@443c61ec
11/25/15 08:01:57 |
Sebastian Huber |
Delete empty libc_init()
5
@ac5f2442
11/25/15 07:33:31 |
Sebastian Huber |
Require getreent()
This function is used by Newlib since 2013-07-09 …
5
@8f3ec7c0
11/17/15 14:22:18 |
Sebastian Huber |
Import latest <sys/ttycom.h> from FreeBSD
Required by new network stack.
5
@f757bb7c
11/17/15 14:12:34 |
Sebastian Huber |
Merge with latest <sys/sockio.h> from FreeBSD
Required by new network …
5
@836803f
11/17/15 13:57:47 |
Sebastian Huber |
Import latest <sys/filio.h> from FreeBSD
5
@f97536d
10/16/15 06:21:48 |
Sebastian Huber |
basdefs.h: Add and use RTEMS_UNUSED
5
@143696a
10/16/15 06:15:03 |
Sebastian Huber |
basedefs.h: Add and use RTEMS_NO_RETURN
5
@2d48456
08/21/15 03:24:17 |
Sebastian Huber |
rbheap: Drop direction from _RBTree_Iterate()
5
@d7665823
06/24/15 13:43:19 |
Sebastian Huber |
score: Introduce Thread_queue_Heads
Move the storage for the thread …
5
@c5d0ca9
07/13/15 08:19:04 |
Sebastian Huber |
libcsupport: Workaround for GCC 5.1 and later
Disable an optimization …
4.115
@48fed9a
06/25/15 12:11:53 |
Sebastian Huber |
score: Simplify <rtems/system.h>
Drop the <rtems/score/percpu.h> …
4.115
@e6b31b27
05/27/15 15:13:58 |
Joel Sherrill |
Remove use ticks for statistics configure option.
This was obsolete …
4.115
@221031e
05/20/15 22:02:19 |
Joel Sherrill |
kill_noposix.c: Remove obsolete kill()
4.115
@776a50c
05/04/15 07:32:00 |
Sebastian Huber |
Filesystem: Thread life protection for env changes
4.115
@4a3c920
05/04/15 07:30:21 |
Sebastian Huber |
libcsupport: Fix umask() locking
Delete comment related to an …
4.115
@2b0bbc4
05/04/15 07:29:38 |
Sebastian Huber |
libcsupport: Avoid Giant lock in rtems_verror()
4.115
@c07c85f
05/04/15 07:24:10 |
Sebastian Huber |
Filesystem: Use lock for deferred release
4.115
@5f7f469
05/04/15 07:22:26 |
Sebastian Huber |
libcsupport: Avoid Giant lock in _times()
4.115
@1a6683a
03/26/15 20:37:33 |
Sebastian Huber |
libcsupport: Include missing header file
4.115
@1f67156
03/09/15 12:18:36 |
Sebastian Huber |
libcsupport: Delete superfluous _gettimeofday()
4.115
@1aa7b8b
03/09/15 21:07:36 |
Joel Sherrill |
Move contents of libcsupport/include/zilog into libbsp/shared
Only a …
4.115
@6796d9c
03/09/15 20:50:27 |
Joel Sherrill |
Remove unused cpukit/libcsupport/include/zilog/z8536.h
4.115
@5bc6237
03/09/15 20:47:47 |
Joel Sherrill |
Move libcsupport/include/motorola/*.h to m68k/idp BSP
These header …
4.115
@2468aa3d
03/08/15 19:34:31 |
Joel Sherrill |
vprintk.c: Reorder switch and add default to eliminate warning
4.115
@a7e4de2
03/06/15 20:33:08 |
Joel Sherrill |
Fix even more Doxygen issues
4.115
@5b5d2fd4
03/05/15 08:37:36 |
Sebastian Huber |
Filesystem: Delete unused null_op_fsmount_me()
4.115
@76f37656
02/25/15 19:52:10 |
Gedare Bloom |
libcsupport: scale times() call to microseconds
4.115
@5eb27ce
02/20/15 04:00:47 |
Nick Withers |
Don't fail to create passwd and group files if /etc already exists
4.115
@353506b9
02/02/15 13:55:23 |
Sebastian Huber |
sys/event.h: Update to FreeBSD 9.3
4.115
@eb77534
02/09/15 14:37:00 |
Sebastian Huber |
Filesystem: Delete unused fsmountme_h handler
4.115
@4c14ace6
01/31/15 20:23:26 |
Sebastian Huber |
Add rtems_filesystem_make_dev_t_from_pointer()
4.115
@efd2965a
02/02/15 14:25:26 |
Sebastian Huber |
Filesystem: Statically initialize rtems_libio_iops
4.115
@ec0f2df
02/02/15 14:25:25 |
Sebastian Huber |
Filesystem: Use rtems_libio_iop_to_descriptor()
Drop parameter check …
4.115
@97db9e30
02/02/15 14:25:24 |
Sebastian Huber |
Filesystem: Delete rtems_libio_last_iop
4.115
@ead010c
02/02/15 14:25:23 |
Sebastian Huber |
Filesystem: Make rtems_libio_number_iops const
4.115
@c625a641
12/21/14 19:12:28 |
Sebastian Huber |
Filesystem: Delete node type operation
Use the fstat handler instead.
