# # ChangeLog for cpukit/aclocal in rtems # # Generated by Trac 1.2.1.dev0 # 05/01/24 12:18:49 Sun, 11 Jan 2004 09:38:10 GMT Ralf Corsepius [ca0eeaa] * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2004-01-11 Ralf Corsepius * ... Sun, 11 Jan 2004 02:30:12 GMT Ralf Corsepius [35d9b418] * cpukit/ChangeLog (modified) * cpukit/aclocal/enable-bare.m4 (modified) * cpukit/aclocal/enable-inlines.m4 (modified) * cpukit/aclocal/enable-itron.m4 (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/aclocal/enable-networking.m4 (modified) * cpukit/aclocal/enable-posix.m4 (modified) * cpukit/aclocal/enable-rtems-debug.m4 (modified) * cpukit/aclocal/multi.m4 (modified) * cpukit/aclocal/multilib.m4 (modified) * cpukit/automake/local.am (modified) * cpukit/configure.ac (modified) 2004-01-11 Ralf Corsepius * ... Fri, 09 Jan 2004 18:14:38 GMT Ralf Corsepius [d7a7573] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/aclocal/enable-networking.m4 (modified) * cpukit/automake/amcompile.am (modified) * cpukit/wrapup/Makefile.am (modified) 2004-01-08 Ralf Corsepius * ... Wed, 07 Jan 2004 20:45:20 GMT Joel Sherrill [161624c] * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-cpu-subdirs.m4 (modified) 2004-01-07 Joel Sherrill * ... Wed, 17 Dec 2003 20:56:10 GMT Joel Sherrill [44652f8] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2003-12-17 Joel Sherrill * ... Sat, 13 Dec 2003 09:31:17 GMT Ralf Corsepius [b7235805] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/wrapup/Makefile.am (modified) 2003-12-13 Ralf Corsepius * ... Sat, 13 Dec 2003 04:10:07 GMT Ralf Corsepius [efe9ef4] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/wrapup/Makefile.am (modified) 2003-12-13 Ralf Corsepius * ... Fri, 12 Dec 2003 10:37:19 GMT Ralf Corsepius [ba962ea] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/lead-dot.m4 (deleted) * cpukit/automake/lib.am (modified) 2003-12-12 Ralf Corsepius * ... Sun, 30 Nov 2003 07:02:49 GMT Ralf Corsepius [e3407a4] * cpukit/ChangeLog (modified) * cpukit/aclocal/lead-dot.m4 (added) * cpukit/aclocal/rtems-top.m4 (modified) 2003-11-30 Ralf Corsepius * ... Thu, 27 Nov 2003 14:36:23 GMT Ralf Corsepius [1bcbe41] * cpukit/ChangeLog (modified) * cpukit/acinclude.m4 (modified) * cpukit/aclocal/check-itron.m4 (modified) * cpukit/aclocal/check-multiprocessing.m4 (modified) * cpukit/aclocal/check-posix.m4 (modified) * cpukit/configure.ac (modified) 2003-11-27 Ralf Corsepius * ... Wed, 26 Nov 2003 06:56:28 GMT Ralf Corsepius [863fb4f] * cpukit/ChangeLog (modified) * cpukit/aclocal/canonicalize-tools.m4 (modified) * cpukit/aclocal/check-itron.m4 (modified) * cpukit/aclocal/check-multiprocessing.m4 (modified) * cpukit/aclocal/check-newlib.m4 (modified) * cpukit/aclocal/check-posix.m4 (modified) * cpukit/aclocal/check-rtems-debug.m4 (modified) * cpukit/aclocal/check-tool.m4 (modified) * cpukit/aclocal/enable-bare.m4 (modified) * cpukit/aclocal/enable-inlines.m4 (modified) * cpukit/aclocal/enable-itron.m4 (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/aclocal/enable-networking.m4 (modified) * cpukit/aclocal/enable-posix.m4 (modified) * cpukit/aclocal/enable-rtems-debug.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/gcc-isystem.m4 (modified) * cpukit/aclocal/gcc-pipe.m4 (modified) * cpukit/aclocal/multi.m4 (modified) * cpukit/aclocal/multilib.