@1cfe012
06/19/15 12:24:27 |
Sebastian Huber |
nfsclient: Use an interrupt lock
4.115
@92422be
03/10/15 13:54:30 |
Gedare Bloom |
dosfs: avoid buffer-overread. closes #2292.
4.115
@f60b4f93
04/27/15 07:10:49 |
Sebastian Huber |
dosfs: Fix warning fix
4.115
@9f10911
04/22/15 19:29:21 |
Sebastian Huber |
score: Delete Thread_queue_Control::state
Use a parameter for …
4.115
@4727585
03/20/15 15:42:33 |
Joel Sherrill |
imfs.h: Add cast to remove warning for pointer/integer size mismatch
4.115
@e6f4a612
03/16/15 19:28:20 |
Sebastian Huber |
IMFS: NUL-terminate name returned by readdir()
4.115
@4b7df86
03/13/15 21:10:08 |
Joel Sherrill |
cpukit/libdl/rtl-obj-comp.c: Use correct printf() specification
4.115
@674f8b1b
03/16/15 17:23:36 |
jamie |
IMFS: don't strlen() an unterminated string in IMFS_dir_read().
4.115
@b4d1f08
03/16/15 16:14:15 |
Gedare Bloom |
rfs: cast minor to uintptr_t to truncate explicitly
4.115
@e0eb07a
03/06/15 19:26:12 |
Joel Sherrill |
Fix more Doxygen typos
4.115
@cc69334f
03/06/15 16:35:40 |
Joel Sherrill |
Fix a number of minor Doxygen formatting issues
4.115
@c735cd5
03/05/15 09:34:28 |
Sebastian Huber |
dosfs: Fix warnings
4.115
@2c88438
03/05/15 09:26:22 |
Sebastian Huber |
IMFS: Fix warning
4.115
@29d36fa
03/05/15 08:58:43 |
Sebastian Huber |
IMFS: Include missing header file
4.115
@81c73acf
03/05/15 08:58:22 |
Sebastian Huber |
IMFS: Fix warning
4.115
@a45dfa14
02/20/15 08:42:15 |
Sebastian Huber |
IMFS: Fix copy on write for linfiles
4.115
@fd14430
02/18/15 16:06:05 |
Sebastian Huber |
IMFS: Silence warning
4.115
@a43a3466
02/15/15 09:38:15 |
Sebastian Huber |
IMFS: Implement variable length node names
This reduces the average …
4.115
@f785492
02/14/15 19:07:19 |
Sebastian Huber |
IMFS: Add CONFIGURE_IMFS_DISABLE_READDIR
4.115
@a9df916
02/08/15 18:43:09 |
Sebastian Huber |
IMFS: Add fine grained configuration
Remove miniIMFS. Statically …
4.115
@a2f5c7e1
02/08/15 15:09:27 |
Sebastian Huber |
IMFS: Allow static initialization of FS info
4.115
@11026956
02/06/15 19:50:49 |
Sebastian Huber |
IMFS: Fix resource leak
4.115
@60cf8a5
02/06/15 15:32:39 |
Sebastian Huber |
IMFS: Add root directory to FS info
Fix memory leak in IMFS_fsunmount().
4.115
@9247d3f
02/05/15 15:58:09 |
Sebastian Huber |
IMFS: Simplify IMFS_symlink()
4.115
@e4d35d8
02/05/15 15:43:58 |
Sebastian Huber |
IMFS: Split linfile and memfile modules
Make several functions static.
4.115
@24ec25d
02/05/15 15:14:59 |
Sebastian Huber |
IMFS: Introduce IMFS_mknod_control
Drop IMFS_node_control::node_size …
4.115
@194eb007
02/12/15 19:52:16 |
Sebastian Huber |
Filesystem: Use ENOTSUP for default mount/unmount
4.115
@eb77534
02/09/15 14:37:00 |
Sebastian Huber |
Filesystem: Delete unused fsmountme_h handler
4.115
@924cbd4f
01/31/15 20:27:01 |
Sebastian Huber |
IMFS: Simplify ino generation
The type of ino_t is unsigned long, so …
4.115
@95308caf
01/31/15 20:25:57 |
Sebastian Huber |
IMFS: Use rtems_filesystem_make_dev_t_from_pointer
4.115
@40d062f5
01/28/15 17:47:19 |
Sebastian Huber |
IMFS: Reduce IMFS node types
Provide only types used by IMFS_mknod().
4.115
@29fa241
01/28/15 17:25:49 |
Sebastian Huber |
IMFS: Aggregate link support in dedicated modules
4.115
@cf36b70
12/31/14 09:56:05 |
Sebastian Huber |
IMFS: Replace node union with individual struct
This reduces the …
4.115
@c625a641
12/21/14 19:12:28 |
Sebastian Huber |
Filesystem: Delete node type operation
Use the fstat handler instead.
