# # ChangeLog for cpukit/itron/src/sysmgmt.c in rtems # # Generated by Trac 1.2.1.dev0 # 05/03/24 17:32:36 Tue, 17 Apr 2007 20:32:13 GMT Joel Sherrill [0ab34c90] * cpukit/ChangeLog (modified) * cpukit/itron/Makefile.am (modified) * cpukit/itron/src/acp_por.c (added) * cpukit/itron/src/act_cyc.c (added) * cpukit/itron/src/cal_por.c (added) * cpukit/itron/src/chg_iXX.c (added) * cpukit/itron/src/clr_flg.c (added) * cpukit/itron/src/cre_flg.c (added) * cpukit/itron/src/cre_mpf.c (added) * cpukit/itron/src/cre_mpl.c (added) * cpukit/itron/src/cre_por.c (added) * cpukit/itron/src/def_alm.c (added) * cpukit/itron/src/def_cyc.c (added) * cpukit/itron/src/def_exc.c (added) * cpukit/itron/src/def_int.c (added) * cpukit/itron/src/def_svc.c (added) * cpukit/itron/src/del_flg.c (added) * cpukit/itron/src/del_mpf.c (added) * cpukit/itron/src/del_mpl.c (added) * cpukit/itron/src/del_por.c (added) * cpukit/itron/src/dis_int.c (added) * cpukit/itron/src/dly_tsk.c (added) * cpukit/itron/src/ena_int.c (added) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/fwd_por.c (added) * cpukit/itron/src/get_blf.c (added) * cpukit/itron/src/get_blk.c (added) * cpukit/itron/src/get_tim.c (added) * cpukit/itron/src/get_ver.c (added) * cpukit/itron/src/itroninittasks.c (added) * cpukit/itron/src/itronintr.c (modified) * cpukit/itron/src/itrontime.c (modified) * cpukit/itron/src/loc_cpu.c (added) * cpukit/itron/src/network.c (modified) * cpukit/itron/src/nget_nod.c (added) * cpukit/itron/src/nget_ver.c (added) * cpukit/itron/src/nrea_dat.c (added) * cpukit/itron/src/nwri_dat.c (added) * cpukit/itron/src/pacp_por.c (added) * cpukit/itron/src/pcal_por.c (added) * cpukit/itron/src/pget_blf.c (added) * cpukit/itron/src/pget_blk.c (added) * cpukit/itron/src/pol_flg.c (added) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/ref_alm.c (added) * cpukit/itron/src/ref_cfg.c (added) * cpukit/itron/src/ref_cyc.c (added) * cpukit/itron/src/ref_flg.c (added) * cpukit/itron/src/ref_iXX.c (added) * cpukit/itron/src/ref_mpf.c (added) * cpukit/itron/src/ref_mpl.c (added) * cpukit/itron/src/ref_por.c (added) * cpukit/itron/src/ref_sys.c (added) * cpukit/itron/src/rel_blf.c (added) * cpukit/itron/src/rel_blk.c (added) * cpukit/itron/src/ret_int.c (added) * cpukit/itron/src/ret_tmr.c (added) * cpukit/itron/src/ret_wup.c (added) * cpukit/itron/src/rpl_rdv.c (added) * cpukit/itron/src/set_flg.c (added) * cpukit/itron/src/set_tim.c (added) * cpukit/itron/src/sysmgmt.c (modified) * cpukit/itron/src/tacp_por.c (added) * cpukit/itron/src/task.c (modified) * cpukit/itron/src/tcal_por.c (added) * cpukit/itron/src/tget_blf.c (added) * cpukit/itron/src/tget_blk.c (added) * cpukit/itron/src/twai_flg.c (added) * cpukit/itron/src/unl_cpu.c (added) * cpukit/itron/src/vmempool.c (modified) * cpukit/itron/src/wai_flg.c (added) * cpukit/posix/Makefile.am (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadinitthreads.c (added) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/src/io.c (modified) 2007-04-17 Joel Sherrill * ... Thu, 15 Apr 2004 04:00:25 GMT Ralf Corsepius [7ded4e37] * cpukit/itron/include/itron.h (modified) * cpukit/itron/include/itronsys/eventflags.h (modified) * cpukit/itron/include/itronsys/fmempool.h (modified) * cpukit/itron/include/itronsys/intr.h (modified) * cpukit/itron/include/itronsys/mbox.h (modified) * cpukit/itron/include/itronsys/msgbuffer.h (modified) * cpukit/itron/include/itronsys/network.h (modified) * cpukit/itron/include/itronsys/port.h (modified) * cpukit/itron/include/itronsys/semaphore.h (modified) * cpukit/itron/include/itronsys/status.h (modified) * cpukit/itron/include/itronsys/sysmgmt.h (modified) * cpukit/itron/include/itronsys/task.h (modified) * cpukit/itron/include/itronsys/time.h (modified) * cpukit/itron/include/itronsys/types.h (modified) * cpukit/itron/include/itronsys/vmempool.h (modified) * cpukit/itron/include/rtems/itron/eventflags.h (modified) * cpukit/itron/include/rtems/itron/fmempool.h (modified) * cpukit/itron/include/rtems/itron/intr.h (modified) * cpukit/itron/include/rtems/itron/itronapi.h (modified) * cpukit/itron/include/rtems/itron/mbox.h (modified) * cpukit/itron/include/rtems/itron/msgbuffer.h (modified) * cpukit/itron/include/rtems/itron/network.h (modified) * cpukit/itron/include/rtems/itron/object.h (modified) * cpukit/itron/include/rtems/itron/port.h (modified) * cpukit/itron/include/rtems/itron/semaphore.h (modified) * cpukit/itron/include/rtems/itron/sysmgmt.h (modified) * cpukit/itron/include/rtems/itron/task.h (modified) * cpukit/itron/include/rtems/itron/time.h (modified) * cpukit/itron/include/rtems/itron/vmempool.h (modified) * cpukit/itron/src/can_wup.c (modified) * cpukit/itron/src/chg_pri.c (modified) * cpukit/itron/src/cre_mbf.c (modified) * cpukit/itron/src/cre_mbx.c (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/del_mbf.c (modified) * cpukit/itron/src/del_sem.c (modified) * cpukit/itron/src/del_tsk.c (modified) * cpukit/itron/src/dis_dsp.c (modified) * cpukit/itron/src/ena_dsp.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/exd_tsk.c (modified) * cpukit/itron/src/ext_tsk.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/get_tid.c (modified) * cpukit/itron/src/itronintr.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/itrontime.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/network.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/preq_sem.c (modified) * cpukit/itron/src/psnd_mbf.c (modified) * cpukit/itron/src/rcv_mbx.c (modified) * cpukit/itron/src/ref_mbf.c (modified) * cpukit/itron/src/ref_mbx.c (modified) * cpukit/itron/src/ref_sem.c (modified) * cpukit/itron/src/ref_tsk.c (modified) * cpukit/itron/src/rel_wai.c (modified) * cpukit/itron/src/rot_rdq.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/snd_mbf.c (modified) * cpukit/itron/src/snd_mbx.c (modified) * cpukit/itron/src/sta_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) * cpukit/itron/src/sysmgmt.c (modified) * cpukit/itron/src/task.c (modified) * cpukit/itron/src/ter_tsk.c (modified) * cpukit/itron/src/trcv_mbf.c (modified) * cpukit/itron/src/trcv_mbx.c (modified) * cpukit/itron/src/tslp_tsk.c (modified) * cpukit/itron/src/twai_sem.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/itron/src/wai_sem.c (modified) * cpukit/itron/src/wup_tsk.c (modified) Remove unnecessary white spaces. Thu, 01 Apr 2004 10:14:23 GMT Ralf Corsepius [ebbe119e] * cpukit/ChangeLog (modified) * cpukit/itron/src/can_wup.c (modified) * cpukit/itron/src/chg_pri.c (modified) * cpukit/itron/src/cre_mbf.c (modified) * cpukit/itron/src/cre_mbx.c (modified) * cpukit/itron/src/cre_sem.c (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/del_mbf.c (modified) * cpukit/itron/src/del_mbx.c (modified) * cpukit/itron/src/del_sem.c (modified) * cpukit/itron/src/del_tsk.c (modified) * cpukit/itron/src/dis_dsp.c (modified) * cpukit/itron/src/ena_dsp.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/exd_tsk.c (modified) * cpukit/itron/src/ext_tsk.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/get_tid.c (modified) * cpukit/itron/src/itronintr.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/itrontime.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/mboxtranslatereturncode.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/msgbuffertranslatereturncode.c (modified) * cpukit/itron/src/network.