@2cd2ed3
05/04/12 11:26:07 |
Sebastian Huber |
nfsclient: Add rename operation
4.115
@078369f
05/04/12 10:46:17 |
Sebastian Huber |
nfsclient: Fix hard link operation
4.115
@1747208
05/04/12 08:48:02 |
Sebastian Huber |
Filesystem: Use proper parameter in NFS
4.115
@6b36ca23
04/26/12 14:34:59 |
Sebastian Huber |
Filesystem: Remove pipe_lseek()
4.115
@ee32f67a
05/04/12 06:55:28 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@3756041
04/28/12 02:21:45 |
Chris Johns |
IMFS: Update IMS_assert check when RTEMS_DEBUG is enabled.
Update the …
4.115
@bc04436
04/23/12 14:21:42 |
Sebastian Huber |
nfsclient: Use UID and GID of NFS handle
Use UID and GID of the NFS …
4.115
@e384438
04/23/12 13:46:07 |
Sebastian Huber |
nfsclient: POSIX conformance
According to POSIX the read() call …
4.115
@790f04d
03/09/12 13:13:22 |
Sebastian Huber |
PR2039: Fix NULL pointer access
In case rtems_bdbuf_read() returns an …
4.115
@796967c
02/28/12 16:19:49 |
Sebastian Huber |
libblock: Change bdbuf API
The functions
o rtems_bdbuf_get(),
o …
4.115
@e998c985
03/05/12 10:51:23 |
Sebastian Huber |
IMFS: Node specific stat handlers
4.115
@04ca77e
03/05/12 10:49:55 |
Sebastian Huber |
IMFS: Generic device identifier
4.115
@c5392ef9
03/01/12 10:51:34 |
Sebastian Huber |
IMFS: Add make generic node support
Generic nodes are an alternative …
4.115
@699ac7c
02/24/12 16:08:06 |
Sebastian Huber |
IMFS: Add and use node control
Add and use structure …
4.115
@70927458
02/24/12 15:40:19 |
Sebastian Huber |
IMFS: New support functions
Add and use IMFS_type() and …
4.115
@6661435f
02/24/12 08:21:04 |
Sebastian Huber |
IMFS: Removed superfluous imfs_dir_open()
4.115
@1bdff036
02/23/12 16:57:27 |
Sebastian Huber |
IMFS: Reference counting for nodes
The introduction of reference …
4.115
@2e0ce55
02/21/12 16:24:10 |
Sebastian Huber |
IMFS: Use unprotected chain operations
Directory entry add or removal …
4.115
@316507ab
02/21/12 16:21:05 |
Sebastian Huber |
IMFS: Lock the file system during directory reads
Other threads may …
4.115
@e00cca9b
02/21/12 14:52:55 |
Sebastian Huber |
IMFS: Do not check for unsupported types
Allow creation of nodes with …
4.115
@2563410
03/13/12 08:22:11 |
Sebastian Huber |
Filesystem: Rename defines
o Removed RTEMS_LIBIO_PERMS_SEARCH.
o …
4.115
@4116fce6
02/24/12 16:39:27 |
Sebastian Huber |
Filesystem: New defaults fsync_h and fdatasync_h
New defaults …
4.115
@a76c2373
02/24/12 08:54:44 |
Sebastian Huber |
Filesystem: Change error indication
Change error indication to ESPIPE …
4.115
@adef4e4
02/24/12 08:53:22 |
Sebastian Huber |
Filesystem: New function
New function …
4.115
@3b7c123
03/13/12 10:33:51 |
Sebastian Huber |
Filesystem: Reference counting for locations
o A new data structure …
4.115
@a4097fdb
02/21/12 11:56:51 |
Sebastian Huber |
PR 2026/filesystem - Fix semaphore attributes
Semaphores of type …
4.115
@6491f67
02/09/12 11:00:15 |
Sebastian Huber |
Moved empty test in front of busy tests
4.115
@e303adf
02/09/12 09:53:16 |
Sebastian Huber |
Check that the file offset is valid after a seek
4.115
@62d8a54
02/08/12 14:54:54 |
Sebastian Huber |
POSIX conformance
For symbolic links, the length in bytes of the …
4.115
@1052242
02/02/12 14:45:16 |
Sebastian Huber |
Removed fpathconf file system node handler.
