# # ChangeLog for cpukit/include in rtems # # Generated by Trac 1.2.1.dev0 # 04/30/24 18:27:26 Mon, 08 Aug 2022 21:51:30 GMT Joel Sherrill [36895bd] * cpukit/include/rtems/test-info.h (modified) cpukit/include/rtems/test-info.h: Change @returns to @return Mon, 01 Aug 2022 22:12:21 GMT Joel Sherrill [4b04589b] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/face.h (added) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/posix/src/psxtimercreate.c (modified) * spec/build/testsuites/psxtests/grp.yml (modified) * spec/build/testsuites/psxtests/psxtimer_face01.yml (added) * testsuites/psxtests/psxtimer_face01/psxtimer.c (added) * testsuites/psxtests/psxtimer_face01/psxtimer_face01.doc (added) * testsuites/psxtests/psxtimer_face01/psxtimer_face01.scn (added) Add support for CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR This adds the ... Wed, 10 Aug 2022 13:20:27 GMT Sebastian Huber [cf3d2b37] * cpukit/include/rtems/malloc.h (modified) rtems/malloc.h: Add API level Doxygen group The interfaces in the ... Fri, 05 Aug 2022 13:35:15 GMT Sebastian Huber [7219d3c] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-hash-sha256.c (modified) libtest: Add T_report_hash_sha256_update() Update #3716. Tue, 02 Aug 2022 11:00:09 GMT Chris Johns [071640d] * cpukit/include/rtems/shellconfig.h (modified) * cpukit/libmisc/shell/main_rtems.c (added) * spec/build/cpukit/objshell.yml (modified) libmisc/shell: Add an 'rtems' command to report a running build - ... Tue, 19 Jul 2022 16:26:40 GMT Ryan Long [ad94dc3] * cpukit/include/sys/exec_elf.h (modified) sys/exec_elf.h: Bring in newer file Updated this file with the ... Thu, 28 Jul 2022 06:20:25 GMT Sebastian Huber [6a65803] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/thread.h (modified) score: Allow linker garbage collection Place the object control ... Tue, 19 Jul 2022 08:38:12 GMT Sebastian Huber [8a864bc6] * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/psxtests/psx08/init.c (modified) score: Use PTHREAD_CANCELED for _Thread_Cancel() The ... Mon, 18 Jul 2022 07:41:39 GMT Sebastian Huber [31036f1d] * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/psxtests/psx08/init.c (modified) * testsuites/psxtests/psx12/init.c (modified) * testsuites/smptests/smppsxmutex01/init.c (modified) * testsuites/validation/tc-task-delete.c (modified) * testsuites/validation/tc-task-exit.c (modified) * testsuites/validation/tc-task-restart.c (modified) score: Use priority inheritance for thread join Threads may join ... Wed, 27 Jul 2022 06:55:10 GMT Sebastian Huber [2501c64b] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/thread.h (modified) score: Fix objects local table initialization The objects local ... Fri, 15 Jul 2022 07:16:04 GMT Sebastian Huber [7fe6d60] * cpukit/include/rtems/posix/priorityimpl.h (modified) * cpukit/include/rtems/score/priority.h (modified) * cpukit/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulerpriorityimpl.h (modified) * cpukit/include/rtems/score/schedulersimpleimpl.h (modified) * cpukit/include/rtems/score/scheduleruniimpl.h (added) * cpukit/rtems/src/timerserver.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/scheduleredfblock.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfschedule.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerpriorityblock.c (modified) * cpukit/score/src/schedulerprioritychangepriority.c (modified) * cpukit/score/src/schedulerpriorityschedule.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimpleblock.c (modified) * cpukit/score/src/schedulersimplechangepriority.c (modified) * cpukit/score/src/schedulersimpleschedule.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/sptests/sptasknopreempt01/init.c (modified) score: Remove PRIORITY_PSEUDO_ISR thread priority The uniprocessor ... Mon, 25 Jul 2022 07:52:41 GMT Sebastian Huber [8dc651f] * cpukit/include/rtems/imfs.h (modified) * cpukit/include/rtems/imfsimpl.h (added) * cpukit/libfs/src/imfs/imfs_add_node.c (modified) * cpukit/libfs/src/imfs/imfs_chown.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_linfile.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_node.c (modified) * cpukit/libfs/src/imfs/imfs_rename.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) imfs: Add Mon, 25 Jul 2022 07:59:14 GMT Sebastian Huber [e584ee4] * cpukit/include/rtems/test-info.h (modified) libtest: Add missing initializer Mon, 23 May 2022 10:27:56 GMT Matt Joyce [6d4b390] * cpukit/include/rtems/confdefs/newlib.h (modified) * cpukit/include/rtems/confdefs/threads.h (modified) * cpukit/include/rtems/libcsupport.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/libcsupport/src/getreentglobal.c (modified) * cpukit/libcsupport/src/newlibc_reent.c (modified) * testsuites/libtests/newlib01/init.c (modified) Support _REENT_THREAD_LOCAL Newlib configuration In case the Newlib ... Wed, 13 Jul 2022 12:42:43 GMT Sebastian Huber [12a03bea] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectfree.c (modified) score: Fix unlimited objects support Commit ... Thu, 14 Jul 2022 13:06:02 GMT Sebastian Huber [1bf878f7] * cpukit/include/rtems/score/memory.h (modified) * cpukit/score/src/memorydirtyfreeareas.c (modified) * cpukit/score/src/memorynoinit.c (added) * cpukit/score/src/memoryzerofreeareas.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/sptests/sp54/init.c (modified) score: Extend memory dirty/zero actions Dirty or zero also the part ... Thu, 14 Jul 2022 11:59:23 GMT Sebastian Huber [4b911a75] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/thread.h (modified) * testsuites/sptests/sp01/init.c (modified) score: Place object controls into .noinit sections Place the ... Fri, 12 Nov 2021 16:59:42 GMT Gleb Smirnoff [388dd97] * cpukit/include/machine/_kernel_in.h (modified) * cpukit/include/machine/_kernel_in6.h (modified) Add in_localip_fib(), in6_localip_fib(). Check if given address/FIB ... Sun, 10 Oct 2021 17:02:26 GMT Gleb Smirnoff [94c33ba9] * cpukit/include/machine/_kernel_in.h (modified) Use network epoch to protect local IPv4 addresses hash. The ... Mon, 06 Sep 2021 22:08:15 GMT Alexander V. Chernikov [7846249e] * cpukit/include/machine/_kernel_in.h (modified) routing: fix source address selection rules for IPv4 over IPv6. ... Wed, 20 May 2020 20:58:17 GMT John Baldwin [070f1b5] * cpukit/include/machine/_kernel_uio.h (modified) Remove copyinfrom() and copyinstrfrom(). These functions were added ... Tue, 05 Jul 2022 06:13:50 GMT Sebastian Huber [6e74ceb] * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadchangepriority.c (modified) score: Conditional _Thread_Priority_replace() This function is only ... Tue, 28 Jun 2022 05:45:02 GMT Sebastian Huber [4f87edb] * cpukit/include/rtems/score/gcov.h (added) * cpukit/include/rtems/test-info.h (modified) * cpukit/libtest/testgcovdumpinfo.c (added) * cpukit/score/src/gcovdumpinfo.c (added) * cpukit/score/src/gcovdumpinfobase64.c (added) * cpukit/score/src/gcovinfoset.c (added) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/librtemstest.yml (modified) * testsuites/validation/tc-terminate.c (modified) gcov: Add functions to dump the gcov information Update #4670. Thu, 23 Jun 2022 06:54:10 GMT Sebastian Huber [ba56e239] * cpukit/include/rtems/score/processormask.h (modified) score: Account for API changes Update #4667. Thu, 23 Jun 2022 06:55:38 GMT Sebastian Huber [a76988c] * cpukit/include/rtems/score/processormask.h (modified) score: Remove unused _Processor_mask_Nand() Update #4667. Mon, 16 May 2022 18:34:59 GMT Sebastian Huber [5dffbc42] * cpukit/include/rtems/score/priorityimpl.h (modified) * cpukit/score/src/kern_tc.