# # ChangeLog for cpukit/include in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 11:51:13 Thu, 26 Nov 2020 18:53:25 GMT Sebastian Huber [9c20b987] * bsps/arm/altera-cyclone-v/rtc/rtc.c (modified) * bsps/arm/lpc32xx/rtc/rtc-config.c (modified) * bsps/bfin/shared/dev/rtc.c (modified) * bsps/shared/dev/rtc/ds1375.c (modified) * bsps/shared/dev/rtc/rtc-support.c (modified) * cpukit/include/rtems/rtems/clock.h (modified) * cpukit/include/rtems/rtems/clockimpl.h (added) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/clocktodtoseconds.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercreate.c (modified) * testsuites/sptests/sp2038/init.c (modified) rtems: Add Mon, 30 Nov 2020 10:43:09 GMT Sebastian Huber [3732c93] * cpukit/Makefile.am (modified) * cpukit/include/rtems/posix/posixapi.h (modified) * cpukit/sapi/src/posixapi.c (deleted) * spec/build/cpukit/librtemscpu.yml (modified) posix: Delete unused _POSIX_Fatal_error() Tue, 01 Dec 2020 13:39:43 GMT Sebastian Huber [7995329] * cpukit/include/rtems/rtems/part.h (modified) rtems: Fix documentation in Update #3993. Fri, 20 Nov 2020 17:46:04 GMT Sebastian Huber [2406fe8] * cpukit/include/rtems/rtems/object.h (modified) rtems: Delete rtems_object_id_api_maximum_class() This directive ... Tue, 24 Nov 2020 07:05:43 GMT Sebastian Huber [6c1afc19] * cpukit/include/rtems/confdefs/inittask.h (modified) config: Check CONFIGURE_INIT_TASK_STACK_SIZE Thu, 19 Nov 2020 15:07:04 GMT Sebastian Huber [657e30c1] * cpukit/Makefile.am (modified) * cpukit/doxygen/appl-config.h (modified) * cpukit/include/rtems/confdefs/inittask.h (modified) * cpukit/include/rtems/rtems/tasksdata.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/rtems/src/taskconstructuser.c (added) * cpukit/sapi/src/interrtext.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal34.yml (added) * testsuites/sptests/spfatal34/init.c (added) * testsuites/sptests/spfatal34/spfatal34.doc (added) * testsuites/sptests/spfatal34/spfatal34.scn (added) * testsuites/sptests/spinternalerror02/init.c (modified) config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE In order to ... Thu, 19 Nov 2020 14:30:17 GMT Sebastian Huber [bc175a1] * cpukit/include/rtems/confdefs/inittask.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/rtems/src/taskinitusers.c (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal02.yml (deleted) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal02/init.c (deleted) * testsuites/sptests/spfatal02/spfatal02.doc (deleted) * testsuites/sptests/spfatal02/spfatal02.scn (deleted) Avoid INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL Replace a ... Wed, 25 Nov 2020 06:59:30 GMT Sebastian Huber [ef8c4ebc] * cpukit/include/rtems/confdefs/wkspace.h (modified) config: Clarify the use of pragmas Thu, 26 Nov 2020 10:08:54 GMT Sebastian Huber [b2a677b] * cpukit/include/rtems/seterr.h (modified) rtems: Move "Set Errno" group to the API Thu, 26 Nov 2020 09:01:18 GMT Sebastian Huber [41725e95] * cpukit/include/rtems/score/percpu.h (modified) score: Change _Per_CPU_Information declaration Change the ... Wed, 14 Oct 2020 08:32:18 GMT Sebastian Huber [3c093d6] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partcreate.c (modified) rtems: Move _Partition_Allocate() It is only used by ... Wed, 14 Oct 2020 08:31:45 GMT Sebastian Huber [accbe3c4] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partcreate.c (modified) rtems: Move _Partition_Initialize() It is only used by ... Wed, 14 Oct 2020 08:30:45 GMT Sebastian Huber [1784799] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partcreate.c (modified) rtems: Move _Partition_Is_buffer_area_aligned() It is only used by ... Wed, 14 Oct 2020 08:29:19 GMT Sebastian Huber [1eafefbf] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partcreate.c (modified) rtems: Move _Partition_Is_buffer_size_aligned() It is only used by ... Wed, 14 Oct 2020 08:26:53 GMT Sebastian Huber [a61e221d] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) rtems: Move _Partition_Is_buffer_on_boundary() It is used only by ... Wed, 14 Oct 2020 08:25:59 GMT Sebastian Huber [2572a3f] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) rtems: Move _Partition_Is_buffer_valid() It is used only in one ... Sat, 21 Nov 2020 20:15:39 GMT Sebastian Huber [aa1c6dd] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) libtest: Fix undefined setjmp() behaviour Bug was introduced by ... Wed, 14 Oct 2020 08:22:52 GMT Sebastian Huber [cbfacee4] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partdelete.c (modified) rtems: Remove _Partition_Destroy() It was a trivial function call ... Wed, 14 Oct 2020 08:22:18 GMT Sebastian Huber [3c029026] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partdelete.c (modified) rtems: Remove _Partition_Free() It was a trivial function call ... Wed, 14 Oct 2020 08:14:10 GMT Sebastian Huber [76263d8] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) rtems: Move _Partition_Free_buffer() It is only used by ... Wed, 14 Oct 2020 08:12:56 GMT Sebastian Huber [6d413ef1] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partgetbuffer.c (modified) rtems: Move _Partition_Allocate_buffer() It is only used by ... Wed, 14 Oct 2020 07:43:48 GMT Sebastian Huber [ede8f51] * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/partimpl.h (modified) rtems: Update partition documentation Wed, 14 Oct 2020 06:51:39 GMT Sebastian Huber [4c1e793] * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) rtems: Canonicalize partition file documentation Wed, 14 Oct 2020 09:30:19 GMT Sebastian Huber [134fc76d] * cpukit/include/rtems/rtems/eventdata.h (modified) * cpukit/include/rtems/rtems/eventimpl.h (modified) rtems: Update event documentation Wed, 14 Oct 2020 09:04:12 GMT Sebastian Huber [83c37fc] * cpukit/include/rtems/rtems/eventimpl.h (modified) rtems: Remove unused _Event_Timeout() Wed, 14 Oct 2020 09:02:25 GMT Sebastian Huber [acf1a987] * cpukit/include/rtems/rtems/eventimpl.h (modified) rtems: Remove EVENT_SETS_NONE_PENDING This define was only used in ... Wed, 14 Oct 2020 09:01:32 GMT Sebastian Huber [422b003] * cpukit/include/rtems/rtems/eventimpl.h (modified) rtems: Remove unused EVENT_CURRENT Wed, 14 Oct 2020 08:57:35 GMT Sebastian Huber [72811c7] * cpukit/include/rtems/rtems/eventdata.h (modified) * cpukit/include/rtems/rtems/eventimpl.h (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) rtems: Canonicalize task event file documentation Tue, 13 Oct 2020 13:52:56 GMT Sebastian Huber [bdfc58fb] * cpukit/include/rtems/libio.h (modified) libio: Move to RTEMS implementation group Tue, 13 Oct 2020 12:35:18 GMT Sebastian Huber [f1d932d5] * cpukit/doxygen.h (modified) * cpukit/doxygen/top-level-groups.h (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/extensionimpl.h (modified) * cpukit/include/rtems/libcsupport.h (modified) * cpukit/include/rtems/posix/posixapi.h (modified) * cpukit/include/rtems/rtems/asrimpl.h (modified) * cpukit/include/rtems/rtems/attrimpl.h (modified) * cpukit/include/rtems/rtems/barrierimpl.h (modified) * cpukit/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/include/rtems/rtems/eventimpl.h (modified) * cpukit/include/rtems/rtems/messageimpl.h (modified) * cpukit/include/rtems/rtems/modesimpl.h (modified) * cpukit/include/rtems/rtems/objectimpl.h (modified) * cpukit/include/rtems/rtems/optionsimpl.h (modified) * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/rtems/regionimpl.h (modified) * cpukit/include/rtems/rtems/semimpl.h (modified) * cpukit/include/rtems/rtems/signalimpl.h (modified) * cpukit/include/rtems/rtems/statusimpl.