@8ef3818
06/12/00 19:57:02 |
Joel Sherrill |
Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier …
4.104.114.84.95
@1bce637
06/12/00 16:37:04 |
Joel Sherrill |
Added printk as a generic, shared routine.
4.104.114.84.95
@df49c60
06/12/00 15:00:15 |
Joel Sherrill |
Merged from 4.5.0-beta3a
4.104.114.84.95
@b27c15f
05/08/00 21:17:50 |
Joel Sherrill |
New file added on 4.5 branch
4.104.114.84.95
@c629812
12/13/99 22:10:45 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@da8ae79b
12/13/99 21:21:31 |
Joel Sherrill |
Warning removal patch from Philip A. Prindeville <philipp@…>.
4.104.114.84.95
@d9230ea
12/13/99 14:49:38 |
Joel Sherrill |
Added RTEMS_IO_ERROR.
4.104.114.84.95
@1563d8c
11/30/99 16:52:21 |
Joel Sherrill |
Removed duplicate definition of rtems_filesystem_umask.
4.104.114.84.95
@e4b25c4
11/30/99 13:46:28 |
Joel Sherrill |
Corrected so they would compile with POSIX disabled.
4.104.114.84.95
@3dfe0b27
11/29/99 15:10:30 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@9181246
11/16/99 22:45:51 |
Jennifer.Averett |
Fixed bug.
4.104.114.84.95
@31473b7
11/16/99 16:03:21 |
Joel Sherrill |
Works now.
Removed times() since the version in the C Library support …
4.104.114.84.95
@817031f
11/16/99 15:28:03 |
Joel Sherrill |
New file.
4.104.114.84.95
@c7016198
11/16/99 15:27:52 |
Joel Sherrill |
Added.
4.104.114.84.95
@b88691c
11/16/99 15:26:29 |
Joel Sherrill |
Source and destination arguments to strncpy were swapped. This …
4.104.114.84.95
@7edb9281
11/05/99 19:02:03 |
Joel Sherrill |
Following comments from Eric Norum <eric@…>, a fairly …
4.104.114.84.95
@458bd34
11/05/99 16:44:02 |
Joel Sherrill |
This is another pass at making sure that nothing outside the BSP …
4.104.114.84.95
@5f2566b
11/02/99 16:27:53 |
Joel Sherrill |
Fixed F_SETFL to properly convert between internal
libio flags and …
4.104.114.84.95
@063e4950
11/02/99 16:27:05 |
Joel Sherrill |
Added support for configuring base filesystem. First attempt at
a …
4.104.114.84.95
@19b74f31
11/02/99 16:25:05 |
Joel Sherrill |
Check for NULL being passed in.
4.104.114.84.95
@4a07d2b
10/29/99 15:19:13 |
Jennifer.Averett |
Moved the rmnod callback from the operations table to the handler table.
4.104.114.84.95
@657e1bf6
10/26/99 20:17:13 |
Joel Sherrill |
Added initial cut at miniIMFS which leaves out memfile and directory …
4.104.114.84.95
@04df848
10/25/99 14:23:03 |
Jennifer.Averett |
Added code to correctly free any allocated space during the evaluation …
4.104.114.84.95
@51435fc7
10/12/99 19:26:37 |
Joel Sherrill |
Split null handlers table to own file and renamed.
Renamed IMFS …
4.104.114.84.95
@dd0f326
10/12/99 19:10:46 |
Joel Sherrill |
Added rtems_filesystem_freenode() macro and added calls at appropriate …
4.104.114.84.95
@578a415
10/12/99 19:08:55 |
Joel Sherrill |
Corrected mistakes in the IMFS file handlers table and added the …
4.104.114.84.95
@d71fcab
10/12/99 18:44:40 |
Joel Sherrill |
Added call to freenod to let each filesystem free its own internal …
4.104.114.84.95
@cb5056b3
10/12/99 18:44:05 |
Joel Sherrill |
Changed bcopy to strncpy to stick to ANSI/ISO routines.
4.104.114.84.95
@ddaa60f
10/06/99 21:08:14 |
Joel Sherrill |
New file.
4.104.114.84.95
@8dd1276
10/05/99 19:21:34 |
Joel Sherrill |
Removed go32 ifdefs
4.104.114.84.95
@0139484
10/05/99 16:34:20 |
Joel Sherrill |
Patch from Wayne Bullaughey <wayne@…>. Comments follow:
I'm …
4.104.114.84.95
@3cad2919
10/01/99 15:55:30 |
Joel Sherrill |
Addition of more functionality by Eric Norum to support GNU readline.
4.104.114.84.95
@6fc973e
08/18/99 16:49:52 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
Here is …
4.104.114.84.95
@a0a225f
07/02/99 18:50:40 |
Joel Sherrill |
Added code to initialize the /etc/group and /etc/passwd files.
4.104.114.84.95
@c51917f3
07/02/99 18:09:03 |
Joel Sherrill |
Fixed format strings and warnings.