4.115
@25e5f61
12/12/14 10:03:42 |
Sebastian Huber |
libcsupport: Do not use _Assert() for sync()
Use a best-effort approach.
4.115
@7bdb765
12/12/14 07:46:30 |
Sebastian Huber |
Add POSIX key value pairs to resource snapshot
4.115
@2c3c657
11/27/14 12:25:22 |
Sebastian Huber |
score: Return heap stats via _Heap_Get_information
Print out heap …
4.115
@01557b0
11/27/14 10:44:48 |
Sebastian Huber |
libcsupport: Delete malloc statistics
Use the heap handler statistics …
4.115
@e22af78
11/27/14 15:30:12 |
Joel Sherrill |
sync.c: Add asserts to document and check assumptions
4.115
@038faca1
11/25/14 15:47:20 |
Sebastian Huber |
rtems: Add rtems_cache_coherent_allocate()
Add …
4.115
@72f63eef
11/19/14 20:34:40 |
josh.oguin |
libcsupport/src/newlibc_exit.c: Remove dead code
This was flagged as …
4.115
@f18fd4f
11/19/14 20:34:06 |
josh.oguin |
libcsupport/src/mount.c: Remove unnecessary operation
This was …
4.115
@3211e8e
11/24/14 20:18:16 |
Joel Sherrill |
cpukit/libcsupport/src/pwdgrp.c: Check return value
Coverity Id …
4.115
@7e5c9b89
11/25/14 13:58:13 |
Sebastian Huber |
rtems: Move rtems_cache_aligned_malloc()
Make sure also the size is …
4.115
@02733495
11/24/14 14:20:25 |
Sebastian Huber |
libcsupport: malloc_is_system_state_OK()
Move system state check to …
4.115
@5dff7425
11/20/14 23:17:18 |
Joel Sherrill |
libcsupport/src/termios.c: Explicitly ignore return value (Coverity ID …
4.115
@e02d5dd9
11/17/14 12:35:58 |
Sebastian Huber |
Ensure security of default user environment
4.115
@b8bd90f6
11/17/14 08:01:53 |
Sebastian Huber |
Add supplementary groups to user environment
4.115
@c3350e7d
11/18/14 06:39:47 |
Sebastian Huber |
Filesystem: Typo
4.115
@ffa71f1
11/17/14 06:53:01 |
Sebastian Huber |
libcsupport: Implement getgroups()
4.115
@395e5d4
11/14/14 14:33:57 |
Sebastian Huber |
libcsupport: Use POSIX key for getgrent()
4.115
@002f351
11/14/14 13:30:36 |
Sebastian Huber |
libcsupport: Minimal /etc/passwd and /etc/group
Create a minimal …
4.115
@6935428
11/14/14 10:30:50 |
Sebastian Huber |
libcsupport: Avoid TOCTOU and format errors
4.115
@80055514
11/14/14 10:09:39 |
Sebastian Huber |
libcsupport: Use pthread_once()
4.115
@b471854b
11/14/14 10:01:48 |
Sebastian Huber |
libcsupport: Split passwd/group support
4.115
@d82f9de1
11/14/14 09:28:15 |
Sebastian Huber |
libcsupport: Add copyrights according to rev hist
4.115
@ea9232d
10/24/14 23:05:59 |
Chris Johns |
ilibcsupport: Add realpath call.
