@4b0d1ab
11/17/00 18:42:02 |
Jennifer.Averett |
2000-11-17 Jennifer Averret <jennifer@…>
* libc/mount.c …
4.104.114.84.95
@5dc2b66d
11/10/00 14:23:46 |
Joel Sherrill |
2000-11-10 Ralf Corsepius <corsepiu@…>
* libc/libio.c: …
4.104.114.84.95
@feead226
11/09/00 16:43:05 |
Joel Sherrill |
2000-11-09 Ralf Corsepius <corsepiu@…>
* Makefile.am: …
4.104.114.84.95
@a314d3b4
11/02/00 15:49:06 |
Joel Sherrill |
2000-11-02 Ralf Corsepius <corsepiu@…>
* Makefile.am: …
4.104.114.84.95
@3ba74c73
11/01/00 21:08:14 |
Joel Sherrill |
2000-11-01 Joel Sherrill <joel@…>
* include/Makefile.am, …
4.104.114.84.95
@2d5748f
10/26/00 12:59:48 |
Joel Sherrill |
2000-10-26 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@7b0001f7
10/25/00 16:56:11 |
Joel Sherrill |
2000-10-24 Joel Sherrill <joel@…>
* libc/ioman.c: Moved to …
4.104.114.84.95
@3815a2b
10/18/00 15:02:06 |
Joel Sherrill |
2000-10-18 Joel Sherrill <joel@…>
* libc/Makefile.am: …
4.104.114.84.95
@e6babd7
10/18/00 13:08:22 |
Joel Sherrill |
* libc/fcntl.c: Do not …
4.104.114.84.95
@9c3fa30
09/28/00 20:19:23 |
Joel Sherrill |
2000-09-28 Joel Sherrill <joel@…>
* libc/libio.h …
4.104.114.84.95
@fb327db3
09/22/00 20:35:12 |
Joel Sherrill |
2000-09-22 Joel Sherrill <joel@…>
* libc/newlibc.c: …
4.104.114.84.95
@5a9a5ec
09/05/00 15:46:02 |
Joel Sherrill |
2000-09-05 Joel Sherrill <joel@…>
* libio.c: Added …
4.104.114.84.95
@188c82b
08/30/00 17:12:55 |
Joel Sherrill |
2000-08-30 Joel Sherrill <joel@…>
* Many files: Moved …
4.104.114.84.95
@50d6077
08/30/00 08:22:01 |
Joel Sherrill |
2000-08-30 Ralf Corsepius <corsepiu@…>
* configure.in: …
4.104.114.84.95
@1a3b281
08/25/00 17:12:14 |
Joel Sherrill |
2000-08-25 Joel Sherrill <joel.sherrill@…>
4.104.114.84.95
@662678d1
08/25/00 13:13:57 |
Joel Sherrill |
4.104.114.84.95
@dd19c0b
08/11/00 20:04:27 |
Joel Sherrill |
2000-08-11 Chris Johns <ccj@…>
* libc/chmod.c: Return ENOTSUP …
4.104.114.84.95
@5b8d82a2
08/03/00 14:43:33 |
Joel Sherrill |
IEEE
-4 = {d = -4, i = {0xc0100000, 0x0}} s=1 e=0x80 m=0x100000 …
4.104.114.84.95
@e6890ba
08/01/00 15:23:59 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to avoid lockup under
the …
4.104.114.84.95
@ca7858bb
07/26/00 19:28:11 |
Joel Sherrill |
Port of RTEMS to the Texas Instruments C3x/C4x DSP families including …
4.104.114.84.95
@195ae7ba
06/30/00 12:31:28 |
Joel Sherrill |
Patch from Chris Johns <cjohns@…> to add fchdir() …
4.104.114.84.95
@9b6d173
06/29/00 16:05:15 |
Joel Sherrill |
Patch from Chris Johns <cjohns@…> to make sure the …
4.104.114.84.95
@a3726b1
06/15/00 19:40:34 |
Joel Sherrill |
Fixing warning obtained by some users.
4.104.114.84.95
@730daa6
06/14/00 21:13:20 |
Joel Sherrill |
Moved <sys/cdefs.h> from libnetworking to lib/include so …
4.104.114.84.95
@9b05600
06/14/00 20:22:31 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@cf1f72e
06/13/00 21:53:38 |
Joel Sherrill |
Moved i386 and m68k cache management code to libcpu. Everything
now …
4.104.114.84.95
@80ad143b
06/13/00 21:42:55 |
Joel Sherrill |
Temporary hack to compile. Need to probably address definition
of all …
4.104.114.84.95
@2adcb4dd
06/13/00 21:41:45 |
Joel Sherrill |
4.104.114.84.95
@8ef3818
06/12/00 19:57:02 |
Joel Sherrill |
Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier …
4.104.114.84.95
@1bce637
06/12/00 16:37:04 |
Joel Sherrill |
Added printk as a generic, shared routine.
