# # ChangeLog for cpukit/libfs in rtems # # Generated by Trac 1.2.1.dev0 # 05/05/24 22:15:17 Tue, 27 Jul 2010 18:11:42 GMT Joel Sherrill [4f3d72f] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libmisc/untar/untar.c (modified) 2010-07-27 Joel Sherrill * ... Mon, 26 Jul 2010 21:29:24 GMT Joel Sherrill [bc3fe3c] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) 2010-07-26 Joel Sherrill * ... Fri, 23 Jul 2010 00:11:32 GMT Joel Sherrill [33645763] * cpukit/ChangeLog (modified) * cpukit/libfs/src/devfs/devstat.c (modified) 2010-07-22 Joel Sherrill ... Thu, 15 Jul 2010 08:59:46 GMT Sebastian Huber [f4dea06] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) 2010-07-16 Sebastian Huber ... Thu, 15 Jul 2010 08:46:06 GMT Sebastian Huber [de39b51] * cpukit/ChangeLog (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/fs_null_handlers.c (deleted) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) 2010-07-16 Sebastian Huber ... Thu, 15 Jul 2010 08:10:48 GMT Sebastian Huber [fd2b1634] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/fstat.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/getdents.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/libio_sockets.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/readv.c (modified) * cpukit/libcsupport/src/write.c (modified) * cpukit/libcsupport/src/writev.c (modified) * cpukit/libfs/src/devfs/devclose.c (modified) * cpukit/libfs/src/devfs/devioctl.c (modified) * cpukit/libfs/src/devfs/devopen.c (modified) * cpukit/libfs/src/devfs/devread.c (modified) * cpukit/libfs/src/devfs/devwrite.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.h (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) 2010-07-16 Sebastian Huber ... Thu, 15 Jul 2010 07:59:57 GMT Sebastian Huber [106d8f5] * cpukit/ChangeLog (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/devfs/devfs_node_type.c (modified) 2010-07-16 Sebastian Huber ... Thu, 15 Jul 2010 07:36:37 GMT Sebastian Huber [1e01385] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_evalformake.c (added) * cpukit/libfs/src/defaults/default_handlers.c (added) * cpukit/libfs/src/defaults/default_node_type.c (added) * cpukit/libfs/src/defaults/default_ops.c (added) * cpukit/libfs/src/dosfs/msdos.h (modified) 2010-07-16 Sebastian Huber ... Wed, 14 Jul 2010 15:44:44 GMT Joel Sherrill [8f7b8f7b] * cpukit/ChangeLog (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_free.c (deleted) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/wrapup/Makefile.am (modified) 2010-07-14 Joel Sherrill * ... Tue, 13 Jul 2010 21:43:32 GMT Joel Sherrill [dd38f3d9] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) 2010-07-13 Vinu Rajashekhar PR ... Fri, 09 Jul 2010 18:39:36 GMT Joel Sherrill [18bd1bd4] * cpukit/ChangeLog (modified) * cpukit/libfs/src/pipe/pipe.c (modified) 2010-07-09 Bharath Suri * ... Tue, 06 Jul 2010 22:32:23 GMT Joel Sherrill [66e5e144] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/ioman.c (modified) 2010-07-06 Joel Sherrill * ... Sun, 04 Jul 2010 14:53:47 GMT Joel Sherrill [71c012af] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/libcsupport/src/mallocfreespace.c (modified) * cpukit/libcsupport/src/mount-mgr.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/rewinddir.c (modified) * cpukit/libcsupport/src/seekdir.c (modified) * cpukit/libcsupport/src/telldir.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_rename.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/shell/vis.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/telnetd/telnetd.c (modified) 2010-07-04 Joel Sherrill * ... Sat, 03 Jul 2010 19:13:25 GMT Joel Sherrill [b637dbb] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/src/defaults/default_read.c (modified) * cpukit/libfs/src/defaults/default_readlink.