# # ChangeLog for cpukit/libblock/src in rtems # # Generated by Trac 1.2.1.dev0 # 04/20/24 04:25:43 Thu, 12 Apr 2012 08:12:03 GMT Sebastian Huber [3d60c1b] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) libblock: Change error status to fatal error Calling the bdbuf API ... Mon, 26 Mar 2012 10:56:01 GMT Sebastian Huber [462ee70f] * cpukit/libblock/src/bdbuf.c (modified) libblock: Use unprotected chain operations The transfer chain is ... Mon, 26 Mar 2012 09:43:57 GMT Sebastian Huber [89a84c0] * cpukit/libblock/src/bdbuf.c (modified) libblock: Use unprotected chain operations The chains are protected ... Tue, 03 Apr 2012 12:50:44 GMT Sebastian Huber [5b045eb] * cpukit/libblock/src/blkdev.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/termios.c (modified) Filesystem: Change type of ioctl_return Change the ioctl_return ... Wed, 14 Mar 2012 09:45:36 GMT Sebastian Huber [9f808d1f] * cpukit/libblock/src/flashdisk.c (modified) PR2040: libblock: Flash disk starvations statistic Wed, 14 Mar 2012 09:33:55 GMT Sebastian Huber [a757d0f] * cpukit/libblock/include/rtems/flashdisk.h (modified) * cpukit/libblock/src/flashdisk.c (modified) PR2040: libblock: Flash disk documentation Fri, 09 Mar 2012 13:45:08 GMT Sebastian Huber [a309a79] * cpukit/libblock/src/flashdisk.c (modified) PR2040: libblock: Fix return status Wed, 14 Mar 2012 07:45:53 GMT Sebastian Huber [c08072ce] * cpukit/libblock/src/flashdisk.c (modified) PR2040: libblock: Avoid erased blocks starvation The compaction ... Tue, 13 Mar 2012 13:52:57 GMT Sebastian Huber [f9fd0c2] * cpukit/libblock/src/flashdisk.c (modified) PR2040: libblock: Track number of erased blocks Tue, 13 Mar 2012 13:51:55 GMT Sebastian Huber [12806cd] * cpukit/libblock/src/flashdisk.c (modified) PR2040: libblock: Use segment control as parameter Mon, 05 Mar 2012 15:22:33 GMT Sebastian Huber [3ab9c76d] * cpukit/libblock/src/media.c (modified) libblock: Use new API for disk media Mon, 05 Mar 2012 14:06:02 GMT Sebastian Huber [01211720] * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/blkdev-imfs.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/block11/Makefile.am (added) * testsuites/libtests/block11/block11.doc (added) * testsuites/libtests/block11/block11.scn (added) * testsuites/libtests/block11/init.c (added) * testsuites/libtests/configure.ac (modified) libblock: Add generic IMFS block device nodes New functions o ... Mon, 05 Mar 2012 13:39:53 GMT Sebastian Huber [291c9264] * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/src/blkdev-ioctl.c (added) * cpukit/libblock/src/blkdev.c (modified) libblock: Split file and simplify Tue, 28 Feb 2012 16:19:49 GMT Sebastian Huber [796967c] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/bdpart.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/bdpart-create.c (modified) * cpukit/libblock/src/bdpart-read.c (modified) * cpukit/libblock/src/bdpart-register.c (modified) * cpukit/libblock/src/bdpart-write.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/media.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (modified) * testsuites/libtests/block02/init.c (modified) * testsuites/libtests/block03/init.c (modified) * testsuites/libtests/block04/init.c (modified) * testsuites/libtests/block05/init.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block07/init.c (modified) * testsuites/libtests/block08/bdbuf_test1_1.c (modified) * testsuites/libtests/block08/bdbuf_test1_2.c (modified) * testsuites/libtests/block08/bdbuf_test1_3.c (modified) * testsuites/libtests/block08/bdbuf_test1_4.c (modified) * testsuites/libtests/block08/bdbuf_test1_5.c (modified) * testsuites/libtests/block08/bdbuf_test2_1.c (modified) * testsuites/libtests/block08/bdbuf_test2_2.c (modified) * testsuites/libtests/block08/bdbuf_test3_1.c (modified) * testsuites/libtests/block08/bdbuf_test3_2.c (modified) * testsuites/libtests/block08/bdbuf_test3_3.c (modified) * testsuites/libtests/block08/bdbuf_test4_1.c (modified) * testsuites/libtests/block08/bdbuf_test4_2.c (modified) * testsuites/libtests/block08/bdbuf_test4_3.c (modified) * testsuites/libtests/block08/bdbuf_tests.c (modified) * testsuites/libtests/block08/bdbuf_tests.h (modified) * testsuites/libtests/block08/test_disk.c (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/samples/fileio/init.c (modified) libblock: Change bdbuf API The functions o rtems_bdbuf_get(), o ... Tue, 28 Feb 2012 14:59:04 GMT Sebastian Huber [c42b03f4] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) libblock: Remove superfluous volatile qualifier All these variables ... Tue, 28 Feb 2012 14:34:42 GMT Sebastian Huber [a3170f7] * cpukit/libblock/src/ide_part_table.c (modified) libblock: Discard extended partitions Discard the extended ... Tue, 28 Feb 2012 13:57:01 GMT Sebastian Huber [c93fc2b3] * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libblock/src/ide_part_table.c (modified) libblock: rtems_ide_part_table_initialize() API Tue, 28 Feb 2012 12:03:15 GMT Sebastian Huber [4f3cbd9] * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/blkdev.c (modified) libblock: New IO control RTEMS_BLKIO_GETDISKDEV Mon, 27 Feb 2012 16:23:05 GMT Sebastian Huber [03ad6b1d] * cpukit/libblock/src/ide_part_table.c (modified) libblock: Avoid bdbuf API Mon, 05 Mar 2012 09:02:52 GMT Sebastian Huber [5e88538] * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/src/ramdisk-init.c (modified) * cpukit/libblock/src/ramdisk-register.c (added) libblock: Split file Mon, 05 Mar 2012 09:01:37 GMT Sebastian Huber [beea580] * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) libblock: Add optional free at delete request Fri, 09 Dec 2011 13:04:48 GMT Ralf Corsepius [da13f46] * cpukit/ChangeLog (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) 2011-12-09 Ralf Corsépius * ... Thu, 03 Nov 2011 06:32:42 GMT Chris Johns [97ae192a] * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) 2011-11-03 Chris Johns PR ... Thu, 07 Jul 2011 22:15:00 GMT Joel Sherrill [0d23caa] * cpukit/ChangeLog (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libi2c/libi2c.c (modified) * cpukit/libmisc/shell/main_msdosfmt.c (modified) 2011-07-07 Joel Sherrill * ... Wed, 11 May 2011 08:28:49 GMT Sebastian Huber [fd9537b] * cpukit/ChangeLog (modified) * cpukit/libblock/src/flashdisk.c (modified) 2011-05-11 Sebastian Huber ... Tue, 22 Feb 2011 15:11:06 GMT Ralf Corsepius [b907b479] * cpukit/ChangeLog (modified) * cpukit/libblock/src/media-path.c (modified) 2011-02-22 Ralf Corsépius * ... Thu, 17 Feb 2011 16:25:43 GMT Sebastian Huber [a8afce38] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdpart.h (modified) * cpukit/libblock/src/bdpart-create.c (modified) * cpukit/libblock/src/bdpart-read.c (modified) * cpukit/libblock/src/bdpart-write.c (modified) * cpukit/libmisc/shell/fdisk.c (modified) 2011-02-17 Sebastian Huber ... Thu, 10 Feb 2011 23:34:58 GMT Ralf Corsepius [fc658e4] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdpart.h (modified) * cpukit/libblock/src/bdpart-create.c (modified) * cpukit/libblock/src/bdpart-read.c (modified) * cpukit/libblock/src/bdpart-write.c (modified) 2011-02-10 Ralf Corsépius * ... Fri, 21 Jan 2011 09:43:24 GMT Sebastian Huber [1680638] * cpukit/ChangeLog (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/blkdev-ops.c (added) 2011-01-21 Sebastian Huber ... Thu, 20 Jan 2011 08:16:15 GMT Sebastian Huber [61380a54] * cpukit/ChangeLog (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/score/src/objectmp.c (modified) 2011-01-20 Sebastian Huber ... Wed, 25 Aug 2010 08:44:14 GMT Sebastian Huber [d4d6bd81] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/media.h (modified) * cpukit/libblock/src/media-server.c (modified) 2010-08-25 Sebastian Huber ... Wed, 25 Aug 2010 08:31:43 GMT Sebastian Huber [6ef96da] * cpukit/ChangeLog (modified) * cpukit/libblock/src/media.c (modified) 2010-08-25 Sebastian Huber ... Wed, 25 Aug 2010 08:26:21 GMT Sebastian Huber [2b5bd836] * cpukit/ChangeLog (modified) * cpukit/libblock/src/media-path.c (modified) 2010-08-25 Sebastian Huber ... Mon, 23 Aug 2010 23:17:42 GMT Joel Sherrill [bf4766fe] * cpukit/ChangeLog (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) 2010-08-23 Joel Sherrill * ... Fri, 13 Aug 2010 12:50:56 GMT Sebastian Huber [f6c33f3] * cpukit/ChangeLog (modified) * cpukit/libblock/src/media.c (modified) 2010-08-13 Sebastian Huber ... Fri, 13 Aug 2010 12:40:16 GMT Sebastian Huber [d91e3a7] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/media.h (added) * cpukit/libblock/src/media-desc.c (added) * cpukit/libblock/src/media-dev-ident.c (added) * cpukit/libblock/src/media-path.c (added) * cpukit/libblock/src/media-server.c (added) * cpukit/libblock/src/media.c (added) * cpukit/preinstall.am (modified) 2010-08-13 Sebastian Huber ... Sun, 04 Jul 2010 14:53:47 GMT Joel Sherrill [71c012af] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/libcsupport/src/mallocfreespace.c (modified) * cpukit/libcsupport/src/mount-mgr.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/rewinddir.c (modified) * cpukit/libcsupport/src/seekdir.c (modified) * cpukit/libcsupport/src/telldir.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_rename.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/shell/vis.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/telnetd/telnetd.c (modified) 2010-07-04 Joel Sherrill * ... Mon, 14 Jun 2010 13:01:58 GMT Joel Sherrill [15bcb41] * cpukit/ChangeLog (modified) * cpukit/libblock/src/flashdisk.c (modified) 2010-06-14 Joel Sherrill ... Tue, 08 Jun 2010 12:59:51 GMT Sebastian Huber [eaee27b] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdpart-mount.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/src/pipe/pipe.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/fsmount/fsmount.h (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/libnetworking/rtems/mkrootfs.h (modified) 2010-06-08 Sebastian Huber ... Mon, 31 May 2010 13:56:37 GMT Chris Johns [29e92b0] * cpukit/ChangeLog (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/libblock/src/bdpart-mount.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/devfs/devfs_eval.c (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/nfsclient/src/librtemsNfs.h (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs.h (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/fsmount/fsmount.h (modified) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/main_mount_ftp.c (deleted) * cpukit/libmisc/shell/main_mount_msdos.c (deleted) * cpukit/libmisc/shell/main_mount_rfs.c (deleted) * cpukit/libmisc/shell/main_mount_tftp.c (deleted) * cpukit/libmisc/shell/shellconfig.h (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/rtems/ftpfs.h (modified) * cpukit/libnetworking/rtems/tftp.h (modified) * cpukit/sapi/include/confdefs.h (modified) 2010-05-31 Chris Johns * ... Sat, 22 May 2010 16:51:05 GMT Ralf Corsepius [f22c154] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/nvdisk.h (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) 2010-05-22 Ralf Corsépius * ... Sat, 22 May 2010 16:43:09 GMT Ralf Corsepius [b5926be] * cpukit/ChangeLog (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) 2010-05-22 Ralf Corsépius * ... Tue, 18 May 2010 02:14:05 GMT Chris Johns [8aa608df] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/diskdevs.c (modified) 2010-05-18 Chris Johns * ... Mon, 17 May 2010 08:08:30 GMT Sebastian Huber [c8522fd] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/diskdevs.c (modified) 2010-05-17 Oleg Kravtsov ... Fri, 14 May 2010 03:59:11 GMT Chris Johns [470708da] * cpukit/ChangeLog (modified) * cpukit/libblock/src/flashdisk.c (modified) 2010-05-14 Chris Johns * ... Wed, 12 May 2010 07:57:58 GMT Sebastian Huber [e682fffd] * cpukit/libblock/src/bdpart.c (deleted) 2010-04-30 Sebastian Huber ... Fri, 30 Apr 2010 08:42:13 GMT Sebastian Huber [6780829] * cpukit/ChangeLog (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/bdpart.h (modified) * cpukit/libblock/src/bdpart-create.c (added) * cpukit/libblock/src/bdpart-dump.c (added) * cpukit/libblock/src/bdpart-mount.c (added) * cpukit/libblock/src/bdpart-read.c (added) * cpukit/libblock/src/bdpart-register.c (added) * cpukit/libblock/src/bdpart-sort.c (added) * cpukit/libblock/src/bdpart-write.c (added) 2010-04-30 Sebastian Huber ... Thu, 29 Apr 2010 11:34:59 GMT Sebastian Huber [b1d4e42] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/diskdevs.c (modified) 2010-04-29 Sebastian Huber ... Fri, 09 Apr 2010 12:28:24 GMT Thomas Doerfler [bdac0eed] * cpukit/ChangeLog (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) fixed disk delete Obtain/release disk during open/close Sun, 28 Mar 2010 03:14:08 GMT Ralf Corsepius [694c3ac6] * cpukit/libblock/src/bdpart.c (modified) * cpukit/libblock/src/ramdisk-config.