# # ChangeLog for cpukit/libblock in rtems # # Generated by Trac 1.2.1.dev0 # 04/24/24 16:11:13 Thu, 18 Feb 2010 00:24:25 GMT Chris Johns [a9fa9b7] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/README (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps-ut.c (added) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c (added) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.h (added) * cpukit/libfs/src/rfs/rtems-rfs-block-pos.h (added) * cpukit/libfs/src/rfs/rtems-rfs-block.c (added) * cpukit/libfs/src/rfs/rtems-rfs-block.h (added) * cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c (added) * cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c (added) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (added) * cpukit/libfs/src/rfs/rtems-rfs-buffer.h (added) * cpukit/libfs/src/rfs/rtems-rfs-data.h (added) * cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c (added) * cpukit/libfs/src/rfs/rtems-rfs-dir-hash.h (added) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (added) * cpukit/libfs/src/rfs/rtems-rfs-dir.h (added) * cpukit/libfs/src/rfs/rtems-rfs-file-system-fwd.h (added) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (added) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (added) * cpukit/libfs/src/rfs/rtems-rfs-file.c (added) * cpukit/libfs/src/rfs/rtems-rfs-file.h (added) * cpukit/libfs/src/rfs/rtems-rfs-format.c (added) * cpukit/libfs/src/rfs/rtems-rfs-format.h (added) * cpukit/libfs/src/rfs/rtems-rfs-group.c (added) * cpukit/libfs/src/rfs/rtems-rfs-group.h (added) * cpukit/libfs/src/rfs/rtems-rfs-inode.c (added) * cpukit/libfs/src/rfs/rtems-rfs-inode.h (added) * cpukit/libfs/src/rfs/rtems-rfs-link.c (added) * cpukit/libfs/src/rfs/rtems-rfs-link.h (added) * cpukit/libfs/src/rfs/rtems-rfs-mutex.c (added) * cpukit/libfs/src/rfs/rtems-rfs-mutex.h (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems.h (added) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (added) * cpukit/libfs/src/rfs/rtems-rfs-shell.h (added) * cpukit/libfs/src/rfs/rtems-rfs-trace.c (added) * cpukit/libfs/src/rfs/rtems-rfs-trace.h (added) * cpukit/libfs/src/rfs/rtems-rfs.h (added) * cpukit/libmisc/shell/main_ls.c (modified) * cpukit/libmisc/shell/print-ls.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/preinstall.am (modified) * cpukit/wrapup/Makefile.am (modified) 2010-02-18 Chris Johns * ... Fri, 29 Jan 2010 14:57:10 GMT Thomas Doerfler [1027f153] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) Fixed invalid chain extract Tue, 26 Jan 2010 15:09:03 GMT Thomas Doerfler [e7fb54e] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/block05/Makefile.am (modified) * testsuites/libtests/block05/block05.doc (modified) * testsuites/libtests/block05/block05.png (added) * testsuites/libtests/block10/Makefile.am (added) * testsuites/libtests/block10/block10.doc (added) * testsuites/libtests/block10/block10.png (added) * testsuites/libtests/block10/block10.scn (added) * testsuites/libtests/block10/init.c (added) * testsuites/libtests/configure.ac (modified) add purge capability to libblock, add proper test case Wed, 20 Jan 2010 17:10:36 GMT Joel Sherrill [04fee31] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdpart.c (modified) 2010-01-20 Joel Sherrill ... Tue, 19 Jan 2010 23:54:17 GMT Joel Sherrill [a518defe] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2010-01-19 Joel Sherrill ... Tue, 19 Jan 2010 23:47:41 GMT Joel Sherrill [b61ad65] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ide_part_table.c (modified) 2010-01-19 Joel Sherrill * ... Tue, 19 Jan 2010 22:09:20 GMT Joel Sherrill [d3231fba] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ide_part_table.c (modified) 2010-01-19 Joel Sherrill ... Tue, 19 Jan 2010 22:05:30 GMT Joel Sherrill [b2ac8a9] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ide_part_table.c (modified) 2010-01-19 Joel Sherrill ... Tue, 19 Jan 2010 09:10:03 GMT Thomas Doerfler [5c587596] * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ata_internal.h (modified) * c/src/wrapup/Makefile.am (modified) * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) libblock API update Tue, 19 Jan 2010 02:23:03 GMT Joel Sherrill [c4c8efd0] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ramdisk-config.c (modified) 2010-01-18 Joel Sherrill ... Fri, 18 Dec 2009 15:59:30 GMT Thomas Doerfler [1e0a5512] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/ide/ata.c (modified) * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) Update for block device API change Mon, 30 Nov 2009 12:39:51 GMT Thomas Doerfler [47c2327] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) documentation fixes Avoid designated initializers for C++ ... Sun, 29 Nov 2009 13:35:32 GMT Ralf Corsepius [18daff9] * cpukit/itron/include/rtems/itron/task.