Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit/libfs/src
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @1996aee7   02/07/05 13:25:14 Ralf Corsepius 2005-02-07 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @a6f5d89   01/28/05 08:44:51 Ralf Corsepius New header guard. 4.104.114.84.95
(edit) @adc829ed   01/19/05 05:10:38 Ralf Corsepius 2005-01-18 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @0247c6c   01/19/05 04:54:12 Ralf Corsepius 2005-01-18 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @fb8f0bc   01/19/05 03:44:36 Ralf Corsepius Cosmetics. 4.104.114.84.95
(edit) @e7b1b05   01/19/05 02:36:57 Ralf Corsepius 2005-01-18 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @c3bb0619   01/19/05 02:31:15 Ralf Corsepius Fix typos in comment. 4.104.114.84.95
(edit) @a3f1b54   11/20/04 03:16:12 Ralf Corsepius 2004-11-20 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @c36f885a   11/20/04 03:11:41 Ralf Corsepius 2004-11-20 Ralf Corsepius <ralf.corsepiu@…> PR … 4.104.114.84.95
(edit) @b34665f8   11/20/04 03:02:54 Ralf Corsepius 2004-11-20 Ralf Corsepius <ralf.corsepiu@…> PR … 4.104.114.84.95
(edit) @8c14432   10/26/04 09:48:53 Ralf Corsepius 2004-10-26 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @3b2c473   04/17/04 08:39:22 Ralf Corsepius 2004-04-17 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @a5305f6b   04/17/04 08:34:41 Ralf Corsepius Remove stray white spaces. 4.104.114.84.95
(edit) @3239698   04/15/04 13:26:21 Ralf Corsepius Remove stray white spaces. 4.104.114.84.95
(edit) @ebbe119e   04/01/04 10:14:23 Ralf Corsepius 2004-04-01 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @f91bbe64   03/22/04 17:10:43 Ralf Corsepius 2004-03-22 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @b6e03375   03/09/04 09:15:48 Ralf Corsepius Remove refs to Makefile*. 4.104.114.84.95
(edit) @2609e83   03/08/04 16:26:41 Ralf Corsepius Unused. 4.104.114.84.95
(edit) @7cdf8b7e   11/27/03 16:59:19 Ralf Corsepius 2003-11-27 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @2ea1779   11/20/03 07:06:08 Ralf Corsepius 2003-11-20 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @471feaf   10/22/03 19:16:44 Joel Sherrill 2003-10-22 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
(edit) @08c09e24   10/22/03 16:35:18 Joel Sherrill 2003-10-22 Ralf Corsepius <corsepiu@…> PR … 4.104.114.84.95
(edit) @897fe13   10/22/03 16:31:17 Joel Sherrill 2003-10-22 Joel Sherrill <joel@…> PR 440/filesystem * … 4.104.114.84.95
(edit) @a4e44c29   10/21/03 05:50:02 Ralf Corsepius 2003-10-21 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @c788f380   10/21/03 05:44:51 Ralf Corsepius 2003-10-21 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @93fabe27   10/21/03 05:32:10 Ralf Corsepius 2003-10-21 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @0f07ee7   09/26/03 17:19:21 Joel Sherrill 2003-09-26 Joel Sherrill <joel@…> PR 492/filesystem * … 4.104.114.84.95
(edit) @8dbb19ab   09/09/03 12:56:13 Joel Sherrill 2003-09-09 Ralf Corsepius <ralf_corsepius@…> PR … 4.104.114.84.95
(edit) @cf0539b1   09/04/03 18:54:17 Joel Sherrill 2003-09-04 Joel Sherrill <joel@…> * src/dosfs/dosfs.h, … 4.104.114.84.95
(edit) @726b06f   09/03/03 13:40:13 Joel Sherrill 2003-09-03 Joel Sherrill <joel@…> * msdos_create.c: Remove … 4.104.114.84.95
(edit) @8d49b7c   08/05/03 20:26:09 Jennifer.Averett 2003-08-05 <djc915@…> PR 443/filesystem * … 4.104.114.84.95
(edit) @92b8547b   08/05/03 18:05:20 Jennifer.Averett 2003-08-05 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
(edit) @e0b7cbb   08/05/03 14:45:46 Jennifer.Averett 2003-08-05 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
(edit) @2e7b6db   08/05/03 14:05:56 Jennifer.Averett 2003-08-04 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