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * cpukit/libblock/src/ramdisk-init.c (modified) * cpukit/libfs/src/pipe/pipe.c (modified) Add HAVE_CONFIG_H support to let files receive configure defines. Fri, 12 Mar 2010 16:35:13 GMT Joel Sherrill [00d17034] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ide_part_table.c (modified) 2010-03-12 Joel Sherrill * ... Thu, 11 Mar 2010 19:12:30 GMT Joel Sherrill [391b4dd] * cpukit/ChangeLog (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/httpd/uemf.c (modified) * cpukit/httpd/um.c (modified) * cpukit/httpd/webs.c (modified) * cpukit/httpd/websuemf.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/monitor/mon-network.c (modified) * cpukit/libmisc/shell/hexdump-odsyntax.c (modified) * cpukit/libmisc/shell/main_ifconfig.c (modified) * cpukit/libmisc/uuid/parse.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) 2010-03-11 Joel Sherrill * ... Thu, 04 Mar 2010 14:41:32 GMT Joel Sherrill [c9a4a9a5] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ramdisk-config.c (modified) 2010-03-04 Joel Sherrill * ... Thu, 04 Mar 2010 14:40:51 GMT Joel Sherrill [7a09a7a] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ramdisk-config.c (modified) * cpukit/sapi/include/confdefs.h (modified) 2010-03-04 Joel Sherrill * ... Fri, 19 Feb 2010 03:23:11 GMT Chris Johns [cca94a2] * cpukit/ChangeLog (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.h (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_debugrfs.c (added) * cpukit/libmisc/shell/main_mkrfs.c (added) * cpukit/libmisc/shell/main_mount_rfs.c (added) * cpukit/libmisc/shell/main_msdosfmt.c (modified) * cpukit/libmisc/shell/shellconfig.h (modified) 2010-02-19 Chris Johns * ... Thu, 18 Feb 2010 00:24:25 GMT Chris Johns [a9fa9b7] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/README (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps-ut.c (added) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c (added) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.h (added) * cpukit/libfs/src/rfs/rtems-rfs-block-pos.h (added) * cpukit/libfs/src/rfs/rtems-rfs-block.c (added) * cpukit/libfs/src/rfs/rtems-rfs-block.h (added) * cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c (added) * cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c (added) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (added) * cpukit/libfs/src/rfs/rtems-rfs-buffer.h (added) * cpukit/libfs/src/rfs/rtems-rfs-data.h (added) * cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c (added) * cpukit/libfs/src/rfs/rtems-rfs-dir-hash.h (added) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (added) * cpukit/libfs/src/rfs/rtems-rfs-dir.h (added) * cpukit/libfs/src/rfs/rtems-rfs-file-system-fwd.h (added) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (added) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (added) * cpukit/libfs/src/rfs/rtems-rfs-file.c (added) * cpukit/libfs/src/rfs/rtems-rfs-file.h (added) * cpukit/libfs/src/rfs/rtems-rfs-format.c (added) * cpukit/libfs/src/rfs/rtems-rfs-format.h (added) * cpukit/libfs/src/rfs/rtems-rfs-group.c (added) * cpukit/libfs/src/rfs/rtems-rfs-group.h (added) * cpukit/libfs/src/rfs/rtems-rfs-inode.c (added) * cpukit/libfs/src/rfs/rtems-rfs-inode.h (added) * cpukit/libfs/src/rfs/rtems-rfs-link.c (added) * cpukit/libfs/src/rfs/rtems-rfs-link.h (added) * cpukit/libfs/src/rfs/rtems-rfs-mutex.c (added) * cpukit/libfs/src/rfs/rtems-rfs-mutex.h (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (added) * cpukit/libfs/src/rfs/rtems-rfs-rtems.h (added) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (added) * cpukit/libfs/src/rfs/rtems-rfs-shell.h (added) * cpukit/libfs/src/rfs/rtems-rfs-trace.c (added) * cpukit/libfs/src/rfs/rtems-rfs-trace.h (added) * cpukit/libfs/src/rfs/rtems-rfs.h (added) * cpukit/libmisc/shell/main_ls.c (modified) * cpukit/libmisc/shell/print-ls.