@9b4422a2
May 3, 2012, 3:09:24 PM |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.11
@84ab4fce
May 11, 2012, 11:04:26 AM |
Sebastian Huber |
libblock: Add RTEMS_BLKIO_PURGEDEV
4.11
@30d4124
May 7, 2012, 2:30:37 PM |
Sebastian Huber |
Filesystem: PR1398: Fix lseek() mechanic
According to POSIX the …
4.11
@33a105fb
May 7, 2012, 4:08:48 PM |
Joel Sherrill |
Revert: Remove CVS Ids
See …
4.11
@ee32f67a
May 4, 2012, 6:55:28 AM |
Ralf Corsepius |
Remove CVS-Ids.
4.11
@08b9d534
Mar 30, 2012, 9:00:37 AM |
Sebastian Huber |
libblock: PR2040: Fix recycle destination update
Check the …
4.11
@ac50df2
Mar 28, 2012, 9:30:59 AM |
Sebastian Huber |
libblock: PR2040: Add starvation threshold
Do not use the unavailable …
4.11
@b467782b
Mar 26, 2012, 12:58:35 PM |
Sebastian Huber |
libblock: Add rtems_bdbuf_set_block_size()
The new function …
4.11
@3d60c1b
Apr 12, 2012, 8:12:03 AM |
Sebastian Huber |
libblock: Change error status to fatal error
Calling the bdbuf API …
4.11
@462ee70f
Mar 26, 2012, 10:56:01 AM |
Sebastian Huber |
libblock: Use unprotected chain operations
The transfer chain is …
4.11
@89a84c0
Mar 26, 2012, 9:43:57 AM |
Sebastian Huber |
The chains are protected …
4.11
@5b045eb
Apr 3, 2012, 12:50:44 PM |
Sebastian Huber |
Filesystem: Change type of ioctl_return
Change the ioctl_return type …
4.11
@9f808d1f
Mar 14, 2012, 9:45:36 AM |
Sebastian Huber |
PR2040: libblock: Flash disk starvations statistic
4.11
@a757d0f
Mar 14, 2012, 9:33:55 AM |
Sebastian Huber |
PR2040: libblock: Flash disk documentation
4.11
@a309a79
Mar 9, 2012, 1:45:08 PM |
Sebastian Huber |
PR2040: libblock: Fix return status
4.11
@c08072ce
Mar 14, 2012, 7:45:53 AM |
Sebastian Huber |
PR2040: libblock: Avoid erased blocks starvation
The compaction …
4.11
@f9fd0c2
Mar 13, 2012, 1:52:57 PM |
Sebastian Huber |
PR2040: libblock: Track number of erased blocks
4.11
@12806cd
Mar 13, 2012, 1:51:55 PM |
Sebastian Huber |
PR2040: libblock: Use segment control as parameter
4.11
@3ab9c76d
Mar 5, 2012, 3:22:33 PM |
Sebastian Huber |
libblock: Use new API for disk media
4.11
@0121172
Mar 5, 2012, 2:06:02 PM |
Sebastian Huber |
libblock: Add generic IMFS block device nodes
New functions
o …
4.11
@291c9264
Mar 5, 2012, 1:39:53 PM |
Sebastian Huber |
libblock: Split file and simplify
4.11
@3ee7b84
Mar 5, 2012, 10:47:56 AM |
Sebastian Huber |
libblock: New support functions
Add
o rtems_disk_get_block_size(),
4.11
@796967c
Feb 28, 2012, 4:19:49 PM |
Sebastian Huber |
libblock: Change bdbuf API
The functions
o rtems_bdbuf_get(),
o …
4.11
@1024561
Feb 28, 2012, 3:29:27 PM |
Sebastian Huber |
libblock: Documentation
4.11
@c42b03f4
Feb 28, 2012, 2:59:04 PM |
Sebastian Huber |
libblock: Remove superfluous volatile qualifier
All these variables …
4.11
@a3170f7
Feb 28, 2012, 2:34:42 PM |
Sebastian Huber |
libblock: Discard extended partitions
Discard the extended partitions …
4.11
@c93fc2b3
Feb 28, 2012, 1:57:01 PM |
Sebastian Huber |
libblock: rtems_ide_part_table_initialize() API
4.11
@c649976
Feb 28, 2012, 12:28:42 PM |
Sebastian Huber |
libblock: New block IO control support functions
4.11
@4f3cbd9
Feb 28, 2012, 12:03:15 PM |
Sebastian Huber |
libblock: New IO control RTEMS_BLKIO_GETDISKDEV
4.11
@03ad6b1d
Feb 27, 2012, 4:23:05 PM |
Sebastian Huber |
libblock: Avoid bdbuf API
4.11
@5e88538
Mar 5, 2012, 9:02:52 AM |
Sebastian Huber |
4.11
@beea580
Mar 5, 2012, 9:01:37 AM |
Sebastian Huber |
libblock: Add optional free at delete request
4.11
@61250b4
Feb 1, 2012, 4:59:44 PM |
Joel Sherrill |
Remove all .cvsignore files.