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadqops.c (modified) * cpukit/score/src/watchdogtick.c (modified) score: Make SMP only code explicit Conditional expressions with ... Wed, 01 Jun 2022 14:31:06 GMT Frank Kühndel [679e7f10] * cpukit/include/rtems/tftp.h (modified) * cpukit/libfs/src/ftpfs/tftpDriver.c (modified) * cpukit/libfs/src/ftpfs/tftp_driver.h (added) * cpukit/libfs/src/ftpfs/tftpfs.c (added) * spec/build/cpukit/libtftpfs.yml (modified) TFTPFS: Implement block and window size options The original file ... Fri, 20 May 2022 09:30:02 GMT Gabriel Moyano [5ccf960] * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/sys/timepps.h (modified) timecounter.h: Add _Timecounter_Discipline() Update #2349. Fri, 20 May 2022 09:30:01 GMT Gabriel Moyano [b3e4f580] * cpukit/include/sys/timepps.h (modified) * cpukit/score/src/kern_ntptime.c (modified) * testsuites/sptests/spntp01/init.c (modified) timepps.h: PPS_SYNC defined by default Update #2349. Fri, 20 May 2022 09:29:57 GMT Gabriel Moyano [ac4ea53] * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/sys/timetc.h (modified) * cpukit/score/src/kern_tc.c (modified) score: Rename tc_getfrequency() Rename tc_getfrequency() to ... Fri, 20 May 2022 09:29:56 GMT Gabriel Moyano [95c747d9] * cpukit/include/sys/timepps.h (modified) * cpukit/score/src/kern_tc.c (modified) kern_tc.c: Replace FreeBSD event mechanism by adding pointers to ... Fri, 20 May 2022 09:29:55 GMT Gabriel Moyano [bf61753a] * cpukit/include/sys/timepps.h (modified) * cpukit/score/src/kern_tc.c (modified) kern_tc.c: Add atomic dependencies required by the PPS API Update #2349. Wed, 18 May 2022 08:00:12 GMT Sebastian Huber [f49ef6b] * cpukit/include/machine/_kernel_cpuset.h (modified) * cpukit/include/machine/_kernel_in.h (modified) * cpukit/include/machine/_kernel_in6.h (modified) * cpukit/include/machine/_kernel_mman.h (modified) * cpukit/include/machine/_kernel_param.h (modified) * cpukit/include/machine/_kernel_time.h (modified) * cpukit/include/machine/_kernel_types.h (modified) * cpukit/include/machine/_kernel_uio.h (modified) * cpukit/include/machine/_timecounter.h (modified) Add file descriptions to kernel space headers Wed, 18 May 2022 07:59:34 GMT Sebastian Huber [b992648] * cpukit/include/machine/_kernel_cpuset.h (modified) * cpukit/include/machine/_kernel_mman.h (modified) * cpukit/include/machine/_kernel_param.h (modified) * cpukit/include/machine/_kernel_time.h (modified) * cpukit/include/machine/_kernel_types.h (modified) * cpukit/include/machine/_timecounter.h (modified) Fix copyright notice of kernel space headers Use the copyright ... Wed, 18 May 2022 07:49:38 GMT Sebastian Huber [81962136] * cpukit/include/machine/_kernel_cpuset.h (modified) * cpukit/include/machine/_kernel_param.h (modified) Add include guard checks to kernel space headers Thu, 12 May 2022 02:48:55 GMT Tian Ye [901bc14] * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) score: Add SMP priority affinity scheduler yield Fri, 29 Apr 2022 19:37:19 GMT Ryan Long [ebfccb0] * cpukit/include/endian.h (modified) * cpukit/include/machine/_kernel_param.h (modified) include: Add file headers and licenses These files had no header, ... Fri, 29 Apr 2022 19:15:19 GMT Ryan Long [0c17d0e] * cpukit/include/rtems/ftpd.h (modified) ftpd.h: Add file header and license This file had no header, ... Fri, 29 Apr 2022 19:08:51 GMT Ryan Long [5cbad67] * cpukit/include/pci/ids_extra.h (modified) include/pci: Add file header and license This file had no header, ... Fri, 29 Apr 2022 18:49:57 GMT Ryan Long [17c92ad] * cpukit/include/rtems/assoc.h (modified) * cpukit/include/rtems/error.h (modified) cpukit/include/rtems: Add file headers and licenses These files had ... Thu, 21 Apr 2022 17:38:31 GMT Ryan Long [47e84cb] * cpukit/include/machine/_kernel_cpuset.h (modified) * cpukit/include/memory.h (modified) * cpukit/include/poll.h (modified) * cpukit/include/rtems/endian.h (modified) * cpukit/include/rtems/monitor.h (modified) * cpukit/include/rtems/passwd.h (modified) * cpukit/include/rtems/ringbuf.h (modified) cpukit/include: Adding file headers and licenses These files had no ... Thu, 28 Apr 2022 06:56:59 GMT Sebastian Huber [8b18037f] * cpukit/include/rtems/score/heapimpl.h (modified) * cpukit/score/src/heapallocate.c (modified) * testsuites/libtests/malloctest/init.c (modified) heap: Fix heap statistics with protection enabled Close #4644. Wed, 06 Apr 2022 06:16:36 GMT Sebastian Huber [2342625] * cpukit/include/rtems/shell.h (modified) * cpukit/libmisc/shell/shell.c (modified) shell: Add rtems_shell_run_main_loop() In contrast to ... Fri, 01 Apr 2022 18:18:49 GMT Joel Sherrill [5f8c41c] * cpukit/include/rtems/pty.h (modified) * cpukit/include/rtems/shell.h (modified) * cpukit/include/rtems/telnetd.h (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/getgrent.c (modified) * cpukit/libcsupport/src/getgrnam.c (modified) * cpukit/libcsupport/src/getpwent.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/pwdgrp.c (modified) * cpukit/libmisc/shell/cat_file.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/login_check.c (modified) * cpukit/libmisc/shell/main_alias.c (modified) * cpukit/libmisc/shell/main_blksync.c (modified) * cpukit/libmisc/shell/main_cat.c (modified) * cpukit/libmisc/shell/main_cd.c (modified) * cpukit/libmisc/shell/main_chdir.c (modified) * cpukit/libmisc/shell/main_chmod.c (modified) * cpukit/libmisc/shell/main_chroot.c (modified) * cpukit/libmisc/shell/main_date.c (modified) * cpukit/libmisc/shell/main_dir.c (modified) * cpukit/libmisc/shell/main_exit.c (modified) * cpukit/libmisc/shell/main_id.c (modified) * cpukit/libmisc/shell/main_logoff.c (modified) * cpukit/libmisc/shell/main_mdump.c (modified) * cpukit/libmisc/shell/main_medit.c (modified) * cpukit/libmisc/shell/main_mfill.c (modified) * cpukit/libmisc/shell/main_mkdir.c (modified) * cpukit/libmisc/shell/main_mmove.c (modified) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/main_mount_nfs.c (modified) * cpukit/libmisc/shell/main_pwd.c (modified) * cpukit/libmisc/shell/main_rmdir.c (modified) * cpukit/libmisc/shell/main_tty.c (modified) * cpukit/libmisc/shell/main_umask.c (modified) * cpukit/libmisc/shell/main_unmount.c (modified) * cpukit/libmisc/shell/main_whoami.