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/preinstall.am (modified) * cpukit/wrapup/Makefile.am (modified) 2010-02-18 Chris Johns * ... Fri, 29 Jan 2010 14:57:10 GMT Thomas Doerfler [1027f153] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) Fixed invalid chain extract Tue, 26 Jan 2010 15:09:03 GMT Thomas Doerfler [e7fb54e] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/block05/Makefile.am (modified) * testsuites/libtests/block05/block05.doc (modified) * testsuites/libtests/block05/block05.png (added) * testsuites/libtests/block10/Makefile.am (added) * testsuites/libtests/block10/block10.doc (added) * testsuites/libtests/block10/block10.png (added) * testsuites/libtests/block10/block10.scn (added) * testsuites/libtests/block10/init.c (added) * testsuites/libtests/configure.ac (modified) add purge capability to libblock, add proper test case Wed, 20 Jan 2010 17:10:36 GMT Joel Sherrill [04fee31] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdpart.c (modified) 2010-01-20 Joel Sherrill ... Tue, 19 Jan 2010 23:54:17 GMT Joel Sherrill [a518defe] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2010-01-19 Joel Sherrill ... Tue, 19 Jan 2010 23:47:41 GMT Joel Sherrill [b61ad65] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ide_part_table.c (modified) 2010-01-19 Joel Sherrill * ... Tue, 19 Jan 2010 22:09:20 GMT Joel Sherrill [d3231fba] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ide_part_table.c (modified) 2010-01-19 Joel Sherrill ... Tue, 19 Jan 2010 22:05:30 GMT Joel Sherrill [b2ac8a9] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ide_part_table.c (modified) 2010-01-19 Joel Sherrill ... Tue, 19 Jan 2010 09:10:03 GMT Thomas Doerfler [5c587596] * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ata_internal.h (modified) * c/src/wrapup/Makefile.am (modified) * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) libblock API update Tue, 19 Jan 2010 02:23:03 GMT Joel Sherrill [c4c8efd0] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ramdisk-config.c (modified) 2010-01-18 Joel Sherrill ... Fri, 18 Dec 2009 15:59:30 GMT Thomas Doerfler [1e0a5512] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/ide/ata.c (modified) * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) Update for block device API change Mon, 30 Nov 2009 12:39:51 GMT Thomas Doerfler [47c2327] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) documentation fixes Avoid designated initializers for C++ ... Sun, 29 Nov 2009 13:35:32 GMT Ralf Corsepius [18daff9] * cpukit/itron/include/rtems/itron/task.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/libcsupport/src/__assert.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/free.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/malloc_get_statistics.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/libcsupport/src/newlibc_init.c (modified) * cpukit/libcsupport/src/open_dev_console.c (modified) * cpukit/libcsupport/src/printk_plugin.c (modified) * cpukit/libcsupport/src/putk.c (modified) * cpukit/libcsupport/src/readv.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/rtems_memalign.c (modified) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libcsupport/src/statvfs.c (modified) * cpukit/libcsupport/src/tcflow.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_setinitialbaud.