(edit) @1e4d4f85   07/24/03 19:54:55 Jennifer.Averett 2003-07-24 jennifer averett <jennifer.averett@…> PR … 4.104.114.84.95
(edit) @1679a7b   07/14/03 23:13:24 Chris Johns MSDOS Volume semaphore timeout is now NO TIMEOUT. MSDOS volume … 4.104.114.84.95
(edit) @c41c8b7   07/08/03 09:47:21 Ralf Corsepius 2003-07-08 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @ffc144e   07/08/03 08:58:21 Ralf Corsepius 2003-07-08 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @c125425   07/02/03 14:09:15 Chris Johns Patch from Victor V. Vengerov <vvv@…> to remove Linux code. 4.104.114.84.95
(edit) @3b44f153   07/02/03 14:08:43 Chris Johns Comments have been updated. 4.104.114.84.95
(edit) @5441193   06/10/03 17:32:00 Joel Sherrill 2003-06-10 Phil Torre <ptorre@…> PR 411/filesystem * … 4.104.114.84.95
(edit) @c151cfc3   03/25/03 17:01:45 Joel Sherrill 2003-03-25 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
(edit) @43f69a2d   02/03/03 22:05:20 Joel Sherrill 2003-02-03 Steven Johnson <sjohnson@…> PR 338/filesystem … 4.104.114.84.95
(edit) @b9fa9f0   01/03/03 16:38:37 Joel Sherrill 2003-01-03 Eugeny S. Mints <Eugeny.Mints@…> * … 4.104.114.84.95
(edit) @2d709236   12/12/02 06:13:49 Ralf Corsepius 2002-12-12 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @a36e988   12/02/02 19:14:27 Joel Sherrill 2002-12-02 Joel Sherrill <joel@…> * src/dosfs/fat.h, … 4.104.114.84.95
(edit) @2b30225   10/02/02 17:42:39 Joel Sherrill 2002-10-02 Jennifer Averett <jennifer@…> * … 4.104.114.84.95
(edit) @d32359a7   09/14/02 21:01:39 Joel Sherrill 2002-09-14 Joel Sherrill <joel@…> * src/dosfs/fat.c, … 4.104.114.84.95
(edit) @239cf33   07/22/02 13:44:42 Ralf Corsepius 2002-07-22 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @3e83325   07/22/02 06:35:23 Ralf Corsepius 2002-07-22 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @7077c87   06/17/02 09:10:53 Ralf Corsepius 2002-06-17 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @47ef863a   05/28/02 17:21:17 Joel Sherrill 2002-05-18 Ralf Corsepius <corsepiu@…> Move from … 4.104.114.84.95
(edit) @c873f40   04/08/02 18:28:59 Joel Sherrill 2002-04-06 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @6940f507   04/04/02 22:17:14 Joel Sherrill 2001-04-04 Joel Sherrill <joel@…> * src/dosfs/Makefile.am: … 4.104.114.84.95
(edit) @aed1f02a   04/04/02 18:22:23 Joel Sherrill 2002-04-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @9fff6bf   03/28/02 13:52:49 Joel Sherrill 2002-03-27 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @05b8b60   03/28/02 00:49:35 Joel Sherrill 2002-03-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @c31deeb   03/20/02 14:21:42 Joel Sherrill 2002-03-16 Ralf Corsepius <corsepiu@…> Addressing PR … 4.104.114.84.95
(edit) @2de2bec   03/15/02 18:55:09 Joel Sherrill 2002-03-14 Ralf Corsepius <corsepiu@…> Reported and … 4.104.114.84.95
(edit) @f9d1afc   03/01/02 16:17:53 Joel Sherrill 2001-03-01 Joel Sherrill <joel@…> * src/imfs/.cvsignore: … 4.104.114.84.95
(edit) @f36a7bfc   02/28/02 20:43:50 Joel Sherrill 2002-02-28 Victor V. Vengerov <vvv@…> * DOS filesystem … 4.104.114.84.95
(edit) @74e0ba5   01/08/02 12:05:36 Joel Sherrill 2002-01-07 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @b2709481   01/04/02 18:30:58 Joel Sherrill 2002-01-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @f667aaec   11/26/01 14:34:09 Joel Sherrill 2001-11-26 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @47901d8   11/08/01 00:24:55 Joel Sherrill 2001-11-07 Jennifer Averett <jennifer@…> Reported by … 4.104.114.84.95
(edit) @fa2f9790   10/26/01 19:40:07 Joel Sherrill 2001-10-26 Victor V. Vengerov <vvv@…> * … 4.104.114.84.95
(edit) @8670008c   10/16/01 19:06:11 Joel Sherrill 2001-10-16 Chris Johns <ccj@…> * imfs/imfs_load_tar.c: Changed … 4.104.114.84.95