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/aclocal/sysv-ipc.m4 (modified) 2003-11-26 Ralf Corsepius * ... Mon, 24 Nov 2003 09:57:09 GMT Ralf Corsepius [dcfba35] * cpukit/.cvsignore (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/enable-inlines.m4 (modified) * cpukit/configure.ac (modified) 2003-11-24 Ralf Corsepius * ... Thu, 20 Nov 2003 07:02:53 GMT Ralf Corsepius [3da33bf8] * cpukit/ChangeLog (modified) * cpukit/acinclude.m4 (added) * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/enable-inlines.m4 (modified) * cpukit/configure.ac (modified) 2003-11-20 Ralf Corsepius * ... Tue, 21 Oct 2003 15:17:21 GMT Ralf Corsepius [ed4b894] * cpukit/ChangeLog (modified) * cpukit/aclocal/canonical-host.m4 (deleted) * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/check-posix.m4 (modified) * cpukit/aclocal/sysv-ipc.m4 (modified) * cpukit/configure.ac (modified) 2003-10-21 Ralf Corsepius * ... Tue, 21 Oct 2003 14:51:01 GMT Ralf Corsepius [5b2e199] * cpukit/ChangeLog (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/check-cpu.m4 (deleted) * cpukit/aclocal/check-itron.m4 (modified) * cpukit/aclocal/check-multiprocessing.m4 (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/configure.ac (modified) 2003-10-21 Ralf Corsepius * ... Fri, 17 Oct 2003 08:17:55 GMT Ralf Corsepius [62f0829] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/configure.ac (modified) 2003-10-17 Ralf Corsepius * ... Fri, 29 Aug 2003 00:06:15 GMT Ralf Corsepius [ac3786b] * aclocal/rtems-top.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/aclocal/rtems-top.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/rtems-top.m4 (modified) 2003-08-28 Ralf Corsepius * ... Mon, 18 Aug 2003 09:45:40 GMT Ralf Corsepius [30d5640] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-rtems-debug.m4 (added) * cpukit/aclocal/enable-rtems-debug.m4 (moved) 2003-08-18 Ralf Corsepius * ... Thu, 03 Jul 2003 14:17:35 GMT Joel Sherrill [73defea0] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-07-03 Joel Sherrill * ... Tue, 27 May 2003 13:03:29 GMT Ralf Corsepius [d46ec86] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/automake/compile.am (modified) * cpukit/automake/local.am (modified) 2003-05-27 Ralf Corsepius PR ... Fri, 02 May 2003 20:29:10 GMT Ralf Corsepius [1e030c49] * cpukit/ChangeLog (modified) * cpukit/aclocal/enable-rtemsbsp.m4 (deleted) * cpukit/aclocal/env-rtemsbsp.m4 (deleted) * cpukit/aclocal/env-rtemscpu.m4 (modified) 2003-05-02 Ralf Corsepius * ... Thu, 17 Apr 2003 19:44:03 GMT Joel Sherrill [7ae9530] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-04-17 Joel Sherrill * ... Fri, 11 Apr 2003 21:51:46 GMT Joel Sherrill [f1208c0] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-04-11 Joel Sherrill * ... Fri, 11 Apr 2003 21:29:42 GMT Joel Sherrill [1ee68d1] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-04-11 Joel Sherrill * ... Mon, 24 Mar 2003 10:23:16 GMT Ralf Corsepius [dbe9b0c] * cpukit/aclocal/env-rtemsbsp.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/tool-paths.m4 (deleted) Merger from rtems-4-6-branch. Tue, 11 Mar 2003 08:10:00 GMT Ralf Corsepius [d2c26e4b] * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/sapi/ChangeLog (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/.cvsignore (deleted) * cpukit/sapi/include/rtems/.cvsignore (deleted) * cpukit/sapi/include/rtems/sptables.h (added) * cpukit/sapi/inline/.cvsignore (deleted) * cpukit/sapi/inline/rtems/.cvsignore (deleted) * cpukit/sapi/macros/.cvsignore (deleted) * cpukit/sapi/macros/rtems/.cvsignore (deleted) * cpukit/sapi/src/.cvsignore (deleted) * cpukit/score/ChangeLog (modified) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/configure.ac (modified) * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/configure.ac (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/configure.ac (modified) * cpukit/score/cpu/hppa1.1/ChangeLog (modified) * cpukit/score/cpu/hppa1.1/configure.ac (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/configure.ac (modified) * cpukit/score/cpu/i960/ChangeLog (modified) * cpukit/score/cpu/i960/configure.ac (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/configure.ac (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/configure.ac (modified) * cpukit/score/cpu/mips64orion/ChangeLog (modified) * cpukit/score/cpu/mips64orion/configure.ac (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/configure.ac (modified) * cpukit/score/cpu/or32/ChangeLog (modified) * cpukit/score/cpu/or32/configure.ac (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/configure.ac (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/configure.ac (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/configure.ac (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/configure.ac (modified) * cpukit/score/include/rtems/system.h (modified) Merger from rtems-4-6-branch. Fri, 28 Feb 2003 06:50:36 GMT Ralf Corsepius [309a9dc] * cpukit/aclocal/env-rtemsbsp.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/gcc-isystem.m4 (added) * cpukit/aclocal/gcc-specs.m4 (deleted) * cpukit/aclocal/prog-cc.m4 (modified) Merger from rtems-4-6-branch. Fri, 14 Feb 2003 05:15:15 GMT Ralf Corsepius [6b2b4a36] * ChangeLog (modified) * aclocal/canonical-target-name.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) Merger from rtems-4-6-branch. Fri, 07 Feb 2003 00:34:40 GMT Joel Sherrill [f18deb2f] * cpukit/aclocal/version.m4 (modified) missed in previous commit. Mon, 09 Dec 2002 11:26:13 GMT Ralf Corsepius [cc51f05a] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-bsps.m4 (deleted) * cpukit/aclocal/env-rtemsbsp.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) 2002-12-09 Ralf Corsepius * ... Fri, 06 Dec 2002 11:21:50 GMT Ralf Corsepius [8e4cd5a] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemsbsp.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/automake/compile.am (modified) * cpukit/automake/multilib.am (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 04:40:18 GMT Ralf Corsepius [8b38a769] * ChangeLog (modified) * aclocal/rtems-flags.m4 (added) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-flags.m4 (added) 2002-12-06 Ralf Corsepius * ... Tue, 19 Nov 2002 17:10:36 GMT Ralf Corsepius [1f64ebf] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-newlib.m4 (modified) * cpukit/aclocal/sysv-ipc.m4 (modified) 2002-11-19 Ralf Corsepius * ... Mon, 18 Nov 2002 13:57:54 GMT Joel Sherrill [b5a59c3f] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2002-11-18 Joel Sherrill * ... Fri, 15 Nov 2002 14:17:09 GMT Ralf Corsepius [1417e2b4] * cpukit/ChangeLog (modified) * cpukit/aclocal/prog-cc.m4 (modified) 2002-11-15 Ralf Corsepius * ... Mon, 11 Nov 2002 21:42:32 GMT Joel Sherrill [2bc3f76] * ChangeLog (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2002-11-11 Joel Sherrill * ... Wed, 30 Oct 2002 15:15:04 GMT Ralf Corsepius [489782d4] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-bsp-cache.m4 (deleted) 2002-10-30 Ralf Corsepius * ... Tue, 29 Oct 2002 16:40:03 GMT Ralf Corsepius [965c49b2] * cpukit/aclocal/multilib.m4 (modified) * cpukit/configure.ac (modified) 2002-10-29 Ralf Corsepius * ... Mon, 21 Oct 2002 16:59:21 GMT Joel Sherrill [f8ee48bf] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2002-10-21 Joel Sherrill * ... Fri, 04 Oct 2002 22:02:09 GMT Joel Sherrill [71a08543] * ChangeLog (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2002-10-04 Joel Sherrill * ... Fri, 04 Oct 2002 16:03:20 GMT Joel Sherrill [47c6985d] * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2002-10-04 Joel Sherrill * ... Thu, 22 Aug 2002 14:00:56 GMT Ralf Corsepius [97b4bc1] * cpukit/ChangeLog (modified) * cpukit/aclocal/prog-gnat.m4 (added) * cpukit/configure.ac (modified) 2002-08-22 Ralf Corsepius * ... Tue, 20 Aug 2002 23:51:08 GMT Ralf Corsepius [310fee6] * cpukit/ChangeLog (modified) * cpukit/aclocal/bsp-alias.m4 (deleted) 2002-08-20 Ralf Corsepius * ... Thu, 08 Aug 2002 16:49:20 GMT Joel Sherrill [52270c07] * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * scripts/ChangeLog (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/target-binutils.add (modified) * scripts/setup.def (modified) 2002-08-08 Joel Sherrill * ... Wed, 07 Aug 2002 07:48:04 GMT Ralf Corsepius [e336882] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/configure.ac (modified) 2002-08-07 Ralf Corsepius * ... Tue, 06 Aug 2002 10:09:33 GMT Ralf Corsepius [d3ed9703] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemsbsp.m4 (modified) 2002-08-06 Ralf Corsepius * ... Tue, 06 Aug 2002 07:31:26 GMT Ralf Corsepius [0aa6384] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) 2002-08-06 Ralf Corsepius * ... Wed, 31 Jul 2002 14:57:47 GMT Ralf Corsepius [532fad28] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/aclocal/canonicalize-tools.m4 (modified) * cpukit/automake/lib.am (modified) 2002-07-31 Ralf Corsepius * ... Wed, 31 Jul 2002 14:40:48 GMT Ralf Corsepius [4bfe135] * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2002-07-31 Ralf Corsepius * ... Wed, 31 Jul 2002 13:32:27 GMT Joel Sherrill [79b15c1d] * ChangeLog (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-cpu-subdirs.m4 (modified) 2002-07-31 Joel Sherrill * ... Mon, 22 Jul 2002 09:17:11 GMT Ralf Corsepius [14620166] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemsbsp.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/automake/compile.am (modified) 2002-07-22 Ralf Corsepius * ... Wed, 17 Jul 2002 22:28:20 GMT Ralf Corsepius [60f3702] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-bsps.m4 (modified) * cpukit/aclocal/check-cpu.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2002-07-17 Ralf Corsepius * ... Fri, 05 Jul 2002 16:13:07 GMT Ralf Corsepius [1b16e63c] * c/src/exec/ChangeLog (modified) * c/src/exec/aclocal/check-bsps.m4 (modified) * c/src/exec/aclocal/check-cpu.m4 (modified) * c/src/exec/aclocal/env-rtemscpu.m4 (modified) * c/src/exec/aclocal/rtems-top.m4 (modified) * c/src/exec/automake/multilib.am (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/check-bsps.m4 (modified) * cpukit/aclocal/check-cpu.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/automake/multilib.am (modified) 2002-07-05 Ralf Corsepius * ... Mon, 01 Jul 2002 12:14:08 GMT Ralf Corsepius [a9d97a8] * c/src/exec/ChangeLog (modified) * c/src/exec/aclocal/check-bsp-cache.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/check-bsp-cache.m4 (modified) 2002-07-01 Ralf Corsepius * ... Mon, 01 Jul 2002 09:20:43 GMT Ralf Corsepius [18ec075f] * c/src/exec/ChangeLog (modified) * c/src/exec/aclocal/enable-multiprocessing.m4 (modified) * c/src/exec/aclocal/prog-cc.