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/include/rtems/rtems/timerimpl.h (modified) * cpukit/include/rtems/score/object.h (modified) doxygen: Rename Internal to Implementation Use a top-level ... Fri, 20 Nov 2020 07:10:06 GMT Sebastian Huber [c13fd2d] * cpukit/include/rtems/score/basedefs.h (modified) score: Restore RTEMS_COMPILER_UNUSED_ATTRIBUTE Commit ... Thu, 19 Nov 2020 07:40:25 GMT Sebastian Huber [298b5ef1] * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/score/src/stackallocatorinit.c (modified) config: Initialize task stack allocator on demand Register a custom ... Thu, 19 Nov 2020 07:40:13 GMT Sebastian Huber [c5af8aa0] * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/score/src/stackallocatorinit.c (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal06.yml (deleted) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal06/init.c (deleted) * testsuites/sptests/spfatal06/spfatal06.doc (deleted) * testsuites/sptests/spfatal06/spfatal06.scn (deleted) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) config: Simplify task stack allocator init Replace runtime checks ... Wed, 11 Nov 2020 16:09:58 GMT Sebastian Huber [78baeb7] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) libtest: Allow assert checks during test begin Allow assert checks ... Wed, 11 Nov 2020 10:27:50 GMT Sebastian Huber [d2bc5945] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-rtems-measure.c (modified) libtest: Rename ValidCache in FullCache This name better reflects ... Tue, 10 Nov 2020 11:02:34 GMT Sebastian Huber [8882635] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-rtems-memory.c (added) * spec/build/cpukit/librtemstest.yml (modified) libtest: Add primitive test case memory allocator This primitive ... Tue, 10 Nov 2020 09:23:10 GMT Sebastian Huber [eae22cc0] * cpukit/Makefile.am (modified) * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-malloc.c (deleted) * cpukit/libtest/t-test.c (modified) * cpukit/libtest/testrun.c (modified) * spec/build/cpukit/librtemstest.yml (modified) * testsuites/libtests/ttest01/init.c (modified) libtest: Make test case allocator configurable Mon, 11 May 2020 12:49:08 GMT Sebastian Huber [21af871] * cpukit/include/rtems/score/basedefs.h (modified) rtems: Generate Change license to ... Wed, 24 Jun 2020 04:35:57 GMT Sebastian Huber [ecc6b2f] * cpukit/include/rtems/rtems/part.h (modified) rtems: Generate Change license to BSD-2-Clause ... Mon, 22 Jun 2020 08:27:29 GMT Sebastian Huber [007ee13] * cpukit/include/rtems/rtems/event.h (modified) rtems: Generate Change license to ... Fri, 05 Jun 2020 12:40:10 GMT Sebastian Huber [f75e240] * cpukit/include/rtems/rtems/attr.h (modified) rtems: Generate Change license to BSD-2-Clause ... Thu, 04 Jun 2020 18:41:12 GMT Sebastian Huber [9b4458e7] * cpukit/include/rtems/rtems/types.h (modified) rtems: Generate Change license to ... Thu, 04 Jun 2020 17:50:25 GMT Sebastian Huber [8de874b] * cpukit/include/rtems/rtems/options.h (modified) rtems: Generate Change license to ... Thu, 04 Jun 2020 14:54:15 GMT Sebastian Huber [e05b100] * cpukit/include/rtems/rtems/modes.h (modified) rtems: Generate Change license to ... Thu, 28 May 2020 11:48:28 GMT Sebastian Huber [c0327d8] * cpukit/include/rtems/rtems/status.h (modified) rtems: Generate Change license to ... Thu, 28 May 2020 11:48:17 GMT Sebastian Huber [da44df3] * cpukit/include/rtems/rtems/config.h (modified) rtems: Generate Change license to ... Thu, 28 May 2020 11:47:15 GMT Sebastian Huber [1af94608] * cpukit/include/rtems/config.h (modified) rtems: Generate Change license to BSD-2-Clause ... Thu, 04 Jun 2020 14:54:36 GMT Sebastian Huber [96559b3] * cpukit/include/rtems/rtems/region.h (modified) * cpukit/include/rtems/rtems/support.h (modified) rtems: Include missing header file Wed, 11 Nov 2020 07:15:02 GMT Sebastian Huber [ced13022] * cpukit/doxygen/appl-config.h (modified) * cpukit/include/rtems.h (modified) * cpukit/include/rtems/io.h (modified) * testsuites/validation/tc-message-construct-errors.c (modified) * testsuites/validation/tc-task-construct-errors.c (modified) * testsuites/validation/ts-validation-0.c (modified) Improve automatically generated warning Thu, 29 Oct 2020 13:11:32 GMT Jan Sommer [da9cc0b] * cpukit/include/rtems/confdefs/libpci.h (modified) confdefs: Add extern C guards to libpci.h Wed, 28 Oct 2020 12:25:45 GMT Sebastian Huber [6823943] * cpukit/include/rtems/score/smplock.h (modified) score: Fix unused parameter 'lock' warning Tue, 13 Oct 2020 11:47:06 GMT Sebastian Huber [3972085] * cpukit/include/rtems/chain.h (modified) * cpukit/include/rtems/rtems/asrimpl.h (modified) * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/include/rtems/score/objectmp.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskconstruct.c (modified) * cpukit/score/src/objectmp.c (modified) Remove *_Is_null() inline functions Simply compare the values ... Fri, 09 Oct 2020 13:40:13 GMT Frank Kühndel [a479686] * cpukit/Makefile.am (modified) * cpukit/include/rtems/bdpart.h (modified) * cpukit/libblock/src/bdpart-mount.c (deleted) * cpukit/libmisc/shell/fdisk.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) shell: Remove not functioning fdisk mount/unmount The shell has an ... Thu, 28 May 2020 13:52:11 GMT Sebastian Huber [8111a6ba] * cpukit/include/rtems/io.h (modified) rtems: Generate The manager documentation is a ... Tue, 06 Oct 2020 05:39:44 GMT Sebastian Huber [d7a48e1] * bsps/include/bsp/bootcard.h (modified) * bsps/powerpc/qoriq/include/bsp.h (modified) * bsps/sparc/leon3/include/leon.h (modified) * cpukit/include/rtems/fatal.h (modified) * cpukit/include/rtems/init.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/score/assert.h (modified) * cpukit/include/rtems/score/basedefs.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/test-info.h (modified) * cpukit/score/cpu/aarch64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) rtems: Improve RTEMS_NO_RETURN attribute Provide RTEMS_NO_RETURN ... Thu, 08 Oct 2020 23:44:36 GMT Chris Johns [89a22be] * cpukit/include/rtems/error.hpp (modified) * cpukit/include/rtems/thread.hpp (modified) * cpukit/librtemscxx/error.cpp (modified) * cpukit/librtemscxx/thread.cpp (modified) librtemscxx: Fix white space to match the coding standard Thu, 08 Oct 2020 08:12:20 GMT Chris Johns [6f2a219f] * cpukit/include/rtems/thread.hpp (modified) * cpukit/librtemscxx/error.cpp (modified) * cpukit/librtemscxx/thread.cpp (modified) librtemscxx: Add join() and detach() to the thread - Do not start ... Wed, 07 Oct 2020 10:12:17 GMT Sebastian Huber [f815d04] * cpukit/include/rtems.h (modified) rtems: Add "Generated from ..." comments Improve file header ... Sat, 03 Oct 2020 06:13:24 GMT Chris Johns [cf95826] * cpukit/include/rtems/error.hpp (added) * cpukit/include/rtems/thread.hpp (added) * cpukit/librtemscxx/error.cpp (added) * cpukit/librtemscxx/thread.cpp (added) * spec/build/cpukit/grp.yml (modified) * spec/build/cpukit/librtemscxx.yml (added) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/rcxx01.yml (added) * testsuites/libtests/rcxx01/init.c (added) * testsuites/libtests/rcxx01/rcxx01.doc (added) * testsuites/libtests/rcxx01/rcxx01.scn (added) * testsuites/libtests/rcxx01/thread.cpp (added) cpukit/librcxx: Add a C++ thread interface with attributes Wed, 30 Sep 2020 12:21:32 GMT Sebastian Huber [97e9728] * cpukit/include/rtems/rtems/part.h (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/sptests/sppartition_err01/init.c (modified) rtems: Add RTEMS_PARTITION_ALIGNMENT Update #4105. Tue, 22 