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/libcsupport/src/__assert.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/free.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/malloc_get_statistics.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/libcsupport/src/newlibc_init.c (modified) * cpukit/libcsupport/src/open_dev_console.c (modified) * cpukit/libcsupport/src/printk_plugin.c (modified) * cpukit/libcsupport/src/putk.c (modified) * cpukit/libcsupport/src/readv.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/rtems_memalign.c (modified) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libcsupport/src/statvfs.c (modified) * cpukit/libcsupport/src/tcflow.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_setinitialbaud.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/writev.c (modified) Whitespace removal. Sun, 29 Nov 2009 11:57:23 GMT Ralf Corsepius [33c3b54d] * cpukit/include/rtems/bsd/sys/queue.h (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/include/rtems/irq.h (modified) * cpukit/include/rtems/pci.h (modified) * cpukit/include/rtems/userenv.h (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/include/rtems/flashdisk.h (modified) * cpukit/libblock/include/rtems/nvdisk-sram.h (modified) * cpukit/libblock/include/rtems/nvdisk.h (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/rtc.h (modified) * cpukit/libcsupport/include/rtems/framebuffer.h (modified) * cpukit/libcsupport/include/rtems/malloc.h (modified) * cpukit/libcsupport/include/sys/ioctl.h (modified) * cpukit/libcsupport/include/timerdrv.h (modified) * cpukit/libcsupport/include/vmeintr.h (modified) * cpukit/libcsupport/include/zilog/z8036.h (modified) * cpukit/libmisc/capture/capture.h (modified) * cpukit/libmisc/dumpbuf/dumpbuf.h (modified) * cpukit/libmisc/fb/fb.h (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) * cpukit/libmisc/stringto/stringto_template.h (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/barrier.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/object.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) Whitespace removal. Fri, 20 Nov 2009 06:33:38 GMT Thomas Doerfler [6d612944] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) numerous changes Thu, 12 Nov 2009 15:32:11 GMT Thomas Doerfler [c0e0a928] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/blkdev.c (modified) Changed set and get IO controls to use the buffer argument for data ... Mon, 02 Nov 2009 12:18:19 GMT Ralf Corsepius [887796b] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2009-11-02 Ralf Corsépius * ... Mon, 02 Nov 2009 09:50:06 GMT Thomas Doerfler [6c9b390] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) Fixed buffer recycling Wake-up access waiters after sync Fri, 30 Oct 2009 10:57:39 GMT Thomas Doerfler [3d5515b] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) Fixed group usage counting. See test "libtests/block02". Thu, 29 Oct 2009 12:50:01 GMT Thomas Doerfler [b5b07cad] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/bdpart.c (modified) * cpukit/libblock/src/blkdev.c (modified) - - Reorderd AVL node fields to save space - Fixed printf() formats. ... Thu, 29 Oct 2009 12:47:04 GMT Thomas Doerfler [982ca110] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/ramdisk-init.c (modified) Aded ramdisk_register(). Thu, 22 Oct 2009 11:56:01 GMT Ralf Corsepius [fb5785cc] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/flashdisk.h (modified) 2009-10-22 Ralf Corsépius * ... Tue, 20 Oct 2009 07:53:19 GMT Thomas Doerfler [e41369ef] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * libblock/include/rtems/diskdevs.h: Documentation. Added field