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) 2010-07-03 Joel Sherrill * ... Thu, 01 Jul 2010 20:18:41 GMT Joel Sherrill [962571e9] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) 2010-07-01 Joel Sherrill * ... Thu, 01 Jul 2010 16:29:17 GMT Joel Sherrill [cfcdb5b2] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/utime.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) 2010-07-01 Vinu Rajashekhar PR ... Thu, 01 Jul 2010 15:39:23 GMT Joel Sherrill [5ef1164c] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/memfile.c (modified) 2010-07-01 Joel Sherrill ... Thu, 01 Jul 2010 09:51:50 GMT Sebastian Huber [59673224] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/librtemsNfs.h (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/sapi/include/confdefs.h (modified) 2010-07-01 Sebastian Huber ... Wed, 30 Jun 2010 13:58:56 GMT Jennifer Averett [6683a58] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_mknod.c (added) 2010-06-30 Jennifer.Averett ... Tue, 29 Jun 2010 19:37:28 GMT Jennifer Averett [dace9ed1] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_chown.c (modified) * cpukit/libfs/src/defaults/default_close.c (added) * cpukit/libfs/src/defaults/default_evalpath.c (modified) * cpukit/libfs/src/defaults/default_evaluate_link.c (added) * cpukit/libfs/src/defaults/default_fpathconf.c (added) * cpukit/libfs/src/defaults/default_freenode.c (modified) * cpukit/libfs/src/defaults/default_fsmount.c (modified) * cpukit/libfs/src/defaults/default_fsunmount.c (added) * cpukit/libfs/src/defaults/default_link.c (modified) * cpukit/libfs/src/defaults/default_mount.c (modified) * cpukit/libfs/src/defaults/default_open.c (added) * cpukit/libfs/src/defaults/default_rename.c (modified) * cpukit/libfs/src/defaults/default_statvfs.c (modified) * cpukit/libfs/src/defaults/default_symlink.c (modified) * cpukit/libfs/src/defaults/default_unlink.c (modified) * cpukit/libfs/src/defaults/default_unmount.c (added) * cpukit/libfs/src/defaults/default_utime.c (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/wrapup/Makefile.am (modified) 2010-06-29 Jennifer.Averett ... Tue, 29 Jun 2010 01:53:18 GMT Joel Sherrill [76950a6] * cpukit/ChangeLog (modified) * cpukit/libfs/src/defaults/default_chown.c (modified) * cpukit/libfs/src/defaults/default_evalpath.c (modified) * cpukit/libfs/src/defaults/default_fchmod.c (modified) * cpukit/libfs/src/defaults/default_fcntl.c (modified) * cpukit/libfs/src/defaults/default_fdatasync.c (modified) * cpukit/libfs/src/defaults/default_freenode.c (modified) * cpukit/libfs/src/defaults/default_fsmount.c (modified) * cpukit/libfs/src/defaults/default_fstat.c (modified) * cpukit/libfs/src/defaults/default_fsync.c (modified) * cpukit/libfs/src/defaults/default_ftruncate.c (modified) * cpukit/libfs/src/defaults/default_ioctl.c (modified) * cpukit/libfs/src/defaults/default_link.c (modified) * cpukit/libfs/src/defaults/default_lseek.c (modified) * cpukit/libfs/src/defaults/default_mount.c (modified) * cpukit/libfs/src/defaults/default_read.c (modified) * cpukit/libfs/src/defaults/default_readlink.c (modified) * cpukit/libfs/src/defaults/default_rename.c (modified) * cpukit/libfs/src/defaults/default_rmnod.c (modified) * cpukit/libfs/src/defaults/default_statvfs.c (modified) * cpukit/libfs/src/defaults/default_symlink.c (modified) * cpukit/libfs/src/defaults/default_unlink.c (modified) * cpukit/libfs/src/defaults/default_utime.c (modified) * cpukit/libfs/src/defaults/default_write.c (modified) 2010-06-28 Joel Sherrill * ... Fri, 25 Jun 2010 14:23:48 GMT Jennifer Averett [f9a4e80] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_chown.c (added) * cpukit/libfs/src/defaults/default_evalpath.c (added) * cpukit/libfs/src/defaults/default_fchmod.c (added) * cpukit/libfs/src/defaults/default_fcntl.c (added) * cpukit/libfs/src/defaults/default_fdatasync.c (added) * cpukit/libfs/src/defaults/default_freenode.c (added) * cpukit/libfs/src/defaults/default_fsmount.c (added) * cpukit/libfs/src/defaults/default_fstat.c (added) * cpukit/libfs/src/defaults/default_fsync.c (added) * cpukit/libfs/src/defaults/default_ftruncate.c (added) * cpukit/libfs/src/defaults/default_ioctl.c (added) * cpukit/libfs/src/defaults/default_link.c (added) * cpukit/libfs/src/defaults/default_lseek.c (added) * cpukit/libfs/src/defaults/default_mount.c (added) * cpukit/libfs/src/defaults/default_read.c (added) * cpukit/libfs/src/defaults/default_readlink.c (added) * cpukit/libfs/src/defaults/default_rename.c (added) * cpukit/libfs/src/defaults/default_rmnod.c (added) * cpukit/libfs/src/defaults/default_statvfs.c (added) * cpukit/libfs/src/defaults/default_symlink.c (added) * cpukit/libfs/src/defaults/default_unlink.c (added) * cpukit/libfs/src/defaults/default_utime.c (added) * cpukit/libfs/src/defaults/default_write.c (added) 2010-06-25 Jennifer Averett [4d32a76d] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/memfile.c (modified) 2010-06-24 Joel Sherrill * ... Thu, 24 Jun 2010 21:37:08 GMT Joel Sherrill [efd6e8e] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) 2010-06-24 Joel Sherrill * ... Thu, 24 Jun 2010 21:31:22 GMT Joel Sherrill [983bfad] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_getchild.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) 2010-06-24 Joel Sherrill * ... Thu, 24 Jun 2010 19:57:58 GMT Joel Sherrill [2d1994c9] * cpukit/ChangeLog (modified) * cpukit/libfs/src/pipe/fifo.c (modified) 2010-06-24 Bharath Suri PR ... Thu, 24 Jun 2010 13:28:39 GMT Joel Sherrill [eb8c45d] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) 2010-06-24 Joel Sherrill ... Wed, 23 Jun 2010 05:01:46 GMT Chris Johns [68b49f1] * cpukit/ChangeLog (modified) * cpukit/libfs/src/pipe/fifo.c (modified) 2010-06-23 Chris Johns PR ... Fri, 18 Jun 2010 09:36:02 GMT Ralf Corsepius [7061170] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) 2010-06-18 Ralf Corsépius * ... Thu, 17 Jun 2010 22:04:51 GMT Chris Johns [099cdd5] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.c (modified) 2010-06-18 Chris Johns * ... Thu, 17 Jun 2010 22:00:47 GMT Chris Johns [ca8c50de] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (modified) 2010-06-18 Chris Johns * ... Thu, 17 Jun 2010 03:57:11 GMT Ralf Corsepius [ff0d62ca] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (modified) 2010-06-17 Ralf Corsépius * ... Thu, 17 Jun 2010 03:48:31 GMT Ralf Corsepius [7ae6ce9] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (modified) 2010-06-17 Ralf Corsépius * ... Thu, 17 Jun 2010 03:46:53 GMT Ralf Corsepius [640a9d9] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.c (modified) 2010-06-17 Ralf Corsépius * ... Thu, 17 Jun 2010 03:41:12 GMT Ralf Corsepius [fa4b7a4] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (modified) 2010-06-17 Ralf Corsépius * ... Thu, 17 Jun 2010 03:36:04 GMT Ralf Corsepius [ca400296] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) 2010-06-17 Ralf Corsépius * ... Thu, 17 Jun 2010 03:16:41 GMT Ralf Corsepius [d4118467] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) 2010-06-17 Ralf Corsépius * ... Thu, 17 Jun 2010 03:13:32 GMT Ralf Corsepius [f544167] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) 2010-06-17 Ralf Corsépius * ... Thu, 17 Jun 2010 03:09:00 GMT Chris Johns [b177ebb7] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-block-pos.