Sep 2020 13:31:34 GMT Kinsey Moore [8387c52] * cpukit/include/rtems/score/tls.h (modified) * cpukit/score/cpu/aarch64/aarch64-context-validate.S (added) * cpukit/score/cpu/aarch64/aarch64-context-volatile-clobber.S (added) * cpukit/score/cpu/aarch64/aarch64-exception-default.S (added) * cpukit/score/cpu/aarch64/aarch64-exception-default.c (added) * cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c (added) * cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S (added) * cpukit/score/cpu/aarch64/aarch64-thread-idle.c (added) * cpukit/score/cpu/aarch64/cpu.c (added) * cpukit/score/cpu/aarch64/cpu_asm.S (added) * cpukit/score/cpu/aarch64/include/libcpu/vectors.h (added) * cpukit/score/cpu/aarch64/include/rtems/asm.h (added) * cpukit/score/cpu/aarch64/include/rtems/score/aarch64.h (added) * cpukit/score/cpu/aarch64/include/rtems/score/cpu.h (added) * cpukit/score/cpu/aarch64/include/rtems/score/cpu_irq.h (added) * cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h (added) * cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h (added) * spec/build/cpukit/cpuaarch64.yml (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Add AArch64 port This adds a CPU port for AArch64(ARMv8) ... Wed, 30 Sep 2020 09:31:58 GMT Sebastian Huber [f2185d10] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/score/wkspacedata.h (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/mallocheap.c (added) * cpukit/score/src/wkspacemallocinitdefault.c (added) * cpukit/score/src/wkspacemallocinitunified.c (added) * spec/build/cpukit/librtemscpu.yml (modified) Decouple the C Program Heap initialization Before this patch ... Sat, 26 Sep 2020 13:18:45 GMT Sebastian Huber [5ff5ce6] * cpukit/include/rtems/io.h (modified) rtems: Remove rtems_io_driver_io_error() The implementation was ... Wed, 23 Sep 2020 14:47:58 GMT Sebastian Huber [4a4f41e] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/message.h (modified) * cpukit/include/rtems/rtems/messageimpl.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/rtems/src/msgqconstruct.c (added) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgwkspace.c (added) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/mptests/mp09/initimpl.h (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/system.h (modified) rtems: Add rtems_message_queue_construct() In contrast to message ... Thu, 24 Sep 2020 07:05:36 GMT Sebastian Huber [24ea1ce] * cpukit/include/rtems/rtems/messagedata.h (modified) * cpukit/libmisc/monitor/mon-queue.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) rtems: Remove Message_queue_Control::attribute_set Add ... Wed, 23 Sep 2020 11:46:38 GMT Sebastian Huber [2c09f54f] * cpukit/headers.am (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coremsgbuffer.h (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Add Move the ... Wed, 23 Sep 2020 08:33:51 GMT Sebastian Huber [69b4fe59] * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/rtems/msgmp.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * testsuites/sptests/spmsgq_err01/init.c (modified) score: Simplify CORE_message_queue_Buffer Merge ... Wed, 23 Sep 2020 08:09:37 GMT Sebastian Huber [5bc7c37] * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/include/rtems/score/status.h (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/score/src/coremsg.c (modified) * testsuites/sptests/sp77/init.c (modified) * testsuites/sptests/spmsgq_err01/init.c (modified) score: Improve _CORE_message_queue_Initialize() Return a status ... Sun, 20 Sep 2020 13:09:48 GMT Sebastian Huber [9f2a207] * cpukit/include/rtems/trace/rtems-trace-buffer-vars.h (modified) * cpukit/libmisc/capture/rtems-trace-buffer-default.c (added) * cpukit/libmisc/capture/rtems-trace-buffer-vars.