive.c (modified) * testsuites/validation/tc-events.c (modified) * testsuites/validation/tc-flsl.c (modified) * testsuites/validation/tc-futex-wait.c (modified) * testsuites/validation/tc-futex-wake.c (modified) * testsuites/validation/tc-intr-clear.c (modified) * testsuites/validation/tc-intr-entry-install.c (modified) * testsuites/validation/tc-intr-entry-remove.c (modified) * testsuites/validation/tc-intr-get-affinity.c (modified) * testsuites/validation/tc-intr-get-attributes.c (modified) * testsuites/validation/tc-intr-handler-iterate.c (modified) * testsuites/validation/tc-intr-is-pending.c (modified) * testsuites/validation/tc-intr-non-smp.c (modified) * testsuites/validation/tc-intr-raise-on.c (modified) * testsuites/validation/tc-intr-raise.c (modified) * testsuites/validation/tc-intr-set-affinity.c (modified) * testsuites/validation/tc-intr-smp-only.c (modified) * testsuites/validation/tc-intr-vector-disable.c (modified) * testsuites/validation/tc-intr-vector-enable.c (modified) * testsuites/validation/tc-intr-vector-is-enabled.c (modified) * testsuites/validation/tc-intr.c (modified) * testsuites/validation/tc-io-getchark.c (modified) * testsuites/validation/tc-io-put-char.c (modified) * testsuites/validation/tc-io-putc.c (modified) * testsuites/validation/tc-message-broadcast.c (modified) * testsuites/validation/tc-message-construct.c (modified) * testsuites/validation/tc-message-delete.c (modified) * testsuites/validation/tc-message-flush-pending.c (modified) * testsuites/validation/tc-message-ident.c (modified) * testsuites/validation/tc-message-macros.c (modified) * testsuites/validation/tc-message-performance.c (modified) * testsuites/validation/tc-message-receive.c (modified) * testsuites/validation/tc-message-urgent-send.c (modified) * testsuites/validation/tc-modes.c (modified) * testsuites/validation/tc-object.c (modified) * testsuites/validation/tc-options.c (modified) * testsuites/validation/tc-part-create.c (modified) * testsuites/validation/tc-part-delete.c (modified) * testsuites/validation/tc-part-get.c (modified) * testsuites/validation/tc-part-ident.c (modified) * testsuites/validation/tc-part-performance.c (modified) * testsuites/validation/tc-part-return.c (modified) * testsuites/validation/tc-part.c (modified) * testsuites/validation/tc-preinit-array.c (modified) * testsuites/validation/tc-ratemon-cancel.c (modified) * testsuites/validation/tc-ratemon-create.c (modified) * testsuites/validation/tc-ratemon-delete.c (modified) * testsuites/validation/tc-ratemon-get-status.c (modified) * testsuites/validation/tc-ratemon-ident.c (modified) * testsuites/validation/tc-ratemon-period.c (modified) * testsuites/validation/tc-ratemon-timeout.c (modified) * testsuites/validation/tc-sched-smp-edf-set-affinity.c (modified) * testsuites/validation/tc-sched-smp-edf.c (modified) * testsuites/validation/tc-sched-smp.c (modified) * testsuites/validation/tc-sched-yield.c (modified) * testsuites/validation/tc-scheduler-add-processor.c (modified) * testsuites/validation/tc-scheduler-get-maximum-priority.c (modified) * testsuites/validation/tc-scheduler-get-processor-set.c (modified) * testsuites/validation/tc-scheduler-ident-by-processor-set.c (modified) * testsuites/validation/tc-scheduler-ident-by-processor.c (modified) * testsuites/validation/tc-scheduler-ident.c (modified) * testsuites/validation/tc-scheduler-non-smp.c (modified) * testsuites/validation/tc-scheduler-remove-processor.c (modified) * testsuites/validation/tc-scheduler-smp-only.c (modified) * testsuites/validation/tc-scheduler.c (modified) * testsuites/validation/tc-score-fatal.c (modified) * testsuites/validation/tc-score-smp-per-cpu-jobs.c (modified) * testsuites/validation/tc-score-smp-thread.c (modified) * testsuites/validation/tc-score-thread-smp-one-cpu.c (modified) * testsuites/validation/tc-score-thread-tls-max-zero.c (modified) * testsuites/validation/tc-score-thread-tls.c (modified) * testsuites/validation/tc-score-thread.c (modified) * testsuites/validation/tc-score-tq-smp.c (modified) * testsuites/validation/tc-score-tq.c (modified) * testsuites/validation/tc-sem-create.c (modified) * testsuites/validation/tc-sem-delete.c (modified) * testsuites/validation/tc-sem-flush.c (modified) * testsuites/validation/tc-sem-ident.c (modified) * testsuites/validation/tc-sem-mrsp-obtain.c (modified) * testsuites/validation/tc-sem-obtain.c (modified) * testsuites/validation/tc-sem-performance.c (modified) * testsuites/validation/tc-sem-release.c (modified) * testsuites/validation/tc-sem-set-priority.c (modified) * testsuites/validation/tc-sem-smp.c (modified) * testsuites/validation/tc-sem-timeout.c (modified) * testsuites/validation/tc-sem-uni.c (modified) * testsuites/validation/tc-signal-catch.c (modified) * testsuites/validation/tc-signal-send.c (modified) * testsuites/validation/tc-signals.c (modified) * testsuites/validation/tc-start-of-optional-processor-failed.c (modified) * testsuites/validation/tc-status-is-equal.c (modified) * testsuites/validation/tc-status-is-successful.c (modified) * testsuites/validation/tc-status-text.c (modified) * testsuites/validation/tc-status.c (modified) * testsuites/validation/tc-support-is-name-valid.c (modified) * testsuites/validation/tc-support.c (modified) * testsuites/validation/tc-sys-lock.c (modified) * testsuites/validation/tc-task-construct.c (modified) * testsuites/validation/tc-task-create-errors.c (modified) * testsuites/validation/tc-task-delete.c (modified) * testsuites/validation/tc-task-exit.c (modified) * testsuites/validation/tc-task-get-affinity.c (modified) * testsuites/validation/tc-task-get-priority.c (modified) * testsuites/validation/tc-task-get-scheduler.c (modified) * testsuites/validation/tc-task-ident.c (modified) * testsuites/validation/tc-task-is-suspended.c (modified) * testsuites/validation/tc-task-mode.c (modified) * testsuites/validation/tc-task-performance.c (modified) * testsuites/validation/tc-task-restart.c (modified) * testsuites/validation/tc-task-resume.c (modified) * testsuites/validation/tc-task-set-affinity.c (modified) * testsuites/validation/tc-task-set-priority.c (modified) * testsuites/validation/tc-task-set-scheduler.c (modified) * testsuites/validation/tc-task-smp.c (modified) * testsuites/validation/tc-task-start.c (modified) * testsuites/validation/tc-task-storage-size.c (modified) * testsuites/validation/tc-task-suspend.c (modified) * testsuites/validation/tc-task-wake-after.c (modified) * testsuites/validation/tc-task-wake-when.c (modified) * testsuites/validation/tc-task.c (modified) * testsuites/validation/tc-terminate.c (modified) * testsuites/validation/tc-thread-idle-body-no-return.c (modified) * testsuites/validation/tc-timecounter-get-smp.c (modified) * testsuites/validation/tc-timecounter-get.c (modified) * testsuites/validation/tc-timecounter-install.c (modified) * testsuites/validation/tc-timer-cancel.c (modified) * testsuites/validation/tc-timer-create.c (modified) * testsuites/validation/tc-timer-delete.c (modified) * testsuites/validation/tc-timer-fire-after.c (modified) * testsuites/validation/tc-timer-fire-when.c (modified) * testsuites/validation/tc-timer-ident.c (modified) * testsuites/validation/tc-timer-initiate-server.c (modified) * testsuites/validation/tc-timer-reset.c (modified) * testsuites/validation/tc-timer-server-fire-after.c (modified) * testsuites/validation/tc-timer-server-fire-when.c (modified) * testsuites/validation/tc-timer.c (modified) * testsuites/validation/tc-type.c (modified) * testsuites/validation/tc-userext-create.c (modified) * testsuites/validation/tc-userext-delete.c (modified) * testsuites/validation/tc-userext-ident.c (modified) * testsuites/validation/tc-userext.c (modified) * testsuites/validation/tc-userext.h (modified) * testsuites/validation/tr-event-constant.c (modified) * testsuites/validation/tr-event-constant.h (modified) * testsuites/validation/tr-event-send-receive.c (modified) * testsuites/validation/tr-event-send-receive.h (modified) * testsuites/validation/tr-fatal-boot-processor-not-assigned-to-scheduler.c (modified) * testsuites/validation/tr-fatal-boot-processor-not-assigned-to-scheduler.h (modified) * testsuites/validation/tr-fatal-idle-thread-create-failed.c (modified) * testsuites/validation/tr-fatal-idle-thread-create-failed.h (modified) * testsuites/validation/tr-fatal-idle-thread-stack-too-small.c (modified) * testsuites/validation/tr-fatal-idle-thread-stack-too-small.h (modified) * testsuites/validation/tr-fatal-init-task-construct-failed.c (modified) * testsuites/validation/tr-fatal-init-task-construct-failed.h (modified) * testsuites/validation/tr-fatal-mandatory-processor-not-present.c (modified) * testsuites/validation/tr-fatal-mandatory-processor-not-present.h (modified) * testsuites/validation/tr-fatal-scheduler-requires-exactly-one-processor.c (modified) * testsuites/validation/tr-fatal-scheduler-requires-exactly-one-processor.h (modified) * testsuites/validation/tr-fatal-smp.c (modified) * testsuites/validation/tr-fatal-smp.h (modified) * testsuites/validation/tr-fatal-start-of-mandatory-processor-failed.c (modified) * testsuites/validation/tr-fatal-start-of-mandatory-processor-failed.h (modified) * testsuites/validation/tr-fatal-start-on-not-online-processor.c (modified) * testsuites/validation/tr-fatal-start-on-not-online-processor.h (modified) * testsuites/validation/tr-fatal-too-large-tls-size.c (modified) * testsuites/validation/tr-fatal-too-large-tls-size.h (modified) * testsuites/validation/tr-io-kernel.c (modified) * testsuites/validation/tr-io-kernel.h (modified) * testsuites/validation/tr-mtx-seize-try.c (modified) * testsuites/validation/tr-mtx-seize-try.h (modified) * testsuites/validation/tr-mtx-seize-wait.c (modified) * testsuites/validation/tr-mtx-seize-wait.h (modified) * testsuites/validation/tr-mtx-surrender.c (modified) * testsuites/validation/tr-mtx-surrender.h (modified) * testsuites/validation/tr-object-ident-local.c (modified) * testsuites/validation/tr-object-ident-local.h (modified) * testsuites/validation/tr-object-ident.c (modified) * testsuites/validation/tr-object-ident.h (modified) * testsuites/validation/tr-sem-seize-try.c (modified) * testsuites/validation/tr-sem-seize-try.h (modified) * testsuites/validation/tr-sem-seize-wait.c (modified) * testsuites/validation/tr-sem-seize-wait.h (modified) * testsuites/validation/tr-sem-surrender.c (modified) * testsuites/validation/tr-sem-surrender.h (modified) * testsuites/validation/tr-signal-constant.c (modified) * testsuites/validation/tr-signal-constant.h (modified) * testsuites/validation/tr-tq-enqueue-ceiling.c (modified) * testsuites/validation/tr-tq-enqueue-ceiling.h (modified) * testsuites/validation/tr-tq-enqueue-deadlock.c (modified) * testsuites/validation/tr-tq-enqueue-deadlock.h (modified) * testsuites/validation/tr-tq-enqueue-fifo.c (modified) * testsuites/validation/tr-tq-enqueue-fifo.h (modified) * testsuites/validation/tr-tq-enqueue-mrsp.c (modified) * testsuites/validation/tr-tq-enqueue-mrsp.h (modified) * testsuites/validation/tr-tq-enqueue-priority-inherit.c (modified) * testsuites/validation/tr-tq-enqueue-priority-inherit.h (modified) * testsuites/validation/tr-tq-enqueue-priority.c (modified) * testsuites/validation/tr-tq-enqueue-priority.h (modified) * testsuites/validation/tr-tq-flush-fifo.c (modified) * testsuites/validation/tr-tq-flush-fifo.h (modified) * testsuites/validation/tr-tq-flush-priority-inherit.c (modified) * testsuites/validation/tr-tq-flush-priority-inherit.h (modified) * testsuites/validation/tr-tq-flush-priority.c (modified) * testsuites/validation/tr-tq-flush-priority.h (modified) * testsuites/validation/tr-tq-surrender-mrsp.c (modified) * testsuites/validation/tr-tq-surrender-mrsp.h (modified) * testsuites/validation/tr-tq-surrender-priority-inherit.c (modified) * testsuites/validation/tr-tq-surrender-priority-inherit.h (modified) * testsuites/validation/tr-tq-surrender.c (modified) * testsuites/validation/tr-tq-surrender.h (modified) * testsuites/validation/tr-tq-timeout-mrsp.c (modified) * testsuites/validation/tr-tq-timeout-mrsp.h (modified) * testsuites/validation/tr-tq-timeout-priority-inherit.c (modified) * testsuites/validation/tr-tq-timeout-priority-inherit.h (modified) * testsuites/validation/tr-tq-timeout.c (modified) * testsuites/validation/tr-tq-timeout.h (modified) * testsuites/validation/ts-acfg.h (modified) * testsuites/validation/ts-config.h (modified) * testsuites/validation/ts-default.h (modified) * testsuites/validation/ts-fatal-boot-processor-not-assigned-to-scheduler.c (modified) * testsuites/validation/ts-fatal-idle-thread-create-failed.c (modified) * testsuites/validation/ts-fatal-idle-thread-stack-too-small.c (modified) * testsuites/validation/ts-fatal-init-task-construct-failed.c (modified) * testsuites/validation/ts-fatal-mandatory-processor-not-present.c (modified) * testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c (modified) * testsuites/validation/ts-fatal-smp.c (modified) * testsuites/validation/ts-fatal-start-of-mandatory-processor-failed.c (modified) * testsuites/validation/ts-fatal-start-on-not-online-processor.c (modified) * testsuites/validation/ts-fatal-sysinit.h (modified) * testsuites/validation/ts-fatal-too-large-tls-size.c (modified) * testsuites/validation/ts-idle.h (modified) * testsuites/validation/ts-performance-no-clock-0.c (modified) * testsuites/validation/ts-terminate.c (modified) * testsuites/validation/ts-userext.c (modified) * testsuites/validation/ts-validation-0.c (modified) * testsuites/validation/ts-validation-1.c (modified) * testsuites/validation/ts-validation-acfg-0.c (modified) * testsuites/validation/ts-validation-acfg-1.c (modified) * testsuites/validation/ts-validation-cache.c (modified) * testsuites/validation/ts-validation-intr.c (modified) * testsuites/validation/ts-validation-io-kernel.c (modified) * testsuites/validation/ts-validation-no-clock-0.c (modified) * testsuites/validation/ts-validation-non-smp.c (modified) * testsuites/validation/ts-validation-one-cpu-0.c (modified) * testsuites/validation/ts-validation-one-cpu-1.c (modified) * testsuites/validation/ts-validation-smp-one-cpu-0.c (modified) * testsuites/validation/ts-validation-smp-only-0.c (modified) * testsuites/validation/ts-validation-smp-only-2.c (modified) * testsuites/validation/ts-validation-timecounter-0.c (modified) * testsuites/validation/ts-validation-timecounter-1.c (modified) * testsuites/validation/ts-validation-timecounter-smp-0.c (modified) * testsuites/validation/ts-validation-tls-0.c (modified) * testsuites/validation/ts-validation-tls-1.c (modified) * testsuites/validation/tx-call-within-isr.c (modified) * testsuites/validation/tx-default-task-config.c (modified) * testsuites/validation/tx-interrupt.c (modified) * testsuites/validation/tx-io-relax.c (modified) * testsuites/validation/tx-memory-alloc.c (modified) * testsuites/validation/tx-preemption-intervention.c (modified) * testsuites/validation/tx-support.c (modified) * testsuites/validation/tx-support.h (modified) * testsuites/validation/tx-thread-queue.c (modified) * testsuites/validation/tx-thread-queue.h (modified) * testsuites/validation/tx-timecounter.c (modified) * testsuites/validation/tx-timer-server.c (modified) * testsuites/validation/tx-wrap-thread-queue.c (modified) * wscript (modified) Update company name The embedded brains GmbH & Co. KG is the legal ... Wed, 17 May 2023 00:03:47 GMT Aaron Nyholm [c2913ec] * cpukit/libmisc/shell/main_flashdev.c (modified) libmisc/shell: Fix file pointer leak and improved input data ... Thu, 16 Mar 2023 01:01:45 GMT Aaron Nyholm [984693a] * cpukit/include/rtems/shellconfig.h (modified) * cpukit/libmisc/shell/main_flashdev.c (added) * spec/build/cpukit/objshell.yml (modified) libmisc/shell: Add flashdev command Wed, 15 Mar 2023 09:06:59 GMT Sebastian Huber [51fdc8f9] * cpukit/libmisc/cpuuse/cpuusagedata.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/cpuuse/cpuuseimpl.h (modified) cpuuse: Add implementation Doxygen group Fri, 10 Feb 2023 02:25:32 GMT zack [809e34e5] * cpukit/libmisc/shell/main_edit.c (modified) libmisc/shell/main_edit.c: User cannot cut using ctrl e and x ... Fri, 10 Feb 2023 13:55:17 GMT Joel Sherrill [26e1610] * cpukit/libmisc/shell/main_pci.c (modified) shell/main_pci.c: Address Dereference after null error check ... Thu, 09 Feb 2023 15:05:58 GMT Joel Sherrill [77e7bd9] * cpukit/include/rtems/serdbg.h (deleted) * cpukit/include/rtems/serdbgcnf.h (deleted) * cpukit/include/rtems/termios_printk.h (deleted) * cpukit/include/rtems/termios_printk_cnf.h (deleted) * cpukit/libmisc/serdbg/README (deleted) * cpukit/libmisc/serdbg/serdbg.c (deleted) * cpukit/libmisc/serdbg/serdbgio.c (deleted) * cpukit/libmisc/serdbg/termios_printk.c (deleted) * spec/build/cpukit/librtemscpu.yml (modified) libmisc/serdbg: Remove obsolete serial debug Closes #2828. Mon, 30 Jan 2023 03:11:59 GMT Chris Johns [edea93c] * cpukit/libmisc/shell/main_edit.c (modified) libmisc/shell/edit: Return if no memory in move_gap Closes #4835 Mon, 30 Jan 2023 02:59:11 GMT Chris Johns [3ad2789] * cpukit/libmisc/shell/main_edit.c (modified) libmisc/shell/edit: Fix closing the editor Closes #4834 Mon, 23 Jan 2023 14:33:46 GMT Sebastian Huber [0340fd9] * cpukit/include/rtems/cpuuse.h (modified) * cpukit/libmisc/cpuuse/cpuusagedata.