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.h (modified) 2010-06-17 Chris Johns ... Thu, 17 Jun 2010 02:48:37 GMT Ralf Corsepius [dc57290] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps-ut.c (modified) 2010-06-17 Ralf Corsépius * ... Thu, 17 Jun 2010 02:44:49 GMT Ralf Corsepius [87ff365] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.c (modified) 2010-06-17 Ralf Corsépius * ... Wed, 16 Jun 2010 17:44:37 GMT Ralf Corsepius [c5500f2] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.c (modified) 2010-06-16 Ralf Corsépius * ... Wed, 16 Jun 2010 17:30:35 GMT Ralf Corsepius [8e843a1] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.c (modified) 2010-06-16 Ralf Corsépius * ... Wed, 16 Jun 2010 17:25:40 GMT Ralf Corsepius [6d537a3] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) 2010-06-16 Ralf Corsépius * ... Wed, 16 Jun 2010 16:59:43 GMT Ralf Corsepius [4b06da6f] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c (modified) 2010-06-16 Ralf Corsépius * ... Wed, 16 Jun 2010 14:39:25 GMT Ralf Corsepius [9bc752b] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-block-pos.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system-fwd.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.h (modified) 2010-06-16 Ralf Corsépius ... Wed, 16 Jun 2010 14:31:48 GMT Ralf Corsepius [f639680] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) 2010-06-16 Ralf Corsépius ... Tue, 15 Jun 2010 23:34:56 GMT Ralf Corsepius [9a783b71] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.c (modified) 2010-06-15 Ralf Corsépius * ... Tue, 15 Jun 2010 15:17:35 GMT Ralf Corsepius [d691d0a0] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (modified) 2010-06-15 Ralf Corsépius * ... Tue, 15 Jun 2010 13:35:28 GMT Ralf Corsepius [06e04f8] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) 2010-06-15 Ralf Corsépius * ... Mon, 14 Jun 2010 05:49:44 GMT Ralf Corsepius [4da0caef] * cpukit/ChangeLog (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libfs/src/pipe/pipe.h (modified) 2010-06-14 Ralf Corsépius * ... Sun, 13 Jun 2010 03:36:58 GMT Ralf Corsepius [de93598] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/include/rtems/tar.h (deleted) * cpukit/libcsupport/include/tar.h (deleted) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libmisc/untar/untar.h (modified) 2010-06-13 Ralf Corsépius * ... Sat, 12 Jun 2010 17:55:13 GMT Joel Sherrill [1a0ccc7] * cpukit/ChangeLog (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) 2010-06-12 Joel Sherrill * ... Sat, 12 Jun 2010 05:18:16 GMT Ralf Corsepius [01f41602] * cpukit/ChangeLog (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-block-pos.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.h (modified) 2010-06-12 Ralf Corsépius * ... Tue, 08 Jun 2010 15:15:31 GMT Sebastian Huber [68cd765] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) 2010-06-08 Sebastian Huber ... Tue, 08 Jun 2010 12:59:51 GMT Sebastian Huber [eaee27b] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdpart-mount.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/src/pipe/pipe.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/fsmount/fsmount.h (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/libnetworking/rtems/mkrootfs.h (modified) 2010-06-08 Sebastian Huber ... Tue, 08 Jun 2010 10:25:46 GMT Sebastian Huber [241f4c96] * cpukit/ChangeLog (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/imfs/fifoimfs_init.c (added) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libfs/src/pipe/pipe.c (modified) * cpukit/libfs/src/pipe/pipe.h (modified) * cpukit/sapi/include/confdefs.h (modified) 2010-06-08 Sebastian Huber ... Tue, 08 Jun 2010 08:50:57 GMT Sebastian Huber [5b5772a] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) 2010-06-08 Sebastian Huber ... Tue, 08 Jun 2010 08:30:04 GMT Sebastian Huber [78f4d6d7] * cpukit/ChangeLog (modified) * cpukit/libfs/src/devfs/devclose.c (modified) * cpukit/libfs/src/devfs/devopen.c (modified) * cpukit/libfs/src/imfs/deviceerrno.