to ... Fri, 16 Oct 2009 08:44:51 GMT Thomas Doerfler [1560d12] * cpukit/ChangeLog (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/ramdisk-config.c (added) * cpukit/libblock/src/ramdisk-driver.c (added) * cpukit/libblock/src/ramdisk-init.c (added) * cpukit/libblock/src/ramdisk.c (deleted) restructuring of ramdisk code Wed, 14 Oct 2009 14:55:15 GMT Ralf Corsepius [809e91e1] * cpukit/ChangeLog (modified) * cpukit/libblock/Makefile.am (modified) 2009-10-14 Ralf Corsépius * ... Tue, 13 Oct 2009 15:40:21 GMT Ralf Corsepius [e9d50ab] * cpukit/libblock/src/bdbuf.c (modified) Use size_t for sizes. Tue, 13 Oct 2009 15:40:03 GMT Ralf Corsepius [463b8df] * cpukit/libblock/src/bdpart.c (modified) Add __attribute__((unused)) to suppress warnings. Tue, 13 Oct 2009 15:39:43 GMT Ralf Corsepius [b36a7d8] * cpukit/libblock/include/rtems/bdbuf.h (modified) Use size_t for swapout_workers. Tue, 13 Oct 2009 15:29:45 GMT Ralf Corsepius [253c3a1d] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2009-10-13 Ralf Corsépius * ... Tue, 13 Oct 2009 07:58:33 GMT Thomas Doerfler [b96e09c] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * libblock/include/rtems/diskdevs.h: Added driver data pointer to IO ... Thu, 08 Oct 2009 07:07:36 GMT Chris Johns [eb649786] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/sys/statvfs.h (added) * cpukit/libcsupport/src/statvfs.c (added) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/hexdump-display.c (modified) * cpukit/libmisc/shell/main_ln.c (added) * cpukit/libmisc/shell/main_mknod.c (added) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/mknod-pack_dev.c (added) * cpukit/libmisc/shell/mknod-pack_dev.h (added) * cpukit/libmisc/shell/shellconfig.h (modified) * cpukit/libmisc/shell/utils-cp.c (modified) * cpukit/preinstall.am (modified) * cpukit/sapi/inline/rtems/chain.inl (modified) * cpukit/score/inline/rtems/score/address.inl (modified) * cpukit/score/inline/rtems/score/chain.inl (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectfree.c (modified) 2009-10-08 Chris Johns * ... Mon, 14 Sep 2009 14:48:38 GMT Joel Sherrill [7c411bd] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/calloc.c (modified) * cpukit/libcsupport/src/malloc_boundary.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/malloc_report_statistics_plugin.c (modified) * cpukit/libcsupport/src/malloc_statistics_helpers.c (modified) * cpukit/libcsupport/src/malloc_walk.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/vprintk.c (modified) * cpukit/rtems/inline/rtems/rtems/region.inl (modified) * cpukit/score/src/wkspace.c (modified) 2009-09-14 Sebastian Huber ... Thu, 06 Aug 2009 03:58:09 GMT Chris Johns [945884fe] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk.c (modified) 2009-08-06 Chris Johns * ... Wed, 05 Aug 2009 18:17:12 GMT Joel Sherrill [c85ab23] * cpukit/ChangeLog (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdpart.c (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/fs_null_handlers.c (modified) * cpukit/libi2c/libi2c.c (modified) * cpukit/libi2c/libi2c.h (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/barrier.h (modified) * cpukit/rtems/include/rtems/rtems/barriermp.h (modified) * cpukit/rtems/include/rtems/rtems/cache.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/eventset.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/object.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/support.inl (modified) 2009-08-05 Sebastian Huber ... Wed, 05 Aug 2009 00:00:54 GMT Chris Johns [0d15414e] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/dummy/dummy-networking.c (added) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/inline/rtems/chain.inl (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/inline/rtems/score/chain.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) 009-08-05 Chris Johns * ... Fri, 12 Jun 2009 17:38:53 GMT Joel Sherrill [918a0d8] * cpukit/ChangeLog (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) 2009-06-12 Joel Sherrill * ... Fri, 12 Jun 2009 02:59:18 GMT Chris Johns [72755421] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/flashdisk.h (modified) * cpukit/libblock/include/rtems/nvdisk.h (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libcsupport/src/eval.c (modified) 2009-06-12 Chris Johns * ... Fri, 12 Jun 2009 01:53:33 GMT Chris Johns [7baa484] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/bdpart.