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) capture: Move default trace data Provide the default trace data in ... Wed, 05 Aug 2020 07:19:20 GMT Sebastian Huber [da27e96] * cpukit/include/rtems/score/schedulerimpl.h (modified) score: Document _Scheduler_Try_to_schedule_node() Wed, 24 Jun 2020 09:23:40 GMT Sebastian Huber [0b410b8a] * cpukit/include/rtems.h (modified) rtems: Generate Change license to BSD-2-Clause according ... Fri, 18 Sep 2020 07:07:46 GMT Sebastian Huber [7892ac0] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/mp.h (modified) rtems: From to Move multiprocessing ... Wed, 24 Jun 2020 08:43:22 GMT Sebastian Huber [c161216d] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/types.h (modified) rtems: From to Move type related ... Wed, 24 Jun 2020 08:40:42 GMT Sebastian Huber [d433b724] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) rtems: From to Move task related ... Wed, 24 Jun 2020 08:39:44 GMT Sebastian Huber [1615b5ff] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/object.h (modified) rtems: From to Move object related ... Wed, 24 Jun 2020 08:36:16 GMT Sebastian Huber [5353ea89] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/sapi/src/getcopyrightnotice.c (modified) * cpukit/sapi/src/getversionstring.c (modified) rtems: Move from to Move configuration ... Fri, 03 Jul 2020 10:41:47 GMT Sebastian Huber [96ea30f0] * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) score: Improve Scheduler Handler documentation Thu, 17 Sep 2020 18:07:08 GMT Sebastian Huber [2f65e13] * cpukit/include/rtems/rtems/tasks.h (modified) rtems: Fix typo Update #3959. Thu, 09 Apr 2020 10:12:13 GMT Sebastian Huber [6942e5f] * cpukit/doxygen/appl-config.h (modified) * cpukit/include/rtems/confdefs/threads.h (modified) * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/rtems/src/taskconstruct.c (added) * cpukit/rtems/src/taskcreate.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/sp01/sp01.doc (modified) * testsuites/sptests/sp01/system.h (modified) rtems: Add rtems_task_construct() In contrast to ... Thu, 10 Sep 2020 14:35:09 GMT Sebastian Huber [c312f31] * cpukit/doxygen/appl-config.h (modified) * cpukit/include/rtems/confdefs/threads.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/src/tlsallocsize.c (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal33.yml (added) * testsuites/sptests/spfatal33/init.c (added) * testsuites/sptests/spfatal33/spfatal33.doc (added) * testsuites/sptests/spfatal33/spfatal33.scn (added) * testsuites/sptests/spinternalerror02/init.c (modified) CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE Add this application ... Wed, 16 Sep 2020 08:34:12 GMT Sebastian Huber [dce1cdf1] * cpukit/include/rtems/score/basedefs.h (modified) rtems: Add RTEMS_ALIGN_UP() Update #3959. Update #4074. Wed, 16 Sep 2020 08:33:52 GMT Sebastian Huber [641b31a4] * cpukit/include/rtems/score/basedefs.h (modified) rtems: Add RTEMS_ALIGN_DOWN() Update #3959. Update #4074. Thu, 09 Apr 2020 10:11:19 GMT Sebastian Huber [aedd92d] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/score/src/stackallocatorfreenothing.c (added) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Add stack free handler to TCB This avoids a dependency to ... Thu, 09 Apr 2020 13:17:46 GMT Sebastian Huber [d817220] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/score/src/stackallocator.c (modified) * cpukit/score/src/stackallocatorinit.c (added) * cpukit/score/src/thread.c (modified) score: Add _Stack_Allocator_do_initialize() Do the stack allocator ... Wed, 08 Apr 2020 09:30:32 GMT Sebastian Huber [354c2b5] * cpukit/headers.am (modified) * cpukit/include/rtems/posix/keyimpl.h (modified) * cpukit/include/rtems/score/freechain.h (modified) * cpukit/include/rtems/score/freechainimpl.h (added) * cpukit/score/src/freechain.