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/prcv_mbf.c (modified) * cpukit/itron/src/prcv_mbx.c (modified) * cpukit/itron/src/preq_sem.c (modified) * cpukit/itron/src/psnd_mbf.c (modified) * cpukit/itron/src/rcv_mbf.c (modified) * cpukit/itron/src/rcv_mbx.c (modified) * cpukit/itron/src/ref_mbf.c (modified) * cpukit/itron/src/ref_mbx.c (modified) * cpukit/itron/src/ref_sem.c (modified) * cpukit/itron/src/ref_tsk.c (modified) * cpukit/itron/src/rel_wai.c (modified) * cpukit/itron/src/rot_rdq.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/sig_sem.c (modified) * cpukit/itron/src/slp_tsk.c (modified) * cpukit/itron/src/snd_mbf.c (modified) * cpukit/itron/src/snd_mbx.c (modified) * cpukit/itron/src/sta_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) * cpukit/itron/src/sysmgmt.c (modified) * cpukit/itron/src/task.c (modified) * cpukit/itron/src/ter_tsk.c (modified) * cpukit/itron/src/trcv_mbf.c (modified) * cpukit/itron/src/trcv_mbx.c (modified) * cpukit/itron/src/tslp_tsk.c (modified) * cpukit/itron/src/tsnd_mbf.c (modified) * cpukit/itron/src/twai_sem.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/itron/src/wai_sem.c (modified) * cpukit/itron/src/wup_tsk.c (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/src/itronapi.c (modified) 2004-04-01 Ralf Corsepius * ... Thu, 04 Sep 2003 18:54:02 GMT Joel Sherrill [e49f9e6b] * cpukit/itron/ChangeLog (modified) * cpukit/itron/include/itron.h (modified) * cpukit/itron/include/itronsys/eventflags.h (modified) * cpukit/itron/include/itronsys/fmempool.h (modified) * cpukit/itron/include/itronsys/intr.h (modified) * cpukit/itron/include/itronsys/mbox.h (modified) * cpukit/itron/include/itronsys/msgbuffer.h (modified) * cpukit/itron/include/itronsys/network.h (modified) * cpukit/itron/include/itronsys/port.h (modified) * cpukit/itron/include/itronsys/semaphore.h (modified) * cpukit/itron/include/itronsys/status.h (modified) * cpukit/itron/include/itronsys/sysmgmt.h (modified) * cpukit/itron/include/itronsys/task.h (modified) * cpukit/itron/include/itronsys/time.h (modified) * cpukit/itron/include/itronsys/types.h (modified) * cpukit/itron/include/itronsys/vmempool.h (modified) * cpukit/itron/include/rtems/itron/config.h (modified) * cpukit/itron/include/rtems/itron/eventflags.h (modified) * cpukit/itron/include/rtems/itron/fmempool.h (modified) * cpukit/itron/include/rtems/itron/intr.h (modified) * cpukit/itron/include/rtems/itron/itronapi.h (modified) * cpukit/itron/include/rtems/itron/mbox.h (modified) * cpukit/itron/include/rtems/itron/msgbuffer.h (modified) * cpukit/itron/include/rtems/itron/network.h (modified) * cpukit/itron/include/rtems/itron/object.h (modified) * cpukit/itron/include/rtems/itron/port.h (modified) * cpukit/itron/include/rtems/itron/semaphore.h (modified) * cpukit/itron/include/rtems/itron/sysmgmt.h (modified) * cpukit/itron/include/rtems/itron/task.h (modified) * cpukit/itron/include/rtems/itron/time.h (modified) * cpukit/itron/include/rtems/itron/vmempool.h (modified) * cpukit/itron/inline/rtems/itron/eventflags.inl (modified) * cpukit/itron/inline/rtems/itron/fmempool.inl (modified) * cpukit/itron/inline/rtems/itron/intr.inl (modified) * cpukit/itron/inline/rtems/itron/mbox.inl (modified) * cpukit/itron/inline/rtems/itron/msgbuffer.inl (modified) * cpukit/itron/inline/rtems/itron/network.inl (modified) * cpukit/itron/inline/rtems/itron/port.inl (modified) * cpukit/itron/inline/rtems/itron/semaphore.inl (modified) * cpukit/itron/inline/rtems/itron/sysmgmt.inl (modified) * cpukit/itron/inline/rtems/itron/task.inl (modified) * cpukit/itron/inline/rtems/itron/time.inl (modified) * cpukit/itron/inline/rtems/itron/vmempool.inl (modified) * cpukit/itron/macros/rtems/itron/eventflags.inl (modified) * cpukit/itron/macros/rtems/itron/fmempool.inl (modified) * cpukit/itron/macros/rtems/itron/intr.inl (modified) * cpukit/itron/macros/rtems/itron/mbox.inl (modified) * cpukit/itron/macros/rtems/itron/msgbuffer.inl (modified) * cpukit/itron/macros/rtems/itron/network.inl (modified) * cpukit/itron/macros/rtems/itron/port.inl (modified) * cpukit/itron/macros/rtems/itron/semaphore.inl (modified) * cpukit/itron/macros/rtems/itron/sysmgmt.inl (modified) * cpukit/itron/macros/rtems/itron/task.inl (modified) * cpukit/itron/macros/rtems/itron/time.inl (modified) * cpukit/itron/macros/rtems/itron/vmempool.inl (modified) * cpukit/itron/src/can_wup.c (modified) * cpukit/itron/src/chg_pri.c (modified) * cpukit/itron/src/cre_mbf.c (modified) * cpukit/itron/src/cre_mbx.c (modified) * cpukit/itron/src/cre_sem.c (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/del_mbf.c (modified) * cpukit/itron/src/del_mbx.c (modified) * cpukit/itron/src/del_sem.c (modified) * cpukit/itron/src/del_tsk.c (modified) * cpukit/itron/src/dis_dsp.c (modified) * cpukit/itron/src/ena_dsp.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/exd_tsk.c (modified) * cpukit/itron/src/ext_tsk.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/get_tid.c (modified) * cpukit/itron/src/itronintr.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/itrontime.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/mboxtranslatereturncode.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/msgbuffertranslatereturncode.c (modified) * cpukit/itron/src/network.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/prcv_mbf.c (modified) * cpukit/itron/src/prcv_mbx.c (modified) * cpukit/itron/src/preq_sem.c (modified) * cpukit/itron/src/psnd_mbf.c (modified) * cpukit/itron/src/rcv_mbf.c (modified) * cpukit/itron/src/rcv_mbx.c (modified) * cpukit/itron/src/ref_mbf.c (modified) * cpukit/itron/src/ref_mbx.c (modified) * cpukit/itron/src/ref_sem.c (modified) * cpukit/itron/src/ref_tsk.c (modified) * cpukit/itron/src/rel_wai.c (modified) * cpukit/itron/src/rot_rdq.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/sig_sem.c (modified) * cpukit/itron/src/slp_tsk.c (modified) * cpukit/itron/src/snd_mbf.c (modified) * cpukit/itron/src/snd_mbx.c (modified) * cpukit/itron/src/sta_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) * cpukit/itron/src/sysmgmt.c (modified) * cpukit/itron/src/task.c (modified) * cpukit/itron/src/ter_tsk.c (modified) * cpukit/itron/src/trcv_mbf.c (modified) * cpukit/itron/src/trcv_mbx.c (modified) * cpukit/itron/src/tslp_tsk.c (modified) * cpukit/itron/src/tsnd_mbf.c (modified) * cpukit/itron/src/twai_sem.