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) * cpukit/libmisc/shell/write_file.c (modified) * cpukit/telnetd/README (modified) * cpukit/telnetd/pty.c (modified) * cpukit/telnetd/telnetd.c (modified) Update email address of Fernando Ruiz Casas to ... Sat, 02 Apr 2022 19:15:16 GMT Joel Sherrill [3a6c3c1] * cpukit/include/drvmgr/drvmgr.h (modified) * cpukit/include/drvmgr/drvmgr_confdefs.h (modified) * cpukit/include/drvmgr/drvmgr_list.h (modified) * cpukit/include/drvmgr/pci_bus.h (modified) * cpukit/include/pci.h (modified) * cpukit/include/pci/access.h (modified) * cpukit/include/pci/cfg.h (modified) * cpukit/include/pci/cfg_auto.h (modified) * cpukit/include/pci/cfg_peripheral.h (modified) * cpukit/include/pci/cfg_read.h (modified) * cpukit/include/pci/cfg_static.h (modified) * cpukit/include/pci/irq.h (modified) cpukit/include; Remove SPDX from Gaisler files NOT changed to BSD-2 Mon, 28 Mar 2022 23:35:59 GMT Joel Sherrill [54ec0264] * cpukit/include/rtems/timespec.h (modified) cpukit/include/rtems/timespec.h: Change license to BSD-2 ... Mon, 28 Mar 2022 23:34:47 GMT Joel Sherrill [59fba6f] * cpukit/include/rtems/cbs.h (modified) cpukit/include/rtems/cbs.h: Change license to BSD-2 Permission ... Tue, 29 Mar 2022 13:23:29 GMT Sebastian Huber [9f9f140] * cpukit/include/rtems/rtems/tasks.h (modified) * spec/build/testsuites/validation/validation-smp-only-0.yml (modified) * testsuites/validation/tc-task-smp.c (added) * testsuites/validation/tc-task.c (modified) * testsuites/validation/tx-support.c (modified) * testsuites/validation/tx-support.h (modified) rtems: Clarify scheduler of created task Fri, 25 Mar 2022 16:17:14 GMT Joel Sherrill [9bbf4003] * cpukit/include/rtems/confdefs/libpci.h (modified) cpukit/include/rtems/confdefs/libpci.h: Manual file header clean up Thu, 24 Mar 2022 21:58:09 GMT Joel Sherrill [c35816a] * cpukit/include/pci/access.h (modified) * cpukit/include/pci/cfg.h (modified) * cpukit/include/pci/cfg_auto.h (modified) * cpukit/include/pci/cfg_peripheral.h (modified) * cpukit/include/pci/cfg_read.h (modified) * cpukit/include/pci/cfg_static.h (modified) * cpukit/include/pci/irq.h (modified) cpukit/include/pci: Manual header file clean up Thu, 24 Mar 2022 21:58:33 GMT Joel Sherrill [9982e8e4] * cpukit/include/drvmgr/drvmgr.h (modified) * cpukit/include/drvmgr/drvmgr_confdefs.h (modified) * cpukit/include/drvmgr/drvmgr_list.h (modified) * cpukit/include/drvmgr/pci_bus.h (modified) cpukit/include/drvmgr: Manual header file clean up Fri, 25 Mar 2022 16:03:39 GMT Joel Sherrill [06c9ab3] * cpukit/include/pci.h (modified) cpukit/include/pci.h: Manual header clean up Fri, 25 Mar 2022 16:02:56 GMT Joel Sherrill [3d435898] * cpukit/include/aio.h (modified) * cpukit/include/mqueue.h (modified) cpukit/include/*.h: Change license to BSD-2 Updates #3053. Thu, 24 Mar 2022 21:35:19 GMT Joel Sherrill [77d1ac6c] * cpukit/include/rtems/bspcmdline.h (modified) * cpukit/include/rtems/btimer.h (modified) * cpukit/include/rtems/chain.h (modified) * cpukit/include/rtems/clockdrv.h (modified) * cpukit/include/rtems/console.h (modified) * cpukit/include/rtems/deviceio.h (modified) * cpukit/include/rtems/devnull.h (modified) * cpukit/include/rtems/dumpbuf.h (modified) * cpukit/include/rtems/extensiondata.h (modified) * cpukit/include/rtems/extensionimpl.h (modified) * cpukit/include/rtems/framebuffer.h (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/include/rtems/inttypes.h (modified) * cpukit/include/rtems/ioimpl.h (modified) * cpukit/include/rtems/iosupp.h (modified) * cpukit/include/rtems/libcsupport.h (modified) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/mptables.h (modified) * cpukit/include/rtems/rtc.h (modified) * cpukit/include/rtems/serial_mouse.h (modified) * cpukit/include/rtems/seterr.h (modified) * cpukit/include/rtems/shellconfig.h (modified) * cpukit/include/rtems/spurious.h (modified) * cpukit/include/rtems/stackchk.h (modified) * cpukit/include/rtems/stringto.h (modified) * cpukit/include/rtems/termiostypes.h (modified) * cpukit/include/rtems/userenv.h (modified) * cpukit/include/rtems/vmeintr.h (modified) * cpukit/include/rtems/watchdogdrv.h (modified) * cpukit/include/sys/statvfs.h (modified) * cpukit/include/sys/utsname.h (modified) cpukit/include/sys: Change license to BSD-2. Updates #3053. Fri, 25 Mar 2022 16:14:25 GMT Joel Sherrill [fb5f575] * cpukit/include/rtems/bdpart.h (modified) * cpukit/include/rtems/bsd.h (modified) * cpukit/include/rtems/concat.h (modified) * cpukit/include/rtems/counter.h (modified) * cpukit/include/rtems/devzero.h (modified) * cpukit/include/rtems/dosfs.h (modified) * cpukit/include/rtems/flashdisk.h (modified) * cpukit/include/rtems/fsmount.h (modified) * cpukit/include/rtems/ftpfs.h (modified) * cpukit/include/rtems/ide_part_table.h (modified) * cpukit/include/rtems/irq.h (modified) * cpukit/include/rtems/jffs2.h (modified) * cpukit/include/rtems/linkersets.h (modified) * cpukit/include/rtems/media.h (modified) * cpukit/include/rtems/nvdisk.h (modified) * cpukit/include/rtems/pipe.h (modified) * cpukit/include/rtems/print.h (modified) * cpukit/include/rtems/printer.h (modified) * cpukit/include/rtems/profiling.h (modified) * cpukit/include/rtems/qreslib.h (modified) * cpukit/include/rtems/rbheap.h (modified) * cpukit/include/rtems/rbtree.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-bitmaps.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-block-pos.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-block.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-buffer.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-data.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-dir-hash.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-dir.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-file-system-fwd.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-file-system.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-file.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-group.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-inode.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-link.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-mutex.h (modified) * cpukit/include/rtems/rfs/rtems-rfs-trace.h (modified) * cpukit/include/rtems/rtems-fdt-shell.h (modified) * cpukit/include/rtems/rtems-fdt.h (modified) * cpukit/include/rtems/rtems-rfs-format.h (modified) * cpukit/include/rtems/rtems-rfs-shell.h (modified) * cpukit/include/rtems/rtems-rfs.h (modified) * cpukit/include/rtems/rtl/dlfcn-shell.h (modified) * cpukit/include/rtems/rtl/rap-shell.h (modified) * cpukit/include/rtems/rtl/rap.h (modified) * cpukit/include/rtems/rtl/rtl-allocator.h (modified) * cpukit/include/rtems/rtl/rtl-archive.h (modified) * cpukit/include/rtems/rtl/rtl-fwd.h (modified) * cpukit/include/rtems/rtl/rtl-indirect-ptr.h (modified) * cpukit/include/rtems/rtl/rtl-obj-cache.h (modified) * cpukit/include/rtems/rtl/rtl-obj-comp.h (modified) * cpukit/include/rtems/rtl/rtl-obj-fwd.h (modified) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-shell.h (modified) * cpukit/include/rtems/rtl/rtl-sym.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/include/rtems/scheduler.h (modified) * cpukit/include/rtems/serdbg.h (modified) * cpukit/include/rtems/serdbgcnf.h (modified) * cpukit/include/rtems/sparse-disk.h (modified) * cpukit/include/rtems/status-checks.