4.115
@65f71f84
10/12/14 20:34:54 |
Joel Sherrill |
libcsupport/include/clockdrv.h: Remove rtems_clock_major/minor
4.115
@22cd282
10/08/14 09:24:36 |
Sebastian Huber |
IMFS: Avoid NULL pointer access
Avoid NULL pointer access in …
4.115
@7fd5e89
10/07/14 14:28:04 |
Sebastian Huber |
termios: Partially hide rtems_termios_tty
Move interrupt lock to …
4.115
@a830cb8
10/07/14 14:27:51 |
Sebastian Huber |
termios: Separate flow control from normal handler
4.115
@ff7217b
10/07/14 12:51:39 |
Sebastian Huber |
termios: Fix transmit daemon
Do not call …
4.115
@f535fe53
09/04/14 20:41:21 |
Joel Sherrill |
tod.h -> libcsupport like other driver and helper prototype files
4.115
@8fbe2e6
09/04/14 13:59:49 |
Joel Sherrill |
Use correct prototype of benchmark_timer_read()
This change starts …
4.115
@8dab980
09/05/14 07:12:59 |
Sebastian Huber |
libcsupport: Use RTEMS_DECONST()
4.115
@3654667f
08/14/14 15:02:29 |
Kolja Waschk |
rtems_termios_puts: Copy and write more than one char at once
Renamed …
4.115
@93726e5
07/09/14 13:44:13 |
Sebastian Huber |
termios: Add rtems_termios_set_best_baud()
4.115
@8074342c
07/03/14 10:55:42 |
Christian.Mauderer |
termios: Add rtems_termios_get_termios()
4.115
@a0fb29f
07/09/14 09:52:56 |
Sebastian Huber |
termios: PR1279: Use first open status
4.115
@32fc6a3
07/09/14 09:15:53 |
Sebastian Huber |
termios: PR1279: Use set attributes status
4.115
@ef8c00bc
06/27/14 11:10:15 |
Sebastian Huber |
termios: PR2153: New low-level device API
Add a new low-level device …
4.115
@f6b1e063
06/27/14 11:08:28 |
Sebastian Huber |
termios: Make tty list static
4.115
@69aa3349
04/08/14 07:42:29 |
Sebastian Huber |
score: Simplify thread control initialization
The thread control …
4.115
@eb2c813
04/04/14 14:24:17 |
Joel Sherrill |
privateenv.c: Remove unused variable warning
4.115
@25a97835
04/01/14 06:31:16 |
Sebastian Huber |
ringbuf: Fix ISR lock initialization/destruction
4.115
@23fec9f0
03/27/14 13:16:12 |
Sebastian Huber |
score: PR2152: Use allocator mutex for objects
Use allocator mutex …
4.115
@1b1be254
03/25/14 09:54:49 |
Sebastian Huber |
score: Thread life cycle re-implementation
The thread deletion is now …
4.115
@5c0c0cf
03/27/14 13:23:21 |
privateenv: Use POSIX keys instead of task variables.
4.115
@7d5c27e
03/27/14 13:23:20 |
privateenv: Remove sharing of user environment between threads.
4.115
@5ef9f23
03/21/14 13:29:55 |
libcsupport: Use POSIX keys for GXX key functions
With this patch C++ …
4.115
@9d9df8b
03/21/14 11:07:28 |
libcsupport: Remove unused gxx-wrapper function.
The …
4.115
@a5385b1
03/20/14 08:22:00 |
score: Unify pthread and gxx_wrapper once and move to score.
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@53ad908
03/07/14 13:36:22 |
Sebastian Huber |
score: Add SMP lock profiling support
4.115
@28779c7
03/07/14 11:53:41 |
Sebastian Huber |
score: Add function to destroy SMP locks
4.115
@d50acdbb
03/10/14 07:25:32 |
Sebastian Huber |
score: Add local context to SMP lock API
Add a local context …
4.115
@b1196e3
03/10/14 07:13:06 |
Sebastian Huber |
printk: Add support for long long
4.115
@83bf105
02/19/14 09:57:46 |
Sebastian Huber |
score: Rename _Internal_error_Occurred()
Rename …
4.115
@bab16de2
02/07/14 08:53:47 |
Sebastian Huber |
score: Change debug helper functions
Rename …
4.115
@cfbeaf6
01/31/14 18:28:02 |
Joel Sherrill |
calloc.c: Remove use of register keyword
4.115
@35b8f48a
12/06/13 18:21:20 |
Daniel Ramirez |
libcsupport: Refactor rtems_deviceio_errno
Renames …
4.115
@564ce0f
12/06/13 02:21:05 |
Daniel Ramirez |
libcsupport: implemented termios functions cfsetspeed and cfmakeraw
4.115
@c1d8ee4
12/17/13 09:59:13 |
Sebastian Huber |
libcsupport: Accept NULL for zero-length entries
4.115
@56bea43
12/16/13 13:26:29 |
Sebastian Huber |
Filesystem: Use default kqfilter and poll handler
4.115
@2f68778
12/16/13 12:44:13 |
Sebastian Huber |
Filesystem: Add readv/writev handlers
The readv() and writev() …
4.115
@95a57280
12/16/13 12:12:22 |
Sebastian Huber |
libcsupport: Add and use rtems_libio_iovec_eval()
4.115
@6122cb6a
12/10/13 01:35:29 |
Chris Johns |
PR2158: Add support for dup2.
Split the dub call into dup and dup2 in …
4.115
@77b1de22
11/22/13 23:09:44 |
Bryan Dunsmore |
gettimeofday: Add restrict keyword
4.115
