# # ChangeLog for cpukit/include/rtems/inttypes.h in rtems # # Generated by Trac 1.2.1.dev0 # 04/24/24 23:51:10 Wed, 29 Nov 2017 13:52:15 GMT Martin Erik Werner [ab304f4] * cpukit/include/rtems/inttypes.h (modified) rtems/inttypes: Clarify hexadecimal in comments Update comments to ... Thu, 27 Jul 2017 22:55:42 GMT Joel Sherrill [0238e31] * cpukit/include/rtems/inttypes.h (modified) cpukit/include/rtems/inttypes.h: Correct PRIdioctl_command_t Fri, 28 Apr 2017 16:11:14 GMT Joel Sherrill [20775247] * cpukit/include/rtems/inttypes.h (modified) rtems/inttypes.h: Add PRIdrtems_vector_number. Missed in previous commit Wed, 26 Apr 2017 01:14:28 GMT Joel Sherrill [9e6ef36] * cpukit/include/rtems/inttypes.h (modified) * testsuites/libtests/block08/bdbuf_tests.c (modified) rtems/inttypes.h, block08: Add and use PRIdrtems_blkdev_bnum Tue, 25 Apr 2017 16:42:18 GMT Joel Sherrill [7db09923] * c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c (modified) * cpukit/include/rtems/inttypes.h (modified) rtems/inttypes.h epiphany_sim/irq/irq.c: Add PRIdrtems_vector_number ... Sun, 23 Apr 2017 17:53:44 GMT Joel Sherrill [473a3cd] * cpukit/include/rtems/inttypes.h (modified) rtems/inttypes.h: Add PRIdioctl_command_t Sat, 22 Apr 2017 19:15:22 GMT Joel Sherrill [438ca2f] * cpukit/configure.ac (modified) * cpukit/include/rtems/inttypes.h (modified) * testsuites/psxtests/include/pmacros.h (modified) rtems/inttypes.h: Add blksize_t and blkcnt_t Fri, 14 Apr 2017 20:18:56 GMT Joel Sherrill [d420b67] * cpukit/configure.ac (modified) * cpukit/include/rtems/inttypes.h (modified) * testsuites/support/include/tmacros.h (modified) Merge tmacros.h PRIxxx constants from testsuites/ into ... Fri, 14 Apr 2017 18:55:48 GMT Joel Sherrill [54bdf0c] * cpukit/Makefile.am (modified) * cpukit/include/rtems/inttypes.h (added) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libfs/src/nfsclient/src/dirutils.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libmisc/shell/main_time.c (modified) * cpukit/preinstall.am (modified) rtems/inttypes.h: New file. Uses contents from cpukit Provide ...