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chmod.c (modified) * cpukit/libcsupport/src/chown.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/eval.c (modified) * cpukit/libcsupport/src/fchdir.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/stat.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libcsupport/src/utime.c (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/devfs/devfs_eval.c (modified) * cpukit/libfs/src/devfs/devstat.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_gtkn.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unlink.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/pipe/pipe.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) 2009-06-12 Chris Johns * ... Fri, 15 May 2009 12:52:12 GMT Joel Sherrill [4670d91] * cpukit/Doxyfile.in (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/bdpart.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/bdpart.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/ramdisk.c (modified) 2009-05-15 Sebastian Huber ... Fri, 08 May 2009 04:55:53 GMT Chris Johns [199ccde] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdpart.c (modified) * cpukit/libmisc/shell/main_msdosfmt.c (modified) * cpukit/libmisc/shell/main_rm.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/score/include/rtems/score/bitfield.h (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) 2009-05-08 Chris Johns * ... Tue, 05 May 2009 12:57:16 GMT Thomas Doerfler [d0c3b38b] * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/fsmount/fsmount.h (modified) Documentation. Changed integer types to match block device types. ... Tue, 05 May 2009 12:56:30 GMT Thomas Doerfler [d8602eb] * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) Documentation Tue, 05 May 2009 12:53:41 GMT Thomas Doerfler [834df50] * cpukit/libblock/include/rtems/bdpart.h (added) * cpukit/libblock/src/bdpart.c (added) * cpukit/libmisc/shell/fdisk.c (added) New files Tue, 05 May 2009 12:52:29 GMT Thomas Doerfler [870d0a2] * cpukit/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/preinstall.am (modified) Update Wed, 29 Apr 2009 08:51:07 GMT Chris Johns [57aa979] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/sapi/include/confdefs.h (modified) 2009-04-29 Sebastian Huber ... Wed, 29 Apr 2009 08:33:35 GMT Chris Johns [164adec] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) 2009-04-29 Chris Johns * ... Tue, 28 Apr 2009 11:17:36 GMT Chris Johns [8c44190a] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2009-04-28 Chris Johns * ... Fri, 02 Jan 2009 12:43:07 GMT Ralf Corsepius [31e2698] * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk.c (modified) Add __attribute__((unused)) to unused function args. Fri, 19 Dec 2008 14:59:35 GMT Joel Sherrill [eb961961] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libmisc/monitor/mon-command.c (modified) * cpukit/libmisc/monitor/mon-editor.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/libmisc/shell/cmds.c (modified) 2008-12-19 Sebastian Huber ... Tue, 16 Dec 2008 20:53:34 GMT Joel Sherrill [26fb4aa] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/mw-fb/mw_uid.c (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodmsecstoticks.c (added) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/coretodtickspersec.c (added) * cpukit/score/src/coretodusectoticks.c (added) 2008-12-16 Joel Sherrill * ... Tue, 09 Dec 2008 14:44:07 GMT Ralf Corsepius [8c5d3743] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2008-12-09 Sebastian Huber ... Sun, 07 Sep 2008 18:06:27 GMT Ralf Corsepius [90b2c072] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) Use "#include <..