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/itron/src/wai_sem.c (modified) * cpukit/itron/src/wup_tsk.c (modified) 2003-09-04 Joel Sherrill * ... Wed, 24 Jan 2001 14:17:28 GMT Joel Sherrill [f42b726] * c/src/exec/itron/ChangeLog (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/itron/src/.cvsignore (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/itron/src/can_wup.c (modified) * c/src/exec/itron/src/chg_pri.c (modified) * c/src/exec/itron/src/cre_mbf.c (modified) * c/src/exec/itron/src/cre_mbx.c (modified) * c/src/exec/itron/src/cre_sem.c (modified) * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/itron/src/del_mbf.c (modified) * c/src/exec/itron/src/del_mbx.c (modified) * c/src/exec/itron/src/del_sem.c (modified) * c/src/exec/itron/src/del_tsk.c (modified) * c/src/exec/itron/src/dis_dsp.c (modified) * c/src/exec/itron/src/ena_dsp.c (modified) * c/src/exec/itron/src/eventflags.c (modified) * c/src/exec/itron/src/exd_tsk.c (modified) * c/src/exec/itron/src/ext_tsk.c (modified) * c/src/exec/itron/src/fmempool.c (modified) * c/src/exec/itron/src/frsm_tsk.c (modified) * c/src/exec/itron/src/get_tid.c (modified) * c/src/exec/itron/src/itronintr.c (modified) * c/src/exec/itron/src/itronsem.c (modified) * c/src/exec/itron/src/itrontime.c (modified) * c/src/exec/itron/src/mbox.c (modified) * c/src/exec/itron/src/mboxtranslatereturncode.c (modified) * c/src/exec/itron/src/msgbuffer.c (modified) * c/src/exec/itron/src/msgbuffertranslatereturncode.c (modified) * c/src/exec/itron/src/network.c (modified) * c/src/exec/itron/src/port.c (modified) * c/src/exec/itron/src/prcv_mbf.c (modified) * c/src/exec/itron/src/prcv_mbx.c (modified) * c/src/exec/itron/src/preq_sem.c (modified) * c/src/exec/itron/src/psnd_mbf.c (modified) * c/src/exec/itron/src/rcv_mbf.c (modified) * c/src/exec/itron/src/rcv_mbx.c (modified) * c/src/exec/itron/src/ref_mbf.c (modified) * c/src/exec/itron/src/ref_mbx.c (modified) * c/src/exec/itron/src/ref_sem.c (modified) * c/src/exec/itron/src/ref_tsk.c (modified) * c/src/exec/itron/src/rel_wai.c (modified) * c/src/exec/itron/src/rot_rdq.c (modified) * c/src/exec/itron/src/rsm_tsk.c (modified) * c/src/exec/itron/src/sig_sem.c (modified) * c/src/exec/itron/src/slp_tsk.c (modified) * c/src/exec/itron/src/snd_mbf.c (modified) * c/src/exec/itron/src/snd_mbx.c (modified) * c/src/exec/itron/src/sta_tsk.c (modified) * c/src/exec/itron/src/sus_tsk.c (modified) * c/src/exec/itron/src/sysmgmt.c (modified) * c/src/exec/itron/src/task.c (modified) * c/src/exec/itron/src/ter_tsk.c (modified) * c/src/exec/itron/src/trcv_mbf.c (modified) * c/src/exec/itron/src/trcv_mbx.c (modified) * c/src/exec/itron/src/tslp_tsk.c (modified) * c/src/exec/itron/src/tsnd_mbf.c (modified) * c/src/exec/itron/src/twai_sem.c (modified) * c/src/exec/itron/src/vmempool.c (modified) * c/src/exec/itron/src/wai_sem.c (modified) * c/src/exec/itron/src/wup_tsk.c (modified) * c/src/exec/libcsupport/src/utsname.c (modified) * c/src/exec/posix/ChangeLog (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/posix/src/.cvsignore (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/posix/src/adasupp.c (modified) * c/src/exec/posix/src/aio.c (modified) * c/src/exec/posix/src/alarm.c (modified) * c/src/exec/posix/src/cancel.c (modified) * c/src/exec/posix/src/cancelrun.c (modified) * c/src/exec/posix/src/cleanuppop.c (modified) * c/src/exec/posix/src/cleanuppush.c (modified) * c/src/exec/posix/src/clockgetcpuclockid.c (modified) * c/src/exec/posix/src/clockgetenableattr.c (modified) * c/src/exec/posix/src/clockgetres.c (modified) * c/src/exec/posix/src/clockgettime.c (modified) * c/src/exec/posix/src/clocksetenableattr.c (modified) * c/src/exec/posix/src/clocksettime.c (modified) * c/src/exec/posix/src/cond.c (modified) * c/src/exec/posix/src/condattrdestroy.c (modified) * c/src/exec/posix/src/condattrgetpshared.c (modified) * c/src/exec/posix/src/condattrinit.c (modified) * c/src/exec/posix/src/condattrsetpshared.c (modified) * c/src/exec/posix/src/condbroadcast.c (modified) * c/src/exec/posix/src/conddefaultattributes.c (modified) * c/src/exec/posix/src/conddestroy.c (modified) * c/src/exec/posix/src/condinit.c (modified) * c/src/exec/posix/src/condmp.c (modified) * c/src/exec/posix/src/condsignal.c (modified) * c/src/exec/posix/src/condsignalsupp.c (modified) * c/src/exec/posix/src/condtimedwait.c (modified) * c/src/exec/posix/src/condwait.c (modified) * c/src/exec/posix/src/condwaitsupp.c (modified) * c/src/exec/posix/src/devctl.c (modified) * c/src/exec/posix/src/execl.c (modified) * c/src/exec/posix/src/execle.c (modified) * c/src/exec/posix/src/execlp.c (modified) * c/src/exec/posix/src/execv.c (modified) * c/src/exec/posix/src/execve.c (modified) * c/src/exec/posix/src/execvp.c (modified) * c/src/exec/posix/src/fork.c (modified) * c/src/exec/posix/src/getegid.c (modified) * c/src/exec/posix/src/geteuid.c (modified) * c/src/exec/posix/src/getgid.c (modified) * c/src/exec/posix/src/getgroups.c (modified) * c/src/exec/posix/src/getlogin.c (modified) * c/src/exec/posix/src/getpgrp.c (modified) * c/src/exec/posix/src/getpid.c (modified) * c/src/exec/posix/src/getppid.c (modified) * c/src/exec/posix/src/getuid.c (modified) * c/src/exec/posix/src/intr.c (modified) * c/src/exec/posix/src/key.c (modified) * c/src/exec/posix/src/keycreate.c (modified) * c/src/exec/posix/src/keydelete.c (modified) * c/src/exec/posix/src/keygetspecific.c (modified) * c/src/exec/posix/src/keyrundestructors.c (modified) * c/src/exec/posix/src/keysetspecific.c (modified) * c/src/exec/posix/src/kill.c (modified) * c/src/exec/posix/src/killinfo.c (modified) * c/src/exec/posix/src/mqueue.c (modified) * c/src/exec/posix/src/mqueueclose.c (modified) * c/src/exec/posix/src/mqueuecreatesupp.c (modified) * c/src/exec/posix/src/mqueuedeletesupp.c (modified) * c/src/exec/posix/src/mqueuegetattr.c (modified) * c/src/exec/posix/src/mqueuenametoid.c (modified) * c/src/exec/posix/src/mqueuenotify.c (modified) * c/src/exec/posix/src/mqueueopen.c (modified) * c/src/exec/posix/src/mqueuereceive.c (modified) * c/src/exec/posix/src/mqueuerecvsupp.c (modified) * c/src/exec/posix/src/mqueuesend.c (modified) * c/src/exec/posix/src/mqueuesendsupp.c (modified) * c/src/exec/posix/src/mqueuesetattr.c (modified) * c/src/exec/posix/src/mqueuetimedreceive.c (modified) * c/src/exec/posix/src/mqueuetimedsend.c (modified) * c/src/exec/posix/src/mqueuetranslatereturncode.c (modified) * c/src/exec/posix/src/mqueueunlink.c (modified) * c/src/exec/posix/src/mutex.c (modified) * c/src/exec/posix/src/mutexattrdestroy.c (modified) * c/src/exec/posix/src/mutexattrgetprioceiling.c (modified) * c/src/exec/posix/src/mutexattrgetprotocol.c (modified) * c/src/exec/posix/src/mutexattrgetpshared.c (modified) * c/src/exec/posix/src/mutexattrinit.c (modified) * c/src/exec/posix/src/mutexattrsetprioceiling.c (modified) * c/src/exec/posix/src/mutexattrsetprotocol.c (modified) * c/src/exec/posix/src/mutexattrsetpshared.c (modified) * c/src/exec/posix/src/mutexdefaultattributes.c (modified) * c/src/exec/posix/src/mutexdestroy.c (modified) * c/src/exec/posix/src/mutexfromcorestatus.c (modified) * c/src/exec/posix/src/mutexgetprioceiling.c (modified) * c/src/exec/posix/src/mutexinit.c (modified) * c/src/exec/posix/src/mutexlock.c (modified) * c/src/exec/posix/src/mutexlocksupp.c (modified) * c/src/exec/posix/src/mutexmp.c (modified) * c/src/exec/posix/src/mutexsetprioceiling.c (modified) * c/src/exec/posix/src/mutextimedlock.c (modified) * c/src/exec/posix/src/mutextrylock.c (modified) * c/src/exec/posix/src/mutexunlock.c (modified) * c/src/exec/posix/src/nanosleep.c (modified) * c/src/exec/posix/src/pause.c (modified) * c/src/exec/posix/src/posixintervaltotimespec.c (modified) * c/src/exec/posix/src/posixtimespecsubtract.c (modified) * c/src/exec/posix/src/posixtimespectointerval.c (modified) * c/src/exec/posix/src/psignal.c (modified) * c/src/exec/posix/src/psignalchecksignal.c (modified) * c/src/exec/posix/src/psignalclearprocesssignals.c (modified) * c/src/exec/posix/src/psignalclearsignals.c (modified) * c/src/exec/posix/src/psignalsetprocesssignals.c (modified) * c/src/exec/posix/src/psignalunblockthread.c (modified) * c/src/exec/posix/src/pthread.c (modified) * c/src/exec/posix/src/pthreadatfork.c (modified) * c/src/exec/posix/src/pthreadattrdestroy.c (modified) * c/src/exec/posix/src/pthreadattrgetdetachstate.c (modified) * c/src/exec/posix/src/pthreadattrgetinheritsched.c (modified) * c/src/exec/posix/src/pthreadattrgetschedparam.c (modified) * c/src/exec/posix/src/pthreadattrgetschedpolicy.c (modified) * c/src/exec/posix/src/pthreadattrgetscope.c (modified) * c/src/exec/posix/src/pthreadattrgetstackaddr.c (modified) * c/src/exec/posix/src/pthreadattrgetstacksize.c (modified) * c/src/exec/posix/src/pthreadattrinit.c (modified) * c/src/exec/posix/src/pthreadattrsetdetachstate.c (modified) * c/src/exec/posix/src/pthreadattrsetinheritsched.c (modified) * c/src/exec/posix/src/pthreadattrsetschedparam.c (modified) * c/src/exec/posix/src/pthreadattrsetschedpolicy.c (modified) * c/src/exec/posix/src/pthreadattrsetscope.c (modified) * c/src/exec/posix/src/pthreadattrsetstackaddr.c (modified) * c/src/exec/posix/src/pthreadattrsetstacksize.c (modified) * c/src/exec/posix/src/pthreadcreate.c (modified) * c/src/exec/posix/src/pthreaddetach.c (modified) * c/src/exec/posix/src/pthreadequal.c (modified) * c/src/exec/posix/src/pthreadexit.c (modified) * c/src/exec/posix/src/pthreadgetcpuclockid.c (modified) * c/src/exec/posix/src/pthreadgetcputime.c (modified) * c/src/exec/posix/src/pthreadgetschedparam.c (modified) * c/src/exec/posix/src/pthreadjoin.c (modified) * c/src/exec/posix/src/pthreadkill.c (modified) * c/src/exec/posix/src/pthreadonce.c (modified) * c/src/exec/posix/src/pthreadself.c (modified) * c/src/exec/posix/src/pthreadsetcputime.c (modified) * c/src/exec/posix/src/pthreadsetschedparam.c (modified) * c/src/exec/posix/src/pthreadsigmask.c (modified) * c/src/exec/posix/src/ptimer.c (modified) * c/src/exec/posix/src/ptimer1.c (modified) * c/src/exec/posix/src/sched.c (modified) * c/src/exec/posix/src/semaphore.c (modified) * c/src/exec/posix/src/semaphorecreatesupp.c (modified) * c/src/exec/posix/src/semaphoredeletesupp.c (modified) * c/src/exec/posix/src/semaphoremp.c (modified) * c/src/exec/posix/src/semaphorenametoid.c (modified) * c/src/exec/posix/src/semaphorewaitsupp.c (modified) * c/src/exec/posix/src/semclose.c (modified) * c/src/exec/posix/src/semdestroy.c (modified) * c/src/exec/posix/src/semgetvalue.c (modified) * c/src/exec/posix/src/seminit.c (modified) * c/src/exec/posix/src/semopen.c (modified) * c/src/exec/posix/src/sempost.c (modified) * c/src/exec/posix/src/semtimedwait.c (modified) * c/src/exec/posix/src/semtrywait.c (modified) * c/src/exec/posix/src/semunlink.c (modified) * c/src/exec/posix/src/semwait.c (modified) * c/src/exec/posix/src/setcancelstate.c (modified) * c/src/exec/posix/src/setcanceltype.c (modified) * c/src/exec/posix/src/setpgid.c (modified) * c/src/exec/posix/src/setsid.c (modified) * c/src/exec/posix/src/sigaction.c (modified) * c/src/exec/posix/src/sigaddset.c (modified) * c/src/exec/posix/src/sigdelset.c (modified) * c/src/exec/posix/src/sigemptyset.c (modified) * c/src/exec/posix/src/sigfillset.c (modified) * c/src/exec/posix/src/sigismember.c (modified) * c/src/exec/posix/src/signal_2.c (modified) * c/src/exec/posix/src/sigpending.c (modified) * c/src/exec/posix/src/sigprocmask.c (modified) * c/src/exec/posix/src/sigqueue.c (modified) * c/src/exec/posix/src/sigsuspend.c (modified) * c/src/exec/posix/src/sigtimedwait.c (modified) * c/src/exec/posix/src/sigwait.c (modified) * c/src/exec/posix/src/sigwaitinfo.c (modified) * c/src/exec/posix/src/sleep.c (modified) * c/src/exec/posix/src/sysconf.c (modified) * c/src/exec/posix/src/testcancel.c (modified) * c/src/exec/posix/src/time.c (modified) * c/src/exec/posix/src/types.c (modified) * c/src/exec/posix/src/utsname.c (modified) * c/src/exec/posix/src/wait.c (modified) * c/src/exec/posix/src/waitpid.c (modified) * c/src/lib/libc/utsname.c (modified) * cpukit/itron/ChangeLog (modified) * cpukit/itron/src/.cvsignore (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/itron/src/can_wup.c (modified) * cpukit/itron/src/chg_pri.c (modified) * cpukit/itron/src/cre_mbf.c (modified) * cpukit/itron/src/cre_mbx.c (modified) * cpukit/itron/src/cre_sem.c (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/del_mbf.c (modified) * cpukit/itron/src/del_mbx.c (modified) * cpukit/itron/src/del_sem.c (modified) * cpukit/itron/src/del_tsk.c (modified) * cpukit/itron/src/dis_dsp.c (modified) * cpukit/itron/src/ena_dsp.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/exd_tsk.c (modified) * cpukit/itron/src/ext_tsk.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/get_tid.c (modified) * cpukit/itron/src/itronintr.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/itrontime.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/mboxtranslatereturncode.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/msgbuffertranslatereturncode.c (modified) * cpukit/itron/src/network.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/prcv_mbf.c (modified) * cpukit/itron/src/prcv_mbx.c (modified) * cpukit/itron/src/preq_sem.c (modified) * cpukit/itron/src/psnd_mbf.c (modified) * cpukit/itron/src/rcv_mbf.c (modified) * cpukit/itron/src/rcv_mbx.c (modified) * cpukit/itron/src/ref_mbf.c (modified) * cpukit/itron/src/ref_mbx.c (modified) * cpukit/itron/src/ref_sem.c (modified) * cpukit/itron/src/ref_tsk.c (modified) * cpukit/itron/src/rel_wai.c (modified) * cpukit/itron/src/rot_rdq.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/sig_sem.c (modified) * cpukit/itron/src/slp_tsk.c (modified) * cpukit/itron/src/snd_mbf.c (modified) * cpukit/itron/src/snd_mbx.c (modified) * cpukit/itron/src/sta_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) * cpukit/itron/src/sysmgmt.c (modified) * cpukit/itron/src/task.c (modified) * cpukit/itron/src/ter_tsk.c (modified) * cpukit/itron/src/trcv_mbf.c (modified) * cpukit/itron/src/trcv_mbx.c (modified) * cpukit/itron/src/tslp_tsk.c (modified) * cpukit/itron/src/tsnd_mbf.c (modified) * cpukit/itron/src/twai_sem.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/itron/src/wai_sem.c (modified) * cpukit/itron/src/wup_tsk.c (modified) * cpukit/libcsupport/src/utsname.c (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/src/.cvsignore (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/posix/src/adasupp.c (modified) * cpukit/posix/src/aio.c (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/cancelrun.c (modified) * cpukit/posix/src/cleanuppop.c (modified) * cpukit/posix/src/cleanuppush.c (modified) * cpukit/posix/src/clockgetcpuclockid.c (modified) * cpukit/posix/src/clockgetenableattr.c (modified) * cpukit/posix/src/clockgetres.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/clocksetenableattr.c (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/posix/src/cond.c (modified) * cpukit/posix/src/condattrdestroy.c (modified) * cpukit/posix/src/condattrgetpshared.c (modified) * cpukit/posix/src/condattrinit.c (modified) * cpukit/posix/src/condattrsetpshared.c (modified) * cpukit/posix/src/condbroadcast.c (modified) * cpukit/posix/src/conddefaultattributes.c (modified) * cpukit/posix/src/conddestroy.c (modified) * cpukit/posix/src/condinit.c (modified) * cpukit/posix/src/condmp.c (modified) * cpukit/posix/src/condsignal.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condtimedwait.c (modified) * cpukit/posix/src/condwait.