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) 2002-07-01 Ralf Corsepius * ... Thu, 27 Jun 2002 12:18:24 GMT Ralf Corsepius [5261406] * c/src/exec/ChangeLog (modified) * c/src/exec/automake/compile.am (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/canonicalize-tools.m4 (modified) * cpukit/aclocal/prog-ccas.m4 (added) * cpukit/automake/compile.am (modified) 2002-06-27 Ralf Corsepius * ... Wed, 26 Jun 2002 10:56:24 GMT Ralf Corsepius [27f9f12] * c/src/exec/ChangeLog (modified) * c/src/exec/aclocal/check-multiprocessing.m4 (modified) * c/src/exec/aclocal/enable-multiprocessing.m4 (modified) * c/src/exec/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/check-multiprocessing.m4 (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/configure.ac (modified) 2002-06-26 Ralf Corsepius * ... Mon, 17 Jun 2002 08:52:47 GMT Ralf Corsepius [ed8ec1c] * c/src/exec/aclocal/bsp-alias.m4 (added) * c/src/exec/aclocal/canonical-host.m4 (added) * c/src/exec/aclocal/canonical-target-name.m4 (added) * c/src/exec/aclocal/canonicalize-tools.m4 (added) * c/src/exec/aclocal/check-bsp-cache.m4 (added) * c/src/exec/aclocal/check-bsps.m4 (added) * c/src/exec/aclocal/check-cpu.m4 (added) * c/src/exec/aclocal/check-itron.m4 (added) * c/src/exec/aclocal/check-multiprocessing.m4 (added) * c/src/exec/aclocal/check-networking.m4 (added) * c/src/exec/aclocal/check-newlib.m4 (added) * c/src/exec/aclocal/check-posix.m4 (added) * c/src/exec/aclocal/check-tool.m4 (added) * c/src/exec/aclocal/enable-bare.m4 (added) * c/src/exec/aclocal/enable-inlines.m4 (added) * c/src/exec/aclocal/enable-itron.m4 (added) * c/src/exec/aclocal/enable-multiprocessing.m4 (added) * c/src/exec/aclocal/enable-networking.m4 (added) * c/src/exec/aclocal/enable-posix.m4 (added) * c/src/exec/aclocal/enable-rtemsbsp.m4 (added) * c/src/exec/aclocal/env-rtemsbsp.m4 (added) * c/src/exec/aclocal/env-rtemscpu.m4 (added) * c/src/exec/aclocal/gcc-pipe.m4 (added) * c/src/exec/aclocal/gcc-specs.m4 (added) * c/src/exec/aclocal/multi.m4 (added) * c/src/exec/aclocal/multilib.m4 (added) * c/src/exec/aclocal/prog-cc.m4 (added) * c/src/exec/aclocal/project-root.m4 (added) * c/src/exec/aclocal/rtems-cpu-subdirs.m4 (added) * c/src/exec/aclocal/rtems-debug.m4 (added) * c/src/exec/aclocal/rtems-top.m4 (added) * c/src/exec/aclocal/subdirs.m4 (added) * c/src/exec/aclocal/sysv-ipc.m4 (added) * c/src/exec/aclocal/tool-paths.m4 (added) * c/src/exec/aclocal/version.m4 (added) * cpukit/aclocal/bsp-alias.m4 (added) * cpukit/aclocal/canonical-host.m4 (added) * cpukit/aclocal/canonical-target-name.m4 (added) * cpukit/aclocal/canonicalize-tools.m4 (added) * cpukit/aclocal/check-bsp-cache.m4 (added) * cpukit/aclocal/check-bsps.m4 (added) * cpukit/aclocal/check-cpu.m4 (added) * cpukit/aclocal/check-itron.m4 (added) * cpukit/aclocal/check-multiprocessing.m4 (added) * cpukit/aclocal/check-networking.m4 (added) * cpukit/aclocal/check-newlib.m4 (added) * cpukit/aclocal/check-posix.m4 (added) * cpukit/aclocal/check-tool.m4 (added) * cpukit/aclocal/enable-bare.m4 (added) * cpukit/aclocal/enable-inlines.m4 (added) * cpukit/aclocal/enable-itron.m4 (added) * cpukit/aclocal/enable-multiprocessing.m4 (added) * cpukit/aclocal/enable-networking.m4 (added) * cpukit/aclocal/enable-posix.m4 (added) * cpukit/aclocal/enable-rtemsbsp.m4 (added) * cpukit/aclocal/env-rtemsbsp.m4 (added) * cpukit/aclocal/env-rtemscpu.m4 (added) * cpukit/aclocal/gcc-pipe.m4 (added) * cpukit/aclocal/gcc-specs.m4 (added) * cpukit/aclocal/multi.m4 (added) * cpukit/aclocal/multilib.m4 (added) * cpukit/aclocal/prog-cc.m4 (added) * cpukit/aclocal/rtems-cpu-subdirs.m4 (added) * cpukit/aclocal/rtems-debug.m4 (added) * cpukit/aclocal/rtems-top.m4 (added) * cpukit/aclocal/sysv-ipc.m4 (added) * cpukit/aclocal/tool-paths.m4 (added) * cpukit/aclocal/version.m4 (added) 2002-06-17 Ralf Corsepius * ...