>" to include public headers. Sat, 06 Sep 2008 04:25:51 GMT Ralf Corsepius [d7001e47] * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libfs/src/nfsclient/proto/mount_prot.x (modified) Convert to Unix file format. Mon, 01 Sep 2008 07:44:48 GMT Ralf Corsepius [4f971343] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) Convert to using "bool". Mon, 01 Sep 2008 07:21:18 GMT Ralf Corsepius [48c5660] * cpukit/ChangeLog (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) 2008-09-01 Ralf Corsépius * ... Mon, 25 Aug 2008 15:07:58 GMT Ralf Corsepius [e03c37a] * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libblock/src/ramdisk.c (modified) s/rtems_boolean/bool/g. Thu, 21 Aug 2008 16:17:35 GMT Joel Sherrill [cec5c069] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/ramdisk.c (modified) 2008-08-21 Joel Sherrill * ... Thu, 21 Aug 2008 04:32:11 GMT Ralf Corsepius [5c0d4fd] * cpukit/libblock/src/flashdisk.c (modified) Remove bool, true, false. Wed, 20 Aug 2008 07:16:02 GMT Ralf Corsepius [291557b] * cpukit/ChangeLog (modified) * cpukit/libblock/src/nvdisk.c (modified) 2008-08-2008 Ralf Corsépius * ... Wed, 06 Aug 2008 04:38:53 GMT Chris Johns [6f162ed] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2008-08-06 Chris Johns * ... Wed, 06 Aug 2008 04:17:46 GMT Chris Johns [b7898e27] * cpukit/ChangeLog (modified) * cpukit/libblock/src/diskdevs.c (modified) 2008-08-06 Brett Swimley ... Wed, 06 Aug 2008 04:04:59 GMT Chris Johns [904ced08] * cpukit/ChangeLog (modified) * cpukit/libblock/src/diskdevs.c (modified) 2008-08-06 Till Straumann ... Sat, 02 Aug 2008 06:23:45 GMT Chris Johns [2eb89ad] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk.c (modified) 2008-08-02 Chris Johns (chrisj@rtems.org> * ... Fri, 01 Aug 2008 05:01:28 GMT Ralf Corsepius [a5fb40cf] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) Add missing prototypes. Tue, 29 Jul 2008 03:55:03 GMT Chris Johns [021cf6b] * cpukit/ChangeLog (modified) * cpukit/libblock/src/nvdisk.c (modified) 2008-07-29 Chris Johns * ... Tue, 29 Jul 2008 03:15:09 GMT Chris Johns [c21c850e] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) 2008-07-29 Chris Johns * ... Tue, 29 Jul 2008 02:21:15 GMT Chris Johns [3899a537] * cpukit/ChangeLog (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libblock/include/rtems/nvdisk.h (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_free.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/cmp-ls.c (added) * cpukit/libmisc/shell/extern-cp.h (modified) * cpukit/libmisc/shell/extern-ls.h (added) * cpukit/libmisc/shell/filemode.c (added) * cpukit/libmisc/shell/main_blksync.c (modified) * cpukit/libmisc/shell/main_cp.c (modified) * cpukit/libmisc/shell/main_ls.c (modified) * cpukit/libmisc/shell/main_rm.c (modified) * cpukit/libmisc/shell/print-ls.c (added) * cpukit/libmisc/shell/pwcache.c (added) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/utils-cp.c (modified) * cpukit/libmisc/shell/utils-ls.c (added) * cpukit/libmisc/shell/vis.c (added) * cpukit/libmisc/shell/vis.h (added) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/interr.c (modified) 2008-07-29 Chris Johns * ... Thu, 03 Jul 2008 01:37:38 GMT Chris Johns [72d2ec4d] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/preinstall.am (modified) * cpukit/libcsupport/src/malloc_boundary.c (modified) * cpukit/libcsupport/src/malloc_deferred.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_getchild.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/chain.h (added) * cpukit/sapi/inline/rtems/chain.inl (added) * cpukit/sapi/preinstall.am (modified) 2008-07-03 Chris Johns * ... Tue, 27 May 2008 10:34:15 GMT Thomas Doerfler [bf95ccb5] * cpukit/ChangeLog (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_config.c (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_getchild.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unixstub.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/posix/include/rtems/posix/psignal.h (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/src/ioregisterdriver.c (modified) * cpukit/sapi/src/itronapi.c (modified) * cpukit/sapi/src/posixapi.c (modified) Added const qualifier to various pointers and data tables to ... Thu, 01 May 2008 04:15:36 GMT Chris Johns [5a2b5b2] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/nvdisk-sram.h (added) * cpukit/libblock/include/rtems/nvdisk.h (added) * cpukit/libblock/src/nvdisk-sram.c (added) * cpukit/libblock/src/nvdisk.c (added) * cpukit/preinstall.am (modified) 2008-05-01 Chris Johns * ... Wed, 23 Jan 2008 22:57:43 GMT Joel Sherrill [ce19f1fa] * cpukit/ChangeLog (modified) * cpukit/itron/include/rtems/itron/object.h (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/monitor/mon-manager.