4.115
@86364e8
12/05/13 01:52:42 |
Nick Withers |
Correct error return mismatches
Closes #2139
4.115
@9d9c426
03/07/14 03:23:30 |
Nick Withers |
Teach rtems_tarfs_load() about symlinks
4.115
@b657ea4d
12/05/14 12:05:34 |
Sebastian Huber |
nfsclient: Avoid FILE and LINE
The FILE prevents …
4.115
@e4d8513
11/14/14 07:58:00 |
cederman |
nfs: Add RPCd task affinity config option
Similar to the task …
4.115
@8dbbea6b
11/27/14 15:29:16 |
Joel Sherrill |
msdos_file.c: Reverse return codes per Gedare
4.115
@4862532
11/19/14 20:40:16 |
josh.oguin |
imfs/imfs_handlers_link.c: Add _Assert for NULL pointer
CodeSonar? …
4.115
@43d6a28
11/19/14 20:39:14 |
josh.oguin |
dosfs/msdos_misc.c: Remove unnecessary operation
CodeSonar? flagged …
4.115
@21c0ca8
11/19/14 20:38:16 |
josh.oguin |
dosfs/msdos_file.c: Return an error if it occurs
4.115
@10f28a3a
11/19/14 20:36:44 |
josh.oguin |
dosfs/msdos_conv.c: Remove unnecessary operations
These were flagged …
4.115
@505b6806
11/24/14 19:55:29 |
Joel Sherrill |
rtems-rfs-rtems.c: Add cast to address warning
4.115
@abf3892c
11/20/14 23:22:22 |
Joel Sherrill |
pipe/fifo.c: NULL dereference flagged by Coverity ID 1063889
It does …
4.115
@e8abdfb
11/20/14 23:21:05 |
Joel Sherrill |
dosfs/fat_fat_operations.c: Explicitly ignore return (Coverity ID …
4.115
@8f73af85
11/20/14 23:19:13 |
Joel Sherrill |
dosfs/msdos_format.c: Dead code removal (Coverity ID 1255325)
4.115
@11925eef
11/21/14 07:49:57 |
Sebastian Huber |
Delete or rename MIN/MAX macros and defines
Include <sys/param.h> if …
4.115
@7bfa0970
11/17/14 12:00:17 |
Sebastian Huber |
dosfs: Avoid MIN() re-definition
4.115
@cf4f962
10/23/14 06:21:26 |
Sebastian Huber |
dosfs: Write meta-data only if it changed
4.115
@a7eaaae8
10/20/14 07:33:34 |
Sebastian Huber |
dosfs: Support ctime and mtime
Implement ctime and mtime updates …
4.115
@e48bbaa
10/20/14 16:31:07 |
Joel Sherrill |
cpukit/libfs/src/imfs/ioman.c: Fix typo
4.115
@b83fe77c
10/20/14 02:11:00 |
Joel Sherrill |
jffs2: Add casts and constant designators to address warnings on …
4.115
@803c49cb
10/13/14 20:59:51 |
Joel Sherrill |
jffs2/src/fs-rtems.c: Add include of <rtems/libio.h> for prototypes
4.115
@23de6fa8
10/13/14 20:56:54 |
Joel Sherrill |
jffs2/src/fs-rtems.c: Eliminate set but not used warnings
4.115
@38f7c78
10/14/14 04:03:47 |
Gedare Bloom |
rfs: explicitly cast to dev_t
4.115
@f641b15
09/04/14 20:39:41 |
Joel Sherrill |
Revert: rtems-rfs-buffer.c: Correct printf() format specifiers to …
4.115
@4c9f02d
09/11/14 11:04:42 |
Sebastian Huber |
dosfs: Check error status
4.115
@2dd1e75e
09/03/14 14:59:10 |
Joel Sherrill |
rtems-rfs-buffer.c: Correct printf() format specifiers to eliminate …
4.115
@5f9c208
09/03/14 03:15:24 |
Chris Johns |
libfs: Fix the warning in the RFS.
Return the first error if one or …
4.115
@59990cc
08/29/14 02:48:01 |
Chris Johns |
Regenerate all preinstall.am files.
With this patch the preinstall.am …
4.115
@73bf499
06/10/14 08:56:55 |
Sebastian Huber |
JFFS2: Add device identifier for the flash device
It is used in …
4.115
@39840438
05/16/14 13:34:33 |
Sebastian Huber |
dosfs: Fix read from invalid memory area
4.115
@5d2ae6e2
04/25/14 07:30:37 |
Chris Johns |
libfs/rfs: Fix the fstime failures for the RFS file system.