4.11
@da13f46
Dec 9, 2011, 1:04:48 PM |
Ralf Corsepius |
2011-12-09 Ralf Corsépius <ralf.corsepius@…>
4.11
@97ae192a
Nov 3, 2011, 6:32:42 AM |
Chris Johns |
2011-11-03 Chris Johns <chrisj@…>
PR …
4.11
@0d23caa
Jul 7, 2011, 10:15:00 PM |
Joel Sherrill |
2011-07-07 Joel Sherrill <joel.sherrill@…>
4.11
@21242c2
Jun 24, 2011, 5:52:58 PM |
Joel Sherrill |
2011-06-24 Joel Sherrill <joel.sherrill@…>
4.11
@f3ea4992
May 11, 2011, 9:38:01 AM |
Sebastian Huber |
2011-05-11 Sebastian Huber <sebastian.huber@…>
4.11
@fd9537b
May 11, 2011, 8:28:49 AM |
Sebastian Huber |
PR …
4.11
@b907b479
Feb 22, 2011, 3:11:06 PM |
Ralf Corsepius |
2011-02-22 Ralf Corsépius <ralf.corsepius@…>
4.11
@a8afce38
Feb 17, 2011, 4:25:43 PM |
Sebastian Huber |
2011-02-17 Sebastian Huber <sebastian.huber@…>
4.11
@fc658e4
Feb 10, 2011, 11:34:58 PM |
Ralf Corsepius |
2011-02-10 Ralf Corsépius <ralf.corsepius@…>
4.11
@1680638
Jan 21, 2011, 9:43:24 AM |
Sebastian Huber |
2011-01-21 Sebastian Huber <sebastian.huber@…>
4.11
@61380a54
Jan 20, 2011, 8:16:15 AM |
Sebastian Huber |
2011-01-20 Sebastian Huber <sebastian.huber@…>
4.11
@d4d6bd81
Aug 25, 2010, 8:44:14 AM |
Sebastian Huber |
2010-08-25 Sebastian Huber <sebastian.huber@…>
4.11
@6ef96da
Aug 25, 2010, 8:31:43 AM |
Sebastian Huber |
CID …
4.11
@2b5bd836
Aug 25, 2010, 8:26:21 AM |
Sebastian Huber |
CID …
4.11
@bf4766fe
Aug 23, 2010, 11:17:42 PM |
Joel Sherrill |
2010-08-23 Joel Sherrill <joel.sherrill@…>
4.11
@f6c33f3
Aug 13, 2010, 12:50:56 PM |
Sebastian Huber |
2010-08-13 Sebastian Huber <sebastian.huber@…>
4.11
@d91e3a7
Aug 13, 2010, 12:40:16 PM |
Sebastian Huber |
4.11
@71c012af
Jul 4, 2010, 2:53:47 PM |
Joel Sherrill |
2010-07-04 Joel Sherrill <joel.sherrill@…>
4.11
@15bcb41
Jun 14, 2010, 1:01:58 PM |
Joel Sherrill |
2010-06-14 Joel Sherrill <joel.sherrilL@…>
PR …
4.11
@eaee27b
Jun 8, 2010, 12:59:51 PM |
Sebastian Huber |
2010-06-08 Sebastian Huber <sebastian.huber@…>
PR …
4.11
@29e92b0
May 31, 2010, 1:56:37 PM |
Chris Johns |
2010-05-31 Chris Johns <chrisj@…>
4.104.11
@f22c154
May 22, 2010, 4:51:05 PM |
Ralf Corsepius |
2010-05-22 Ralf Corsépius <ralf.corsepius@…>
4.104.11
@b5926be
May 22, 2010, 4:43:09 PM |
Ralf Corsepius |
4.104.11
@8aa608df
May 18, 2010, 2:14:05 AM |
Chris Johns |
2010-05-18 Chris Johns <chrisj@…>
4.104.11
@c8522fd
May 17, 2010, 8:08:30 AM |
Sebastian Huber |
2010-05-17 Oleg Kravtsov <Oleg.Kravtsov@…>
PR 1449/cpukit …
