# # ChangeLog for cpukit/libdl/rtl-mdreloc-i386.c in rtems # # Generated by Trac 1.2.1.dev0 # 04/24/24 09:44:59 Sat, 02 Feb 2019 04:09:53 GMT Chris Johns [6c9f017] * bsps/powerpc/psim/start/linkcmds (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-bit-alloc.c (added) * cpukit/libdl/rtl-bit-alloc.h (added) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/dl01/dl-load.c (modified) * testsuites/libtests/dl02/dl-load.c (modified) * testsuites/libtests/dl02/dl-o1.c (modified) * testsuites/libtests/dl02/dl-o2.c (modified) * testsuites/libtests/dl03/dl-bit-alloc.c (added) * testsuites/libtests/dl03/dl-bit-alloc.h (added) * testsuites/libtests/dl03/init.c (modified) * testsuites/libtests/dl05/dl-load.c (modified) * testsuites/libtests/dl07/dl-load.c (modified) * testsuites/libtests/dl07/dl-o1.c (modified) * testsuites/libtests/dl07/dl-o2.c (modified) * testsuites/libtests/dl07/dl-o3.c (modified) * testsuites/libtests/dl07/dl-o4.c (modified) * testsuites/libtests/dl07/dl-o5.c (modified) * testsuites/libtests/dl07/init.c (modified) * testsuites/libtests/dl08/dl-o1.c (modified) * testsuites/libtests/dl08/dl-o2.c (modified) * testsuites/libtests/dl08/dl-o3.c (modified) * testsuites/libtests/dl08/dl-o4.c (modified) * testsuites/libtests/dl08/dl-o5.c (modified) * testsuites/libtests/dl08/dl-o6-123456789-123456789.c (modified) * testsuites/libtests/dl09/dl-load.c (modified) * testsuites/libtests/dl09/dl-o1.c (modified) * testsuites/libtests/dl09/dl-o2.c (modified) * testsuites/libtests/dl09/dl-o3.c (modified) * testsuites/libtests/dl09/dl-o4.c (modified) * testsuites/libtests/dl09/dl-o5.c (modified) libdl: Add powerpc large memory and small data support. - Add ... Mon, 21 Jan 2019 21:48:19 GMT Chris Johns [194eb403] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/dl08/dl-load.c (modified) * testsuites/libtests/dl09/dl-load.c (modified) * testsuites/libtests/dl09/dl-o5.c (modified) libdl: Add support for large memory programs - Add trampolines to ... Tue, 15 Jan 2019 06:47:41 GMT Chris Johns [d8c70ba6] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl01/dl-load.c (modified) * testsuites/libtests/dl08/dl-load.c (modified) * testsuites/libtests/dl09/dl-load.c (added) * testsuites/libtests/dl09/dl-load.h (added) * testsuites/libtests/dl09/dl-o1.c (added) * testsuites/libtests/dl09/dl-o1.h (added) * testsuites/libtests/dl09/dl-o2.c (added) * testsuites/libtests/dl09/dl-o2.h (added) * testsuites/libtests/dl09/dl-o3.c (added) * testsuites/libtests/dl09/dl-o3.h (added) * testsuites/libtests/dl09/dl-o4.c (added) * testsuites/libtests/dl09/dl-o4.h (added) * testsuites/libtests/dl09/dl-o5.c (added) * testsuites/libtests/dl09/dl-o5.h (added) * testsuites/libtests/dl09/dl09.doc (added) * testsuites/libtests/dl09/dl09.scn (added) * testsuites/libtests/dl09/init.c (added) libdl: Add support for trampolines - Trampolines or fixups for ... Thu, 12 Apr 2018 07:46:49 GMT Chris Johns [f59d435d] * cpukit/include/link_elf.h (modified) * cpukit/include/rtems/rtl/rap.h (modified) * cpukit/include/rtems/rtl/rtl-allocator.h (modified) * cpukit/include/rtems/rtl/rtl-fwd.h (modified) * cpukit/include/rtems/rtl/rtl-indirect-ptr.h (modified) * cpukit/include/rtems/rtl/rtl-obj-cache.h (modified) * cpukit/include/rtems/rtl/rtl-obj-comp.h (modified) * cpukit/include/rtems/rtl/rtl-obj-fwd.h (modified) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-sym.h (modified) * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/dlfcn-shell.c (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rap.c (modified) * cpukit/libdl/rtl-alloc-heap.c (modified) * cpukit/libdl/rtl-alloc-heap.h (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-error.h (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj-cache.c (modified) * cpukit/libdl/rtl-obj-comp.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-rap.c (modified) * cpukit/libdl/rtl-rap.h (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl-unwind-dw2.c (modified) * cpukit/libdl/rtl-unwind-dw2.h (modified) * cpukit/libdl/rtl-unwind.h (modified) * cpukit/libdl/rtl.c (modified) libdl: Remove _t from all structures as this is reserved for the ... Wed, 13 Dec 2017 07:20:30 GMT Sebastian Huber [990adc5] * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-find-file.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj-cache.c (modified) * cpukit/libdl/rtl-obj-comp.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-rap.c (modified) * cpukit/libdl/rtl-rap.h (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-string.c (modified) * cpukit/libdl/rtl-string.h (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-trace.