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/writev.c (modified) Whitespace removal. Fri, 20 Nov 2009 06:33:38 GMT Thomas Doerfler [6d612944] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) numerous changes Thu, 12 Nov 2009 15:32:11 GMT Thomas Doerfler [c0e0a928] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/blkdev.c (modified) Changed set and get IO controls to use the buffer argument for data ... Mon, 02 Nov 2009 12:18:19 GMT Ralf Corsepius [887796b] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2009-11-02 Ralf Corsépius * ... Mon, 02 Nov 2009 09:50:06 GMT Thomas Doerfler [6c9b390] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) Fixed buffer recycling Wake-up access waiters after sync Fri, 30 Oct 2009 10:57:39 GMT Thomas Doerfler [3d5515b] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) Fixed group usage counting. See test "libtests/block02". Thu, 29 Oct 2009 12:50:01 GMT Thomas Doerfler [b5b07cad] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/bdpart.c (modified) * cpukit/libblock/src/blkdev.c (modified) - - Reorderd AVL node fields to save space - Fixed printf() formats. ... Thu, 29 Oct 2009 12:47:04 GMT Thomas Doerfler [982ca110] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/ramdisk-init.c (modified) Aded ramdisk_register(). Tue, 20 Oct 2009 07:53:19 GMT Thomas Doerfler [e41369ef] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * libblock/include/rtems/diskdevs.h: Documentation. Added field to ... Fri, 16 Oct 2009 08:44:51 GMT Thomas Doerfler [1560d12] * cpukit/ChangeLog (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/ramdisk-config.c (added) * cpukit/libblock/src/ramdisk-driver.c (added) * cpukit/libblock/src/ramdisk-init.c (added) * cpukit/libblock/src/ramdisk.c (deleted) restructuring of ramdisk code Tue, 13 Oct 2009 15:40:21 GMT Ralf Corsepius [e9d50ab] * cpukit/libblock/src/bdbuf.c (modified) Use size_t for sizes. Tue, 13 Oct 2009 15:40:03 GMT Ralf Corsepius [463b8df] * cpukit/libblock/src/bdpart.c (modified) Add __attribute__((unused)) to suppress warnings. Tue, 13 Oct 2009 15:29:45 GMT Ralf Corsepius [253c3a1d] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2009-10-13 Ralf Corsépius * ... Tue, 13 Oct 2009 07:58:33 GMT Thomas Doerfler [b96e09c] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * libblock/include/rtems/diskdevs.h: Added driver data pointer to IO ... Thu, 08 Oct 2009 07:07:36 GMT Chris Johns [eb649786] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/sys/statvfs.h (added) * cpukit/libcsupport/src/statvfs.c (added) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/hexdump-display.c (modified) * cpukit/libmisc/shell/main_ln.c (added) * cpukit/libmisc/shell/main_mknod.c (added) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/mknod-pack_dev.c (added) * cpukit/libmisc/shell/mknod-pack_dev.h (added) * cpukit/libmisc/shell/shellconfig.h (modified) * cpukit/libmisc/shell/utils-cp.c (modified) * cpukit/preinstall.am (modified) * cpukit/sapi/inline/rtems/chain.inl (modified) * cpukit/score/inline/rtems/score/address.inl (modified) * cpukit/score/inline/rtems/score/chain.inl (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectfree.c (modified) 2009-10-08 Chris Johns * ... Thu, 06 Aug 2009 03:58:09 GMT Chris Johns [945884fe] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk.c (modified) 2009-08-06 Chris Johns * ... Wed, 05 Aug 2009 18:17:12 GMT Joel Sherrill [c85ab23] * cpukit/ChangeLog (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdpart.c (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/fs_null_handlers.c (modified) * cpukit/libi2c/libi2c.c (modified) * cpukit/libi2c/libi2c.h (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/barrier.h (modified) * cpukit/rtems/include/rtems/rtems/barriermp.h (modified) * cpukit/rtems/include/rtems/rtems/cache.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/eventset.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/object.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/support.inl (modified) 2009-08-05 Sebastian Huber ... Wed, 05 Aug 2009 00:00:54 GMT Chris Johns [0d15414e] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/dummy/dummy-networking.c (added) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/inline/rtems/chain.inl (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/inline/rtems/score/chain.