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@ba386a6
01/31/14 18:28:47 |
Joel Sherrill |
dosfs/fat.c: Remove use of register keyword
4.115
@5b34e7a
01/16/14 12:05:13 |
Sebastian Huber |
IMFS: Improved support for generic nodes
The …
4.115
@45e82bb8
01/16/14 12:02:50 |
Sebastian Huber |
IMFS: Allow sockets as generic nodes
4.115
@c1d8ee4
12/17/13 09:59:13 |
Sebastian Huber |
libcsupport: Accept NULL for zero-length entries
4.115
@56bea43
12/16/13 13:26:29 |
Sebastian Huber |
Filesystem: Use default kqfilter and poll handler
4.115
@2f68778
12/16/13 12:44:13 |
Sebastian Huber |
Filesystem: Add readv/writev handlers
The readv() and writev() …
4.115
@a9619f3c
12/18/13 17:00:42 |
alan.cudmore |
For PR 2164 - RFS File System - fix bitmap_create_search loop bug
4.115
@9b48dc6
12/18/13 17:37:47 |
alan.cudmore |
For PR 2162 - RFS File System - statvfs reports 1 block free
This is …
4.115
@e60b7b1
12/18/13 16:39:19 |
alan.cudmore |
For PR 2163 - RFS File System - fix group search algorithm bug
This …
4.115
@fb664a2
12/16/13 09:55:27 |
Sebastian Huber |
nfsclient: Move defines to cover all header files
4.115
@99c2323
12/13/13 12:57:06 |
Sebastian Huber |
JFFS2: Do not re-define struct iovec
4.115
@98e5c95
12/11/13 08:39:09 |
Sebastian Huber |
PR2160: imfs: Use ENOSYS for unsupported nodes
Return an error status …
4.115
@c59f668
12/10/13 04:00:27 |
Chris Johns |
PR2138: rtems_rfs_rtems_initialize() can erroneously set errno.
Patch …
4.115
@9da8740
12/10/13 01:33:22 |
Chris Johns |
PR2159: Have the FIFO driver read follow POSIX standard.
The read …
4.115
@b51d8a4
12/10/13 01:30:20 |
Chris Johns |
libfs/imfs: Set the FIFO control block.
The FIFO was incorrectly set …
4.115
@03e54614
11/27/13 19:06:16 |
Joel Sherrill |
statvfs filesystem handlers: Remove restrict
4.115
@bb81e04
11/21/13 22:54:21 |
Daniel Ramirez |
statvfs and ALL filesystem handlers: Add restrict keyword.
4.115
@8cb2882
10/31/13 14:00:20 |
Sebastian Huber |
Filesystem: Add kernel event filter handler
This handler is necessary …
4.115
@16829460
10/31/13 14:00:14 |
Sebastian Huber |
Filesystem: Add poll() handler
This handler is necessary to implement …
4.115
@ba120d1
10/31/13 13:17:57 |
Sebastian Huber |
Filesystem: Use ENOTTY for default ioctl() handler
This is in line …
4.115
@73e7345
10/27/13 17:49:01 |
Sebastian Huber |
IMFS: Use IMFS_mtime_ctime_update()
4.115
@e89ed92
10/18/13 16:08:00 |
ralf.kirchner |
dosfs: Ensure initially the sector size is used as bdbuf block size
4.115
@1f724a0
10/16/13 12:45:00 |
Sebastian Huber |
RFS: Include missing header file
4.115
@3c2bb22
10/11/13 14:22:00 |
Sebastian Huber |
Return EINVAL in default ftruncate() handler
According to POSIX this …
4.115
@40eea001
09/22/13 15:36:57 |
Joel Sherrill |
nfsclient/src/dirutils.c: Fix missing prototype warnings
4.115
@3c96bee
09/12/13 13:32:07 |
Sebastian Huber |
JFFS2: Add RTEMS support
4.115
@78b85286
09/12/13 14:53:41 |
Sebastian Huber |
JFFS2: Update Linux compatibility layer
Modify compatbility layer for …
4.115
@672038b
09/12/13 14:46:51 |
Sebastian Huber |
JFFS2: Import from eCos
Import of Linux compatibility layer and JFFS2 …
4.115
@0c0f128
09/12/13 13:57:47 |
Sebastian Huber |
JFFS2: Import from Linux
Import of Journalling Flash File System, …
4.115
@c5b2d79
09/13/13 13:17:57 |
Sebastian Huber |
IMFS: Fix truncate according to POSIX
ftruncate() and open() with …
4.115
@f82851c5
09/13/13 13:17:35 |
Sebastian Huber |
IMFS: Use inline functions instead of macros
4.115
@b6657c39
09/11/13 08:34:02 |
Sebastian Huber |
Filesystem: Add and use rtems_filesystem_chmod()
Implement POSIX …
4.115
@3dbb68d
09/10/13 08:48:23 |
ralf.kirchner |
dosfs: Correct handling of iconv() return value
4.115
@8ee95e6
09/05/13 18:44:24 |
Gedare Bloom |
imfs: use safe string functions
Replace strcpy and strcat with …
4.115
@97ae1eeb
09/05/13 18:13:32 |
Gedare Bloom |
imfs: check return value from mkdir
4.115