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (modified) 2010-06-08 Sebastian Huber ... Tue, 01 Jun 2010 10:41:40 GMT Ralf Corsepius [0b701e6] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/xdr_mbuf.c (modified) 2010-06-01 Ralf Corsépius * ... Mon, 31 May 2010 13:56:37 GMT Chris Johns [29e92b0] * cpukit/ChangeLog (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/libblock/src/bdpart-mount.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/devfs/devfs_eval.c (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/nfsclient/src/librtemsNfs.h (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs.h (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/fsmount/fsmount.h (modified) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/main_mount_ftp.c (deleted) * cpukit/libmisc/shell/main_mount_msdos.c (deleted) * cpukit/libmisc/shell/main_mount_rfs.c (deleted) * cpukit/libmisc/shell/main_mount_tftp.c (deleted) * cpukit/libmisc/shell/shellconfig.h (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/rtems/ftpfs.h (modified) * cpukit/libnetworking/rtems/tftp.h (modified) * cpukit/sapi/include/confdefs.h (modified) 2010-05-31 Chris Johns * ... Sun, 30 May 2010 10:18:41 GMT Ralf Corsepius [8b389473] * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) 2010-05-30 Ralf Corsépius * ... Sat, 29 May 2010 04:30:47 GMT Ralf Corsepius [6b2c3f11] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/xdr_mbuf.c (modified) 2010-05-29 Ralf Corsépius * ... Sat, 29 May 2010 02:31:09 GMT Ralf Corsepius [21d9736] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/libfs/src/nfsclient/src/dirutils.c (modified) 2010-05-29 Ralf Corsépius * ... Fri, 28 May 2010 15:16:39 GMT Ralf Corsepius [8f4ceeb] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) 2010-05-28 Ralf Corsépius * ... Thu, 27 May 2010 16:47:06 GMT Ralf Corsepius [d5143ba] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/xdr_mbuf.c (modified) 2010-05-27 Ralf Corsépius * ... Thu, 27 May 2010 16:32:46 GMT Ralf Corsepius [ef5da32] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) 2010-05-27 Ralf Corsépius * ... Thu, 27 May 2010 16:24:47 GMT Ralf Corsepius [cd469f2] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) 2010-05-27 Ralf Corsépius * ... Thu, 27 May 2010 16:23:04 GMT Ralf Corsepius [9813fb6] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) 2010-05-27 Ralf Corsépius * ... Thu, 27 May 2010 16:20:44 GMT Ralf Corsepius [596bead5] * cpukit/ChangeLog (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/devfs/devfs_eval.c (modified) 2010-05-27 Ralf Corsépius * ... Thu, 27 May 2010 16:17:44 GMT Ralf Corsepius [f7449929] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) 2010-05-27 Ralf Corsépius * ... Thu, 27 May 2010 14:20:10 GMT Ralf Corsepius [bf0b23a] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) 2010-05-27 Ralf Corsépius * ... Thu, 27 May 2010 09:44:43 GMT Ralf Corsepius [d132b92a] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) 2010-05-27 Ralf Corsépius * ... Thu, 27 May 2010 09:42:14 GMT Ralf Corsepius [dadbcba] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) 2010-05-27 Ralf Corsépius * ... Thu, 27 May 2010 07:41:51 GMT Ralf Corsepius [bc26d607] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) * cpukit/libfs/src/nfsclient/src/rpcio.h (modified) 2010-05-27 Ralf Corsépius * ... Thu, 27 May 2010 04:14:17 GMT Ralf Corsepius [0bf68a5] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) 2010-05-27 Ralf Corsépius * ... Sat, 22 May 2010 16:46:59 GMT Ralf Corsepius [eb5cd5b] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps-ut.c (modified) 2010-05-22 Ralf Corsépius * ... Sat, 15 May 2010 06:29:55 GMT Chris Johns [8162008] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) 2010-05-15 Chris Johns * ... Fri, 30 Apr 2010 08:43:31 GMT Sebastian Huber [361e26df] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) 2010-04-30 Sebastian Huber ... Mon, 26 Apr 2010 02:43:30 GMT Joel Sherrill [74b4bb1f] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps-ut.c (modified) 2010-04-25 Joel Sherrill * ... Mon, 12 Apr 2010 05:29:25 GMT Chris Johns [1d539c0] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-data.