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/devctl.c (modified) * cpukit/posix/src/execl.c (modified) * cpukit/posix/src/execle.c (modified) * cpukit/posix/src/execlp.c (modified) * cpukit/posix/src/execv.c (modified) * cpukit/posix/src/execve.c (modified) * cpukit/posix/src/execvp.c (modified) * cpukit/posix/src/fork.c (modified) * cpukit/posix/src/getegid.c (modified) * cpukit/posix/src/geteuid.c (modified) * cpukit/posix/src/getgid.c (modified) * cpukit/posix/src/getgroups.c (modified) * cpukit/posix/src/getlogin.c (modified) * cpukit/posix/src/getpgrp.c (modified) * cpukit/posix/src/getpid.c (modified) * cpukit/posix/src/getppid.c (modified) * cpukit/posix/src/getuid.c (modified) * cpukit/posix/src/intr.c (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keydelete.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keyrundestructors.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueueclose.c (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuegetattr.c (modified) * cpukit/posix/src/mqueuenametoid.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/mqueuereceive.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesend.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mqueuesetattr.c (modified) * cpukit/posix/src/mqueuetimedreceive.c (modified) * cpukit/posix/src/mqueuetimedsend.c (modified) * cpukit/posix/src/mqueuetranslatereturncode.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/mutex.c (modified) * cpukit/posix/src/mutexattrdestroy.c (modified) * cpukit/posix/src/mutexattrgetprioceiling.c (modified) * cpukit/posix/src/mutexattrgetprotocol.c (modified) * cpukit/posix/src/mutexattrgetpshared.c (modified) * cpukit/posix/src/mutexattrinit.c (modified) * cpukit/posix/src/mutexattrsetprioceiling.c (modified) * cpukit/posix/src/mutexattrsetprotocol.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/mutexdefaultattributes.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexfromcorestatus.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlock.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexmp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutextimedlock.c (modified) * cpukit/posix/src/mutextrylock.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/pause.c (modified) * cpukit/posix/src/posixintervaltotimespec.c (modified) * cpukit/posix/src/posixtimespecsubtract.c (modified) * cpukit/posix/src/posixtimespectointerval.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalchecksignal.c (modified) * cpukit/posix/src/psignalclearprocesssignals.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalsetprocesssignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadatfork.c (modified) * cpukit/posix/src/pthreadattrdestroy.c (modified) * cpukit/posix/src/pthreadattrgetdetachstate.c (modified) * cpukit/posix/src/pthreadattrgetinheritsched.c (modified) * cpukit/posix/src/pthreadattrgetschedparam.c (modified) * cpukit/posix/src/pthreadattrgetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrgetscope.c (modified) * cpukit/posix/src/pthreadattrgetstackaddr.c (modified) * cpukit/posix/src/pthreadattrgetstacksize.c (modified) * cpukit/posix/src/pthreadattrinit.c (modified) * cpukit/posix/src/pthreadattrsetdetachstate.c (modified) * cpukit/posix/src/pthreadattrsetinheritsched.c (modified) * cpukit/posix/src/pthreadattrsetschedparam.c (modified) * cpukit/posix/src/pthreadattrsetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrsetscope.c (modified) * cpukit/posix/src/pthreadattrsetstackaddr.c (modified) * cpukit/posix/src/pthreadattrsetstacksize.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetcpuclockid.c (modified) * cpukit/posix/src/pthreadgetcputime.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadonce.c (modified) * cpukit/posix/src/pthreadself.c (modified) * cpukit/posix/src/pthreadsetcputime.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/ptimer1.c (modified) * cpukit/posix/src/sched.c (modified) * cpukit/posix/src/semaphore.c (modified) * cpukit/posix/src/semaphorecreatesupp.c (modified) * cpukit/posix/src/semaphoredeletesupp.c (modified) * cpukit/posix/src/semaphoremp.c (modified) * cpukit/posix/src/semaphorenametoid.c (modified) * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/posix/src/semclose.c (modified) * cpukit/posix/src/semdestroy.c (modified) * cpukit/posix/src/semgetvalue.c (modified) * cpukit/posix/src/seminit.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semtimedwait.c (modified) * cpukit/posix/src/semtrywait.c (modified) * cpukit/posix/src/semunlink.c (modified) * cpukit/posix/src/semwait.c (modified) * cpukit/posix/src/setcancelstate.c (modified) * cpukit/posix/src/setcanceltype.c (modified) * cpukit/posix/src/setpgid.c (modified) * cpukit/posix/src/setsid.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigaddset.c (modified) * cpukit/posix/src/sigdelset.c (modified) * cpukit/posix/src/sigemptyset.c (modified) * cpukit/posix/src/sigfillset.c (modified) * cpukit/posix/src/sigismember.c (modified) * cpukit/posix/src/signal_2.c (modified) * cpukit/posix/src/sigpending.c (modified) * cpukit/posix/src/sigprocmask.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/sigsuspend.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/sigwait.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) * cpukit/posix/src/sleep.c (modified) * cpukit/posix/src/sysconf.c (modified) * cpukit/posix/src/testcancel.c (modified) * cpukit/posix/src/time.c (modified) * cpukit/posix/src/types.c (modified) * cpukit/posix/src/wait.c (modified) * cpukit/posix/src/waitpid.c (modified) 2001-01-24 Ralf Corsepius * ... Wed, 17 Nov 1999 16:47:58 GMT Jennifer Averett [9d9a3dd] * c/src/exec/itron/include/itron.h (modified) * c/src/exec/itron/include/itronsys/eventflags.h (modified) * c/src/exec/itron/include/itronsys/fmempool.h (modified) * c/src/exec/itron/include/itronsys/intr.h (modified) * c/src/exec/itron/include/itronsys/mbox.h (modified) * c/src/exec/itron/include/itronsys/msgbuffer.h (modified) * c/src/exec/itron/include/itronsys/network.h (modified) * c/src/exec/itron/include/itronsys/port.h (modified) * c/src/exec/itron/include/itronsys/semaphore.h (modified) * c/src/exec/itron/include/itronsys/status.h (modified) * c/src/exec/itron/include/itronsys/sysmgmt.h (modified) * c/src/exec/itron/include/itronsys/task.h (modified) * c/src/exec/itron/include/itronsys/time.h (modified) * c/src/exec/itron/include/itronsys/types.h (modified) * c/src/exec/itron/include/itronsys/vmempool.h (modified) * c/src/exec/itron/include/rtems/itron/config.h (modified) * c/src/exec/itron/include/rtems/itron/eventflags.h (modified) * c/src/exec/itron/include/rtems/itron/fmempool.h (modified) * c/src/exec/itron/include/rtems/itron/intr.h (modified) * c/src/exec/itron/include/rtems/itron/itronapi.h (modified) * c/src/exec/itron/include/rtems/itron/mbox.h (modified) * c/src/exec/itron/include/rtems/itron/msgbuffer.h (modified) * c/src/exec/itron/include/rtems/itron/network.h (modified) * c/src/exec/itron/include/rtems/itron/object.h (modified) * c/src/exec/itron/include/rtems/itron/port.h (modified) * c/src/exec/itron/include/rtems/itron/semaphore.h (modified) * c/src/exec/itron/include/rtems/itron/sysmgmt.h (modified) * c/src/exec/itron/include/rtems/itron/task.h (modified) * c/src/exec/itron/include/rtems/itron/time.h (modified) * c/src/exec/itron/include/rtems/itron/vmempool.h (modified) * c/src/exec/itron/inline/rtems/itron/eventflags.inl (modified) * c/src/exec/itron/inline/rtems/itron/fmempool.inl (modified) * c/src/exec/itron/inline/rtems/itron/intr.inl (modified) * c/src/exec/itron/inline/rtems/itron/mbox.inl (modified) * c/src/exec/itron/inline/rtems/itron/msgbuffer.inl (modified) * c/src/exec/itron/inline/rtems/itron/network.inl (modified) * c/src/exec/itron/inline/rtems/itron/port.inl (modified) * c/src/exec/itron/inline/rtems/itron/semaphore.inl (modified) * c/src/exec/itron/inline/rtems/itron/sysmgmt.inl (modified) * c/src/exec/itron/inline/rtems/itron/task.inl (modified) * c/src/exec/itron/inline/rtems/itron/time.inl (modified) * c/src/exec/itron/inline/rtems/itron/vmempool.inl (modified) * c/src/exec/itron/src/can_wup.c (modified) * c/src/exec/itron/src/chg_pri.c (modified) * c/src/exec/itron/src/cre_mbf.c (modified) * c/src/exec/itron/src/cre_mbx.c (modified) * c/src/exec/itron/src/cre_sem.c (modified) * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/itron/src/del_mbf.c (modified) * c/src/exec/itron/src/del_mbx.c (modified) * c/src/exec/itron/src/del_sem.c (modified) * c/src/exec/itron/src/del_tsk.c (modified) * c/src/exec/itron/src/dis_dsp.c (modified) * c/src/exec/itron/src/ena_dsp.c (modified) * c/src/exec/itron/src/eventflags.c (modified) * c/src/exec/itron/src/exd_tsk.c (modified) * c/src/exec/itron/src/ext_tsk.c (modified) * c/src/exec/itron/src/fmempool.c (modified) * c/src/exec/itron/src/frsm_tsk.c (modified) * c/src/exec/itron/src/get_tid.c (modified) * c/src/exec/itron/src/itronintr.c (modified) * c/src/exec/itron/src/itronsem.c (modified) * c/src/exec/itron/src/itrontime.c (modified) * c/src/exec/itron/src/mbox.c (modified) * c/src/exec/itron/src/mboxtranslatereturncode.c (modified) * c/src/exec/itron/src/msgbuffer.c (modified) * c/src/exec/itron/src/msgbuffertranslatereturncode.c (modified) * c/src/exec/itron/src/network.c (modified) * c/src/exec/itron/src/port.c (modified) * c/src/exec/itron/src/prcv_mbf.c (modified) * c/src/exec/itron/src/prcv_mbx.c (modified) * c/src/exec/itron/src/preq_sem.c (modified) * c/src/exec/itron/src/psnd_mbf.c (modified) * c/src/exec/itron/src/rcv_mbf.c (modified) * c/src/exec/itron/src/rcv_mbx.c (modified) * c/src/exec/itron/src/ref_mbf.c (modified) * c/src/exec/itron/src/ref_mbx.c (modified) * c/src/exec/itron/src/ref_sem.c (modified) * c/src/exec/itron/src/ref_tsk.c (modified) * c/src/exec/itron/src/rel_wai.c (modified) * c/src/exec/itron/src/rot_rdq.c (modified) * c/src/exec/itron/src/rsm_tsk.c (modified) * c/src/exec/itron/src/sig_sem.c (modified) * c/src/exec/itron/src/slp_tsk.c (modified) * c/src/exec/itron/src/snd_mbf.c (modified) * c/src/exec/itron/src/snd_mbx.c (modified) * c/src/exec/itron/src/sta_tsk.c (modified) * c/src/exec/itron/src/sus_tsk.c (modified) * c/src/exec/itron/src/sysmgmt.c (modified) * c/src/exec/itron/src/task.c (modified) * c/src/exec/itron/src/ter_tsk.c (modified) * c/src/exec/itron/src/trcv_mbf.c (modified) * c/src/exec/itron/src/trcv_mbx.c (modified) * c/src/exec/itron/src/tslp_tsk.c (modified) * c/src/exec/itron/src/tsnd_mbf.c (modified) * c/src/exec/itron/src/twai_sem.c (modified) * c/src/exec/itron/src/vmempool.c (modified) * c/src/exec/itron/src/wai_sem.c (modified) * c/src/exec/itron/src/wup_tsk.c (modified) * c/src/tests/itrontests/itronhello/init.c (modified) * c/src/tests/itrontests/itronhello/itronhello.doc (modified) * c/src/tests/itrontests/itronhello/system.h (modified) * c/src/tests/itrontests/itronmbf01/init.c (modified) * c/src/tests/itrontests/itronmbf01/itronmbf01.doc (modified) * c/src/tests/itrontests/itronmbf01/system.h (modified) * c/src/tests/itrontests/itronmbox01/init.c (modified) * c/src/tests/itrontests/itronmbox01/system.h (modified) * c/src/tests/itrontests/itronsem01/init.c (modified) * c/src/tests/itrontests/itronsem01/itronsem01.doc (modified) * c/src/tests/itrontests/itronsem01/system.h (modified) * c/src/tests/itrontests/itrontask01/init.c (modified) * c/src/tests/itrontests/itrontask01/itrontask01.doc (modified) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask01/task1.c (modified) * c/src/tests/itrontests/itrontask02/dormant.c (modified) * c/src/tests/itrontests/itrontask02/init.c (modified) * c/src/tests/itrontests/itrontask02/itrontask02.doc (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * c/src/tests/itrontests/itrontask03/init.c (modified) * c/src/tests/itrontests/itrontask03/itrontask03.doc (modified) * c/src/tests/itrontests/itrontask03/preempt.c (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * c/src/tests/itrontests/itrontask03/task1.c (modified) * c/src/tests/itrontests/itrontask03/task2.c (modified) * c/src/tests/itrontests/itrontask03/task3.c (modified) * c/src/tests/itrontests/itrontask04/init.c (modified) * c/src/tests/itrontests/itrontask04/itrontask04.doc (modified) * c/src/tests/itrontests/itrontask04/system.h (modified) * c/src/tests/itrontests/itrontask04/task1.c (modified) * c/src/tests/itrontests/itrontask04/task2.c (modified) * c/src/tests/itrontests/itrontask04/task3.c (modified) * c/src/tests/itrontests/itrontime01/init.c (modified) * c/src/tests/itrontests/itrontime01/system.h (modified) * cpukit/itron/include/itron.h (modified) * cpukit/itron/include/itronsys/eventflags.h (modified) * cpukit/itron/include/itronsys/fmempool.h (modified) * cpukit/itron/include/itronsys/intr.h (modified) * cpukit/itron/include/itronsys/mbox.h (modified) * cpukit/itron/include/itronsys/msgbuffer.h (modified) * cpukit/itron/include/itronsys/network.h (modified) * cpukit/itron/include/itronsys/port.h (modified) * cpukit/itron/include/itronsys/semaphore.h (modified) * cpukit/itron/include/itronsys/status.h (modified) * cpukit/itron/include/itronsys/sysmgmt.h (modified) * cpukit/itron/include/itronsys/task.h (modified) * cpukit/itron/include/itronsys/time.h (modified) * cpukit/itron/include/itronsys/types.h (modified) * cpukit/itron/include/itronsys/vmempool.h (modified) * cpukit/itron/include/rtems/itron/config.h (modified) * cpukit/itron/include/rtems/itron/eventflags.h (modified) * cpukit/itron/include/rtems/itron/fmempool.h (modified) * cpukit/itron/include/rtems/itron/intr.h (modified) * cpukit/itron/include/rtems/itron/itronapi.h (modified) * cpukit/itron/include/rtems/itron/mbox.h (modified) * cpukit/itron/include/rtems/itron/msgbuffer.h (modified) * cpukit/itron/include/rtems/itron/network.h (modified) * cpukit/itron/include/rtems/itron/object.h (modified) * cpukit/itron/include/rtems/itron/port.h (modified) * cpukit/itron/include/rtems/itron/semaphore.h (modified) * cpukit/itron/include/rtems/itron/sysmgmt.h (modified) * cpukit/itron/include/rtems/itron/task.h (modified) * cpukit/itron/include/rtems/itron/time.h (modified) * cpukit/itron/include/rtems/itron/vmempool.h (modified) * cpukit/itron/inline/rtems/itron/eventflags.inl (modified) * cpukit/itron/inline/rtems/itron/fmempool.inl (modified) * cpukit/itron/inline/rtems/itron/intr.inl (modified) * cpukit/itron/inline/rtems/itron/mbox.inl (modified) * cpukit/itron/inline/rtems/itron/msgbuffer.inl (modified) * cpukit/itron/inline/rtems/itron/network.inl (modified) * cpukit/itron/inline/rtems/itron/port.inl (modified) * cpukit/itron/inline/rtems/itron/semaphore.inl (modified) * cpukit/itron/inline/rtems/itron/sysmgmt.inl (modified) * cpukit/itron/inline/rtems/itron/task.inl (modified) * cpukit/itron/inline/rtems/itron/time.inl (modified) * cpukit/itron/inline/rtems/itron/vmempool.inl (modified) * cpukit/itron/src/can_wup.c (modified) * cpukit/itron/src/chg_pri.c (modified) * cpukit/itron/src/cre_mbf.c (modified) * cpukit/itron/src/cre_mbx.c (modified) * cpukit/itron/src/cre_sem.c (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/del_mbf.c (modified) * cpukit/itron/src/del_mbx.c (modified) * cpukit/itron/src/del_sem.c (modified) * cpukit/itron/src/del_tsk.c (modified) * cpukit/itron/src/dis_dsp.c (modified) * cpukit/itron/src/ena_dsp.