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) cpuuse: Use standard wording and group name Use standard wording in ... Mon, 26 Dec 2022 02:40:57 GMT zack leung [c8c713c] * cpukit/libmisc/shell/main_chmod.c (modified) rtems_shell_main_chmod: Correct argument indexing Closes #4751 Thu, 15 Dec 2022 01:12:25 GMT zack leung [4523c713] * cpukit/libmisc/shell/main_mmove.c (modified) rtems_shell_main_mmove problem --0000000000006acec205efd38cd6 ... Fri, 25 Nov 2022 01:18:07 GMT Chris Johns [408dbeb] * cpukit/include/rtems/rtems-fdt.h (modified) * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) libmisc/rtems-fdt: Support prop map items up to the size of uintptr_t ... Fri, 25 Nov 2022 01:14:00 GMT Chris Johns [904a9112] * cpukit/libmisc/shell/main_edit.c (modified) libmisc/shell: Fix edit Coverity error Coverity Id: CID 1517029, ... Tue, 22 Nov 2022 10:05:48 GMT Chris Johns [8425e67] * cpukit/libmisc/shell/main_edit.c (modified) * cpukit/libmisc/shell/main_help.c (modified) * cpukit/libmisc/shell/shell.c (modified) libmisc/shell: Support terminal size as env variables Closes #4763 Fri, 18 Nov 2022 15:43:51 GMT Kinsey Moore [5b7eea6] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) cpukit/rtems-fdt: Avoid use of malloc/errno Use of malloc implies ... Mon, 14 Nov 2022 09:55:53 GMT Daniel Cederman [9384ac2] * cpukit/include/drvmgr/drvmgr.h (modified) * cpukit/include/drvmgr/drvmgr_confdefs.h (modified) * cpukit/include/drvmgr/drvmgr_list.h (modified) * cpukit/include/drvmgr/pci_bus.h (modified) * cpukit/include/pci.h (modified) * cpukit/include/pci/access.h (modified) * cpukit/include/pci/cfg.h (modified) * cpukit/include/pci/cfg_auto.h (modified) * cpukit/include/pci/cfg_peripheral.h (modified) * cpukit/include/pci/cfg_read.h (modified) * cpukit/include/pci/cfg_static.h (modified) * cpukit/include/pci/ids_extra.h (modified) * cpukit/include/pci/irq.h (modified) * cpukit/include/rtems/confdefs/libpci.h (modified) * cpukit/libmisc/shell/main_drvmgr.c (modified) * cpukit/libmisc/shell/main_pci.c (modified) * cpukit/score/cpu/riscv/include/libcpu/access.h (modified) * cpukit/score/cpu/sparc/include/libcpu/grlib-tn-0018.h (modified) cpukit: Change license to BSD-2 for files with Gaisler copyright ... Thu, 29 Sep 2022 13:35:37 GMT Sebastian Huber [829e489] * cpukit/include/rtems/stackchk.h (modified) * cpukit/libmisc/stackchk/check.c (modified) stackchk: Add rtems_stack_checker_iterate() Fri, 14 Oct 2022 02:43:08 GMT Chris Johns [580a3a68] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) libmisc/rtems-fdt: Fix return error values Updates #4729 Tue, 11 Oct 2022 01:50:30 GMT Chris Johns [fe104e39] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) libmisc/rtems-fdt: Fix missing error string - Coverity CID 1515930 ... Thu, 29 Sep 2022 05:47:30 GMT Chris Johns [40eb58f] * cpukit/include/rtems/rtems-fdt.h (modified) * cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c (modified) * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) libmisc/rtems-fdt: Update to support 64bit addresses - Add support ... Tue, 20 Sep 2022 15:30:12 GMT Kinsey Moore [3af84c1] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) cpukit/fdt: Free index before container Ensure that the index is ... Tue, 20 Sep 2022 15:24:59 GMT Kinsey Moore [584f5bc9] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) cpukit/fdt: Check correct allocation The second allocation check ... Tue, 02 Aug 2022 11:00:09 GMT Chris Johns [071640d] * cpukit/include/rtems/shellconfig.h (modified) * cpukit/libmisc/shell/main_rtems.c (added) * spec/build/cpukit/objshell.yml (modified) libmisc/shell: Add an 'rtems' command to report a running build - ... Tue, 14 Jun 2022 01:23:01 GMT Chris Johns [acc32a8] * cpukit/libmd/md5.c (modified) * cpukit/libmisc/shell/hexdump-conv.c (modified) * cpukit/libmisc/shell/main_edit.c (modified) cpukit: Fixes for GCC 12 warnings Updates #6442 Fri, 22 Apr 2022 15:46:14 GMT Ryan Long [27fd10d] * cpukit/libmisc/shell/main_getenv.c (modified) * cpukit/libmisc/shell/main_setenv.c (modified) * cpukit/libmisc/shell/main_unsetenv.c (modified) cpukit/libmisc: Add file headers and licenses These files had no ... Wed, 06 Apr 2022 06:16:36 GMT Sebastian Huber [2342625] * cpukit/include/rtems/shell.h (modified) * cpukit/libmisc/shell/shell.c (modified) shell: Add rtems_shell_run_main_loop() In contrast to ... Wed, 06 Apr 2022 06:40:45 GMT Sebastian Huber [a800e4de] * cpukit/libmisc/shell/shell.c (modified) shell: Move rtems_shell_init_environment() call Move ... Wed, 06 Apr 2022 06:36:06 GMT Sebastian Huber [3407a3b] * cpukit/libmisc/shell/shell.c (modified) shell: Add and use SHELL_MAGIC Tue, 05 Apr 2022 14:47:59 GMT Sebastian Huber [e765cfb] * cpukit/libmisc/shell/shell.c (modified) shell: Simplify rtems_shell_dup_current_env() Do not assign members ... Tue, 05 Apr 2022 14:34:38 GMT Sebastian Huber [1a8ad7e] * cpukit/libmisc/shell/shell.c (modified) shell: Refactor rtems_shell_main_loop() Disentangle the shell main ... Tue, 05 Apr 2022 14:00:53 GMT Sebastian Huber [9320c7ec] * cpukit/libmisc/shell/shell.c (modified) shell: Move line editor output check Move call to isatty() to ... Tue, 29 Mar 2022 07:35:40 GMT Chris Johns [500e6963] * cpukit/libmisc/untar/untar.c (modified) libmisc/untar: Use a larger block size to read and write files - A ... Fri, 01 Apr 2022 18:18:49 GMT Joel Sherrill [5f8c41c] * cpukit/include/rtems/pty.h (modified) * cpukit/include/rtems/shell.h (modified) * cpukit/include/rtems/telnetd.h (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/getgrent.c (modified) * cpukit/libcsupport/src/getgrnam.c (modified) * cpukit/libcsupport/src/getpwent.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/pwdgrp.c (modified) * cpukit/libmisc/shell/cat_file.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/login_check.c (modified) * cpukit/libmisc/shell/main_alias.c (modified) * cpukit/libmisc/shell/main_blksync.c (modified) * cpukit/libmisc/shell/main_cat.c (modified) * cpukit/libmisc/shell/main_cd.c (modified) * cpukit/libmisc/shell/main_chdir.c (modified) * cpukit/libmisc/shell/main_chmod.c (modified) * cpukit/libmisc/shell/main_chroot.c (modified) * cpukit/libmisc/shell/main_date.c (modified) * cpukit/libmisc/shell/main_dir.c (modified) * cpukit/libmisc/shell/main_exit.c (modified) * cpukit/libmisc/shell/main_id.c (modified) * cpukit/libmisc/shell/main_logoff.c (modified) * cpukit/libmisc/shell/main_mdump.c (modified) * cpukit/libmisc/shell/main_medit.c (modified) * cpukit/libmisc/shell/main_mfill.c (modified) * cpukit/libmisc/shell/main_mkdir.c (modified) * cpukit/libmisc/shell/main_mmove.c (modified) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/main_mount_nfs.c (modified) * cpukit/libmisc/shell/main_pwd.c (modified) * cpukit/libmisc/shell/main_rmdir.c (modified) * cpukit/libmisc/shell/main_tty.c (modified) * cpukit/libmisc/shell/main_umask.c (modified) * cpukit/libmisc/shell/main_unmount.c (modified) * cpukit/libmisc/shell/main_whoami.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) * cpukit/libmisc/shell/write_file.c (modified) * cpukit/telnetd/README (modified) * cpukit/telnetd/pty.c (modified) * cpukit/telnetd/telnetd.c (modified) Update email address of Fernando Ruiz Casas to ... Sat, 02 Apr 2022 19:16:42 GMT Joel Sherrill [2a7f7767] * cpukit/libmisc/dumpbuf/dumpbuf.c (modified) cpukit/libmisc/dumpbuf/dumpbuf.c: Manually change license to BSD-2 ... Thu, 24 Mar 2022 17:37:47 GMT Joel Sherrill [e4cc56a7] * cpukit/libmisc/monitor/mon-command.c (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/libmisc/monitor/mon-driver.c (modified) * cpukit/libmisc/monitor/mon-editor.c (modified) * cpukit/libmisc/monitor/mon-extension.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/libmisc/monitor/mon-manager.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-mpci.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-part.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/libmisc/monitor/mon-queue.c (modified) * cpukit/libmisc/monitor/mon-region.c (modified) * cpukit/libmisc/monitor/mon-sema.