# # ChangeLog for cpukit/include/rtems in rtems # # Generated by Trac 1.2.1.dev0 # 06/17/24 09:53:46 Wed, 03 Apr 2019 06:49:07 GMT Andreas Dachsberger [7b09032] * cpukit/doxygen.h (modified) * cpukit/include/rtems/bspcmdline.h (modified) * cpukit/include/rtems/cpuuse.h (modified) * cpukit/include/rtems/dumpbuf.h (modified) * cpukit/include/rtems/mw_uid.h (modified) * cpukit/include/rtems/stackchk.h (modified) * cpukit/include/rtems/stringto.h (modified) * cpukit/include/rtems/untar.h (modified) doxygen: Split up "libmisc" subgroups and removed libmisc Update #3706. Wed, 03 Apr 2019 06:31:25 GMT Andreas Dachsberger [c9bd696] * cpukit/doxygen.h (modified) * cpukit/include/rtems/capture.h (modified) * cpukit/include/rtems/recorddata.h (modified) doxygen: New API subgroup Tracing Update #3706. Wed, 03 Apr 2019 06:22:08 GMT Andreas Dachsberger [51f8d73b] * cpukit/include/rtems/inttypes.h (modified) doxygen: Added inttypes.h to Print Support Update #3706. Wed, 03 Apr 2019 05:45:22 GMT Andreas Dachsberger [57a076cd] * cpukit/include/rtems/rtl/rap.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/include/rtems/status-checks.h (modified) * cpukit/include/rtems/test.h (modified) doxygen: Added subclasses to API Update #3706. RTEMS Application ... Tue, 02 Apr 2019 12:52:35 GMT Andreas Dachsberger [7155b5bc] * cpukit/include/rtems/devnull.h (modified) * cpukit/include/rtems/devzero.h (modified) doxygen: Zero and Null Device Drivers now in Device Drivers Update ... Tue, 02 Apr 2019 12:45:28 GMT Andreas Dachsberger [7e5ed6b] * cpukit/doxygen.h (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/print.h (modified) doxygen: Print Support now in API->IO Update #3706. Tue, 02 Apr 2019 12:36:32 GMT Andreas Dachsberger [74bfbc1f] * cpukit/doxygen.h (modified) * cpukit/include/rtems/tm27-default.h (modified) doxygen: Time Test 27 now in Device Drivers Update #3706. Tue, 02 Apr 2019 12:32:52 GMT Andreas Dachsberger [b8cff58] * cpukit/doxygen.h (modified) * cpukit/include/rtems/btimer.h (modified) doxygen: Benchmark Timer Driver Interface now in Device Drivers ... Tue, 02 Apr 2019 12:26:39 GMT Andreas Dachsberger [2bc058d] * cpukit/include/rtems/rtc.h (modified) doxygen: Put Real-Timer Clock Driver Interface into group Device ... Tue, 02 Apr 2019 12:15:50 GMT Andreas Dachsberger [885c9a70] * cpukit/include/rtems/print.h (modified) doxygen: Put Print Support in IO Update #3706. Tue, 02 Apr 2019 12:14:30 GMT Andreas Dachsberger [2a56a1cf] * cpukit/include/rtems/tod.h (modified) doxygen: Real Time Clock Time of Day API Definition in BSP->Shared ... Tue, 02 Apr 2019 11:55:19 GMT Andreas Dachsberger [f91da319] * cpukit/include/rtems/libcsupport.h (modified) * cpukit/include/rtems/posix/posixapi.h (modified) doxygen: Put C Library Support and POSIX in Internal Update #3706. Tue, 02 Apr 2019 11:43:08 GMT Andreas Dachsberger [b6b00917] * cpukit/include/rtems/libi2c.h (modified) * cpukit/include/rtems/media.h (modified) * cpukit/include/rtems/profiling.h (modified) doxygen: Added some subgroups to API and IO I2C library, Media ... Tue, 02 Apr 2019 11:33:49 GMT Andreas Dachsberger [e78e7fe0] * cpukit/include/rtems/recorddata.h (modified) * cpukit/include/rtems/timecounter.h (modified) * cpukit/include/rtems/version.h (modified) * cpukit/sapi/src/version.c (modified) doxygen: Added Version to API->Classic Update #3706. Tue, 02 Apr 2019 11:32:40 GMT Andreas Dachsberger [6b23763e] * cpukit/include/rtems/fb.h (modified) doxygen: Added Frame Buffer Device Driver Interface to Device Drivers ... Tue, 02 Apr 2019 11:30:31 GMT Andreas Dachsberger [4b841b3] * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/ftpfs.h (modified) * cpukit/include/rtems/libio_.h (modified) doxygen: Added some subgroups to IO Library Update #3706. Types ... Tue, 02 Apr 2019 11:05:29 GMT Andreas Dachsberger [333bead] * cpukit/include/rtems/rtems/barrierdata.h (modified) doxygen: Removed XXX group Update #3706. Content was added to ... Tue, 02 Apr 2019 10:11:21 GMT Andreas Dachsberger [529d251b] * cpukit/doxygen.h (modified) * cpukit/include/rtems/bspcmdline.h (modified) doxygen: Added libmisc group and libmisc mouse group Update #3706. ... Tue, 02 Apr 2019 10:09:49 GMT Andreas Dachsberger [0f02e6f] * cpukit/doxygen.h (modified) * cpukit/include/rtems/bdbuf.h (modified) doxygen: Added toplevel group for device drivers Update #3706. Tue, 02 Apr 2019 10:06:30 GMT Andreas Dachsberger [b7927ef] * cpukit/include/rtems/assoc.h (modified) * cpukit/include/rtems/bsd.h (modified) doxygen: Added further groups to RTEMSAPI Update #3706. ... Tue, 02 Apr 2019 10:01:42 GMT Andreas Dachsberger [ff1f374] * cpukit/include/rtems/rtems/mainpage.h (modified) doxygen: Added Mainpage to RTEMSAPIClassic Update #3706. Tue, 02 Apr 2019 08:14:56 GMT Andreas Dachsberger [6644867] * cpukit/include/rtems/extensionimpl.h (modified) doxygen: User Extensions Implementation group now in ... Wed, 03 Apr 2019 10:44:42 GMT Sebastian Huber [fbe8a7a] * cpukit/include/rtems/rtems/message.h (modified) * cpukit/include/rtems/score/rbtree.h (modified) * cpukit/include/rtems/score/wkspace.h (modified) doxygen: Rework some Doxygen comments They are intended as examples ... Mon, 01 Apr 2019 09:48:57 GMT Andreas Dachsberger [058f637] * cpukit/include/rtems/score/corerwlockimpl.h (modified) doxygen: score: Added ScoreRWLock to Score group Update #3706. Thu, 28 Mar 2019 12:27:05 GMT Andreas Dachsberger [b07c721] * cpukit/doxygen.h (modified) * cpukit/include/rtems.h (modified) * cpukit/include/rtems/chain.h (modified) * cpukit/include/rtems/counter.h (modified) * cpukit/include/rtems/extension.h (modified) * cpukit/include/rtems/fatal.h (modified) * cpukit/include/rtems/io.h (modified) * cpukit/include/rtems/rbheap.h (modified) * cpukit/include/rtems/rbtree.h (modified) * cpukit/include/rtems/rtems/asr.h (modified) * cpukit/include/rtems/rtems/asrimpl.h (modified) * cpukit/include/rtems/rtems/attr.h (modified) * cpukit/include/rtems/rtems/attrimpl.h (modified) * cpukit/include/rtems/rtems/barrier.h (modified) * cpukit/include/rtems/rtems/barrierimpl.h (modified) * cpukit/include/rtems/rtems/cache.h (modified) * cpukit/include/rtems/rtems/clock.