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/posix/src/condinit.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuenametoid.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/pbarrierinit.c (modified) * cpukit/posix/src/prwlockinit.c (modified) * cpukit/posix/src/pspininit.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/semaphorecreatesupp.c (modified) * cpukit/posix/src/semaphorenametoid.c (modified) * cpukit/posix/src/timercreate.c (modified) * cpukit/rtems/src/barrierident.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/sapi/src/extensionident.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/src/apimutexallocate.c (modified) * cpukit/score/src/objectclearname.c (deleted) * cpukit/score/src/objectcomparenameraw.c (deleted) * cpukit/score/src/objectcomparenamestring.c (deleted) * cpukit/score/src/objectcopynameraw.c (deleted) * cpukit/score/src/objectcopynamestring.c (deleted) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnametoid.c (modified) 2008-01-23 Joel Sherrill * ... Sat, 05 Jan 2008 06:57:17 GMT Chris Johns [a5de1ef] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/libblock/include/rtems/flashdisk.h (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libmisc/shell/shell.c (modified) 2008-01-05 Chris Johns * ... Sat, 22 Dec 2007 08:27:18 GMT Chris Johns [1ff9922] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/monitor/mon-network.c (modified) * cpukit/libmisc/shell/err.c (added) * cpukit/libmisc/shell/err.h (added) * cpukit/libmisc/shell/errx.c (added) * cpukit/libmisc/shell/extern-cp.h (added) * cpukit/libmisc/shell/fts.c (added) * cpukit/libmisc/shell/fts.h (added) * cpukit/libmisc/shell/main_cp.c (added) * cpukit/libmisc/shell/main_mount_nfs.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libmisc/shell/shellconfig.h (modified) * cpukit/libmisc/shell/utils-cp.c (added) * cpukit/libmisc/shell/verr.c (added) * cpukit/libmisc/shell/verrx.c (added) * cpukit/libmisc/shell/vwarn.c (added) * cpukit/libmisc/shell/vwarnx.c (added) * cpukit/libmisc/shell/warn.c (added) * cpukit/libmisc/shell/warnx.c (added) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/inline/rtems/score/coremutex.inl (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/telnetd/icmds.c (modified) 2007-12-22 Chris Johns * ... Fri, 14 Dec 2007 06:02:42 GMT Chris Johns [30088aa] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/flashdisk.h (modified) * cpukit/libblock/src/flashdisk.c (modified) 2007-12-12 Chris Johns * ... Fri, 14 Dec 2007 04:58:04 GMT Chris Johns [3c68c6c8] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/flashdisk.h (added) * cpukit/libblock/src/flashdisk.c (added) * cpukit/preinstall.am (modified) 2007-12-12 Chris Johns * ... Tue, 08 May 2007 15:30:53 GMT Ralf Corsepius [69d5809] * cpukit/ChangeLog (modified) * cpukit/libblock/src/show_bdbuf.c (modified) 2007-05-08 Ralf Corsépius * ... Tue, 30 Jan 2007 07:55:58 GMT Ralf Corsepius [53cd606] * cpukit/ChangeLog (modified) * cpukit/libblock/src/show_bdbuf.c (modified) 2007-01-30 Ralf Corsépius * ... Sat, 27 Jan 2007 18:18:05 GMT Ralf Corsepius [460175ef] * cpukit/ChangeLog (modified) * cpukit/libblock/src/show_bdbuf.c (modified) 2007-01-27 Ralf Corsépius * ... Sun, 21 Jan 2007 18:25:31 GMT Thomas Doerfler [3d14a45] * c/src/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.h (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan_int.h (added) * c/src/libchip/ide/ata.c (modified) * cpukit/ChangeLog (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/show_bdbuf.c (added) * testsuites/samples/ChangeLog (modified) * testsuites/samples/fileio/init.c (modified) mproved gen5200 MSCAN driver fixed synchronization bug between ata.c ... Tue, 21 Nov 2006 11:07:04 GMT Ralf Corsepius [b4bf2897] * cpukit/ChangeLog (modified) * cpukit/libblock/Makefile.am (modified) 2006-11-21 Ralf Corsépius * ... Tue, 21 Nov 2006 11:06:31 GMT Ralf Corsepius [1a741fdc] * cpukit/libblock/preinstall.am (deleted) Remove (unused). Sun, 09 Jul 2006 10:05:27 GMT Thomas Doerfler [c9b005a9] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_glue.