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) libdl: Include Prepare for header file move to ... Wed, 07 Dec 2016 06:20:38 GMT Chris Johns [c6eead1] * c/src/lib/libbsp/sparc/erc32/make/custom/erc32-testsuite.tcfg (deleted) * cpukit/libdl/Makefile.am (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-allocator.h (modified) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-obj.h (modified) * cpukit/libdl/rtl-rap.c (modified) * cpukit/libdl/rtl-rap.h (modified) * cpukit/libdl/rtl-unwind-dw2.c (added) * cpukit/libdl/rtl-unwind-dw2.h (added) * cpukit/libdl/rtl-unwind.h (added) * cpukit/libdl/rtl.c (modified) * cpukit/libdl/rtl.h (modified) * testsuites/libtests/dl01/init.c (modified) * testsuites/libtests/dl02/init.c (modified) * testsuites/libtests/dl03/init.c (modified) * testsuites/libtests/dl04/init.c (modified) * testsuites/libtests/dl05/dl-cpp.cpp (modified) * testsuites/libtests/dl05/dl-load.c (modified) * testsuites/libtests/dl05/dl-load.h (modified) * testsuites/libtests/dl05/dl-o5.cpp (modified) * testsuites/libtests/dl05/dl05.scn (modified) * testsuites/libtests/dl05/init.c (modified) libdl: Add C++ exception support to loaded modules. This has been ... Mon, 27 Oct 2014 01:09:41 GMT Chris Johns [ae5fe7e6] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libdl/Makefile.am (added) * cpukit/libdl/dlfcn-shell.c (added) * cpukit/libdl/dlfcn-shell.h (added) * cpukit/libdl/dlfcn.c (added) * cpukit/libdl/dlfcn.h (added) * cpukit/libdl/fastlz.c (added) * cpukit/libdl/fastlz.h (added) * cpukit/libdl/include/arch/arm/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/bfin/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/h8300/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/i386/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/lm32/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/m32r/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/m68k/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/mips/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/moxie/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/nios2/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/powerpc/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/sparc/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/v850/machine/elf_machdep.h (added) * cpukit/libdl/include/link.h (added) * cpukit/libdl/include/link_elf.h (added) * cpukit/libdl/include/sys/cdefs_elf.h (added) * cpukit/libdl/include/sys/exec_elf.h (added) * cpukit/libdl/preinstall.am (added) * cpukit/libdl/rap-shell.c (added) * cpukit/libdl/rap-shell.h (added) * cpukit/libdl/rap.c (added) * cpukit/libdl/rap.h (added) * cpukit/libdl/rtl-alloc-heap.c (added) * cpukit/libdl/rtl-alloc-heap.h (added) * cpukit/libdl/rtl-allocator.c (added) * cpukit/libdl/rtl-allocator.h (added) * cpukit/libdl/rtl-chain-iterator.c (added) * cpukit/libdl/rtl-chain-iterator.h (added) * cpukit/libdl/rtl-debugger.c (added) * cpukit/libdl/rtl-elf.c (added) * cpukit/libdl/rtl-elf.h (added) * cpukit/libdl/rtl-error.c (added) * cpukit/libdl/rtl-error.h (added) * cpukit/libdl/rtl-find-file.c (added) * cpukit/libdl/rtl-find-file.h (added) * cpukit/libdl/rtl-fwd.h (added) * cpukit/libdl/rtl-indirect-ptr.h (added) * cpukit/libdl/rtl-mdreloc-arm.c (added) * cpukit/libdl/rtl-mdreloc-bfin.c (added) * cpukit/libdl/rtl-mdreloc-h8300.c (added) * cpukit/libdl/rtl-mdreloc-i386.c (added) * cpukit/libdl/rtl-mdreloc-lm32.c (added) * cpukit/libdl/rtl-mdreloc-m32r.c (added) * cpukit/libdl/rtl-mdreloc-m68k.c (added) * cpukit/libdl/rtl-mdreloc-mips.c (added) * cpukit/libdl/rtl-mdreloc-moxie.c (added) * cpukit/libdl/rtl-mdreloc-nios2.c (added) * cpukit/libdl/rtl-mdreloc-powerpc.c (added) * cpukit/libdl/rtl-mdreloc-sparc.c (added) * cpukit/libdl/rtl-mdreloc-v850.c (added) * cpukit/libdl/rtl-obj-cache.c (added) * cpukit/libdl/rtl-obj-cache.h (added) * cpukit/libdl/rtl-obj-comp.c (added) * cpukit/libdl/rtl-obj-comp.h (added) * cpukit/libdl/rtl-obj-fwd.h (added) * cpukit/libdl/rtl-obj.c (added) * cpukit/libdl/rtl-obj.h (added) * cpukit/libdl/rtl-rap.c (added) * cpukit/libdl/rtl-rap.h (added) * cpukit/libdl/rtl-shell.c (added) * cpukit/libdl/rtl-shell.h (added) * cpukit/libdl/rtl-string.c (added) * cpukit/libdl/rtl-string.h (added) * cpukit/libdl/rtl-sym.c (added) * cpukit/libdl/rtl-sym.h (added) * cpukit/libdl/rtl-trace.c (added) * cpukit/libdl/rtl-trace.h (added) * cpukit/libdl/rtl-unresolved.c (added) * cpukit/libdl/rtl-unresolved.h (added) * cpukit/libdl/rtl.c (added) * cpukit/libdl/rtl.h (added) * cpukit/preinstall.am (modified) * cpukit/wrapup/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl01/Makefile.am (added) * testsuites/libtests/dl01/dl-load.c (added) * testsuites/libtests/dl01/dl-load.h (added) * testsuites/libtests/dl01/dl-o1.c (added) * testsuites/libtests/dl01/dl01.doc (added) * testsuites/libtests/dl01/dl01.scn (added) * testsuites/libtests/dl01/init.c (added) cpukit: Add libdl with the Runtime Loader (RTL) code. This is a ...