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/include/rtems/rtems/dpmem.h (modified) * cpukit/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/include/rtems/rtems/event.h (modified) * cpukit/include/rtems/rtems/eventimpl.h (modified) * cpukit/include/rtems/rtems/eventmp.h (modified) * cpukit/include/rtems/rtems/intr.h (modified) * cpukit/include/rtems/rtems/mainpage.h (modified) * cpukit/include/rtems/rtems/message.h (modified) * cpukit/include/rtems/rtems/messageimpl.h (modified) * cpukit/include/rtems/rtems/modes.h (modified) * cpukit/include/rtems/rtems/modesimpl.h (modified) * cpukit/include/rtems/rtems/mp.h (modified) * cpukit/include/rtems/rtems/object.h (modified) * cpukit/include/rtems/rtems/options.h (modified) * cpukit/include/rtems/rtems/optionsimpl.h (modified) * cpukit/include/rtems/rtems/part.h (modified) * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/rtems/ratemon.h (modified) * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/rtems/region.h (modified) * cpukit/include/rtems/rtems/regionimpl.h (modified) * cpukit/include/rtems/rtems/sem.h (modified) * cpukit/include/rtems/rtems/semimpl.h (modified) * cpukit/include/rtems/rtems/semmp.h (modified) * cpukit/include/rtems/rtems/signal.h (modified) * cpukit/include/rtems/rtems/signalimpl.h (modified) * cpukit/include/rtems/rtems/smp.h (modified) * cpukit/include/rtems/rtems/status.h (modified) * cpukit/include/rtems/rtems/statusimpl.h (modified) * cpukit/include/rtems/rtems/support.h (modified) * cpukit/include/rtems/rtems/taskmp.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/include/rtems/rtems/timer.h (modified) * cpukit/include/rtems/rtems/timerimpl.h (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/include/rtems/timespec.h (modified) doxygen: Restructured cpukit/include/rtems/rtems Update #3706. Thu, 28 Mar 2019 10:42:58 GMT Andreas Dachsberger [b86148a] * cpukit/include/rtems/posix/config.h (modified) doxygen: Reviewed cpukit/include/rtems/posix Update #3706. Thu, 28 Mar 2019 09:28:40 GMT Andreas Dachsberger [7a722e75] * cpukit/include/rtems/rtems/asr.h (modified) * cpukit/include/rtems/rtems/attr.h (modified) * cpukit/include/rtems/rtems/clock.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/include/rtems/rtems/eventmp.h (modified) * cpukit/include/rtems/rtems/intr.h (modified) * cpukit/include/rtems/rtems/mainpage.h (modified) * cpukit/include/rtems/rtems/modes.h (modified) * cpukit/include/rtems/rtems/mp.h (modified) * cpukit/include/rtems/rtems/object.h (modified) * cpukit/include/rtems/rtems/options.h (modified) * cpukit/include/rtems/rtems/ratemon.h (modified) * cpukit/include/rtems/rtems/semmp.h (modified) * cpukit/include/rtems/rtems/status.h (modified) * cpukit/include/rtems/rtems/support.h (modified) * cpukit/include/rtems/rtems/taskmp.h (modified) doxygen: Reviewed cpukit/include/rtems/rtems Update #3706. Thu, 28 Mar 2019 08:46:08 GMT Andreas Dachsberger [69d6671f] * cpukit/include/rtems/score/isrlevel.h (modified) * cpukit/include/rtems/score/profiling.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/include/rtems/score/smplock.h (modified) * cpukit/include/rtems/score/todimpl.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) doxygen: Reviewed cpukit/include/rtems/score Update #3706. Mon, 25 Mar 2019 09:45:25 GMT Sebastian Huber [5526527e] * cpukit/include/rtems/score/object.h (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/include/rtems/asm.h (modified) * cpukit/score/cpu/arm/include/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/epiphany/epiphany-exception-handler.S (modified) * cpukit/score/cpu/epiphany/include/rtems/score/epiphany-utility.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/or1k-exception-handler-low.S (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) * cpukit/score/src/objectshrinkinformation.c (modified) score: Rename ScoreCPU Doxygen group Update #3706. Mon, 25 Mar 2019 09:31:51 GMT Sebastian Huber [40d15f5] * cpukit/doxygen.h (added) * cpukit/include/rtems/score/object.h (modified) score: Add implementation top-level group Update #3706. Wed, 20 Mar 2019 10:03:12 GMT Sebastian Huber [311270c] * cpukit/include/rtems/score/objectdata.h (modified) score: Update Objects_Information documentation Sat, 09 Mar 2019 18:04:42 GMT Chris Johns [dad6fd43] * cpukit/include/rtems/rtl/rtl-archive.h (modified) * cpukit/include/rtems/rtl/rtl-shell.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-trace.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl10/dl-load.c (added) * testsuites/libtests/dl10/dl-load.h (added) * testsuites/libtests/dl10/dl-o1.c (added) * testsuites/libtests/dl10/dl-o1.h (added) * testsuites/libtests/dl10/dl-o2.c (added) * testsuites/libtests/dl10/dl-o2.h (added) * testsuites/libtests/dl10/dl-o3.c (added) * testsuites/libtests/dl10/dl-o3.h (added) * testsuites/libtests/dl10/dl-o4.c (added) * testsuites/libtests/dl10/dl-o4.h (added) * testsuites/libtests/dl10/dl-o5.c (added) * testsuites/libtests/dl10/dl-o5.h (added) * testsuites/libtests/dl10/dl-o6.c (added) * testsuites/libtests/dl10/dl10.doc (added) * testsuites/libtests/dl10/dl10.scn (added) * testsuites/libtests/dl10/init.c (added) * testsuites/testdata/rtems.tcfg (modified) libdl: Add an archive command - The archive command lists archives, ... Fri, 01 Feb 2019 09:00:36 GMT Sebastian Huber [3fe2155] * bsps/arm/shared/start/bsp-start-in-hyp-support.S (modified) * bsps/arm/shared/start/bsp-start-memcpy.S (modified) * bsps/i386/shared/irq/irq_asm.S (modified) * bsps/m68k/csb360/start/idle-mcf5272.c (modified) * bsps/m68k/shared/fpsp/rtems_fpsp.c (modified) * bsps/m68k/shared/m68kidle.c (modified) * bsps/powerpc/beatnik/start/bspstart.c (modified) * bsps/powerpc/include/libcpu/powerpc-utility.h (modified) * bsps/powerpc/motorola_powerpc/bootloader/misc.c (modified) * bsps/powerpc/motorola_powerpc/console/polled_io.c (modified) * bsps/powerpc/mvme5500/irq/BSP_irq.c (modified) * bsps/powerpc/mvme5500/start/bspstart.c (modified) * bsps/powerpc/shared/btimer/btimer-ppc-dec.c (modified) * bsps/powerpc/shared/cpu.c (modified) * bsps/powerpc/shared/exceptions/ppc_exc.S (modified) * bsps/powerpc/virtex/include/bsp/opbintctrl.h (modified) * bsps/sh/gensh1/start/cpu_asm.c (modified) * bsps/sh/gensh2/start/cpu_asm.c (modified) * bsps/sh/gensh4/start/cpu_asm.c (modified) * bsps/sh/gensh4/start/ispsh7750.c (modified) * bsps/sh/shsim/start/cpu_asm.c (modified) * cpukit/include/rtems/posix/aio_misc.