4.104.114.84.95
@c3d20eb
07/02/99 18:03:43 |
Joel Sherrill |
Reentrant versions added by Joel. Signficant formatting cleanup.
4.104.114.84.95
@258fd79
07/02/99 17:13:27 |
Joel Sherrill |
Password and group routines added by Ralf Corsepius …
4.104.114.84.95
@937ab62c
06/15/99 22:16:30 |
Joel Sherrill |
After comments D. V. Henkel-Wallace <gumby@…>, the interface …
4.104.114.84.95
@4ecc390
06/14/99 20:18:56 |
Joel Sherrill |
RTEMS_FILESYSTEM_READ_WRITE_ONLY changed to …
4.104.114.84.95
@d741406c
06/14/99 20:18:13 |
Joel Sherrill |
Wrong prototype corrected.
4.104.114.84.95
@0ac8e382
06/14/99 19:44:07 |
Joel Sherrill |
Warning removal from D. V. Henkel-Wallace <gumby@…>.
4.104.114.84.95
@d001776f
06/11/99 14:49:13 |
Joel Sherrill |
Added local prototype of ioctl() to avoid requiring sys/ioctl.h.
4.104.114.84.95
@8dba373
06/09/99 13:50:47 |
Joel Sherrill |
Switched to using strcasecmp() since it is more portable.
D. V. …
4.104.114.84.95
@1c841bd2
05/27/99 16:13:19 |
Joel Sherrill |
Split out the routine rtems_assoc_name_bad().
4.104.114.84.95
@556ea0e3
05/27/99 16:12:20 |
Joel Sherrill |
Removed usage of printf.
4.104.114.84.95
@5adf355a
05/27/99 16:11:52 |
Joel Sherrill |
Split initialization and reserve resources from termios to reduce
size …
4.104.114.84.95
@4c5080ed
05/11/99 16:30:51 |
Joel Sherrill |
Fix based on bug report from Jay Kulpinski <jskulpin@…> …
4.104.114.84.95
@933388ae
04/22/99 21:13:23 |
Joel Sherrill |
Added lstat().
4.104.114.84.95
@d006519b
04/15/99 19:01:32 |
Joel Sherrill |
Added reentrant versions.
4.104.114.84.95
@a68e6b9
04/15/99 18:58:43 |
Joel Sherrill |
Updated version string.
4.104.114.84.95
@5eb7da97
04/01/99 16:20:03 |
Joel Sherrill |
Disable IXON by default based on comment from Eric Norum …
4.104.114.84.95
@18040d3
03/31/99 23:35:22 |
Joel Sherrill |
Patch from Thomas Doerfler <td@…> to add flow control:
4.104.114.84.95
@ec2328ee
03/31/99 23:24:57 |
Jennifer.Averett |
Removed asserts that shouldn't be called and commented case where this …
4.104.114.84.95
@f719ef1
03/31/99 23:23:52 |
Jennifer.Averett |
Corrected return value.
4.104.114.84.95
@707d4d0
03/30/99 17:42:25 |
Joel Sherrill |
Removed warning for const removal.
4.104.114.84.95
@77c81fd2
03/29/99 18:24:34 |
Jennifer.Averett |
Removed an uninitialized variable.
4.104.114.84.95
@4fb9af8
03/19/99 23:26:11 |
Joel Sherrill |
Another cleanup patch for the previous rejected hunk.
4.104.114.84.95
@c0a36429
03/19/99 22:59:20 |
Joel Sherrill |
A cleanup patch on fcntl.c from Eric Norum <eric@…> for …
4.104.114.84.95
@af020036
03/19/99 21:51:58 |
Joel Sherrill |
Patch from Eric Norum <eric@…> that adds external
fcntl …
4.104.114.84.95
@23c4bbf5
03/16/99 01:41:16 |
Joel Sherrill |
Use proper include for libio.h.
4.104.114.84.95
@3195d9c
03/08/99 21:39:16 |
Joel Sherrill |
Added code to translate internal libio flags to POSIX style flags.
4.104.114.84.95
@1bb17020
03/08/99 21:38:56 |
Joel Sherrill |
Added support for F_GETFL and F_SETFL.
4.104.114.84.95
@3ef8798
03/06/99 18:09:15 |
Joel Sherrill |
Added F_GETFL support so the fdopen() implementation in newlib 1.8.1 …
4.104.114.84.95
@73f6236
03/01/99 22:40:08 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to eliminate external
IO …
4.104.114.84.95
@3cf8394
02/24/99 20:58:47 |
Joel Sherrill |
Changed IMFS to use IMFS_NAME_MAX as the maximum length of a basename …
4.104.114.84.95
@edfb0eb
02/18/99 15:11:41 |
Joel Sherrill |
GLobal reentrancy structure is now dynamically initialized.
