# # ChangeLog for cpukit/libfs/src/dosfs/msdos.h in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 14:28:12 Thu, 27 May 2010 16:23:04 GMT Ralf Corsepius [9813fb6] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) 2010-05-27 Ralf Corsépius * ... Thu, 04 Mar 2010 06:36:51 GMT Chris Johns [8ec7abb] * cpukit/ChangeLog (modified) * cpukit/httpd/asp.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/_rename_r.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_rename.c (added) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_rename.c (added) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) 010-03-04 Chris Johns * ... Mon, 02 Nov 2009 11:08:31 GMT Ralf Corsepius [5ac15a5] * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_conv.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) Use uint16_t instead of "unsigned short" to circumvent warning on ... Fri, 12 Jun 2009 01:53:33 GMT Chris Johns [7baa484] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/bdpart.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chmod.c (modified) * cpukit/libcsupport/src/chown.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/eval.c (modified) * cpukit/libcsupport/src/fchdir.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/stat.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libcsupport/src/utime.c (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/devfs/devfs_eval.c (modified) * cpukit/libfs/src/devfs/devstat.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_gtkn.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unlink.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/pipe/pipe.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) 2009-06-12 Chris Johns * ... Wed, 29 Apr 2009 08:31:27 GMT Chris Johns [07d6fd5] * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/fat_file.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_conv.c (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libmisc/shell/main_msdosfmt.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) 2009-04-29 Chris Johns * ... Mon, 09 Mar 2009 14:11:23 GMT Joel Sherrill [f855b9e3] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) 2009-03-09 Joel Sherrill ... Mon, 08 Sep 2008 15:19:34 GMT Joel Sherrill [a5b6cdd] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/libio_sockets.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/rtems/inline/rtems/rtems/part.inl (modified) * cpukit/score/include/rtems/score/bitfield.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/threadmp.c (modified) 2008-09-08 Joel Sherrill * ... Thu, 04 Sep 2008 08:33:06 GMT Ralf Corsepius [0a896eb] * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) Use "bool" instead of "rtems_boolean|boolean". Tue, 27 May 2008 10:34:15 GMT Thomas Doerfler [bf95ccb5] * cpukit/ChangeLog (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_config.c (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_getchild.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unixstub.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/posix/include/rtems/posix/psignal.h (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/src/ioregisterdriver.c (modified) * cpukit/sapi/src/itronapi.c (modified) * cpukit/sapi/src/posixapi.c (modified) Added const qualifier to various pointers and data tables to ... Fri, 08 Dec 2006 07:18:27 GMT Ralf Corsepius [7192476f] * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Use size_t instead of uint32_t for read/write count-args. Tue, 29 Aug 2006 19:38:08 GMT Joel Sherrill [e197621] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_free.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) 2006-08-29 Joel Sherrill * ... Fri, 05 Aug 2005 10:38:05 GMT Ralf Corsepius [a72c454] * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_free.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) Introduce msdos_status_t. Fri, 06 May 2005 14:57:43 GMT Joel Sherrill [b17ff491] * cpukit/ChangeLog (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/fat_file.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) 2005-05-06 Joel Sherrill * ... Sat, 20 Nov 2004 03:16:12 GMT Ralf Corsepius [a3f1b54] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) 2004-11-20 Ralf Corsepius * ... Sat, 17 Apr 2004 08:34:41 GMT Ralf Corsepius [a5305f6b] * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/fat_file.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_conv.c (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_free.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) * cpukit/libfs/src/dosfs/msdos_node_type.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_chown.c (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fcntl.c (modified) * cpukit/libfs/src/imfs/imfs_free.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_getchild.c (modified) * cpukit/libfs/src/imfs/imfs_gtkn.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_ntype.c (modified) * cpukit/libfs/src/imfs/imfs_readlink.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unixstub.c (modified) * cpukit/libfs/src/imfs/imfs_unlink.c (modified) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) Remove stray white spaces. Mon, 22 Mar 2004 17:10:43 GMT Ralf Corsepius [f91bbe64] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/fat_file.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/linearfile.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) 2004-03-22 Ralf Corsepius * ... Thu, 04 Sep 2003 18:54:17 GMT Joel Sherrill [cf0539b1] * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.h (modified) * cpukit/libfs/src/dosfs/fat_file.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_free.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) * cpukit/libfs/src/dosfs/msdos_node_type.