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/libcsupport/src/getegid.c (modified) * cpukit/libcsupport/src/geteuid.c (modified) * cpukit/libcsupport/src/getlogin.c (modified) * cpukit/libcsupport/src/getppid.c (modified) * cpukit/libcsupport/src/setegid.c (modified) * cpukit/libgnat/adasupp.c (modified) * cpukit/libmisc/shell/main_help.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell_getchar.c (modified) * cpukit/libmisc/shell/shell_getprompt.c (modified) * cpukit/posix/src/aio_cancel.c (modified) * cpukit/posix/src/aio_error.c (modified) * cpukit/posix/src/aio_fsync.c (modified) * cpukit/posix/src/aio_read.c (modified) * cpukit/posix/src/aio_return.c (modified) * cpukit/posix/src/aio_suspend.c (modified) * cpukit/posix/src/aio_write.c (modified) * cpukit/posix/src/barrierattrinit.c (modified) * cpukit/posix/src/clockgetcpuclockid.c (modified) * cpukit/posix/src/condattrgetpshared.c (modified) * cpukit/posix/src/conddefaultattributes.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/kill_r.c (modified) * cpukit/posix/src/lio_listio.c (modified) * cpukit/posix/src/mqueuesend.c (modified) * cpukit/posix/src/mutexattrsetprotocol.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/mutexattrsettype.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalsetprocesssignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/psxtimerdelete.c (modified) * cpukit/posix/src/pthreadgetcpuclockid.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/rwlockattrinit.c (modified) * cpukit/posix/src/sched_getparam.c (modified) * cpukit/posix/src/sched_getprioritymin.c (modified) * cpukit/posix/src/sched_getscheduler.c (modified) * cpukit/posix/src/sched_setparam.c (modified) * cpukit/posix/src/sched_setscheduler.c (modified) * cpukit/posix/src/sigaddset.c (modified) * cpukit/posix/src/sigdelset.c (modified) * cpukit/posix/src/sigemptyset.c (modified) * cpukit/posix/src/sigfillset.c (modified) * cpukit/posix/src/sigismember.c (modified) * cpukit/posix/src/sigpending.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/timergetoverrun.c (modified) * cpukit/rtems/src/barrierident.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/rtems/src/modes.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemsbuildname.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskself.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/rtems/src/workspace.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/extensionident.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/getversionstring.c (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/include/rtems/asm.h (modified) * cpukit/score/cpu/moxie/cpu.c (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/riscv/include/libcpu/access.h (modified) * cpukit/score/cpu/sh/context.c (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/include/libcpu/access.h (modified) * cpukit/score/cpu/sparc/include/libcpu/byteorder.h (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/v850/cpu.c (modified) * cpukit/score/cpu/x86_64/cpu.c (modified) * cpukit/score/src/coremsgflushwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapgetfreeinfo.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/heapwalk.c (modified) * cpukit/score/src/pheapallocate.c (modified) * cpukit/score/src/pheapextend.c (modified) * cpukit/score/src/pheapfree.c (modified) * cpukit/score/src/pheapgetblocksize.c (modified) * cpukit/score/src/pheapgetfreeinfo.c (modified) * cpukit/score/src/pheapgetinfo.c (modified) * cpukit/score/src/pheapgetsize.c (modified) * cpukit/score/src/pheapinit.c (modified) * cpukit/score/src/pheapresizeblock.c (modified) * cpukit/score/src/schedulercbsgetapprovedbudget.c (modified) * cpukit/score/src/schedulercbsgetparameters.c (modified) * cpukit/score/src/schedulercbsgetserverid.c (modified) * cpukit/score/src/timespeclessthan.c (modified) * testsuites/sptests/spsize/size.c (modified) Remove superfluous includes Thu, 31 Jan 2019 13:45:17 GMT Sebastian Huber [20d472d] * bsps/shared/rtems-version.c (modified) * cpukit/include/rtems/version.h (modified) * testsuites/sptests/spversion01/init.c (modified) Add rtems_board_support_package() Tue, 12 Mar 2019 08:00:51 GMT Sebastian Huber [01a5ced5] * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-text.c (modified) record: Add more system events Update #3665. Tue, 12 Mar 2019 07:27:52 GMT Sebastian Huber [ebb8c28e] * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-text.c (modified) record: Add system call entry/exit events This corresponds to the ... Tue, 12 Mar 2019 07:15:19 GMT Sebastian Huber [d91951fb] * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-client.c (modified) * cpukit/libtrace/record/record-server.c (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record.c (modified) * testsuites/libtests/record01/init.c (modified) record: Rename internal per-CPU events Update #3665. Wed, 27 Feb 2019 09:53:30 GMT Sebastian Huber [feea03b6] * bsps/arm/include/bsp/arm-errata.h (modified) * bsps/arm/include/bsp/arm-release-id.h (modified) * bsps/arm/include/cmsis_gcc.h (modified) * bsps/arm/include/core_cm7.h (modified) * bsps/arm/include/core_cmFunc.h (modified) * bsps/arm/include/core_cmInstr.h (modified) * bsps/arm/include/core_cmSimd.h (modified) * bsps/arm/lpc176x/btimer/btimer.c (modified) * bsps/arm/lpc176x/can/can.c (modified) * bsps/arm/lpc176x/gpio/lpc-gpio.c (modified) * bsps/arm/lpc176x/include/bsp/adc-defs.h (modified) * bsps/arm/lpc176x/include/bsp/adc.h (modified) * bsps/arm/lpc176x/include/bsp/can-defs.h (modified) * bsps/arm/lpc176x/include/bsp/can.h (modified) * bsps/arm/lpc176x/include/bsp/common-types.h (modified) * bsps/arm/lpc176x/include/bsp/gpio-defs.h (modified) * bsps/arm/lpc176x/include/bsp/io-defs.h (modified) * bsps/arm/lpc176x/include/bsp/io.h (modified) * bsps/arm/lpc176x/include/bsp/lpc-gpio.h (modified) * bsps/arm/lpc176x/include/bsp/lpc176x.h (modified) * bsps/arm/lpc176x/include/bsp/mbed-pinmap.h (modified) * bsps/arm/lpc176x/include/bsp/pwmout-defs.h (modified) * bsps/arm/lpc176x/include/bsp/pwmout.h (modified) * bsps/arm/lpc176x/include/bsp/timer-defs.h (modified) * bsps/arm/lpc176x/include/bsp/timer.h (modified) * bsps/arm/lpc176x/include/bsp/watchdog-defs.h (modified) * bsps/arm/lpc176x/include/bsp/watchdog.h (modified) * bsps/arm/lpc176x/pwm/pwmout.c (modified) * bsps/arm/lpc176x/start/adc.c (modified) * bsps/arm/lpc176x/start/bspstarthooks.c (modified) * bsps/arm/lpc176x/start/io.c (modified) * bsps/arm/lpc176x/start/watchdog.c (modified) * bsps/arm/lpc176x/timer/timer.c (modified) * bsps/arm/lpc32xx/include/tm27.h (modified) * bsps/arm/raspberrypi/gpio/gpio-interfaces-pi1-rev2.c (modified) * bsps/arm/raspberrypi/gpio/rpi-gpio.c (modified) * bsps/arm/raspberrypi/i2c/i2c.c (modified) * bsps/arm/raspberrypi/include/bsp/i2c.h (modified) * bsps/arm/raspberrypi/include/bsp/raspberrypi.h (modified) * bsps/arm/raspberrypi/include/bsp/rpi-gpio.h (modified) * bsps/arm/raspberrypi/include/bsp/spi.h (modified) * bsps/arm/raspberrypi/irq/irq.c (modified) * bsps/arm/raspberrypi/spi/spi.c (modified) * bsps/arm/shared/start/bsp-start-init-registers.S (modified) * bsps/arm/tms570/clock/clock.c (modified) * bsps/arm/tms570/console/printk-support.c (modified) * bsps/arm/tms570/console/tms570-sci.c (modified) * bsps/arm/tms570/include/bsp.h (modified) * bsps/arm/tms570/include/bsp/irq.h (modified) * bsps/arm/tms570/include/bsp/system-clocks.h (modified) * bsps/arm/tms570/include/bsp/tms570-pinmux.h (modified) * bsps/arm/tms570/include/bsp/tms570-pins.h (modified) * bsps/arm/tms570/include/bsp/tms570-pom.h (modified) * bsps/arm/tms570/include/bsp/tms570-rti.h (modified) * bsps/arm/tms570/include/bsp/tms570-sci-driver.h (modified) * bsps/arm/tms570/include/bsp/tms570-sci.h (modified) * bsps/arm/tms570/include/bsp/tms570-vim.h (modified) * bsps/arm/tms570/include/bsp/tms570_selftest.h (modified) * bsps/arm/tms570/include/bsp/tms570_selftest_parity.h (modified) * bsps/arm/tms570/include/bsp/tms570lc4357-pins.h (modified) * bsps/arm/tms570/include/bsp/tms570ls3137zwt-pins.h (modified) * bsps/arm/tms570/irq/irq.c (modified) * bsps/arm/tms570/start/bspreset.c (modified) * bsps/arm/tms570/start/bspstart.c (modified) * bsps/arm/tms570/start/bspstarthooks.c (modified) * bsps/arm/tms570/start/init_emif_sdram.c (modified) * bsps/arm/tms570/start/init_esm.c (modified) * bsps/arm/tms570/start/init_pinmux.c (modified) * bsps/arm/tms570/start/init_system.c (modified) * bsps/arm/tms570/start/pinmux.c (modified) * bsps/arm/tms570/start/tms570-pom.c (modified) * bsps/arm/tms570/start/tms570_selftest.c (modified) * bsps/arm/tms570/start/tms570_selftest_par_can.c (modified) * bsps/arm/tms570/start/tms570_selftest_par_mibspi.c (modified) * bsps/arm/tms570/start/tms570_selftest_par_std.c (modified) * bsps/arm/tms570/start/tms570_selftest_parity.c (modified) * bsps/arm/tms570/start/tms570_tcram_tests.c (modified) * bsps/bfin/TLL6527M/console/console.c (modified) * bsps/bfin/TLL6527M/include/bsp.h (modified) * bsps/bfin/TLL6527M/start/interrupt.c (modified) * bsps/bfin/include/bf52x.h (modified) * bsps/bfin/include/bsp/interrupt.h (modified) * bsps/i386/include/bsp/realmode_int.h (modified) * bsps/i386/include/libcpu/page.h (modified) * bsps/i386/pc386/console/fb_vesa_rm.c (modified) * bsps/i386/pc386/include/bsp/fb_default_mode.h (modified) * bsps/i386/pc386/include/bsp/fb_vesa.h (modified) * bsps/i386/pc386/include/bsp/vbe3.h (modified) * bsps/i386/pc386/include/edid.h (modified) * bsps/i386/pc386/start/realmode_int.c (modified) * bsps/include/bsp/gpio.h (modified) * bsps/powerpc/include/rtems/powerpc/powerpc.h (modified) * bsps/powerpc/virtex4/start/start.S (modified) * bsps/powerpc/virtex5/start/start.S (modified) * bsps/shared/dev/gpio/gpio-support.c (modified) * cpukit/include/memory.h (modified) * cpukit/include/rtems/assoc.h (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/bspcmdline.h (modified) * cpukit/include/rtems/btimer.h (modified) * cpukit/include/rtems/capture-cli.h (modified) * cpukit/include/rtems/capture.h (modified) * cpukit/include/rtems/captureimpl.h (modified) * cpukit/include/rtems/concat.h (modified) * cpukit/include/rtems/cpuuse.h (modified) * cpukit/include/rtems/devfs.h (modified) * cpukit/include/rtems/devzero.h (modified) * cpukit/include/rtems/endian.h (modified) * cpukit/include/rtems/error.h (modified) * cpukit/include/rtems/fb.h (modified) * cpukit/include/rtems/framebuffer.h (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/include/rtems/fsmount.h (modified) * cpukit/include/rtems/gxx_wrappers.h (modified) * cpukit/include/rtems/inttypes.h (modified) * cpukit/include/rtems/iosupp.h (modified) * cpukit/include/rtems/irq.h (modified) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/monitor.h (modified) * cpukit/include/rtems/mouse_parser.h (modified) * cpukit/include/rtems/mw_uid.h (modified) * cpukit/include/rtems/nvdisk-sram.h (modified) * cpukit/include/rtems/nvdisk.h (modified) * cpukit/include/rtems/pci.h (modified) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/include/rtems/print.h (modified) * cpukit/include/rtems/printer.h (modified) * cpukit/include/rtems/qreslib.h (modified) * cpukit/include/rtems/rtems/asr.h (modified) * cpukit/include/rtems/rtems/attr.h (modified) * cpukit/include/rtems/rtems/clock.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/include/rtems/rtems/eventmp.h (modified) * cpukit/include/rtems/rtems/intr.h (modified) * cpukit/include/rtems/rtems/mainpage.h (modified) * cpukit/include/rtems/rtems/modes.h (modified) * cpukit/include/rtems/rtems/mp.h (modified) * cpukit/include/rtems/rtems/msgmp.h (modified) * cpukit/include/rtems/rtems/object.h (modified) * cpukit/include/rtems/rtems/options.h (modified) * cpukit/include/rtems/rtems/partmp.h (modified) * cpukit/include/rtems/rtems/ratemon.h (modified) * cpukit/include/rtems/rtems/semmp.h (modified) * cpukit/include/rtems/rtems/signalmp.h (modified) * cpukit/include/rtems/rtems/status.h (modified) * cpukit/include/rtems/rtems/taskmp.h (modified) * cpukit/include/rtems/score/address.h (modified) * cpukit/include/rtems/score/context.h (modified) * cpukit/include/rtems/score/copyrt.h (modified) * cpukit/include/rtems/score/corebarrier.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coresem.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/isr.h (modified) * cpukit/include/rtems/score/isrlevel.h (modified) * cpukit/include/rtems/score/mppkt.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectmp.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/prioritybitmap.h (modified) * cpukit/include/rtems/score/rbtree.