There existed no calling …
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@8504f124
12/09/11 07:21:02 |
Chris Johns |
2011-12-09 Chris Johns <chrisj@…>
PR …
4.115
@47528a8f
12/06/11 15:20:50 |
Ralf Corsepius |
2011-12-06 Ralf Corsépius <ralf.corsepius@…>
4.115
@46ae58a5
12/06/11 07:05:54 |
Ralf Corsepius |
4.115
@326d83f
12/02/11 17:27:16 |
Ralf Corsepius |
2011-12-02 Ralf Corsépius <ralf.corsepius@…>
4.115
@03f407b
12/02/11 17:25:31 |
Ralf Corsepius |
4.115
@3eb8f288
12/02/11 13:39:58 |
Ralf Corsepius |
4.115
@66b8047
11/06/11 12:44:24 |
Ralf Corsepius |
Remove stray whitespaces.
4.115
@984c4c49
11/06/11 12:00:04 |
Ralf Corsepius |
2011-11-06 Ralf Corsépius <ralf.corsepius@…>
4.115
@22ad8263
11/06/11 11:57:10 |
Ralf Corsepius |
4.115
@59ca2f8c
11/06/11 11:54:49 |
Ralf Corsepius |
4.115
@e4c0a04b
11/06/11 11:52:45 |
Ralf Corsepius |
4.115
@e3865876
11/06/11 07:08:32 |
Ralf Corsepius |
4.115
@1e0f63b5
11/03/11 22:02:01 |
Chris Johns |
2011-11-04 Chris Johns <chrisj@…>
4.115
@97ae192a
11/03/11 06:32:42 |
Chris Johns |
2011-11-03 Chris Johns <chrisj@…>
PR …
4.115
@8c30ecd
10/26/11 03:49:27 |
Ralf Corsepius |
2011-10-26 Ralf Corsépius <ralf.corsepius@…>
4.115
@9b42315c
10/20/11 10:48:30 |
Ralf Corsepius |
2011-10-20 Ralf Corsépius <ralf.corsepius@…>
4.115
@49755cfd
10/18/11 09:35:17 |
Ralf Corsepius |
2011-10-18 Ralf Corsépius <ralf.corsepius@…>
4.115
@f25425b1
10/17/11 13:59:26 |
Ralf Corsepius |
2011-10-17 Ralf Corsépius <ralf.corsepius@…>
4.115
@48943dc
10/10/11 07:11:26 |
Ralf Corsepius |
2011-10-10 Ralf Corsépius <ralf.corsepius@…>
4.115
@da30d6c0
10/07/11 09:36:35 |
Ralf Corsepius |
2011-10-07 Ralf Corsépius <ralf.corsepius@…>
4.115
@13c4f853
08/02/11 19:25:59 |
Joel Sherrill |
2011-08-02 Joel Sherrill <joel.sherrill@…>
PR 1877/cpukit …
4.115
@363aace
08/01/11 07:27:25 |
Sebastian Huber |
2011-08-01 Sebastian Huber <sebastian.huber@…>
4.115
@186fee2
07/21/11 13:18:30 |
Joel Sherrill |
2011-07-21 Joel Sherrill <joel.sherrill@…>
4.115
@a2900a8b
07/21/11 12:03:26 |
Sebastian Huber |
2011-07-21 Sebastian Huber <sebastian.huber@…>
4.115
@aa03052
07/13/11 19:05:43 |
Joel Sherrill |
2011-07-13 Till Straumann <strauman@…>
PR …
4.115
@acb92e3
07/04/11 00:31:25 |
Chris Johns |
2011-07-04 Chris Johns <chrisj@…>
PR …
4.115
@21242c2
06/24/11 17:52:58 |
Joel Sherrill |
2011-06-24 Joel Sherrill <joel.sherrill@…>
4.115
@b5e2739
06/10/11 18:16:42 |
Joel Sherrill |
2011-06-10 Joel Sherrill <joel.sherrilL@…>
PR …
4.115
@e0ae9008
05/11/11 03:01:54 |
Chris Johns |
2011-05-11 Chris Johns <chrisj@…>
PR …
4.115
@e0bc543
04/16/11 04:40:11 |
Chris Johns |
2011-04-16 Chris Johns <chrisj@…>
PR …
4.115
@8bbb37d
04/15/11 11:13:21 |
Sebastian Huber |
2011-04-15 Sebastian Huber <sebastian.huber@…>
4.115
@5d2aacc2
04/05/11 13:38:49 |
Joel Sherrill |
2011-04-05 Joel Sherrill <joel.sherrilL@…>
PR …
4.115
@315c9b89
03/15/11 15:05:29 |
Joel Sherrill |
2011-03-15 Joel Sherrill <joel.sherrill@…>
4.115
@59762469
03/15/11 07:32:39 |
Chris Johns |
2011-03-15 Chris Johns <chrisj@…>
4.115
@ecfeb16b