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/exd_tsk.c (modified) * cpukit/itron/src/ext_tsk.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/get_tid.c (modified) * cpukit/itron/src/itronintr.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/itrontime.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/mboxtranslatereturncode.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/msgbuffertranslatereturncode.c (modified) * cpukit/itron/src/network.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/prcv_mbf.c (modified) * cpukit/itron/src/prcv_mbx.c (modified) * cpukit/itron/src/preq_sem.c (modified) * cpukit/itron/src/psnd_mbf.c (modified) * cpukit/itron/src/rcv_mbf.c (modified) * cpukit/itron/src/rcv_mbx.c (modified) * cpukit/itron/src/ref_mbf.c (modified) * cpukit/itron/src/ref_mbx.c (modified) * cpukit/itron/src/ref_sem.c (modified) * cpukit/itron/src/ref_tsk.c (modified) * cpukit/itron/src/rel_wai.c (modified) * cpukit/itron/src/rot_rdq.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/sig_sem.c (modified) * cpukit/itron/src/slp_tsk.c (modified) * cpukit/itron/src/snd_mbf.c (modified) * cpukit/itron/src/snd_mbx.c (modified) * cpukit/itron/src/sta_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) * cpukit/itron/src/sysmgmt.c (modified) * cpukit/itron/src/task.c (modified) * cpukit/itron/src/ter_tsk.c (modified) * cpukit/itron/src/trcv_mbf.c (modified) * cpukit/itron/src/trcv_mbx.c (modified) * cpukit/itron/src/tslp_tsk.c (modified) * cpukit/itron/src/tsnd_mbf.c (modified) * cpukit/itron/src/twai_sem.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/itron/src/wai_sem.c (modified) * cpukit/itron/src/wup_tsk.c (modified) * testsuites/itrontests/itronhello/init.c (modified) * testsuites/itrontests/itronhello/itronhello.doc (modified) * testsuites/itrontests/itronhello/system.h (modified) * testsuites/itrontests/itronmbf01/init.c (modified) * testsuites/itrontests/itronmbf01/itronmbf01.doc (modified) * testsuites/itrontests/itronmbf01/system.h (modified) * testsuites/itrontests/itronmbox01/init.c (modified) * testsuites/itrontests/itronmbox01/system.h (modified) * testsuites/itrontests/itronsem01/init.c (modified) * testsuites/itrontests/itronsem01/itronsem01.doc (modified) * testsuites/itrontests/itronsem01/system.h (modified) * testsuites/itrontests/itrontask01/init.c (modified) * testsuites/itrontests/itrontask01/itrontask01.doc (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask01/task1.c (modified) * testsuites/itrontests/itrontask02/dormant.c (modified) * testsuites/itrontests/itrontask02/init.c (modified) * testsuites/itrontests/itrontask02/itrontask02.doc (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/init.c (modified) * testsuites/itrontests/itrontask03/itrontask03.doc (modified) * testsuites/itrontests/itrontask03/preempt.c (modified) * testsuites/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask03/task1.c (modified) * testsuites/itrontests/itrontask03/task2.c (modified) * testsuites/itrontests/itrontask03/task3.c (modified) * testsuites/itrontests/itrontask04/init.c (modified) * testsuites/itrontests/itrontask04/itrontask04.doc (modified) * testsuites/itrontests/itrontask04/system.h (modified) * testsuites/itrontests/itrontask04/task1.c (modified) * testsuites/itrontests/itrontask04/task2.c (modified) * testsuites/itrontests/itrontask04/task3.c (modified) * testsuites/itrontests/itrontime01/init.c (modified) * testsuites/itrontests/itrontime01/system.h (modified) + Updated copyright information. Tue, 09 Nov 1999 22:07:23 GMT Joel Sherrill [352c9b2] * c/src/exec/Makefile.am (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/Makefile.am (added) * c/src/exec/itron/configure.in (added) * c/src/exec/itron/include/Makefile.am (added) * c/src/exec/itron/include/itron.h (added) * c/src/exec/itron/include/itronsys/Makefile.am (added) * c/src/exec/itron/include/itronsys/README (added) * c/src/exec/itron/include/itronsys/eventflags.h (added) * c/src/exec/itron/include/itronsys/fmempool.h (added) * c/src/exec/itron/include/itronsys/intr.h (added) * c/src/exec/itron/include/itronsys/mbox.h (added) * c/src/exec/itron/include/itronsys/msgbuffer.h (added) * c/src/exec/itron/include/itronsys/network.h (added) * c/src/exec/itron/include/itronsys/port.h (added) * c/src/exec/itron/include/itronsys/semaphore.h (added) * c/src/exec/itron/include/itronsys/status.h (added) * c/src/exec/itron/include/itronsys/sysmgmt.h (added) * c/src/exec/itron/include/itronsys/task.h (added) * c/src/exec/itron/include/itronsys/time.h (added) * c/src/exec/itron/include/itronsys/types.h (added) * c/src/exec/itron/include/itronsys/vmempool.h (added) * c/src/exec/itron/include/rtems/Makefile.am (added) * c/src/exec/itron/include/rtems/itron/Makefile.am (added) * c/src/exec/itron/include/rtems/itron/README (added) * c/src/exec/itron/include/rtems/itron/config.h (added) * c/src/exec/itron/include/rtems/itron/eventflags.h (added) * c/src/exec/itron/include/rtems/itron/fmempool.h (added) * c/src/exec/itron/include/rtems/itron/intr.h (added) * c/src/exec/itron/include/rtems/itron/itronapi.h (added) * c/src/exec/itron/include/rtems/itron/mbox.h (added) * c/src/exec/itron/include/rtems/itron/msgbuffer.h (added) * c/src/exec/itron/include/rtems/itron/network.h (added) * c/src/exec/itron/include/rtems/itron/object.h (added) * c/src/exec/itron/include/rtems/itron/port.h (added) * c/src/exec/itron/include/rtems/itron/semaphore.h (added) * c/src/exec/itron/include/rtems/itron/sysmgmt.h (added) * c/src/exec/itron/include/rtems/itron/task.h (added) * c/src/exec/itron/include/rtems/itron/time.h (added) * c/src/exec/itron/include/rtems/itron/vmempool.h (added) * c/src/exec/itron/inline/Makefile.am (added) * c/src/exec/itron/inline/rtems/Makefile.am (added) * c/src/exec/itron/inline/rtems/itron/Makefile.am (added) * c/src/exec/itron/inline/rtems/itron/eventflags.inl (added) * c/src/exec/itron/inline/rtems/itron/fmempool.inl (added) * c/src/exec/itron/inline/rtems/itron/intr.inl (added) * c/src/exec/itron/inline/rtems/itron/mbox.inl (added) * c/src/exec/itron/inline/rtems/itron/msgbuffer.inl (added) * c/src/exec/itron/inline/rtems/itron/network.inl (added) * c/src/exec/itron/inline/rtems/itron/port.inl (added) * c/src/exec/itron/inline/rtems/itron/semaphore.inl (added) * c/src/exec/itron/inline/rtems/itron/sysmgmt.inl (added) * c/src/exec/itron/inline/rtems/itron/task.inl (added) * c/src/exec/itron/inline/rtems/itron/time.inl (added) * c/src/exec/itron/inline/rtems/itron/vmempool.inl (added) * c/src/exec/itron/src/Makefile.in (added) * c/src/exec/itron/src/can_wup.c (added) * c/src/exec/itron/src/chg_pri.c (added) * c/src/exec/itron/src/cre_tsk.c (added) * c/src/exec/itron/src/del_tsk.c (added) * c/src/exec/itron/src/dis_dsp.c (added) * c/src/exec/itron/src/ena_dsp.c (added) * c/src/exec/itron/src/eventflags.c (added) * c/src/exec/itron/src/exd_tsk.c (added) * c/src/exec/itron/src/ext_tsk.c (added) * c/src/exec/itron/src/fmempool.c (added) * c/src/exec/itron/src/frsm_tsk.c (added) * c/src/exec/itron/src/get_tid.c (added) * c/src/exec/itron/src/itronintr.c (added) * c/src/exec/itron/src/itronsem.c (added) * c/src/exec/itron/src/itrontime.c (added) * c/src/exec/itron/src/mbox.c (added) * c/src/exec/itron/src/msgbuffer.c (added) * c/src/exec/itron/src/network.c (added) * c/src/exec/itron/src/port.c (added) * c/src/exec/itron/src/ref_tsk.c (added) * c/src/exec/itron/src/rel_wai.c (added) * c/src/exec/itron/src/rot_rdq.c (added) * c/src/exec/itron/src/rsm_tsk.c (added) * c/src/exec/itron/src/slp_tsk.c (added) * c/src/exec/itron/src/sta_tsk.c (added) * c/src/exec/itron/src/sus_tsk.c (added) * c/src/exec/itron/src/sysmgmt.c (added) * c/src/exec/itron/src/task.c (added) * c/src/exec/itron/src/ter_tsk.c (added) * c/src/exec/itron/src/tslp_tsk.c (added) * c/src/exec/itron/src/vmempool.c (added) * c/src/exec/itron/src/wup_tsk.c (added) * c/src/exec/posix/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/itronapi.c (added) * c/src/exec/score/cpu/configure.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/score/interr.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/wrapup/Makefile.am (modified) * c/src/exec/wrapup/itron/Makefile.in (added) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/Makefile.am (added) * c/src/tests/itrontests/README (added) * c/src/tests/itrontests/configure.in (added) * c/src/tests/itrontests/itronhello/init.c (added) * c/src/tests/itrontests/itronhello/system.h (added) * c/src/tests/itrontests/itronmbf01/init.c (added) * c/src/tests/itrontests/itronmbf01/system.h (added) * c/src/tests/itrontests/itronsem01/init.c (added) * c/src/tests/itrontests/itronsem01/system.h (added) * c/src/tests/itrontests/itrontask01/init.c (added) * c/src/tests/itrontests/itrontask01/system.h (added) * c/src/tests/samples/configure.in (modified) * c/src/tests/tmitrontests/Makefile.am (added) * c/src/tests/tmitrontests/README (added) * c/src/tests/tmitrontests/configure.in (added) * c/src/tests/tmitrontests/include/Makefile.am (added) * c/src/tests/tmitrontests/include/timesys.h (added) * c/src/tests/tmitrontests/tmitronsem01/Makefile.in (added) * c/src/tests/tmitrontests/tmitronsem01/init.c (added) * c/src/tests/tmitrontests/tmitronsem01/system.h (added) * c/src/tests/tmitrontests/tmitronsem01/tmitronsem01.doc (added) * cpukit/Makefile.am (modified) * cpukit/itron/Makefile.am (added) * cpukit/itron/include/Makefile.am (added) * cpukit/itron/include/itron.h (added) * cpukit/itron/include/itronsys/README (added) * cpukit/itron/include/itronsys/eventflags.h (added) * cpukit/itron/include/itronsys/fmempool.h (added) * cpukit/itron/include/itronsys/intr.h (added) * cpukit/itron/include/itronsys/mbox.h (added) * cpukit/itron/include/itronsys/msgbuffer.h (added) * cpukit/itron/include/itronsys/network.h (added) * cpukit/itron/include/itronsys/port.h (added) * cpukit/itron/include/itronsys/semaphore.h (added) * cpukit/itron/include/itronsys/status.h (added) * cpukit/itron/include/itronsys/sysmgmt.h (added) * cpukit/itron/include/itronsys/task.h (added) * cpukit/itron/include/itronsys/time.h (added) * cpukit/itron/include/itronsys/types.h (added) * cpukit/itron/include/itronsys/vmempool.h (added) * cpukit/itron/include/rtems/itron/README (added) * cpukit/itron/include/rtems/itron/config.h (added) * cpukit/itron/include/rtems/itron/eventflags.h (added) * cpukit/itron/include/rtems/itron/fmempool.h (added) * cpukit/itron/include/rtems/itron/intr.h (added) * cpukit/itron/include/rtems/itron/itronapi.h (added) * cpukit/itron/include/rtems/itron/mbox.h (added) * cpukit/itron/include/rtems/itron/msgbuffer.h (added) * cpukit/itron/include/rtems/itron/network.h (added) * cpukit/itron/include/rtems/itron/object.h (added) * cpukit/itron/include/rtems/itron/port.h (added) * cpukit/itron/include/rtems/itron/semaphore.h (added) * cpukit/itron/include/rtems/itron/sysmgmt.h (added) * cpukit/itron/include/rtems/itron/task.h (added) * cpukit/itron/include/rtems/itron/time.h (added) * cpukit/itron/include/rtems/itron/vmempool.h (added) * cpukit/itron/inline/Makefile.am (added) * cpukit/itron/inline/rtems/itron/eventflags.inl (added) * cpukit/itron/inline/rtems/itron/fmempool.inl (added) * cpukit/itron/inline/rtems/itron/intr.inl (added) * cpukit/itron/inline/rtems/itron/mbox.inl (added) * cpukit/itron/inline/rtems/itron/msgbuffer.inl (added) * cpukit/itron/inline/rtems/itron/network.inl (added) * cpukit/itron/inline/rtems/itron/port.inl (added) * cpukit/itron/inline/rtems/itron/semaphore.inl (added) * cpukit/itron/inline/rtems/itron/sysmgmt.inl (added) * cpukit/itron/inline/rtems/itron/task.inl (added) * cpukit/itron/inline/rtems/itron/time.inl (added) * cpukit/itron/inline/rtems/itron/vmempool.inl (added) * cpukit/itron/src/can_wup.c (added) * cpukit/itron/src/chg_pri.c (added) * cpukit/itron/src/cre_tsk.c (added) * cpukit/itron/src/del_tsk.c (added) * cpukit/itron/src/dis_dsp.c (added) * cpukit/itron/src/ena_dsp.c (added) * cpukit/itron/src/eventflags.c (added) * cpukit/itron/src/exd_tsk.c (added) * cpukit/itron/src/ext_tsk.c (added) * cpukit/itron/src/fmempool.c (added) * cpukit/itron/src/frsm_tsk.c (added) * cpukit/itron/src/get_tid.c (added) * cpukit/itron/src/itronintr.c (added) * cpukit/itron/src/itronsem.c (added) * cpukit/itron/src/itrontime.c (added) * cpukit/itron/src/mbox.c (added) * cpukit/itron/src/msgbuffer.c (added) * cpukit/itron/src/network.c (added) * cpukit/itron/src/port.c (added) * cpukit/itron/src/ref_tsk.c (added) * cpukit/itron/src/rel_wai.c (added) * cpukit/itron/src/rot_rdq.c (added) * cpukit/itron/src/rsm_tsk.c (added) * cpukit/itron/src/slp_tsk.c (added) * cpukit/itron/src/sta_tsk.c (added) * cpukit/itron/src/sus_tsk.c (added) * cpukit/itron/src/sysmgmt.c (added) * cpukit/itron/src/task.c (added) * cpukit/itron/src/ter_tsk.c (added) * cpukit/itron/src/tslp_tsk.c (added) * cpukit/itron/src/vmempool.c (added) * cpukit/itron/src/wup_tsk.c (added) * cpukit/posix/Makefile.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/itronapi.c (added) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/wrapup/Makefile.am (modified) * testsuites/itrontests/Makefile.am (added) * testsuites/itrontests/README (added) * testsuites/itrontests/itronhello/init.c (added) * testsuites/itrontests/itronhello/system.h (added) * testsuites/itrontests/itronmbf01/init.c (added) * testsuites/itrontests/itronmbf01/system.h (added) * testsuites/itrontests/itronsem01/init.c (added) * testsuites/itrontests/itronsem01/system.h (added) * testsuites/itrontests/itrontask01/init.c (added) * testsuites/itrontests/itrontask01/system.h (added) * testsuites/tmitrontests/Makefile.am (added) * testsuites/tmitrontests/README (added) * testsuites/tmitrontests/include/Makefile.am (added) * testsuites/tmitrontests/include/timesys.h (added) * testsuites/tmitrontests/tmitronsem01/init.c (added) * testsuites/tmitrontests/tmitronsem01/system.h (added) * testsuites/tmitrontests/tmitronsem01/tmitronsem01.doc (added) This patch adds the basic framework for the ITRON 3.0 API ...