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) 2010-04-12 Chris Johns ... Tue, 30 Mar 2010 11:16:29 GMT Chris Johns [8f77f8f] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) 2010-03-30 Chris Johns * ... Sun, 28 Mar 2010 03:14:08 GMT Ralf Corsepius [694c3ac6] * cpukit/libblock/src/bdpart.c (modified) * cpukit/libblock/src/ramdisk-config.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * cpukit/libblock/src/ramdisk-init.c (modified) * cpukit/libfs/src/pipe/pipe.c (modified) Add HAVE_CONFIG_H support to let files receive configure defines. Sat, 27 Mar 2010 04:04:40 GMT Chris Johns [355b0544] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/cexphelp.c (modified) * cpukit/libfs/src/nfsclient/src/dirutils.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.modini.c (modified) * cpukit/libfs/src/nfsclient/src/nfsTest.c (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) * cpukit/libfs/src/nfsclient/src/rpcio.modini.c (modified) * cpukit/libfs/src/nfsclient/src/sock_mbuf.c (modified) * cpukit/libfs/src/nfsclient/src/xdr_mbuf.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps-ut.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-mutex.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-trace.c (modified) 2010-03-27 Chris Johns ... Fri, 26 Mar 2010 01:19:51 GMT Chris Johns [1b3f7e92] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) 2010-03-26 Chris Johns * ... Mon, 22 Mar 2010 14:55:37 GMT Joel Sherrill [5fe3834] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps-ut.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) 2010-03-22 Joel Sherrill * ... Fri, 12 Mar 2010 16:26:16 GMT Joel Sherrill [bab5c5fa] * cpukit/ChangeLog (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/httpd/asp.c (modified) * cpukit/httpd/ejparse.c (modified) * cpukit/httpd/emfdb.c (modified) * cpukit/httpd/misc.c (modified) * cpukit/httpd/um.c (modified) * cpukit/httpd/webs.c (modified) * cpukit/httpd/websuemf.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/monitor/mon-network.c (modified) * cpukit/libmisc/shell/hexdump-odsyntax.c (modified) * cpukit/libmisc/shell/main_ifconfig.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell_makeargs.c (modified) * cpukit/libmisc/uuid/parse.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_init.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) 2010-03-12 Joel Sherrill * ... Fri, 12 Mar 2010 08:31:31 GMT Thomas Doerfler [6982ed78] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) Do not overwrite errno in case fat_file_write() returns with an error ... Thu, 04 Mar 2010 06:36:51 GMT Chris Johns [8ec7abb] * cpukit/ChangeLog (modified) * cpukit/httpd/asp.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/_rename_r.