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulercbs.h (modified) * cpukit/include/rtems/score/scheduleredf.h (modified) * cpukit/include/rtems/score/schedulerpriority.h (modified) * cpukit/include/rtems/score/schedulersimple.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/include/rtems/score/states.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/include/rtems/score/timespec.h (modified) * cpukit/include/rtems/score/timestamp.h (modified) * cpukit/include/rtems/score/timestampimpl.h (modified) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/include/rtems/seterr.h (modified) * cpukit/include/rtems/shell.h (modified) * cpukit/include/rtems/shellconfig.h (modified) * cpukit/include/rtems/spurious.h (modified) * cpukit/include/rtems/stackchk.h (modified) * cpukit/include/rtems/stringto.h (modified) * cpukit/include/rtems/termiostypes.h (modified) * cpukit/include/rtems/watchdogdrv.h (modified) * cpukit/include/sys/statvfs.h (modified) * cpukit/libfs/src/dosfs/msdos_statvfs.c (modified) * cpukit/libmisc/capture/capture_buffer.h (modified) * cpukit/libnetworking/rtems/bsdnet/servers.h (modified) * cpukit/libnetworking/rtems/mkrootfs.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/rtems/include/rtems/rtems/barriermp.h (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/score/cpu/epiphany/include/rtems/asm.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/epiphany.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/include/rtems/mips/iregdef.h (modified) * cpukit/score/cpu/mips/include/rtems/score/mips.h (modified) * cpukit/score/cpu/moxie/include/rtems/asm.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/moxie.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/asm.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/asm.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/or1k.h (modified) * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/riscv.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/asm.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/timespecsubtract.c (modified) * cpukit/score/src/timespectoticks.c (modified) Remove explicit file names from @file This makes the @file ... Mon, 18 Feb 2019 01:18:50 GMT Chris Johns [62b01ab] * cpukit/include/rtems/rtl/rtl-archive.h (modified) * cpukit/libdl/rtl-archive.c (modified) libdl/archive: Fix the config file string index while removing ... Mon, 18 Feb 2019 00:46:22 GMT Chris Johns [22afb034] * cpukit/include/rtems/rtl/rtl-allocator.h (modified) * cpukit/libdl/rtl-alloc-heap.c (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-elf.c (modified) libdl/alloc: Add a locking interface to the allocator. - Allow an ... Tue, 12 Feb 2019 11:19:38 GMT Sebastian Huber [e4ad14cc] * cpukit/include/rtems/score/onceimpl.h (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/score/src/once.c (modified) * testsuites/psxtests/psxonce01/init.c (modified) * testsuites/psxtests/psxonce01/psxonce01.scn (modified) * testsuites/psxtests/psxonce01/system.h (modified) * testsuites/sptests/spcxx01/init.cc (modified) * testsuites/sptests/spcxx01/spcxx01.doc (modified) score: Avoid some deadlocks in _Once() Recursive usage of the same ... Thu, 14 Feb 2019 03:00:05 GMT Chris Johns [e309f77] * cpukit/include/rtems/rtl/rtl-allocator.h (modified) * cpukit/libdl/rtl-alloc-heap.c (modified) * cpukit/libdl/rtl-alloc-heap.h (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-obj.c (modified) libdl: Allocator does not unlock and lock memory on loading. Close #3692 Tue, 12 Feb 2019 12:18:56 GMT Sebastian Huber [e214ff4b] * cpukit/include/rtems/posix/posixapi.h (modified) posix: Remove unused _POSIX_Get_object_body() Sat, 02 Feb 2019 04:09:53 GMT Chris Johns [6c9f017] * bsps/powerpc/psim/start/linkcmds (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-bit-alloc.c (added) * cpukit/libdl/rtl-bit-alloc.h (added) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/dl01/dl-load.c (modified) * testsuites/libtests/dl02/dl-load.c (modified) * testsuites/libtests/dl02/dl-o1.c (modified) * testsuites/libtests/dl02/dl-o2.c (modified) * testsuites/libtests/dl03/dl-bit-alloc.c (added) * testsuites/libtests/dl03/dl-bit-alloc.h (added) * testsuites/libtests/dl03/init.c (modified) * testsuites/libtests/dl05/dl-load.c (modified) * testsuites/libtests/dl07/dl-load.c (modified) * testsuites/libtests/dl07/dl-o1.c (modified) * testsuites/libtests/dl07/dl-o2.c (modified) * testsuites/libtests/dl07/dl-o3.c (modified) * testsuites/libtests/dl07/dl-o4.c (modified) * testsuites/libtests/dl07/dl-o5.c (modified) * testsuites/libtests/dl07/init.c (modified) * testsuites/libtests/dl08/dl-o1.c (modified) * testsuites/libtests/dl08/dl-o2.c (modified) * testsuites/libtests/dl08/dl-o3.c (modified) * testsuites/libtests/dl08/dl-o4.c (modified) * testsuites/libtests/dl08/dl-o5.c (modified) * testsuites/libtests/dl08/dl-o6-123456789-123456789.c (modified) * testsuites/libtests/dl09/dl-load.c (modified) * testsuites/libtests/dl09/dl-o1.c (modified) * testsuites/libtests/dl09/dl-o2.c (modified) * testsuites/libtests/dl09/dl-o3.c (modified) * testsuites/libtests/dl09/dl-o4.c (modified) * testsuites/libtests/dl09/dl-o5.c (modified) libdl: Add powerpc large memory and small data support. - Add ... Mon, 21 Jan 2019 21:48:19 GMT Chris Johns [194eb403] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/dl08/dl-load.c (modified) * testsuites/libtests/dl09/dl-load.c (modified) * testsuites/libtests/dl09/dl-o5.c (modified) libdl: Add support for large memory programs - Add trampolines to ... Tue, 15 Jan 2019 06:47:41 GMT Chris Johns [d8c70ba6] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl01/dl-load.c (modified) * testsuites/libtests/dl08/dl-load.c (modified) * testsuites/libtests/dl09/dl-load.c (added) * testsuites/libtests/dl09/dl-load.h (added) * testsuites/libtests/dl09/dl-o1.c (added) * testsuites/libtests/dl09/dl-o1.h (added) * testsuites/libtests/dl09/dl-o2.c (added) * testsuites/libtests/dl09/dl-o2.h (added) * testsuites/libtests/dl09/dl-o3.c (added) * testsuites/libtests/dl09/dl-o3.h (added) * testsuites/libtests/dl09/dl-o4.c (added) * testsuites/libtests/dl09/dl-o4.h (added) * testsuites/libtests/dl09/dl-o5.c (added) * testsuites/libtests/dl09/dl-o5.h (added) * testsuites/libtests/dl09/dl09.doc (added) * testsuites/libtests/dl09/dl09.scn (added) * testsuites/libtests/dl09/init.c (added) libdl: Add support for trampolines - Trampolines or fixups for ... Wed, 09 Jan 2019 11:14:11 GMT Chris Johns [4408603] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) * cpukit/score/cpu/arm/include/machine/elf_machdep.h (modified) * testsuites/libtests/dl08/dl-load.c (modified) libdl: Fix the support for constructors and desctructors. - Fix the ... Mon, 17 Dec 2018 05:36:48 GMT Chris Johns [89c59be] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtl/rtl-archive.h (added) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-shell.h (moved) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rtl-archive.c (added) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-string.h (modified) * cpukit/libdl/rtl-trace.