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/symbols.h (modified) cpukit/libmisc/monitor/: Manually change to BSD-2 license This code ... Fri, 18 Mar 2022 15:32:02 GMT Joel Sherrill [fab1a86] * cpukit/libmisc/untar/untar.c (modified) * cpukit/libmisc/untar/untar_tgz.c (modified) * cpukit/libmisc/untar/untar_txz.c (modified) cpukit/libmisc/untar: Change license to BSD-2 Updates #3053. Fri, 18 Mar 2022 15:30:46 GMT Joel Sherrill [ed4200e] * cpukit/libmisc/stackchk/check.c (modified) cpukit/libmisc/check: Change license to BSD-2 Updates #3053. Fri, 18 Mar 2022 15:29:34 GMT Joel Sherrill [50ec42c] * cpukit/libmisc/serdbg/serdbg.c (modified) * cpukit/libmisc/serdbg/serdbgio.c (modified) * cpukit/libmisc/serdbg/termios_printk.c (modified) cpukit/libmisc/serdbg: Change license to BSD-2 Updates #3053. Fri, 18 Mar 2022 15:28:33 GMT Joel Sherrill [c02836c] * cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c (modified) * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) cpukit/libmisc/rtems-fdt: Change license to BSD-2 Updates #3053. Fri, 18 Mar 2022 15:27:53 GMT Joel Sherrill [aa4c0102] * cpukit/libmisc/redirector/stdio-redirect.c (modified) cpukit/libmisc/redirector: Manually change license to BSD-2 Updates ... Fri, 18 Mar 2022 15:26:41 GMT Joel Sherrill [903bba25] * cpukit/libmisc/mouse/serial_mouse.c (modified) cpukit/libmisc/mouse: Change license to BSD-2 Updates #3053. Fri, 18 Mar 2022 15:24:46 GMT Joel Sherrill [8227a27] * cpukit/libmisc/fsmount/fsmount.c (modified) cpukit/libmisc/fsmount/fsmount.c: Manual header clean up Fri, 18 Mar 2022 15:24:03 GMT Joel Sherrill [ccf82871] * cpukit/libmisc/fsmount/fsmount.c (modified) cpukit/libmisc/fsmount: Change license to BSD-2. Updates #3053. Fri, 18 Mar 2022 15:22:17 GMT Joel Sherrill [3674288a] * cpukit/libmisc/dumpbuf/dumpbuf.c (modified) cpukit/libmisc/dumpbuf: Change license to BSD-2 Updates #3053. Fri, 18 Mar 2022 15:21:52 GMT Joel Sherrill [97236622] * cpukit/libmisc/dummy/default-configuration.c (modified) cpukit/libmisc/dummy: Change license to BSD-2. Updates #3053. Fri, 18 Mar 2022 15:20:36 GMT Joel Sherrill [183209b] * cpukit/libmisc/devnull/devzero.c (modified) cpukit/libmisc/devnull/devzero.c: Change license to BSD-2 Updates #3053. Fri, 18 Mar 2022 15:19:13 GMT Joel Sherrill [f147091] * cpukit/libmisc/cpuuse/cpuinforeport.c (modified) * cpukit/libmisc/cpuuse/cpuusagedata.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/cpuuse/cpuuseimpl.h (modified) cpukit/libmisc/cpuuse: Change license to BSD-2 Updates #3053. Fri, 18 Mar 2022 15:18:07 GMT Joel Sherrill [4b7fbc7] * cpukit/libmisc/capture/README (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/capture/capture_buffer.c (modified) * cpukit/libmisc/capture/capture_buffer.h (modified) * cpukit/libmisc/capture/capture_support.c (modified) * cpukit/libmisc/capture/capture_user_extension.c (modified) cpukit/libmisc/capture: Manually change license to BSD-2 These ... Fri, 18 Mar 2022 15:09:57 GMT Joel Sherrill [1dc5ba2a] * cpukit/libmisc/capture/rtems-trace-buffer-default.c (modified) * cpukit/libmisc/capture/rtems-trace-buffer-vars.c (modified) cpukit/capture: Change license to BSD-2 Updates #3053. Fri, 18 Mar 2022 15:08:54 GMT Joel Sherrill [152ab750] * cpukit/libmisc/bspcmdline/bspcmdline_get.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparam.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c (modified) cpukit/libmisc/bspcmdline: Change license to BSD-2 Updates #3053. Tue, 15 Mar 2022 06:24:55 GMT Sebastian Huber [b837c83] * cpukit/libmisc/shell/shell.c (modified) shell: Avoid potential stack corruption The rtems_shell_init() ... Mon, 07 Mar 2022 12:52:08 GMT Christian Mauderer [bb2e149e] * cpukit/include/rtems/fsmount.h (modified) * cpukit/include/rtems/ftpfs.h (modified) * cpukit/include/rtems/serdbg.h (modified) * cpukit/include/rtems/serdbgcnf.h (modified) * cpukit/include/rtems/termios_printk.h (modified) * cpukit/include/rtems/termios_printk_cnf.h (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/serdbg/serdbg.c (modified) * cpukit/libmisc/serdbg/serdbgio.c (modified) * cpukit/libmisc/serdbg/termios_printk.c (modified) cpukit: Automated IMD header file clean up Use the same form of IMD ... Thu, 03 Mar 2022 12:27:32 GMT Christian Mauderer [d7955b2] * bsps/i386/pc386/ata/ide.c (modified) * bsps/i386/pc386/ata/idecfg.c (modified) * cpukit/include/rtems/fsmount.h (modified) * cpukit/include/rtems/serdbg.h (modified) * cpukit/include/rtems/serdbgcnf.h (modified) * cpukit/include/rtems/termios_printk.h (modified) * cpukit/include/rtems/termios_printk_cnf.h (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/serdbg/serdbg.c (modified) bsps and cpukit: Manual file header clean up Updates #4625. Tue, 01 Mar 2022 20:40:44 GMT Joel Sherrill [255fe43] * cpukit/dev/i2c/eeprom.c (modified) * cpukit/dev/i2c/gpio-nxp-pca9535.c (modified) * cpukit/dev/i2c/i2c-bus.c (modified) * cpukit/dev/i2c/i2c-dev.c (modified) * cpukit/dev/i2c/sensor-lm75a.c (modified) * cpukit/dev/i2c/switch-nxp-pca9548a.c (modified) * cpukit/dev/serial/sc16is752-regs.h (modified) * cpukit/dev/serial/sc16is752-spi.c (modified) * cpukit/dev/serial/sc16is752.c (modified) * cpukit/dev/spi/spi-bus.c (modified) * cpukit/include/dev/i2c/eeprom.h (modified) * cpukit/include/dev/i2c/gpio-nxp-pca9535.h (modified) * cpukit/include/dev/i2c/i2c.h (modified) * cpukit/include/dev/i2c/sensor-lm75a.h (modified) * cpukit/include/dev/i2c/switch-nxp-pca9548a.h (modified) * cpukit/include/dev/serial/sc16is752.h (modified) * cpukit/include/dev/spi/spi.h (modified) * cpukit/include/linux/i2c-dev.h (modified) * cpukit/include/linux/i2c.h (modified) * cpukit/include/linux/rbtree.h (modified) * cpukit/include/linux/spi/spidev.h (modified) * cpukit/include/rtems/bsd.h (modified) * cpukit/include/rtems/counter.h (modified) * cpukit/include/rtems/devzero.h (modified) * cpukit/include/rtems/ftpfs.h (modified) * cpukit/include/rtems/jffs2.h (modified) * cpukit/include/rtems/linkersets.h (modified) * cpukit/include/rtems/media.h (modified) * cpukit/include/rtems/profiling.h (modified) * cpukit/include/rtems/rbheap.h (modified) * cpukit/include/rtems/scheduler.h (modified) * cpukit/include/rtems/score/assert.h (modified) * cpukit/include/rtems/score/io.h (modified) * cpukit/include/rtems/score/isrlock.h (modified) * cpukit/include/rtems/score/mrsp.h (modified) * cpukit/include/rtems/score/mrspimpl.h (modified) * cpukit/include/rtems/score/muteximpl.h (modified) * cpukit/include/rtems/score/onceimpl.h (modified) * cpukit/include/rtems/score/percpudata.h (modified) * cpukit/include/rtems/score/priorityimpl.h (modified) * cpukit/include/rtems/score/processormask.h (modified) * cpukit/include/rtems/score/profiling.h (modified) * cpukit/include/rtems/score/schedulercbsimpl.h (modified) * cpukit/include/rtems/score/schedulernode.h (modified) * cpukit/include/rtems/score/schedulernodeimpl.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/include/rtems/score/schedulersmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/semaphoreimpl.h (modified) * cpukit/include/rtems/score/smpbarrier.h (modified) * cpukit/include/rtems/score/status.h (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/timecounterimpl.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/include/rtems/sparse-disk.h (modified) * cpukit/include/rtems/status-checks.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/include/rtems/telnetd.h (modified) * cpukit/include/rtems/test-info.h (modified) * cpukit/include/rtems/thread.h (modified) * cpukit/include/rtems/timecounter.h (modified) * cpukit/libblock/src/bdpart-create.c (modified) * cpukit/libblock/src/bdpart-dump.c (modified) * cpukit/libblock/src/bdpart-read.c (modified) * cpukit/libblock/src/bdpart-register.c (modified) * cpukit/libblock/src/bdpart-sort.c (modified) * cpukit/libblock/src/bdpart-write.c (modified) * cpukit/libblock/src/blkdev-blkstats.c (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libblock/src/blkdev-ops.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (modified) * cpukit/libblock/src/diskdevs-init.c (modified) * cpukit/libblock/src/media-desc.c (modified) * cpukit/libblock/src/media-dev-ident.c (modified) * cpukit/libblock/src/media-path.c (modified) * cpukit/libblock/src/media-server.c (modified) * cpukit/libblock/src/media.c (modified) * cpukit/libblock/src/ramdisk-init.c (modified) * cpukit/libblock/src/ramdisk-register.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/libblock/src/sparse-disk.c (modified) * cpukit/libcrypt/crypt.c (modified) * cpukit/libcsupport/src/arc4random_getentropy_fail.c (modified) * cpukit/libcsupport/src/cachecoherentalloc.c (modified) * cpukit/libcsupport/src/clock.c (modified) * cpukit/libcsupport/src/clonenode.c (modified) * cpukit/libcsupport/src/consolesimple.h (modified) * cpukit/libcsupport/src/consolesimpleread.c (modified) * cpukit/libcsupport/src/getreentglobal.c (modified) * cpukit/libcsupport/src/libio_exit.c (modified) * cpukit/libcsupport/src/mount-mktgt.c (modified) * cpukit/libcsupport/src/printerfprintfputc.c (modified) * cpukit/libcsupport/src/printertask.c (modified) * cpukit/libcsupport/src/printf_plugin.c (modified) * cpukit/libcsupport/src/pwdgrp.