(edit) @d9b0b866   10/11/01 13:16:24 Joel Sherrill 2001-10-10 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @52b3ff6   09/28/01 13:34:57 Joel Sherrill 2001-09-28 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @3520280   09/24/01 18:29:17 Joel Sherrill 2001-09-22 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @b6a2d2fa   08/09/01 22:09:36 Joel Sherrill 2001-08-09 Fernando-Ruiz Casas <correo@…> * … 4.104.114.84.95
(edit) @b8c8cab   07/06/01 21:48:16 Joel Sherrill 2001-07-06 Thomas Doerfler <Thomas.Doerfler@…> * … 4.104.114.84.95
(edit) @e807db0   05/25/01 13:47:47 Joel Sherrill 2001-05-25 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @eb22ebe   04/24/01 23:06:50 Joel Sherrill 2001-04-24 Joel Sherrill <joel@…> * src/imfs/memfile.c … 4.104.114.84.95
(edit) @53462762   04/20/01 13:27:24 Joel Sherrill 2001-04-20 Joel Sherrill <joel@…> * src/imfs/imfs_debug.c … 4.104.114.84.95
(edit) @d79ef17   03/23/01 14:02:02 Joel Sherrill 2001-03-23 Joel Sherrill <joel@…> * src/imfs/memfile.c: … 4.104.114.84.95
(edit) @8b5d0db3   02/05/01 18:24:14 Joel Sherrill 2001-02-03 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @d6b1d73   01/22/01 14:05:14 Joel Sherrill 2001-01-22 Ralf Corsepius <corsepiu@…> * configure.in: … 4.104.114.84.95
(edit) @d1941587   01/12/01 13:44:12 Joel Sherrill 2001-01-12 Jake Janovetz <janovetz@…> * src/imfs/imfs.h, … 4.104.114.84.95
(edit) @0ef748fb   12/13/00 17:53:55 Joel Sherrill 2000-12-12 Jake Janovetz <janovetz@…> * … 4.104.114.84.95
(edit) @6b5519a   11/28/00 21:53:48 Joel Sherrill 2000-11-28 Joel Sherrill <joel@…> * src/imfs/memfile.c: … 4.104.114.84.95
(edit) @13e47e2e   11/17/00 18:46:03 Jennifer.Averett 2000-11-17 Jennifer Averret <jennifer@…> * … 4.104.114.84.95
(edit) @c058578   11/01/00 21:02:46 Joel Sherrill 2000-11-01 Joel Sherrill <joel@…> * src/imfs/Makefile.am, … 4.104.114.84.95
(edit) @a0756c9a   10/25/00 16:51:22 Joel Sherrill 2000-10-24 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @5b59c4d   10/19/00 15:52:22 Joel Sherrill 2000-10-19 Joel Sherrill <joel@…> * .cvsignore, … 4.104.114.84.95
(edit) @d71c6c1   10/18/00 18:10:55 Joel Sherrill 2000-10-18 Chris Johns <ccj@…> * libfs created. * src, … 4.104.114.84.95
(edit) @9c3fa30   09/28/00 20:19:23 Joel Sherrill 2000-09-28 Joel Sherrill <joel@…> * libc/libio.h … 4.104.114.84.95
(edit) @662678d1   08/25/00 13:13:57 Joel Sherrill 2000-08-25 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @dd19c0b   08/11/00 20:04:27 Joel Sherrill 2000-08-11 Chris Johns <ccj@…> * libc/chmod.c: Return ENOTSUP … 4.104.114.84.95
(edit) @3af0828   07/02/00 12:29:47 Joel Sherrill Fixed stat_ino should be st_ino. 4.104.114.84.95
(edit) @068b6473   06/30/00 12:36:32 Joel Sherrill Patch from Chris Johns <cjohns@…> so the directory read … 4.104.114.84.95
(edit) @e5d6705e   06/30/00 12:33:13 Joel Sherrill Patch from Chris Johns <cjohns@…> to add support for … 4.104.114.84.95
(edit) @e42a135   06/26/00 14:49:58 Joel Sherrill Patch from Chris Johns <cjohns@…> and Jennifer Averett … 4.104.114.84.95
(edit) @5e0e012c   06/26/00 14:46:19 Joel Sherrill Patch from Chris Johns <cjohns@…> and Jennifer Averett … 4.104.114.84.95
(edit) @df49c60   06/12/00 15:00:15 Joel Sherrill Merged from 4.5.0-beta3a 4.104.114.84.95
(edit) @562e7ed1   02/11/00 15:54:47 Joel Sherrill Increased block size to 128 and added comments based on feedback from … 4.104.114.84.95
(edit) @3a8b95e   01/05/00 21:32:57 Joel Sherrill Spacing corrected. 4.104.114.84.95
(edit) @08311cc3   11/17/99 17:51:34 Joel Sherrill Updated copyright notice. 4.104.114.84.95
(edit) @18c3155   11/16/99 22:45:33 Jennifer.Averett Added handler for fsync. For the memfile it is the same as the data sync. 4.104.114.84.95
(edit) @b440e57b   11/09/99 13:40:30 Joel Sherrill Added imfs_unixstub.c to satisfy linker problems on UNIX port. 4.104.114.84.95