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) libdl: Add symbol searching and loading from archives. - Load ... Fri, 08 Feb 2019 09:16:07 GMT Sebastian Huber [26333f2a] * cpukit/include/rtems/score/userextimpl.h (modified) score: Fix _User_extensions_Thread_switch() (SMP) We have to read ... Wed, 30 Jan 2019 08:41:49 GMT Sebastian Huber [03cdd5ea] * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record.c (modified) * testsuites/libtests/record01/init.c (modified) * testsuites/libtests/record02/init.c (modified) record: Add enum value for each event Update #3665. Sat, 28 Apr 2018 09:36:11 GMT Sebastian Huber [dca6184] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/record.h (added) * cpukit/include/rtems/recordclient.h (added) * cpukit/include/rtems/recorddata.h (added) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/libtrace/record/record-client.c (added) * cpukit/libtrace/record/record-server.c (added) * cpukit/libtrace/record/record-sysinit.c (added) * cpukit/libtrace/record/record-text.c (added) * cpukit/libtrace/record/record-userext.c (added) * cpukit/libtrace/record/record.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/record01/init.c (added) * testsuites/libtests/record01/record01.doc (added) * testsuites/libtests/record01/record01.scn (added) * testsuites/libtests/record02/init.c (added) * testsuites/libtests/record02/record02.doc (added) * testsuites/libtests/record02/record02.scn (added) Add low level event recording support Add low level event recording ... Fri, 18 Jan 2019 12:32:51 GMT Sebastian Huber [926ed2b0] * cpukit/include/rtems/score/isrlock.h (modified) * testsuites/sptests/sp37/init.c (modified) score: Remove unused _ISR_lock_Flash() Fri, 18 Jan 2019 12:16:29 GMT Sebastian Huber [41310c02] * cpukit/include/rtems/rtems/intr.h (modified) * cpukit/include/rtems/score/isrlock.h (modified) * testsuites/sptests/sp37/init.c (modified) score: Improve debug support for ISR locks Ensure that interrupts ... Mon, 14 Jan 2019 06:50:26 GMT Sebastian Huber [93e3b341] * cpukit/include/rtems/score/address.h (modified) score: Simplify _Addresses_Is_aligned() The CPU_ALIGNMENT must not ... Thu, 10 Jan 2019 08:05:49 GMT Sebastian Huber [7bde91b] * cpukit/include/rtems/inttypes.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libmisc/shell/main_rm.c (modified) * cpukit/libmisc/shell/print-ls.c (modified) * testsuites/psxtests/psxreaddir/test.c (modified) Fix format warnings due to ino_t changes Mon, 07 Jan 2019 08:30:43 GMT Sebastian Huber [956d76cc] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/score/src/objectinitializeinformation.c (modified) score: Remove superfluous include from chainimpl.h Tue, 18 Dec 2018 07:45:06 GMT Sebastian Huber [7c19e50] * cpukit/include/rtems/score/interr.h (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpfatal09/init.c (added) * testsuites/smptests/smpfatal09/smpfatal09.doc (added) * testsuites/smptests/smpfatal09/smpfatal09.scn (added) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) score: Fix per-CPU data allocation Allocate the per-CPU data for ... Fri, 14 Dec 2018 07:07:08 GMT Sebastian Huber [e7b0a72] * cpukit/include/rtems/confdefs.h (modified) config: Remove CONFIGURE_CONFDEFS_DEBUG This configuration option ... Thu, 22 Nov 2018 18:14:51 GMT Sebastian Huber [21275b58] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/extensiondata.h (modified) * cpukit/include/rtems/extensionimpl.h (modified) * cpukit/include/rtems/posix/key.h (modified) * cpukit/include/rtems/posix/keyimpl.h (modified) * cpukit/include/rtems/posix/mqueue.h (modified) * cpukit/include/rtems/posix/mqueueimpl.h (modified) * cpukit/include/rtems/posix/pthread.h (modified) * cpukit/include/rtems/posix/pthreadimpl.h (modified) * cpukit/include/rtems/posix/semaphore.h (modified) * cpukit/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/include/rtems/posix/shm.h (modified) * cpukit/include/rtems/posix/shmimpl.h (modified) * cpukit/include/rtems/posix/sigset.h (modified) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/include/rtems/posix/timerimpl.h (modified) * cpukit/include/rtems/rtems/barrierdata.h (modified) * cpukit/include/rtems/rtems/barrierimpl.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/include/rtems/rtems/dpmemdata.h (modified) * cpukit/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/include/rtems/rtems/messagedata.h (modified) * cpukit/include/rtems/rtems/messageimpl.h (modified) * cpukit/include/rtems/rtems/msgmp.h (modified) * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/rtems/partmp.h (modified) * cpukit/include/rtems/rtems/ratemondata.h (modified) * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/rtems/regiondata.h (modified) * cpukit/include/rtems/rtems/regionimpl.h (modified) * cpukit/include/rtems/rtems/semdata.h (modified) * cpukit/include/rtems/rtems/semimpl.h (modified) * cpukit/include/rtems/rtems/semmp.h (modified) * cpukit/include/rtems/rtems/tasksdata.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/include/rtems/rtems/timerdata.h (modified) * cpukit/include/rtems/rtems/timerimpl.h (modified) * cpukit/include/rtems/score/freechain.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadq.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keyzerokvp.c (added) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/psxsemaphore.c (modified) * cpukit/posix/src/psxtimercreate.