Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit/libfs/src
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @47ef863a   05/28/02 17:21:17 Joel Sherrill 2002-05-18 Ralf Corsepius <corsepiu@…> Move from … 4.104.114.84.95
(edit) @c873f40   04/08/02 18:28:59 Joel Sherrill 2002-04-06 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @6940f507   04/04/02 22:17:14 Joel Sherrill 2001-04-04 Joel Sherrill <joel@…> * src/dosfs/Makefile.am: … 4.104.114.84.95
(edit) @aed1f02a   04/04/02 18:22:23 Joel Sherrill 2002-04-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @9fff6bf   03/28/02 13:52:49 Joel Sherrill 2002-03-27 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @05b8b60   03/28/02 00:49:35 Joel Sherrill 2002-03-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @c31deeb   03/20/02 14:21:42 Joel Sherrill 2002-03-16 Ralf Corsepius <corsepiu@…> Addressing PR … 4.104.114.84.95
(edit) @2de2bec   03/15/02 18:55:09 Joel Sherrill 2002-03-14 Ralf Corsepius <corsepiu@…> Reported and … 4.104.114.84.95
(edit) @f9d1afc   03/01/02 16:17:53 Joel Sherrill 2001-03-01 Joel Sherrill <joel@…> * src/imfs/.cvsignore: … 4.104.114.84.95
(edit) @f36a7bfc   02/28/02 20:43:50 Joel Sherrill 2002-02-28 Victor V. Vengerov <vvv@…> * DOS filesystem … 4.104.114.84.95
(edit) @74e0ba5   01/08/02 12:05:36 Joel Sherrill 2002-01-07 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @b2709481   01/04/02 18:30:58 Joel Sherrill 2002-01-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @f667aaec   11/26/01 14:34:09 Joel Sherrill 2001-11-26 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @47901d8   11/08/01 00:24:55 Joel Sherrill 2001-11-07 Jennifer Averett <jennifer@…> Reported by … 4.104.114.84.95
(edit) @fa2f9790   10/26/01 19:40:07 Joel Sherrill 2001-10-26 Victor V. Vengerov <vvv@…> * … 4.104.114.84.95
(edit) @8670008c   10/16/01 19:06:11 Joel Sherrill 2001-10-16 Chris Johns <ccj@…> * imfs/imfs_load_tar.c: Changed … 4.104.114.84.95
(edit) @d9b0b866   10/11/01 13:16:24 Joel Sherrill 2001-10-10 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @52b3ff6   09/28/01 13:34:57 Joel Sherrill 2001-09-28 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @3520280   09/24/01 18:29:17 Joel Sherrill 2001-09-22 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @b6a2d2fa   08/09/01 22:09:36 Joel Sherrill 2001-08-09 Fernando-Ruiz Casas <correo@…> * … 4.104.114.84.95
(edit) @b8c8cab   07/06/01 21:48:16 Joel Sherrill 2001-07-06 Thomas Doerfler <Thomas.Doerfler@…> * … 4.104.114.84.95
(edit) @e807db0   05/25/01 13:47:47 Joel Sherrill 2001-05-25 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @eb22ebe   04/24/01 23:06:50 Joel Sherrill 2001-04-24 Joel Sherrill <joel@…> * src/imfs/memfile.c … 4.104.114.84.95
(edit) @53462762   04/20/01 13:27:24 Joel Sherrill 2001-04-20 Joel Sherrill <joel@…> * src/imfs/imfs_debug.c … 4.104.114.84.95
(edit) @d79ef17   03/23/01 14:02:02 Joel Sherrill 2001-03-23 Joel Sherrill <joel@…> * src/imfs/memfile.c: … 4.104.114.84.95
(edit) @8b5d0db3   02/05/01 18:24:14 Joel Sherrill 2001-02-03 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @d6b1d73   01/22/01 14:05:14 Joel Sherrill 2001-01-22 Ralf Corsepius <corsepiu@…> * configure.in: … 4.104.114.84.95