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) 009-08-05 Chris Johns * ... Fri, 12 Jun 2009 17:38:53 GMT Joel Sherrill [918a0d8] * cpukit/ChangeLog (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) 2009-06-12 Joel Sherrill * ... Fri, 12 Jun 2009 02:59:18 GMT Chris Johns [72755421] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/flashdisk.h (modified) * cpukit/libblock/include/rtems/nvdisk.h (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libcsupport/src/eval.c (modified) 2009-06-12 Chris Johns * ... Fri, 12 Jun 2009 01:53:33 GMT Chris Johns [7baa484] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/bdpart.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chmod.c (modified) * cpukit/libcsupport/src/chown.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/eval.c (modified) * cpukit/libcsupport/src/fchdir.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/stat.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libcsupport/src/utime.c (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/devfs/devfs_eval.c (modified) * cpukit/libfs/src/devfs/devstat.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_gtkn.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unlink.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/pipe/pipe.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) 2009-06-12 Chris Johns * ... Fri, 15 May 2009 12:52:12 GMT Joel Sherrill [4670d91] * cpukit/Doxyfile.in (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/bdpart.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/bdpart.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/ramdisk.c (modified) 2009-05-15 Sebastian Huber ... Fri, 08 May 2009 04:55:53 GMT Chris Johns [199ccde] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdpart.c (modified) * cpukit/libmisc/shell/main_msdosfmt.c (modified) * cpukit/libmisc/shell/main_rm.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/score/include/rtems/score/bitfield.h (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) 2009-05-08 Chris Johns * ... Tue, 05 May 2009 12:57:16 GMT Thomas Doerfler [d0c3b38b] * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/fsmount/fsmount.h (modified) Documentation. Changed integer types to match block device types. ... Tue, 05 May 2009 12:53:41 GMT Thomas Doerfler [834df50] * cpukit/libblock/include/rtems/bdpart.h (added) * cpukit/libblock/src/bdpart.c (added) * cpukit/libmisc/shell/fdisk.c (added) New files Wed, 29 Apr 2009 08:51:07 GMT Chris Johns [57aa979] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/sapi/include/confdefs.h (modified) 2009-04-29 Sebastian Huber ... Tue, 28 Apr 2009 11:17:36 GMT Chris Johns [8c44190a] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2009-04-28 Chris Johns * ... Fri, 02 Jan 2009 12:43:07 GMT Ralf Corsepius [31e2698] * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk.c (modified) Add __attribute__((unused)) to unused function args. Fri, 19 Dec 2008 14:59:35 GMT Joel Sherrill [eb961961] * cpukit/ChangeLog (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libmisc/monitor/mon-command.c (modified) * cpukit/libmisc/monitor/mon-editor.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/libmisc/shell/cmds.c (modified) 2008-12-19 Sebastian Huber ... Tue, 16 Dec 2008 20:53:34 GMT Joel Sherrill [26fb4aa] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/mw-fb/mw_uid.c (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodmsecstoticks.c (added) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/coretodtickspersec.c (added) * cpukit/score/src/coretodusectoticks.c (added) 2008-12-16 Joel Sherrill * ... Tue, 09 Dec 2008 14:44:07 GMT Ralf Corsepius [8c5d3743] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2008-12-09 Sebastian Huber ... Mon, 01 Sep 2008 07:44:48 GMT Ralf Corsepius [4f971343] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) Convert to using "bool". Mon, 01 Sep 2008 07:21:18 GMT Ralf Corsepius [48c5660] * cpukit/ChangeLog (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) 2008-09-01 Ralf Corsépius * ...
