# # ChangeLog for cpukit/ada in rtems # # Generated by Trac 1.2.1.dev0 # 04/20/24 00:12:47 Tue, 30 Sep 1997 14:49:56 GMT Joel Sherrill [8959fcc] * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.ads (modified) fixed typo Tue, 30 Sep 1997 14:44:28 GMT Joel Sherrill [63cebf6] * c/src/ada/rtems.adb (modified) * cpukit/ada/rtems.adb (modified) Fixed typos. Thu, 28 Aug 1997 22:23:10 GMT Joel Sherrill [ad9250cf] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) Fixed IO Manager calls to remove an argument which was used in 3.2.1 ... Thu, 28 Aug 1997 13:57:29 GMT Joel Sherrill [b47be20] * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.ads (modified) Added IO_Error status code and fixed No_Memory error number. Thu, 10 Jul 1997 20:24:00 GMT Joel Sherrill [bb566a02] * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.ads (modified) Reordered specs. Thu, 10 Jul 1997 20:23:27 GMT Joel Sherrill [0b172df9] * c/src/ada/rtems.adb (modified) * cpukit/ada/rtems.adb (modified) fixed milliseconds and microseconds to tick conversion routines. Tue, 03 Jun 1997 18:07:30 GMT Joel Sherrill [6666ea88] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) Added True and False constants for RTEMS.Boolean types. This ... Tue, 03 Jun 1997 16:04:00 GMT Joel Sherrill [87e951a2] * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.ads (modified) Added RTEMS boolean constants. Tue, 03 Jun 1997 15:22:09 GMT Joel Sherrill [4c3340c] * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.ads (modified) Added Pending_Events and lined up other event constants Tue, 03 Jun 1997 15:11:39 GMT Joel Sherrill [d348ad96] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) added more constants and fixed numer Tue, 03 Jun 1997 00:55:42 GMT Joel Sherrill [a6b44a8a] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) added Signal constants, Is_Status_Successful, and Attribute constants. Tue, 03 Jun 1997 00:33:48 GMT Joel Sherrill [7e3dcbc] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) added rtems_interrupt_level_attribute routien to return a properly ... Mon, 02 Jun 1997 23:46:15 GMT Joel Sherrill [d766b7fd] * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.ads (modified) added Minimum_Stack_Size and Mode constants Mon, 02 Jun 1997 20:52:48 GMT Joel Sherrill [f3f06f79] * c/src/ada-tests/support/init.c (added) * c/src/ada-tests/support/status_io.ads (added) * c/src/ada-tests/support/test_support.adb (added) * c/src/ada-tests/support/test_support.ads (added) * c/src/ada-tests/support/unsigned32_io.ads (added) * c/src/ada/rtems.adb (added) * c/src/ada/rtems.ads (added) * cpukit/ada/rtems.adb (added) * cpukit/ada/rtems.ads (added) added new files from test area. This code has successfully been ...