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libcsupport/src/rtems_heap_extend.c (modified) * cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c (modified) * cpukit/libcsupport/src/rtems_heap_greedy.c (modified) * cpukit/libcsupport/src/rtems_heap_null_extend.c (modified) * cpukit/libcsupport/src/setgroups.c (modified) * cpukit/libcsupport/src/sup_fs_check_permissions.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path_generic.c (modified) * cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c (modified) * cpukit/libcsupport/src/sup_fs_location.c (modified) * cpukit/libcsupport/src/sup_fs_mount_iterate.c (modified) * cpukit/libcsupport/src/sup_fs_next_token.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libcsupport/src/uenvgetgroups.c (modified) * cpukit/libcsupport/src/vprintk.c (modified) * cpukit/libfs/src/defaults/default_are_nodes_equal.c (modified) * cpukit/libfs/src/defaults/default_clone.c (modified) * cpukit/libfs/src/defaults/default_eval_path.c (modified) * cpukit/libfs/src/defaults/default_fsync_success.c (modified) * cpukit/libfs/src/defaults/default_ftruncate_directory.c (modified) * cpukit/libfs/src/defaults/default_handlers.c (modified) * cpukit/libfs/src/defaults/default_kqfilter.c (modified) * cpukit/libfs/src/defaults/default_lock_and_unlock.c (modified) * cpukit/libfs/src/defaults/default_lseek_directory.c (modified) * cpukit/libfs/src/defaults/default_lseek_file.c (modified) * cpukit/libfs/src/defaults/default_poll.c (modified) * cpukit/libfs/src/defaults/default_readv.c (modified) * cpukit/libfs/src/defaults/default_writev.c (modified) * cpukit/libfs/src/dosfs/msdos_conv_default.c (modified) * cpukit/libfs/src/dosfs/msdos_conv_utf8.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/jffs2/include/linux/kernel-rtems.h (modified) * cpukit/libmisc/cpuuse/cpuinforeport.c (modified) * cpukit/libmisc/devnull/devzero.c (modified) * cpukit/libmisc/shell/fdisk.c (modified) * cpukit/libmisc/shell/login_check.c (modified) * cpukit/libmisc/shell/login_prompt.c (modified) * cpukit/libmisc/shell/main_blkstats.c (modified) * cpukit/libmisc/shell/main_cmdchmod.c (modified) * cpukit/libmisc/shell/main_cmdchown.c (modified) * cpukit/libmisc/shell/main_cmdls.c (modified) * cpukit/libmisc/shell/main_cpuinfo.c (modified) * cpukit/libmisc/shell/main_lsof.c (modified) * cpukit/libmisc/shell/main_profreport.c (modified) * cpukit/libmisc/shell/main_rtc.c (modified) * cpukit/libmisc/shell/shell-wait-for-input.c (modified) * cpukit/libmisc/untar/untar_tgz.c (modified) * cpukit/libtest/testbeginend.c (modified) * cpukit/libtest/testbusy.c (modified) * cpukit/libtest/testextension.c (modified) * cpukit/libtest/testparallel.c (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * cpukit/rtems/src/rtemsmaxprio.c (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/rtems/src/statustext.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/taskexit.c (modified) * cpukit/rtems/src/taskgetpriority.c (modified) * cpukit/rtems/src/taskgetscheduler.c (modified) * cpukit/rtems/src/taskiterate.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/rtems/src/workspacegreedy.c (modified) * cpukit/sapi/src/chainappendnotify.c (modified) * cpukit/sapi/src/chaingetnotify.c (modified) * cpukit/sapi/src/chaingetwait.c (modified) * cpukit/sapi/src/chainprependnotify.c (modified) * cpukit/sapi/src/chainprotected.c (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * cpukit/sapi/src/delaynano.c (modified) * cpukit/sapi/src/delayticks.c (modified) * cpukit/sapi/src/fatalsrctext.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/sapi/src/panic.c (modified) * cpukit/sapi/src/profilingiterate.c (modified) * cpukit/sapi/src/profilingreportxml.c (modified) * cpukit/sapi/src/rbheap.c (modified) * cpukit/sapi/src/tcsimpleinstall.c (modified) * cpukit/score/cpu/arm/__aeabi_read_tp.c (modified) * cpukit/score/cpu/arm/__tls_get_addr.c (modified) * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) * cpukit/score/cpu/arm/arm-exception-default.c (modified) * cpukit/score/cpu/arm/arm-exception-frame-print.c (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (modified) * cpukit/score/cpu/arm/armv4-sync-synchronize.c (modified) * cpukit/score/cpu/arm/armv7-thread-idle.c (modified) * cpukit/score/cpu/arm/armv7m-context-initialize.c (modified) * cpukit/score/cpu/arm/armv7m-context-restore.c (modified) * cpukit/score/cpu/arm/armv7m-context-switch.c (modified) * cpukit/score/cpu/arm/armv7m-exception-default.c (modified) * cpukit/score/cpu/arm/armv7m-exception-handler-get.c (modified) * cpukit/score/cpu/arm/armv7m-exception-handler-set.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-get.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-handler.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-set.c (modified) * cpukit/score/cpu/arm/armv7m-isr-dispatch.c (modified) * cpukit/score/cpu/arm/armv7m-isr-enter-leave.c (modified) * cpukit/score/cpu/arm/armv7m-isr-level-get.c (modified) * cpukit/score/cpu/arm/armv7m-isr-level-set.c (modified) * cpukit/score/cpu/arm/armv7m-isr-vector-install.c (modified) * cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c (modified) * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) * cpukit/score/cpu/arm/include/rtems/score/armv4.h (modified) * cpukit/score/cpu/arm/include/rtems/score/armv7m.h (modified) * cpukit/score/cpu/bfin/bfin-exception-frame-print.c (modified) * cpukit/score/cpu/lm32/lm32-exception-frame-print.c (modified) * cpukit/score/cpu/m68k/__m68k_read_tp.c (modified) * cpukit/score/cpu/m68k/m68k-exception-frame-print.c (modified) * cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h (modified) * cpukit/score/cpu/nios2/nios2-context-validate.S (modified) * cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S (modified) * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-exception-frame-print.c (modified) * cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-add-region.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-configuration.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-descriptor.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-reset.c (modified) * cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c (modified) * cpukit/score/cpu/no_cpu/cpucounterfrequency.c (modified) * cpukit/score/cpu/no_cpu/cpucounterread.c (modified) * cpukit/score/cpu/no_cpu/cpuidle.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S (modified) * cpukit/score/cpu/sh/sh-exception-frame-print.c (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) * cpukit/score/cpu/sparc/sparc-counter-asm.S (modified) * cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c (modified) * cpukit/score/cpu/v850/v850-exception-frame-print.c (modified) * cpukit/score/src/allocatormutex.c (modified) * cpukit/score/src/chainnodecount.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/debugisthreaddispatchingallowed.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/heapgreedy.c (modified) * cpukit/score/src/heapiterate.c (modified) * cpukit/score/src/heapnoextend.c (modified) * cpukit/score/src/ioprintf.c (modified) * cpukit/score/src/isrisinprogress.c (modified) * cpukit/score/src/libatomic.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/objectactivecount.c (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/percpuasm.c (modified) * cpukit/score/src/percpustatewait.c (modified) * cpukit/score/src/pheapiterate.c (modified) * cpukit/score/src/processormaskcopy.c (modified) * cpukit/score/src/profilingisrentryexit.c (modified) * cpukit/score/src/profilingsmplock.c (modified) * cpukit/score/src/rbtreeiterate.c (modified) * cpukit/score/src/rbtreepostorder.c (modified) * cpukit/score/src/rbtreereplace.c (modified) * cpukit/score/src/sched.c (modified) * cpukit/score/src/schedulergetaffinity.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/smpbarrierwait.c (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/threadentryadaptoridle.c (modified) * cpukit/score/src/threadentryadaptornumeric.c (modified) * cpukit/score/src/threadentryadaptorpointer.c (modified) * cpukit/score/src/threadgetcputimeused.c (modified) * cpukit/score/src/threaditerate.c (modified) * cpukit/score/src/threadqops.c (modified) * cpukit/score/src/threadscheduler.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) * cpukit/score/src/threadyield.