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/include/rtems/termios_printk.h (modified) * cpukit/include/rtems/termios_printk_cnf.h (modified) * cpukit/include/rtems/test-info.h (modified) * cpukit/include/rtems/thread.h (modified) * cpukit/include/rtems/timecounter.h (modified) * cpukit/include/rtems/tm27-default.h (modified) * cpukit/include/rtems/trace/rtems-trace-buffer-vars.h (modified) * cpukit/include/rtems/untar.h (modified) * cpukit/include/rtems/version.h (modified) cpukit/include/rtems: Change license to BSD-2 Updates #3053. Thu, 24 Mar 2022 21:40:25 GMT Joel Sherrill [3ec0b267] * cpukit/include/linux/i2c-dev.h (modified) * cpukit/include/linux/i2c.h (modified) * cpukit/include/linux/rbtree.h (modified) * cpukit/include/linux/spi/spidev.h (modified) cpukit/include/linux: Change license to BSD-2 Updates #3053. Thu, 24 Mar 2022 21:40:00 GMT Joel Sherrill [35d1f9a] * cpukit/include/dev/i2c/eeprom.h (modified) * cpukit/include/dev/i2c/fpga-i2c-slave.h (modified) * cpukit/include/dev/i2c/gpio-nxp-pca9535.h (modified) * cpukit/include/dev/i2c/i2c.h (modified) * cpukit/include/dev/i2c/sensor-lm75a.h (modified) * cpukit/include/dev/i2c/switch-nxp-pca9548a.h (modified) * cpukit/include/dev/i2c/ti-ads-16bit-adc.h (modified) * cpukit/include/dev/i2c/ti-lm25066a.h (modified) * cpukit/include/dev/i2c/ti-tmp112.h (modified) * cpukit/include/dev/i2c/xilinx-axi-i2c.h (modified) * cpukit/include/dev/serial/sc16is752.h (modified) * cpukit/include/dev/spi/spi.h (modified) cpukit/include/dev: Change license to BSD-2 Updates #3053. Tue, 22 Mar 2022 19:40:34 GMT Joel Sherrill [628bd9b] * cpukit/include/rtems/tftp.h (modified) * cpukit/libcsupport/src/getgrent.c (modified) * cpukit/libcsupport/src/getgrnam.c (modified) * cpukit/libcsupport/src/getpwent.c (modified) * cpukit/libcsupport/src/pwdgrp.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termiosinitialize.c (modified) * cpukit/libfs/src/ftpfs/tftpDriver.c (modified) * cpukit/score/cpu/m68k/include/rtems/m68k/m68360.h (modified) cpukit/: Update Eric Norum contact info and normalize file headers Thu, 10 Mar 2022 13:11:12 GMT Sebastian Huber [3661518] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) * spec/build/testsuites/validation/fatal-start-on-not-online-processor.yml (added) * spec/build/testsuites/validation/grp.yml (modified) * testsuites/validation/tr-fatal-start-on-not-online-processor.c (added) * testsuites/validation/tr-fatal-start-on-not-online-processor.h (added) * testsuites/validation/ts-fatal-start-on-not-online-processor.c (added) smp: Add fatal error Add SMP-specifc ... Thu, 08 Apr 2021 06:18:20 GMT Sebastian Huber [cc1c944] * cpukit/include/rtems/test-scheduler.h (added) * cpukit/libtest/t-test-scheduler.c (added) * spec/build/cpukit/librtemstest.yml (modified) libtest: Add scheduler test support Add support to record scheduler ... Thu, 15 Jul 2021 14:51:17 GMT Sebastian Huber [d0de6fd] * cpukit/include/rtems/score/io.h (modified) * cpukit/score/src/iorelax.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Add _IO_Relax() This function may be used to burn a couple ... Fri, 18 Mar 2022 15:13:04 GMT Sebastian Huber [7fe3c62] * cpukit/include/rtems/thread.hpp (modified) thread.hpp: Fix redefinition of default argument A default argument ... Tue, 15 Mar 2022 16:34:34 GMT Sebastian Huber [f311caf] * bsps/shared/irq/irq-affinity.c (modified) * cpukit/include/rtems/rtems/intr.h (modified) bsps/irq: Improve affinity set handling Restrict the affinity set ... Mon, 07 Mar 2022 12:52:08 GMT Christian Mauderer [bb2e149e] * cpukit/include/rtems/fsmount.h (modified) * cpukit/include/rtems/ftpfs.h (modified) * cpukit/include/rtems/serdbg.h (modified) * cpukit/include/rtems/serdbgcnf.h (modified) * cpukit/include/rtems/termios_printk.h (modified) * cpukit/include/rtems/termios_printk_cnf.h (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/serdbg/serdbg.c (modified) * cpukit/libmisc/serdbg/serdbgio.c (modified) * cpukit/libmisc/serdbg/termios_printk.c (modified) cpukit: Automated IMD header file clean up Use the same form of IMD ... Thu, 03 Mar 2022 12:27:32 GMT Christian Mauderer [d7955b2] * bsps/i386/pc386/ata/ide.c (modified) * bsps/i386/pc386/ata/idecfg.c (modified) * cpukit/include/rtems/fsmount.h (modified) * cpukit/include/rtems/serdbg.h (modified) * cpukit/include/rtems/serdbgcnf.h (modified) * cpukit/include/rtems/termios_printk.h (modified) * cpukit/include/rtems/termios_printk_cnf.h (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/serdbg/serdbg.c (modified) bsps and cpukit: Manual file header clean up Updates #4625. Tue, 01 Mar 2022 20:40:44 GMT Joel Sherrill [255fe43] * cpukit/dev/i2c/eeprom.c (modified) * cpukit/dev/i2c/gpio-nxp-pca9535.c (modified) * cpukit/dev/i2c/i2c-bus.c (modified) * cpukit/dev/i2c/i2c-dev.c (modified) * cpukit/dev/i2c/sensor-lm75a.c (modified) * cpukit/dev/i2c/switch-nxp-pca9548a.c (modified) * cpukit/dev/serial/sc16is752-regs.h (modified) * cpukit/dev/serial/sc16is752-spi.c (modified) * cpukit/dev/serial/sc16is752.c (modified) * cpukit/dev/spi/spi-bus.c (modified) * cpukit/include/dev/i2c/eeprom.h (modified) * cpukit/include/dev/i2c/gpio-nxp-pca9535.h (modified) * cpukit/include/dev/i2c/i2c.h (modified) * cpukit/include/dev/i2c/sensor-lm75a.h (modified) * cpukit/include/dev/i2c/switch-nxp-pca9548a.h (modified) * cpukit/include/dev/serial/sc16is752.h (modified) * cpukit/include/dev/spi/spi.h (modified) * cpukit/include/linux/i2c-dev.h (modified) * cpukit/include/linux/i2c.h (modified) * cpukit/include/linux/rbtree.h (modified) * cpukit/include/linux/spi/spidev.h (modified) * cpukit/include/rtems/bsd.h (modified) * cpukit/include/rtems/counter.h (modified) * cpukit/include/rtems/devzero.h (modified) * cpukit/include/rtems/ftpfs.h (modified) * cpukit/include/rtems/jffs2.h (modified) * cpukit/include/rtems/linkersets.h (modified) * cpukit/include/rtems/media.h (modified) * cpukit/include/rtems/profiling.h (modified) * cpukit/include/rtems/rbheap.h (modified) * cpukit/include/rtems/scheduler.h (modified) * cpukit/include/rtems/score/assert.h (modified) * cpukit/include/rtems/score/io.h (modified) * cpukit/include/rtems/score/isrlock.h (modified) * cpukit/include/rtems/score/mrsp.h (modified) * cpukit/include/rtems/score/mrspimpl.h (modified) * cpukit/include/rtems/score/muteximpl.h (modified) * cpukit/include/rtems/score/onceimpl.h (modified) * cpukit/include/rtems/score/percpudata.h (modified) * cpukit/include/rtems/score/priorityimpl.h (modified) * cpukit/include/rtems/score/processormask.h (modified) * cpukit/include/rtems/score/profiling.h (modified) * cpukit/include/rtems/score/schedulercbsimpl.h (modified) * cpukit/include/rtems/score/schedulernode.h (modified) * cpukit/include/rtems/score/schedulernodeimpl.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/include/rtems/score/schedulersmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/semaphoreimpl.h (modified) * cpukit/include/rtems/score/smpbarrier.h (modified) * cpukit/include/rtems/score/status.h (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/timecounterimpl.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/include/rtems/sparse-disk.h (modified) * cpukit/include/rtems/status-checks.