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/shm.c (modified) * cpukit/posix/src/shmopen.c (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/barriercreate.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/score/src/freechain.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/psxtests/psxobj01/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal13/spfatal13.doc (deleted) * testsuites/sptests/spfatal13/spfatal13.scn (deleted) * testsuites/sptests/spfatal13/testcase.h (deleted) * testsuites/sptests/spfreechain01/init.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) score: Static Objects_Information initialization Statically ... Mon, 10 Dec 2018 11:51:33 GMT Sebastian Huber [0f5b2c09] * cpukit/Makefile.am (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/getconfigmax.c (added) rtems: Use object information to get config max Use functions ... Mon, 10 Dec 2018 12:44:53 GMT Sebastian Huber [8b0e752f] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * testsuites/samples/unlimited/test1.c (modified) score: Remove Objects_Information::auto_extend Use ... Sun, 25 Nov 2018 19:26:02 GMT Sebastian Huber [f70079c] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) score: Remove Objects_Information::the_api Remove ... Sun, 25 Nov 2018 19:15:26 GMT Sebastian Huber [1c2d178] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/score/src/objectactivecount.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectgetinfo.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/threaditerate.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) score: Remove Objects_Information::maximum This information is ... Sat, 24 Nov 2018 10:51:28 GMT Sebastian Huber [3899bc1a] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/rtems/src/ratemonresetall.c (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectgetnoprotection.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/threaditerate.c (modified) * testsuites/sptests/spconfig02/init.c (modified) score: Optimize object lookup Use the maximum ID for the ID to ... Thu, 22 Nov 2018 05:38:42 GMT Sebastian Huber [359a3a3] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) score: Rename Objects_Information::allocation_size Rename ... Thu, 22 Nov 2018 05:16:52 GMT Sebastian Huber [0da9d80] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: Rename Objects_Information::size Rename ... Wed, 21 Nov 2018 16:30:52 GMT Sebastian Huber [9c9c6a9] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/psxsemaphore.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/shm.c (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectnamespaceremove.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectsetname.c (modified) * cpukit/score/src/thread.c (modified) * testsuites/psxtests/psxobj01/init.c (modified) score: Remove Objects_Information::is_string Use ... Thu, 06 Dec 2018 08:57:01 GMT Sebastian Huber [7ee6437] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/schedulergetmaxprio.c (added) * testsuites/sptests/spscheduler01/init.c (modified) rtems: Add rtems_scheduler_get_maximum_priority() Update #3636. Mon, 03 Dec 2018 12:10:21 GMT Sebastian Huber [ef23838] * cpukit/headers.am (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/timestamp.h (modified) * cpukit/include/rtems/score/timestampimpl.h (added) * cpukit/include/rtems/score/watchdogimpl.h (modified) * cpukit/rtems/src/clockgetuptimenanoseconds.c (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * testsuites/psxtests/psx13/test.c (modified) * testsuites/psxtmtests/psxtmcond08/init.c (modified) score: Avoid sbintime_t in API headers The sbintime_t is a ... Thu, 06 Dec 2018 12:40:08 GMT Sebastian Huber [e50b4bd3] * cpukit/include/rtems/score/basedefs.h (modified) score: Use __typeof__ for strict ISO C compat Enable the use of ... Thu, 06 Dec 2018 09:49:43 GMT Sebastian Huber [4e46ba8] * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/taskrestart.c (modified) rtems: Fix rtems_task_restart() argument type Close #3637. Mon, 03 Dec 2018 20:37:32 GMT Marçal Comajoan Cara [0446f680] * bsps/i386/pc386/start/README-SMP (modified) * bsps/powerpc/shared/exceptions/ppc_exc_address.c (modified) * bsps/sparc/leon3/start/bspclean.c (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/rtems/mainpage.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libfs/src/defaults/default_rename.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libi2c/README_libi2c (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * testsuites/smptests/smpmutex01/init.c (modified) Spelling and grammar fixes in source code comments (GCI 2018) Fri, 30 Nov 2018 12:57:04 GMT Sebastian Huber [b9ffb624] * cpukit/include/rtems/counter.h (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * testsuites/sptests/spcpucounter01/init.c (modified) Convert CPU counter ticks to/from sbintime_t The sbintime_t is an ... Mon, 26 Nov 2018 13:04:59 GMT Sebastian Huber [0a75a4aa] * bsps/shared/cache/cacheimpl.h (modified) * cpukit/include/rtems/rtems/cache.h (modified) * testsuites/smptests/smpcache01/init.c (modified) Remove rtems_cache_*_processor_set() functions The following ... Mon, 26 Nov 2018 07:25:36 GMT Sebastian Huber [5fc727f] * cpukit/include/rtems/score/smplockstats.h (modified) * cpukit/score/src/profilingsmplock.c (modified) score: Remove ... Tue, 20 Nov 2018 15:22:56 GMT Sebastian Huber [eaa5ea84] * cpukit/headers.am (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/include/rtems/score/heap.h (modified) * cpukit/include/rtems/score/heapinfo.h (added) * testsuites/libtests/stackchk/blow.c (modified) score: Introduce Move ... Tue, 20 Nov 2018 03:56:11 GMT Chris Johns [03139d5b] * cpukit/include/rtems/rtl/rtl-obj-fwd.h (modified) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-sym.