# # ChangeLog for cpukit/automake in rtems # # Generated by Trac 1.2.1.dev0 # 05/08/24 01:09:30 Sat, 22 May 2010 09:15:42 GMT Ralf Corsepius [82034cbe] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2010-05-22 Ralf Corsépius * ... Sat, 28 Nov 2009 06:15:55 GMT Ralf Corsepius [e447c7d2] * cpukit/automake/subdirs.am (modified) * cpukit/itron/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/src/nfsclient/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/m32r/Makefile.am (modified) Whitespace removal. Fri, 23 Oct 2009 14:57:58 GMT Ralf Corsepius [05eb1fb] * c/src/aclocal/prog-cc.m4 (modified) * c/src/automake/compile.am (modified) * cpukit/automake/compile.am (modified) Remove RTEMS_CFLAGS. Mon, 16 Oct 2006 15:58:13 GMT Ralf Corsepius [ed908735] * cpukit/aclocal/multi.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/aclocal/prog-ccas.m4 (modified) * cpukit/automake/compile.am (modified) * cpukit/configure.ac (modified) Adaptations to automake-1.10. Sun, 13 Nov 2005 09:11:32 GMT Ralf Corsepius [bc82457e] * cpukit/automake/local.am (modified) * testsuites/automake/host.am (modified) * testsuites/automake/local.am (modified) Remove depend. Fri, 04 Feb 2005 16:18:45 GMT Ralf Corsepius [f2a95293] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2005-02-04 Ralf Corsepius * ... Fri, 28 Jan 2005 03:06:51 GMT Ralf Corsepius [07750ff] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2005-01-28 Ralf Corsepius * ... Wed, 05 Jan 2005 16:07:20 GMT Ralf Corsepius [7ddfdb2] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/automake/compile.am (modified) 2005-01-05 Ralf Corsepius * ... Wed, 05 Jan 2005 08:41:18 GMT Ralf Corsepius [20cef00f] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/automake/compile.am (modified) 2005-01-05 Ralf Corsepius * ... Sat, 01 Jan 2005 10:41:29 GMT Ralf Corsepius [846a4af] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/itron/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) 2005-01-01 Ralf Corsepius * ... Thu, 21 Oct 2004 09:01:00 GMT Ralf Corsepius [6741c2e1] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2004-10-20 Ralf Corsepius * ... Wed, 14 Jan 2004 05:20:59 GMT Ralf Corsepius [5c24afe9] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/automake/local.am (modified) * cpukit/automake/subdirs.am (modified) 2004-01-14 Ralf Corsepius * ... Sun, 11 Jan 2004 05:25:27 GMT Ralf Corsepius [a42f159a] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/automake/amcompile.am (deleted) * cpukit/automake/compile.am (modified) * cpukit/automake/lib.am (deleted) 2004-01-11 Ralf Corsepius * ... Sun, 11 Jan 2004 02:30:12 GMT Ralf Corsepius [35d9b418] * cpukit/ChangeLog (modified) * cpukit/aclocal/enable-bare.m4 (modified) * cpukit/aclocal/enable-inlines.m4 (modified) * cpukit/aclocal/enable-itron.m4 (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/aclocal/enable-networking.m4 (modified) * cpukit/aclocal/enable-posix.m4 (modified) * cpukit/aclocal/enable-rtems-debug.m4 (modified) * cpukit/aclocal/multi.m4 (modified) * cpukit/aclocal/multilib.m4 (modified) * cpukit/automake/local.am (modified) * cpukit/configure.ac (modified) 2004-01-11 Ralf Corsepius * ... Fri, 09 Jan 2004 18:14:38 GMT Ralf Corsepius [d7a7573] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/aclocal/enable-networking.m4 (modified) * cpukit/automake/amcompile.am (modified) * cpukit/wrapup/Makefile.am (modified) 2004-01-08 Ralf Corsepius * ... Wed, 07 Jan 2004 17:16:36 GMT Ralf Corsepius [e7d110ba] * cpukit/ChangeLog (modified) * cpukit/automake/amcompile.am (added) * cpukit/configure.ac (modified) 2004-01-07 Ralf Corsepius * ... Wed, 17 Dec 2003 03:54:31 GMT Ralf Corsepius [a953fa1] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2003-12-17 Ralf Corsepius * ... Fri, 12 Dec 2003 10:37:19 GMT Ralf Corsepius [ba962ea] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/lead-dot.m4 (deleted) * cpukit/automake/lib.am (modified) 2003-12-12 Ralf Corsepius * ... Mon, 01 Dec 2003 04:10:53 GMT Ralf Corsepius [5ef82f97] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) * cpukit/wrapup/Makefile.am (modified) 2003-11-30 Ralf Corsepius * ... Mon, 18 Aug 2003 06:57:29 GMT Ralf Corsepius [63a04f7] * cpukit/ChangeLog (modified) * cpukit/automake/local.am (modified) 2003-08-18 Ralf Corsepius * ... Tue, 27 May 2003 13:03:29 GMT Ralf Corsepius [d46ec86] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/automake/compile.am (modified) * cpukit/automake/local.am (modified) 2003-05-27 Ralf Corsepius PR ... Wed, 14 May 2003 04:34:20 GMT Ralf Corsepius [46fa6611] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2003-05-14 Ralf Corsepius * ... Fri, 28 Feb 2003 06:57:04 GMT Ralf Corsepius [b9184faa] * cpukit/automake/compile.am (modified) * cpukit/automake/local.am (modified) Merger from rtems-4-6-branch. Thu, 23 Jan 2003 22:21:24 GMT Ralf Corsepius [08df9a21] * cpukit/ChangeLog (modified) * cpukit/automake/local.am (modified) 2003-01-23 Ralf Corsepius * ... Tue, 21 Jan 2003 13:40:05 GMT Ralf Corsepius [16735ca] * ChangeLog (modified) * automake/compile.am (modified) * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2003-01-21 Ralf Corsepius * ... Thu, 19 Dec 2002 05:17:22 GMT Ralf Corsepius [28ed8f3] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2002-12-19 Ralf Corsepius * ... Fri, 06 Dec 2002 13:07:15 GMT Ralf Corsepius [baa8dd7c] * ChangeLog (modified) * automake/compile.am (modified) * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 11:21:50 GMT Ralf Corsepius [8e4cd5a] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemsbsp.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/automake/compile.am (modified) * cpukit/automake/multilib.am (modified) 2002-12-06 Ralf Corsepius * ... Wed, 20 Nov 2002 02:57:45 GMT Ralf Corsepius [fd5e23a] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2002-11-19 Ralf Corsepius * ... Fri, 15 Nov 2002 15:00:13 GMT Ralf Corsepius [789a953] * cpukit/automake/compile.am (modified) 2002-11-15 Ralf Corsepius * ... Wed, 31 Jul 2002 14:57:47 GMT Ralf Corsepius [532fad28] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/aclocal/canonicalize-tools.m4 (modified) * cpukit/automake/lib.am (modified) 2002-07-31 Ralf Corsepius * ... Fri, 26 Jul 2002 12:51:02 GMT Ralf Corsepius [c3efdb3] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2002-07-26 Ralf Corsepius * ... Mon, 22 Jul 2002 09:27:52 GMT Ralf Corsepius [9f6d7a3] * cpukit/ChangeLog (modified) * cpukit/automake/lib.am (modified) 2002-07-22 Ralf Corsepius * ... Mon, 22 Jul 2002 09:17:11 GMT Ralf Corsepius [14620166] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemsbsp.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/automake/compile.am (modified) 2002-07-22 Ralf Corsepius * ... Fri, 05 Jul 2002 16:13:07 GMT Ralf Corsepius [1b16e63c] * c/src/exec/ChangeLog (modified) * c/src/exec/aclocal/check-bsps.m4 (modified) * c/src/exec/aclocal/check-cpu.m4 (modified) * c/src/exec/aclocal/env-rtemscpu.m4 (modified) * c/src/exec/aclocal/rtems-top.m4 (modified) * c/src/exec/automake/multilib.am (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/check-bsps.m4 (modified) * cpukit/aclocal/check-cpu.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/automake/multilib.am (modified) 2002-07-05 Ralf Corsepius * ... Thu, 27 Jun 2002 12:18:24 GMT Ralf Corsepius [5261406] * c/src/exec/ChangeLog (modified) * c/src/exec/automake/compile.am (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/canonicalize-tools.m4 (modified) * cpukit/aclocal/prog-ccas.m4 (added) * cpukit/automake/compile.am (modified) 2002-06-27 Ralf Corsepius * ... Sat, 15 Jun 2002 05:29:18 GMT Ralf Corsepius [9ea3832c] * c/src/exec/automake/compile.am (added) * c/src/exec/automake/lib.am (added) * c/src/exec/automake/local.am (added) * c/src/exec/automake/multilib.am (added) * c/src/exec/automake/subdirs.am (added) * cpukit/automake/compile.am (added) * cpukit/automake/lib.am (added) * cpukit/automake/local.am (added) * cpukit/automake/multilib.am (added) * cpukit/automake/subdirs.am (added) Copied over from the automake/