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/include/rtems/telnetd.h (modified) * cpukit/include/rtems/test-info.h (modified) * cpukit/include/rtems/thread.h (modified) * cpukit/include/rtems/timecounter.h (modified) * cpukit/libblock/src/bdpart-create.c (modified) * cpukit/libblock/src/bdpart-dump.c (modified) * cpukit/libblock/src/bdpart-read.c (modified) * cpukit/libblock/src/bdpart-register.c (modified) * cpukit/libblock/src/bdpart-sort.c (modified) * cpukit/libblock/src/bdpart-write.c (modified) * cpukit/libblock/src/blkdev-blkstats.c (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libblock/src/blkdev-ops.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (modified) * cpukit/libblock/src/diskdevs-init.c (modified) * cpukit/libblock/src/media-desc.c (modified) * cpukit/libblock/src/media-dev-ident.c (modified) * cpukit/libblock/src/media-path.c (modified) * cpukit/libblock/src/media-server.c (modified) * cpukit/libblock/src/media.c (modified) * cpukit/libblock/src/ramdisk-init.c (modified) * cpukit/libblock/src/ramdisk-register.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/libblock/src/sparse-disk.c (modified) * cpukit/libcrypt/crypt.c (modified) * cpukit/libcsupport/src/arc4random_getentropy_fail.c (modified) * cpukit/libcsupport/src/cachecoherentalloc.c (modified) * cpukit/libcsupport/src/clock.c (modified) * cpukit/libcsupport/src/clonenode.c (modified) * cpukit/libcsupport/src/consolesimple.h (modified) * cpukit/libcsupport/src/consolesimpleread.c (modified) * cpukit/libcsupport/src/getreentglobal.c (modified) * cpukit/libcsupport/src/libio_exit.c (modified) * cpukit/libcsupport/src/mount-mktgt.c (modified) * cpukit/libcsupport/src/printerfprintfputc.c (modified) * cpukit/libcsupport/src/printertask.c (modified) * cpukit/libcsupport/src/printf_plugin.c (modified) * cpukit/libcsupport/src/pwdgrp.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libcsupport/src/rtems_heap_extend.c (modified) * cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c (modified) * cpukit/libcsupport/src/rtems_heap_greedy.c (modified) * cpukit/libcsupport/src/rtems_heap_null_extend.c (modified) * cpukit/libcsupport/src/setgroups.c (modified) * cpukit/libcsupport/src/sup_fs_check_permissions.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path_generic.c (modified) * cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c (modified) * cpukit/libcsupport/src/sup_fs_location.c (modified) * cpukit/libcsupport/src/sup_fs_mount_iterate.c (modified) * cpukit/libcsupport/src/sup_fs_next_token.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libcsupport/src/uenvgetgroups.c (modified) * cpukit/libcsupport/src/vprintk.c (modified) * cpukit/libfs/src/defaults/default_are_nodes_equal.c (modified) * cpukit/libfs/src/defaults/default_clone.c (modified) * cpukit/libfs/src/defaults/default_eval_path.c (modified) * cpukit/libfs/src/defaults/default_fsync_success.c (modified) * cpukit/libfs/src/defaults/default_ftruncate_directory.c (modified) * cpukit/libfs/src/defaults/default_handlers.c (modified) * cpukit/libfs/src/defaults/default_kqfilter.c (modified) * cpukit/libfs/src/defaults/default_lock_and_unlock.c (modified) * cpukit/libfs/src/defaults/default_lseek_directory.c (modified) * cpukit/libfs/src/defaults/default_lseek_file.c (modified) * cpukit/libfs/src/defaults/default_poll.c (modified) * cpukit/libfs/src/defaults/default_readv.c (modified) * cpukit/libfs/src/defaults/default_writev.c (modified) * cpukit/libfs/src/dosfs/msdos_conv_default.c (modified) * cpukit/libfs/src/dosfs/msdos_conv_utf8.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/jffs2/include/linux/kernel-rtems.h (modified) * cpukit/libmisc/cpuuse/cpuinforeport.c (modified) * cpukit/libmisc/devnull/devzero.c (modified) * cpukit/libmisc/shell/fdisk.c (modified) * cpukit/libmisc/shell/login_check.c (modified) * cpukit/libmisc/shell/login_prompt.c (modified) * cpukit/libmisc/shell/main_blkstats.c (modified) * cpukit/libmisc/shell/main_cmdchmod.c (modified) * cpukit/libmisc/shell/main_cmdchown.c (modified) * cpukit/libmisc/shell/main_cmdls.c (modified) * cpukit/libmisc/shell/main_cpuinfo.c (modified) * cpukit/libmisc/shell/main_lsof.c (modified) * cpukit/libmisc/shell/main_profreport.c (modified) * cpukit/libmisc/shell/main_rtc.c (modified) * cpukit/libmisc/shell/shell-wait-for-input.c (modified) * cpukit/libmisc/untar/untar_tgz.c (modified) * cpukit/libtest/testbeginend.c (modified) * cpukit/libtest/testbusy.c (modified) * cpukit/libtest/testextension.c (modified) * cpukit/libtest/testparallel.c (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * cpukit/rtems/src/rtemsmaxprio.c (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/rtems/src/statustext.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/taskexit.c (modified) * cpukit/rtems/src/taskgetpriority.c (modified) * cpukit/rtems/src/taskgetscheduler.c (modified) * cpukit/rtems/src/taskiterate.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/rtems/src/workspacegreedy.c (modified) * cpukit/sapi/src/chainappendnotify.c (modified) * cpukit/sapi/src/chaingetnotify.c (modified) * cpukit/sapi/src/chaingetwait.c (modified) * cpukit/sapi/src/chainprependnotify.c (modified) * cpukit/sapi/src/chainprotected.c (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * cpukit/sapi/src/delaynano.c (modified) * cpukit/sapi/src/delayticks.c (modified) * cpukit/sapi/src/fatalsrctext.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/sapi/src/panic.c (modified) * cpukit/sapi/src/profilingiterate.c (modified) * cpukit/sapi/src/profilingreportxml.c (modified) * cpukit/sapi/src/rbheap.c (modified) * cpukit/sapi/src/tcsimpleinstall.c (modified) * cpukit/score/cpu/arm/__aeabi_read_tp.c (modified) * cpukit/score/cpu/arm/__tls_get_addr.c (modified) * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) * cpukit/score/cpu/arm/arm-exception-default.c (modified) * cpukit/score/cpu/arm/arm-exception-frame-print.c (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (modified) * cpukit/score/cpu/arm/armv4-sync-synchronize.c (modified) * cpukit/score/cpu/arm/armv7-thread-idle.c (modified) * cpukit/score/cpu/arm/armv7m-context-initialize.c (modified) * cpukit/score/cpu/arm/armv7m-context-restore.c (modified) * cpukit/score/cpu/arm/armv7m-context-switch.c (modified) * cpukit/score/cpu/arm/armv7m-exception-default.c (modified) * cpukit/score/cpu/arm/armv7m-exception-handler-get.c (modified) * cpukit/score/cpu/arm/armv7m-exception-handler-set.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-get.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-handler.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-set.c (modified) * cpukit/score/cpu/arm/armv7m-isr-dispatch.c (modified) * cpukit/score/cpu/arm/armv7m-isr-enter-leave.c (modified) * cpukit/score/cpu/arm/armv7m-isr-level-get.c (modified) * cpukit/score/cpu/arm/armv7m-isr-level-set.c (modified) * cpukit/score/cpu/arm/armv7m-isr-vector-install.c (modified) * cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c (modified) * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) * cpukit/score/cpu/arm/include/rtems/score/armv4.h (modified) * cpukit/score/cpu/arm/include/rtems/score/armv7m.h (modified) * cpukit/score/cpu/bfin/bfin-exception-frame-print.c (modified) * cpukit/score/cpu/lm32/lm32-exception-frame-print.c (modified) * cpukit/score/cpu/m68k/__m68k_read_tp.c (modified) * cpukit/score/cpu/m68k/m68k-exception-frame-print.c (modified) * cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h (modified) * cpukit/score/cpu/nios2/nios2-context-validate.S (modified) * cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S (modified) * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-exception-frame-print.c (modified) * cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-add-region.