03/15/11 05:14:39 |
Chris Johns |
PR …
4.115
@d0fcd0b
03/15/11 05:02:34 |
Chris Johns |
PR 1763/shell
4.115
@78d1190
03/14/11 16:24:00 |
Joel Sherrill |
2011-03-14 Joel Sherrill <joel.sherrill@…>
4.115
@9a65833
03/03/11 06:22:48 |
Chris Johns |
2011-03-03 Chris Johns <chrisj@…>
4.115
@8485c7f
02/23/11 13:57:02 |
Ralf Corsepius |
2011-02-23 Ralf Corsépius <ralf.corsepius@…>
4.115
@9632f83
02/07/11 22:41:37 |
Chris Johns |
011-02-08 Brett Swimley <bswimley@…>
4.115
@a84d456
01/04/11 19:18:09 |
Joel Sherrill |
2011-01-04 Joel Sherrill <joel.sherrill@…>
4.115
@f447932f
01/04/11 18:32:59 |
Joel Sherrill |
4.115
@d00b7a5a
12/28/10 09:55:57 |
Sebastian Huber |
2010-12-28 Sebastian Huber <sebastian.huber@…>
4.115
@3ae5950
12/28/10 08:46:57 |
Sebastian Huber |
4.115
@45edf78
12/27/10 14:35:13 |
Sebastian Huber |
2010-12-27 Sebastian Huber <sebastian.huber@…>
4.115
@ce002b16
11/25/10 09:27:06 |
Sebastian Huber |
2010-11-25 Sebastian Huber <sebastian.huber@…>
4.115
@6dd4853c
10/18/10 22:39:35 |
Chris Johns |
2010-10-19 Chris Johns <chrisj@…>
4.115
@0a127c5
10/11/10 04:34:48 |
Chris Johns |
2010-10-11 Chris Johns <chrisj@…>
4.115
@d62711f2
09/27/10 12:32:40 |
Sebastian Huber |
2010-09-27 Sebastian Huber <sebastian.huber@…>
4.115
@c188f8e
08/28/10 19:49:47 |
Joel Sherrill |
Just comment out line.
4.115
@28ff594
08/28/10 19:48:41 |
Joel Sherrill |
2010-08-28 Joel Sherrill <joel.sherrilL@…>
4.115
@f70b7917
08/27/10 17:43:26 |
Joel Sherrill |
2010-08-27 Joel Sherrill <joel.sherrilL@…>
PR …
4.115
@9063a0e
08/27/10 17:32:59 |
Joel Sherrill |
PR …
4.115
@2252163
08/27/10 06:42:46 |
Sebastian Huber |
2010-08-26 Sebastian Huber <sebastian.huber@…>
4.115
@6ed22ab
08/26/10 06:31:15 |
Chris Johns |
2010-08-26 Chris Johns <chrisj@…>
4.115
@9788279
08/25/10 09:37:49 |
Sebastian Huber |
2010-08-25 Sebastian Huber <sebastian.huber@…>
4.115
@bf4766fe
08/23/10 23:17:42 |
Joel Sherrill |
2010-08-23 Joel Sherrill <joel.sherrill@…>
4.115
@85b9e7f
08/23/10 21:29:31 |
Joel Sherrill |
CID 99
CID 100 …
4.115
@2728f7e5
08/18/10 09:58:15 |
Chris Johns |
2010-08-18 Chris Johns <chrisj@…>
PR …
4.115
@c3367ad
08/13/10 04:49:31 |
Chris Johns |
2010-08-13 Chris Johns <chrisj@…>
4.115
@8f0b334
08/10/10 17:41:32 |
Joel Sherrill |
2010-08-09 Bharath Suri <bharath.s.jois@…>
PR …
4.115
@561ab3b
08/08/10 20:25:00 |
Joel Sherrill |
2010-08-08 Joel Sherrill <joel.sherrill@…>
4.115
@8851c0a
08/02/10 18:27:23 |
Joel Sherrill |
2010-08-02 Joel Sherrill <joel.sherrill@…>
4.115
@0aea082
07/30/10 22:36:32 |
Joel Sherrill |
2010-07-30 Joel Sherrill <joel.sherrill@…>
4.115
@4f3d72f
07/27/10 18:11:42 |
Joel Sherrill |
2010-07-27 Joel Sherrill <joel.sherrill@…>
4.115
@bc3fe3c
07/26/10 21:29:24 |
Joel Sherrill |
2010-07-26 Joel Sherrill <joel.sherrill@…>
4.115
@33645763
07/23/10 00:11:32 |
Joel Sherrill |
2010-07-22 Joel Sherrill <joel.sherrill@…>
PR 1627/testing …
4.115
@f4dea06
07/15/10 08:59:46 |
Sebastian Huber |
2010-07-16 Sebastian Huber <sebastian.huber@…>
4.115
@de39b51
07/15/10 08:46:06 |
Sebastian Huber |
4.115