4.104.11
@470708da
May 14, 2010, 3:59:11 AM |
Chris Johns |
2010-05-14 Chris Johns <chrisj@…>
4.104.11
@e682fffd
May 12, 2010, 7:57:58 AM |
Sebastian Huber |
2010-04-30 Sebastian Huber <sebastian.huber@…>
4.104.11
@6780829
Apr 30, 2010, 8:42:13 AM |
Sebastian Huber |
4.104.11
@b1d4e42
Apr 29, 2010, 11:34:59 AM |
Sebastian Huber |
2010-04-29 Sebastian Huber <sebastian.huber@…>
4.104.11
@bdac0eed
Apr 9, 2010, 12:28:24 PM |
Thomas.Doerfler |
fixed disk delete
Obtain/release disk during open/close
4.104.11
@694c3ac6
Mar 28, 2010, 3:14:08 AM |
Ralf Corsepius |
Add HAVE_CONFIG_H support to let files receive configure defines.
4.104.11
@00d17034
Mar 12, 2010, 4:35:13 PM |
Joel Sherrill |
2010-03-12 Joel Sherrill <joel.sherrill@…>
4.104.11
@391b4dd
Mar 11, 2010, 7:12:30 PM |
Joel Sherrill |
2010-03-11 Joel Sherrill <joel.sherrill@…>
* ftpd/ftpd.c, …
4.104.11
@c9a4a9a5
Mar 4, 2010, 2:41:32 PM |
Joel Sherrill |
2010-03-04 Joel Sherrill <joel.sherrill@…>
4.104.11
@7a09a7a
Mar 4, 2010, 2:40:51 PM |
Joel Sherrill |
4.104.11
@cca94a2
Feb 19, 2010, 3:23:11 AM |
Chris Johns |
2010-02-19 Chris Johns <chrisj@…>
4.104.11
@a9fa9b7
Feb 18, 2010, 12:24:25 AM |
Chris Johns |
2010-02-18 Chris Johns <chrisj@…>
4.104.11
@1027f153
Jan 29, 2010, 2:57:10 PM |
Thomas.Doerfler |
Fixed invalid chain extract
4.104.11
@e7fb54e
Jan 26, 2010, 3:09:03 PM |
Thomas.Doerfler |
add purge capability to libblock, add proper test case
4.104.11
@04fee31
Jan 20, 2010, 5:10:36 PM |
Joel Sherrill |
2010-01-20 Joel Sherrill <joel.sherrill@…>
Coverity Id 7 …
4.104.11
@a518defe
Jan 19, 2010, 11:54:17 PM |
Joel Sherrill |
2010-01-19 Joel Sherrill <joel.sherrill@…>
Coverity Id 10 …
4.104.11
@b61ad65
Jan 19, 2010, 11:47:41 PM |
Joel Sherrill |
4.104.11
@d3231fba
Jan 19, 2010, 10:09:20 PM |
Joel Sherrill |
Coverity Id 24 …
4.104.11
@b2ac8a9
Jan 19, 2010, 10:05:30 PM |
Joel Sherrill |
Coverity Id 25 …
4.104.11
@5c587596
Jan 19, 2010, 9:10:03 AM |
Thomas.Doerfler |
libblock API update
4.104.11
@c4c8efd
Jan 19, 2010, 2:23:03 AM |
Joel Sherrill |
2010-01-18 Joel Sherrill <joel.sherrill@…>
Coverity Id 27 …
4.104.11
@1e0a551
Dec 18, 2009, 3:59:30 PM |
Thomas.Doerfler |
Update for block device API change
4.104.11
@47c2327
Nov 30, 2009, 12:39:51 PM |
Thomas.Doerfler |
documentation fixes
Avoid designated initializers for C++ …
4.104.11
@18daff9
Nov 29, 2009, 1:35:32 PM |
Ralf Corsepius |
Whitespace removal.