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-configuration.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-descriptor.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-reset.c (modified) * cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c (modified) * cpukit/score/cpu/no_cpu/cpucounterfrequency.c (modified) * cpukit/score/cpu/no_cpu/cpucounterread.c (modified) * cpukit/score/cpu/no_cpu/cpuidle.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S (modified) * cpukit/score/cpu/sh/sh-exception-frame-print.c (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) * cpukit/score/cpu/sparc/sparc-counter-asm.S (modified) * cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c (modified) * cpukit/score/cpu/v850/v850-exception-frame-print.c (modified) * cpukit/score/src/allocatormutex.c (modified) * cpukit/score/src/chainnodecount.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/debugisthreaddispatchingallowed.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/heapgreedy.c (modified) * cpukit/score/src/heapiterate.c (modified) * cpukit/score/src/heapnoextend.c (modified) * cpukit/score/src/ioprintf.c (modified) * cpukit/score/src/isrisinprogress.c (modified) * cpukit/score/src/libatomic.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/objectactivecount.c (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/percpuasm.c (modified) * cpukit/score/src/percpustatewait.c (modified) * cpukit/score/src/pheapiterate.c (modified) * cpukit/score/src/processormaskcopy.c (modified) * cpukit/score/src/profilingisrentryexit.c (modified) * cpukit/score/src/profilingsmplock.c (modified) * cpukit/score/src/rbtreeiterate.c (modified) * cpukit/score/src/rbtreepostorder.c (modified) * cpukit/score/src/rbtreereplace.c (modified) * cpukit/score/src/sched.c (modified) * cpukit/score/src/schedulergetaffinity.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/smpbarrierwait.c (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/threadentryadaptoridle.c (modified) * cpukit/score/src/threadentryadaptornumeric.c (modified) * cpukit/score/src/threadentryadaptorpointer.c (modified) * cpukit/score/src/threadgetcputimeused.c (modified) * cpukit/score/src/threaditerate.c (modified) * cpukit/score/src/threadqops.c (modified) * cpukit/score/src/threadscheduler.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) * cpukit/score/src/threadyield.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogtick.c (modified) * cpukit/score/src/wkstringduplicate.c (modified) * cpukit/telnetd/check_passwd.c (modified) cpukit/: Scripted embedded brains header file clean up Updates #4625. Thu, 17 Feb 2022 15:44:10 GMT Joel Sherrill [2fb29836] * cpukit/include/adainclude/rtems-barrier.adb (modified) * cpukit/include/adainclude/rtems-barrier.ads (modified) * cpukit/include/adainclude/rtems-clock.adb (modified) * cpukit/include/adainclude/rtems-clock.ads (modified) * cpukit/include/adainclude/rtems-cpu_usage.ads (modified) * cpukit/include/adainclude/rtems-event.adb (modified) * cpukit/include/adainclude/rtems-event.ads (modified) * cpukit/include/adainclude/rtems-extension.adb (modified) * cpukit/include/adainclude/rtems-extension.ads (modified) * cpukit/include/adainclude/rtems-fatal.adb (modified) * cpukit/include/adainclude/rtems-fatal.ads (modified) * cpukit/include/adainclude/rtems-interrupt.ads (modified) * cpukit/include/adainclude/rtems-io.adb (modified) * cpukit/include/adainclude/rtems-io.ads (modified) * cpukit/include/adainclude/rtems-message_queue.adb (modified) * cpukit/include/adainclude/rtems-message_queue.ads (modified) * cpukit/include/adainclude/rtems-multiprocessing.adb (modified) * cpukit/include/adainclude/rtems-multiprocessing.ads (modified) * cpukit/include/adainclude/rtems-object.adb (modified) * cpukit/include/adainclude/rtems-object.ads (modified) * cpukit/include/adainclude/rtems-partition.adb (modified) * cpukit/include/adainclude/rtems-partition.ads (modified) * cpukit/include/adainclude/rtems-port.adb (modified) * cpukit/include/adainclude/rtems-port.ads (modified) * cpukit/include/adainclude/rtems-rate_monotonic.adb (modified) * cpukit/include/adainclude/rtems-rate_monotonic.ads (modified) * cpukit/include/adainclude/rtems-region.adb (modified) * cpukit/include/adainclude/rtems-region.ads (modified) * cpukit/include/adainclude/rtems-semaphore.adb (modified) * cpukit/include/adainclude/rtems-semaphore.ads (modified) * cpukit/include/adainclude/rtems-signal.adb (modified) * cpukit/include/adainclude/rtems-signal.ads (modified) * cpukit/include/adainclude/rtems-stack_checker.ads (modified) * cpukit/include/adainclude/rtems-tasks.adb (modified) * cpukit/include/adainclude/rtems-tasks.ads (modified) * cpukit/include/adainclude/rtems-timer.adb (modified) * cpukit/include/adainclude/rtems-timer.ads (modified) * cpukit/include/adainclude/rtems.adb (modified) * cpukit/include/adainclude/rtems.ads (modified) cpukit/include/adainclude: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:32:36 GMT Joel Sherrill [46a16ada] * cpukit/include/rtems/posix/aio_misc.h (modified) * cpukit/include/rtems/posix/barrierimpl.h (modified) * cpukit/include/rtems/posix/condimpl.h (modified) * cpukit/include/rtems/posix/key.h (modified) * cpukit/include/rtems/posix/keyimpl.h (modified) * cpukit/include/rtems/posix/mmanimpl.h (modified) * cpukit/include/rtems/posix/mqueue.h (modified) * cpukit/include/rtems/posix/mqueueimpl.h (modified) * cpukit/include/rtems/posix/muteximpl.h (modified) * cpukit/include/rtems/posix/posixapi.h (modified) * cpukit/include/rtems/posix/priorityimpl.h (modified) * cpukit/include/rtems/posix/psignal.h (modified) * cpukit/include/rtems/posix/psignalimpl.h (modified) * cpukit/include/rtems/posix/pthread.h (modified) * cpukit/include/rtems/posix/pthreadattrimpl.h (modified) * cpukit/include/rtems/posix/pthreadimpl.h (modified) * cpukit/include/rtems/posix/rwlockimpl.h (modified) * cpukit/include/rtems/posix/semaphore.h (modified) * cpukit/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/include/rtems/posix/shm.h (modified) * cpukit/include/rtems/posix/shmimpl.h (modified) * cpukit/include/rtems/posix/sigset.h (modified) * cpukit/include/rtems/posix/spinlockimpl.h (modified) * cpukit/include/rtems/posix/threadsup.h (modified) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/include/rtems/posix/timerimpl.h (modified) cpukit/include/rtems/posix/*.h: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:29:38 GMT Joel Sherrill [a2ed06e] * cpukit/include/rtems/rtems/asrdata.h (modified) * cpukit/include/rtems/rtems/attrimpl.h (modified) * cpukit/include/rtems/rtems/barrierdata.h (modified) * cpukit/include/rtems/rtems/barrierimpl.h (modified) * cpukit/include/rtems/rtems/clockimpl.h (modified) * cpukit/include/rtems/rtems/dpmemdata.h (modified) * cpukit/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/include/rtems/rtems/eventdata.h (modified) * cpukit/include/rtems/rtems/eventimpl.h (modified) * cpukit/include/rtems/rtems/eventmp.h (modified) * cpukit/include/rtems/rtems/mainpage.h (modified) * cpukit/include/rtems/rtems/messagedata.h (modified) * cpukit/include/rtems/rtems/messageimpl.h (modified) * cpukit/include/rtems/rtems/modesimpl.h (modified) * cpukit/include/rtems/rtems/msgmp.h (modified) * cpukit/include/rtems/rtems/optionsimpl.h (modified) * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/rtems/partmp.h (modified) * cpukit/include/rtems/rtems/ratemondata.h (modified) * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/rtems/regiondata.h (modified) * cpukit/include/rtems/rtems/regionimpl.h (modified) * cpukit/include/rtems/rtems/semdata.h (modified) * cpukit/include/rtems/rtems/semimpl.h (modified) * cpukit/include/rtems/rtems/semmp.h (modified) * cpukit/include/rtems/rtems/signalimpl.h (modified) * cpukit/include/rtems/rtems/signalmp.h (modified) * cpukit/include/rtems/rtems/statusimpl.h (modified) * cpukit/include/rtems/rtems/taskmp.h (modified) * cpukit/include/rtems/rtems/tasksdata.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/include/rtems/rtems/timerdata.h (modified) * cpukit/include/rtems/rtems/timerimpl.h (modified) cpukit/include/rtems/rtems/*.h: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 21:16:11 GMT Joel Sherrill [7b85efb8] * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulercbs.h (modified) * cpukit/include/rtems/score/schedulercbsimpl.h (modified) * cpukit/include/rtems/score/scheduleredf.h (modified) * cpukit/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulernode.h (modified) * cpukit/include/rtems/score/schedulernodeimpl.h (modified) * cpukit/include/rtems/score/schedulerpriority.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerpriorityimpl.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/include/rtems/score/schedulersimple.h (modified) * cpukit/include/rtems/score/schedulersimpleimpl.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulersmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/semaphoreimpl.h (modified) * cpukit/include/rtems/score/smp.h (modified) * cpukit/include/rtems/score/smpbarrier.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/include/rtems/score/smplock.h (modified) * cpukit/include/rtems/score/smplockmcs.h (modified) * cpukit/include/rtems/score/smplockseq.h (modified) * cpukit/include/rtems/score/smplockstats.h (modified) * cpukit/include/rtems/score/smplockticket.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/states.h (modified) * cpukit/include/rtems/score/statesimpl.h (modified) * cpukit/include/rtems/score/status.h (modified) * cpukit/include/rtems/score/sysstate.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threaddispatch.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/include/rtems/score/threadq.h (modified) * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/timecounterimpl.h (modified) * cpukit/include/rtems/score/timestamp.h (modified) * cpukit/include/rtems/score/timestampimpl.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/include/rtems/score/todimpl.h (modified) * cpukit/include/rtems/score/userext.h (modified) * cpukit/include/rtems/score/userextdata.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) * cpukit/include/rtems/score/watchdog.h (modified) * cpukit/include/rtems/score/watchdogimpl.h (modified) * cpukit/include/rtems/score/watchdogticks.h (modified) * cpukit/include/rtems/score/wkspace.h (modified) cpukit/include/rtems/score/[s-z]*.h: Change license to BSD-2 ... Wed, 16 Feb 2022 21:15:58 GMT Joel Sherrill [7ebce359] * cpukit/include/rtems/score/address.h (modified) * cpukit/include/rtems/score/apimutex.h (modified) * cpukit/include/rtems/score/assert.h (modified) * cpukit/include/rtems/score/atomic.h (modified) * cpukit/include/rtems/score/chain.h (modified) * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/include/rtems/score/context.h (modified) * cpukit/include/rtems/score/copyrt.h (modified) * cpukit/include/rtems/score/corebarrier.h (modified) * cpukit/include/rtems/score/corebarrierimpl.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/include/rtems/score/coremutex.h (modified) * cpukit/include/rtems/score/coremuteximpl.h (modified) * cpukit/include/rtems/score/corerwlockimpl.h (modified) * cpukit/include/rtems/score/coresem.h (modified) * cpukit/include/rtems/score/coresemimpl.h (modified) * cpukit/include/rtems/score/cpustdatomic.h (modified) * cpukit/include/rtems/score/freechain.h (modified) * cpukit/include/rtems/score/freechainimpl.h (modified) * cpukit/include/rtems/score/heap.h (modified) * cpukit/include/rtems/score/heapimpl.h (modified) * cpukit/include/rtems/score/heapinfo.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/io.h (modified) * cpukit/include/rtems/score/isr.h (modified) * cpukit/include/rtems/score/isrlevel.h (modified) * cpukit/include/rtems/score/isrlock.h (modified) * cpukit/include/rtems/score/mpci.h (modified) * cpukit/include/rtems/score/mpciimpl.h (modified) * cpukit/include/rtems/score/mppkt.h (modified) * cpukit/include/rtems/score/mrsp.h (modified) * cpukit/include/rtems/score/mrspimpl.h (modified) * cpukit/include/rtems/score/muteximpl.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/objectmp.h (modified) * cpukit/include/rtems/score/onceimpl.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/percpudata.h (modified) * cpukit/include/rtems/score/priority.h (modified) * cpukit/include/rtems/score/prioritybitmap.h (modified) * cpukit/include/rtems/score/prioritybitmapimpl.h (modified) * cpukit/include/rtems/score/priorityimpl.h (modified) * cpukit/include/rtems/score/processormask.h (modified) * cpukit/include/rtems/score/profiling.h (modified) * cpukit/include/rtems/score/protectedheap.h (modified) * cpukit/include/rtems/score/rbtree.h (modified) * cpukit/include/rtems/score/rbtreeimpl.h (modified) cpukit/include/rtems/score/[a-r]*.h: Change license to BSD-2 ... Mon, 07 Feb 2022 15:10:45 GMT Sebastian Huber [8f1e8f8f] * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/sys/timex.h (modified) * cpukit/posix/src/adjtime.c (deleted) * cpukit/score/src/kern_ntptime.c (modified) * cpukit/score/src/kern_tc.