Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit/libfs/src/dosfs
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @fb8f0bc   01/19/05 03:44:36 Ralf Corsepius Cosmetics. 4.104.114.84.95
(edit) @e7b1b05   01/19/05 02:36:57 Ralf Corsepius 2005-01-18 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @c3bb0619   01/19/05 02:31:15 Ralf Corsepius Fix typos in comment. 4.104.114.84.95
(edit) @a3f1b54   11/20/04 03:16:12 Ralf Corsepius 2004-11-20 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @c36f885a   11/20/04 03:11:41 Ralf Corsepius 2004-11-20 Ralf Corsepius <ralf.corsepiu@…> PR … 4.104.114.84.95
(edit) @b34665f8   11/20/04 03:02:54 Ralf Corsepius 2004-11-20 Ralf Corsepius <ralf.corsepiu@…> PR … 4.104.114.84.95
(edit) @8c14432   10/26/04 09:48:53 Ralf Corsepius 2004-10-26 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @a5305f6b   04/17/04 08:34:41 Ralf Corsepius Remove stray white spaces. 4.104.114.84.95
(edit) @3239698   04/15/04 13:26:21 Ralf Corsepius Remove stray white spaces. 4.104.114.84.95
(edit) @f91bbe64   03/22/04 17:10:43 Ralf Corsepius 2004-03-22 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @b6e03375   03/09/04 09:15:48 Ralf Corsepius Remove refs to Makefile*. 4.104.114.84.95
(edit) @7cdf8b7e   11/27/03 16:59:19 Ralf Corsepius 2003-11-27 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @2ea1779   11/20/03 07:06:08 Ralf Corsepius 2003-11-20 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @471feaf   10/22/03 19:16:44 Joel Sherrill 2003-10-22 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
(edit) @08c09e24   10/22/03 16:35:18 Joel Sherrill 2003-10-22 Ralf Corsepius <corsepiu@…> PR … 4.104.114.84.95
(edit) @897fe13   10/22/03 16:31:17 Joel Sherrill 2003-10-22 Joel Sherrill <joel@…> PR 440/filesystem * … 4.104.114.84.95
(edit) @a4e44c29   10/21/03 05:50:02 Ralf Corsepius 2003-10-21 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @c788f380   10/21/03 05:44:51 Ralf Corsepius 2003-10-21 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @93fabe27   10/21/03 05:32:10 Ralf Corsepius 2003-10-21 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @0f07ee7   09/26/03 17:19:21 Joel Sherrill 2003-09-26 Joel Sherrill <joel@…> PR 492/filesystem * … 4.104.114.84.95
(edit) @8dbb19ab   09/09/03 12:56:13 Joel Sherrill 2003-09-09 Ralf Corsepius <ralf_corsepius@…> PR … 4.104.114.84.95
(edit) @cf0539b1   09/04/03 18:54:17 Joel Sherrill 2003-09-04 Joel Sherrill <joel@…> * src/dosfs/dosfs.h, … 4.104.114.84.95
(edit) @726b06f   09/03/03 13:40:13 Joel Sherrill 2003-09-03 Joel Sherrill <joel@…> * msdos_create.c: Remove … 4.104.114.84.95
(edit) @92b8547b   08/05/03 18:05:20 Jennifer.Averett 2003-08-05 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
(edit) @e0b7cbb   08/05/03 14:45:46 Jennifer.Averett 2003-08-05 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
(edit) @2e7b6db   08/05/03 14:05:56 Jennifer.Averett 2003-08-04 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
(edit) @1679a7b   07/14/03 23:13:24 Chris Johns MSDOS Volume semaphore timeout is now NO TIMEOUT. MSDOS volume … 4.104.114.84.95
(edit) @c41c8b7   07/08/03 09:47:21 Ralf Corsepius 2003-07-08 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @ffc144e   07/08/03 08:58:21 Ralf Corsepius 2003-07-08 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @c125425   07/02/03 14:09:15 Chris Johns Patch from Victor V. Vengerov <vvv@…> to remove Linux code. 4.104.114.84.95
(edit) @3b44f153   07/02/03 14:08:43 Chris Johns Comments have been updated. 4.104.114.84.95
(edit) @c151cfc3   03/25/03 17:01:45 Joel Sherrill 2003-03-25 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
(edit) @b9fa9f0   01/03/03 16:38:37 Joel Sherrill 2003-01-03 Eugeny S. Mints <Eugeny.Mints@…> * … 4.104.114.84.95
(edit) @2d709236   12/12/02 06:13:49 Ralf Corsepius 2002-12-12 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @a36e988   12/02/02 19:14:27 Joel Sherrill 2002-12-02 Joel Sherrill <joel@…> * src/dosfs/fat.h, … 4.104.114.84.95
(edit) @d32359a7   09/14/02 21:01:39 Joel Sherrill 2002-09-14 Joel Sherrill <joel@…> * src/dosfs/fat.c, … 4.104.114.84.95
(edit) @239cf33   07/22/02 13:44:42 Ralf Corsepius 2002-07-22 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @3e83325   07/22/02 06:35:23 Ralf Corsepius 2002-07-22 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @7077c87   06/17/02 09:10:53 Ralf Corsepius 2002-06-17 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @47ef863a   05/28/02 17:21:17 Joel Sherrill 2002-05-18 Ralf Corsepius <corsepiu@…> Move from … 4.104.114.84.95
(edit) @6940f507   04/04/02 22:17:14 Joel Sherrill 2001-04-04 Joel Sherrill <joel@…> * src/dosfs/Makefile.am: … 4.104.114.84.95
(edit) @aed1f02a   04/04/02 18:22:23 Joel Sherrill 2002-04-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @9fff6bf   03/28/02 13:52:49 Joel Sherrill 2002-03-27 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @05b8b60   03/28/02 00:49:35 Joel Sherrill 2002-03-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @c31deeb   03/20/02 14:21:42 Joel Sherrill 2002-03-16 Ralf Corsepius <corsepiu@…> Addressing PR … 4.104.114.84.95
(edit) @2de2bec   03/15/02 18:55:09 Joel Sherrill 2002-03-14 Ralf Corsepius <corsepiu@…> Reported and … 4.104.114.84.95
(add) @f36a7bfc   02/28/02 20:43:50 Joel Sherrill 2002-02-28 Victor V. Vengerov <vvv@…> * DOS filesystem … 4.104.114.84.95