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bsp_specs (modified) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/mpc5200.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.h (modified) * c/src/lib/libbsp/powerpc/gen5200/network_5200/network.c (modified) * c/src/lib/libbsp/powerpc/gen5200/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen5200/tod/pcf8563.c (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ata.h (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libcsupport/include/sys/cdefs.h (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libnetworking/netinet/tcp_var.h (modified) * cpukit/libnetworking/sys/linker_set.h (modified) * cpukit/sapi/include/confdefs.h (modified) * make/custom/mpc8260ads.cfg (modified) * testsuites/samples/fileio/system.h (modified) applied patches for PR1117/1118/1119/1120 Tue, 07 Mar 2006 21:26:23 GMT Joel Sherrill [0ebfac19] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2006-03-07 Thomas Doerfler ... Thu, 12 Jan 2006 10:01:38 GMT Ralf Corsepius [6be04ed] * cpukit/libblock/preinstall.am (added) * cpukit/libfs/preinstall.am (added) * cpukit/libmisc/preinstall.am (added) New. Thu, 12 Jan 2006 09:57:43 GMT Ralf Corsepius [4e97166] * cpukit/Makefile.am (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/itron/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/avr/Makefile.am (modified) * cpukit/score/cpu/c4x/Makefile.am (modified) * cpukit/score/cpu/h8300/Makefile.am (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/telnetd/Makefile.am (modified) * cpukit/zlib/Makefile.am (modified) Remove all-local. Tue, 05 Jul 2005 09:25:37 GMT Ralf Corsepius [f139738] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) 2005-07-05 Ralf Corsepius * ... Fri, 06 May 2005 14:57:43 GMT Joel Sherrill [b17ff491] * cpukit/ChangeLog (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/fat_file.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) 2005-05-06 Joel Sherrill * ... Thu, 17 Feb 2005 08:38:59 GMT Ralf Corsepius [e0820e0] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) 2005-02-17 Ralf Corsepius * ... Thu, 17 Feb 2005 07:24:46 GMT Ralf Corsepius [f6a8433d] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/ramdisk.c (modified) 2005-02-17 Ralf Corsepius * ... Tue, 08 Feb 2005 04:04:46 GMT Ralf Corsepius [fa73ccb] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libfs/Makefile.am (modified) 2005-02-08 Ralf Corsepius * ... Wed, 02 Feb 2005 00:06:18 GMT Joel Sherrill [ce92867b] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/posix/macros/rtems/posix/cond.inl (modified) * cpukit/posix/macros/rtems/posix/mutex.inl (modified) 2005-02-01 Joel Sherrill * ... Fri, 28 Jan 2005 08:44:51 GMT Ralf Corsepius [a6f5d89] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/imfs/imfs.h (modified) New header guard. Fri, 28 Jan 2005 02:32:38 GMT Ralf Corsepius [05b37c50] * cpukit/itron/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) 2005-01-28 Ralf Corsepius * ... Fri, 07 Jan 2005 06:05:49 GMT Ralf Corsepius [a369ade] * cpukit/ChangeLog (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/itron/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/score/Makefile.am (modified) 2005-01-07 Ralf Corsepius * ... Wed, 05 Jan 2005 18:17:01 GMT Ralf Corsepius [08885d63] * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libmisc/capture/capture.c (modified) Fix typo. Sat, 01 Jan 2005 10:41:29 GMT Ralf Corsepius [846a4af] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/itron/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) 2005-01-01 Ralf Corsepius * ... Mon, 22 Nov 2004 03:48:05 GMT Ralf Corsepius [b80dd59d] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) 2004-11-22 Ralf Corsepius * ... Sat, 17 Apr 2004 08:19:11 GMT Ralf Corsepius [d63a2c2] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ide_part_table.c (modified) 2004-04-17 Ralf Corsepius * ... Sat, 17 Apr 2004 08:15:17 GMT Ralf Corsepius [8b96149] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libblock/src/ramdisk.c (modified) Remove stray white spaces. Thu, 15 Apr 2004 14:50:20 GMT Ralf Corsepius [048dcd2b] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libblock/src/ramdisk.c (modified) Remove stray white spaces.