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogtick.c (modified) * cpukit/score/src/wkstringduplicate.c (modified) * cpukit/telnetd/check_passwd.c (modified) cpukit/: Scripted embedded brains header file clean up Updates #4625. Tue, 01 Mar 2022 20:39:46 GMT Joel Sherrill [d8369225] * cpukit/libi2c/libi2c.c (modified) * cpukit/libmisc/serdbg/serdbgio.c (modified) * cpukit/libmisc/serdbg/termios_printk.c (modified) libmisc/serdbg: Manual header clean up Updates #4625. Wed, 26 Jan 2022 22:00:04 GMT Kinsey Moore [b539af8] * cpukit/libmisc/stackchk/check.c (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/stackchk02.yml (added) * testsuites/libtests/stackchk02/init.c (added) * testsuites/libtests/stackchk02/stackchk02.doc (added) * testsuites/libtests/stackchk02/stackchk02.scn (added) cpukit: Prevent error with disabled stack checker When the stack ... Thu, 16 Dec 2021 20:36:19 GMT Ryan Long [98ab693] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) libmisc/rtems-fdt: close() file 'bf' close() file 'bf' to avoid ... Wed, 01 Dec 2021 15:39:46 GMT Christian Mauderer [ffc57e3] * cpukit/libmisc/untar/untar.c (modified) * testsuites/libtests/tar01/init.c (modified) * testsuites/libtests/tar01/tar01.doc (modified) * testsuites/libtests/tar01/tar01.scn (modified) * testsuites/libtests/tar01/tar01.tar (modified) untar: Make behavior similar to GNU or BSD tar RTEMS untar ... Thu, 02 Dec 2021 13:00:53 GMT Sebastian Huber [0d83bed2] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/scheduler.h (added) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetmaxprio.c (modified) * cpukit/rtems/src/schedulergetprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessormax.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (modified) * cpukit/rtems/src/schedulermapfromposix.c (modified) * cpukit/rtems/src/schedulermaptoposix.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) rtems: Move scheduler directives to own header Move all ... Tue, 12 Oct 2021 06:26:39 GMT Sebastian Huber [0221da5f] * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libtest/testbusy.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/score/src/threadgetcputimeused.c (modified) * cpukit/score/src/threadgetcputimeusedafterreset.c (added) * spec/build/cpukit/librtemscpu.yml (modified) rtems: Fix rate monotonic statistics The rate monotonic period ... Sat, 21 Aug 2021 02:49:36 GMT Chris Johns [8f3973f] * cpukit/libmisc/shell/shell_cmdset.c (modified) libmisc/shell: Check the shell command pointers when adding a command Sat, 21 Aug 2021 02:46:32 GMT Chris Johns [4dc81f65] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) libmisc/fdt: fix node initialise error with RTEMS_DEBUG Tue, 10 Aug 2021 10:42:11 GMT Sebastian Huber [9399e12c] * cpukit/include/rtems/monitor.h (modified) * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/libmisc/monitor/mon-part.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) rtems: Fix rtems_partition_return_buffer() The ... Tue, 08 Jun 2021 15:03:53 GMT Ryan Long [4127a6c] * cpukit/libmisc/shell/main_edit.c (modified) main_edit.c: get rid of malloc warning A warning was present when ... Fri, 28 May 2021 00:31:53 GMT Harrison Edward Gerber [6a56fd9] * cpukit/libmisc/monitor/mon-editor.c (modified) cpukit/libmisc/monitor: Fix src/dest overlap of strcpy in mon- ... Tue, 30 Mar 2021 15:04:07 GMT Ryan Long [2deba02] * cpukit/libmisc/shell/main_help.c (modified) main_help.c: Do not care what char is returned by getchar() CID ... Thu, 25 Mar 2021 14:10:39 GMT Ryan Long [f29b312e] * cpukit/libmisc/shell/main_cp.c (modified) main_cp.c: Ignore return value from stat() CID 26051: Unchecked ... Thu, 25 Mar 2021 13:59:26 GMT Ryan Long [a187b09] * cpukit/libmisc/uuid/gen_uuid.c (modified) gen_uuid.c: Ignore return values from fcntl() CID 1049146: ... Thu, 18 Mar 2021 17:01:27 GMT Stephen Clark [cd5fd85] * cpukit/libmisc/stackchk/check.c (modified) stackchk: Fixed 32bit pointers Using 32bit types like uint32_t for ... Thu, 18 Mar 2021 16:54:03 GMT Stephen Clark [ca02143] * cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c (modified) rtems-fdt: Fixed 32bit pointers Using 32bit types like uint32_t for ... Wed, 10 Mar 2021 18:51:20 GMT Ryan Long [8cf30c4] * cpukit/libmisc/shell/main_rtrace.c (modified) main_rtrace.c: Add error return when malloc fails CID 1399709: ... Fri, 12 Mar 2021 20:25:40 GMT Ryan Long [0b23660] * cpukit/libmisc/shell/print-ls.c (modified) print-ls.c: Unused value (CID #1255346) CID 1255346: Unused value ... Fri, 12 Mar 2021 17:14:47 GMT Ryan Long [fbc76440] * cpukit/libmisc/shell/main_cp.c (modified) main_cp.c: Unused value (CID #1255344) CID 1255344: Unused value in ... Thu, 25 Feb 2021 02:06:38 GMT Vijay Kumar Banerjee [2a13ad3] * cpukit/libmisc/dummy/dummy-networking.c (deleted) * cpukit/libmisc/monitor/mon-network.c (deleted) * cpukit/libmisc/shell/main_ifconfig.c (deleted) * cpukit/libmisc/shell/main_netstats.c (deleted) * cpukit/libmisc/shell/main_ping.c (deleted) * cpukit/libmisc/shell/main_route.c (deleted) * cpukit/libnetworking/README (deleted) * cpukit/libnetworking/arpa/nameser.h (deleted) * cpukit/libnetworking/arpa/nameser_compat.h (deleted) * cpukit/libnetworking/bpfilter.h (deleted) * cpukit/libnetworking/dev/mii/mii.h (deleted) * cpukit/libnetworking/headers.am (deleted) * cpukit/libnetworking/ifaddrs.h (deleted) * cpukit/libnetworking/kern/kern_mib.c (deleted) * cpukit/libnetworking/kern/kern_subr.c (deleted) * cpukit/libnetworking/kern/kern_sysctl.c (deleted) * cpukit/libnetworking/kern/uipc_domain.c (deleted) * cpukit/libnetworking/kern/uipc_mbuf.c (deleted) * cpukit/libnetworking/kern/uipc_socket.c (deleted) * cpukit/libnetworking/kern/uipc_socket2.c (deleted) * cpukit/libnetworking/lib/README (deleted) * cpukit/libnetworking/lib/getprotoby.c (deleted) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (deleted) * cpukit/libnetworking/lib/syslog.c (deleted) * cpukit/libnetworking/libc/base64.c (deleted) * cpukit/libnetworking/libc/byteorder.3 (deleted) * cpukit/libnetworking/libc/ethers.3 (deleted) * cpukit/libnetworking/libc/gethostbydns.c (deleted) * cpukit/libnetworking/libc/gethostbyht.c (deleted) * cpukit/libnetworking/libc/gethostbyname.3 (deleted) * cpukit/libnetworking/libc/gethostbynis.c (deleted) * cpukit/libnetworking/libc/gethostnamadr.c (deleted) * cpukit/libnetworking/libc/getifaddrs.c (deleted) * cpukit/libnetworking/libc/getnameinfo.c (deleted) * cpukit/libnetworking/libc/getnetbydns.c (deleted) * cpukit/libnetworking/libc/getnetbyht.c (deleted) * cpukit/libnetworking/libc/getnetbynis.c (deleted) * cpukit/libnetworking/libc/getnetent.3 (deleted) * cpukit/libnetworking/libc/getnetnamadr.c (deleted) * cpukit/libnetworking/libc/getproto.c (deleted) * cpukit/libnetworking/libc/getprotoent.3 (deleted) * cpukit/libnetworking/libc/getprotoent.c (deleted) * cpukit/libnetworking/libc/getprotoname.c (deleted) * cpukit/libnetworking/libc/getservbyname.c (deleted) * cpukit/libnetworking/libc/getservbyport.c (deleted) * cpukit/libnetworking/libc/getservent.3 (deleted) * cpukit/libnetworking/libc/getservent.c (deleted) * cpukit/libnetworking/libc/herror.c (deleted) * cpukit/libnetworking/libc/if_indextoname.c (deleted) * cpukit/libnetworking/libc/if_nameindex.c (deleted) * cpukit/libnetworking/libc/inet.3 (deleted) * cpukit/libnetworking/libc/inet_addr.c (deleted) * cpukit/libnetworking/libc/inet_lnaof.c (deleted) * cpukit/libnetworking/libc/inet_makeaddr.c (deleted) * cpukit/libnetworking/libc/inet_netof.c (deleted) * cpukit/libnetworking/libc/inet_network.c (deleted) * cpukit/libnetworking/libc/inet_ntoa.c (deleted) * cpukit/libnetworking/libc/inet_ntop.c (deleted) * cpukit/libnetworking/libc/inet_pton.c (deleted) * cpukit/libnetworking/libc/linkaddr.3 (deleted) * cpukit/libnetworking/libc/linkaddr.c (deleted) * cpukit/libnetworking/libc/map_v4v6.c (deleted) * cpukit/libnetworking/libc/ns.3 (deleted) * cpukit/libnetworking/libc/ns_name.c (deleted) * cpukit/libnetworking/libc/ns_netint.c (deleted) * cpukit/libnetworking/libc/ns_parse.c (deleted) * cpukit/libnetworking/libc/ns_print.c (deleted) * cpukit/libnetworking/libc/ns_ttl.c (deleted) * cpukit/libnetworking/libc/nsap_addr.c (deleted) * cpukit/libnetworking/libc/port_after.h (deleted) * cpukit/libnetworking/libc/port_before.h (deleted) * cpukit/libnetworking/libc/rcmd.3 (deleted) * cpukit/libnetworking/libc/rcmd.c (deleted) * cpukit/libnetworking/libc/recv.c (deleted) * cpukit/libnetworking/libc/res_comp.c (deleted) * cpukit/libnetworking/libc/res_config.h (deleted) * cpukit/libnetworking/libc/res_data.c (deleted) * cpukit/libnetworking/libc/res_debug.c (deleted) * cpukit/libnetworking/libc/res_init.c (deleted) * cpukit/libnetworking/libc/res_mkquery.c (deleted) * cpukit/libnetworking/libc/res_mkupdate.c (deleted) * cpukit/libnetworking/libc/res_query.c (deleted) * cpukit/libnetworking/libc/res_send.c (deleted) * cpukit/libnetworking/libc/res_stubs.c (deleted) * cpukit/libnetworking/libc/res_update.c (deleted) * cpukit/libnetworking/libc/resolver.3 (deleted) * cpukit/libnetworking/libc/send.c (deleted) * cpukit/libnetworking/librtemsNfs.h (deleted) * cpukit/libnetworking/loop.h (deleted) * cpukit/libnetworking/machine/_align.h (deleted) * cpukit/libnetworking/machine/_kernel_if.h (deleted) * cpukit/libnetworking/machine/_kernel_lock.h (deleted) * cpukit/libnetworking/machine/_kernel_socket.h (deleted) * cpukit/libnetworking/machine/cpu.h (deleted) * cpukit/libnetworking/machine/cpufunc.h (deleted) * cpukit/libnetworking/machine/in_cksum.h (deleted) * cpukit/libnetworking/machine/limits.h (deleted) * cpukit/libnetworking/machine/rtems-bsd-kernel-space.h (deleted) * cpukit/libnetworking/machine/rtems-bsd-user-space.h (deleted) * cpukit/libnetworking/machine/vmparam.h (deleted) * cpukit/libnetworking/net/bpf.h (deleted) * cpukit/libnetworking/net/ethernet.h (deleted) * cpukit/libnetworking/net/if.c (deleted) * cpukit/libnetworking/net/if_arp.h (deleted) * cpukit/libnetworking/net/if_dl.h (deleted) * cpukit/libnetworking/net/if_ethersubr.c (deleted) * cpukit/libnetworking/net/if_llc.h (deleted) * cpukit/libnetworking/net/if_loop.c (deleted) * cpukit/libnetworking/net/if_media.h (deleted) * cpukit/libnetworking/net/if_ppp.c (deleted) * cpukit/libnetworking/net/if_ppp.h (deleted) * cpukit/libnetworking/net/if_pppvar.h (deleted) * cpukit/libnetworking/net/if_types.h (deleted) * cpukit/libnetworking/net/if_var.h (deleted) * cpukit/libnetworking/net/netisr.h (deleted) * cpukit/libnetworking/net/ppp_comp.h (deleted) * cpukit/libnetworking/net/ppp_defs.h (deleted) * cpukit/libnetworking/net/ppp_tty.c (deleted) * cpukit/libnetworking/net/radix.c (deleted) * cpukit/libnetworking/net/radix.h (deleted) * cpukit/libnetworking/net/raw_cb.c (deleted) * cpukit/libnetworking/net/raw_cb.h (deleted) * cpukit/libnetworking/net/raw_usrreq.c (deleted) * cpukit/libnetworking/net/route.c (deleted) * cpukit/libnetworking/net/route.h (deleted) * cpukit/libnetworking/net/rtsock.c (deleted) * cpukit/libnetworking/net/slcompress.c (deleted) * cpukit/libnetworking/net/slcompress.h (deleted) * cpukit/libnetworking/netinet/icmp_var.h (deleted) * cpukit/libnetworking/netinet/if_ether.c (deleted) * cpukit/libnetworking/netinet/if_ether.h (deleted) * cpukit/libnetworking/netinet/igmp.c (deleted) * cpukit/libnetworking/netinet/igmp.h (deleted) * cpukit/libnetworking/netinet/igmp_var.h (deleted) * cpukit/libnetworking/netinet/in.c (deleted) * cpukit/libnetworking/netinet/in_cksum.c (deleted) * cpukit/libnetworking/netinet/in_cksum_arm.h (deleted) * cpukit/libnetworking/netinet/in_cksum_i386.h (deleted) * cpukit/libnetworking/netinet/in_cksum_m68k.h (deleted) * cpukit/libnetworking/netinet/in_cksum_nios2.h (deleted) * cpukit/libnetworking/netinet/in_cksum_powerpc.h (deleted) * cpukit/libnetworking/netinet/in_cksum_sparc.h (deleted) * cpukit/libnetworking/netinet/in_pcb.c (deleted) * cpukit/libnetworking/netinet/in_pcb.h (deleted) * cpukit/libnetworking/netinet/in_proto.c (deleted) * cpukit/libnetworking/netinet/in_rmx.c (deleted) * cpukit/libnetworking/netinet/in_systm.h (deleted) * cpukit/libnetworking/netinet/in_var.h (deleted) * cpukit/libnetworking/netinet/ip.h (deleted) * cpukit/libnetworking/netinet/ip_divert.c (deleted) * cpukit/libnetworking/netinet/ip_fw.c (deleted) * cpukit/libnetworking/netinet/ip_fw.h (deleted) * cpukit/libnetworking/netinet/ip_icmp.c (deleted) * cpukit/libnetworking/netinet/ip_icmp.h (deleted) * cpukit/libnetworking/netinet/ip_input.c (deleted) * cpukit/libnetworking/netinet/ip_mroute.c (deleted) * cpukit/libnetworking/netinet/ip_mroute.h (deleted) * cpukit/libnetworking/netinet/ip_output.c (deleted) * cpukit/libnetworking/netinet/ip_var.h (deleted) * cpukit/libnetworking/netinet/raw_ip.c (deleted) * cpukit/libnetworking/netinet/tcp_debug.c (deleted) * cpukit/libnetworking/netinet/tcp_debug.h (deleted) * cpukit/libnetworking/netinet/tcp_fsm.h (deleted) * cpukit/libnetworking/netinet/tcp_input.c (deleted) * cpukit/libnetworking/netinet/tcp_output.c (deleted) * cpukit/libnetworking/netinet/tcp_seq.h (deleted) * cpukit/libnetworking/netinet/tcp_subr.c (deleted) * cpukit/libnetworking/netinet/tcp_timer.c (deleted) * cpukit/libnetworking/netinet/tcp_timer.h (deleted) * cpukit/libnetworking/netinet/tcp_usrreq.c (deleted) * cpukit/libnetworking/netinet/tcp_var.h (deleted) * cpukit/libnetworking/netinet/tcpip.h (deleted) * cpukit/libnetworking/netinet/udp.h (deleted) * cpukit/libnetworking/netinet/udp_usrreq.c (deleted) * cpukit/libnetworking/netinet/udp_var.h (deleted) * cpukit/libnetworking/nfs/bootp_subr.c (deleted) * cpukit/libnetworking/nfs/nfsproto.h (deleted) * cpukit/libnetworking/nfs/rpcv2.h (deleted) * cpukit/libnetworking/nfs/xdr_subs.h (deleted) * cpukit/libnetworking/nfsclient/nfsargs.h (deleted) * cpukit/libnetworking/nfsclient/nfsdiskless.h (deleted) * cpukit/libnetworking/opt_atalk.h (deleted) * cpukit/libnetworking/opt_bdg.h (deleted) * cpukit/libnetworking/opt_compat.h (deleted) * cpukit/libnetworking/opt_inet.h (deleted) * cpukit/libnetworking/opt_inet6.h (deleted) * cpukit/libnetworking/opt_ipfw.h (deleted) * cpukit/libnetworking/opt_ipsec.h (deleted) * cpukit/libnetworking/opt_ipx.h (deleted) * cpukit/libnetworking/opt_mac.h (deleted) * cpukit/libnetworking/opt_mrouting.h (deleted) * cpukit/libnetworking/opt_netgraph.h (deleted) * cpukit/libnetworking/opt_ppp.h (deleted) * cpukit/libnetworking/opt_tcpdebug.h (deleted) * cpukit/libnetworking/resolv.h (deleted) * cpukit/libnetworking/rpc/auth.h (deleted) * cpukit/libnetworking/rpc/auth_unix.h (deleted) * cpukit/libnetworking/rpc/clnt.h (deleted) * cpukit/libnetworking/rpc/clnt_soc.h (deleted) * cpukit/libnetworking/rpc/clnt_stat.h (deleted) * cpukit/libnetworking/rpc/pmap_clnt.h (deleted) * cpukit/libnetworking/rpc/pmap_prot.h (deleted) * cpukit/libnetworking/rpc/pmap_rmt.h (deleted) * cpukit/libnetworking/rpc/rpc.h (deleted) * cpukit/libnetworking/rpc/rpc_com.h (deleted) * cpukit/libnetworking/rpc/rpc_msg.h (deleted) * cpukit/libnetworking/rpc/rpcent.h (deleted) * cpukit/libnetworking/rpc/svc.h (deleted) * cpukit/libnetworking/rpc/svc_auth.h (deleted) * cpukit/libnetworking/rpc/svc_soc.h (deleted) * cpukit/libnetworking/rpc/types.h (deleted) * cpukit/libnetworking/rpc/xdr.h (deleted) * cpukit/libnetworking/rtems/bootp.h (deleted) * cpukit/libnetworking/rtems/bsdnet/_types.h (deleted) * cpukit/libnetworking/rtems/bsdnet/servers.h (deleted) * cpukit/libnetworking/rtems/dhcp.h (deleted) * cpukit/libnetworking/rtems/mkrootfs.c (deleted) * cpukit/libnetworking/rtems/mkrootfs.h (deleted) * cpukit/libnetworking/rtems/rtems_bootp.c (deleted) * cpukit/libnetworking/rtems/rtems_bsdnet.h (deleted) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (deleted) * cpukit/libnetworking/rtems/rtems_bsdnet_malloc_starvation.c (deleted) * cpukit/libnetworking/rtems/rtems_dhcp.c (deleted) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (deleted) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.h (deleted) * cpukit/libnetworking/rtems/rtems_glue.c (deleted) * cpukit/libnetworking/rtems/rtems_malloc_mbuf.c (deleted) * cpukit/libnetworking/rtems/rtems_mii_ioctl.c (deleted) * cpukit/libnetworking/rtems/rtems_mii_ioctl.h (deleted) * cpukit/libnetworking/rtems/rtems_mii_ioctl_kern.c (deleted) * cpukit/libnetworking/rtems/rtems_netdb.h (deleted) * cpukit/libnetworking/rtems/rtems_netinet_in.h (deleted) * cpukit/libnetworking/rtems/rtems_select.c (deleted) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (deleted) * cpukit/libnetworking/rtems/rtems_showifstat.c (deleted) * cpukit/libnetworking/rtems/rtems_showipstat.c (deleted) * cpukit/libnetworking/rtems/rtems_showmbuf.c (deleted) * cpukit/libnetworking/rtems/rtems_showroute.c (deleted) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (deleted) * cpukit/libnetworking/rtems/rtems_showudpstat.c (deleted) * cpukit/libnetworking/rtems/rtems_socketpair.c (deleted) * cpukit/libnetworking/rtems/rtems_syscall.c (deleted) * cpukit/libnetworking/rtems/rtems_syscall.h (deleted) * cpukit/libnetworking/rtems/rtems_syscall_api.c (deleted) * cpukit/libnetworking/rtems/sghostname.c (deleted) * cpukit/libnetworking/sys/callout.h (deleted) * cpukit/libnetworking/sys/conf.h (deleted) * cpukit/libnetworking/sys/domain.h (deleted) * cpukit/libnetworking/sys/kernel.h (deleted) * cpukit/libnetworking/sys/libkern.h (deleted) * cpukit/libnetworking/sys/linker_set.h (deleted) * cpukit/libnetworking/sys/malloc.h (deleted) * cpukit/libnetworking/sys/mbuf.h (deleted) * cpukit/libnetworking/sys/mount.h (deleted) * cpukit/libnetworking/sys/proc.h (deleted) * cpukit/libnetworking/sys/protosw.h (deleted) * cpukit/libnetworking/sys/reboot.h (deleted) * cpukit/libnetworking/sys/resourcevar.h (deleted) * cpukit/libnetworking/sys/selinfo.h (deleted) * cpukit/libnetworking/sys/signalvar.h (deleted) * cpukit/libnetworking/sys/socketvar.h (deleted) * cpukit/libnetworking/sys/sysctl.h (deleted) * cpukit/libnetworking/sys/systm.h (deleted) * cpukit/libnetworking/sys/ucred.h (deleted) * cpukit/libnetworking/vm/vm.h (deleted) * cpukit/libnetworking/vm/vm_extern.h (deleted) * cpukit/libnetworking/vm/vm_kern.h (deleted) * cpukit/libnetworking/vm/vm_param.h (deleted) * cpukit/librpc/README_RTEMS (deleted) * cpukit/librpc/include/rpcsvc/bootparam_prot.x (deleted) * cpukit/librpc/include/rpcsvc/crypt.x (deleted) * cpukit/librpc/include/rpcsvc/key_prot.x (deleted) * cpukit/librpc/include/rpcsvc/klm_prot.x (deleted) * cpukit/librpc/include/rpcsvc/mount.x (deleted) * cpukit/librpc/include/rpcsvc/nfs_prot.x (deleted) * cpukit/librpc/include/rpcsvc/nis.x (deleted) * cpukit/librpc/include/rpcsvc/nis_cache.x (deleted) * cpukit/librpc/include/rpcsvc/nis_callback.x (deleted) * cpukit/librpc/include/rpcsvc/nis_db.h (deleted) * cpukit/librpc/include/rpcsvc/nis_object.x (deleted) * cpukit/librpc/include/rpcsvc/nis_tags.h (deleted) * cpukit/librpc/include/rpcsvc/nislib.h (deleted) * cpukit/librpc/include/rpcsvc/nlm_prot.x (deleted) * cpukit/librpc/include/rpcsvc/pmap_prot.x (deleted) * cpukit/librpc/include/rpcsvc/rex.x (deleted) * cpukit/librpc/include/rpcsvc/rnusers.x (deleted) * cpukit/librpc/include/rpcsvc/rquota.x (deleted) * cpukit/librpc/include/rpcsvc/rstat.x (deleted) * cpukit/librpc/include/rpcsvc/rwall.x (deleted) * cpukit/librpc/include/rpcsvc/sm_inter.x (deleted) * cpukit/librpc/include/rpcsvc/spray.x (deleted) * cpukit/librpc/include/rpcsvc/yp.x (deleted) * cpukit/librpc/include/rpcsvc/yp_prot.h (deleted) * cpukit/librpc/include/rpcsvc/ypclnt.h (deleted) * cpukit/librpc/include/rpcsvc/yppasswd.x (deleted) * cpukit/librpc/include/rpcsvc/ypupdate_prot.x (deleted) * cpukit/librpc/include/rpcsvc/ypxfrd.x (deleted) * cpukit/librpc/src/rpc/DISCLAIMER (deleted) * cpukit/librpc/src/rpc/README (deleted) * cpukit/librpc/src/rpc/auth_none.c (deleted) * cpukit/librpc/src/rpc/auth_unix.c (deleted) * cpukit/librpc/src/rpc/authunix_prot.c (deleted) * cpukit/librpc/src/rpc/bindresvport.3 (deleted) * cpukit/librpc/src/rpc/bindresvport.c (deleted) * cpukit/librpc/src/rpc/clnt_generic.c (deleted) * cpukit/librpc/src/rpc/clnt_perror.c (deleted) * cpukit/librpc/src/rpc/clnt_raw.c (deleted) * cpukit/librpc/src/rpc/clnt_simple.c (deleted) * cpukit/librpc/src/rpc/clnt_tcp.c (deleted) * cpukit/librpc/src/rpc/clnt_udp.c (deleted) * cpukit/librpc/src/rpc/des_crypt.3 (deleted) * cpukit/librpc/src/rpc/get_myaddress.c (deleted) * cpukit/librpc/src/rpc/getrpcent.3 (deleted) * cpukit/librpc/src/rpc/getrpcent.c (deleted) * cpukit/librpc/src/rpc/getrpcport.3 (deleted) * cpukit/librpc/src/rpc/getrpcport.c (deleted) * cpukit/librpc/src/rpc/netname.c (deleted) * cpukit/librpc/src/rpc/netnamer.c (deleted) * cpukit/librpc/src/rpc/pmap_clnt.c (deleted) * cpukit/librpc/src/rpc/pmap_getmaps.c (deleted) * cpukit/librpc/src/rpc/pmap_getport.c (deleted) * cpukit/librpc/src/rpc/pmap_prot.c (deleted) * cpukit/librpc/src/rpc/pmap_prot2.c (deleted) * cpukit/librpc/src/rpc/pmap_rmt.c (deleted) * cpukit/librpc/src/rpc/publickey.3 (deleted) * cpukit/librpc/src/rpc/publickey.5 (deleted) * cpukit/librpc/src/rpc/rpc.3 (deleted) * cpukit/librpc/src/rpc/rpc.5 (deleted) * cpukit/librpc/src/rpc/rpc_callmsg.c (deleted) * cpukit/librpc/src/rpc/rpc_commondata.c (deleted) * cpukit/librpc/src/rpc/rpc_dtablesize.c (deleted) * cpukit/librpc/src/rpc/rpc_prot.c (deleted) * cpukit/librpc/src/rpc/rpc_secure.3 (deleted) * cpukit/librpc/src/rpc/rpcdname.c (deleted) * cpukit/librpc/src/rpc/rstat.1 (deleted) * cpukit/librpc/src/rpc/rstat_svc.8 (deleted) * cpukit/librpc/src/rpc/rtems-rpc-config.h (deleted) * cpukit/librpc/src/rpc/rtems_portmapper.c (deleted) * cpukit/librpc/src/rpc/rtems_rpc.c (deleted) * cpukit/librpc/src/rpc/rtime.3 (deleted) * cpukit/librpc/src/rpc/rtime.c (deleted) * cpukit/librpc/src/rpc/svc.c (deleted) * cpukit/librpc/src/rpc/svc_auth.c (deleted) * cpukit/librpc/src/rpc/svc_auth_unix.c (deleted) * cpukit/librpc/src/rpc/svc_raw.c (deleted) * cpukit/librpc/src/rpc/svc_run.c (deleted) * cpukit/librpc/src/rpc/svc_simple.c (deleted) * cpukit/librpc/src/rpc/svc_tcp.c (deleted) * cpukit/librpc/src/rpc/svc_udp.c (deleted) * cpukit/librpc/src/xdr/xdr.3 (deleted) * cpukit/librpc/src/xdr/xdr.c (deleted) * cpukit/librpc/src/xdr/xdr_array.c (deleted) * cpukit/librpc/src/xdr/xdr_float.c (deleted) * cpukit/librpc/src/xdr/xdr_mem.c (deleted) * cpukit/librpc/src/xdr/xdr_rec.c (deleted) * cpukit/librpc/src/xdr/xdr_reference.c (deleted) * cpukit/librpc/src/xdr/xdr_sizeof.c (deleted) * cpukit/librpc/src/xdr/xdr_stdio.c (deleted) cpukit: Remove libnetworking Update #3850 Wed, 24 Mar 2021 12:57:43 GMT Joel Sherrill [62bbb0c] * cpukit/libmisc/uuid/gen_uuid.c (modified) gen_uuid.c: Revert previous patch ... Thu, 18 Mar 2021 02:50:56 GMT G S Niteesh Babu [bd9e45d9] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) rtems-fdt/rtems-fdt.c: Fix bug in loop termination The while loop, ... Tue, 02 Mar 2021 18:51:46 GMT Ryan Long [fbab832] * cpukit/libmisc/shell/main_help.c (modified) main_help.c: Unchecked return value from library (CID #1437650) CID ... Tue, 02 Mar 2021 16:34:36 GMT Ryan Long [8e34aa3] * cpukit/libmisc/shell/main_chmod.c (modified) main_chmod.c: Fix Unchecked return value from library (CID #1063856) ... Tue, 02 Mar 2021 16:08:28 GMT Ryan Long [597e4f4] * cpukit/libmisc/uuid/gen_uuid.c (modified) gen_uuid.c: Fix two Unchecked return value from library errors CID ... Mon, 01 Mar 2021 16:07:42 GMT Ryan Long [3246fa42] * cpukit/libmisc/shell/main_edit.c (modified) main_edit.c: Fix Unchecked return value (CID #1255318) CID 1255318: ... Mon, 01 Mar 2021 21:06:41 GMT Ryan Long [c7eb89f8] * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) cpuusagetop.c: Fix three Missing break in switch Coverity errors ... Thu, 18 Feb 2021 14:35:13 GMT Ryan Long [fa25b73] * cpukit/libmisc/shell/shell.c (modified) shell.c: Fix Dereference before null check (CID #1467420) CID ... Wed, 18 Nov 2020 07:36:48 GMT Christian Mauderer [1618e69] * cpukit/Makefile.am (modified) * cpukit/include/rtems/shellconfig.h (modified) * cpukit/libmisc/shell/main_i2cdetect.c (added) * cpukit/libmisc/shell/main_i2cget.c (added) * cpukit/libmisc/shell/main_i2cset.c (added) * cpukit/libmisc/shell/main_spi.c (added) * spec/build/cpukit/objshell.yml (modified) shell: Add i2c and spi commands This adds some commands that are ... Sat, 28 Nov 2020 08:44:08 GMT Sebastian Huber [501bd46f] * cpukit/libmisc/shell/dd.h (modified) * cpukit/libmisc/shell/extern-dd.h (modified) * cpukit/libmisc/shell/main_dd.c (modified) shell: Rename "IO" typedef for better Doxygen An automatic link ... Mon, 19 Oct 2020 12:54:39 GMT Frank Kühndel [daeb0a1] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) rtems-fdt / shell - Fix string truncation warning The compiler ... Fri, 16 Oct 2020 04:22:45 GMT Sebastian Huber [e2250eeb] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) Revert "rtems-fdt / shell - Fix string truncation warning" This ... Thu, 15 Oct 2020 09:33:13 GMT Frank Kühndel [355bc37a] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) rtems-fdt / shell - Fix string truncation warning The compiler ... Mon, 12 Oct 2020 16:50:24 GMT Frank Kühndel [1dbd1079] * cpukit/libmisc/shell/main_edit.c (modified) shell/main_edit.c: Fix string truncation warning Using strlcpy() ... Mon, 12 Oct 2020 16:06:30 GMT Frank Kühndel [b03c103] * cpukit/libmisc/shell/main_edit.c (modified) shell/main_edit.c: Fix use of wrong constant realpath() requires a ... Mon, 12 Oct 2020 16:01:45 GMT Frank Kühndel [529402f5] * cpukit/libmisc/shell/shell.c (modified) shell/shell.c: Fix illegal string copy This is an illegal use of ... Mon, 12 Oct 2020 15:11:18 GMT Frank Kühndel [2361b2c] * cpukit/libmisc/shell/shell.c (modified) shell/shell.c: Fix an implicit type cast With some compiler ... Fri, 09 Oct 2020 13:40:13 GMT Frank Kühndel [a479686] * cpukit/Makefile.am (modified) * cpukit/include/rtems/bdpart.h (modified) * cpukit/libblock/src/bdpart-mount.c (deleted) * cpukit/libmisc/shell/fdisk.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) shell: Remove not functioning fdisk mount/unmount The shell has an ...