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_rename.c (added) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_rename.c (added) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) 010-03-04 Chris Johns * ... Sun, 28 Feb 2010 22:36:28 GMT Chris Johns [d3cfd63] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.h (modified) 2010-03-01 Chris Johns * ... Fri, 26 Feb 2010 05:54:59 GMT Chris Johns [3cfa636] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) 010-02-26 Chris Johns * ... Wed, 24 Feb 2010 09:30:40 GMT Chris Johns [520705c] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libmisc/shell/main_msdosfmt.c (modified) * cpukit/libmisc/shell/shellconfig.h (modified) 2010-02-24 Chris Johns * ... Mon, 22 Feb 2010 23:06:03 GMT Chris Johns [5027104] * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) Fixed the inode values. Mon, 22 Feb 2010 23:02:41 GMT Chris Johns [59762963] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) 2010-02-23 Chris Johns * ... Sat, 20 Feb 2010 02:27:58 GMT Chris Johns [5268642] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) 2010-02-20 Chris Johns * ... Fri, 19 Feb 2010 03:23:11 GMT Chris Johns [cca94a2] * cpukit/ChangeLog (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.h (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_debugrfs.c (added) * cpukit/libmisc/shell/main_mkrfs.c (added) * cpukit/libmisc/shell/main_mount_rfs.c (added) * cpukit/libmisc/shell/main_msdosfmt.c (modified) * cpukit/libmisc/shell/shellconfig.h (modified) 2010-02-19 Chris Johns * ... Thu, 18 Feb 2010 00:24:25 GMT Chris Johns [a9fa9b7] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/README (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps-ut.c (added) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c (added) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.h (added) * cpukit/libfs/src/rfs/rtems-rfs-block-pos.h (added) * cpukit/libfs/src/rfs/rtems-rfs-block.c (added) * cpukit/libfs/src/rfs/rtems-rfs-block.h (added) * cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c (added) * cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c (added) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (added) * cpukit/libfs/src/rfs/rtems-rfs-buffer.h (added) * cpukit/libfs/src/rfs/rtems-rfs-data.h (added) * cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c (added) * cpukit/libfs/src/rfs/rtems-rfs-dir-hash.h (added) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (added) * cpukit/libfs/src/rfs/rtems-rfs-dir.h (added) * cpukit/libfs/src/rfs/rtems-rfs-file-system-fwd.h (added) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (added) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (added) * cpukit/libfs/src/rfs/rtems-rfs-file.c (added) * cpukit/libfs/src/rfs/rtems-rfs-file.h (added) * cpukit/libfs/src/rfs/rtems-rfs-format.c (added) * cpukit/libfs/src/rfs/rtems-rfs-format.h (added) * cpukit/libfs/src/rfs/rtems-rfs-group.c (added) * cpukit/libfs/src/rfs/rtems-rfs-group.h (added) * cpukit/libfs/src/rfs/rtems-rfs-inode.c (added) * cpukit/libfs/src/rfs/rtems-rfs-inode.h (added) * cpukit/libfs/src/rfs/rtems-rfs-link.c (added) * cpukit/libfs/src/rfs/rtems-rfs-link.h (added) * cpukit/libfs/src/rfs/rtems-rfs-mutex.c (added) * cpukit/libfs/src/rfs/rtems-rfs-mutex.h (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems.h (added) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (added) * cpukit/libfs/src/rfs/rtems-rfs-shell.h (added) * cpukit/libfs/src/rfs/rtems-rfs-trace.c (added) * cpukit/libfs/src/rfs/rtems-rfs-trace.h (added) * cpukit/libfs/src/rfs/rtems-rfs.h (added) * cpukit/libmisc/shell/main_ls.c (modified) * cpukit/libmisc/shell/print-ls.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/preinstall.am (modified) * cpukit/wrapup/Makefile.am (modified) 2010-02-18 Chris Johns * ... Tue, 19 Jan 2010 19:31:00 GMT Joel Sherrill [cb4e992] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) 2010-01-19 Joel Sherrill * ... Tue, 19 Jan 2010 01:55:28 GMT Joel Sherrill [ad7824bc] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/memfile.c (modified) 2010-01-18 Joel Sherrill ... Mon, 18 Jan 2010 23:39:31 GMT Joel Sherrill [9ba0e55] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) 2010-01-18 Joel Sherrill ...