(edit) @d1941587   01/12/01 13:44:12 Joel Sherrill 2001-01-12 Jake Janovetz <janovetz@…> * src/imfs/imfs.h, … 4.104.114.84.95
(edit) @0ef748fb   12/13/00 17:53:55 Joel Sherrill 2000-12-12 Jake Janovetz <janovetz@…> * … 4.104.114.84.95
(edit) @6b5519a   11/28/00 21:53:48 Joel Sherrill 2000-11-28 Joel Sherrill <joel@…> * src/imfs/memfile.c: … 4.104.114.84.95
(edit) @13e47e2e   11/17/00 18:46:03 Jennifer.Averett 2000-11-17 Jennifer Averret <jennifer@…> * … 4.104.114.84.95
(edit) @c058578   11/01/00 21:02:46 Joel Sherrill 2000-11-01 Joel Sherrill <joel@…> * src/imfs/Makefile.am, … 4.104.114.84.95
(edit) @a0756c9a   10/25/00 16:51:22 Joel Sherrill 2000-10-24 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @5b59c4d   10/19/00 15:52:22 Joel Sherrill 2000-10-19 Joel Sherrill <joel@…> * .cvsignore, … 4.104.114.84.95
(edit) @d71c6c1   10/18/00 18:10:55 Joel Sherrill 2000-10-18 Chris Johns <ccj@…> * libfs created. * src, … 4.104.114.84.95
(edit) @9c3fa30   09/28/00 20:19:23 Joel Sherrill 2000-09-28 Joel Sherrill <joel@…> * libc/libio.h … 4.104.114.84.95
(edit) @662678d1   08/25/00 13:13:57 Joel Sherrill 2000-08-25 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @dd19c0b   08/11/00 20:04:27 Joel Sherrill 2000-08-11 Chris Johns <ccj@…> * libc/chmod.c: Return ENOTSUP … 4.104.114.84.95
(edit) @3af0828   07/02/00 12:29:47 Joel Sherrill Fixed stat_ino should be st_ino. 4.104.114.84.95
(edit) @068b6473   06/30/00 12:36:32 Joel Sherrill Patch from Chris Johns <cjohns@…> so the directory read … 4.104.114.84.95
(edit) @e5d6705e   06/30/00 12:33:13 Joel Sherrill Patch from Chris Johns <cjohns@…> to add support for … 4.104.114.84.95
(edit) @e42a135   06/26/00 14:49:58 Joel Sherrill Patch from Chris Johns <cjohns@…> and Jennifer Averett … 4.104.114.84.95
(edit) @5e0e012c   06/26/00 14:46:19 Joel Sherrill Patch from Chris Johns <cjohns@…> and Jennifer Averett … 4.104.114.84.95
(edit) @df49c60   06/12/00 15:00:15 Joel Sherrill Merged from 4.5.0-beta3a 4.104.114.84.95
(edit) @562e7ed1   02/11/00 15:54:47 Joel Sherrill Increased block size to 128 and added comments based on feedback from … 4.104.114.84.95
(edit) @3a8b95e   01/05/00 21:32:57 Joel Sherrill Spacing corrected. 4.104.114.84.95
(edit) @08311cc3   11/17/99 17:51:34 Joel Sherrill Updated copyright notice. 4.104.114.84.95
(edit) @18c3155   11/16/99 22:45:33 Jennifer.Averett Added handler for fsync. For the memfile it is the same as the data sync. 4.104.114.84.95
(edit) @b440e57b   11/09/99 13:40:30 Joel Sherrill Added imfs_unixstub.c to satisfy linker problems on UNIX port. 4.104.114.84.95
(edit) @f758f810   11/05/99 22:26:12 Jennifer.Averett Correctly set and called handlers table for the link. 4.104.114.84.95
(edit) @089ad91d   11/05/99 22:25:16 Jennifer.Averett Fixed comment 4.104.114.84.95
(edit) @7f6a0750   11/05/99 22:24:56 Jennifer.Averett Moved imfs set handlers prototype to the imfs.h file. 4.104.114.84.95
(edit) @378fe02   11/05/99 21:11:09 Joel Sherrill New file. 4.104.114.84.95
(edit) @94b357c2   11/05/99 21:10:54 Joel Sherrill Unmount was failing as a side-effect of splitting the rmnod handler … 4.104.114.84.95