4.104.114.84.95
@df49c60
06/12/00 15:00:15 |
Joel Sherrill |
Merged from 4.5.0-beta3a
4.104.114.84.95
@b27c15f
05/08/00 21:17:50 |
Joel Sherrill |
New file added on 4.5 branch
4.104.114.84.95
@e4c07444
04/13/00 14:47:15 |
Joel Sherrill |
Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@bf85b19
04/13/00 14:37:14 |
Joel Sherrill |
4.104.114.84.95
@c629812
12/13/99 22:10:45 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@da8ae79b
12/13/99 21:21:31 |
Joel Sherrill |
Warning removal patch from Philip A. Prindeville <philipp@…>.
4.104.114.84.95
@d9230ea
12/13/99 14:49:38 |
Joel Sherrill |
Added RTEMS_IO_ERROR.
4.104.114.84.95
@1563d8c
11/30/99 16:52:21 |
Joel Sherrill |
Removed duplicate definition of rtems_filesystem_umask.
4.104.114.84.95
@e4b25c4
11/30/99 13:46:28 |
Joel Sherrill |
Corrected so they would compile with POSIX disabled.
4.104.114.84.95
@3dfe0b27
11/29/99 15:10:30 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@9181246
11/16/99 22:45:51 |
Jennifer.Averett |
Fixed bug.
4.104.114.84.95
@ce18601a
11/16/99 16:13:26 |
Joel Sherrill |
Removed start subdirectory and distributed contents to the appropriate …
4.104.114.84.95
@31473b7
11/16/99 16:03:21 |
Joel Sherrill |
Works now.
Removed times() since the version in the C Library support …
4.104.114.84.95
@817031f
11/16/99 15:28:03 |
Joel Sherrill |
New file.
4.104.114.84.95
@c7016198
11/16/99 15:27:52 |
Joel Sherrill |
Added.
4.104.114.84.95
@b88691c
11/16/99 15:26:29 |
Joel Sherrill |
Source and destination arguments to strncpy were swapped. This …
4.104.114.84.95
@7edb9281
11/05/99 19:02:03 |
Joel Sherrill |
Following comments from Eric Norum <eric@…>, a fairly …
4.104.114.84.95
@458bd34
11/05/99 16:44:02 |
Joel Sherrill |
This is another pass at making sure that nothing outside the BSP …
4.104.114.84.95
@5f2566b
11/02/99 16:27:53 |
Joel Sherrill |
Fixed F_SETFL to properly convert between internal
libio flags and …
4.104.114.84.95
@063e4950
11/02/99 16:27:05 |
Joel Sherrill |
Added support for configuring base filesystem. First attempt at
a …
4.104.114.84.95
@19b74f31
11/02/99 16:25:05 |
Joel Sherrill |
Check for NULL being passed in.
4.104.114.84.95
@4a07d2b
10/29/99 15:19:13 |
Jennifer.Averett |
Moved the rmnod callback from the operations table to the handler table.
4.104.114.84.95
@4bde8072
10/29/99 14:28:39 |
Jennifer.Averett |
Joel added a table of mount entry requests to be processed during …
4.104.114.84.95
@2fe47ff
10/26/99 21:51:07 |
Joel Sherrill |
Added include of libio.h so this would compile when posix is disabled.
4.104.114.84.95
@657e1bf6
10/26/99 20:17:13 |
Joel Sherrill |
Added initial cut at miniIMFS which leaves out memfile and directory …
4.104.114.84.95
@2782e69
10/26/99 12:39:24 |
Joel Sherrill |
idir=/opt/tmp/opt/rtems
rdir=/opt/rtems
cd $idir
find . -type f | …
4.104.114.84.95
@dd04e32
10/26/99 02:58:06 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to move …
4.104.114.84.95
@04df848
10/25/99 14:23:03 |
Jennifer.Averett |
Added code to correctly free any allocated space during the evaluation …
4.104.114.84.95
@51435fc7
10/12/99 19:26:37 |
Joel Sherrill |
Split null handlers table to own file and renamed.
Renamed IMFS …
4.104.114.84.95
@dd0f326
10/12/99 19:10:46 |
Joel Sherrill |
Added rtems_filesystem_freenode() macro and added calls at appropriate …
4.104.114.84.95
@e2116f9
10/12/99 19:09:27 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@578a415
10/12/99 19:08:55 |
Joel Sherrill |
Corrected mistakes in the IMFS file handlers table and added the …
4.104.114.84.95
@d71fcab
10/12/99 18:44:40 |
Joel Sherrill |
Added call to freenod to let each filesystem free its own internal …
4.104.114.84.95
@cb5056b3
10/12/99 18:44:05 |
Joel Sherrill |
Changed bcopy to strncpy to stick to ANSI/ISO routines.