4.104.11
@33c3b54d
Nov 29, 2009, 11:57:23 AM |
Ralf Corsepius |
Whitespace removal.
4.104.11
@6d612944
Nov 20, 2009, 6:33:38 AM |
Thomas.Doerfler |
numerous changes
4.104.11
@c0e0a928
Nov 12, 2009, 3:32:11 PM |
Thomas.Doerfler |
Changed set and get IO controls to use the buffer argument for data …
4.104.11
@887796b
Nov 2, 2009, 12:18:19 PM |
Ralf Corsepius |
2009-11-02 Ralf Corsépius <ralf.corsepius@…>
4.104.11
@6c9b390
Nov 2, 2009, 9:50:06 AM |
Thomas.Doerfler |
Fixed buffer recycling
Wake-up access waiters after sync
4.104.11
@3d5515b
Oct 30, 2009, 10:57:39 AM |
Thomas.Doerfler |
Fixed group usage counting. See test "libtests/block02".
4.104.11
@b5b07cad
Oct 29, 2009, 12:50:01 PM |
Thomas.Doerfler |
- - Reorderd AVL node fields to save space
- Fixed printf() formats. …
4.104.11
@982ca110
Oct 29, 2009, 12:47:04 PM |
Thomas.Doerfler |
Aded ramdisk_register().
4.104.11
@fb5785cc
Oct 22, 2009, 11:56:01 AM |
Ralf Corsepius |
2009-10-22 Ralf Corsépius <ralf.corsepius@…>
4.104.11
@e41369ef
Oct 20, 2009, 7:53:19 AM |
Thomas.Doerfler |
* libblock/include/rtems/diskdevs.h: Documentation. Added field to
4.104.11
@1560d12
Oct 16, 2009, 8:44:51 AM |
Thomas.Doerfler |
restructuring of ramdisk code
4.104.11
@809e91e
Oct 14, 2009, 2:55:15 PM |
Ralf Corsepius |
2009-10-14 Ralf Corsépius <ralf.corsepius@…>
4.104.11
@e9d50ab
Oct 13, 2009, 3:40:21 PM |
Ralf Corsepius |
Use size_t for sizes.
4.104.11
@463b8df
Oct 13, 2009, 3:40:03 PM |
Ralf Corsepius |
Add attribute((unused)) to suppress warnings.
4.104.11
@b36a7d8
Oct 13, 2009, 3:39:43 PM |
Ralf Corsepius |
Use size_t for swapout_workers.
4.104.11
@253c3a1d
Oct 13, 2009, 3:29:45 PM |
Ralf Corsepius |
2009-10-13 Ralf Corsépius <ralf.corsepius@…>
4.104.11
@b96e09c
Oct 13, 2009, 7:58:33 AM |
Thomas.Doerfler |
* libblock/include/rtems/diskdevs.h: Added driver data pointer to IO
4.104.11
@eb649786
Oct 8, 2009, 7:07:36 AM |
Chris Johns |
2009-10-08 Chris Johns <chrisj@…>
* Makefile.am, …
4.104.11