(edit) @b568ccb   11/02/99 20:20:13 Joel Sherrill The object memfile.o was being included in the miniIMFS even though it … 4.104.114.84.95
(edit) @3fb2a8da   11/02/99 16:23:50 Joel Sherrill Fixed typo where memfile_handlers set twice and directory_handlers was … 4.104.114.84.95
(edit) @ac8adcf   11/02/99 16:22:58 Joel Sherrill Properly initialize location variable. 4.104.114.84.95
(edit) @4a07d2b   10/29/99 15:19:13 Jennifer.Averett Moved the rmnod callback from the operations table to the handler table. 4.104.114.84.95
(edit) @7999174   10/26/99 21:51:20 Joel Sherrill New files created by split of old imfs_handlers.c. 4.104.114.84.95
(edit) @657e1bf6   10/26/99 20:17:13 Joel Sherrill Added initial cut at miniIMFS which leaves out memfile and directory … 4.104.114.84.95
(edit) @1e57186   10/25/99 14:46:56 Joel Sherrill Patch from Eric Valette <valette@…> and Emmanuel Raguet … 4.104.114.84.95
(edit) @c774a07e   10/25/99 14:09:46 Joel Sherrill Changed leading spaces to periods to ease comparing test output. 4.104.114.84.95
(edit) @a6883c4   10/12/99 20:22:27 Joel Sherrill Spacing. 4.104.114.84.95
(edit) @51435fc7   10/12/99 19:26:37 Joel Sherrill Split null handlers table to own file and renamed. Renamed IMFS … 4.104.114.84.95
(edit) @dd0f326   10/12/99 19:10:46 Joel Sherrill Added rtems_filesystem_freenode() macro and added calls at appropriate … 4.104.114.84.95
(edit) @578a415   10/12/99 19:08:55 Joel Sherrill Corrected mistakes in the IMFS file handlers table and added the … 4.104.114.84.95
(edit) @d71fcab   10/12/99 18:44:40 Joel Sherrill Added call to freenod to let each filesystem free its own internal … 4.104.114.84.95
(edit) @0ac8e382   06/14/99 19:44:07 Joel Sherrill Warning removal from D. V. Henkel-Wallace <gumby@…>. 4.104.114.84.95
(edit) @556ea0e3   05/27/99 16:12:20 Joel Sherrill Removed usage of printf. 4.104.114.84.95
(edit) @ec2328ee   03/31/99 23:24:57 Jennifer.Averett Removed asserts that shouldn't be called and commented case where this … 4.104.114.84.95
(edit) @b10f6e1   03/08/99 21:39:39 Joel Sherrill Corrected bug where pointer to doubly linked blocks was being … 4.104.114.84.95
(edit) @3cf8394   02/24/99 20:58:47 Joel Sherrill Changed IMFS to use IMFS_NAME_MAX as the maximum length of a basename … 4.104.114.84.95
(edit) @efb1b830   02/10/99 17:04:54 Joel Sherrill Corrected multiple places the file size was not being properly updated. 4.104.114.84.95
(edit) @2f87c843   02/05/99 00:28:43 Joel Sherrill Corrected spacing and added some new error checks that were needed to … 4.104.114.84.95
(edit) @a4e2f08   12/03/98 22:19:06 Jennifer.Averett Added imfs_fdatasync routine that gets called from both fdatasync and … 4.104.114.84.95
(edit) @49629bd8   12/03/98 22:17:46 Jennifer.Averett Added a imfs fdatasync routine that gets called for fdatasync and datasync. 4.104.114.84.95
(edit) @7a3878b   12/03/98 22:17:13 Jennifer.Averett Modifications for RTEMS_UNIX. 4.104.114.84.95
(add) @07a3253d   11/23/98 19:07:58 Joel Sherrill Added base version of file system infrastructure. This includes a … 4.104.114.84.95