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadallocateunlimited.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/sptests/spfreechain01/init.c (modified) score: Add Hide implementation ... Wed, 08 Apr 2020 09:21:27 GMT Sebastian Huber [91c811a1] * cpukit/include/rtems/score/freechain.h (modified) * cpukit/score/src/freechain.c (modified) score: Add _Freechain_Push() Update #3959. Thu, 16 Apr 2020 10:13:31 GMT Sebastian Huber [ced28f2] * cpukit/include/rtems/confdefs/libio.h (modified) config: Provide file descriptors only if necessary Only provide the ... Wed, 24 Jun 2020 11:54:23 GMT Sebastian Huber [c7e3085] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/rtems/objectimpl.h (added) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/rtems/src/barrierident.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/rtemsnametoid.c (added) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/sapi/src/extensionident.c (modified) * cpukit/score/src/objectnametoid.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) rtems: Add _RTEMS_Name_to_id() Simplify object name to identifier ... Wed, 24 Jun 2020 11:12:49 GMT Sebastian Huber [33dbb33] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/objectmp.h (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnametoid.c (modified) score: Constify objects name to id functions Thu, 16 Apr 2020 10:12:53 GMT Sebastian Huber [a7a0a364] * cpukit/include/rtems/confdefs/threads.h (modified) config: Conditionally include header Fri, 21 Aug 2020 06:42:12 GMT Sebastian Huber [81efe37c] * cpukit/include/rtems/confdefs/mpci.h (modified) * cpukit/include/rtems/confdefs/threads.h (modified) confdefs: Fix cyclic dependency Close #4061. Wed, 19 Aug 2020 04:47:38 GMT Sebastian Huber [05d5772] * cpukit/include/adainclude/rtems.ads (modified) ada: Add missing attributes Mon, 17 Aug 2020 10:29:24 GMT Sebastian Huber [593a67f6] * cpukit/include/rtems/rtems/attr.h (modified) rtems: Use unique option values The RTEMS_BARRIER_AUTOMATIC_RELEASE ... Fri, 14 Aug 2020 07:56:51 GMT Sebastian Huber [c7289484] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) * testsuites/libtests/ttest01/init.c (modified) * testsuites/libtests/ttest01/test-plan.c (modified) libtest: Add T_push_plan() and T_pop_plan() Update #3199. Thu, 13 Aug 2020 09:33:47 GMT Sebastian Huber [72960bc7] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) * testsuites/libtests/ttest01/test-destructor.c (modified) * testsuites/libtests/ttest01/test-plan.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) libtest: Change T_step() and T_assert_step() Normally, the expected ... Thu, 13 Aug 2020 07:59:19 GMT Sebastian Huber [5383d4db] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) * testsuites/libtests/ttest01/init.c (modified) * testsuites/libtests/ttest01/test-fixture.c (modified) * testsuites/libtests/ttest02/init.c (modified) libtest: Add fixture steps Support a new test plan for each nested ... Thu, 13 Aug 2020 05:44:25 GMT Sebastian Huber [5d614fd] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) libtest: Add T_puts() Update #3199. Wed, 12 Aug 2020 14:57:39 GMT Sebastian Huber [5a8114c6] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) * testsuites/libtests/ttest01/test-fixture.c (modified) libtest: Change fixture scope method Return the produced character ... Tue, 11 Aug 2020 08:41:26 GMT Aschref Ben Thabet [5869c647] * cpukit/include/rtems/printer.h (modified) rtems/printer.h Fix build warnings -Wclass-memaccess Fri, 07 Aug 2020 18:30:39 GMT Sebastian Huber [c1354f0] * cpukit/Makefile.am (modified) * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-thread-switch.c (added) * testsuites/libtests/ttest02/init.c (modified) libtest: Add T_thread_switch_record() Add support to record thread ...