4.104.114.84.95
@7e2a525b
02/15/99 18:56:08 |
Joel Sherrill |
Patch from Eric Valette <valette@…> to undo the patch
that …
4.104.114.84.95
@9619ff3
02/10/99 17:05:55 |
Joel Sherrill |
Set the read/write offset to 0 when the file is opened. The ACVC had …
4.104.114.84.95
@3165b4d3
02/10/99 17:04:12 |
Joel Sherrill |
Added getcwd().
4.104.114.84.95
@2f87c843
02/05/99 00:28:43 |
Joel Sherrill |
Corrected spacing and added some new error checks that were needed
to …
4.104.114.84.95
@c9df8d8f
01/28/99 18:42:04 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to set more flags in …
4.104.114.84.95
@d78b7a9e
01/26/99 01:49:31 |
Joel Sherrill |
Added libio_sockets.c to hold support routines for networking code.
4.104.114.84.95
@2d733c42
01/20/99 15:48:22 |
Joel Sherrill |
More general fix based on bug report and patch from Ian Lance Taylor …
4.104.114.84.95
@eb6fafd
01/19/99 20:19:22 |
Joel Sherrill |
Per bug report from Jiri Gaisler that RTEMS would no longer build
with …
4.104.114.84.95
@73441b6f
01/04/99 16:26:37 |
Joel Sherrill |
Removed blank lines
4.104.114.84.95
@e22d644
12/14/98 23:01:43 |
Joel Sherrill |
Corrected prototype to confirm to POSIX 1003.1b.
4.104.114.84.95
@cca4400
12/10/98 23:31:54 |
Joel Sherrill |
Merged Eric Norum's select patch that was based on 4.0 and resolved …
4.104.114.84.95
@5822f43
12/03/98 22:17:26 |
Jennifer.Averett |
Added source for F_DUPFD.
4.104.114.84.95
@7a3878b
12/03/98 22:17:13 |
Jennifer.Averett |
Modifications for RTEMS_UNIX.
4.104.114.84.95
@07a3253d
11/23/98 19:07:58 |
Joel Sherrill |
Added base version of file system infrastructure. This includes a …
4.104.114.84.95
@d3b34d2
10/22/98 16:15:40 |
Joel Sherrill |
Changed all of these to stubs.
4.104.114.84.95
@0cd2bd96
10/13/98 18:04:16 |
Joel Sherrill |
Added rest of opendir family and made it compile.
4.104.114.84.95
@928395e
10/13/98 16:07:38 |
Joel Sherrill |
New files.
4.104.114.84.95
@22bb7cd1
10/12/98 17:28:33 |
Joel Sherrill |
New files.
4.104.114.84.95
@388be68f
10/01/98 21:44:31 |
Joel Sherrill |
Patch from Ian Lance Taylor <ian@…>:
The reentrant …
4.104.114.84.95
@3b93a2de
09/23/98 16:34:23 |
Joel Sherrill |
Modifed to zero out the C heap if the CPU Table indicates that the …
4.104.114.84.95
@8a496e46
09/23/98 13:20:34 |
Joel Sherrill |
Patch from Aleksey (Quality Quorum <qqi@…>):
1. …
4.104.114.84.95
@30ba752
09/21/98 00:01:26 |
Joel Sherrill |
Patch from Eric Norum:
I fixed the problems noted by Victor …
4.104.114.84.95
@d9d75fc
08/31/98 23:06:50 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…>:
I have reworked …
4.104.114.84.95
@85734b3
08/31/98 22:53:42 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
I think I figured …
4.104.114.84.95
@b3fd1641
08/21/98 15:32:19 |
Joel Sherrill |
Fix from Eric Norum <eric@…>:
"Thomas Doerfler" …
4.104.114.84.95
@bbdab89
08/21/98 12:52:08 |
Joel Sherrill |
Added initialization of missing termios structure entries.
4.104.114.84.95
@bd7c547
07/28/98 16:49:36 |
Joel Sherrill |
Closed window thanks to patch from Eric Norum.
4.104.114.84.95
@4555bc1e
07/17/98 22:34:54 |
Joel Sherrill |
Initialized tty->refcount to 0. When (for whatever reason) malloc() …
4.104.114.84.95
@6e65840
07/17/98 13:05:03 |
Joel Sherrill |
Patch from Dario Alcocer <alcocer@…>. His comments:
4.104.114.84.95
@270d58f
07/06/98 19:00:33 |
Joel Sherrill |
New file to satisfy readdir() family.
4.104.114.84.95
@9a6994b4
06/18/98 15:22:35 |
Joel Sherrill |
Added freebsd support from Dario Alcocer <alcocer@…>.
4.104.114.84.95
@ce691c51
06/18/98 15:14:48 |
Joel Sherrill |
Corrected so it returns the correct date. Previously was getting the …
4.104.114.84.95
@119bced
05/22/98 14:51:11 |
Joel Sherrill |
Added tcdrain(), cfgetospeed(0, cfsetospeed(), cfgetispeed(), and …
4.104.114.84.95