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spntp01.yml (added) * testsuites/psxtests/psxtime/test.c (modified) * testsuites/sptests/spntp01/init.c (added) kern_ntptime.c: Port to RTEMS Remove previous adjtime() ... Fri, 18 Feb 2022 15:33:10 GMT Sebastian Huber [d69acf8] * cpukit/include/rtems/confdefs/threads.h (modified) config: CONFIGURE_DISABLE_NEWLIB_REENTRANCY Do not initialize ... Thu, 12 Aug 2021 07:51:55 GMT Christian Mauderer [7b5948d4] * cpukit/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) termios: Pass number of sent chars to l_start At the moment the ... Wed, 26 Jan 2022 10:01:44 GMT Sebastian Huber [2145e0c7] * cpukit/include/rtems/gxx_wrappers.h (deleted) * cpukit/include/rtems/score/interr.h (modified) * cpukit/libcsupport/src/gxx_wrappers.c (deleted) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/gxx01.yml (deleted) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal24.yml (deleted) * spec/build/testsuites/sptests/spfatal25.yml (deleted) * testsuites/libtests/gxx01/gxx01.doc (deleted) * testsuites/libtests/gxx01/gxx01.scn (deleted) * testsuites/libtests/gxx01/init.c (deleted) * testsuites/sptests/spfatal24/init.c (deleted) * testsuites/sptests/spfatal24/spfatal24.doc (deleted) * testsuites/sptests/spfatal24/spfatal24.scn (deleted) * testsuites/sptests/spfatal25/init.c (deleted) * testsuites/sptests/spfatal25/spfatal25.doc (deleted) * testsuites/sptests/spfatal25/spfatal25.scn (deleted) Remove obsolete rtems_gxx_*() implementation GCC versions prior to ... Wed, 22 Dec 2021 07:16:43 GMT Sebastian Huber [d404771] * cpukit/include/rtems/rtems/clock.h (modified) rtems: Fix Clock Manager parameter descriptions Update #4572. Thu, 18 Nov 2021 02:53:56 GMT Vikram Garhwal [75b3f48a] * cpukit/include/libfdt.h (modified) libfdt: overlay: make overlay_get_target() public This is done to ... Fri, 18 Jun 2021 17:20:27 GMT Andre Przywara [c07e238] * cpukit/include/libfdt.h (modified) fdtget: Fix signedness comparisons warnings With -Wsign-compare, ... Tue, 29 Dec 2020 04:17:49 GMT Justin Covell [a582ab3] * cpukit/dtc/libfdt/fdt_rw.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) * cpukit/include/libfdt.h (modified) Set last_comp_version correctly in new dtb and fix potential version ... Fri, 11 Dec 2020 02:27:36 GMT Tom Rini [03b601af] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/libfdt_internal.h (modified) * cpukit/include/libfdt.h (modified) libfdt: Internally perform potentially unaligned loads Commits ... Wed, 04 Nov 2020 13:06:05 GMT Tom Rini [064a1d7] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/include/libfdt.h (modified) libfdt: Check for 8-byte address alignment in fdt_ro_probe_() The ... Mon, 12 Oct 2020 16:53:31 GMT Andre Przywara [611a2a5a] * cpukit/include/libfdt.h (modified) libfdt: Fix kernel-doc comments The API documentation in libfdt.h ... Tue, 16 Jun 2020 01:12:17 GMT Patrick Oppenlander [f5379faf] * cpukit/include/libfdt.h (modified) libfdt: add extern "C" for C++ Signed-off-by: Patrick Oppenlander ... Fri, 10 Dec 2021 07:48:27 GMT Sebastian Huber [868e6d8] * cpukit/include/rtems/rtems/intr.h (modified) rtems: Improve ordering in Move the data ... Wed, 14 Oct 2020 08:47:44 GMT Sebastian Huber [fb17dfb1] * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/ratemondata.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) Avoid ISR_LOCK_MEMBER() since it confuses Doxygen If RTEMS_SMP is ... Tue, 07 Dec 2021 15:31:45 GMT Sebastian Huber [39e6f532] * cpukit/include/rtems/score/wkspaceinitone.h (modified) score: Fix _Workspace_Initialize_for_one_area() In ... Sun, 05 Dec 2021 15:37:33 GMT Sebastian Huber [69d643f7] * cpukit/include/rtems/score/cpustdatomic.h (modified) score: Fix atomic stores for C++ Close #4566. Thu, 02 Dec 2021 14:06:48 GMT Sebastian Huber [9089bcc] * cpukit/include/rtems/irq-extension.h (modified) * cpukit/include/rtems/rtems/intr.h (modified) rtems: Move all Interrupt Manager stuff to intr.h Since the ... Thu, 02 Dec 2021 13:00:53 GMT Sebastian Huber [0d83bed2] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/scheduler.h (added) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetmaxprio.c (modified) * cpukit/rtems/src/schedulergetprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessormax.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (modified) * cpukit/rtems/src/schedulermapfromposix.c (modified) * cpukit/rtems/src/schedulermaptoposix.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) rtems: Move scheduler directives to own header Move all ... Wed, 08 Apr 2020 15:14:41 GMT Sebastian Huber [d7205f0] * bsps/shared/start/mallocinitmulti.c (added) * bsps/shared/start/mallocinitone.c (added) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/mallocinitmulti.h (added) * cpukit/include/rtems/mallocinitone.h (added) * cpukit/libcsupport/src/malloc_initialize.c (deleted) * cpukit/libcsupport/src/mallocheap.c (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/i386/pc386/obj.yml (modified) * spec/build/bsps/objmem.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (modified) * spec/build/bsps/powerpc/objmem.yml (modified) * spec/build/bsps/powerpc/qoriq/obj.yml (modified) * spec/build/bsps/powerpc/tqm8xx/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (modified) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/libtests/malloc04/init.c (modified) libc: Optimize malloc() initialization The BSPs provide memory for ... Wed, 08 Apr 2020 14:54:34 GMT Sebastian Huber [3d0620b] * bsps/shared/start/wkspaceinitmulti.c (added) * bsps/shared/start/wkspaceinitone.c (added) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/include/rtems/score/wkspaceinitmulti.h (added) * cpukit/include/rtems/score/wkspaceinitone.h (added) * cpukit/score/src/wkspace.c (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/i386/pc386/obj.yml (modified) * spec/build/bsps/objmem.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (modified) * spec/build/bsps/powerpc/objmem.yml (modified) * spec/build/bsps/powerpc/qoriq/obj.yml (modified) * spec/build/bsps/powerpc/tqm8xx/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (modified) score: Optimize Workspace Handler initialization The BSPs provide ... Tue, 23 Nov 2021 14:15:27 GMT Sebastian Huber [675e879] * cpukit/include/rtems/rtems/clock.h (modified) rtems: Replace "precision" with "resolution" Resolution is the ... Thu, 11 Nov 2021 07:44:29 GMT Sebastian Huber [5468464] * cpukit/include/rtems/score/status.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Properly continue the thread during restart The ... Thu, 11 Nov 2021 08:00:03 GMT Sebastian Huber [2e56aab] * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqextract.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Move _Thread_queue_Extract() Move _Thread_queue_Extract() ... Thu, 11 Nov 2021 09:34:31 GMT Sebastian Huber [e429e97] * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadtimeout.c (modified) * testsuites/sptests/spintrcritical08/init.c (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) score: Simplify thread wait state handling Remove the ... Thu, 11 Nov 2021 07:35:22 GMT Sebastian Huber [50aef135] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadrestart.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/objmpci.yml (modified) score: Add _Thread_MP_Extract_proxy() Remove ... Mon, 08 Nov 2021 10:08:24 GMT Sebastian Huber [c69a70a] * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) rtems: Fix rtems_scheduler_remove_processor() Return an error ... Wed, 10 Nov 2021 07:54:03 GMT Sebastian Huber [6443c9d] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Fix assertion in SMP scheduler framework Properly assert ... Fri, 29 Oct 2021 07:30:13 GMT Sebastian Huber [fc64e837] * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/schedulersmp.c (modified) * cpukit/score/src/threaddispatch.c (modified) score: Rework ask for help requests Process ask for help requests ... Fri, 29 Oct 2021 12:17:54 GMT Sebastian Huber [4d90289e] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: _Scheduler_SMP_Schedule_highest_ready() Simplify callers of ...