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_chown.c (modified) * cpukit/libfs/src/imfs/imfs_config.c (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fcntl.c (modified) * cpukit/libfs/src/imfs/imfs_fdatasync.c (modified) * cpukit/libfs/src/imfs/imfs_free.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_getchild.c (modified) * cpukit/libfs/src/imfs/imfs_gtkn.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_ntype.c (modified) * cpukit/libfs/src/imfs/imfs_readlink.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unixstub.c (modified) * cpukit/libfs/src/imfs/imfs_unlink.c (modified) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/imfs/linearfile.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) 2003-09-04 Joel Sherrill * ... Tue, 05 Aug 2003 14:05:56 GMT Jennifer Averett [2e7b6db] * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) 2003-08-04 Thomas Doerfler ... Mon, 14 Jul 2003 23:13:24 GMT Chris Johns [1679a7b] * cpukit/libfs/src/dosfs/msdos.h (modified) MSDOS Volume semaphore timeout is now NO TIMEOUT. MSDOS volume ... Wed, 02 Jul 2003 14:09:15 GMT Chris Johns [c125425] * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/src/dosfs/Makefile.am (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_conv.c (added) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) Patch from Victor V. Vengerov to remove Linux code. Tue, 25 Mar 2003 17:01:45 GMT Joel Sherrill [c151cfc3] * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/src/dosfs/Makefile.am (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) 2003-03-25 Thomas Doerfler ... Mon, 02 Dec 2002 19:14:27 GMT Joel Sherrill [a36e988] * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) 2002-12-02 Joel Sherrill * ... Thu, 28 Feb 2002 20:43:50 GMT Joel Sherrill [f36a7bfc] * c/src/exec/libfs/ChangeLog (modified) * c/src/exec/libfs/configure.ac (modified) * c/src/exec/libfs/src/Makefile.am (modified) * c/src/exec/libfs/src/dosfs/.cvsignore (added) * c/src/exec/libfs/src/dosfs/Makefile.am (added) * c/src/exec/libfs/src/dosfs/dosfs.h (added) * c/src/exec/libfs/src/dosfs/fat.c (added) * c/src/exec/libfs/src/dosfs/fat.h (added) * c/src/exec/libfs/src/dosfs/fat_fat_operations.c (added) * c/src/exec/libfs/src/dosfs/fat_fat_operations.h (added) * c/src/exec/libfs/src/dosfs/fat_file.c (added) * c/src/exec/libfs/src/dosfs/fat_file.h (added) * c/src/exec/libfs/src/dosfs/msdos.h (added) * c/src/exec/libfs/src/dosfs/msdos_create.c (added) * c/src/exec/libfs/src/dosfs/msdos_dir.c (added) * c/src/exec/libfs/src/dosfs/msdos_eval.c (added) * c/src/exec/libfs/src/dosfs/msdos_file.c (added) * c/src/exec/libfs/src/dosfs/msdos_free.c (added) * c/src/exec/libfs/src/dosfs/msdos_fsunmount.c (added) * c/src/exec/libfs/src/dosfs/msdos_handlers_dir.c (added) * c/src/exec/libfs/src/dosfs/msdos_handlers_file.c (added) * c/src/exec/libfs/src/dosfs/msdos_init.c (added) * c/src/exec/libfs/src/dosfs/msdos_initsupp.c (added) * c/src/exec/libfs/src/dosfs/msdos_misc.c (added) * c/src/exec/libfs/src/dosfs/msdos_mknod.c (added) * c/src/exec/libfs/src/dosfs/msdos_node_type.c (added) * c/src/exec/libfs/wrapup/Makefile.am (modified) * c/src/libfs/ChangeLog (modified) * c/src/libfs/configure.ac (modified) * c/src/libfs/src/Makefile.am (modified) * c/src/libfs/src/dosfs/.cvsignore (added) * c/src/libfs/src/dosfs/Makefile.am (added) * c/src/libfs/src/dosfs/config.h.in (added) * c/src/libfs/src/dosfs/dosfs.h (added) * c/src/libfs/src/dosfs/fat.c (added) * c/src/libfs/src/dosfs/fat.h (added) * c/src/libfs/src/dosfs/fat_fat_operations.c (added) * c/src/libfs/src/dosfs/fat_fat_operations.h (added) * c/src/libfs/src/dosfs/fat_file.c (added) * c/src/libfs/src/dosfs/fat_file.h (added) * c/src/libfs/src/dosfs/msdos.h (added) * c/src/libfs/src/dosfs/msdos_create.c (added) * c/src/libfs/src/dosfs/msdos_dir.c (added) * c/src/libfs/src/dosfs/msdos_eval.c (added) * c/src/libfs/src/dosfs/msdos_file.c (added) * c/src/libfs/src/dosfs/msdos_free.c (added) * c/src/libfs/src/dosfs/msdos_fsunmount.c (added) * c/src/libfs/src/dosfs/msdos_handlers_dir.c (added) * c/src/libfs/src/dosfs/msdos_handlers_file.c (added) * c/src/libfs/src/dosfs/msdos_init.c (added) * c/src/libfs/src/dosfs/msdos_initsupp.c (added) * c/src/libfs/src/dosfs/msdos_misc.c (added) * c/src/libfs/src/dosfs/msdos_mknod.c (added) * c/src/libfs/src/dosfs/msdos_node_type.c (added) * c/src/libfs/src/dosfs/stamp-h2.in (added) * c/src/libfs/wrapup/Makefile.am (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libfs/src/Makefile.am (modified) * cpukit/libfs/src/dosfs/.cvsignore (added) * cpukit/libfs/src/dosfs/Makefile.am (added) * cpukit/libfs/src/dosfs/dosfs.h (added) * cpukit/libfs/src/dosfs/fat.c (added) * cpukit/libfs/src/dosfs/fat.h (added) * cpukit/libfs/src/dosfs/fat_fat_operations.c (added) * cpukit/libfs/src/dosfs/fat_fat_operations.h (added) * cpukit/libfs/src/dosfs/fat_file.c (added) * cpukit/libfs/src/dosfs/fat_file.h (added) * cpukit/libfs/src/dosfs/msdos.h (added) * cpukit/libfs/src/dosfs/msdos_create.c (added) * cpukit/libfs/src/dosfs/msdos_dir.c (added) * cpukit/libfs/src/dosfs/msdos_eval.c (added) * cpukit/libfs/src/dosfs/msdos_file.c (added) * cpukit/libfs/src/dosfs/msdos_free.c (added) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (added) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (added) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (added) * cpukit/libfs/src/dosfs/msdos_init.c (added) * cpukit/libfs/src/dosfs/msdos_initsupp.c (added) * cpukit/libfs/src/dosfs/msdos_misc.c (added) * cpukit/libfs/src/dosfs/msdos_mknod.c (added) * cpukit/libfs/src/dosfs/msdos_node_type.c (added) * cpukit/libfs/wrapup/Makefile.am (modified) 2002-02-28 Victor V. Vengerov * DOS ...