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl02/dl-load.c (modified) * testsuites/libtests/dl07/dl-load.c (added) * testsuites/libtests/dl07/dl-load.h (added) * testsuites/libtests/dl07/dl-o1.c (added) * testsuites/libtests/dl07/dl-o1.h (added) * testsuites/libtests/dl07/dl-o2.c (added) * testsuites/libtests/dl07/dl-o2.h (added) * testsuites/libtests/dl07/dl-o3.c (added) * testsuites/libtests/dl07/dl-o4.c (added) * testsuites/libtests/dl07/dl-o4.h (added) * testsuites/libtests/dl07/dl-o5.c (added) * testsuites/libtests/dl07/dl-o5.h (added) * testsuites/libtests/dl07/dl07.doc (added) * testsuites/libtests/dl07/dl07.scn (added) * testsuites/libtests/dl07/init.c (added) libdl: Add object file dependencies to track references Tracking ... Tue, 20 Nov 2018 03:00:48 GMT Chris Johns [8e7c72a7] * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/libdl/rtl-unresolved.c (modified) libdl: Reindex unresolved names after removing used records. ... Tue, 13 Nov 2018 06:26:17 GMT Chris Johns [803eac9] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-obj.c (modified) libdl: Manage the allocation of common uninitialised variables. The ... Fri, 16 Nov 2018 06:06:12 GMT Sebastian Huber [59e7209f] * cpukit/include/rtems/inttypes.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/libmisc/monitor/mon-driver.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) score: Remove support for RTEMS_USE_16_BIT_OBJECT The ... Wed, 14 Nov 2018 06:23:21 GMT Sebastian Huber [dc563556] * cpukit/include/rtems/rtems/cache.h (modified) Include missing Update #3598. Fri, 09 Nov 2018 11:11:11 GMT Sebastian Huber [6efc831] * cpukit/include/rtems/malloc.h (modified) * cpukit/libcsupport/src/malloc_deferred.c (modified) * testsuites/libtests/malloctest/init.c (modified) Add rtems_malloc() and rtems_calloc() Close #3583. Fri, 09 Nov 2018 10:20:09 GMT Sebastian Huber [c1f3c2b8] * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/score/basedefs.h (modified) score: Add and use malloc() family attributes Update #3583. Thu, 08 Nov 2018 05:25:06 GMT Sebastian Huber [b15b288] * cpukit/include/rtems/score/basedefs.h (modified) score: Deprecate proc_ptr Update #3585. Mon, 12 Nov 2018 08:28:49 GMT Sebastian Huber [963c6c2] * cpukit/headers.am (modified) * cpukit/include/rtems/extensiondata.h (modified) * cpukit/include/rtems/score/userext.h (modified) * cpukit/include/rtems/score/userextdata.h (added) * cpukit/include/rtems/score/userextimpl.h (modified) score: Move internal structures to userextdata.h Update #3598. Mon, 12 Nov 2018 08:24:28 GMT Sebastian Huber [356b07e6] * cpukit/include/rtems/score/smplockstats.h (modified) score: Includes in Include ... Mon, 12 Nov 2018 08:23:32 GMT Sebastian Huber [3b69a0e2] * cpukit/include/rtems/rtems/cache.h (modified) rtems: Simplify includes in Update #3598. Mon, 12 Nov 2018 08:00:36 GMT Sebastian Huber [a6e7d5e4] * cpukit/headers.am (modified) * cpukit/include/rtems/extensiondata.h (modified) * cpukit/include/rtems/posix/mqueue.h (modified) * cpukit/include/rtems/posix/semaphore.h (modified) * cpukit/include/rtems/posix/shm.h (modified) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/include/rtems/rtems/barrierdata.h (modified) * cpukit/include/rtems/rtems/dpmemdata.h (modified) * cpukit/include/rtems/rtems/messagedata.h (modified) * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/regiondata.h (modified) * cpukit/include/rtems/rtems/timerdata.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectdata.h (added) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) score: Move internal structures to objectdata.h Update #3598. Thu, 08 Nov 2018 11:57:26 GMT Sebastian Huber [e897c7d] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/tasksdata.h (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/rtems/src/rtemsmaxprio.c (added) rtems: Avoid include of Update #3598. Thu, 08 Nov 2018 11:05:44 GMT Sebastian Huber [2fa014db] * cpukit/include/rtems/rtems/tasks.h (modified) rtems: Avoid include of Update #3598. Thu, 08 Nov 2018 10:55:11 GMT Sebastian Huber [805f9c26] * cpukit/include/rtems/score/heap.h (modified) score: Avoid complex include in heap.h Update #3598. Thu, 08 Nov 2018 10:53:12 GMT Sebastian Huber [9763245] * cpukit/include/rtems/rtems/types.h (modified) rtems: Remove superfluous include Update #3598. Thu, 08 Nov 2018 10:50:24 GMT Sebastian Huber [ccc6695] * cpukit/headers.am (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/rtems/clock.h (modified) * cpukit/include/rtems/rtems/ratemon.h (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/include/rtems/score/mppkt.h (modified) * cpukit/include/rtems/score/threadq.h (modified) * cpukit/include/rtems/score/watchdog.h (modified) * cpukit/include/rtems/score/watchdogimpl.h (modified) * cpukit/include/rtems/score/watchdogticks.h (added) * cpukit/score/src/watchdogtickssinceboot.c (modified) score: Introduce Separate the ... Thu, 08 Nov 2018 10:32:13 GMT Sebastian Huber [98c01a5] * cpukit/Makefile.am (modified) * cpukit/include/rtems/imfs.h (modified) * cpukit/include/rtems/rtems/clock.h (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (added) rtems: Avoid in API Use a real function ... Thu, 08 Nov 2018 12:12:32 GMT Sebastian Huber [a11b98c] * cpukit/include/rtems/score/userext.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) score: Avoid include of Update #3598. Thu, 08 Nov 2018 10:14:04 GMT Sebastian Huber [742d6db] * cpukit/headers.am (modified) * cpukit/include/rtems/rtems/clock.h (modified) * cpukit/include/rtems/score/tod.h (deleted) * cpukit/include/rtems/score/todimpl.h (modified) score: Remove empty Update #3598. Thu, 08 Nov 2018 12:17:37 GMT Sebastian Huber [5fc855d] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/extension.h (modified) * cpukit/include/rtems/extensiondata.h (added) * cpukit/include/rtems/extensionimpl.h (modified) * cpukit/libmisc/monitor/mon-extension.c (modified) rtems: Move internal structures to extensiondata.h Update #3598. Thu, 08 Nov 2018 10:07:57 GMT Sebastian Huber [e1b7c188] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/rtems/timer.h (modified) * cpukit/include/rtems/rtems/timerdata.h (added) * cpukit/include/rtems/rtems/timerimpl.h (modified) rtems: Move internal structures to timerdata.h Update #3598. Thu, 08 Nov 2018 09:57:21 GMT Sebastian Huber [b7af3e44] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/tasksdata.h (added) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/taskmode.c (modified) rtems: Move internal structures to tasksdata.h Update #3598. Thu, 08 Nov 2018 09:45:44 GMT Sebastian Huber [739df1f5] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/rtems/sem.h (modified) * cpukit/include/rtems/rtems/semdata.h (added) * cpukit/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/semcreate.c (modified) rtems: Move internal structures to semdata.h Update #3598.