4.104.114.84.95
@45269dc
10/11/99 15:34:26 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to move librdbg
to …
4.104.114.84.95
@ddaa60f
10/06/99 21:08:14 |
Joel Sherrill |
New file.
4.104.114.84.95
@8dd1276
10/05/99 19:21:34 |
Joel Sherrill |
Removed go32 ifdefs
4.104.114.84.95
@0139484
10/05/99 16:34:20 |
Joel Sherrill |
Patch from Wayne Bullaughey <wayne@…>. Comments follow:
I'm …
4.104.114.84.95
@811804fe
10/04/99 19:15:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make fix bug …
4.104.114.84.95
@0efa9f0
10/04/99 18:53:31 |
Joel Sherrill |
4.104.114.84.95
@cc63e08
10/04/99 18:40:53 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make …
4.104.114.84.95
@b62a92c
10/04/99 18:20:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
The patch below …
4.104.114.84.95
@3cad2919
10/01/99 15:55:30 |
Joel Sherrill |
Addition of more functionality by Eric Norum to support GNU readline.
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@6fc973e
08/18/99 16:49:52 |
Joel Sherrill |
Here is …
4.104.114.84.95
@a0a225f
07/02/99 18:50:40 |
Joel Sherrill |
Added code to initialize the /etc/group and /etc/passwd files.
4.104.114.84.95
@c51917f3
07/02/99 18:09:03 |
Joel Sherrill |
Fixed format strings and warnings.
4.104.114.84.95
@c3d20eb
07/02/99 18:03:43 |
Joel Sherrill |
Reentrant versions added by Joel. Signficant formatting cleanup.
4.104.114.84.95
@258fd79
07/02/99 17:13:27 |
Joel Sherrill |
Password and group routines added by Ralf Corsepius …
4.104.114.84.95
@937ab62c
06/15/99 22:16:30 |
Joel Sherrill |
After comments D. V. Henkel-Wallace <gumby@…>, the interface …
4.104.114.84.95
@4ecc390
06/14/99 20:18:56 |
Joel Sherrill |
RTEMS_FILESYSTEM_READ_WRITE_ONLY changed to …
4.104.114.84.95
@d741406c
06/14/99 20:18:13 |
Joel Sherrill |
Wrong prototype corrected.
4.104.114.84.95
@0ac8e382
06/14/99 19:44:07 |
Joel Sherrill |
Warning removal from D. V. Henkel-Wallace <gumby@…>.
4.104.114.84.95
@d001776f
06/11/99 14:49:13 |
Joel Sherrill |
Added local prototype of ioctl() to avoid requiring sys/ioctl.h.
4.104.114.84.95
@8dba373
06/09/99 13:50:47 |
Joel Sherrill |
Switched to using strcasecmp() since it is more portable.
D. V. …
4.104.114.84.95
@1c841bd2
05/27/99 16:13:19 |
Joel Sherrill |
Split out the routine rtems_assoc_name_bad().
4.104.114.84.95
@556ea0e3
05/27/99 16:12:20 |
Joel Sherrill |
Removed usage of printf.
4.104.114.84.95
@5adf355a
05/27/99 16:11:52 |
Joel Sherrill |
Split initialization and reserve resources from termios to reduce
size …
4.104.114.84.95
@4c5080ed
05/11/99 16:30:51 |
Joel Sherrill |
Fix based on bug report from Jay Kulpinski <jskulpin@…> …
4.104.114.84.95
@933388ae
04/22/99 21:13:23 |
Joel Sherrill |
Added lstat().
4.104.114.84.95
@d006519b
04/15/99 19:01:32 |
Joel Sherrill |
Added reentrant versions.
4.104.114.84.95
@a68e6b9
04/15/99 18:58:43 |
Joel Sherrill |
Updated version string.
4.104.114.84.95
@5eb7da97
04/01/99 16:20:03 |
Joel Sherrill |
Disable IXON by default based on comment from Eric Norum …
4.104.114.84.95
@18040d3
03/31/99 23:35:22 |
Joel Sherrill |
Patch from Thomas Doerfler <td@…> to add flow control:
4.104.114.84.95
@ec2328ee
03/31/99 23:24:57 |
Jennifer.Averett |
Removed asserts that shouldn't be called and commented case where this …
4.104.114.84.95
@f719ef1
03/31/99 23:23:52 |
Jennifer.Averett |
Corrected return value.
4.104.114.84.95
@707d4d0
03/30/99 17:42:25 |
Joel Sherrill |
Removed warning for const removal.
4.104.114.84.95
@77c81fd2
03/29/99 18:24:34 |
Jennifer.Averett |
Removed an uninitialized variable.
4.104.114.84.95
@a432c4b7
03/24/99 22:52:47 |
Joel Sherrill |
Fix based on bug report from Ralf Corsepius <corsepiu@…>: …
4.104.114.84.95
